Other Parts Discussed in Thread: CC3100
for the below code i have to
1.find Identify the code that helps in establishing connection over SMTP.
2.Modify the code to trigger E-mail application based upon external analog input.
so please help me to find out this two question's answer.
* main.c - sample application to send email
* Application Name - Email
* Application Overview - This sample application demonstrates how CC3100
* can be used to send an email over SMTP. The application
* configures CC3100 to connect w/ an SMTP server and sends
* email to it. SMTP server forwards it to the recipient's
* email-server and the recipient receives the email from
* his email-server using IMAP/POP3 and/or other proprietary
* protocol.
* Application Details - processors.wiki.ti.com/.../CC31xx_Email_Demo_Application
* doc\examples\email.pdf
#include "email.h"
#include "config.h"
#include "sl_common.h"
#define APPLICATION_VERSION "1.2.0"
#define SL_STOP_TIMEOUT 0xFF
* GLOBAL VARIABLES -- Start
_u32 g_Status = 0;
* GLOBAL VARIABLES -- End
* STATIC FUNCTION DEFINITIONS -- Start
static _i32 establishConnectionWithAP();
static _i32 disconnectFromAP();
static _i32 configureSimpleLinkToDefaultState();
static _i32 initializeAppVariables();
static void displayBanner();
static _i32 setEmail();
static _i32 sendEmail();
* STATIC FUNCTION DEFINITIONS -- End
* ASYNCHRONOUS EVENT HANDLERS -- Start
\brief This function handles WLAN events
\param[in] pWlanEvent is the event passed to the handler
\return None
\note
\warning
void SimpleLinkWlanEventHandler(SlWlanEvent_t *pWlanEvent)
if(pWlanEvent == NULL)
CLI_Write(" [WLAN EVENT] NULL Pointer Error \n\r");
return;
switch(pWlanEvent->Event)
case SL_WLAN_CONNECT_EVENT:
SET_STATUS_BIT(g_Status, STATUS_BIT_CONNECTION);
* Information about the connected AP (like name, MAC etc.) will be
* available in 'slWlanConnectAsyncResponse_t' - Applications
* can use it if required
* slWlanConnectAsyncResponse_t *pEventData = NULL;
* pEventData = &pWlanEvent->EventData.STAandP2PModeWlanConnected;
break;
case SL_WLAN_DISCONNECT_EVENT:
slWlanConnectAsyncResponse_t* pEventData = NULL;
CLR_STATUS_BIT(g_Status, STATUS_BIT_CONNECTION);
CLR_STATUS_BIT(g_Status, STATUS_BIT_IP_ACQUIRED);
pEventData = &pWlanEvent->EventData.STAandP2PModeDisconnected;
/* If the user has initiated 'Disconnect' request, 'reason_code' is SL_USER_INITIATED_DISCONNECTION */
if(SL_WLAN_DISCONNECT_USER_INITIATED_DISCONNECTION == pEventData->reason_code)
CLI_Write(" Device disconnected from the AP on application's request \n\r");
else
CLI_Write(" Device disconnected from the AP on an ERROR..!! \n\r");
break;
default:
CLI_Write(" [WLAN EVENT] Unexpected event \n\r");
break;
\brief This function handles events for IP address acquisition via DHCP
indication
\param[in] pNetAppEvent is the event passed to the handler
\return None
\note
\warning
void SimpleLinkNetAppEventHandler(SlNetAppEvent_t *pNetAppEvent)
if(pNetAppEvent == NULL)
CLI_Write(" [NETAPP EVENT] NULL Pointer Error \n\r");
return;
switch(pNetAppEvent->Event)
case SL_NETAPP_IPV4_IPACQUIRED_EVENT:
SET_STATUS_BIT(g_Status, STATUS_BIT_IP_ACQUIRED);
* Information about the connected AP's IP, gateway, DNS etc.
