Are there any automotive lineup of window comparator for monitoring 1.35V supply without resistance?
I found that the TPS3702-Q1 however, this device couldn't monitor 1.35V supply.
Ryuji Asaka
Ryuji Asaka
HI Asaka-san,
Thank you for your inquiry.
These are programmed and trimmed at the factory. The initial releases were for common voltages. So many other voltage options are possible. I recommend you please contact your local TI Sales or Distribution partner to discuss. I believe the minimum step size is 50mV so setting up a 1.35V rail monitor version is within the scope of the current design.
