DRA829V: Connection between DRA829 and PCIe SW(PI7C9X3G1632GP) [Again]
Part Number: DRA829V
Other Parts Discussed in Thread: DRA829, , TDA4VM, DRA821, AM69A
Hi experts,
*This is a re-post as the original thread is completely unresponsive.
We want to connect a DRA829 with a PCIe SW(PI7C9X3G1632GP), but we cannot see the downstream of the PCIe SW and an error occurs.
Also tried to connect DRA829 with another PCIe SW, but result is similarly.
Q1:Is there something I need to configure in the device-tree of the DRA829? If you have any example settings, please let us know.
Q2:Could you please tell me which PCIe SWs TI have tested the connection with the DRA829EVM and their configurations?
We have tested connections between the DRA829EVM and several different PCIe SWs, but we get errors in the downstream port configuration on all PCIe SWs.
we are wondering if it is possible to connect PCIe SW to DRA829.
O.H
  • Hi O.H,
    Apologies for the delayed response. I saw from the previous thread that there is suspicion that the issue being seen is related to: https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1215795/processor-sdk-j721e-pcie-bridge-linux-kernel-panic
    Could you specify if Takumi or Paulo are posting on your behalf? I would like to know which logs are related to the issue that you are facing in particular, since there is always a possibility that the issue has similar behaviors, but the root cause of the issue is different.
    In regards to Q1 and Q2, personally I do not have history on whether there has been internal testing with a PCIe switch device connected as EP. Essentially, connecting the DRA829V to a PCIe backplane, which is similar to the example documented here except instead of DRA829V acting as PCIe backplane, a different device is the backplane: https://software-dl.ti.com/jacinto7/esd/processor-sdk-linux-jacinto7/08_06_01_02/exports/docs/linux/Foundational_Components/Kernel/Kernel_Drivers/PCIe/PCIe_Backplane.html . I can check on this and get back to you in the next two days at the latest on whether we have done internal testing in the past with a PCIe switch device.
    Takuma
  • Hi Takuma-san,
    Thank you for your support.
    I am posting on behalf of Takumi.
    In order to investigate Takumi's case accurately, I can ask Takumi to explain the latest situation and issues in this thread.
    How about the above?
    If the above is fine, I would be grateful if you could point out any additional information you require.
    (For example, "the full kernel crash log, including all the logs leading up to the kernel crash")
    I understood. It would be helpful if you could let us know the results as soon as you know them.
    O.H
  • Hi O.H,
    Got it, so I would treat Paulo's logs from the separate E2E as a similar, but 'possibly' different issue. I found that Takumi-san mentions posting to another E2E thread: https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1209929/dra829v-pcie-rescan-fails
    Based on Takumi-san's old post, I assume that the board is able to initialize the PCIe link to up during boot, and doing a rescan after the Linux kernel has fully booted up causes the error - but is this understanding correct?
    And yes, the full kernel crash log including the logs leading up to the kernel crash would be nice, and additionally, if you could post the boot logs from the "dmesg" command, that would be helpful to determine whether the issue has the same behavior as Paulo or Johnson from the other threads.
    Takuma
  • Hi O.H,
    On top of the crash logs and boot logs, could you also post output from "lspci" if possible? I assume that Linux was able to initialize so all Linux commandline tools are available.
    Takuma
  • Hi O.H, and Takuma-san
    In the custom board, the PCIeSW is reset at startup, so the reset is released with GPIO.
    Then when I run the scan I get an error.
    Expand logs and lspci results when using a custom board.
    U-Boot SPL 2021.01-g44a87e3ab8 (Sep 06 2022 - 07:31:49 +0000)
    Model: Texas Instruments K3 J721E SoC
    EEPROM not available at 0x50, trying to read at 0x51
    Reading on-board EEPROM at 0x51 failed 1
    Board: J721EX-PM1-SOM rev E2
    SYSFW ABI: 3.1 (firmware rev 0x0016 '22.1.1--v2022.01 (Terrific Llam')
    i2c_write: error waiting for data ACK (status=0x116)
    read error from device: 41c8639c register: x!
    Trying to boot from MMC2
    Starting ATF on ARM64 core...
    NOTICE:  BL31: v2.5(release):08.03.00.002-dirty
    NOTICE:  BL31: Built : 08:27:01, Jun 28 2022
    U-Boot SPL 2021.01-g44a87e3ab8 (Mar 29 2023 - 04:13:35 +0000)
    U-Boot 2021.01-g44a87e3ab8 (Mar 29 2023 - 04:13:35 +0000)
    SoC:   J721E SR1.1
    DRAM:  4 GiB
    Flash: 0 Bytes
    MMC:   sdhci@4f80000: 0, sdhci@4fb0000: 1
    In:    serial@2800000
    Out:   serial@2800000
    Err:   serial@2800000
    am65_cpsw_nuss ethernet@46000000: K3 CPSW: nuss_ver: 0x6BA00101 cpsw_ver: 0x6BA80100 ale_ver: 0x00293904 Ports:1 mdio_freq:1000000
    Net:   eth0: ethernet@46000000port@1
    Hit any key to stop autoboot:  2  1  0
    pca953x gpio@22: Error reading output register
    switch to partitions #0, OK
    mmc1 is current device
    SD/MMC found on device 1
    Failed to load 'boot.scr'
    Failed to load 'uEnv.txt'
    19413504 bytes read in 809 ms (22.9 MiB/s)
    46201 bytes read in 11 ms (4 MiB/s)
       Loading Device Tree to 000000008fef1000, end 000000008fffffff ... OK
    Starting kernel ...
    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
    [    0.000000] Linux version 5.10.100-g7a7a3af903 (oe-user@oe-host) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #1 SMP PREEMPT Tue Apr 11 00:59:16 UTC 2023
    [    0.000000] Machine model: Texas Instruments K3 J721E SoC
    [    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
    [    0.000000] printk: bootconsole [ns16550a0] enabled
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000ac000000, size 2 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-virtual-eth-queues@ac000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000ac200000, size 30 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-virtual-eth-buffers@ac200000, compatible id shared-dma-pool
    [    0.000000] Zone ranges:
    [    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
    [    0.000000]   DMA32    empty
    [    0.000000]   Normal   [mem 0x0000000100000000-0x00000008ffffffff]
    [    0.000000] Movable zone start for each node
    [    0.000000] Early memory node ranges
    [    0.000000]   node   0: [mem 0x0000000080000000-0x000000009e7fffff]
    [    0.000000]   node   0: [mem 0x000000009e800000-0x000000009fffffff]
    [    0.000000]   node   0: [mem 0x00000000a0000000-0x00000000a9ffffff]
    [    0.000000]   node   0: [mem 0x00000000aa000000-0x00000000abbfffff]
    [    0.000000]   node   0: [mem 0x00000000abc00000-0x00000000abffffff]
    [    0.000000]   node   0: [mem 0x00000000ac000000-0x00000000adffffff]
    [    0.000000]   node   0: [mem 0x00000000ae000000-0x00000000ffffffff]
    [    0.000000]   node   0: [mem 0x0000000880000000-0x00000008ffffffff]
    [    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff]
    [    0.000000] cma: Reserved 512 MiB at 0x00000000e0000000
    [    0.000000] psci: probing for conduit method from DT.
    [    0.000000] psci: PSCIv1.1 detected in firmware.
    [    0.000000] psci: Using standard PSCI v0.2 function IDs
    [    0.000000] psci: Trusted OS migration not required
    [    0.000000] psci: SMC Calling Convention v1.2
    [    0.000000] percpu: Embedded 2 pages/cpu s49880 r8192 d73000 u131072
    [    0.000000] Detected PIPT I-cache on CPU0
    [    0.000000] CPU features: detected: GIC system register CPU interface
    [    0.000000] CPU features: detected: EL2 vector hardening
    [    0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 65472
    [    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),1m(ospi.sysfw),256k(ospi.env.backup),57088k@8m(ospi.rootfs),256k(ospi.phypattern);47034000.hyperbus:512k(hbmc.tiboot3),2m(hbmc.tispl),4m(hbmc.u-boot),256k(hbmc.env),1m(hbmc.sysfw),-@8m(hbmc.rootfs) root=PARTUUID=de3fd043-02 rw rootfstype=ext4 rootwait
    [    0.000000] Dentry cache hash table entries: 524288 (order: 6, 4194304 bytes, linear)
    [    0.000000] Inode-cache hash table entries: 262144 (order: 5, 2097152 bytes, linear)
    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
    [    0.000000] software IO TLB: mapped [mem 0x00000000dc000000-0x00000000e0000000] (64MB)
    [    0.000000] Memory: 3486656K/4194304K available (10944K kernel code, 1294K rwdata, 4416K rodata, 1856K init, 765K bss, 183360K reserved, 524288K cma-reserved)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
    [    0.000000] rcu: 	RCU event tracing is enabled.
    [    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
    [    0.000000] 	Trampoline variant of Tasks RCU enabled.
    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    [    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
    [    0.000000] GICv3: 960 SPIs implemented
    [    0.000000] GICv3: 0 Extended SPIs implemented
    [    0.000000] GICv3: Distributor has no Range Selector support
    [    0.000000] GICv3: 16 PPIs implemented
    [    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
    [    0.000000] ITS [mem 0x01820000-0x0182ffff]
    [    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
    [    0.000000] ITS@0x0000000001820000: allocated 1048576 Devices @880800000 (flat, esz 8, psz 64K, shr 0)
    [    0.000000] ITS: using cache flushing for cmd queue
    [    0.000000] GICv3: using LPI property table @0x00000008800b0000
    [    0.000000] GIC: using cache flushing for LPI property table
    [    0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008800c0000
    [    0.000000] random: get_random_bytes called from start_kernel+0x31c/0x4c4 with crng_init=0
    [    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
    [    0.000002] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
    [    0.008301] Console: colour dummy device 80x25
    [    0.012862] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [    0.023532] pid_max: default: 32768 minimum: 301
    [    0.028279] LSM: Security Framework initializing
    [    0.033024] Mount-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
    [    0.040590] Mountpoint-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
    [    0.049533] rcu: Hierarchical SRCU implementation.
    [    0.054580] Platform MSI: msi-controller@1820000 domain created
    [    0.060715] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
    [    0.069982] EFI services will not be available.
    [    0.074726] smp: Bringing up secondary CPUs ...
    [    0.079969] Detected PIPT I-cache on CPU1
    [    0.079991] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
    [    0.080002] GICv3: CPU1: using allocated LPI pending table @0x00000008800d0000
    [    0.080038] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
    [    0.080085] smp: Brought up 1 node, 2 CPUs
    [    0.109430] SMP: Total of 2 processors activated.
    [    0.114235] CPU features: detected: 32-bit EL0 Support
    [    0.119490] CPU features: detected: CRC32 instructions
    [    0.133269] CPU: All CPU(s) started at EL2
    [    0.137464] alternatives: patching kernel code
    [    0.142464] devtmpfs: initialized
    [    0.148364] KASLR disabled due to lack of seed
    [    0.153015] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.162978] futex hash table entries: 512 (order: -1, 32768 bytes, linear)
    [    0.170601] pinctrl core: initialized pinctrl subsystem
    [    0.176176] DMI not present or invalid.
    [    0.180389] NET: Registered protocol family 16
    [    0.187774] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
    [    0.195076] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.203079] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.211377] thermal_sys: Registered thermal governor 'step_wise'
    [    0.211379] thermal_sys: Registered thermal governor 'power_allocator'
    [    0.217808] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.231450] ASID allocator initialised with 65536 entries
    [    0.248084] HugeTLB registered 16.0 GiB page size, pre-allocated 0 pages
    [    0.254952] HugeTLB registered 512 MiB page size, pre-allocated 0 pages
    [    0.261712] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.269697] cryptd: max_cpu_qlen set to 1000
    [    0.275639] k3-chipinfo 43000014.chipid: Family:J721E rev:SR2.0 JTAGID[0x1bb6402f] Detected
    [    0.284408] vsys_3v3: supplied by evm_12v0
    [    0.288787] vsys_5v0: supplied by evm_12v0
    [    0.293099] vdd_mmc1: supplied by vsys_3v3
    [    0.297625] iommu: Default domain type: Translated
    [    0.302752] SCSI subsystem initialized
    [    0.306787] mc: Linux media interface: v0.10
    [    0.311157] videodev: Linux video capture interface: v2.00
    [    0.316784] pps_core: LinuxPPS API ver. 1 registered
    [    0.321855] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.331192] PTP clock support registered
    [    0.335209] EDAC MC: Ver: 3.0.0
    [    0.338755] FPGA manager framework
    [    0.342266] Advanced Linux Sound Architecture Driver Initialized.
    [    0.348866] clocksource: Switched to clocksource arch_sys_counter
    [    0.355290] VFS: Disk quotas dquot_6.6.0
    [    0.359350] VFS: Dquot-cache hash table entries: 8192 (order 0, 65536 bytes)
    [    0.368999] NET: Registered protocol family 2
    [    0.373582] IP idents hash table entries: 65536 (order: 3, 524288 bytes, linear)
    [    0.382193] tcp_listen_portaddr_hash hash table entries: 4096 (order: 0, 65536 bytes, linear)
    [    0.390955] TCP established hash table entries: 32768 (order: 2, 262144 bytes, linear)
    [    0.399149] TCP bind hash table entries: 32768 (order: 3, 524288 bytes, linear)
    [    0.406950] TCP: Hash tables configured (established 32768 bind 32768)
    [    0.413698] UDP hash table entries: 2048 (order: 0, 65536 bytes, linear)
    [    0.420591] UDP-Lite hash table entries: 2048 (order: 0, 65536 bytes, linear)
    [    0.427974] NET: Registered protocol family 1
    [    0.432663] RPC: Registered named UNIX socket transport module.
    [    0.438725] RPC: Registered udp transport module.
    [    0.443529] RPC: Registered tcp transport module.
    [    0.448332] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.454916] PCI: CLS 0 bytes, default 64
    [    0.459248] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
    [    0.469446] Initialise system trusted keyrings
    [    0.474060] workingset: timestamp_bits=46 max_order=16 bucket_order=0
    [    0.482315] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.488532] NFS: Registering the id_resolver key type
    [    0.493749] Key type id_resolver registered
    [    0.498021] Key type id_legacy registered
    [    0.502139] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.508987] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    0.516623] 9p: Installing v9fs 9p2000 file system support
    [    0.542184] Key type asymmetric registered
    [    0.546370] Asymmetric key parser 'x509' registered
    [    0.551366] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
    [    0.558924] io scheduler mq-deadline registered
    [    0.563550] io scheduler kyber registered
    [    0.568632] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
    [    0.574792] pinctrl-single 11c000.pinctrl: 173 pins, size 692
    [    0.581906] switchtec: loaded.
    [    0.586021] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
    [    0.592283] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
    [    0.599882] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
    [    0.607840] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x00001faf)
    [    0.616836] arm-smmu-v3 36600000.iommu: allocated 524288 entries for cmdq
    [    0.625706] arm-smmu-v3 36600000.iommu: allocated 524288 entries for evtq
    [    0.633424] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to wired irqs
    [    0.645730] brd: module loaded
    [    0.651624] loop: module loaded
    [    0.655392] megasas: 07.714.04.00-rc1
    [    0.660609] tun: Universal TUN/TAP device driver, 1.6
    [    0.665986] igbvf: Intel(R) Gigabit Virtual Function Network Driver
    [    0.672397] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
    [    0.678472] sky2: driver version 1.30
    [    0.682625] VFIO - User Level meta-driver version: 0.3
    [    0.688236] i2c /dev entries driver
    [    0.692072] Error: Driver 'k3-soc-thermal' is already registered, aborting...
    [    0.699620] sdhci: Secure Digital Host Controller Interface driver
    [    0.705936] sdhci: Copyright(c) Pierre Ossman
    [    0.710580] sdhci-pltfm: SDHCI platform and OF driver helper
    [    0.716793] ledtrig-cpu: registered to indicate activity on CPUs
    [    0.723079] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    0.730124] optee: probing for conduit method.
    [    0.734680] optee: revision 3.12 (3d47a131)
    [    0.734916] optee: initialized driver
    [    0.743850] NET: Registered protocol family 17
    [    0.748460] 9pnet: Installing 9P2000 support
    [    0.752843] Key type dns_resolver registered
    [    0.757282] Loading compiled-in X.509 certificates
    [    0.766443] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
    [    0.772779] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
    [    0.780279] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0016 '22.1.1--v2022.01 (Terrific Llam')
    [    0.807654] random: fast init done
    [    0.817786] omap_i2c 2000000.i2c: bus 0 rev0.12 at 380 kHz
    [    0.823834] omap_i2c 2010000.i2c: bus 1 rev0.12 at 100 kHz
    [    0.829801] omap_i2c 2020000.i2c: bus 2 rev0.12 at 380 kHz
    [    0.835780] omap_i2c 2030000.i2c: bus 3 rev0.12 at 380 kHz
    [    0.841732] omap_i2c 2040000.i2c: bus 4 rev0.12 at 100 kHz
    [    0.847934] omap_i2c 2050000.i2c: bus 5 rev0.12 at 380 kHz
    [    0.854792] omap_i2c 2060000.i2c: bus 6 rev0.12 at 100 kHz
    [    0.860574] ti-sci-intr bus@100000:bus@28380000:interrupt-controller2: Interrupt Router 137 domain created
    [    0.870547] ti-sci-intr bus@100000:interrupt-controller0: Interrupt Router 131 domain created
    [    0.879354] ti-sci-intr bus@100000:main-navss:interrupt-controller1: Interrupt Router 213 domain created
    [    0.889200] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created
    [    0.910485] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    0.918169] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    0.926450] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    0.934735] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    1.945071] j721e-pcie 2900000.pcie: PCI host bridge to bus 0000:00
    [    1.951495] pci_bus 0000:00: root bus resource [bus 00-ff]
    [    1.957111] pci_bus 0000:00: root bus resource [io  0x0000-0xffff] (bus address [0x10001000-0x10010fff])
    [    1.966802] pci_bus 0000:00: root bus resource [mem 0x10011000-0x17ffffff]
    [    1.973830] pci_bus 0000:00: child_bus_ext, ava0
    [    1.978546] pci_bus 0000:00: get slot end devfn 0
    [    1.983350] pci_bus 0000:00: vendor config
    [    1.987531] pci_bus 0000:00: before generic vendor read
    [    1.992870] pci_bus 0000:00: Read Vender ID l = 0xb00d104c
    [    1.998473] pci_bus 0000:00: vendor id 0xb00d104c
    [    2.003366] pci_bus 0000:00: pci_alloc_devt end
    [    2.007994] pci_bus 0000:00: set of node  end
    [    2.012463] pci 0000:00:00.0: [104c:b00d] type 01 class 0x060400
    [    2.018602] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
    [    2.028472] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
    [    2.038353] pci_bus 0000:00: set dev end
    [    2.042358] pci_bus 0000:00: scan device end
    [    2.046724] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0xe8 may corrupt adjacent RW1C bits
    [    2.056683] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits
    [    2.066650] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x92 may corrupt adjacent RW1C bits
    [    2.076613] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0xb2 may corrupt adjacent RW1C bits
    [    2.086598] pci 0000:00:00.0: supports D1
    [    2.090692] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
    [    2.096564] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x84 may corrupt adjacent RW1C bits
    [    2.106607] pci_bus 0000:00: child_bus_ext devfn=0,nr_devs=1
    [    2.112471] pci_bus 0000:00: get slot end devfn 8
    [    2.117275] pci_bus 0000:00: vendor config
    [    2.121457] pci_bus 0000:00: before generic vendor read
    [    2.126794] pci_bus 0000:00: child_bus_ext devfn=8,nr_devs=0
    [    2.132600] pci_bus 0000:00: get slot end devfn 16
    [    2.137494] pci_bus 0000:00: vendor config
    [    2.141676] pci_bus 0000:00: before generic vendor read
    [    2.147013] pci_bus 0000:00: child_bus_ext devfn=16,nr_devs=0
    [    2.152905] pci_bus 0000:00: get slot end devfn 24
    [    2.157797] pci_bus 0000:00: vendor config
    [    2.161979] pci_bus 0000:00: before generic vendor read
    [    2.167315] pci_bus 0000:00: child_bus_ext devfn=24,nr_devs=0
    [    2.173208] pci_bus 0000:00: get slot end devfn 32
    [    2.178100] pci_bus 0000:00: vendor config
    [    2.182281] pci_bus 0000:00: before generic vendor read
    [    2.187618] pci_bus 0000:00: child_bus_ext devfn=32,nr_devs=0
    [    2.193510] pci_bus 0000:00: get slot end devfn 40
    [    2.198403] pci_bus 0000:00: vendor config
    [    2.202585] pci_bus 0000:00: before generic vendor read
    [    2.207922] pci_bus 0000:00: child_bus_ext devfn=40,nr_devs=0
    [    2.213814] pci_bus 0000:00: get slot end devfn 48
    [    2.218706] pci_bus 0000:00: vendor config
    [    2.222888] pci_bus 0000:00: before generic vendor read
    [    2.228224] pci_bus 0000:00: child_bus_ext devfn=48,nr_devs=0
    [    2.234116] pci_bus 0000:00: get slot end devfn 56
    [    2.239008] pci_bus 0000:00: vendor config
    [    2.243189] pci_bus 0000:00: before generic vendor read
    [    2.248526] pci_bus 0000:00: child_bus_ext devfn=56,nr_devs=0
    [    2.254418] pci_bus 0000:00: get slot end devfn 64
    [    2.259312] pci_bus 0000:00: vendor config
    [    2.263493] pci_bus 0000:00: before generic vendor read
    [    2.268831] pci_bus 0000:00: child_bus_ext devfn=64,nr_devs=0
    [    2.274723] pci_bus 0000:00: get slot end devfn 72
    [    2.279614] pci_bus 0000:00: vendor config
    [    2.283796] pci_bus 0000:00: before generic vendor read
    [    2.289132] pci_bus 0000:00: child_bus_ext devfn=72,nr_devs=0
    [    2.295024] pci_bus 0000:00: get slot end devfn 80
    [    2.299916] pci_bus 0000:00: vendor config
    [    2.304097] pci_bus 0000:00: before generic vendor read
    [    2.309434] pci_bus 0000:00: child_bus_ext devfn=80,nr_devs=0
    [    2.315326] pci_bus 0000:00: get slot end devfn 88
    [    2.320219] pci_bus 0000:00: vendor config
    [    2.324401] pci_bus 0000:00: before generic vendor read
    [    2.329739] pci_bus 0000:00: child_bus_ext devfn=88,nr_devs=0
    [    2.335631] pci_bus 0000:00: get slot end devfn 96
    [    2.340523] pci_bus 0000:00: vendor config
    [    2.344704] pci_bus 0000:00: before generic vendor read
    [    2.350041] pci_bus 0000:00: child_bus_ext devfn=96,nr_devs=0
    [    2.355933] pci_bus 0000:00: get slot end devfn 104
    [    2.360914] pci_bus 0000:00: vendor config
    [    2.365095] pci_bus 0000:00: before generic vendor read
    [    2.370432] pci_bus 0000:00: child_bus_ext devfn=104,nr_devs=0
    [    2.376412] pci_bus 0000:00: get slot end devfn 112
    [    2.381395] pci_bus 0000:00: vendor config
    [    2.385576] pci_bus 0000:00: before generic vendor read
    [    2.390913] pci_bus 0000:00: child_bus_ext devfn=112,nr_devs=0
    [    2.396894] pci_bus 0000:00: get slot end devfn 120
    [    2.401874] pci_bus 0000:00: vendor config
    [    2.406056] pci_bus 0000:00: before generic vendor read
    [    2.411392] pci_bus 0000:00: child_bus_ext devfn=120,nr_devs=0
    [    2.417373] pci_bus 0000:00: get slot end devfn 128
    [    2.422355] pci_bus 0000:00: vendor config
    [    2.426536] pci_bus 0000:00: before generic vendor read
    [    2.431872] pci_bus 0000:00: child_bus_ext devfn=128,nr_devs=0
    [    2.437853] pci_bus 0000:00: get slot end devfn 136
    [    2.442836] pci_bus 0000:00: vendor config
    [    2.447018] pci_bus 0000:00: before generic vendor read
    [    2.452355] pci_bus 0000:00: child_bus_ext devfn=136,nr_devs=0
    [    2.458336] pci_bus 0000:00: get slot end devfn 144
    [    2.463316] pci_bus 0000:00: vendor config
    [    2.467497] pci_bus 0000:00: before generic vendor read
    [    2.472834] pci_bus 0000:00: child_bus_ext devfn=144,nr_devs=0
    [    2.478815] pci_bus 0000:00: get slot end devfn 152
    [    2.483796] pci_bus 0000:00: vendor config
    [    2.487977] pci_bus 0000:00: before generic vendor read
    [    2.493313] pci_bus 0000:00: child_bus_ext devfn=152,nr_devs=0
    [    2.499294] pci_bus 0000:00: get slot end devfn 160
    [    2.504277] pci_bus 0000:00: vendor config
    [    2.508458] pci_bus 0000:00: before generic vendor read
    [    2.513795] pci_bus 0000:00: child_bus_ext devfn=160,nr_devs=0
    [    2.519776] pci_bus 0000:00: get slot end devfn 168
    [    2.524756] pci_bus 0000:00: vendor config
    [    2.528938] pci_bus 0000:00: before generic vendor read
    [    2.534274] pci_bus 0000:00: child_bus_ext devfn=168,nr_devs=0
    [    2.540255] pci_bus 0000:00: get slot end devfn 176
    [    2.545236] pci_bus 0000:00: vendor config
    [    2.549417] pci_bus 0000:00: before generic vendor read
    [    2.554754] pci_bus 0000:00: child_bus_ext devfn=176,nr_devs=0
    [    2.560735] pci_bus 0000:00: get slot end devfn 184
    [    2.565717] pci_bus 0000:00: vendor config
    [    2.569899] pci_bus 0000:00: before generic vendor read
    [    2.575235] pci_bus 0000:00: child_bus_ext devfn=184,nr_devs=0
    [    2.581216] pci_bus 0000:00: get slot end devfn 192
    [    2.586197] pci_bus 0000:00: vendor config
    [    2.590379] pci_bus 0000:00: before generic vendor read
    [    2.595715] pci_bus 0000:00: child_bus_ext devfn=192,nr_devs=0
    [    2.601696] pci_bus 0000:00: get slot end devfn 200
    [    2.606677] pci_bus 0000:00: vendor config
