customr evaluate TPS23756 encounter some issue of VC voltage when power on,detail as below picture,pls help provide some suggestion, SCH as attachedPOE SCH.pdf
Hi User,
The VC voltage will dip when the converter starts switching due to the gate cap of the primary FET.
What is the voltage rating of the 10uF cap? If too low, the DC bias will make the effective capacitance much lower. The cap should be increased to 22uF if the voltage is drooping too much such that the DCDC shutdowns.
Darwin
