Other Parts Discussed in Thread: CC3220SF
Hello
I am trying the provisioning sample on CC3220SF - LAUNCHXL,
SL_WLAN_EVENT_DISCONNECT is raised in SimpleLinkWlanEventHandler.
Reason Code indicates "9".
I assume that this is "SL_WLAN_DISCONNECT_STA_NOT_AUTH" in wlan.h
I found it, but I do not know the meaning of this error and how to deal with it.
Which document describes this workaround?
The timing that occurs is the next step.
1. First Provising --- Success
2. Power ON Reset --- Reset Button
3.Second ...
SimpleLinkWlanEventHandler SL_WLAN_EVENT_CONNECT
SimpleLinkNetAppEventHandler IP Acquired
SimpleLinkWlanEventHandler SL_WLAN_EVENT_DISCONNECT
([Event] STA disconnected from AP (Reason Code = 9)
I will reconnect after this, so is there no problem?CCS: Version: 8.1.0.00011
simplelink_cc32xx_sdk_2_10_00_04
Thank you.
H.Wt