    [    2.610858] pci_bus 0000:00: before generic vendor read
    [    2.616194] pci_bus 0000:00: child_bus_ext devfn=200,nr_devs=0
    [    2.622174] pci_bus 0000:00: get slot end devfn 208
    [    2.627156] pci_bus 0000:00: vendor config
    [    2.631338] pci_bus 0000:00: before generic vendor read
    [    2.636675] pci_bus 0000:00: child_bus_ext devfn=208,nr_devs=0
    [    2.642656] pci_bus 0000:00: get slot end devfn 216
    [    2.647636] pci_bus 0000:00: vendor config
    [    2.651818] pci_bus 0000:00: before generic vendor read
    [    2.657154] pci_bus 0000:00: child_bus_ext devfn=216,nr_devs=0
    [    2.663135] pci_bus 0000:00: get slot end devfn 224
    [    2.668115] pci_bus 0000:00: vendor config
    [    2.672296] pci_bus 0000:00: before generic vendor read
    [    2.677633] pci_bus 0000:00: child_bus_ext devfn=224,nr_devs=0
    [    2.683614] pci_bus 0000:00: get slot end devfn 232
    [    2.688596] pci_bus 0000:00: vendor config
    [    2.692778] pci_bus 0000:00: before generic vendor read
    [    2.698114] pci_bus 0000:00: child_bus_ext devfn=232,nr_devs=0
    [    2.704095] pci_bus 0000:00: get slot end devfn 240
    [    2.709076] pci_bus 0000:00: vendor config
    [    2.713257] pci_bus 0000:00: before generic vendor read
    [    2.718593] pci_bus 0000:00: child_bus_ext devfn=240,nr_devs=0
    [    2.724574] pci_bus 0000:00: get slot end devfn 248
    [    2.729554] pci_bus 0000:00: vendor config
    [    2.733736] pci_bus 0000:00: before generic vendor read
    [    2.739073] pci_bus 0000:00: child_bus_ext devfn=248,nr_devs=0
    [    2.745055] pci_bus 0000:00: child_bus_ext, used_buses=0,max=0, bus->is_added 0
    [    2.752526] pci_bus 0000:00: hotplg 0, nomal 1
    [    2.757065] pci 0000:00:00.0: pci_enable_crs end max 0, ava_buses 0,pass 0, pri 0, sec 0, sub 0
    [    2.765958] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    2.774139] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits
    [    2.784095] pci 0000:00:00.0: btcl 2, is_card 0, broken 1
    [    2.789610] pci 0000:00:00.0: if 2
    [    2.793081] pci 0000:00:00.0: goto out 0x0002
    [    2.797530] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits
    [    2.807488] pci_bus 0000:00: 1 pci_scan_bridge_ext max 0
    [    2.812914] pci_bus 0000:00: used_buses 1
    [    2.817007] pci_bus 0000:00: buses 0
    [    2.820654] pci 0000:00:00.0: pci_enable_crs end max 0, ava_buses 0,pass 1, pri 0, sec 0, sub 0
    [    2.829547] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits
    [    2.839504] pci 0000:00:00.0: btcl 2, is_card 0, broken 0
    [    2.845019] pci 0000:00:00.0: if 2
    [    2.848491] pci 0000:00:00.0: fixed_buses 0, next_busnr 1
    [    2.854037] pci 0000:00:00.0: child 35629056
    [    2.858398] pci 0000:00:00.0: buses 0x00ff0100
    [    2.862935] pci 0000:00:00.0: next pci_scan_child_bus_extend bctl 0x0002
    [    2.869786] pci_bus 0000:01: child_bus_ext, ava0
    [    2.874501] pci_bus 0000:01: get slot end devfn 0
    [    2.879304] pci_bus 0000:01: vendor config
    [    2.883485] pci_bus 0000:01: before generic vendor read
    [    2.888822] pci_bus 0000:01: child_bus_ext devfn=0,nr_devs=0
    [    2.894626] pci_bus 0000:01: child_bus_ext devfn=8,nr_devs=0
    [    2.900430] pci_bus 0000:01: child_bus_ext devfn=16,nr_devs=0
    [    2.906321] pci_bus 0000:01: child_bus_ext devfn=24,nr_devs=0
    [    2.912213] pci_bus 0000:01: child_bus_ext devfn=32,nr_devs=0
    [    2.918105] pci_bus 0000:01: child_bus_ext devfn=40,nr_devs=0
    [    2.923997] pci_bus 0000:01: child_bus_ext devfn=48,nr_devs=0
    [    2.929890] pci_bus 0000:01: child_bus_ext devfn=56,nr_devs=0
    [    2.935782] pci_bus 0000:01: child_bus_ext devfn=64,nr_devs=0
    [    2.941674] pci_bus 0000:01: child_bus_ext devfn=72,nr_devs=0
    [    2.947566] pci_bus 0000:01: child_bus_ext devfn=80,nr_devs=0
    [    2.953457] pci_bus 0000:01: child_bus_ext devfn=88,nr_devs=0
    [    2.959349] pci_bus 0000:01: child_bus_ext devfn=96,nr_devs=0
    [    2.965242] pci_bus 0000:01: child_bus_ext devfn=104,nr_devs=0
    [    2.971222] pci_bus 0000:01: child_bus_ext devfn=112,nr_devs=0
    [    2.977203] pci_bus 0000:01: child_bus_ext devfn=120,nr_devs=0
    [    2.983184] pci_bus 0000:01: child_bus_ext devfn=128,nr_devs=0
    [    2.989166] pci_bus 0000:01: child_bus_ext devfn=136,nr_devs=0
    [    2.995147] pci_bus 0000:01: child_bus_ext devfn=144,nr_devs=0
    [    3.001127] pci_bus 0000:01: child_bus_ext devfn=152,nr_devs=0
    [    3.007108] pci_bus 0000:01: child_bus_ext devfn=160,nr_devs=0
    [    3.013088] pci_bus 0000:01: child_bus_ext devfn=168,nr_devs=0
    [    3.019069] pci_bus 0000:01: child_bus_ext devfn=176,nr_devs=0
    [    3.025049] pci_bus 0000:01: child_bus_ext devfn=184,nr_devs=0
    [    3.031030] pci_bus 0000:01: child_bus_ext devfn=192,nr_devs=0
    [    3.037010] pci_bus 0000:01: child_bus_ext devfn=200,nr_devs=0
    [    3.042991] pci_bus 0000:01: child_bus_ext devfn=208,nr_devs=0
    [    3.048973] pci_bus 0000:01: child_bus_ext devfn=216,nr_devs=0
    [    3.054954] pci_bus 0000:01: child_bus_ext devfn=224,nr_devs=0
    [    3.060934] pci_bus 0000:01: child_bus_ext devfn=232,nr_devs=0
    [    3.066914] pci_bus 0000:01: child_bus_ext devfn=240,nr_devs=0
    [    3.072895] pci_bus 0000:01: child_bus_ext devfn=248,nr_devs=0
    [    3.078876] pci_bus 0000:01: child_bus_ext, used_buses=0,max=1, bus->is_added 0
    [    3.086346] pci_bus 0000:01: hotplg 0, nomal 0
    [    3.090883] pci_bus 0000:01: used_buses 0
    [    3.094976] pci_bus 0000:01: 2 pci_scan_bridge_ext max 1
    [    3.100401] pci_bus 0000:01: bus scan returning with max=01
    [    3.106097] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
    [    3.112857] pci 0000:00:00.0: SUBORDINATE_BUS max 1
    [    3.117841] pci 0000:00:00.0: PCI Bus 0000:01
    [    3.122289] pci 0000:00:00.0: goto out 0x0002
    [    3.126738] pci_bus 0000:00: 2 pci_scan_bridge_ext max 1
    [    3.132163] pci_bus 0000:00: bus scan returning with max=01
    [    3.137864] pci 0000:00:00.0: PCI bridge to [bus 01]
    [    3.143017] pci_bus 0000:00: vendor config
    [    3.147200] pci_bus 0000:00: before generic vendor read
    [    3.152538] pci_bus 0000:00: Read Vender ID l = 0xb00d104c
    [    3.158268] pcieport 0000:00:00.0: PME: Signaling with IRQ 36
    [    3.164618] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [    3.172289] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [    3.180565] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [    3.188845] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    3.197711] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [    3.205392] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
    [    3.213669] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
    [    3.221947] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    3.231079] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235
    [    3.240957] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
    [    3.247716] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64
    [    3.256667] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211
    [    3.266819] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
    [    3.273578] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64
    [    3.281545] printk: console [ttyS2] disabled
    [    3.285936] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 23, base_baud = 3000000) is a 8250
    [    3.294682] printk: console [ttyS2] enabled
    [    3.303118] printk: bootconsole [ns16550a0] disabled
    [    3.313644] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 24, base_baud = 3000000) is a 8250
    [    3.322996] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled
    [    3.333505] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcc-supply regulator, assuming enabled
    [    3.343659] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq-supply regulator, assuming enabled
    [    3.353900] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq2-supply regulator, assuming enabled
    [    3.364778] scsi host0: ufshcd
    [    3.370099] mdio_bus 46000f00.mdio: mii_bus 46000f00.mdio couldn't get reset GPIO
    [    3.377737] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
    [    3.390891] value of fuse 0 is 0xe8a6ab2a
    [    3.394894] value of fuse 1 is 0x6ec76db9
    [    3.398892] value of fuse 2 is 0x79b9bb2d
    [    3.402888] value of fuse 3 is 0x199999
    [    3.406714] k3_bandgap_probe and count is 5
    [    3.410885] WORKAROUND NOT NEEDED EFUSE0[31:30] = 0b11
    [    3.410970] Value of CTRLMMR_WKUP_RESET_SRC_STAT Register is 0x0
    [    3.422088] high_max is 760 and low_max is 648 and regval is 0x28802f8
    [    3.528604] Value of WKUP_VTM_MISC_CTRL2 is 0x28802f8
    [    3.533643] Value of WKUP_VTM_MISC_CTRL is 0x1
    [    3.538072] The contents of derived array
    [    3.542068] Code   Temperaturei
    [    3.545197] 0       -49002
    [    3.547891] 1       -48677
    [    3.550587] 2       -48352
    [    3.553284] 3       -48028
    [    3.555977] 4       -47704
    [    3.558674] 5       -47381
    [    3.561370] 6       -47057
    [    3.564063] 7       -46734
    [    3.566759] 8       -46412
    [    3.569456] 9       -46090
    [    3.572154] 10       -45768
    [    3.574942] 11       -45446
    [    3.577725] 12       -45125
    [    3.580506] 13       -44804
    [    3.583288] 14       -44484
    [    3.586071] 15       -44163
    [    3.588851] 16       -43844
    [    3.591634] 17       -43524
    [    3.594419] 18       -43205
    [    3.597203] 19       -42886
    [    3.599983] 20       -42567
    [    3.602766] 21       -42249
    [    3.605549] 22       -41931
    [    3.608329] 23       -41614
    [    3.611112] 24       -41297
    [    3.613895] 25       -40980
    [    3.616675] 26       -40663
    [    3.619458] 27       -40347
    [    3.622241] 28       -40031
    [    3.625025] 29       -39716
    [    3.627804] 30       -39400
    [    3.630587] 31       -39085
    [    3.633370] 32       -38771
    [    3.636150] 33       -38457
    [    3.638933] 34       -38143
    [    3.641716] 35       -37829
    [    3.644496] 36       -37516
    [    3.647279] 37       -37203
    [    3.650062] 38       -36890
    [    3.652842] 39       -36578
    [    3.655627] 40       -36266
    [    3.658410] 41       -35955
    [    3.661193] 42       -35643
    [    3.663974] 43       -35332
    [    3.666757] 44       -35022
    [    3.669540] 45       -34712
    [    3.672320] 46       -34402
    [    3.675103] 47       -34092
    [    3.677890] 48       -33783
    [    3.680675] 49       -33474
    [    3.683458] 50       -33165
    [    3.686241] 51       -32857
    [    3.689024] 52       -32549
    [    3.691804] 53       -32241
    [    3.694587] 54       -31934
    [    3.697371] 55       -31626
    [    3.700151] 56       -31320
    [    3.702934] 57       -31013
    [    3.705717] 58       -30707
    [    3.708497] 59       -30401
    [    3.711280] 60       -30096
    [    3.714065] 61       -29791
    [    3.716845] 62       -29486
    [    3.719628] 63       -29182
    [    3.722411] 64       -28877
    [    3.725194] 65       -28573
    [    3.727973] 66       -28270
    [    3.730756] 67       -27967
    [    3.733540] 68       -27664
    [    3.736320] 69       -27361
    [    3.739103] 70       -27059
    [    3.741886] 71       -26757
    [    3.744667] 72       -26455
    [    3.747449] 73       -26154
    [    3.750233] 74       -25853
    [    3.753015] 75       -25552
    [    3.755796] 76       -25252
    [    3.758578] 77       -24952
    [    3.761361] 78       -24652
    [    3.764141] 79       -24353
    [    3.766924] 80       -24054
    [    3.769707] 81       -23755
    [    3.772488] 82       -23456
    [    3.775273] 83       -23158
    [    3.778056] 84       -22860
    [    3.780836] 85       -22563
    [    3.783623] 86       -22265
    [    3.784735] cdns-ufshcd 4e84000.ufs: link startup failed 1
    [    3.786405] 87       -21968
    [    3.786407] 88       -21672
    [    3.786408] 89       -21376
    [    3.786411] 90       -21079
    [    3.791881] cdns-ufshcd 4e84000.ufs: UFS Host state=0
    [    3.794661] 91       -20784
    [    3.797443] cdns-ufshcd 4e84000.ufs: outstanding reqs=0x0 tasks=0x0
    [    3.800220] 92       -20488
    [    3.800222] 93       -20193
    [    3.803005] cdns-ufshcd 4e84000.ufs: saved_err=0x0, saved_uic_err=0x0
    [    3.808038] 94       -19899
    [    3.810820] cdns-ufshcd 4e84000.ufs: Device power mode=1, UIC link state=0
    [    3.817067] 95       -19604
    [    3.819847] cdns-ufshcd 4e84000.ufs: PM in progress=0, sys. suspended=0
    [    3.822628] 96       -19310
    [    3.829049] cdns-ufshcd 4e84000.ufs: Auto BKOPS=0, Host self-block=0
    [    3.831827] 97       -19016
    [    3.838682] cdns-ufshcd 4e84000.ufs: Clk gate=1
    [    3.838684] cdns-ufshcd 4e84000.ufs: last_hibern8_exit_tstamp at 0 us, hibern8_exit_cnt=0
    [    3.841465] 98       -18723
    [    3.848061] cdns-ufshcd 4e84000.ufs: last intr at 3666761 us, last intr status=0x404
    [    3.850840] 99       -18429
    [    3.857175] cdns-ufshcd 4e84000.ufs: error handling flags=0x0, req. abort count=0
    [    3.859953] 100       -18136
    [    3.864480] cdns-ufshcd 4e84000.ufs: hba->ufs_version=0x210, Host capabilities=0x1587031f, caps=0x0
    [    3.872623] 101       -17844
    [    3.875405] cdns-ufshcd 4e84000.ufs: quirks=0x0, dev. quirks=0x0
    [    3.883125] 102       -17551
    [    3.885907] cdns-ufshcd 4e84000.ufs: clk: core_clk, rate: 250000000
    [    3.893367] 103       -17259
    [    3.893369] 104       -16968
    [    3.896236] cdns-ufshcd 4e84000.ufs: clk: phy_clk, rate: 19200000
    [    3.905259] 105       -16676
    [    3.908125] cdns-ufshcd 4e84000.ufs: clk: ref_clk, rate: 19200000
    [    3.914112] 106       -16385
    [    3.916982] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[0, 0], lane[0, 0], pwr[INVALID MODE, INVALID MODE], rate = 0
    [    3.923229] 107       -16094
    [    3.926134] host_regs: 00000000: 1587031f 00000000 00000210 00000000
    [    3.928970] 108       -15804
    [    3.935045] host_regs: 00000010: 00000000 00000000 00000000 00000000
    [    3.937913] 109       -15514
    [    3.943988] host_regs: 00000020: 00000000 00000470 00000000 00000000
    [    3.946856] 110       -15224
    [    3.958997] host_regs: 00000030: 00000008 00000001 00000000 00000000
    [    3.958999] host_regs: 00000040: 00000000 00000000 00000000 00000000
    [    3.961866] 111       -14934
    [    3.968203] host_regs: 00000050: 00000000 00000000 00000000 00000000
    [    3.971071] 112       -14645
    [    3.977406] host_regs: 00000060: 00000000 00000000 00000000 00000000
    [    3.980271] 113       -14356
    [    3.986605] host_regs: 00000070: 00000000 00000000 00000000 00000000
    [    3.989473] 114       -14067
    [    3.995808] host_regs: 00000080: 00000000 00000000 00000000 00000000
    [    4.002142] 115       -13779
    [    4.002144] 116       -13491
    [    4.005011] host_regs: 00000090: 00000000 00000000 00000000 00000000
    [    4.011345] 117       -13203
    [    4.014214] cdns-ufshcd 4e84000.ufs: No record of pa_err
    [    4.020548] 118       -12916
    [    4.023416] cdns-ufshcd 4e84000.ufs: No record of dl_err
    [    4.029751] 119       -12628
    [    4.032617] cdns-ufshcd 4e84000.ufs: No record of nl_err
    [    4.038951] 120       -12342
    [    4.041819] cdns-ufshcd 4e84000.ufs: No record of tl_err
    [    4.044683] 121       -12055
    [    4.051019] cdns-ufshcd 4e84000.ufs: No record of dme_err
    [    4.053885] 122       -11769
    [    4.059180] cdns-ufshcd 4e84000.ufs: No record of auto_hibern8_err
    [    4.062048] 123       -11483
    [    4.067342] cdns-ufshcd 4e84000.ufs: No record of fatal_err
    [    4.070209] 124       -11197
    [    4.075504] cdns-ufshcd 4e84000.ufs: link_startup_fail[0] = 0x1 at 3667873 us
    [    4.078371] 125       -10912
    [    4.083666] cdns-ufshcd 4e84000.ufs: No record of resume_fail
    [    4.086534] 126       -10627
    [    4.091917] cdns-ufshcd 4e84000.ufs: No record of suspend_fail
    [    4.094785] 127       -10342
    [    4.100946] cdns-ufshcd 4e84000.ufs: No record of dev_reset
    [    4.103810] 128       -10057
    [    4.109365] cdns-ufshcd 4e84000.ufs: No record of host_reset
    [    4.112229] 129       -9773
    [    4.119344] cdns-ufshcd 4e84000.ufs: No record of task_abort
    [    4.122212] 130       -9489
    [    4.164767] 131       -9206
    [    4.167550] 132       -8922
    [    4.170333] 133       -8639
    [    4.173116] 134       -8357
    [    4.175896] 135       -8074
    [    4.178678] 136       -7792
    [    4.181461] 137       -7510
    [    4.184241] 138       -7229
    [    4.187024] 139       -6947
    [    4.189807] 140       -6666
    [    4.192587] 141       -6386
    [    4.195370] 142       -6105
    [    4.198154] 143       -5825
    [    4.200937] 144       -5546
    [    4.203717] 145       -5266
    [    4.206500] 146       -4987
    [    4.209283] 147       -4708
    [    4.212063] 148       -4429
    [    4.214848] 149       -4151
    [    4.217631] 150       -3873
    [    4.220411] 151       -3595
    [    4.223194] 152       -3318
    [    4.225976] 153       -3041
    [    4.228756] 154       -2764
    [    4.231539] 155       -2487
    [    4.234322] 156       -2211
    [    4.237105] 157       -1935
    [    4.239885] 158       -1659
    [    4.242668] 159       -1384
    [    4.245451] 160       -1108
    [    4.248231] 161       -834
    [    4.250927] 162       -559
    [    4.253624] 163       -285
    [    4.256317] 164       -11
    [    4.258926] 165       263
    [    4.261536] 166       537
    [    4.264142] 167       810
    [    4.266752] 168       1083
    [    4.269448] 169       1355
    [    4.272142] 170       1628
    [    4.274840] 171       1900
    [    4.277537] 172       2171
    [    4.280231] 173       2443
    [    4.282927] 174       2714
    [    4.285623] 175       2985
    [    4.288316] 176       3255
    [    4.291013] 177       3526
    [    4.293709] 178       3796
    [    4.296402] 179       4066
    [    4.299098] 180       4335
    [    4.301794] 181       4604
    [    4.304488] 182       4873
    [    4.307184] 183       5142
    [    4.309881] 184       5410
    [    4.312574] 185       5679
    [    4.315270] 186       5946
    [    4.317967] 187       6214
    [    4.320660] 188       6481
    [    4.323356] 189       6748
    [    4.326053] 190       7015
    [    4.328746] 191       7281
    [    4.331442] 192       7548
    [    4.334140] 193       7813
    [    4.336834] 194       8079
    [    4.339530] 195       8344
    [    4.342227] 196       8609
    [    4.344923] 197       8874
    [    4.347617] 198       9139
    [    4.350313] 199       9403
    [    4.353009] 200       9667
    [    4.355702] 201       9931
    [    4.358399] 202       10194
    [    4.361182] 203       10457
    [    4.363962] 204       10720
    [    4.366745] 205       10983
    [    4.369528] 206       11245
    [    4.372308] 207       11507
    [    4.375090] 208       11769
    [    4.377873] 209       12030
    [    4.380653] 210       12292
    [    4.383436] 211       12553
    [    4.386219] 212       12813
    [    4.389002] 213       13074
    [    4.391782] 214       13334
    [    4.394565] 215       13594
    [    4.397348] 216       13854
    [    4.400129] 217       14113
    [    4.402912] 218       14372
    [    4.405695] 219       14631
    [    4.408475] 220       14889
    [    4.411259] 221       15148
    [    4.414042] 222       15406
    [    4.416822] 223       15664
    [    4.419605] 224       15921
    [    4.422388] 225       16178
    [    4.425171] 226       16435
    [    4.427951] 227       16692
    [    4.430734] 228       16948
    [    4.433517] 229       17205
    [    4.436297] 230       17461
    [    4.439079] 231       17716
    [    4.441862] 232       17972
    [    4.444643] 233       18227
    [    4.447425] 234       18482
    [    4.450209] 235       18736
    [    4.452993] 236       18991
    [    4.455774] 237       19245
    [    4.458557] 238       19498
    [    4.461340] 239       19752
    [    4.464120] 240       20005
    [    4.466903] 241       20258
    [    4.469686] 242       20511
    [    4.472466] 243       20764
    [    4.475250] 244       21016
    [    4.478033] 245       21268
    [    4.480813] 246       21520
    [    4.483596] 247       21771
    [    4.486379] 248       22022
    [    4.489162] 249       22273
    [    4.491942] 250       22524
    [    4.494725] 251       22774
    [    4.497508] 252       23025
    [    4.500289] 253       23274
    [    4.503072] 254       23524
    [    4.505854] 255       23774
    [    4.508635] 256       24023
    [    4.511418] 257       24272
    [    4.514203] 258       24520
    [    4.516985] 259       24769
    [    4.519766] 260       25017
    [    4.522548] 261       25265
    [    4.525331] 262       25512
    [    4.528112] 263       25760
    [    4.530895] 264       26007
    [    4.533678] 265       26254
    [    4.536458] 266       26500
    [    4.539241] 267       26747
    [    4.542024] 268       26993
    [    4.544804] 269       27239
    [    4.547587] 270       27484
    [    4.550370] 271       27730
    [    4.553153] 272       27975
    [    4.555933] 273       28220
    [    4.558716] 274       28464
    [    4.561499] 275       28708
    [    4.564280] 276       28953
    [    4.567062] 277       29196
    [    4.569845] 278       29440
    [    4.572625] 279       29683
    [    4.575410] 280       29927
    [    4.578193] 281       30169
    [    4.580976] 282       30412
    [    4.583756] 283       30654
    [    4.586539] 284       30896
    [    4.589322] 285       31138
    [    4.592102] 286       31380
    [    4.594885] 287       31621
    [    4.597668] 288       31862
    [    4.600449] 289       32103
    [    4.603232] 290       32344
    [    4.606015] 291       32584
    [    4.608795] 292       32824
    [    4.611576] 293       33064
    [    4.614359] 294       33304
    [    4.617142] 295       33543
    [    4.619922] 296       33783
    [    4.622705] 297       34022
    [    4.625488] 298       34260
    [    4.628268] 299       34499
    [    4.631051] 300       34737
    [    4.633835] 301       34975
    [    4.636616] 302       35213
    [    4.639399] 303       35450
    [    4.642182] 304       35687
    [    4.644965] 305       35924
    [    4.647745] 306       36161
    [    4.650529] 307       36397
    [    4.653312] 308       36634
    [    4.656092] 309       36870
    [    4.658875] 310       37105
    [    4.661658] 311       37341
    [    4.664438] 312       37576
    [    4.667221] 313       37811
    [    4.670004] 314       38046
    [    4.672784] 315       38281
    [    4.675567] 316       38515
    [    4.678350] 317       38749
    [    4.681133] 318       38983
    [    4.683913] 319       39217
    [    4.686696] 320       39450
    [    4.689479] 321       39683
    [    4.692260] 322       39916
    [    4.695044] 323       40149
    [    4.697828] 324       40381
    [    4.700608] 325       40614
    [    4.703390] 326       40846
    [    4.706173] 327       41077
    [    4.708956] 328       41309
    [    4.711736] 329       41540
    [    4.714519] 330       41771
    [    4.717303] 331       42002
    [    4.720083] 332       42233
    [    4.722866] 333       42463
    [    4.725649] 334       42693
    [    4.728429] 335       42923
    [    4.731212] 336       43153
    [    4.733995] 337       43382
    [    4.736775] 338       43611
    [    4.739558] 339       43840
    [    4.742342] 340       44069
    [    4.745124] 341       44297
    [    4.747905] 342       44526
    [    4.750688] 343       44754
    [    4.753472] 344       44981
    [    4.756252] 345       45209
    [    4.759036] 346       45436
    [    4.761819] 347       45663
    [    4.764599] 348       45890
    [    4.767382] 349       46117
    [    4.770165] 350       46343
    [    4.772948] 351       46570
    [    4.775728] 352       46796
    [    4.778511] 353       47021
    [    4.781292] 354       47247
    [    4.784073] 355       47472
    [    4.786856] 356       47697
    [    4.789638] 357       47922
    [    4.792419] 358       48147
    [    4.795201] 359       48371
    [    4.797984] 360       48595
    [    4.800765] 361       48819
    [    4.803548] 362       49043
    [    4.806331] 363       49266
    [    4.809114] 364       49490
    [    4.811894] 365       49713
    [    4.814679] 366       49935
    [    4.817462] 367       50158
    [    4.820242] 368       50380
    [    4.823025] 369       50603
    [    4.825808] 370       50824
    [    4.828588] 371       51046
    [    4.831371] 372       51268
    [    4.834154] 373       51489
    [    4.836937] 374       51710
    [    4.839718] 375       51931
    [    4.842501] 376       52151
    [    4.845283] 377       52372
    [    4.848064] 378       52592
    [    4.850847] 379       52812
    [    4.853630] 380       53031
    [    4.856410] 381       53251
    [    4.859193] 382       53470
    [    4.861976] 383       53689
    [    4.864756] 384       53908
    [    4.867540] 385       54127
    [    4.870322] 386       54345
    [    4.873107] 387       54563
    [    4.875887] 388       54781
    [    4.878671] 389       54999
    [    4.881454] 390       55217
    [    4.884233] 391       55434
    [    4.887016] 392       55651
    [    4.889799] 393       55868
    [    4.892580] 394       56085
    [    4.895363] 395       56301
    [    4.898146] 396       56517
    [    4.900929] 397       56733
    [    4.903709] 398       56949
    [    4.906492] 399       57165
    [    4.909275] 400       57380
    [    4.912055] 401       57595
    [    4.914838] 402       57810
    [    4.917621] 403       58025
    [    4.920402] 404       58239
    [    4.923185] 405       58454
    [    4.925966] 406       58668
    [    4.928746] 407       58882
    [    4.931529] 408       59095
    [    4.934314] 409       59309
    [    4.937097] 410       59522
    [    4.939877] 411       59735
    [    4.942659] 412       59948
    [    4.945442] 413       60160
    [    4.948222] 414       60373