* will be available in 'SlIpV4AcquiredAsync_t' - Applications
* SlIpV4AcquiredAsync_t *pEventData = NULL;
* pEventData = &pNetAppEvent->EventData.ipAcquiredV4;
* <gateway_ip> = pEventData->gateway;
break;
default:
CLI_Write(" [NETAPP EVENT] Unexpected event \n\r");
break;
\brief This function handles callback for the HTTP server events
\param[in] pHttpEvent - Contains the relevant event information
\param[in] pHttpResponse - Should be filled by the user with the
relevant response information
\return None
\note
\warning
void SimpleLinkHttpServerCallback(SlHttpServerEvent_t *pHttpEvent,
SlHttpServerResponse_t *pHttpResponse)
* This application doesn't work with HTTP server - Hence these
* events are not handled/expected here
CLI_Write(" [HTTP EVENT] Unexpected event \n\r");
\brief This function handles general error events indication
\param[in] pDevEvent is the event passed to the handler
\return None
void SimpleLinkGeneralEventHandler(SlDeviceEvent_t *pDevEvent)
* Most of the general errors are not FATAL are are to be handled
* appropriately by the application
CLI_Write(" [GENERAL EVENT] \n\r");
\brief This function handles socket events indication
\param[in] pSock is the event passed to the handler
\return None
void SimpleLinkSockEventHandler(SlSockEvent_t *pSock)
if(pSock == NULL)
CLI_Write(" [SOCK EVENT] NULL Pointer Error \n\r");
return;
switch( pSock->Event )
case SL_SOCKET_TX_FAILED_EVENT:
* TX Failed
* Information about the socket descriptor and status will be
* available in 'SlSockEventData_t' - Applications can use it if
* required
* SlSockEventData_u *pEventData = NULL;
* pEventData = & pSock->socketAsyncEvent;
switch( pSock->socketAsyncEvent.SockTxFailData.status )
case SL_ECLOSE:
CLI_Write(" [SOCK EVENT] Close socket operation failed to transmit all queued packets\n\r");
break;
default:
CLI_Write(" [SOCK EVENT] Unexpected event \n\r");
break;
break;
default:
break;
* ASYNCHRONOUS EVENT HANDLERS -- End
* Application's entry point
int main(int argc, char** argv)
_i32 retVal = -1;
retVal = initializeAppVariables();
ASSERT_ON_ERROR(retVal);
/* Stop WDT and initialize the system-clock of the MCU */
stopWDT();
initClk();
/* Configure command line interface */
CLI_Configure();
displayBanner();
* Following function configures the device to default state by cleaning
* the persistent settings stored in NVMEM (viz. connection profiles &
* policies, power policy etc)
* Applications may choose to skip this step if the developer is sure
* that the device is in its default state at start of application
* Note that all profiles and persistent settings that were done on the
* device will be lost
retVal = configureSimpleLinkToDefaultState();
if(retVal < 0)
if (DEVICE_NOT_IN_STATION_MODE == retVal)
CLI_Write(" Failed to configure the device in its default state \n\r");
LOOP_FOREVER();
CLI_Write(" Device is configured in default state \n\r");
* Initializing the CC3100 device
* Assumption is that the device is configured in station mode already
* and it is in its default state
retVal = sl_Start(0, 0, 0);
if ((retVal < 0) ||
(ROLE_STA != retVal) )
CLI_Write(" Failed to start the device \n\r");
LOOP_FOREVER();
CLI_Write(" Device started as STATION \n\r");
/* Configure the source email */
retVal = setEmail();
if(retVal < 0)
LOOP_FOREVER();
/* Connecting to WLAN AP */
retVal = establishConnectionWithAP();
