Part Number: MSP-EXP432P401R
Hello!
I'm trying to run an example code from fatsd_MSP_EXP432P401R_TI_MSP432P401R to write a file to the sdhc card. I tried different connection configurations between the board and sd card. The initialization seems to finish successfully. However, all the time while trying to create a new file I get the same answer:
Creating a new file "fat:0:input.txt"...Error: "fat:0:input.txt" could not be created.
Please check the Getting Started Guide if additional jumpers are necessary.
Aborting..."
Very similar conditions to this issue were previously described here https://e2e.ti.com/support/embedded/tirtos/f/355/t/470752?tisearch=e2e-sitesearch&keymatch=sdhc%20msp432 with the only difference that changing wires doesn't change anything. I will appreciate any advise from your side.
Thanks!