    [    4.951006] 415       60585
    [    4.953789] 416       60797
    [    4.956569] 417       61009
    [    4.959352] 418       61220
    [    4.962135] 419       61432
    [    4.964919] 420       61643
    [    4.967699] 421       61854
    [    4.970482] 422       62064
    [    4.973265] 423       62275
    [    4.976045] 424       62485
    [    4.978828] 425       62695
    [    4.981611] 426       62905
    [    4.984391] 427       63115
    [    4.987174] 428       63324
    [    4.989957] 429       63534
    [    4.992737] 430       63743
    [    4.995522] 431       63952
    [    4.998305] 432       64160
    [    5.001088] 433       64369
    [    5.003868] 434       64577
    [    5.006651] 435       64785
    [    5.009434] 436       64993
    [    5.012214] 437       65200
    [    5.014997] 438       65408
    [    5.017780] 439       65615
    [    5.020560] 440       65822
    [    5.023343] 441       66029
    [    5.026126] 442       66236
    [    5.028909] 443       66442
    [    5.031690] 444       66648
    [    5.034473] 445       66854
    [    5.037256] 446       67060
    [    5.040036] 447       67266
    [    5.042817] 448       67471
    [    5.045600] 449       67676
    [    5.048380] 450       67881
    [    5.051164] 451       68086
    [    5.053947] 452       68291
    [    5.056726] 453       68495
    [    5.059509] 454       68699
    [    5.062292] 455       68903
    [    5.065074] 456       69107
    [    5.067855] 457       69311
    [    5.070638] 458       69514
    [    5.073419] 459       69717
    [    5.076200] 460       69920
    [    5.078983] 461       70123
    [    5.081766] 462       70326
    [    5.084546] 463       70528
    [    5.087329] 464       70730
    [    5.090112] 465       70932
    [    5.092894] 466       71134
    [    5.095675] 467       71336
    [    5.098458] 468       71537
    [    5.101241] 469       71738
    [    5.104021] 470       71939
    [    5.106803] 471       72140
    [    5.109586] 472       72341
    [    5.112367] 473       72541
    [    5.115152] 474       72742
    [    5.117935] 475       72942
    [    5.120715] 476       73142
    [    5.123499] 477       73341
    [    5.126282] 478       73541
    [    5.129064] 479       73740
    [    5.131845] 480       73939
    [    5.134628] 481       74138
    [    5.137411] 482       74337
    [    5.140191] 483       74535
    [    5.142974] 484       74733
    [    5.145757] 485       74932
    [    5.148537] 486       75130
    [    5.151320] 487       75327
    [    5.154103] 488       75525
    [    5.156886] 489       75722
    [    5.159666] 490       75919
    [    5.162450] 491       76116
    [    5.165232] 492       76313
    [    5.168013] 493       76510
    [    5.170796] 494       76706
    [    5.173580] 495       76902
    [    5.176360] 496       77098
    [    5.179144] 497       77294
    [    5.181926] 498       77490
    [    5.184707] 499       77685
    [    5.187490] 500       77881
    [    5.190272] 501       78076
    [    5.193055] 502       78271
    [    5.195836] 503       78465
    [    5.198618] 504       78660
    [    5.201401] 505       78854
    [    5.204181] 506       79048
    [    5.206965] 507       79242
    [    5.209747] 508       79436
    [    5.212528] 509       79630
    [    5.215309] 510       79823
    [    5.218093] 511       80016
    [    5.220876] 512       80210
    [    5.223656] 513       80402
    [    5.226439] 514       80595
    [    5.229222] 515       80788
    [    5.232002] 516       80980
    [    5.234787] 517       81172
    [    5.237570] 518       81364
    [    5.240350] 519       81556
    [    5.243133] 520       81747
    [    5.245916] 521       81939
    [    5.248696] 522       82130
    [    5.251479] 523       82321
    [    5.254262] 524       82512
    [    5.257045] 525       82702
    [    5.259825] 526       82893
    [    5.262608] 527       83083
    [    5.265391] 528       83273
    [    5.268172] 529       83463
    [    5.270955] 530       83653
    [    5.273738] 531       83843
    [    5.276518] 532       84032
    [    5.279301] 533       84221
    [    5.282084] 534       84410
    [    5.284867] 535       84599
    [    5.287647] 536       84788
    [    5.290430] 537       84976
    [    5.293214] 538       85165
    [    5.295995] 539       85353
    [    5.298778] 540       85541
    [    5.301561] 541       85728
    [    5.304340] 542       85916
    [    5.307123] 543       86103
    [    5.309905] 544       86291
    [    5.312686] 545       86478
    [    5.315467] 546       86665
    [    5.318250] 547       86851
    [    5.321033] 548       87038
    [    5.323813] 549       87224
    [    5.326596] 550       87411
    [    5.329379] 551       87597
    [    5.332159] 552       87782
    [    5.334942] 553       87968
    [    5.337725] 554       88154
    [    5.340506] 555       88339
    [    5.343289] 556       88524
    [    5.346071] 557       88709
    [    5.348852] 558       88894
    [    5.351635] 559       89078
    [    5.354419] 560       89263
    [    5.357202] 561       89447
    [    5.359982] 562       89631
    [    5.362766] 563       89815
    [    5.365548] 564       89999
    [    5.368328] 565       90182
    [    5.371111] 566       90366
    [    5.373894] 567       90549
    [    5.376674] 568       90732
    [    5.379457] 569       90915
    [    5.382240] 570       91098
    [    5.385022] 571       91280
    [    5.387802] 572       91463
    [    5.390585] 573       91645
    [    5.393366] 574       91827
    [    5.396147] 575       92009
    [    5.398930] 576       92191
    [    5.401712] 577       92372
    [    5.404492] 578       92554
    [    5.407275] 579       92735
    [    5.410058] 580       92916
    [    5.412838] 581       93097
    [    5.415622] 582       93277
    [    5.418406] 583       93458
    [    5.421188] 584       93638
    [    5.423969] 585       93818
    [    5.426752] 586       93998
    [    5.429535] 587       94178
    [    5.432314] 588       94358
    [    5.435097] 589       94537
    [    5.437879] 590       94717
    [    5.440659] 591       94896
    [    5.443442] 592       95075
    [    5.446225] 593       95254
    [    5.449008] 594       95433
    [    5.451788] 595       95611
    [    5.454571] 596       95790
    [    5.457354] 597       95968
    [    5.460134] 598       96146
    [    5.462918] 599       96324
    [    5.465701] 600       96501
    [    5.468481] 601       96679
    [    5.471264] 602       96856
    [    5.474049] 603       97033
    [    5.476829] 604       97211
    [    5.479611] 605       97387
    [    5.482394] 606       97564
    [    5.485177] 607       97741
    [    5.487957] 608       97917
    [    5.490740] 609       98093
    [    5.493523] 610       98269
    [    5.496302] 611       98445
    [    5.499085] 612       98621
    [    5.501868] 613       98797
    [    5.504648] 614       98972
    [    5.507431] 615       99147
    [    5.510214] 616       99322
    [    5.512996] 617       99497
    [    5.515777] 618       99672
    [    5.518560] 619       99847
    [    5.521343] 620       100021
    [    5.524210] 621       100196
    [    5.527080] 622       100370
    [    5.529950] 623       100544
    [    5.532817] 624       100718
    [    5.535688] 625       100891
    [    5.538557] 626       101065
    [    5.541425] 627       101238
    [    5.544292] 628       101411
    [    5.547162] 629       101584
    [    5.550032] 630       101757
    [    5.552901] 631       101930
    [    5.555769] 632       102103
    [    5.558638] 633       102275
    [    5.561506] 634       102447
    [    5.564374] 635       102619
    [    5.567242] 636       102791
    [    5.570112] 637       102963
    [    5.572982] 638       103135
    [    5.575849] 639       103306
    [    5.578719] 640       103478
    [    5.581588] 641       103649
    [    5.584455] 642       103820
    [    5.587325] 643       103991
    [    5.590195] 644       104161
    [    5.593067] 645       104332
    [    5.595934] 646       104502
    [    5.598804] 647       104673
    [    5.601674] 648       104843
    [    5.604541] 649       105013
    [    5.607409] 650       105182
    [    5.610279] 651       105352
    [    5.613149] 652       105522
    [    5.616016] 653       105691
    [    5.618885] 654       105860
    [    5.621754] 655       106029
    [    5.624621] 656       106198
    [    5.627491] 657       106367
    [    5.630361] 658       106535
    [    5.633231] 659       106704
    [    5.636098] 660       106872
    [    5.638968] 661       107040
    [    5.641838] 662       107208
    [    5.644705] 663       107376
    [    5.647574] 664       107544
    [    5.650444] 665       107711
    [    5.653316] 666       107878
    [    5.656183] 667       108046
    [    5.659052] 668       108213
    [    5.661922] 669       108380
    [    5.664789] 670       108546
    [    5.667659] 671       108713
    [    5.670527] 672       108880
    [    5.673397] 673       109046
    [    5.676263] 674       109212
    [    5.679131] 675       109378
    [    5.682001] 676       109544
    [    5.684871] 677       109710
    [    5.687738] 678       109875
    [    5.690608] 679       110041
    [    5.693478] 680       110206
    [    5.696345] 681       110371
    [    5.699215] 682       110536
    [    5.702083] 683       110701
    [    5.704953] 684       110866
    [    5.707820] 685       111030
    [    5.710690] 686       111195
    [    5.713561] 687       111359
    [    5.716427] 688       111523
    [    5.719297] 689       111687
    [    5.722167] 690       111851
    [    5.725037] 691       112015
    [    5.727904] 692       112178
    [    5.730774] 693       112342
    [    5.733644] 694       112505
    [    5.736511] 695       112668
    [    5.739381] 696       112831
    [    5.742249] 697       112994
    [    5.745119] 698       113157
    [    5.747986] 699       113319
    [    5.750856] 700       113482
    [    5.753726] 701       113644
    [    5.756591] 702       113806
    [    5.759461] 703       113968
    [    5.762331] 704       114130
    [    5.765201] 705       114292
    [    5.768068] 706       114453
    [    5.770938] 707       114615
    [    5.773809] 708       114776
    [    5.776676] 709       114937
    [    5.779547] 710       115098
    [    5.782417] 711       115259
    [    5.785286] 712       115420
    [    5.788152] 713       115580
    [    5.791022] 714       115741
    [    5.793892] 715       115901
    [    5.796759] 716       116061
    [    5.799629] 717       116221
    [    5.802498] 718       116381
    [    5.805368] 719       116541
    [    5.808235] 720       116701
    [    5.811103] 721       116860
    [    5.813973] 722       117019
    [    5.816840] 723       117179
    [    5.819710] 724       117338
    [    5.822579] 725       117497
    [    5.825448] 726       117655
    [    5.828315] 727       117814
    [    5.831184] 728       117973
    [    5.834056] 729       118131
    [    5.836926] 730       118289
    [    5.839793] 731       118447
    [    5.842663] 732       118605
    [    5.845532] 733       118763
    [    5.848399] 734       118921
    [    5.851268] 735       119078
    [    5.854138] 736       119236
    [    5.857008] 737       119393
    [    5.859875] 738       119550
    [    5.862745] 739       119707
    [    5.865613] 740       119864
    [    5.868480] 741       120021
    [    5.871350] 742       120178
    [    5.874218] 743       120334
    [    5.877088] 744       120490
    [    5.879955] 745       120647
    [    5.882825] 746       120803
    [    5.885695] 747       120959
    [    5.888561] 748       121115
    [    5.891430] 749       121270
    [    5.894314] 750       121426
    [    5.897184] 751       121581
    [    5.900052] 752       121737
    [    5.902920] 753       121892
    [    5.905790] 754       122047
    [    5.908657] 755       122202
    [    5.911527] 756       122356
    [    5.914397] 757       122511
    [    5.917265] 758       122666
    [    5.920132] 759       122820
    [    5.923001] 760       122974
    [    5.925870] 761       123128
    [    5.928737] 762       123282
    [    5.931608] 763       123436
    [    5.934476] 764       123590
    [    5.937345] 765       123744
    [    5.940213] 766       123897
    [    5.943082] 767       124050
    [    5.945951] 768       124204
    [    5.948818] 769       124357
    [    5.951687] 770       124510
    [    5.954559] 771       124662
    [    5.957429] 772       124815
    [    5.960295] 773       124968
    [    5.963165] 774       125120
    [    5.966035] 775       125273
    [    5.968904] 776       125425
    [    5.971771] 777       125577
    [    5.974640] 778       125729
    [    5.977511] 779       125881
    [    5.980378] 780       126032
    [    5.983248] 781       126184
    [    5.986116] 782       126335
    [    5.988984] 783       126487
    [    5.991850] 784       126638
    [    5.994720] 785       126789
    [    5.997589] 786       126940
    [    6.000457] 787       127091
    [    6.003326] 788       127241
    [    6.006195] 789       127392
    [    6.009065] 790       127542
    [    6.011931] 791       127693
    [    6.014803] 792       127843
    [    6.017673] 793       127993
    [    6.020540] 794       128143
    [    6.023410] 795       128293
    [    6.026280] 796       128442
    [    6.029150] 797       128592
    [    6.032016] 798       128741
    [    6.034885] 799       128891
    [    6.037755] 800       129040
    [    6.040622] 801       129189
    [    6.043492] 802       129338
    [    6.046362] 803       129487
    [    6.049232] 804       129635
    [    6.052099] 805       129784
    [    6.054968] 806       129932
    [    6.057838] 807       130081
    [    6.060705] 808       130229
    [    6.063574] 809       130377
    [    6.066444] 810       130525
    [    6.069314] 811       130673
    [    6.072181] 812       130821
    [    6.075053] 813       130968
    [    6.077923] 814       131116
    [    6.080790] 815       131263
    [    6.083660] 816       131410
    [    6.086530] 817       131558
    [    6.089400] 818       131705
    [    6.092267] 819       131851
    [    6.095137] 820       131998
    [    6.098006] 821       132145
    [    6.100876] 822       132291
    [    6.103742] 823       132438
    [    6.106612] 824       132584
    [    6.109481] 825       132730
    [    6.112349] 826       132876
    [    6.115219] 827       133022
    [    6.118088] 828       133168
    [    6.120958] 829       133314
    [    6.123825] 830       133460
    [    6.126693] 831       133605
    [    6.129563] 832       133750
    [    6.132429] 833       133896
    [    6.135299] 834       134041
    [    6.138169] 835       134186
    [    6.141038] 836       134331
    [    6.143905] 837       134476
    [    6.146774] 838       134620
    [    6.149643] 839       134765
    [    6.152510] 840       134909
    [    6.155379] 841       135054
    [    6.158249] 842       135198
    [    6.161118] 843       135342
    [    6.163983] 844       135486
    [    6.166853] 845       135630
    [    6.169723] 846       135773
    [    6.172590] 847       135917
    [    6.175460] 848       136061
    [    6.178328] 849       136204
    [    6.181198] 850       136347
    [    6.184065] 851       136491
    [    6.186934] 852       136634
    [    6.189804] 853       136777
    [    6.192671] 854       136919
    [    6.195542] 855       137062
    [    6.198412] 856       137205
    [    6.201282] 857       137347
    [    6.204149] 858       137490
    [    6.207019] 859       137632
    [    6.209889] 860       137774
    [    6.212755] 861       137916
    [    6.215623] 862       138058
    [    6.218493] 863       138200
    [    6.221361] 864       138342
    [    6.224228] 865       138483
    [    6.227098] 866       138625
    [    6.229968] 867       138766
    [    6.232835] 868       138907
    [    6.235703] 869       139049
    [    6.238573] 870       139190
    [    6.241443] 871       139331
    [    6.244310] 872       139471
    [    6.247180] 873       139612
    [    6.250050] 874       139753
    [    6.252921] 875       139893
    [    6.255789] 876       140034
    [    6.258657] 877       140174
    [    6.261528] 878       140314
    [    6.264393] 879       140454
    [    6.267261] 880       140594
    [    6.270131] 881       140734
    [    6.273001] 882       140874
    [    6.275868] 883       141013
    [    6.278737] 884       141153
    [    6.281606] 885       141292
    [    6.284473] 886       141432
    [    6.287344] 887       141571
    [    6.290213] 888       141710
    [    6.293083] 889       141849
    [    6.295950] 890       141988
    [    6.298819] 891       142127
    [    6.301687] 892       142265
    [    6.304553] 893       142404
    [    6.307423] 894       142542
    [    6.310291] 895       142681
    [    6.313163] 896       142819
    [    6.316030] 897       142957
    [    6.318899] 898       143095
    [    6.321769] 899       143233
    [    6.324636] 900       143371
    [    6.327505] 901       143509
    [    6.330375] 902       143646
    [    6.333245] 903       143784
    [    6.336111] 904       143921
    [    6.338980] 905       144058
    [    6.341850] 906       144196
    [    6.344716] 907       144333
    [    6.347585] 908       144470
    [    6.350454] 909       144607
    [    6.353324] 910       144743
    [    6.356190] 911       144880
    [    6.359058] 912       145017
    [    6.361928] 913       145153
    [    6.364794] 914       145289
    [    6.367662] 915       145426
    [    6.370532] 916       145562
    [    6.373403] 917       145698
    [    6.376269] 918       145834
    [    6.379139] 919       145970
    [    6.382007] 920       146105
    [    6.384877] 921       146241
    [    6.387744] 922       146377
    [    6.390613] 923       146512
    [    6.393481] 924       146647
    [    6.396347] 925       146783
    [    6.399215] 926       146918
    [    6.402085] 927       147053
    [    6.404955] 928       147188
    [    6.407821] 929       147323
    [    6.410689] 930       147457
    [    6.413559] 931       147592
    [    6.416425] 932       147727
    [    6.419294] 933       147861
    [    6.422165] 934       147995
    [    6.425035] 935       148130
    [    6.427902] 936       148264
    [    6.430772] 937       148398
    [    6.433643] 938       148532
    [    6.436509] 939       148666
    [    6.439379] 940       148799
    [    6.442249] 941       148933
    [    6.445119] 942       149067
    [    6.447986] 943       149200
    [    6.450856] 944       149333
    [    6.453725] 945       149467
    [    6.456591] 946       149600
    [    6.459459] 947       149733
    [    6.462329] 948       149866
    [    6.465199] 949       149999
    [    6.468066] 950       150131
    [    6.470936] 951       150264
    [    6.473805] 952       150397
    [    6.476672] 953       150529
    [    6.479542] 954       150661
    [    6.482411] 955       150794
    [    6.485281] 956       150926
    [    6.488146] 957       151058
    [    6.491017] 958       151190
    [    6.493888] 959       151322
    [    6.496754] 960       151454
    [    6.499623] 961       151585
    [    6.502492] 962       151717
    [    6.505362] 963       151848
    [    6.508229] 964       151980
    [    6.511099] 965       152111
    [    6.513968] 966       152242
    [    6.516835] 967       152373
    [    6.519705] 968       152505
    [    6.522575] 969       152635
    [    6.525445] 970       152766
    [    6.528311] 971       152897
    [    6.531180] 972       153028
    [    6.534050] 973       153158
    [    6.536920] 974       153289
    [    6.539786] 975       153419
    [    6.542656] 976       153549
    [    6.545526] 977       153680
    [    6.548393] 978       153810
    [    6.551263] 979       153940
    [    6.554134] 980       154070
    [    6.557005] 981       154199
    [    6.559872] 982       154329
    [    6.562742] 983       154459
    [    6.565611] 984       154588
    [    6.568478] 985       154718
    [    6.571348] 986       154847
    [    6.574218] 987       154976
    [    6.577088] 988       155105
    [    6.579955] 989       155235
    [    6.582824] 990       155363
    [    6.585692] 991       155492
    [    6.588557] 992       155621
    [    6.591427] 993       155750
    [    6.594297] 994       155879
    [    6.597167] 995       156007
    [    6.600033] 996       156135
    [    6.602902] 997       156264
    [    6.605771] 998       156392
    [    6.608636] 999       156520
    [    6.611506] 1000       156648
    [    6.614464] 1001       156776
    [    6.617420] 1002       156904
    [    6.620374] 1003       157032
    [    6.623329] 1004       157160
    [    6.626284] 1005       157287
    [    6.629240] 1006       157415
    [    6.632192] 1007       157542
    [    6.635149] 1008       157670
    [    6.638104] 1009       157797
    [    6.641061] 1010       157924
    [    6.644015] 1011       158051
    [    6.646970] 1012       158178
    [    6.649927] 1013       158305
    [    6.652882] 1014       158432
    [    6.655835] 1015       158559
    [    6.658791] 1016       158685
    [    6.661746] 1017       158812
    [    6.664700] 1018       158938
    [    6.667657] 1019       159065
    [    6.670613] 1020       159191
    [    6.673571] 1021       159317
    [    6.676523] 1022       159443
    [    6.679480] 1023       159569
    [    6.683697] mmc1: CQHCI version 5.10
    [    6.685935] davinci_gpio 42100000.gpio: IRQ index 0 not found
    [    6.693008] davinci_gpio 42100000.gpio: error -ENXIO: IRQ not populated
    [    6.706921] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [    6.714433] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [    6.722513] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [    6.723484] mmc1: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
    [    6.730595] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    6.848733] j721e-pcie 2910000.pcie: Link up
    [    6.853109] j721e-pcie 2910000.pcie: PCI host bridge to bus 0001:00
    [    6.859368] pci_bus 0001:00: root bus resource [bus 00-0f]
    [    6.864897] pci_bus 0001:00: root bus resource [io  0x10000-0x1ffff] (bus address [0x18001000-0x18010fff])
    [    6.874581] pci_bus 0001:00: root bus resource [mem 0x18011000-0x1fffffff]
    [    6.881494] pci_bus 0001:00: child_bus_ext, ava0
    [    6.886152] pci_bus 0001:00: get slot end devfn 0
    [    6.890897] pci_bus 0001:00: vendor config
    [    6.895033] pci_bus 0001:00: before generic vendor read
    [    6.900299] pci_bus 0001:00: Read Vender ID l = 0xb00d104c
    [    6.905822] pci_bus 0001:00: vendor id 0xb00d104c
    [    6.910652] pci_bus 0001:00: pci_alloc_devt end
    [    6.915227] pci_bus 0001:00: set of node  end
    [    6.919589] pci 0001:00:00.0: [104c:b00d] type 01 class 0x060400
    [    6.925597] pci_bus 0001:00: set dev end
    [    6.929508] pci_bus 0001:00: scan device end
    [    6.933815] pci 0001:00:00.0: supports D1
    [    6.937813] pci 0001:00:00.0: PME# supported from D0 D1 D3hot
    [    6.943632] pci_bus 0001:00: child_bus_ext devfn=0,nr_devs=1
    [    6.949360] pci_bus 0001:00: get slot end devfn 8
    [    6.954051] pci_bus 0001:00: vendor config
    [    6.958135] pci_bus 0001:00: before generic vendor read
    [    6.963402] pci_bus 0001:00: child_bus_ext devfn=8,nr_devs=0
    [    6.969125] pci_bus 0001:00: get slot end devfn 16
    [    6.973909] pci_bus 0001:00: vendor config
    [    6.978045] pci_bus 0001:00: before generic vendor read
    [    6.983310] pci_bus 0001:00: child_bus_ext devfn=16,nr_devs=0
    [    6.989117] pci_bus 0001:00: get slot end devfn 24
    [    6.993946] pci_bus 0001:00: vendor config
    [    6.998081] pci_bus 0001:00: before generic vendor read
    [    7.003346] pci_bus 0001:00: child_bus_ext devfn=24,nr_devs=0
    [    7.009154] pci_bus 0001:00: get slot end devfn 32
    [    7.013983] pci_bus 0001:00: vendor config
    [    7.018119] pci_bus 0001:00: before generic vendor read
    [    7.023384] pci_bus 0001:00: child_bus_ext devfn=32,nr_devs=0
    [    7.029139] pci_bus 0001:00: get slot end devfn 40
    [    7.033920] pci_bus 0001:00: vendor config
    [    7.038004] pci_bus 0001:00: before generic vendor read
    [    7.043215] pci_bus 0001:00: child_bus_ext devfn=40,nr_devs=0
    [    7.048970] pci_bus 0001:00: get slot end devfn 48
    [    7.053747] pci_bus 0001:00: vendor config
    [    7.057830] pci_bus 0001:00: before generic vendor read
    [    7.063041] pci_bus 0001:00: child_bus_ext devfn=48,nr_devs=0
    [    7.068797] pci_bus 0001:00: get slot end devfn 56
    [    7.073575] pci_bus 0001:00: vendor config
    [    7.077658] pci_bus 0001:00: before generic vendor read
    [    7.082869] pci_bus 0001:00: child_bus_ext devfn=56,nr_devs=0
    [    7.088624] pci_bus 0001:00: get slot end devfn 64
    [    7.093403] pci_bus 0001:00: vendor config
    [    7.097486] pci_bus 0001:00: before generic vendor read
    [    7.102697] pci_bus 0001:00: child_bus_ext devfn=64,nr_devs=0
    [    7.108451] pci_bus 0001:00: get slot end devfn 72
    [    7.113228] pci_bus 0001:00: vendor config
    [    7.117311] pci_bus 0001:00: before generic vendor read
    [    7.122522] pci_bus 0001:00: child_bus_ext devfn=72,nr_devs=0
    [    7.128277] pci_bus 0001:00: get slot end devfn 80
    [    7.133054] pci_bus 0001:00: vendor config
    [    7.137137] pci_bus 0001:00: before generic vendor read
    [    7.142348] pci_bus 0001:00: child_bus_ext devfn=80,nr_devs=0
    [    7.148101] pci_bus 0001:00: get slot end devfn 88
    [    7.152880] pci_bus 0001:00: vendor config
    [    7.156963] pci_bus 0001:00: before generic vendor read
    [    7.162174] pci_bus 0001:00: child_bus_ext devfn=88,nr_devs=0
    [    7.167927] pci_bus 0001:00: get slot end devfn 96
    [    7.172704] pci_bus 0001:00: vendor config
    [    7.176788] pci_bus 0001:00: before generic vendor read
    [    7.181999] pci_bus 0001:00: child_bus_ext devfn=96,nr_devs=0
    [    7.187752] pci_bus 0001:00: get slot end devfn 104
    [    7.192616] pci_bus 0001:00: vendor config
    [    7.196699] pci_bus 0001:00: before generic vendor read
