We are using the TDA2X Vision SDK (2.5)
We have created a use case as follows:
NullSrc -> Alg_Plugin(DSP1) ->Display
We are feeding static images using null source link to DSP core for processing and then to display.
We want to send a command from Algorithm Plugin (DSP) to previous link i.e. Null Source (IPU_0).
We tried using the link api System_sendLinkCmd to pass the command but as the algorithm is executing on DSP there is IPC_Out and IPC_In links in picture.
We are not able to pass command to previuos link (IPU_0 Core).
Is there any mechanism wherein we can pass data or command to previous links (different core) in existing Vision SDK frame work.
Swapnil Nagare
