Dears:
Could you kindly help to check the below schematic?
Is there any requirement of time sequence about SMPS and LDO after power on?
Thanks a lot!
Best regards
Luck Wu
Dears:
Thanks a lot!
Best regards
Luck Wu
Luck,
The configurations can be found in the user guide: http://www.ti.com/lit/pdf/swcu175
Figure 1 will show the default voltages for the 0x87 OTP that you are using. Sections 4 - 6 will show you the rest of the default settings, including the power sequencing.
Please let me know if you need anything else.
Nastasha