    [    7.201910] pci_bus 0001:00: child_bus_ext devfn=104,nr_devs=0
    [    7.207752] pci_bus 0001:00: get slot end devfn 112
    [    7.212615] pci_bus 0001:00: vendor config
    [    7.216700] pci_bus 0001:00: before generic vendor read
    [    7.221911] pci_bus 0001:00: child_bus_ext devfn=112,nr_devs=0
    [    7.227752] pci_bus 0001:00: get slot end devfn 120
    [    7.232616] pci_bus 0001:00: vendor config
    [    7.236699] pci_bus 0001:00: before generic vendor read
    [    7.241911] pci_bus 0001:00: child_bus_ext devfn=120,nr_devs=0
    [    7.247750] pci_bus 0001:00: get slot end devfn 128
    [    7.252615] pci_bus 0001:00: vendor config
    [    7.256698] pci_bus 0001:00: before generic vendor read
    [    7.261909] pci_bus 0001:00: child_bus_ext devfn=128,nr_devs=0
    [    7.267749] pci_bus 0001:00: get slot end devfn 136
    [    7.272613] pci_bus 0001:00: vendor config
    [    7.276697] pci_bus 0001:00: before generic vendor read
    [    7.281909] pci_bus 0001:00: child_bus_ext devfn=136,nr_devs=0
    [    7.287751] pci_bus 0001:00: get slot end devfn 144
    [    7.292614] pci_bus 0001:00: vendor config
    [    7.296697] pci_bus 0001:00: before generic vendor read
    [    7.301908] pci_bus 0001:00: child_bus_ext devfn=144,nr_devs=0
    [    7.307748] pci_bus 0001:00: get slot end devfn 152
    [    7.312611] pci_bus 0001:00: vendor config
    [    7.316694] pci_bus 0001:00: before generic vendor read
    [    7.321905] pci_bus 0001:00: child_bus_ext devfn=152,nr_devs=0
    [    7.327746] pci_bus 0001:00: get slot end devfn 160
    [    7.332609] pci_bus 0001:00: vendor config
    [    7.336694] pci_bus 0001:00: before generic vendor read
    [    7.341905] pci_bus 0001:00: child_bus_ext devfn=160,nr_devs=0
    [    7.347746] pci_bus 0001:00: get slot end devfn 168
    [    7.352609] pci_bus 0001:00: vendor config
    [    7.356693] pci_bus 0001:00: before generic vendor read
    [    7.361904] pci_bus 0001:00: child_bus_ext devfn=168,nr_devs=0
    [    7.367744] pci_bus 0001:00: get slot end devfn 176
    [    7.372607] pci_bus 0001:00: vendor config
    [    7.376690] pci_bus 0001:00: before generic vendor read
    [    7.381901] pci_bus 0001:00: child_bus_ext devfn=176,nr_devs=0
    [    7.387742] pci_bus 0001:00: get slot end devfn 184
    [    7.392605] pci_bus 0001:00: vendor config
    [    7.396690] pci_bus 0001:00: before generic vendor read
    [    7.401902] pci_bus 0001:00: child_bus_ext devfn=184,nr_devs=0
    [    7.407741] pci_bus 0001:00: get slot end devfn 192
    [    7.412605] pci_bus 0001:00: vendor config
    [    7.416688] pci_bus 0001:00: before generic vendor read
    [    7.421899] pci_bus 0001:00: child_bus_ext devfn=192,nr_devs=0
    [    7.427739] pci_bus 0001:00: get slot end devfn 200
    [    7.432603] pci_bus 0001:00: vendor config
    [    7.436686] pci_bus 0001:00: before generic vendor read
    [    7.441897] pci_bus 0001:00: child_bus_ext devfn=200,nr_devs=0
    [    7.447737] pci_bus 0001:00: get slot end devfn 208
    [    7.452601] pci_bus 0001:00: vendor config
    [    7.456686] pci_bus 0001:00: before generic vendor read
    [    7.461897] pci_bus 0001:00: child_bus_ext devfn=208,nr_devs=0
    [    7.467736] pci_bus 0001:00: get slot end devfn 216
    [    7.472599] pci_bus 0001:00: vendor config
    [    7.476683] pci_bus 0001:00: before generic vendor read
    [    7.481893] pci_bus 0001:00: child_bus_ext devfn=216,nr_devs=0
    [    7.487735] pci_bus 0001:00: get slot end devfn 224
    [    7.492598] pci_bus 0001:00: vendor config
    [    7.496681] pci_bus 0001:00: before generic vendor read
    [    7.501892] pci_bus 0001:00: child_bus_ext devfn=224,nr_devs=0
    [    7.507733] pci_bus 0001:00: get slot end devfn 232
    [    7.512597] pci_bus 0001:00: vendor config
    [    7.516682] pci_bus 0001:00: before generic vendor read
    [    7.521894] pci_bus 0001:00: child_bus_ext devfn=232,nr_devs=0
    [    7.527735] pci_bus 0001:00: get slot end devfn 240
    [    7.532599] pci_bus 0001:00: vendor config
    [    7.536682] pci_bus 0001:00: before generic vendor read
    [    7.541893] pci_bus 0001:00: child_bus_ext devfn=240,nr_devs=0
    [    7.547733] pci_bus 0001:00: get slot end devfn 248
    [    7.552596] pci_bus 0001:00: vendor config
    [    7.556680] pci_bus 0001:00: before generic vendor read
    [    7.561891] pci_bus 0001:00: child_bus_ext devfn=248,nr_devs=0
    [    7.567731] pci_bus 0001:00: child_bus_ext, used_buses=0,max=0, bus->is_added 0
    [    7.575026] pci_bus 0001:00: hotplg 0, nomal 1
    [    7.579459] pci 0001:00:00.0: pci_enable_crs end max 0, ava_buses 0,pass 0, pri 0, sec 0, sub 0
    [    7.588140] pci 0001:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    7.596126] pci_generic_config_write32: 24 callbacks suppressed
    [    7.596130] pci_bus 0001:00: 2-byte config write to 0001:00:00.0 offset 0x3e may corrupt adjacent RW1C bits
    [    7.611748] pci 0001:00:00.0: btcl 2, is_card 0, broken 1
    [    7.617132] pci 0001:00:00.0: if 2
    [    7.620521] pci 0001:00:00.0: goto out 0x0002
    [    7.624865] pci_bus 0001:00: 2-byte config write to 0001:00:00.0 offset 0x3e may corrupt adjacent RW1C bits
    [    7.634585] pci_bus 0001:00: 1 pci_scan_bridge_ext max 0
    [    7.639883] pci_bus 0001:00: used_buses 1
    [    7.643879] pci_bus 0001:00: buses 0
    [    7.647445] pci 0001:00:00.0: pci_enable_crs end max 0, ava_buses 0,pass 1, pri 0, sec 0, sub 0
    [    7.656127] pci_bus 0001:00: 2-byte config write to 0001:00:00.0 offset 0x3e may corrupt adjacent RW1C bits
    [    7.665845] pci 0001:00:00.0: btcl 2, is_card 0, broken 0
    [    7.671230] pci 0001:00:00.0: if 2
    [    7.674621] pci_bus 0001:00: 2-byte config write to 0001:00:00.0 offset 0x6 may corrupt adjacent RW1C bits
    [    7.684256] pci 0001:00:00.0: fixed_buses 0, next_busnr 1
    [    7.689675] pci 0001:00:00.0: child 35639296
    [    7.693937] pci 0001:00:00.0: buses 0x000f0100
    [    7.698368] pci 0001:00:00.0: next pci_scan_child_bus_extend bctl 0x0002
    [    7.705054] pci_bus 0001:01: child_bus_ext, ava0
    [    7.709657] pci_bus 0001:01: get slot end devfn 0
    [    7.714347] pci_bus 0001:01: vendor config
    [    7.718430] pci_bus 0001:01: before generic vendor read
    [    7.723643] pci_bus 0001:01: Read Vender ID l = 0x500d2646
    [    7.729114] pci_bus 0001:01: vendor id 0x500d2646
    [    7.733892] pci_bus 0001:01: pci_alloc_devt end
    [    7.738410] pci_bus 0001:01: set of node  end
    [    7.742787] pci 0001:01:00.0: [2646:500d] type 00 class 0x010802
    [    7.748812] pci 0001:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
    [    7.755641] pci_bus 0001:01: set dev end
    [    7.759551] pci_bus 0001:01: scan device end
    [    7.763964] pci_bus 0001:00: 2-byte config write to 0001:00:00.0 offset 0xe8 may corrupt adjacent RW1C bits
    [    7.773728] pci 0001:01:00.0: 15.752 Gb/s available PCIe bandwidth, limited by 8.0 GT/s PCIe x2 link at 0001:00:00.0 (capable of 31.504 Gb/s with 8.0 GT/s PCIe x4 link)
    [    7.788792] pci_bus 0001:00: 2-byte config write to 0001:00:00.0 offset 0xd0 may corrupt adjacent RW1C bits
    [    7.798513] pci_bus 0001:00: 2-byte config write to 0001:00:00.0 offset 0xd0 may corrupt adjacent RW1C bits
    [    7.808281] pci_bus 0001:01: child_bus_ext devfn=0,nr_devs=1
    [    7.813956] pci_bus 0001:01: child_bus_ext devfn=8,nr_devs=0
    [    7.819626] pci_bus 0001:01: child_bus_ext devfn=16,nr_devs=0
    [    7.825381] pci_bus 0001:01: child_bus_ext devfn=24,nr_devs=0
    [    7.831133] pci_bus 0001:01: child_bus_ext devfn=32,nr_devs=0
    [    7.836889] pci_bus 0001:01: child_bus_ext devfn=40,nr_devs=0
    [    7.842642] pci_bus 0001:01: child_bus_ext devfn=48,nr_devs=0
    [    7.848395] pci_bus 0001:01: child_bus_ext devfn=56,nr_devs=0
    [    7.854149] pci_bus 0001:01: child_bus_ext devfn=64,nr_devs=0
    [    7.859903] pci_bus 0001:01: child_bus_ext devfn=72,nr_devs=0
    [    7.865655] pci_bus 0001:01: child_bus_ext devfn=80,nr_devs=0
    [    7.871410] pci_bus 0001:01: child_bus_ext devfn=88,nr_devs=0
    [    7.877165] pci_bus 0001:01: child_bus_ext devfn=96,nr_devs=0
    [    7.882918] pci_bus 0001:01: child_bus_ext devfn=104,nr_devs=0
    [    7.888759] pci_bus 0001:01: child_bus_ext devfn=112,nr_devs=0
    [    7.894599] pci_bus 0001:01: child_bus_ext devfn=120,nr_devs=0
    [    7.900440] pci_bus 0001:01: child_bus_ext devfn=128,nr_devs=0
    [    7.906280] pci_bus 0001:01: child_bus_ext devfn=136,nr_devs=0
    [    7.912119] pci_bus 0001:01: child_bus_ext devfn=144,nr_devs=0
    [    7.917959] pci_bus 0001:01: child_bus_ext devfn=152,nr_devs=0
    [    7.923799] pci_bus 0001:01: child_bus_ext devfn=160,nr_devs=0
    [    7.929638] pci_bus 0001:01: child_bus_ext devfn=168,nr_devs=0
    [    7.935479] pci_bus 0001:01: child_bus_ext devfn=176,nr_devs=0
    [    7.941321] pci_bus 0001:01: child_bus_ext devfn=184,nr_devs=0
    [    7.947161] pci_bus 0001:01: child_bus_ext devfn=192,nr_devs=0
    [    7.953001] pci_bus 0001:01: child_bus_ext devfn=200,nr_devs=0
    [    7.958845] pci_bus 0001:01: child_bus_ext devfn=208,nr_devs=0
    [    7.964685] pci_bus 0001:01: child_bus_ext devfn=216,nr_devs=0
    [    7.970526] pci_bus 0001:01: child_bus_ext devfn=224,nr_devs=0
    [    7.976366] pci_bus 0001:01: child_bus_ext devfn=232,nr_devs=0
    [    7.982206] pci_bus 0001:01: child_bus_ext devfn=240,nr_devs=0
    [    7.988045] pci_bus 0001:01: child_bus_ext devfn=248,nr_devs=0
    [    7.993886] pci_bus 0001:01: child_bus_ext, used_buses=0,max=1, bus->is_added 0
    [    8.001180] pci_bus 0001:01: hotplg 0, nomal 0
    [    8.005611] pci_bus 0001:01: used_buses 0
    [    8.009608] pci_bus 0001:01: 2 pci_scan_bridge_ext max 1
    [    8.014905] pci_bus 0001:01: bus scan returning with max=01
    [    8.020468] pci_bus 0001:01: busn_res: [bus 01-0f] end is updated to 01
    [    8.027067] pci_bus 0001:00: 1-byte config write to 0001:00:00.0 offset 0x1a may corrupt adjacent RW1C bits
    [    8.036786] pci 0001:00:00.0: SUBORDINATE_BUS max 1
    [    8.041649] pci 0001:00:00.0: PCI Bus 0001:01
    [    8.045993] pci 0001:00:00.0: goto out 0x0002
    [    8.050338] pci_bus 0001:00: 2-byte config write to 0001:00:00.0 offset 0x3e may corrupt adjacent RW1C bits
    [    8.060056] pci_bus 0001:00: 2 pci_scan_bridge_ext max 1
    [    8.065356] pci_bus 0001:00: bus scan returning with max=01
    [    8.070926] pci 0001:00:00.0: BAR 14: assigned [mem 0x18100000-0x181fffff]
    [    8.077786] pci 0001:01:00.0: BAR 0: assigned [mem 0x18100000-0x18103fff 64bit]
    [    8.085094] pci 0001:00:00.0: PCI bridge to [bus 01]
    [    8.090046] pci_bus 0001:00: 2-byte config write to 0001:00:00.0 offset 0x1c may corrupt adjacent RW1C bits
    [    8.099765] pci 0001:00:00.0:   bridge window [mem 0x18100000-0x181fffff]
    [    8.106630] pci_bus 0001:00: vendor config
    [    8.110715] pci_bus 0001:00: before generic vendor read
    [    8.115927] pci_bus 0001:00: Read Vender ID l = 0xb00d104c
    [    8.121401] pcieport 0001:00:00.0: enabling device (0000 -> 0002)
    [    8.127603] pcieport 0001:00:00.0: PME: Signaling with IRQ 476
    [    8.133956] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [    8.141450] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
    [    8.149529] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
    [    8.157611] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    8.268221] j721e-pcie 2920000.pcie: Link up
    [    8.272533] j721e-pcie 2920000.pcie: PCI host bridge to bus 0002:00
    [    8.278788] pci_bus 0002:00: root bus resource [bus 00-0f]
    [    8.284260] pci_bus 0002:00: root bus resource [io  0x20000-0x2ffff] (bus address [0x1000-0x10fff])
    [    8.293284] pci_bus 0002:00: root bus resource [mem 0x4400011000-0x4407ffffff] (bus address [0x00011000-0x07ffffff])
    [    8.303785] pci_bus 0002:00: child_bus_ext, ava0
    [    8.308388] pci_bus 0002:00: get slot end devfn 0
    [    8.313078] pci_bus 0002:00: vendor config
    [    8.317161] pci_bus 0002:00: before generic vendor read
    [    8.322373] pci_bus 0002:00: Read Vender ID l = 0xb00d104c
    [    8.327843] pci_bus 0002:00: vendor id 0xb00d104c
    [    8.332622] pci_bus 0002:00: pci_alloc_devt end
    [    8.337141] pci_bus 0002:00: set of node  end
    [    8.341500] pci 0002:00:00.0: [104c:b00d] type 01 class 0x060400
    [    8.347507] pci_bus 0002:00: set dev end
    [    8.351417] pci_bus 0002:00: scan device end
    [    8.355722] pci 0002:00:00.0: supports D1
    [    8.359720] pci 0002:00:00.0: PME# supported from D0 D1 D3hot
    [    8.365529] pci_bus 0002:00: child_bus_ext devfn=0,nr_devs=1
    [    8.371233] pci_bus 0002:00: get slot end devfn 8
    [    8.375923] pci_bus 0002:00: vendor config
    [    8.380006] pci_bus 0002:00: before generic vendor read
    [    8.385218] pci_bus 0002:00: child_bus_ext devfn=8,nr_devs=0
    [    8.390888] pci_bus 0002:00: get slot end devfn 16
    [    8.395665] pci_bus 0002:00: vendor config
    [    8.399749] pci_bus 0002:00: before generic vendor read
    [    8.404960] pci_bus 0002:00: child_bus_ext devfn=16,nr_devs=0
    [    8.410714] pci_bus 0002:00: get slot end devfn 24
    [    8.415491] pci_bus 0002:00: vendor config
    [    8.419575] pci_bus 0002:00: before generic vendor read
    [    8.424785] pci_bus 0002:00: child_bus_ext devfn=24,nr_devs=0
    [    8.430539] pci_bus 0002:00: get slot end devfn 32
    [    8.435315] pci_bus 0002:00: vendor config
    [    8.439398] pci_bus 0002:00: before generic vendor read
    [    8.444609] pci_bus 0002:00: child_bus_ext devfn=32,nr_devs=0
    [    8.450365] pci_bus 0002:00: get slot end devfn 40
    [    8.455143] pci_bus 0002:00: vendor config
    [    8.459227] pci_bus 0002:00: before generic vendor read
    [    8.464438] pci_bus 0002:00: child_bus_ext devfn=40,nr_devs=0
    [    8.470193] pci_bus 0002:00: get slot end devfn 48
    [    8.474969] pci_bus 0002:00: vendor config
    [    8.479052] pci_bus 0002:00: before generic vendor read
    [    8.484264] pci_bus 0002:00: child_bus_ext devfn=48,nr_devs=0
    [    8.490016] pci_bus 0002:00: get slot end devfn 56
    [    8.494793] pci_bus 0002:00: vendor config
    [    8.498876] pci_bus 0002:00: before generic vendor read
    [    8.504087] pci_bus 0002:00: child_bus_ext devfn=56,nr_devs=0
    [    8.509842] pci_bus 0002:00: get slot end devfn 64
    [    8.514618] pci_bus 0002:00: vendor config
    [    8.518702] pci_bus 0002:00: before generic vendor read
    [    8.523913] pci_bus 0002:00: child_bus_ext devfn=64,nr_devs=0
    [    8.529666] pci_bus 0002:00: get slot end devfn 72
    [    8.534443] pci_bus 0002:00: vendor config
    [    8.538527] pci_bus 0002:00: before generic vendor read
    [    8.543738] pci_bus 0002:00: child_bus_ext devfn=72,nr_devs=0
    [    8.549491] pci_bus 0002:00: get slot end devfn 80
    [    8.554267] pci_bus 0002:00: vendor config
    [    8.558351] pci_bus 0002:00: before generic vendor read
    [    8.563562] pci_bus 0002:00: child_bus_ext devfn=80,nr_devs=0
    [    8.569317] pci_bus 0002:00: get slot end devfn 88
    [    8.574094] pci_bus 0002:00: vendor config
    [    8.578177] pci_bus 0002:00: before generic vendor read
    [    8.583388] pci_bus 0002:00: child_bus_ext devfn=88,nr_devs=0
    [    8.589141] pci_bus 0002:00: get slot end devfn 96
    [    8.593918] pci_bus 0002:00: vendor config
    [    8.598001] pci_bus 0002:00: before generic vendor read
    [    8.603212] pci_bus 0002:00: child_bus_ext devfn=96,nr_devs=0
    [    8.608966] pci_bus 0002:00: get slot end devfn 104
    [    8.613830] pci_bus 0002:00: vendor config
    [    8.617913] pci_bus 0002:00: before generic vendor read
    [    8.623124] pci_bus 0002:00: child_bus_ext devfn=104,nr_devs=0
    [    8.628966] pci_bus 0002:00: get slot end devfn 112
    [    8.633830] pci_bus 0002:00: vendor config
    [    8.637913] pci_bus 0002:00: before generic vendor read
    [    8.643124] pci_bus 0002:00: child_bus_ext devfn=112,nr_devs=0
    [    8.648965] pci_bus 0002:00: get slot end devfn 120
    [    8.653828] pci_bus 0002:00: vendor config
    [    8.657911] pci_bus 0002:00: before generic vendor read
    [    8.663122] pci_bus 0002:00: child_bus_ext devfn=120,nr_devs=0
    [    8.668963] pci_bus 0002:00: get slot end devfn 128
    [    8.673826] pci_bus 0002:00: vendor config
    [    8.677909] pci_bus 0002:00: before generic vendor read
    [    8.683120] pci_bus 0002:00: child_bus_ext devfn=128,nr_devs=0
    [    8.688962] pci_bus 0002:00: get slot end devfn 136
    [    8.693825] pci_bus 0002:00: vendor config
    [    8.697909] pci_bus 0002:00: before generic vendor read
    [    8.703120] pci_bus 0002:00: child_bus_ext devfn=136,nr_devs=0
    [    8.708961] pci_bus 0002:00: get slot end devfn 144
    [    8.713824] pci_bus 0002:00: vendor config
    [    8.717907] pci_bus 0002:00: before generic vendor read
    [    8.723118] pci_bus 0002:00: child_bus_ext devfn=144,nr_devs=0
    [    8.728958] pci_bus 0002:00: get slot end devfn 152
    [    8.733822] pci_bus 0002:00: vendor config
    [    8.737906] pci_bus 0002:00: before generic vendor read
    [    8.743117] pci_bus 0002:00: child_bus_ext devfn=152,nr_devs=0
    [    8.748958] pci_bus 0002:00: get slot end devfn 160
    [    8.753821] pci_bus 0002:00: vendor config
    [    8.757904] pci_bus 0002:00: before generic vendor read
    [    8.763116] pci_bus 0002:00: child_bus_ext devfn=160,nr_devs=0
    [    8.768956] pci_bus 0002:00: get slot end devfn 168
    [    8.773820] pci_bus 0002:00: vendor config
    [    8.777903] pci_bus 0002:00: before generic vendor read
    [    8.783114] pci_bus 0002:00: child_bus_ext devfn=168,nr_devs=0
    [    8.788954] pci_bus 0002:00: get slot end devfn 176
    [    8.793817] pci_bus 0002:00: vendor config
    [    8.797901] pci_bus 0002:00: before generic vendor read
    [    8.803112] pci_bus 0002:00: child_bus_ext devfn=176,nr_devs=0
    [    8.808954] pci_bus 0002:00: get slot end devfn 184
    [    8.813817] pci_bus 0002:00: vendor config
    [    8.817901] pci_bus 0002:00: before generic vendor read
    [    8.823112] pci_bus 0002:00: child_bus_ext devfn=184,nr_devs=0
    [    8.828952] pci_bus 0002:00: get slot end devfn 192
    [    8.833816] pci_bus 0002:00: vendor config
    [    8.837899] pci_bus 0002:00: before generic vendor read
    [    8.843110] pci_bus 0002:00: child_bus_ext devfn=192,nr_devs=0
    [    8.848950] pci_bus 0002:00: get slot end devfn 200
    [    8.853813] pci_bus 0002:00: vendor config
    [    8.857897] pci_bus 0002:00: before generic vendor read
    [    8.863108] pci_bus 0002:00: child_bus_ext devfn=200,nr_devs=0
    [    8.868950] pci_bus 0002:00: get slot end devfn 208
    [    8.873814] pci_bus 0002:00: vendor config
    [    8.877897] pci_bus 0002:00: before generic vendor read
    [    8.883109] pci_bus 0002:00: child_bus_ext devfn=208,nr_devs=0
    [    8.888949] pci_bus 0002:00: get slot end devfn 216
    [    8.893812] pci_bus 0002:00: vendor config
    [    8.897896] pci_bus 0002:00: before generic vendor read
    [    8.903107] pci_bus 0002:00: child_bus_ext devfn=216,nr_devs=0
    [    8.908946] pci_bus 0002:00: get slot end devfn 224
    [    8.913809] pci_bus 0002:00: vendor config
    [    8.917893] pci_bus 0002:00: before generic vendor read
    [    8.923104] pci_bus 0002:00: child_bus_ext devfn=224,nr_devs=0
    [    8.928946] pci_bus 0002:00: get slot end devfn 232
    [    8.933810] pci_bus 0002:00: vendor config
    [    8.937893] pci_bus 0002:00: before generic vendor read
    [    8.943104] pci_bus 0002:00: child_bus_ext devfn=232,nr_devs=0
    [    8.948947] pci_bus 0002:00: get slot end devfn 240
    [    8.953810] pci_bus 0002:00: vendor config
    [    8.957893] pci_bus 0002:00: before generic vendor read
    [    8.963104] pci_bus 0002:00: child_bus_ext devfn=240,nr_devs=0
    [    8.968944] pci_bus 0002:00: get slot end devfn 248
    [    8.973807] pci_bus 0002:00: vendor config
    [    8.977890] pci_bus 0002:00: before generic vendor read
    [    8.983102] pci_bus 0002:00: child_bus_ext devfn=248,nr_devs=0
    [    8.988945] pci_bus 0002:00: child_bus_ext, used_buses=0,max=0, bus->is_added 0
    [    8.996239] pci_bus 0002:00: hotplg 0, nomal 1
    [    9.000672] pci 0002:00:00.0: pci_enable_crs end max 0, ava_buses 0,pass 0, pri 0, sec 0, sub 0
    [    9.009353] pci 0002:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    9.017339] pci 0002:00:00.0: btcl 2, is_card 0, broken 1
    [    9.022723] pci 0002:00:00.0: if 2
    [    9.026115] pci 0002:00:00.0: goto out 0x0002
    [    9.030459] pci_bus 0002:00: 1 pci_scan_bridge_ext max 0
    [    9.035757] pci_bus 0002:00: used_buses 1
    [    9.039754] pci_bus 0002:00: buses 0
    [    9.043319] pci 0002:00:00.0: pci_enable_crs end max 0, ava_buses 0,pass 1, pri 0, sec 0, sub 0
    [    9.052003] pci 0002:00:00.0: btcl 2, is_card 0, broken 0
    [    9.057388] pci 0002:00:00.0: if 2
    [    9.060779] pci 0002:00:00.0: fixed_buses 0, next_busnr 1
    [    9.066194] pci 0002:00:00.0: child 35643392
    [    9.070454] pci 0002:00:00.0: buses 0x000f0100
    [    9.074885] pci 0002:00:00.0: next pci_scan_child_bus_extend bctl 0x0002
    [    9.081570] pci_bus 0002:01: child_bus_ext, ava0
    [    9.086175] pci_bus 0002:01: get slot end devfn 0
    [    9.090864] pci_bus 0002:01: vendor config
    [    9.094948] pci_bus 0002:01: before generic vendor read
    [    9.100161] pci_bus 0002:01: Read Vender ID l = 0x500d2646
    [    9.105632] pci_bus 0002:01: vendor id 0x500d2646
    [    9.110411] pci_bus 0002:01: pci_alloc_devt end
    [    9.114928] pci_bus 0002:01: set of node  end
    [    9.119306] pci 0002:01:00.0: [2646:500d] type 00 class 0x010802
    [    9.125330] pci 0002:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
    [    9.132158] pci_bus 0002:01: set dev end
    [    9.136069] pci_bus 0002:01: scan device end
    [    9.140525] pci 0002:01:00.0: 15.752 Gb/s available PCIe bandwidth, limited by 8.0 GT/s PCIe x2 link at 0002:00:00.0 (capable of 31.504 Gb/s with 8.0 GT/s PCIe x4 link)
    [    9.164907] pci_bus 0002:01: child_bus_ext devfn=0,nr_devs=1
    [    9.170582] pci_bus 0002:01: child_bus_ext devfn=8,nr_devs=0
    [    9.176250] pci_bus 0002:01: child_bus_ext devfn=16,nr_devs=0
    [    9.182003] pci_bus 0002:01: child_bus_ext devfn=24,nr_devs=0
    [    9.187757] pci_bus 0002:01: child_bus_ext devfn=32,nr_devs=0
    [    9.193510] pci_bus 0002:01: child_bus_ext devfn=40,nr_devs=0
    [    9.199264] pci_bus 0002:01: child_bus_ext devfn=48,nr_devs=0
    [    9.205017] pci_bus 0002:01: child_bus_ext devfn=56,nr_devs=0
    [    9.210769] pci_bus 0002:01: child_bus_ext devfn=64,nr_devs=0
    [    9.216525] pci_bus 0002:01: child_bus_ext devfn=72,nr_devs=0
    [    9.222278] pci_bus 0002:01: child_bus_ext devfn=80,nr_devs=0
    [    9.228033] pci_bus 0002:01: child_bus_ext devfn=88,nr_devs=0
    [    9.233786] pci_bus 0002:01: child_bus_ext devfn=96,nr_devs=0
    [    9.239540] pci_bus 0002:01: child_bus_ext devfn=104,nr_devs=0
    [    9.245380] pci_bus 0002:01: child_bus_ext devfn=112,nr_devs=0
    [    9.251220] pci_bus 0002:01: child_bus_ext devfn=120,nr_devs=0
    [    9.257060] pci_bus 0002:01: child_bus_ext devfn=128,nr_devs=0
    [    9.262900] pci_bus 0002:01: child_bus_ext devfn=136,nr_devs=0
    [    9.268740] pci_bus 0002:01: child_bus_ext devfn=144,nr_devs=0
    [    9.274581] pci_bus 0002:01: child_bus_ext devfn=152,nr_devs=0
    [    9.280421] pci_bus 0002:01: child_bus_ext devfn=160,nr_devs=0
    [    9.286263] pci_bus 0002:01: child_bus_ext devfn=168,nr_devs=0
    [    9.292103] pci_bus 0002:01: child_bus_ext devfn=176,nr_devs=0
    [    9.297944] pci_bus 0002:01: child_bus_ext devfn=184,nr_devs=0
    [    9.303784] pci_bus 0002:01: child_bus_ext devfn=192,nr_devs=0
    [    9.309623] pci_bus 0002:01: child_bus_ext devfn=200,nr_devs=0
    [    9.315464] pci_bus 0002:01: child_bus_ext devfn=208,nr_devs=0
    [    9.321303] pci_bus 0002:01: child_bus_ext devfn=216,nr_devs=0
    [    9.327144] pci_bus 0002:01: child_bus_ext devfn=224,nr_devs=0
    [    9.332985] pci_bus 0002:01: child_bus_ext devfn=232,nr_devs=0
    [    9.338824] pci_bus 0002:01: child_bus_ext devfn=240,nr_devs=0
    [    9.344664] pci_bus 0002:01: child_bus_ext devfn=248,nr_devs=0
    [    9.350507] pci_bus 0002:01: child_bus_ext, used_buses=0,max=1, bus->is_added 0
    [    9.357801] pci_bus 0002:01: hotplg 0, nomal 0
    [    9.362231] pci_bus 0002:01: used_buses 0
    [    9.366228] pci_bus 0002:01: 2 pci_scan_bridge_ext max 1
    [    9.371525] pci_bus 0002:01: bus scan returning with max=01
    [    9.377087] pci_bus 0002:01: busn_res: [bus 01-0f] end is updated to 01
    [    9.383685] pci 0002:00:00.0: SUBORDINATE_BUS max 1
    [    9.388549] pci 0002:00:00.0: PCI Bus 0002:01
    [    9.392893] pci 0002:00:00.0: goto out 0x0002
    [    9.397238] pci_bus 0002:00: 2 pci_scan_bridge_ext max 1
    [    9.402535] pci_bus 0002:00: bus scan returning with max=01
    [    9.408103] pci 0002:00:00.0: BAR 14: assigned [mem 0x4400100000-0x44001fffff]
    [    9.415313] pci 0002:01:00.0: BAR 0: assigned [mem 0x4400100000-0x4400103fff 64bit]
    [    9.422966] pci 0002:00:00.0: PCI bridge to [bus 01]
    [    9.427920] pci 0002:00:00.0:   bridge window [mem 0x4400100000-0x44001fffff]
    [    9.435121] pci_bus 0002:00: vendor config
    [    9.439206] pci_bus 0002:00: before generic vendor read
    [    9.444418] pci_bus 0002:00: Read Vender ID l = 0xb00d104c
    [    9.449892] pcieport 0002:00:00.0: enabling device (0000 -> 0002)
    [    9.456096] pcieport 0002:00:00.0: PME: Signaling with IRQ 478
    [    9.462795] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
    [    9.473258] ti-udma 31150000.dma-controller: Channels: 122 (tchan: 61, rchan: 61, gp-rflow: 16)
    [    9.524876] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    9.533871] davinci_mdio 46000f00.mdio: phy[1]: device 46000f00.mdio:01, driver SMSC LAN8820 / LAN8820i
    [    9.543311] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
    [    9.556933] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
    [    9.563936] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
    [    9.571150] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
    [    9.577473] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0
    [    9.588167] debugfs: Directory 'pd:241' with parent 'pm_genpd' already present!
