I try build a customer Bootloader.
I need build application code and put it in a dedicate segment address. Code files should use .BIN.
I will not use BSL API, just coding by hand.
I will put two set code in different address, and bootloader can controlled to run one of them at one time.
If any sample can found?I think it should be include how to modify .icf, how re-write vector table, how run code which saved in different segment address.