if(retVal < 0)
CLI_Write(" Failed to establish connection w/ an AP \n\r");
LOOP_FOREVER();
CLI_Write(" Connection established w/ AP and IP is acquired \n\r");
/* Configure and send the email */
CLI_Write(" Sending email... \n\r");
retVal = sendEmail();
if (retVal < 0)
CLI_Write(" Device couldn't send the email \n\r");
LOOP_FOREVER();
else
CLI_Write(" Email Sent successfully \n\r");
/* Disconnect from AP */
retVal = disconnectFromAP();
if(retVal < 0)
CLI_Write(" Failed to disconnect from the AP \n\r");
LOOP_FOREVER();
retVal = sl_Stop(SL_STOP_TIMEOUT);
if(retVal < 0)
LOOP_FOREVER();
return 0;
\brief This function configures the source email using parameters defined
in "config.h" file
\param[in] none
\return none
\note
\warning
_i32 retVal = -1;
SlNetAppSourceEmail_t sourceEmailId = {0};
SlNetAppSourcePassword_t sourceEmailPwd = {0};
SlNetAppEmailOpt_t eMailServerSetting = {0};
pal_Memcpy(sourceEmailId.Username,USER,pal_Strlen(USER)+1);
retVal = sl_NetAppEmailSet(NETAPP_SOURCE_EMAIL,pal_Strlen(USER)+1,
(_u8*)&sourceEmailId);
pal_Memcpy(sourceEmailPwd.Password,PASS,pal_Strlen(PASS)+1);
retVal = sl_NetAppEmailSet(NETAPP_PASSWORD,pal_Strlen(PASS)+1,
(_u8*)&sourceEmailPwd);
eMailServerSetting.Family = AF_INET;
eMailServerSetting.Port = GMAIL_HOST_PORT;
eMailServerSetting.Ip = SL_IPV4_VAL(74,125,129,108);
eMailServerSetting.SecurityMethod = SL_SO_SEC_METHOD_SSLv3_TLSV1_2;
//we changed SL_SO_SEC_METHOD_ SSLV3 with SL_SO_SEC_METHOD_SSLv3_TLSV1_2
eMailServerSetting.SecurityCypher = SL_SEC_MASK_TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA256;
//we changed SL_SEC_MASK_SSL_RSA_WITH_RC4_128_MD5 with SL_SEC_MASK_TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA256
// eMailServerSetting.SecurityMethod = SL_SO_SEC_METHOD_SSLV3;
// eMailServerSetting.SecurityCypher = SL_SEC_MASK_SSL_RSA_WITH_RC4_128_MD5;
retVal = sl_NetAppEmailSet(NETAPP_ADVANCED_OPT,sizeof(SlNetAppEmailOpt_t),
(_u8*)&eMailServerSetting);
return SUCCESS;
\brief Send the email to the preconfigured email ID
\param[in] none
\return 0 for success , -1 otherwise
\note
\warning
_i32 Status = -1;
Status = sl_NetAppEmailSet(NETAPP_DEST_EMAIL,
pal_Strlen(DESTINATION_EMAIL),
(_u8 *)DESTINATION_EMAIL);
ASSERT_ON_ERROR(Status);
Status = sl_NetAppEmailSet(NETAPP_SUBJECT,
pal_Strlen(EMAIL_SUBJECT),
(_u8 *)EMAIL_SUBJECT);
Status = sl_NetAppEmailSet(NETAPP_MESSAGE,
pal_Strlen(EMAIL_MESSAGE),
(_u8 *)EMAIL_MESSAGE);
Status = sl_NetAppEmailConnect();
Status = sl_NetAppEmailSend();
return SUCCESS;
\brief This function configure the SimpleLink device in its default state. It:
- Sets the mode to STATION
- Configures connection policy to Auto and AutoSmartConfig
- Deletes all the stored profiles
- Enables DHCP
- Disables Scan policy
- Sets Tx power to maximum
- Sets power policy to normal
- Unregisters mDNS services
- Remove all filters
\param[in] none
\return On success, zero is returned. On error, negative is returned
SlVersionFull ver = {0};
_WlanRxFilterOperationCommandBuff_t RxFilterIdMask = {0};
_u8 val = 1;
_u8 configOpt = 0;
_u8 configLen = 0;
_u8 power = 0;
_i32 retVal = -1;
_i32 mode = -1;
mode = sl_Start(0, 0, 0);
ASSERT_ON_ERROR(mode);
/* If the device is not in station-mode, try configuring it in station-mode */
if (ROLE_STA != mode)
if (ROLE_AP == mode)
/* If the device is in AP mode, we need to wait for this event before doing anything */