    [    9.588231] mmc0: CQHCI version 5.10
    [    9.595536] debugfs: Directory 'pd:240' with parent 'pm_genpd' already present!
    [    9.606353] debugfs: Directory 'pd:239' with parent 'pm_genpd' already present!
    [    9.619761] ALSA device list:
    [    9.622725]   No soundcards found.
    [   10.661484] mmc0: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
    [   10.669248] Waiting for root device PARTUUID=de3fd043-02...
    [   10.724109] mmc0: new ultra high speed DDR50 SDHC card at address 5048
    [   10.730946] mmcblk0: mmc0:5048 SDCIT 15.0 GiB
    [   10.738233]  mmcblk0: p1 p2
    [   11.082341] EXT4-fs (mmcblk0p2): recovery complete
    [   11.088785] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [   11.096895] VFS: Mounted root (ext4 filesystem) on device 179:2.
    [   11.104723] devtmpfs: mounted
    [   11.107993] Freeing unused kernel memory: 1856K
    [   11.112578] Run /sbin/init as init process
    [   11.264640] systemd[1]: System time before build time, advancing clock.
    [   11.316025] NET: Registered protocol family 10
    [   11.320918] Segment Routing with IPv6
    [   11.337238] systemd[1]: systemd 244 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
    [   11.358726] systemd[1]: Detected architecture arm64.
    Welcome to Arago 2021.09!
    [   11.393840] systemd[1]: Set hostname to <j7-evm>.
    [   11.567497] systemd[1]: /lib/systemd/system/docker.socket:6: ListenStream= references a path below legacy directory /var/run/, updating /var/run/docker.sock → /run/docker.sock; please update the unit file accordingly.
    [   11.632331] random: systemd: uninitialized urandom read (16 bytes read)
    [   11.639065] systemd[1]: system-getty.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
    [   11.651392] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
    [   11.661348] systemd[1]: Created slice system-getty.slice.
    [  OK  ] Created slice system-getty.slice.
    [   11.680946] random: systemd: uninitialized urandom read (16 bytes read)
    [   11.688189] systemd[1]: Created slice system-serial\x2dgetty.slice.
    [  OK  ] Created slice system-serial\x2dgetty.slice.
    [   11.708933] random: systemd: uninitialized urandom read (16 bytes read)
    [   11.716125] systemd[1]: Created slice system-serial\x2dgetty9600.slice.
    [  OK  ] Created slice system-serial\x2dgetty9600.slice.
    [   11.737544] systemd[1]: Created slice User and Session Slice.
    [  OK  ] Created slice User and Session Slice.
    [   11.761051] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [  OK  ] Started Dispatch Password …ts to Console Directory Watch.
    [   11.784973] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [  OK  ] Started Forward Password R…uests to Wall Directory Watch.
    [   11.808982] systemd[1]: Reached target Paths.
    [  OK  ] Reached target Paths.
    [   11.824919] systemd[1]: Reached target Remote File Systems.
    [  OK  ] Reached target Remote File Systems.
    [   11.844912] systemd[1]: Reached target Slices.
    [  OK  ] Reached target Slices.
    [   11.860916] systemd[1]: Reached target Swap.
    [  OK  ] Reached target Swap.
    [   11.878486] systemd[1]: Listening on RPCbind Server Activation Socket.
    [  OK  ] Listening on RPCbind Server Activation Socket.
    [   11.900945] systemd[1]: Reached target RPC Port Mapper.
    [  OK  ] Reached target RPC Port Mapper.
    [   11.923449] systemd[1]: Listening on Process Core Dump Socket.
    [  OK  ] Listening on Process Core Dump Socket.
    [   11.945032] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [  OK  ] Listening on initctl Compatibility Named Pipe.
    [   11.977790] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
    [   11.986099] systemd[1]: Listening on Journal Socket (/dev/log).
    [  OK  ] Listening on Journal Socket (/dev/log).
    [   12.009135] systemd[1]: Listening on Journal Socket.
    [  OK  ] Listening on Journal Socket.
    [   12.025191] systemd[1]: Listening on Network Service Netlink Socket.
    [  OK  ] Listening on Network Service Netlink Socket.
    [   12.049106] systemd[1]: Listening on udev Control Socket.
    [  OK  ] Listening on udev Control Socket.
    [   12.069020] systemd[1]: Listening on udev Kernel Socket.
    [  OK  ] Listening on udev Kernel Socket.
    [   12.091590] systemd[1]: Mounting Huge Pages File System...
    [   12.111850] systemd[1]: Mounting POSIX Message Queue File System...
    [   12.135066] systemd[1]: Mounting Kernel Debug File System...
    [   12.156074] systemd[1]: Mounting Temporary Directory (/tmp)...
    [   12.175232] systemd[1]: Starting Create list of static device nodes for the current kernel...
             Starting Create list of st…odes for the current kernel...
    [   12.203503] systemd[1]: Starting Start psplash boot splash screen...
    [   12.227779] systemd[1]: Starting RPC Bind...
    [   12.245053] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
    [   12.257328] systemd[1]: Starting Journal Service...
    [   12.281145] systemd[1]: Starting Load Kernel Modules...
    [   12.296973] cryptodev: loading out-of-tree module taints kernel.
    [   12.305391] systemd[1]: Starting Remount Root and Kernel File Systems...
             Starting Remount Root and Kernel File Systems cryptodev: driver 1.10 loaded.
    [0m...
    [   12.335923] systemd[1]: Starting udev Coldplug all Devices...
    [   12.343575] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    [   12.367442] systemd[1]: Started RPC Bind.
    [  OK  ] Started RPC Bind.
    [   12.381355] systemd[1]: Mounted Huge Pages File System.
    [  OK  ] Mounted Huge Pages File System.
    [   12.405300] systemd[1]: Mounted POSIX Message Queue File System.
    [  OK  ] Mounted POSIX Message Queue File System.
    [   12.429284] systemd[1]: Mounted Kernel Debug File System.
    [  OK  ] Mounted Kernel Debug File System.
    [   12.449315] systemd[1]: Mounted Temporary Directory (/tmp).
    [  OK  ] Mounted Temporary Directory (/tmp).
    [   12.474266] systemd[1]: Started Create list of static device nodes for the current kernel.
    [  OK  ] Started Create list of sta… nodes for the current kernel.
    [   12.501274] systemd[1]: psplash-start.service: Main process exited, code=exited, status=255/EXCEPTION
    [   12.510742] systemd[1]: psplash-start.service: Failed with result 'exit-code'.
    [   12.518868] systemd[1]: Failed to start Start psplash boot splash screen.
    [FAILED] Failed to start Start psplash boot splash screen.
    See 'systemctl status psplash-start.service' for details.
    [   12.552936] systemd[1]: Dependency failed for Start psplash-systemd progress communication helper.
    [DEPEND] Dependency failed for Star…progress communication helper.
    [   12.576902] systemd[1]: psplash-systemd.service: Job psplash-systemd.service/start failed with result 'dependency'.
    [   12.587573] systemd[1]: Started Journal Service.
    [  OK  ] Started Journal Service.
    [  OK  ] Started Load Kernel Modules.
    [  OK  ] Started Remount Root and Kernel File Systems.
             Mounting Kernel Configuration File System...
             Starting Flush Journal to Persistent Storage...
    [   12.664759] systemd-journald[163]: Received client request to flush runtime journal.
             Starting Apply Kernel Variables...
             Starting Create Static Device Nodes in /dev...
    [  OK  ] Mounted Kernel Configuration File System.
    [  OK  ] Started Flush Journal to Persistent Storage.
    [  OK  ] Started Apply Kernel Variables.
    [  OK  ] Started udev Coldplug all Devices.
    [  OK  ] Started Create Static Device Nodes in /dev.
    [  OK  ] Reached target Local File Systems (Pre).
             Mounting /media/ram...
             Mounting /var/volatile...
             Starting udev Wait for Complete Device Initialization...
             Starting udev Kernel Device Manager...
    [  OK  ] Mounted /media/ram.
    [  OK  ] Mounted /var/volatile.
             Starting Load/Save Random Seed...
    [  OK  ] Reached target Local File Systems.
             Starting Create Volatile Files and Directories...
    [  OK  ] Started udev Kernel Device Manager.
    [  OK  ] Started Create Volatile Files and Directories.
             Starting Network Time Synchronization...
             Starting Update UTMP about System Boot/Shutdown...
    [  OK  ] Started Update UTMP about System Boot/Shutdown.
    [  OK  ] Started Network Time Synchronization.
    [  OK  ] Reached target System Time Set.
    [  OK  ] Reached target System Time Synchronized.
    [   13.430853] nvme nvme0: pci function 0001:01:00.0
    [   13.455513] pci_bus 0001:01: vendor config
    [   13.459655] pci_bus 0001:01: before generic vendor read
    [   13.470683] pci_bus 0001:01: Read Vender ID l = 0x500d2646
    [   13.480923] nvme 0001:01:00.0: enabling device (0000 -> 0002)
    [   13.509505] nvme nvme1: pci function 0002:01:00.0
    [   13.530267] nvme nvme0: missing or invalid SUBNQN field.
    [   13.539700] nvme nvme0: 2/0/0 default/read/poll queues
    [   13.652942] pci_bus 0002:01: vendor config
    [   13.657062] pci_bus 0002:01: before generic vendor read
    [   13.662326] pci_bus 0002:01: Read Vender ID l = 0x500d2646
    [   13.667826] nvme 0002:01:00.0: enabling device (0000 -> 0002)
    [   13.689800] nvme nvme1: missing or invalid SUBNQN field.
    [   13.701230] nvme nvme1: 2/0/0 default/read/poll queues
    [   14.799492] usbcore: registered new interface driver usbfs
    [   14.854694] usbcore: registered new interface driver hub
    [   14.869599] usbcore: registered new device driver usb
    [  OK  ] Created slice system-systemd\x2dfsck.slice.
    [  OK  ] Found device KINGSTON OM8PDP3512B-A01.
             Starting File System Check on /dev/nvme0n1...
             Starting File System Check on /dev/nvme1n1...
    [  OK  ] Found device /dev/mmcblk0p1.
             Starting File System Check on /dev/mmcblk0p1...
    [  OK  ] Started File System Check on /dev/nvme1n1.
             Mounting /run/media/nvme1n1...
    [  OK  ] Started File System Check on /dev/nvme0n1.
             Mounting /run/media/nvme0n1...
    [  OK  ] Started File System Check on /dev/mmcblk0p1.
    [   15.311904] EXT4-fs (nvme1n1): mounted filesystem with ordered data mode. Opts: (null)
             Mounting /run/media/mmcblk0p1...
    [   15.329893] EXT4-fs (nvme0n1): mounted filesystem with ordered data mode. Opts: (null)
    [  OK  ] Mounted /run/media/nvme1n1.
    [  OK  ] Mounted /run/media/nvme0n1.
    [  OK  ] Mounted /run/media/mmcblk0p1.
    [   15.372884] random: crng init done
    [   15.376277] random: 7 urandom warning(s) missed due to ratelimiting
    [  OK  ] Started Load/Save Random Seed.
    [  OK  ] Started udev Wait for Complete Device Initialization.
    [  OK  ] Started Hardware RNG Entropy Gatherer Daemon.
    [  OK  ] Reached target System Initialization.
    [  OK  ] Started Daily rotation of log files.
    [  OK  ] Started Daily Cleanup of Temporary Directories.
    [  OK  ] Reached target Timers.
    [  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
    [  OK  ] Listening on D-Bus System Message Bus Socket.
             Starting Docker Socket for the API.
    [  OK  ] Listening on dropbear.socket.
             Starting Reboot and dump vmcore via kexec...
    [  OK  ] Listening on Docker Socket for the API.
    [  OK  ] Started Reboot and dump vmcore via kexec.
    [  OK  ] Reached target Sockets.
    [  OK  ] Reached target Basic System.
    [  OK  ] Started Job spooling tools.
    [  OK  ] Started Periodic Command Scheduler.
    [  OK  ] Started D-Bus System Message Bus.
             Starting Print notice about GPLv3 packages...
             Starting set host name as per compatible name...
             Starting IPv6 Packet Filtering Framework...
             Starting IPv4 Packet Filtering Framework...
    [  OK  ] Started irqbalance daemon.
             Starting Telephony service...
             Starting rc.pvr.service...
             Starting startwlanap...
             Starting startwlansta...
             Starting Login Service...
    [  OK  ] Started TEE Supplicant.
             Starting Update weston ini… based on the platform name...
    [  OK  ] Started IPv6 Packet Filtering Framework.
    [  OK  ] Started IPv4 Packet Filtering Framework.
    [  OK  ] Started set host name as per compatible name.
    [  OK  ] Started startwlansta.
    [  OK  ] Reached target Network (Pre).
             Starting Network Service...
    [  OK  ] Started Network Service.
    [  OK  ] Started rc.pvr.service.
    [  OK  ] Started startwlanap.
    [  OK  ] Started Update weston ini …ge based on the platform name.
             Starting Wait for Network to be Configured...
             Starting Network Name Resolution...
             Starting weston.service...
    [  OK  ] Started Telephony service.
    [   16.325129] {SMSC DRIVER} phy write 27 0x0100
    [  OK  ] Listening on Load/Save RF …itch Status /dev/rfkill Watch.
    [   16.351349] SMSC LAN8820 / LAN8820i 46000f00.mdio:01: attached PHY driver [SMSC LAN8820 / LAN8820i] (mii_bus:phy_addr=46000f00.mdio:01, irq=POLL)
    [   16.369935] Bluetooth: Core ver 2.22
    [   16.374273] NET: Registered protocol family 31
    [   16.384957] Bluetooth: HCI device and connection manager initialized
    [   16.391369] Bluetooth: HCI socket layer initialized
    [   16.396270] Bluetooth: L2CAP socket layer initialized
    [   16.404027] Bluetooth: SCO socket layer initialized
    [   16.411121] am65-cpsw-nuss 46000000.ethernet eth0: Link is Down
    [  OK  ] Started Login Service.
    [  OK  ] Started Network Name Resolution.
    [  OK  ] Reached target Network.
    [  OK  ] Reached target Host and Network Name Lookups.
             Starting Avahi mDNS/DNS-SD Stack...
             Starting Enable and configure wl18xx bluetooth stack...
    [  OK  ] Started NFS status monitor for NFSv2/3 locking..
             Starting Simple Network Ma…ent Protocol (SNMP) Daemon....
             Starting Permit User Sessions...
    [  OK  ] Started Permit User Sessions.
    [  OK  ] Started Getty on tty1.
    [  OK  ] Started Serial Getty on ttyS3.
    [  OK  ] Started Serial Getty on ttyS2.
    [  OK  ] Reached target Login Prompts.
             Starting Synchronize System and HW clocks...
    [  OK  ] Started Avahi mDNS/DNS-SD Stack.
    [FAILED] Failed to start Synchronize System and HW clocks.
    See 'systemctl status sync-clocks.service' for details.
    [  OK  ] Started Enable and configure wl18xx bluetooth stack.
    [  OK  ] Started Simple Network Man…ement Protocol (SNMP) Daemon..
    NOTICE: This file system contains the following GPLv3 packages:
    	autoconf
    	bash-dev
    	bash
    	bc
    	binutils
    	cifs-utils
    	coreutils-stdbuf
    	coreutils
    	cpio
    	cpp-symlinks
    	cpp
    	dosfstools
    	elfutils
    	g++-symlinks
    	g++
    	gawk
    	gcc-symlinks
    	gcc
    	gdb
    	gdbserver
    	gettext
    	glmark2
    	gstreamer1.0-libav-dev
    	gstreamer1.0-libav
    	gzip
    	less
    	libasm1
    	libbfd
    	libdw1
    	libelf1
    	libgdbm-compat4
    	libgdbm-dev
    	libgdbm6
    	libgettextlib
    	libgettextsrc
    	libgmp-dev
    	libgmp10
    	libgmpxx4
    	libidn2-0
    	libidn2-dev
    	libmpc3
    	libmpfr6
    	libreadline-dev
    	libreadline8
    	libunistring-dev
    	libunistring2
    	m4-dev
    	m4
    	make
    	nettle-dev
    	nettle
    	parted
    	python3-rfc3987
    	python3-strict-rfc3339
    	tar
    	which
    	zeromq
    If you do not wish to distribute GPLv3 components please remove
    the above packages prior to distribution.  This can be done using
    the opkg remove command.  i.e.:
        opkg remove <package>
    Where <package> is the name printed in the list above
    NOTE: If the package is a dependency of another package you
          will be notified of the dependent packages.  You should
          use the --force-removal-of-dependent-packages option to
          also remove the dependent packages as well
    [  OK  ] Started Print notice about GPLv3 packages.
    [  OK  ] Started weston.service.
             Starting DEMO...
             Starting telnetd.service...
    [  OK  ] Started DEMO.
    [  OK  ] Started telnetd.service.
     _____                    _____           _         _
    |  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
    |     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
    |__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
                  |___|                    |___|
    Arago Project http://arago-project.org j7-evm ttyS2
    Arago 2021.09 j7-evm ttyS2
    j7-evm login: root (automatic login)
    root@j7-evm:~# echo 405 > /sys/class/gpio/export
    root@j7-evm:~# echo 406 > /sys/class/gpio/export
    root@j7-evm:~# echo high | tee /sys/class/gpio/gpio406/direction  /sys/class/gpio/gpio405/direction
    high
    root@j7-evm:~# echo 1 > /sys/bus/pci/devices/0000\:00\:00.0/remove
    [   87.325074] pci_generic_config_write32: 45 callbacks suppressed
    [   87.325080] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x84 may corrupt adjacent RW1C bits
    [   87.340778] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0xdc may corrupt adjacent RW1C bits
    [   87.350534] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x92 may corrupt adjacent RW1C bits
    [   87.360252] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x9c may corrupt adjacent RW1C bits
    [   87.370063] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x92 may corrupt adjacent RW1C bits
    [   87.379812] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
    [   87.389545] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
    [   87.399237] pci_bus 0000:01: busn_res: [bus 01] is released
    root@j7-evm:~# echo 1 > /sys/bus/pci/rescan
    [   93.486840] pci 0000:00:00.0: [104c:b00d] type 01 class 0x060400
    [   93.492842] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
    [   93.502481] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
    [   93.520328] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x92 may corrupt adjacent RW1C bits
    [   93.530062] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0xb2 may corrupt adjacent RW1C bits
    [   93.539815] pci 0000:00:00.0: supports D1
    [   93.543815] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
    [   93.549552] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x84 may corrupt adjacent RW1C bits
    [   94.206130] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits
    [   94.262539] pci 0000:01:00.0: [12d8:c232] type 01 class 0x060400
    [   94.268560] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x0007ffff]
    [   94.283216] pci 0000:01:00.0: PME# supported from D0 D3hot D3cold
    [   94.289347] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0xe8 may corrupt adjacent RW1C bits
    [   94.299287] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0xd0 may corrupt adjacent RW1C bits
    [   94.309521] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0xd0 may corrupt adjacent RW1C bits
    [   94.526146] pci 0000:01:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [   94.583161] pci_bus 0000:02: busn_res: can not insert [bus 02-01] under [bus 01] (conflicts with (null) [bus 01])
    ERROR:   Unhandled External Abort received on 0x80000001 from S-EL1
    ERROR:   exception reason=0 syndrome=0xbf000000
    Unhandled Exception from EL1
    x0             = 0xffff8000148c0000
    x1             = 0x0000000000000000
    x2             = 0xffff800015400008
    x3             = 0x0000000000000002
    x4             = 0x000000000000000b
    x5             = 0xffff0008035b6000
    x6             = 0x0000000000000001
    x7             = 0xc0000000ffffefff
    x8             = 0x0000000000017fe8
    x9             = 0xffff8000111e23f8
    x10            = 0xffff8000111e23a0
    x11            = 0xffff8000111fa3e0
    x12            = 0x00000000ffffffea
    x13            = 0xffff00080268ad30
    x14            = 0x00000000000009be
    x15            = 0xffff00080268ad30
    x16            = 0x0000000000000000
    x17            = 0x0000000000000000
    x18            = 0x0000000000000010
    x19            = 0xffff80001630f824
    x20            = 0x0000000000000004
    x21            = 0xffff0008035bc800
    x22            = 0x0000000000000087
    x23            = 0xffff80001630f914
    x24            = 0x0000000000000000
    x25            = 0xffff800011313a98
    x26            = 0xffff800010dd58b8
    x27            = 0xffff800010dd58a8
    x28            = 0xffff800010dd5880
    x29            = 0xffff80001630f7a0
    x30            = 0xffff8000104f1b3c
    scr_el3        = 0x000000000000073d
    sctlr_el3      = 0x0000000030cd183f
    cptr_el3       = 0x0000000000000000
    tcr_el3        = 0x0000000080803520
    daif           = 0x00000000000002c0
    mair_el3       = 0x00000000004404ff
    spsr_el3       = 0x0000000020000085
    elr_el3        = 0xffff8000104f1b54
    ttbr0_el3      = 0x0000000070010c00
    esr_el3        = 0x00000000bf000000
    far_el3        = 0x0000000000000000
    spsr_el1       = 0x0000000040000005
    elr_el1        = 0xffff8000100b2ec0
    spsr_abt       = 0x0000000000000000
    spsr_und       = 0x0000000000000000
    spsr_irq       = 0x0000000000000000
    spsr_fiq       = 0x0000000000000000
    sctlr_el1      = 0x0000000034d4d91d
    actlr_el1      = 0x0000000000000000
    cpacr_el1      = 0x0000000000300000
    csselr_el1     = 0x0000000000000000
    sp_el1         = 0xffff80001630f7a0
    esr_el1        = 0x0000000056000000
    ttbr0_el1      = 0x0000000881972000
    ttbr1_el1      = 0x0b16000082f60000
    mair_el1       = 0x000c0400bb44ffff
    amair_el1      = 0x0000000000000000
    tcr_el1        = 0x00000034f5d07590
    tpidr_el1      = 0xffff80086eac0000
    tpidr_el0      = 0x0000ffffa5923c40
    tpidrro_el0    = 0x0000000000000000
    par_el1        = 0x0000000000000000
    mpidr_el1      = 0x0000000080000001
    afsr0_el1      = 0x0000000000000000
    afsr1_el1      = 0x0000000000000000
    contextidr_el1 = 0x0000000000000000
    vbar_el1       = 0xffff800010010800
    cntp_ctl_el0   = 0x0000000000000005
    cntp_cval_el0  = 0x00000004a07cd96d
    cntv_ctl_el0   = 0x0000000000000000
    cntv_cval_el0  = 0x0000000000000000
    cntkctl_el1    = 0x00000000000000d6
    sp_el0         = 0x000000007000abd0
    isr_el1        = 0x0000000000000040
    dacr32_el2     = 0x0000000000000000
    ifsr32_el2     = 0x0000000000000000
    cpuectlr_el1   = 0x0000001b00000040
    cpumerrsr_el1  = 0x0000000000000000
    l2merrsr_el1   = 0x0000000000000000
    /usr/sbin/lspci
    0000:00:00.0 PCI bridge: Texas Instruments Device b00d
    0001:00:00.0 PCI bridge: Texas Instruments Device b00d
    0001:01:00.0 Non-Volatile memory controller: Kingston Technology Company, Inc. Device 500d (rev 01)
    0002:00:00.0 PCI bridge: Texas Instruments Device b00d
    0002:01:00.0 Non-Volatile memory controller: Kingston Technology Company, Inc. Device 500d (rev 01)
    I got the PCIeSW evaluation board.
    Although the environment changes from the above, we are testing the connection with TDA4VM EVM and PCIe Slot.
    At this time, an error has occurred in the scan at startup. This error occurs at the same position as in Custom Board.
    Expand the log when connecting TDA4VM EVM and PCIeSW EVM.
    U-Boot SPL 2021.01-g44a87e3ab8 (Sep 06 2022 - 07:31:49 +0000)
    Model: Texas Instruments K3 J721E SoC
    Board: J721EX-PM2-SOM rev A
    SYSFW ABI: 3.1 (firmware rev 0x0016 '22.1.1--v2022.01 (Terrific Llam')
    Trying to boot from MMC2
    Starting ATF on ARM64 core...
    NOTICE:  BL31: v2.5(release):08.03.00.002-dirty
    NOTICE:  BL31: Built : 08:27:01, Jun 28 2022
    U-Boot SPL 2021.01-g44a87e3ab8 (Mar 29 2023 - 04:13:35 +0000)
    U-Boot 2021.01-g44a87e3ab8 (Mar 29 2023 - 04:13:35 +0000)
    SoC:   J721E SR1.1
    DRAM:  4 GiB
    Flash: 0 Bytes
    MMC:   sdhci@4f80000: 0, sdhci@4fb0000: 1
    In:    serial@2800000
    Out:   serial@2800000
    Err:   serial@2800000
    am65_cpsw_nuss ethernet@46000000: K3 CPSW: nuss_ver: 0x6BA00101 cpsw_ver: 0x6BA80100 ale_ver: 0x00293904 Ports:1 mdio_freq:1000000
    Net:   eth0: ethernet@46000000port@1
    Hit any key to stop autoboot:  2  1  0
    switch to partitions #0, OK
    mmc1 is current device
    SD/MMC found on device 1
    Failed to load 'boot.scr'
    Failed to load 'uEnv.txt'
    20236800 bytes read in 845 ms (22.8 MiB/s)
    102282 bytes read in 14 ms (7 MiB/s)
       Loading Device Tree to 000000008fee4000, end 000000008fffffff ... OK
    Starting kernel ...
