How to use writefile() method ( using kernel32.dll for reading and writing) at PCside in MSP430 device using C# Donet, please suggest me how to implement.
Hello Prasad,
Can you please give us more information on the USB class (CDC, HID, MSC) you are interested in knowing about? What operating system and MSP430 device are you working with? What issue are you trying to solve?
In regards to MSP430USB drivers, the CDC interface is the only device class that requires a specialized USB driver that we package with the MSP430USBDevelopersPackage. There are two documents that explain how to run the examples included in the Developers Package as well as a Programmer's guide and each document will tell you how the CDC driver is installed on the host side.
All of the examples in MSP430USBDevelopersPackage have been written in C and compiled using Code Composer Studio and/or IAR IDEs.
Arthi Bhat
Hello Prasad,
The MSP430USBDevelopersPackage contains all the java source code used in creating the HidDemo tool that interfaces with HID USB class.
The java source files can be found in the latest developers package in the following directory: ../MSP430USBDevelopersPackage_5_00_01/Host_USB_Software/Java_HID_Demo/Windows. The older versions of the Developers package also contains the code for the tool but it is in a different directory.
The .dll files were created from the source code that is part of the java source files. The 'release_notes.html' file has instructions on how to run and compile the tool and other pertinent information.
Arthi
Hi Arthi Bhat,
Thank you for you support.
Do you sample code in C# DotNet for USD communication and bootlooder(Firmware upgrade) for MSP430F6638 Device.
Prasad Marri.