while(!IS_IP_ACQUIRED(g_Status)) { _SlNonOsMainLoopTask(); }
/* Switch to STA role and restart */
retVal = sl_WlanSetMode(ROLE_STA);
/* Check if the device is in station again */
if (ROLE_STA != retVal)
/* We don't want to proceed if the device is not coming up in station-mode */
ASSERT_ON_ERROR(DEVICE_NOT_IN_STATION_MODE);
/* Get the device's version-information */
configOpt = SL_DEVICE_GENERAL_VERSION;
configLen = sizeof(ver);
retVal = sl_DevGet(SL_DEVICE_GENERAL_CONFIGURATION, &configOpt, &configLen, (_u8 *)(&ver));
/* Set connection policy to Auto + SmartConfig (Device's default connection policy) */
retVal = sl_WlanPolicySet(SL_POLICY_CONNECTION, SL_CONNECTION_POLICY(1, 0, 0, 0, 1), NULL, 0);
/* Remove all profiles */
retVal = sl_WlanProfileDel(0xFF);
* Device in station-mode. Disconnect previous connection if any
* The function returns 0 if 'Disconnected done', negative number if already disconnected
* Wait for 'disconnection' event if 0 is returned, Ignore other return-codes
retVal = sl_WlanDisconnect();
if(0 == retVal)
/* Wait */
while(IS_CONNECTED(g_Status)) { _SlNonOsMainLoopTask(); }
/* Enable DHCP client*/
retVal = sl_NetCfgSet(SL_IPV4_STA_P2P_CL_DHCP_ENABLE,1,1,&val);
/* Disable scan */
configOpt = SL_SCAN_POLICY(0);
retVal = sl_WlanPolicySet(SL_POLICY_SCAN , configOpt, NULL, 0);
/* Set Tx power level for station mode
Number between 0-15, as dB offset from max power - 0 will set maximum power */
power = 0;
retVal = sl_WlanSet(SL_WLAN_CFG_GENERAL_PARAM_ID, WLAN_GENERAL_PARAM_OPT_STA_TX_POWER, 1, (_u8 *)&power);
/* Set PM policy to normal */
retVal = sl_WlanPolicySet(SL_POLICY_PM , SL_NORMAL_POLICY, NULL, 0);
/* Unregister mDNS services */
retVal = sl_NetAppMDNSUnRegisterService(0, 0);
/* Remove all 64 filters (8*8) */
pal_Memset(RxFilterIdMask.FilterIdMask, 0xFF, 8);
retVal = sl_WlanRxFilterSet(SL_REMOVE_RX_FILTER, (_u8 *)&RxFilterIdMask,
sizeof(_WlanRxFilterOperationCommandBuff_t));
return retVal; /* Success */
\brief Connecting to a WLAN Access point
This function connects to the required AP (SSID_NAME).
The function will return once we are connected and have acquired IP address
\param[in] None
\return 0 on success, negative error-code on error
\note
\warning If the WLAN connection fails or we don't acquire an IP address,
We will be stuck in this function forever.
SlSecParams_t secParams = {0};
_i32 retVal = 0;
secParams.Key = PASSKEY;
secParams.KeyLen = PASSKEY_LEN;
secParams.Type = SEC_TYPE;
retVal = sl_WlanConnect(SSID_NAME, pal_Strlen(SSID_NAME), 0, &secParams, 0);
/* Wait */
while((!IS_CONNECTED(g_Status)) || (!IS_IP_ACQUIRED(g_Status))) { _SlNonOsMainLoopTask(); }
return SUCCESS;
\brief Disconnecting from a WLAN Access point
This function disconnects from the connected AP
\param[in] None
\return none
\note
\warning If the WLAN disconnection fails, we will be stuck in this function forever.
_i32 retVal = -1;
if(0 == retVal)
/* Wait */
return SUCCESS;
\brief This function initializes the application variables
\param[in] None
g_Status = 0;
return SUCCESS;
\brief This function displays the application's banner
\param None
\return None
CLI_Write("\n\r\n\r");
CLI_Write(" Email application - Version ");
CLI_Write(APPLICATION_VERSION);
CLI_Write("\n\r*******************************************************************************\n\r");