    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
    [    0.000000] Linux version 5.10.100-g7a7a3af903 (oe-user@oe-host) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #1 SMP PREEMPT Tue Apr 25 08:48:44 UTC 2023
    [    0.000000] Machine model: Texas Instruments K3 J721E SoC
    [    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
    [    0.000000] printk: bootconsole [ns16550a0] enabled
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a1000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a1100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a2000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a2100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a3000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a3100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a4000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a4100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a5000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a5000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a5100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a5100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node c66-dma-memory@a6000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node c66-memory@a6100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node c66-dma-memory@a7000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node c66-memory@a7100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node c71-dma-memory@a8000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node c71-memory@a8100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000ac000000, size 2 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-virtual-eth-queues@ac000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000ac200000, size 30 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-virtual-eth-buffers@ac200000, compatible id shared-dma-pool
    [    0.000000] Zone ranges:
    [    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
    [    0.000000]   DMA32    empty
    [    0.000000]   Normal   [mem 0x0000000100000000-0x00000008ffffffff]
    [    0.000000] Movable zone start for each node
    [    0.000000] Early memory node ranges
    [    0.000000]   node   0: [mem 0x0000000080000000-0x000000009e7fffff]
    [    0.000000]   node   0: [mem 0x000000009e800000-0x00000000a8ffffff]
    [    0.000000]   node   0: [mem 0x00000000a9000000-0x00000000a9ffffff]
    [    0.000000]   node   0: [mem 0x00000000aa000000-0x00000000abbfffff]
    [    0.000000]   node   0: [mem 0x00000000abc00000-0x00000000abffffff]
    [    0.000000]   node   0: [mem 0x00000000ac000000-0x00000000adffffff]
    [    0.000000]   node   0: [mem 0x00000000ae000000-0x00000000ffffffff]
    [    0.000000]   node   0: [mem 0x0000000880000000-0x00000008ffffffff]
    [    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff]
    [    0.000000] cma: Reserved 512 MiB at 0x00000000e0000000
    [    0.000000] psci: probing for conduit method from DT.
    [    0.000000] psci: PSCIv1.1 detected in firmware.
    [    0.000000] psci: Using standard PSCI v0.2 function IDs
    [    0.000000] psci: Trusted OS migration not required
    [    0.000000] psci: SMC Calling Convention v1.2
    [    0.000000] percpu: Embedded 2 pages/cpu s50776 r8192 d72104 u131072
    [    0.000000] Detected PIPT I-cache on CPU0
    [    0.000000] CPU features: detected: GIC system register CPU interface
    [    0.000000] CPU features: detected: EL2 vector hardening
    [    0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 65472
    [    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),1m(ospi.sysfw),256k(ospi.env.backup),57088k@8m(ospi.rootfs),256k(ospi.phypattern);47034000.hyperbus:512k(hbmc.tiboot3),2m(hbmc.tispl),4m(hbmc.u-boot),256k(hbmc.env),1m(hbmc.sysfw),-@8m(hbmc.rootfs) root=PARTUUID=f430005c-02 rw rootfstype=ext4 rootwait
    [    0.000000] Dentry cache hash table entries: 524288 (order: 6, 4194304 bytes, linear)
    [    0.000000] Inode-cache hash table entries: 262144 (order: 5, 2097152 bytes, linear)
    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
    [    0.000000] software IO TLB: mapped [mem 0x00000000dc000000-0x00000000e0000000] (64MB)
    [    0.000000] Memory: 3338176K/4194304K available (11392K kernel code, 1330K rwdata, 4608K rodata, 1984K init, 752K bss, 331840K reserved, 524288K cma-reserved)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
    [    0.000000] rcu: 	RCU event tracing is enabled.
    [    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
    [    0.000000] 	Trampoline variant of Tasks RCU enabled.
    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    [    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
    [    0.000000] GICv3: 960 SPIs implemented
    [    0.000000] GICv3: 0 Extended SPIs implemented
    [    0.000000] GICv3: Distributor has no Range Selector support
    [    0.000000] GICv3: 16 PPIs implemented
    [    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
    [    0.000000] ITS [mem 0x01820000-0x0182ffff]
    [    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
    [    0.000000] ITS@0x0000000001820000: allocated 1048576 Devices @880800000 (flat, esz 8, psz 64K, shr 0)
    [    0.000000] ITS: using cache flushing for cmd queue
    [    0.000000] GICv3: using LPI property table @0x00000008800b0000
    [    0.000000] GIC: using cache flushing for LPI property table
    [    0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008800c0000
    [    0.000000] random: get_random_bytes called from start_kernel+0x31c/0x4cc with crng_init=0
    [    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
    [    0.000002] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
    [    0.008355] Console: colour dummy device 80x25
    [    0.012917] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [    0.023586] pid_max: default: 32768 minimum: 301
    [    0.028334] LSM: Security Framework initializing
    [    0.033075] Mount-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
    [    0.040641] Mountpoint-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
    [    0.049578] rcu: Hierarchical SRCU implementation.
    [    0.054629] Platform MSI: msi-controller@1820000 domain created
    [    0.060875] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
    [    0.070168] EFI services will not be available.
    [    0.074914] smp: Bringing up secondary CPUs ...
    [    0.080152] Detected PIPT I-cache on CPU1
    [    0.080174] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
    [    0.080185] GICv3: CPU1: using allocated LPI pending table @0x00000008800d0000
    [    0.080218] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
    [    0.080269] smp: Brought up 1 node, 2 CPUs
    [    0.109616] SMP: Total of 2 processors activated.
    [    0.114421] CPU features: detected: 32-bit EL0 Support
    [    0.119675] CPU features: detected: CRC32 instructions
    [    0.133460] CPU: All CPU(s) started at EL2
    [    0.137656] alternatives: patching kernel code
    [    0.142632] devtmpfs: initialized
    [    0.151031] KASLR disabled due to lack of seed
    [    0.155689] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.165651] futex hash table entries: 512 (order: -1, 32768 bytes, linear)
    [    0.173305] pinctrl core: initialized pinctrl subsystem
    [    0.178884] DMI not present or invalid.
    [    0.183106] NET: Registered protocol family 16
    [    0.190454] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
    [    0.197755] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.205758] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.214063] thermal_sys: Registered thermal governor 'step_wise'
    [    0.214065] thermal_sys: Registered thermal governor 'power_allocator'
    [    0.220515] cpuidle: using governor menu
    [    0.231311] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.238271] ASID allocator initialised with 65536 entries
    [    0.261027] HugeTLB registered 16.0 GiB page size, pre-allocated 0 pages
    [    0.267888] HugeTLB registered 512 MiB page size, pre-allocated 0 pages
    [    0.274646] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.282574] cryptd: max_cpu_qlen set to 1000
    [    0.288305] ACPI: Interpreter disabled.
    [    0.292432] k3-chipinfo 43000014.chipid: Family:J721E rev:SR2.0 JTAGID[0x1bb6402f] Detected
    [    0.301223] vsys_3v3: supplied by evm_12v0
    [    0.305583] vsys_5v0: supplied by evm_12v0
    [    0.310318] iommu: Default domain type: Translated
    [    0.315491] SCSI subsystem initialized
    [    0.319619] mc: Linux media interface: v0.10
    [    0.323989] videodev: Linux video capture interface: v2.00
    [    0.329616] pps_core: LinuxPPS API ver. 1 registered
    [    0.334689] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.344025] PTP clock support registered
    [    0.348043] EDAC MC: Ver: 3.0.0
    [    0.351821] FPGA manager framework
    [    0.355332] Advanced Linux Sound Architecture Driver Initialized.
    [    0.361937] clocksource: Switched to clocksource arch_sys_counter
    [    0.368365] VFS: Disk quotas dquot_6.6.0
    [    0.372411] VFS: Dquot-cache hash table entries: 8192 (order 0, 65536 bytes)
    [    0.379717] pnp: PnP ACPI: disabled
    [    0.385574] NET: Registered protocol family 2
    [    0.390153] IP idents hash table entries: 65536 (order: 3, 524288 bytes, linear)
    [    0.398742] tcp_listen_portaddr_hash hash table entries: 4096 (order: 0, 65536 bytes, linear)
    [    0.407510] TCP established hash table entries: 32768 (order: 2, 262144 bytes, linear)
    [    0.415707] TCP bind hash table entries: 32768 (order: 3, 524288 bytes, linear)
    [    0.423525] TCP: Hash tables configured (established 32768 bind 32768)
    [    0.430268] UDP hash table entries: 2048 (order: 0, 65536 bytes, linear)
    [    0.437159] UDP-Lite hash table entries: 2048 (order: 0, 65536 bytes, linear)
    [    0.444544] NET: Registered protocol family 1
    [    0.449228] RPC: Registered named UNIX socket transport module.
    [    0.455291] RPC: Registered udp transport module.
    [    0.460095] RPC: Registered tcp transport module.
    [    0.464898] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.471482] PCI: CLS 0 bytes, default 64
    [    0.475843] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
    [    0.486108] Initialise system trusted keyrings
    [    0.490714] workingset: timestamp_bits=46 max_order=16 bucket_order=0
    [    0.498982] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.505179] NFS: Registering the id_resolver key type
    [    0.510353] Key type id_resolver registered
    [    0.514624] Key type id_legacy registered
    [    0.518740] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.525588] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    0.533227] 9p: Installing v9fs 9p2000 file system support
    [    0.558569] Key type asymmetric registered
    [    0.562757] Asymmetric key parser 'x509' registered
    [    0.567753] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
    [    0.575312] io scheduler mq-deadline registered
    [    0.579938] io scheduler kyber registered
    [    0.585247] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
    [    0.591421] pinctrl-single 11c000.pinctrl: 173 pins, size 692
    [    0.597816] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
    [    0.605622] switchtec: loaded.
    [    0.610396] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
    [    0.616657] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
    [    0.624478] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
    [    0.632653] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x00001faf)
    [    0.641616] arm-smmu-v3 36600000.iommu: allocated 524288 entries for cmdq
    [    0.650464] arm-smmu-v3 36600000.iommu: allocated 524288 entries for evtq
    [    0.658176] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to wired irqs
    [    0.671165] brd: module loaded
    [    0.676938] loop: module loaded
    [    0.680848] megasas: 07.714.04.00-rc1
    [    0.686436] tun: Universal TUN/TAP device driver, 1.6
    [    0.691872] igbvf: Intel(R) Gigabit Virtual Function Network Driver
    [    0.698280] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
    [    0.704352] sky2: driver version 1.30
    [    0.708670] VFIO - User Level meta-driver version: 0.3
    [    0.714363] i2c /dev entries driver
    [    0.718246] Error: Driver 'k3-soc-thermal' is already registered, aborting...
    [    0.725912] sdhci: Secure Digital Host Controller Interface driver
    [    0.732229] sdhci: Copyright(c) Pierre Ossman
    [    0.736941] sdhci-pltfm: SDHCI platform and OF driver helper
    [    0.743320] ledtrig-cpu: registered to indicate activity on CPUs
    [    0.749642] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    0.756837] optee: probing for conduit method.
    [    0.761396] optee: revision 3.12 (3d47a131)
    [    0.761640] optee: initialized driver
    [    0.771039] NET: Registered protocol family 17
    [    0.775648] 9pnet: Installing 9P2000 support
    [    0.780033] Key type dns_resolver registered
    [    0.784541] Loading compiled-in X.509 certificates
    [    0.794229] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
    [    0.800564] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
    [    0.808743] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0016 '22.1.1--v2022.01 (Terrific Llam')
    [    0.838171] random: fast init done
    [    0.870866] davinci-mcasp 2ba0000.mcasp: IRQ common not found
    [    0.878565] omap_i2c 40b00000.i2c: bus 0 rev0.12 at 100 kHz
    [    0.884635] omap_i2c 40b10000.i2c: bus 1 rev0.12 at 100 kHz
    [    0.890684] omap_i2c 42120000.i2c: bus 2 rev0.12 at 100 kHz
    [    0.897105] pca953x 3-0020: supply vcc not found, using dummy regulator
    [    0.903917] pca953x 3-0020: using no AI
    [    0.930734] pca953x 3-0022: supply vcc not found, using dummy regulator
    [    0.937535] pca953x 3-0022: using AI
    [    0.941803] gpio-480 (CTRL_PM_I2C_OE): hogged as output/high
    [    0.947778] gpio-481 (MCASP/TRACE_MUX_S0): hogged as output/low
    [    0.954019] gpio-482 (MCASP/TRACE_MUX_S1): hogged as output/high
    [    0.960512] omap_i2c 2000000.i2c: bus 3 rev0.12 at 400 kHz
    [    0.966919] omap_i2c 2010000.i2c: bus 4 rev0.12 at 400 kHz
    [    0.976639] omap_i2c 2020000.i2c: bus 5 rev0.12 at 400 kHz
    [    0.982945] pca953x 6-0020: supply vcc not found, using dummy regulator
    [    0.989766] pca953x 6-0020: using no AI
    [    1.014604] omap_i2c 2030000.i2c: bus 6 rev0.12 at 400 kHz
    [    1.020689] omap_i2c 2040000.i2c: bus 7 rev0.12 at 100 kHz
    [    1.026645] omap_i2c 2050000.i2c: bus 8 rev0.12 at 100 kHz
    [    1.032869] pca953x 9-0020: supply vcc not found, using dummy regulator
    [    1.039682] pca953x 9-0020: using no AI
    [    1.066264] omap_i2c 2060000.i2c: bus 9 rev0.12 at 400 kHz
    [    1.072700] ti-sci-intr bus@100000:bus@28380000:interrupt-controller2: Interrupt Router 137 domain created
    [    1.082677] ti-sci-intr bus@100000:interrupt-controller0: Interrupt Router 131 domain created
    [    1.091482] ti-sci-intr bus@100000:main-navss:interrupt-controller1: Interrupt Router 213 domain created
    [    1.101319] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created
    [    1.124313] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    1.131990] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    1.140266] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    1.148544] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    2.159460] j721e-pcie 2900000.pcie: PCI host bridge to bus 0000:00
    [    2.165882] pci_bus 0000:00: root bus resource [bus 00-ff]
    [    2.171495] pci_bus 0000:00: root bus resource [io  0x0000-0xffff] (bus address [0x10001000-0x10010fff])
    [    2.181185] pci_bus 0000:00: root bus resource [mem 0x10011000-0x17ffffff]
    [    2.188237] pci 0000:00:00.0: [104c:b00d] type 01 class 0x060400
    [    2.194376] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
    [    2.204245] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
    [    2.214135] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0xe8 may corrupt adjacent RW1C bits
    [    2.224096] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits
    [    2.234063] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x92 may corrupt adjacent RW1C bits
    [    2.244023] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0xb2 may corrupt adjacent RW1C bits
    [    2.254006] pci 0000:00:00.0: supports D1
    [    2.258099] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
    [    2.263971] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x84 may corrupt adjacent RW1C bits
    [    2.275651] pci 0000:00:00.0: scanning [bus 00-00] behind bridge, pass 0
    [    2.282508] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    2.290690] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits
    [    2.300648] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits
    [    2.310608] pci 0000:00:00.0: scanning [bus 00-00] behind bridge, pass 1
    [    2.317456] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits
    [    2.327453] pci 0000:00:00.0: write PRIMARY_BUS  00ff0100, busn_res.end 0xff is_cardbus 0
    [    2.337280] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
    [    2.344051] pci 0000:00:00.0: PCI bridge to [bus 01]
    [    2.349342] pcieport 0000:00:00.0: PME: Signaling with IRQ 61
    [    2.355368] pcieport 0000:00:00.0: AER: enabled with IRQ 61
    [    2.361580] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [    2.369255] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [    2.377531] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [    2.385808] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    2.496997] j721e-pcie 2910000.pcie: Link up
    [    2.501413] j721e-pcie 2910000.pcie: PCI host bridge to bus 0001:00
    [    2.507819] pci_bus 0001:00: root bus resource [bus 00-ff]
    [    2.513424] pci_bus 0001:00: root bus resource [io  0x10000-0x1ffff] (bus address [0x18001000-0x18010fff])
    [    2.523292] pci_bus 0001:00: root bus resource [mem 0x18011000-0x1fffffff]
    [    2.530338] pci 0001:00:00.0: [104c:b00d] type 01 class 0x060400
    [    2.536537] pci 0001:00:00.0: supports D1
    [    2.540630] pci 0001:00:00.0: PME# supported from D0 D1 D3hot
    [    2.548162] pci 0001:00:00.0: scanning [bus 00-00] behind bridge, pass 0
    [    2.555015] pci 0001:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    2.563204] pci 0001:00:00.0: scanning [bus 00-00] behind bridge, pass 1
    [    2.570091] pci 0001:00:00.0: write PRIMARY_BUS  00ff0100, busn_res.end 0xff is_cardbus 0
    [    2.578501] pci 0001:01:00.0: [12d8:c232] type 01 class 0x060400
    [    2.584658] pci 0001:01:00.0: reg 0x10: [mem 0x00000000-0x0007ffff]
    [    2.591277] pci 0001:01:00.0: PME# supported from D0 D3hot D3cold
    [    2.597676] pci 0001:01:00.0: 15.752 Gb/s available PCIe bandwidth, limited by 8.0 GT/s PCIe x2 link at 0001:00:00.0 (capable of 63.008 Gb/s with 8.0 GT/s PCIe x8 link)
    [    2.623450] pci 0001:01:00.0: scanning [bus 00-00] behind bridge, pass 0
    [    2.630302] pci 0001:01:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    2.638495] pci 0001:01:00.0: scanning [bus 00-00] behind bridge, pass 1
    [    2.645431] pci 0001:01:00.0: write PRIMARY_BUS  000c0201, busn_res.end 0xff is_cardbus 0
    x0             = 0xffff800014b60000
    x2             = 0xffff800016400008
    x5             = 0xffff0008024d8800
    x6             = 0xffff800011b8f724
    x7             = 0x000000000000ea60
    x8             = 0x0000000080b5111d
    x9             = 0x00000000c23212d8
    x10            = 0xffff8000112a2498
    x11            = 0xffff8000112ba4d8
    x13            = 0xffff000800312130
    x14            = 0x0000000000000165
    x15            = 0xffff000800311c00
    x16            = 0xffff0008003718d0
    x19            = 0xffff800011b8f664
    x21            = 0xffff0008024d9000
    x23            = 0xffff800011b8f724
    x25            = 0xffff8000113d8ac0
    x26            = 0xffff800010e63248
    x27            = 0x0000000000000000
    x28            = 0xffff000800577000
    x29            = 0xffff800011b8f5e0
    x30            = 0xffff8000104f682c
    elr_el3        = 0xffff8000104f6844
    spsr_el1       = 0x0000000060000005
    elr_el1        = 0xffff8000100b3f70
    sp_el1         = 0xffff800011b8f5e0
    esr_el1        = 0x0000000000000000
    ttbr0_el1      = 0x0000000082ff0000
    ttbr1_el1      = 0x0000000083000000
    tpidr_el1      = 0xffff80086e9d0000
    tpidr_el0      = 0x0000000000000000
    cntp_cval_el0  = 0x0000000060f722e3
    Regardless of the timing of the scan, I believe the error is occurring when accessing the PCIeSW.
    Takumi
  • Hi Takumi-san,
    I have a couple of questions to clarify my understanding. In the previous E2E thread, you had mentioned:
    "The DRA829 evaluation board uses the firmware with the RC side settings described below.
    software-dl.ti.com/.../PCIe_End_Point.html"
    The documentation that is pointed to is when DRA829 is configured as EP, but from your statement it seems DRA829 is configured as RC. I assume the DRA829 is configured as RC but can you confirm? This will narrow down the relevant code to check within the PCIe driver.
    From the logs shared, my understanding is that when using the custom board, the board is able to boot up into Linux and doing a rescan causes the kernel to crash, while using the TI DRA829 EVM the kernel crashes during boot. And 2x PCIe lanes are connected to the PCIe SW which is then connected to 2 instances of 2x PCIe lanes for a total of 4x PCIe lanes.
    What are the device(s) that are connected to the PCIe switch when collecting these logs? Is it two NVMe SSD cards, or two other DRA829V? Mainly asking since previous thread mentions that two other DRA829V are connected, while in the lspci logs it seems like two SSD cards are connected.
    Does doing a rescan with no devices connected to PCIe switch cause a crash? If it crashes, then we can isolate the issue to the connection between DRA829V and PCIe switch.
    Lastly, is there a recommended standalone PCIe switch card that we can buy that can be connected easily to the TI DRA829 EVM board? From searching online for the part number mentioned in the thread, I was not sure if the PCIe switch mentioned is a PCIe card that can easily be slotted into our EVM board, or if it is just the chip and needs to be designed into a custom board. If it is a card instead of just a chip, then I would like to check with my manager to see if it is possible for us to procure a switch to see if we can recreate the issue.
    Takuma
  • Hi Takuma-san
    The DRA829 that is getting the logs is configured as RC.
    For host (RC) settings, use the ones published in the following HOST device settings.
    https://software-dl.ti.com/jacinto7/esd/processor-sdk-linux-rt-jacinto7/08_02_00_01/exports/docs/linux/Foundational_Components/Kernel/Kernel_Drivers/PCIe/PCIe_End_Point.html
    A custom board (RC) connects a PI7C9X3G1632GP and two NVMeSSDs.
    Eight DRA829V are connected to PI7C9X3G1632GP.
    Even if there are no devices attached to the PCIe switch
    I get an error when I run a rescan.
    There is no PCIe switch card recommended for purchase.
    PI7C9X3G1632GP is for chip sales only. I borrowed EVM.
    Regarding the PCIe switch, I'm having the same problem with the PEX 8648.
    Takumi
  • Hi Takumi,
    Looks like the issue is isolated to the connection between RC and PCIe switch. Could you share logs from the RC-side for this particular configuration when there is no devices connected to PCIe switch?
    Understood. I'll see if I can obtain a random PCIe switch online to see if I can reproduce the issue on my end. I am buying a card that is titled "Dual M.2 Pcie Nvme X4 Adapter With Pcie Bifurcation Function" which should allow me to plug in 2x SSD cards to the 4xlane PCIe ports on the TI EVMs. Shipment is planned to come in June 20, so hands-on experimentation TI-side will start next week at the earliest.
    Takuma
  • Hi Takumi,
    As an update, I received the PCIe switch card today and will be doing some initial experiments.
    Takuma
  • Hi Takumi,
    We found some interesting behaviors for the PCIe switch. When using the DRA829V TI EVM, we are also able to reproduce the issue that you were seeing.
    However, when using a similar processor, the DRA821 TI EVM, the board is able to enumerate the PCIe switch. Issue looks to be very specific to the DRA829V EVM. We will be looking into this and I will keep you updated if we find any other interesting results/experiments/fixes. If you do not hear back from me and want an update, please let me know by posting in this E2E and I will let you know the latest.
    Takuma
  • Hi, Takuma-san,
    Thank you for your response.
    We were also able to enumerate the external PCIeSW when using another processor's AM69A EVM. So I think it's a problem specific to the DRA829.
    Takumi
  • Hi Takumi,
    Thanks for the information. We are still trying to root cause what the issue is, but I do have some ideas. Both AM69A and DRA821 have a PCIe PHY that is different from DRA829.
    So the most suspicious piece of code right now is the PHY-specific code which are phy-cadence-sierra.c and phy-cadence-torrent.c. The difference in code is quite large (although flow is similar), so it would take a few days to list up the differences and do some experiments to gain some more information about the issue.
    In the meantime, could you post output from "/usr/sbin/lspci -vvv" on the custom board? This should get more verbose information about the PCIe switch device. If the switch supports ARI based on the logs from lspci, then we could try an experiment to see if enabling ARI would work around the issue we are seeing.
    Takuma
  • Hi Takuma-san
    The result of "/usr/sbin/lspci -vvv" on Custom board is shown below.
