I am a phd student and I am looking for an isolated GaN FET driver. Could you please let me know whether you have any isolated GaN driver or any related GaN driver?
thanks
thanks
Hi Mohammad,
The following link will show you our portfolio of GaN-specific gate drivers: http://www.ti.com/lsds/ti/power-management/gan-fet-drivers-products.page
For our isolated drivers, please take a look at this location: http://www.ti.com/lsds/ti/isolation/isolated-gate-driver-products.page
One application with isolation and GaN on the same board is the LMG3410-HB-EVM, which uses the ISO7831 isolator and LMG3410 GaN power stage.
I hope this post helps answer your question. If it has, please press the "Verify Answer" button below.
- Daniel
Thanks for your reply. I want to use EPC2034 GaN FETs. As I see your proposed drivers, the GaN FETs and drivers are integrated to each other. Could you please let me know whether you can propose any similar isolated GaN driver for EPC2034 or you have integrated products which use GaN FET similar to EPC2034 power rate. Thanks for your consideration.
Hi Mohammad,
we currently offer both half-bridge and low-side FET drivers that are optimized for GaN.
Those are respectively LMG1205 and LM5114.
Depending on what you are trying to accomplish you might want to use the digital isolator or not : the LMG1205 already has a level shifter to drive the high side FET.
Alberto
Thanks for your reply. I am working on zero voltage switching converters. As I read about GaN Fets, there is not a body diode across drain-source of this Fet. Hence, I need to put a fast recovery body diode across the drain-source of GaN. Could you please let me know whether there is a GaN diode or I should use SiC diodes. Thanks for your consideration
I am designing the PCB of LMG1205YFXR. I cannot find its schematic and footprint in TI libraries. Could please let me know whether there is any footprint for it and if there exists, send me its footprint and schematic, please.
Mohammad
