HI,
I have developed CC1310 base Concentrator with 2 layer board. Antenna, I used is the same as LAUNCHPAD one for 868Mhz.
I loaded concentrator software from TI example code into this design and 4 sensor nodes I used LAUNCHPAD.
Everything works but range of communication is about 20m compared to LAUNCHPAD based sensor-concentrator 200m.
Probably antenna should is unmatched? How I can easily match this antenna without complex RF equipment?
I can see LAUNCHPAD has left C24, C58 & R12 for matching. Right now there is no C24 & C58 but R12=1.8pF
What component you would recommend for this PI filter to go into matching direction?