    PCIeSW is connected to the Custom Board, but an error occurs when rescanning, so the command is executed just before that.
      boot -> PCIeSW reset off -> "lspci" ->rescan
    0000:00:00.0 PCI bridge: Texas Instruments Device b00d (prog-if 00 [Normal decode])
    	Control: I/O- Mem- BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
    	Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
    	Latency: 0
    	Interrupt: pin A routed to IRQ 36
    	Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
    	I/O behind bridge: 0000f000-00000fff [disabled]
    	Memory behind bridge: fff00000-000fffff [disabled]
    	Prefetchable memory behind bridge: 00000000fff00000-00000000000fffff [disabled]
    	Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR- <PERR-
    	BridgeCtl: Parity- SERR+ NoISA- VGA- VGA16- MAbort- >Reset- FastB2B-
    		PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
    	Capabilities: [80] Power Management version 3
    		Flags: PMEClk- DSI- D1+ D2- AuxCurrent=0mA PME(D0+,D1+,D2-,D3hot+,D3cold-)
    		Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
    	Capabilities: [90] MSI: Enable+ Count=1/1 Maskable+ 64bit+
    		Address: 0000000001000000  Data: 0000
    		Masking: 00000000  Pending: 00000000
    	Capabilities: [b0] MSI-X: Enable- Count=1 Masked-
    		Vector table: BAR=0 offset=00000000
    		PBA: BAR=0 offset=00000008
    	Capabilities: [c0] Express (v2) Root Port (Slot+), MSI 00
    		DevCap:	MaxPayload 256 bytes, PhantFunc 0
    			ExtTag- RBE+
    		DevCtl:	CorrErr- NonFatalErr- FatalErr- UnsupReq-
    			RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop+
    			MaxPayload 128 bytes, MaxReadReq 512 bytes
    		DevSta:	CorrErr- NonFatalErr- FatalErr- UnsupReq- AuxPwr- TransPend-
    		LnkCap:	Port #0, Speed 8GT/s, Width x2, ASPM L1, Exit Latency L1 <8us
    			ClockPM- Surprise- LLActRep- BwNot+ ASPMOptComp+
    		LnkCtl:	ASPM Disabled; RCB 64 bytes Disabled- CommClk-
    			ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
    		LnkSta:	Speed 8GT/s (ok), Width x2 (ok)
    			TrErr- Train- SlotClk- DLActive- BWMgmt- ABWMgmt+
    		SltCap:	AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug- Surprise-
    			Slot #0, PowerLimit 0.000W; Interlock- NoCompl-
    		SltCtl:	Enable: AttnBtn- PwrFlt- MRL- PresDet- CmdCplt- HPIrq- LinkChg-
    			Control: AttnInd Off, PwrInd Off, Power+ Interlock-
    		SltSta:	Status: AttnBtn- PowerFlt- MRL+ CmdCplt- PresDet- Interlock-
    			Changed: MRL- PresDet- LinkState-
    		RootCap: CRSVisible-
    		RootCtl: ErrCorrectable- ErrNon-Fatal- ErrFatal- PMEIntEna+ CRSVisible-
    		RootSta: PME ReqID 0000, PMEStatus- PMEPending-
    		DevCap2: Completion Timeout: Range B, TimeoutDis+, NROPrPrP-, LTR+
    			 10BitTagComp+, 10BitTagReq-, OBFF Not Supported, ExtFmt+, EETLPPrefix+, MaxEETLPPrefixes 1
    			 EmergencyPowerReduction Not Supported, EmergencyPowerReductionInit-
    			 FRS-, LN System CLS Not Supported, TPHComp-, ExtTPHComp-, ARIFwd+
    			 AtomicOpsCap: Routing- 32bit- 64bit- 128bitCAS-
    		DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR+, OBFF Disabled ARIFwd-
    			 AtomicOpsCtl: ReqEn- EgressBlck-
    		LnkCtl2: Target Link Speed: 8GT/s, EnterCompliance- SpeedDis-
    			 Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
    			 Compliance De-emphasis: -6dB
    		LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete+, EqualizationPhase1+
    			 EqualizationPhase2+, EqualizationPhase3+, LinkEqualizationRequest-
    	Capabilities: [100 v2] Advanced Error Reporting
    		UESta:	DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
    		UEMsk:	DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
    		UESvrt:	DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
    		CESta:	RxErr- BadTLP- BadDLLP- Rollover- Timeout- AdvNonFatalErr-
    		CEMsk:	RxErr- BadTLP- BadDLLP- Rollover- Timeout- AdvNonFatalErr+
    		AERCap:	First Error Pointer: 00, ECRCGenCap+ ECRCGenEn- ECRCChkCap+ ECRCChkEn-
    			MultHdrRecCap- MultHdrRecEn- TLPPfxPres- HdrLogCap-
    		HeaderLog: 00000000 00000000 00000000 00000000
    		RootCmd: CERptEn- NFERptEn- FERptEn-
    		RootSta: CERcvd- MultCERcvd- UERcvd- MultUERcvd-
    			 FirstFatal- NonFatalMsg- FatalMsg- IntMsg 0
    		ErrorSrc: ERR_COR: 0000 ERR_FATAL/NONFATAL: 0000
    	Capabilities: [150 v1] Device Serial Number 00-00-00-00-00-00-00-00
    	Capabilities: [300 v1] Secondary PCI Express
    		LnkCtl3: LnkEquIntrruptEn-, PerformEqu-
    		LaneErrStat: 0
    	Capabilities: [4c0 v1] Virtual Channel
    		Caps:	LPEVC=0 RefClk=100ns PATEntryBits=1
    		Arb:	Fixed- WRR32- WRR64- WRR128-
    		Ctrl:	ArbSelect=Fixed
    		Status:	InProgress-
    		VC0:	Caps:	PATOffset=00 MaxTimeSlots=1 RejSnoopTrans-
    			Arb:	Fixed- WRR32- WRR64- WRR128- TWRR128- WRR256-
    			Ctrl:	Enable+ ID=0 ArbSelect=Fixed TC/VC=ff
    			Status:	NegoPending- InProgress-
    		VC1:	Caps:	PATOffset=00 MaxTimeSlots=1 RejSnoopTrans-
    			Ctrl:	Enable- ID=1 ArbSelect=Fixed TC/VC=00
    		VC2:	Caps:	PATOffset=00 MaxTimeSlots=1 RejSnoopTrans-
    			Ctrl:	Enable- ID=2 ArbSelect=Fixed TC/VC=00
    		VC3:	Caps:	PATOffset=00 MaxTimeSlots=1 RejSnoopTrans-
    			Ctrl:	Enable- ID=3 ArbSelect=Fixed TC/VC=00
    	Capabilities: [5c0 v1] Address Translation Service (ATS)
    		ATSCap:	Invalidate Queue Depth: 01
    		ATSCtl:	Enable-, Smallest Translation Unit: 00
    	Capabilities: [640 v1] Page Request Interface (PRI)
    		PRICtl: Enable- Reset-
    		PRISta: RF- UPRGI- Stopped+
    		Page Request Capacity: 00000001, Page Request Allocation: 00000000
    	Capabilities: [900 v1] L1 PM Substates
    		L1SubCap: PCI-PM_L1.2+ PCI-PM_L1.1+ ASPM_L1.2+ ASPM_L1.1+ L1_PM_Substates+
    			  PortCommonModeRestoreTime=255us PortTPowerOnTime=26us
    		L1SubCtl1: PCI-PM_L1.2- PCI-PM_L1.1- ASPM_L1.2- ASPM_L1.1-
    			   T_CommonMode=0us LTR1.2_Threshold=0ns
    		L1SubCtl2: T_PwrOn=10us
    	Kernel driver in use: pcieport
    0001:00:00.0 PCI bridge: Texas Instruments Device b00d (prog-if 00 [Normal decode])
    	Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
    	Latency: 0
    	Interrupt: pin A routed to IRQ 476
    	Memory behind bridge: 18100000-181fffff [size=1M]
    		Address: 0000000001040000  Data: 0000
    			ExtTag- RBE+
    			TrErr- Train- SlotClk- DLActive- BWMgmt+ ABWMgmt-
    		LaneErrStat: 0
    		Status:	InProgress-
    			   T_CommonMode=255us LTR1.2_Threshold=458752ns
    		L1SubCtl2: T_PwrOn=220us
    0001:01:00.0 Non-Volatile memory controller: Kingston Technology Company, Inc. Device 500d (rev 01) (prog-if 02 [NVM Express])
    	Subsystem: Kingston Technology Company, Inc. Device 500d
    	Latency: 0
    	Interrupt: pin A routed to IRQ 475
    	Region 0: Memory at 18100000 (64-bit, non-prefetchable) [size=16K]
    	Capabilities: [80] Express (v2) Endpoint, MSI 00
    		DevCap:	MaxPayload 128 bytes, PhantFunc 0, Latency L0s unlimited, L1 unlimited
    			ExtTag+ AttnBtn- AttnInd- PwrInd- RBE+ FLReset+ SlotPowerLimit 0.000W
    			RlxdOrd+ ExtTag+ PhantFunc- AuxPwr- NoSnoop+ FLReset-
    		LnkCap:	Port #1, Speed 8GT/s, Width x4, ASPM L1, Exit Latency L1 unlimited
    			ClockPM- Surprise- LLActRep- BwNot- ASPMOptComp+
    		LnkSta:	Speed 8GT/s (ok), Width x2 (downgraded)
    			TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
    		DevCap2: Completion Timeout: Range ABCD, TimeoutDis+, NROPrPrP-, LTR+
    			 10BitTagComp-, 10BitTagReq-, OBFF Not Supported, ExtFmt+, EETLPPrefix-
    			 FRS-, TPHComp-, ExtTPHComp-
    			 AtomicOpsCap: 32bit- 64bit- 128bitCAS-
    	Capabilities: [d0] MSI-X: Enable+ Count=9 Masked-
    		Vector table: BAR=0 offset=00002000
    		PBA: BAR=0 offset=00003000
    	Capabilities: [e0] MSI: Enable- Count=1/8 Maskable+ 64bit+
    		Address: 0000000000000000  Data: 0000
    	Capabilities: [f8] Power Management version 3
    		Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot-,D3cold-)
    	Capabilities: [100 v1] Latency Tolerance Reporting
    		Max snoop latency: 0ns
    		Max no snoop latency: 0ns
    	Capabilities: [110 v1] L1 PM Substates
    			  PortCommonModeRestoreTime=10us PortTPowerOnTime=220us
    			   T_CommonMode=0us LTR1.2_Threshold=458752ns
    	Capabilities: [200 v2] Advanced Error Reporting
    		UESvrt:	DLP+ SDES- TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP+ ECRC- UnsupReq- ACSViol-
    		AERCap:	First Error Pointer: 00, ECRCGenCap- ECRCGenEn- ECRCChkCap+ ECRCChkEn-
    		LaneErrStat: 0
    	Kernel driver in use: nvme
    	Kernel modules: nvme
    0002:00:00.0 PCI bridge: Texas Instruments Device b00d (prog-if 00 [Normal decode])
    	Latency: 0
    	Interrupt: pin A routed to IRQ 478
    	Memory behind bridge: 00100000-001fffff [size=1M]
    		Address: 0000000001080000  Data: 0000
    			ExtTag- RBE+
    		LaneErrStat: 0
    		Status:	InProgress-
    0002:01:00.0 Non-Volatile memory controller: Kingston Technology Company, Inc. Device 500d (rev 01) (prog-if 02 [NVM Express])
    	Latency: 0
    	Interrupt: pin A routed to IRQ 477
    	Region 0: Memory at 4400100000 (64-bit, non-prefetchable) [size=16K]
    		LaneErrStat: 0
    root@j7-evm:~#
    Takumi
  • Hi Takumi-san,
    From the logs, it looks like there is no capabilities for ARI (Alternative Routing-ID Interpretation), so we will probably not be able to do a workaround. We will continue to debug this issue.
    Thank you for your patience.
    Takuma
  • Hi, Takuma-san,
    You said that the PHY-specific code was suspect, but what is the status of the confirmation after that?
    Takumi
  • Hi Takumi,
    Unfortunately, I have not been able to confirm if this is an issue with the PHY-specific code, or an issue with the PCIe driver itself which only manifests due to the combination of the specific PHY that is being used.
    In terms of current situation, based on the logs and looking through the code, it seems the logs are generated from pci_scan_bridge_extend in probe.c. Specifically, this code does two passes for scanning devices. Once to scan devices configured by BIOS, and then another scan for remaining busses. This second pass is what is failing.
    Now, we are still in the process of root causing why this second pass is failing only on DRA829V, and would need some more time on this.
    Takuma
  • Hi, Takuma-san,
    Thank you for your reply.
    We would like to determine whether the matter can be resolved by the end of July.
    we appreciate your cooperation.
    Takumi
  • Hi Takumi-san,
    Apologies for the late reply. Good news that I can share with you is that we think we have located the root cause, and there is a workaround that seems to work with my PCIe switch on my setup.
    Could you try applying this patch and see if it works for you?
    https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/791/0001_2D00_Temporary_2D00_workaround_2D00_to_2D00_disable_2D00_kernel_2D00_panic_2D00_for_2D00_pci.patch
    For context on the issue:
    We found that errata i2086 was indeed causing the issue. However, instead of issues with polling non-existent device functions on a single device, the issue seems to be that the default behavior for PCIe switch is to probe all 256 possible device IDs that could be on its bus. Like the errata describes, probing a non-existent device causes a UR response. CPU considers it a non-recoverable bus error, even though in reality it is recoverable, causing a kernel panic.
    As a warning, the shared patch is not the cleanest of workarounds, since what it does is it assumes non-recoverable error as recoverable and suppresses this error response. However, as long as no other errors with the ID of 0xbf000000 happens, then for the case of enabling PCIe switch on DRA829 there should be no issues.
    Takuma
  • Hi Takuma-san
    Thank you for posting the patch.
    I tried to apply the patch immediately.
    I got the same error as before.
    The combination used is TDA4VM EVM and PCIeSW EVM.
    I will also expand the log at this time.
    SoC:   J721E SR1.1
    DRAM:  4 GiB
    Flash: 0 Bytes
    In:    serial@2800000
    Out:   serial@2800000
    Err:   serial@2800000
    Hit any key to stop autoboot:  0
    20236800 bytes read in 842 ms (22.9 MiB/s)
    102282 bytes read in 12 ms (8.1 MiB/s)
    Starting kernel ...
    [    0.000000] Linux version 5.10.100-g7a7a3af903 (oe-user@oe-host) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #1 SMP PREEMPT Tue Aug 1 01:28:31 UTC 2023
    [    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),1m(ospi.sysfw),256k(ospi.env.backup),57088k@8m(ospi.rootfs),256k(ospi.phypattern);47034000.hyperbus:512k(hbmc.tiboot3),2m(hbmc.tispl),4m(hbmc.u-boot),256k(hbmc.env),1m(hbmc.sysfw),-@8m(hbmc.rootfs) root=PARTUUID=0c55d475-02 rw rootfstype=ext4 rootwait
    [    0.008356] Console: colour dummy device 80x25
    [    0.012919] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [    0.023589] pid_max: default: 32768 minimum: 301
    [    0.028339] LSM: Security Framework initializing
    [    0.033082] Mount-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
    [    0.040648] Mountpoint-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
    [    0.049584] rcu: Hierarchical SRCU implementation.
    [    0.054641] Platform MSI: msi-controller@1820000 domain created
    [    0.060883] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
    [    0.070178] EFI services will not be available.
    [    0.074924] smp: Bringing up secondary CPUs ...
    [    0.080166] Detected PIPT I-cache on CPU1
    [    0.080188] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
    [    0.080199] GICv3: CPU1: using allocated LPI pending table @0x00000008800d0000
    [    0.080233] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
    [    0.080285] smp: Brought up 1 node, 2 CPUs
    [    0.109633] SMP: Total of 2 processors activated.
    [    0.114437] CPU features: detected: 32-bit EL0 Support
    [    0.119692] CPU features: detected: CRC32 instructions
    [    0.133470] CPU: All CPU(s) started at EL2
    [    0.137665] alternatives: patching kernel code
    [    0.142649] devtmpfs: initialized
    [    0.150978] KASLR disabled due to lack of seed
    [    0.155638] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.165603] futex hash table entries: 512 (order: -1, 32768 bytes, linear)
    [    0.173245] pinctrl core: initialized pinctrl subsystem
    [    0.178830] DMI not present or invalid.
    [    0.183058] NET: Registered protocol family 16
    [    0.190478] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
    [    0.197782] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.205783] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.214088] thermal_sys: Registered thermal governor 'step_wise'
    [    0.214090] thermal_sys: Registered thermal governor 'power_allocator'
    [    0.220537] cpuidle: using governor menu
    [    0.231351] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.238310] ASID allocator initialised with 65536 entries
    [    0.261085] HugeTLB registered 16.0 GiB page size, pre-allocated 0 pages
    [    0.267945] HugeTLB registered 512 MiB page size, pre-allocated 0 pages
    [    0.274703] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.282619] cryptd: max_cpu_qlen set to 1000
    [    0.288356] ACPI: Interpreter disabled.
    [    0.292491] k3-chipinfo 43000014.chipid: Family:J721E rev:SR2.0 JTAGID[0x1bb6402f] Detected
    [    0.301276] vsys_3v3: supplied by evm_12v0
    [    0.305636] vsys_5v0: supplied by evm_12v0
    [    0.310344] iommu: Default domain type: Translated
    [    0.315468] SCSI subsystem initialized
    [    0.319601] mc: Linux media interface: v0.10
    [    0.323973] videodev: Linux video capture interface: v2.00
    [    0.329600] pps_core: LinuxPPS API ver. 1 registered
    [    0.334669] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.344006] PTP clock support registered
    [    0.348027] EDAC MC: Ver: 3.0.0
    [    0.351781] FPGA manager framework
    [    0.355291] Advanced Linux Sound Architecture Driver Initialized.
    [    0.361920] clocksource: Switched to clocksource arch_sys_counter
    [    0.368342] VFS: Disk quotas dquot_6.6.0
    [    0.372391] VFS: Dquot-cache hash table entries: 8192 (order 0, 65536 bytes)
    [    0.379702] pnp: PnP ACPI: disabled
    [    0.385647] NET: Registered protocol family 2
    [    0.390235] IP idents hash table entries: 65536 (order: 3, 524288 bytes, linear)
    [    0.398908] tcp_listen_portaddr_hash hash table entries: 4096 (order: 0, 65536 bytes, linear)
    [    0.407676] TCP established hash table entries: 32768 (order: 2, 262144 bytes, linear)
    [    0.415875] TCP bind hash table entries: 32768 (order: 3, 524288 bytes, linear)
    [    0.423664] TCP: Hash tables configured (established 32768 bind 32768)
    [    0.430409] UDP hash table entries: 2048 (order: 0, 65536 bytes, linear)
    [    0.437302] UDP-Lite hash table entries: 2048 (order: 0, 65536 bytes, linear)
    [    0.444686] NET: Registered protocol family 1
    [    0.449373] RPC: Registered named UNIX socket transport module.
    [    0.455434] RPC: Registered udp transport module.
    [    0.460239] RPC: Registered tcp transport module.
    [    0.465042] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.471627] PCI: CLS 0 bytes, default 64
    [    0.476010] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
    [    0.486276] Initialise system trusted keyrings
    [    0.490893] workingset: timestamp_bits=46 max_order=16 bucket_order=0
    [    0.499090] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.505303] NFS: Registering the id_resolver key type
    [    0.510516] Key type id_resolver registered
    [    0.514790] Key type id_legacy registered
    [    0.518907] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.525755] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    0.533394] 9p: Installing v9fs 9p2000 file system support
    [    0.558696] Key type asymmetric registered
    [    0.562882] Asymmetric key parser 'x509' registered
    [    0.567880] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
    [    0.575439] io scheduler mq-deadline registered
    [    0.580065] io scheduler kyber registered
    [    0.585406] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
    [    0.591573] pinctrl-single 11c000.pinctrl: 173 pins, size 692
    [    0.597973] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
    [    0.605769] switchtec: loaded.
    [    0.610489] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
    [    0.616750] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
    [    0.624576] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
    [    0.632735] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x00001faf)
    [    0.641708] arm-smmu-v3 36600000.iommu: allocated 524288 entries for cmdq
    [    0.650574] arm-smmu-v3 36600000.iommu: allocated 524288 entries for evtq
    [    0.658303] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to wired irqs
    [    0.671346] brd: module loaded
    [    0.677128] loop: module loaded
    [    0.681040] megasas: 07.714.04.00-rc1
    [    0.686635] tun: Universal TUN/TAP device driver, 1.6
    [    0.692087] igbvf: Intel(R) Gigabit Virtual Function Network Driver
    [    0.698494] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
    [    0.704565] sky2: driver version 1.30
    [    0.708865] VFIO - User Level meta-driver version: 0.3
    [    0.714547] i2c /dev entries driver
    [    0.718430] Error: Driver 'k3-soc-thermal' is already registered, aborting...
    [    0.726075] sdhci: Secure Digital Host Controller Interface driver
    [    0.732390] sdhci: Copyright(c) Pierre Ossman
    [    0.737033] sdhci-pltfm: SDHCI platform and OF driver helper
    [    0.743419] ledtrig-cpu: registered to indicate activity on CPUs
    [    0.749726] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    0.756911] optee: probing for conduit method.
    [    0.761469] optee: revision 3.12 (3d47a131)
    [    0.761712] optee: initialized driver
    [    0.771051] NET: Registered protocol family 17
    [    0.775661] 9pnet: Installing 9P2000 support
    [    0.780048] Key type dns_resolver registered
    [    0.784566] Loading compiled-in X.509 certificates
    [    0.794177] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
    [    0.800511] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
    [    0.808575] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0016 '22.1.1--v2022.01 (Terrific Llam')
    [    0.838107] random: fast init done
    [    0.870758] davinci-mcasp 2ba0000.mcasp: IRQ common not found
    [    0.878418] omap_i2c 40b00000.i2c: bus 0 rev0.12 at 100 kHz
    [    0.884486] omap_i2c 40b10000.i2c: bus 1 rev0.12 at 100 kHz
    [    0.890536] omap_i2c 42120000.i2c: bus 2 rev0.12 at 100 kHz
    [    0.896961] pca953x 3-0020: supply vcc not found, using dummy regulator
    [    0.903771] pca953x 3-0020: using no AI
    [    0.930703] pca953x 3-0022: supply vcc not found, using dummy regulator
    [    0.937504] pca953x 3-0022: using AI
    [    0.941770] gpio-480 (CTRL_PM_I2C_OE): hogged as output/high
    [    0.947744] gpio-481 (MCASP/TRACE_MUX_S0): hogged as output/low
    [    0.953985] gpio-482 (MCASP/TRACE_MUX_S1): hogged as output/high
    [    0.960479] omap_i2c 2000000.i2c: bus 3 rev0.12 at 400 kHz
    [    0.966872] omap_i2c 2010000.i2c: bus 4 rev0.12 at 400 kHz
    [    0.976604] omap_i2c 2020000.i2c: bus 5 rev0.12 at 400 kHz
    [    0.982894] pca953x 6-0020: supply vcc not found, using dummy regulator
    [    0.989711] pca953x 6-0020: using no AI
    [    1.014582] omap_i2c 2030000.i2c: bus 6 rev0.12 at 400 kHz
    [    1.020666] omap_i2c 2040000.i2c: bus 7 rev0.12 at 100 kHz
    [    1.026631] omap_i2c 2050000.i2c: bus 8 rev0.12 at 100 kHz
    [    1.032866] pca953x 9-0020: supply vcc not found, using dummy regulator
    [    1.039680] pca953x 9-0020: using no AI
    [    1.066242] omap_i2c 2060000.i2c: bus 9 rev0.12 at 400 kHz
    [    1.072669] ti-sci-intr bus@100000:bus@28380000:interrupt-controller2: Interrupt Router 137 domain created
    [    1.082651] ti-sci-intr bus@100000:interrupt-controller0: Interrupt Router 131 domain created
    [    1.091458] ti-sci-intr bus@100000:main-navss:interrupt-controller1: Interrupt Router 213 domain created
    [    1.101294] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created
    [    1.124234] j721e-pcie 2900000.pcie: J721E PROBE
    [    1.128976] j721e-pcie 2900000.pcie: pcie->mode 0
    [    1.133888] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    1.141552] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    1.149828] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    1.158107] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    2.169468] j721e-pcie 2900000.pcie: PCI host bridge to bus 0000:00
    [    2.175893] pci_bus 0000:00: root bus resource [bus 00-ff]
    [    2.181506] pci_bus 0000:00: root bus resource [io  0x0000-0xffff] (bus address [0x10001000-0x10010fff])
    [    2.191196] pci_bus 0000:00: root bus resource [mem 0x10011000-0x17ffffff]
    [    2.198247] pci 0000:00:00.0: [104c:b00d] type 01 class 0x060400
    [    2.204386] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
    [    2.214256] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
    [    2.224145] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0xe8 may corrupt adjacent RW1C bits
    [    2.234106] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits
    [    2.244071] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x92 may corrupt adjacent RW1C bits
    [    2.254031] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0xb2 may corrupt adjacent RW1C bits
    [    2.264015] pci 0000:00:00.0: supports D1
    [    2.268109] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
    [    2.273980] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x84 may corrupt adjacent RW1C bits
    [    2.283971] pci 0000:00:00.0: DPC: DPC init
    [    2.289939] pci 0000:00:00.0: scanning [bus 00-00] behind bridge, pass 0
    [    2.296790] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    2.304971] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits
    [    2.314929] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits
    [    2.324889] pci 0000:00:00.0: scanning [bus 00-00] behind bridge, pass 1
    [    2.331737] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bitss
    [    2.351473] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
    [    2.358245] pci 0000:00:00.0: PCI bridge to [bus 01]
    [    2.363525] pcieport 0000:00:00.0: PME: Signaling with IRQ 61
    [    2.369555] pcieport 0000:00:00.0: AER: enabled with IRQ 61
    [    2.375368] j721e-pcie 2900000.pcie: PCI RC End
    [    2.380316] j721e-pcie 2910000.pcie: J721E PROBE
    [    2.385037] j721e-pcie 2910000.pcie: pcie->mode 0
    [    2.389952] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [    2.397614] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [    2.405888] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [    2.414167] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    2.525355] j721e-pcie 2910000.pcie: Link up
    [    2.529771] j721e-pcie 2910000.pcie: PCI host bridge to bus 0001:00
    [    2.536177] pci_bus 0001:00: root bus resource [bus 00-ff]
    [    2.541782] pci_bus 0001:00: root bus resource [io  0x10000-0x1ffff] (bus address [0x18001000-0x18010fff])
    [    2.551650] pci_bus 0001:00: root bus resource [mem 0x18011000-0x1fffffff]
    [    2.558695] pci 0001:00:00.0: [104c:b00d] type 01 class 0x060400
    [    2.564895] pci 0001:00:00.0: supports D1
    [    2.568988] pci 0001:00:00.0: PME# supported from D0 D1 D3hot
    [    2.574892] pci 0001:00:00.0: DPC: DPC init
    [    2.580806] pci 0001:00:00.0: scanning [bus 00-00] behind bridge, pass 0
    [    2.587661] pci 0001:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    2.595847] pci 0001:00:00.0: scanning [bus 00-00] behind bridge, pass 1
    [    2.611056] pci 0001:01:00.0: [12d8:c232] type 01 class 0x060400
    [    2.617215] pci 0001:01:00.0: reg 0x10: [mem 0x00000000-0x0007ffff]
    [    2.623835] pci 0001:01:00.0: PME# supported from D0 D3hot D3cold
    [    2.630214] pci 0001:01:00.0: DPC: DPC init
    [    2.634511] pci 0001:01:00.0: 15.752 Gb/s available PCIe bandwidth, limited by 8.0 GT/s PCIe x2 link at 0001:00:00.0 (capable of 63.008 Gb/s with 8.0 GT/s PCIe x8 link)
    [    2.663425] pci 0001:01:00.0: scanning [bus 00-00] behind bridge, pass 0
    [    2.670277] pci 0001:01:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    2.678469] pci 0001:01:00.0: scanning [bus 00-00] behind bridge, pass 1
    x5             = 0xffff0008024f0000
    x6             = 0xffff800012a2f724
    x13            = 0xffff000801340530
    x14            = 0x000000000000016d
    x15            = 0xffff000801340000
    x16            = 0xffff000800371690
    x19            = 0xffff800012a2f664
    x21            = 0xffff0008024f0800
    x23            = 0xffff800012a2f724
    x26            = 0xffff800010e63278
    x28            = 0xffff00080057c000
    x29            = 0xffff800012a2f5e0
    sp_el1         = 0xffff800012a2f5e0
    cntp_cval_el0  = 0x000000005f70d8fe
  • Hi Takumi,
    Could you try this patch in trusted-firmware?
    https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/791/0001_2D00_Testing_2D00_return_2D00_from_2D00_ea_2D00_handler_2D00_for_2D00_debug_2D00_purposes.patch
    It can be rebuilt using the method in this E2E: https://e2e.ti.com/support/processors-group/processors/f/processors-forum/884767/tda4vm-j721e-arm-trusted-firmware-build
    And could you remind me which SDK version is being used? I am testing on the 8.6.1.2 version of Processor SDK Linux.
    It seems the same error syndrome/ID is received between your setup and mine, but for some reason the error is handled by arm trusted firmware instead of Linux kernel, which is a slightly different behavior than what I was seeing. Since I cannot reproduce the exact error, this new patch is untested, but could you test this out to see if the behavior improves? This patch should essentially do the same thing as the previous patch, which is to ignore errors.
    Takuma
  • Hi Takuma-san,
    I created tispl.bin with the newly deployed patch.
    By using this tispl.bin, I confirmed that the conventional error does not occur with TDA4VM EVM and PCIeSW EVM.
    Expand the log at this time.
    spl_load_fit_image: Skip load 'dm': image size is 0!
    NOTICE:  BL31: v2.5(release):08.01.00.006-dirty
    NOTICE:  BL31: Built : 00:07:53, Aug  2 2023
    U-Boot SPL 2021.01-dirty (Aug 02 2023 - 00:57:18 +0000)
    Detected: J7X-BASE-CPB rev E3
    Detected: J7X-VSC8514-ETH rev E2
    SoC:   J721E SR1.1
    DRAM:  4 GiB
    Flash: 0 Bytes
    In:    serial@2800000
    Out:   serial@2800000
    Err:   serial@2800000
    20236800 bytes read in 844 ms (22.9 MiB/s)
    102282 bytes read in 13 ms (7.5 MiB/s)
    Starting kernel ...
    [    0.008382] Console: colour dummy device 80x25
    [    0.012944] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [    0.023615] pid_max: default: 32768 minimum: 301
    [    0.028363] LSM: Security Framework initializing
    [    0.033106] Mount-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
    [    0.040673] Mountpoint-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
    [    0.049614] rcu: Hierarchical SRCU implementation.
    [    0.054673] Platform MSI: msi-controller@1820000 domain created
    [    0.060916] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
    [    0.070216] EFI services will not be available.
    [    0.074961] smp: Bringing up secondary CPUs ...
    [    0.080201] Detected PIPT I-cache on CPU1
    [    0.080224] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
    [    0.080236] GICv3: CPU1: using allocated LPI pending table @0x00000008800d0000
    [    0.080270] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
    [    0.080326] smp: Brought up 1 node, 2 CPUs
    [    0.109670] SMP: Total of 2 processors activated.
    [    0.114475] CPU features: detected: 32-bit EL0 Support
    [    0.119729] CPU features: detected: CRC32 instructions
    [    0.133541] CPU: All CPU(s) started at EL2
    [    0.137736] alternatives: patching kernel code
    [    0.142716] devtmpfs: initialized
    [    0.151041] KASLR disabled due to lack of seed
    [    0.155695] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.165659] futex hash table entries: 512 (order: -1, 32768 bytes, linear)
    [    0.173311] pinctrl core: initialized pinctrl subsystem
    [    0.178892] DMI not present or invalid.
    [    0.183118] NET: Registered protocol family 16
    [    0.190444] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
    [    0.197744] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.205746] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.214046] thermal_sys: Registered thermal governor 'step_wise'
    [    0.214049] thermal_sys: Registered thermal governor 'power_allocator'
    [    0.220497] cpuidle: using governor menu
    [    0.231295] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.238255] ASID allocator initialised with 65536 entries
    [    0.261653] HugeTLB registered 16.0 GiB page size, pre-allocated 0 pages
    [    0.268513] HugeTLB registered 512 MiB page size, pre-allocated 0 pages
    [    0.275272] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.283189] cryptd: max_cpu_qlen set to 1000
    [    0.288936] ACPI: Interpreter disabled.
    [    0.293077] k3-chipinfo 43000014.chipid: Family:J721E rev:SR2.0 JTAGID[0x1bb6402f] Detected
    [    0.301871] vsys_3v3: supplied by evm_12v0
    [    0.306261] vsys_5v0: supplied by evm_12v0
    [    0.310976] iommu: Default domain type: Translated
    [    0.316106] SCSI subsystem initialized
    [    0.320249] mc: Linux media interface: v0.10
    [    0.324621] videodev: Linux video capture interface: v2.00
    [    0.330249] pps_core: LinuxPPS API ver. 1 registered
    [    0.335319] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.344656] PTP clock support registered
    [    0.348679] EDAC MC: Ver: 3.0.0
    [    0.352435] FPGA manager framework
    [    0.355943] Advanced Linux Sound Architecture Driver Initialized.
    [    0.362557] clocksource: Switched to clocksource arch_sys_counter
    [    0.368976] VFS: Disk quotas dquot_6.6.0
    [    0.373026] VFS: Dquot-cache hash table entries: 8192 (order 0, 65536 bytes)
    [    0.380335] pnp: PnP ACPI: disabled
    [    0.386294] NET: Registered protocol family 2
    [    0.390885] IP idents hash table entries: 65536 (order: 3, 524288 bytes, linear)
    [    0.399553] tcp_listen_portaddr_hash hash table entries: 4096 (order: 0, 65536 bytes, linear)
    [    0.408321] TCP established hash table entries: 32768 (order: 2, 262144 bytes, linear)
    [    0.416520] TCP bind hash table entries: 32768 (order: 3, 524288 bytes, linear)
    [    0.424314] TCP: Hash tables configured (established 32768 bind 32768)
    [    0.431054] UDP hash table entries: 2048 (order: 0, 65536 bytes, linear)
    [    0.437947] UDP-Lite hash table entries: 2048 (order: 0, 65536 bytes, linear)
    [    0.445332] NET: Registered protocol family 1
    [    0.450022] RPC: Registered named UNIX socket transport module.
    [    0.456085] RPC: Registered udp transport module.
    [    0.460889] RPC: Registered tcp transport module.
    [    0.465692] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.472276] PCI: CLS 0 bytes, default 64
    [    0.476636] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
    [    0.486939] Initialise system trusted keyrings
    [    0.491553] workingset: timestamp_bits=46 max_order=16 bucket_order=0
    [    0.499749] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.505949] NFS: Registering the id_resolver key type
    [    0.511172] Key type id_resolver registered
    [    0.515445] Key type id_legacy registered
    [    0.519563] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.526412] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    0.534053] 9p: Installing v9fs 9p2000 file system support
    [    0.559072] Key type asymmetric registered
    [    0.563258] Asymmetric key parser 'x509' registered
    [    0.568255] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
    [    0.575814] io scheduler mq-deadline registered
    [    0.580440] io scheduler kyber registered
    [    0.585790] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
    [    0.591958] pinctrl-single 11c000.pinctrl: 173 pins, size 692
    [    0.598345] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
    [    0.606172] switchtec: loaded.
    [    0.610897] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
    [    0.617155] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
    [    0.624985] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
    [    0.633150] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x00001faf)
    [    0.642117] arm-smmu-v3 36600000.iommu: allocated 524288 entries for cmdq
    [    0.650975] arm-smmu-v3 36600000.iommu: allocated 524288 entries for evtq
    [    0.658696] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to wired irqs
    [    0.671749] brd: module loaded
    [    0.677519] loop: module loaded
    [    0.681434] megasas: 07.714.04.00-rc1
    [    0.687039] tun: Universal TUN/TAP device driver, 1.6
    [    0.692498] igbvf: Intel(R) Gigabit Virtual Function Network Driver
    [    0.698905] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
    [    0.704977] sky2: driver version 1.30
    [    0.709278] VFIO - User Level meta-driver version: 0.3
    [    0.714970] i2c /dev entries driver
    [    0.718857] Error: Driver 'k3-soc-thermal' is already registered, aborting...
    [    0.726492] sdhci: Secure Digital Host Controller Interface driver
    [    0.732809] sdhci: Copyright(c) Pierre Ossman
    [    0.737451] sdhci-pltfm: SDHCI platform and OF driver helper
    [    0.743834] ledtrig-cpu: registered to indicate activity on CPUs
    [    0.750140] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    0.757324] optee: probing for conduit method.
    [    0.761882] optee: revision 3.12 (3d47a131)
    [    0.762122] optee: initialized driver
    [    0.771465] NET: Registered protocol family 17
    [    0.776075] 9pnet: Installing 9P2000 support
    [    0.780460] Key type dns_resolver registered
    [    0.784964] Loading compiled-in X.509 certificates
    [    0.794548] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
    [    0.800905] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
    [    0.809053] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0016 '22.1.1--v2022.01 (Terrific Llam')
    [    0.838993] random: fast init done
    [    0.871784] davinci-mcasp 2ba0000.mcasp: IRQ common not found
    [    0.879462] omap_i2c 40b00000.i2c: bus 0 rev0.12 at 100 kHz
    [    0.885540] omap_i2c 40b10000.i2c: bus 1 rev0.12 at 100 kHz
    [    0.891583] omap_i2c 42120000.i2c: bus 2 rev0.12 at 100 kHz
    [    0.898028] pca953x 3-0020: supply vcc not found, using dummy regulator
    [    0.904841] pca953x 3-0020: using no AI
    [    0.931363] pca953x 3-0022: supply vcc not found, using dummy regulator
    [    0.938161] pca953x 3-0022: using AI
    [    0.942428] gpio-480 (CTRL_PM_I2C_OE): hogged as output/high
    [    0.948402] gpio-481 (MCASP/TRACE_MUX_S0): hogged as output/low
    [    0.954647] gpio-482 (MCASP/TRACE_MUX_S1): hogged as output/high
    [    0.961140] omap_i2c 2000000.i2c: bus 3 rev0.12 at 400 kHz
    [    0.967564] omap_i2c 2010000.i2c: bus 4 rev0.12 at 400 kHz
    [    0.977623] omap_i2c 2020000.i2c: bus 5 rev0.12 at 400 kHz
    [    0.983940] pca953x 6-0020: supply vcc not found, using dummy regulator
    [    0.990760] pca953x 6-0020: using no AI
    [    1.019238] omap_i2c 2030000.i2c: bus 6 rev0.12 at 400 kHz
    [    1.025325] omap_i2c 2040000.i2c: bus 7 rev0.12 at 100 kHz
    [    1.031288] omap_i2c 2050000.i2c: bus 8 rev0.12 at 100 kHz
    [    1.037533] pca953x 9-0020: supply vcc not found, using dummy regulator
    [    1.044347] pca953x 9-0020: using no AI
    [    1.070880] omap_i2c 2060000.i2c: bus 9 rev0.12 at 400 kHz
    [    1.077316] ti-sci-intr bus@100000:bus@28380000:interrupt-controller2: Interrupt Router 137 domain created
    [    1.087297] ti-sci-intr bus@100000:interrupt-controller0: Interrupt Router 131 domain created
    [    1.096104] ti-sci-intr bus@100000:main-navss:interrupt-controller1: Interrupt Router 213 domain created
    [    1.105960] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created
    [    1.128932] j721e-pcie 2900000.pcie: J721E PROBE
    [    1.133673] j721e-pcie 2900000.pcie: pcie->mode 0
    [    1.138593] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    1.146262] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    1.154538] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    1.162819] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    2.174186] j721e-pcie 2900000.pcie: PCI host bridge to bus 0000:00
    [    2.180610] pci_bus 0000:00: root bus resource [bus 00-ff]
    [    2.186223] pci_bus 0000:00: root bus resource [io  0x0000-0xffff] (bus address [0x10001000-0x10010fff])
    [    2.195914] pci_bus 0000:00: root bus resource [mem 0x10011000-0x17ffffff]
    [    2.202965] pci 0000:00:00.0: [104c:b00d] type 01 class 0x060400
    [    2.209103] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
    [    2.218972] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
    [    2.228862] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0xe8 may corrupt adjacent RW1C bits
    [    2.238822] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits
    [    2.248788] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x92 may corrupt adjacent RW1C bits
    [    2.258748] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0xb2 may corrupt adjacent RW1C bits
    [    2.268732] pci 0000:00:00.0: supports D1
    [    2.272825] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
    [    2.278697] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x84 may corrupt adjacent RW1C bits
    [    2.288685] pci 0000:00:00.0: DPC: DPC init
    [    2.294651] pci 0000:00:00.0: scanning [bus 00-00] behind bridge, pass 0
    [    2.301503] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    2.309685] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits
    [    2.319646] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits
    [    2.329607] pci 0000:00:00.0: scanning [bus 00-00] behind bridge, pass 1
    [    2.336454] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits
    [    2.356203] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
    [    2.362975] pci 0000:00:00.0: PCI bridge to [bus 01]
    [    2.368264] pcieport 0000:00:00.0: PME: Signaling with IRQ 61
    [    2.374296] pcieport 0000:00:00.0: AER: enabled with IRQ 61
    [    2.380109] j721e-pcie 2900000.pcie: PCI RC End
    [    2.385057] j721e-pcie 2910000.pcie: J721E PROBE
    [    2.389780] j721e-pcie 2910000.pcie: pcie->mode 0
    [    2.394691] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [    2.402354] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [    2.410629] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [    2.418908] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    2.530102] j721e-pcie 2910000.pcie: Link up
    [    2.534520] j721e-pcie 2910000.pcie: PCI host bridge to bus 0001:00
    [    2.540927] pci_bus 0001:00: root bus resource [bus 00-ff]
    [    2.546532] pci_bus 0001:00: root bus resource [io  0x10000-0x1ffff] (bus address [0x18001000-0x18010fff])
    [    2.556399] pci_bus 0001:00: root bus resource [mem 0x18011000-0x1fffffff]
    [    2.563444] pci 0001:00:00.0: [104c:b00d] type 01 class 0x060400
    [    2.569644] pci 0001:00:00.0: supports D1
    [    2.573738] pci 0001:00:00.0: PME# supported from D0 D1 D3hot
    [    2.579641] pci 0001:00:00.0: DPC: DPC init
    [    2.585539] pci 0001:00:00.0: scanning [bus 00-00] behind bridge, pass 0
    [    2.592395] pci 0001:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    2.600581] pci 0001:00:00.0: scanning [bus 00-00] behind bridge, pass 1
    [    2.615792] pci 0001:01:00.0: [12d8:c232] type 01 class 0x060400
    [    2.621950] pci 0001:01:00.0: reg 0x10: [mem 0x00000000-0x0007ffff]
    [    2.628569] pci 0001:01:00.0: PME# supported from D0 D3hot D3cold
    [    2.634948] pci 0001:01:00.0: DPC: DPC init
    [    2.639245] pci 0001:01:00.0: 15.752 Gb/s available PCIe bandwidth, limited by 8.0 GT/s PCIe x2 link at 0001:00:00.0 (capable of 63.008 Gb/s with 8.0 GT/s PCIe x8 link)
    [    2.668051] pci 0001:01:00.0: scanning [bus 00-00] behind bridge, pass 0
    [    2.674903] pci 0001:01:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    2.683095] pci 0001:01:00.0: scanning [bus 00-00] behind bridge, pass 1
    [    2.698547] pci 0001:02:04.0: [12d8:c232] type 01 class 0x060400
    [    2.704925] pci 0001:02:04.0: PME# supported from D0 D3hot D3cold
    [    2.711287] pci 0001:02:04.0: DPC: DPC init
    [    2.715572] pci 0001:02:04.0: DPC: dpc->cap 0x2a0
    [    2.720609] pci 0001:02:06.0: [12d8:c232] type 01 class 0x060400
    [    2.726989] pci 0001:02:06.0: PME# supported from D0 D3hot D3cold
    [    2.733351] pci 0001:02:06.0: DPC: DPC init
    [    2.737636] pci 0001:02:06.0: DPC: dpc->cap 0x2a0
    [    2.742694] pci 0001:02:09.0: [12d8:c232] type 01 class 0x060400
    [    2.749017] pci 0001:02:09.0: PME# supported from D0 D3hot D3cold
    [    2.755316] pci 0001:02:09.0: DPC: DPC init
    [    2.760772] pci 0001:02:04.0: scanning [bus 00-00] behind bridge, pass 0
    [    2.767621] pci 0001:02:04.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    2.775813] pci 0001:02:06.0: scanning [bus 00-00] behind bridge, pass 0
    [    2.782660] pci 0001:02:06.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    2.790854] pci 0001:02:09.0: scanning [bus 00-00] behind bridge, pass 0
    [    2.797701] pci 0001:02:09.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    2.805893] pci 0001:02:04.0: scanning [bus 00-00] behind bridge, pass 1
    [    2.822559] pci_bus 0001:03: busn_res: [bus 03-ff] end is updated to 03
    [    2.829326] pci 0001:02:06.0: scanning [bus 00-00] behind bridge, pass 1
    [    2.845990] pci_bus 0001:04: busn_res: [bus 04-ff] end is updated to 04
    [    2.852760] pci 0001:02:09.0: scanning [bus 00-00] behind bridge, pass 1
    [    2.867994] pci 0001:05:00.0: [12d8:c232] type 01 class 0x060400
    [    2.874322] pci 0001:05:00.0: PME# supported from D0 D3hot D3cold
    [    2.880620] pci 0001:05:00.0: DPC: DPC init
    [    2.884908] pci 0001:05:00.0: 15.752 Gb/s available PCIe bandwidth, limited by 8.0 GT/s PCIe x2 link at 0001:00:00.0 (capable of 126.016 Gb/s with 8.0 GT/s PCIe x16 link)
    [    2.902042] pci 0001:05:00.0: scanning [bus 00-00] behind bridge, pass 0
    [    2.908891] pci 0001:05:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    2.917085] pci 0001:05:00.0: scanning [bus 00-00] behind bridge, pass 1
    [    2.932347] pci 0001:06:00.0: [12d8:c232] type 01 class 0x060400
    [    2.938733] pci 0001:06:00.0: PME# supported from D0 D3hot D3cold
    [    2.945103] pci 0001:06:00.0: DPC: DPC init
    [    2.949391] pci 0001:06:00.0: DPC: dpc->cap 0x2a0
    [    2.954411] pci 0001:06:02.0: [12d8:c232] type 01 class 0x060400
    [    2.960796] pci 0001:06:02.0: PME# supported from D0 D3hot D3cold
    [    2.967164] pci 0001:06:02.0: DPC: DPC init
    [    2.971449] pci 0001:06:02.0: DPC: dpc->cap 0x2a0
    [    2.976470] pci 0001:06:04.0: [12d8:c232] type 01 class 0x060400
    [    2.982857] pci 0001:06:04.0: PME# supported from D0 D3hot D3cold
    [    2.989226] pci 0001:06:04.0: DPC: DPC init
    [    2.993511] pci 0001:06:04.0: DPC: dpc->cap 0x2a0
    [    2.998531] pci 0001:06:06.0: [12d8:c232] type 01 class 0x060400
    [    3.004917] pci 0001:06:06.0: PME# supported from D0 D3hot D3cold
    [    3.011285] pci 0001:06:06.0: DPC: DPC init
    [    3.015570] pci 0001:06:06.0: DPC: dpc->cap 0x2a0
    [    3.021727] pci 0001:06:00.0: scanning [bus 00-00] behind bridge, pass 0
    [    3.028575] pci 0001:06:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    3.036769] pci 0001:06:02.0: scanning [bus 00-00] behind bridge, pass 0
    [    3.043616] pci 0001:06:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    3.051812] pci 0001:06:04.0: scanning [bus 00-00] behind bridge, pass 0
    [    3.058658] pci 0001:06:04.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    3.066850] pci 0001:06:06.0: scanning [bus 00-00] behind bridge, pass 0
    [    3.073697] pci 0001:06:06.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    3.081889] pci 0001:06:00.0: scanning [bus 00-00] behind bridge, pass 1
    [    3.098560] pci_bus 0001:07: busn_res: [bus 07-ff] end is updated to 07
    [    3.105328] pci 0001:06:02.0: scanning [bus 00-00] behind bridge, pass 1
    [    3.121991] pci_bus 0001:08: busn_res: [bus 08-ff] end is updated to 08
    [    3.128758] pci 0001:06:04.0: scanning [bus 00-00] behind bridge, pass 1
    [    3.145421] pci_bus 0001:09: busn_res: [bus 09-ff] end is updated to 09
    [    3.152189] pci 0001:06:06.0: scanning [bus 00-00] behind bridge, pass 1
    [    3.168856] pci_bus 0001:0a: busn_res: [bus 0a-ff] end is updated to 0a
    [    3.175622] pci_bus 0001:06: busn_res: [bus 06-ff] end is updated to 0a
    [    3.182387] pci_bus 0001:05: busn_res: [bus 05-ff] end is updated to 0a
    [    3.189152] pci_bus 0001:02: busn_res: [bus 02-ff] end is updated to 0a
    [    3.195917] pci_bus 0001:01: busn_res: [bus 01-ff] end is updated to 0a
    [    3.202697] pci 0001:00:00.0: BAR 14: assigned [mem 0x18100000-0x183fffff]
    [    3.209723] pci 0001:00:00.0: BAR 15: assigned [mem 0x18400000-0x185fffff 64bit pref]
    [    3.217726] pci 0001:00:00.0: BAR 13: assigned [io  0x10000-0x10fff]
    [    3.224222] pci 0001:01:00.0: BAR 14: assigned [mem 0x18100000-0x182fffff]
    [    3.231248] pci 0001:01:00.0: BAR 15: assigned [mem 0x18400000-0x185fffff 64bit pref]
    [    3.239250] pci 0001:01:00.0: BAR 0: assigned [mem 0x18300000-0x1837ffff]
    [    3.246190] pci 0001:01:00.0: BAR 13: assigned [io  0x10000-0x10fff]
    [    3.252683] pci 0001:02:09.0: BAR 14: assigned [mem 0x18100000-0x182fffff]
    [    3.259708] pci 0001:02:09.0: BAR 15: assigned [mem 0x18400000-0x185fffff 64bit pref]
    [    3.267712] pci 0001:02:09.0: BAR 13: assigned [io  0x10000-0x10fff]
    [    3.274205] pci 0001:02:04.0: PCI bridge to [bus 03]
    [    3.279293] pci 0001:02:06.0: PCI bridge to [bus 04]
    [    3.284384] pci 0001:05:00.0: BAR 14: assigned [mem 0x18100000-0x182fffff]
    [    3.291410] pci 0001:05:00.0: BAR 15: assigned [mem 0x18400000-0x185fffff 64bit pref]
    [    3.299412] pci 0001:05:00.0: BAR 13: assigned [io  0x10000-0x10fff]
    [    3.305905] pci 0001:06:04.0: BAR 14: assigned [mem 0x18100000-0x182fffff]
    [    3.312930] pci 0001:06:04.0: BAR 15: assigned [mem 0x18400000-0x185fffff 64bit pref]
    [    3.320932] pci 0001:06:04.0: BAR 13: assigned [io  0x10000-0x10fff]
    [    3.327423] pci 0001:06:00.0: PCI bridge to [bus 07]
    [    3.332512] pci 0001:06:02.0: PCI bridge to [bus 08]
    [    3.337600] pci 0001:06:04.0: PCI bridge to [bus 09]
    [    3.342674] pci 0001:06:04.0:   bridge window [io  0x10000-0x10fff]
    [    3.349083] pci 0001:06:04.0:   bridge window [mem 0x18100000-0x182fffff]
    [    3.356023] pci 0001:06:04.0:   bridge window [mem 0x18400000-0x185fffff 64bit pref]
    [    3.363944] pci 0001:06:06.0: PCI bridge to [bus 0a]
    [    3.369034] pci 0001:05:00.0: PCI bridge to [bus 06-0a]
    [    3.374376] pci 0001:05:00.0:   bridge window [io  0x10000-0x10fff]
    [    3.380785] pci 0001:05:00.0:   bridge window [mem 0x18100000-0x182fffff]
    [    3.387724] pci 0001:05:00.0:   bridge window [mem 0x18400000-0x185fffff 64bit pref]
    [    3.395645] pci 0001:02:09.0: PCI bridge to [bus 05-0a]
    [    3.400983] pci 0001:02:09.0:   bridge window [io  0x10000-0x10fff]
    [    3.407393] pci 0001:02:09.0:   bridge window [mem 0x18100000-0x182fffff]
    [    3.414333] pci 0001:02:09.0:   bridge window [mem 0x18400000-0x185fffff 64bit pref]
    [    3.422253] pci 0001:01:00.0: PCI bridge to [bus 02-0a]
    [    3.427592] pci 0001:01:00.0:   bridge window [io  0x10000-0x10fff]
    [    3.434000] pci 0001:01:00.0:   bridge window [mem 0x18100000-0x182fffff]
    [    3.440940] pci 0001:01:00.0:   bridge window [mem 0x18400000-0x185fffff 64bit pref]
    [    3.448860] pci 0001:00:00.0: PCI bridge to [bus 01-0a]
    [    3.454197] pci 0001:00:00.0:   bridge window [io  0x10000-0x10fff]
    [    3.460601] pci 0001:00:00.0:   bridge window [mem 0x18100000-0x183fffff]
    [    3.467538] pci 0001:00:00.0:   bridge window [mem 0x18400000-0x185fffff 64bit pref]
    [    3.475566] pcieport 0001:00:00.0: enabling device (0000 -> 0003)
    [    3.481916] pcieport 0001:00:00.0: PME: Signaling with IRQ 64
    [    3.487966] pcieport 0001:00:00.0: AER: enabled with IRQ 64
    [    3.493826] pcieport 0001:01:00.0: enabling device (0000 -> 0003)
    [    3.501114] pcieport 0001:02:04.0: DPC: DPC probe
    [    3.506003] pcieport 0001:02:04.0: DPC: enabled with IRQ 70
    [    3.511703] pcieport 0001:02:04.0: DPC: error containment capabilities: Int Msg #1, RPExt- PoisonedTLP- SwTrigger- RP PIO Log 0, DL_ActiveErr-
    [    3.525036] pcieport 0001:00:00.0: of_irq_parse_pci: failed with rc=-22
    [    3.532251] pcieport 0001:02:06.0: DPC: DPC probe
    [    3.537129] pcieport 0001:02:06.0: DPC: enabled with IRQ 74
    [    3.542840] pcieport 0001:02:06.0: DPC: error containment capabilities: Int Msg #1, RPExt- PoisonedTLP- SwTrigger- RP PIO Log 0, DL_ActiveErr-
    [    3.556171] pcieport 0001:00:00.0: of_irq_parse_pci: failed with rc=-22
    [    3.562943] pcieport 0001:02:09.0: enabling device (0000 -> 0003)
    [    3.569729] pcieport 0001:05:00.0: enabling device (0000 -> 0003)
    [    3.576529] pcieport 0001:00:00.0: of_irq_parse_pci: failed with rc=-22
    [    3.583746] pcieport 0001:06:00.0: DPC: DPC probe
    [    3.588638] pcieport 0001:06:00.0: DPC: enabled with IRQ 80
    [    3.594342] pcieport 0001:06:00.0: DPC: error containment capabilities: Int Msg #1, RPExt- PoisonedTLP- SwTrigger- RP PIO Log 0, DL_ActiveErr-
    [    3.607689] pcieport 0001:00:00.0: of_irq_parse_pci: failed with rc=-22
    [    3.614910] pcieport 0001:06:02.0: DPC: DPC probe
    [    3.619811] pcieport 0001:06:02.0: DPC: enabled with IRQ 84
    [    3.625508] pcieport 0001:06:02.0: DPC: error containment capabilities: Int Msg #1, RPExt- PoisonedTLP- SwTrigger- RP PIO Log 0, DL_ActiveErr-
    [    3.638852] pcieport 0001:00:00.0: of_irq_parse_pci: failed with rc=-22
    [    3.645628] pcieport 0001:06:04.0: enabling device (0000 -> 0003)
    [    3.652315] pcieport 0001:06:04.0: pciehp: Slot #0 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise+ Interlock- NoCompl- IbPresDis- LLActRep+
    [    3.666213] pcieport 0001:06:04.0: pciehp: Slot(0): Card present
    [    3.666242] pcieport 0001:06:04.0: DPC: DPC probe
    [    3.677242] pcieport 0001:06:04.0: DPC: enabled with IRQ 88
    [    3.682942] pcieport 0001:06:04.0: DPC: error containment capabilities: Int Msg #1, RPExt- PoisonedTLP- SwTrigger- RP PIO Log 0, DL_ActiveErr-
    [    3.696317] pcieport 0001:00:00.0: of_irq_parse_pci: failed with rc=-22
    [    3.703539] pcieport 0001:06:06.0: DPC: DPC probe
    [    3.708422] pcieport 0001:06:06.0: DPC: enabled with IRQ 92
    [    3.714120] pcieport 0001:06:06.0: DPC: error containment capabilities: Int Msg #1, RPExt- PoisonedTLP- SwTrigger- RP PIO Log 0, DL_ActiveErr-
    [    3.727422] j721e-pcie 2910000.pcie: PCI RC End
    [    3.732369] j721e-pcie 2920000.pcie: J721E PROBE
    [    3.737099] j721e-pcie 2920000.pcie: pcie->mode 0
    [    3.742000] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [    3.749664] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
    [    3.757940] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
    [    3.766219] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    3.877564] j721e-pcie 2920000.pcie: Link up
    [    3.881984] j721e-pcie 2920000.pcie: PCI host bridge to bus 0002:00
    [    3.888390] pci_bus 0002:00: root bus resource [bus 00-ff]
    [    3.893995] pci_bus 0002:00: root bus resource [io  0x20000-0x2ffff] (bus address [0x1000-0x10fff])
    [    3.903241] pci_bus 0002:00: root bus resource [mem 0x4400011000-0x4407ffffff] (bus address [0x00011000-0x07ffffff])
    [    3.914021] pci 0002:00:00.0: [104c:b00d] type 01 class 0x060400
    [    3.920223] pci 0002:00:00.0: supports D1
    [    3.924317] pci 0002:00:00.0: PME# supported from D0 D1 D3hot
    [    3.930219] pci 0002:00:00.0: DPC: DPC init
    [    3.936165] pci 0002:00:00.0: scanning [bus 00-00] behind bridge, pass 0
    [    3.943021] pci 0002:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    3.951207] pci 0002:00:00.0: scanning [bus 00-00] behind bridge, pass 1
    [    3.966409] pci 0002:01:00.0: [2646:500d] type 00 class 0x010802
    [    3.972580] pci 0002:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
    [    3.979795] pci 0002:01:00.0: DPC: DPC init
    [    3.984088] pci 0002:01:00.0: 15.752 Gb/s available PCIe bandwidth, limited by 8.0 GT/s PCIe x2 link at 0002:00:00.0 (capable of 31.504 Gb/s with 8.0 GT/s PCIe x4 link)
    [    4.012082] pci_bus 0002:01: busn_res: [bus 01-ff] end is updated to 01
    [    4.018858] pci 0002:00:00.0: BAR 14: assigned [mem 0x4400100000-0x44001fffff]
    [    4.026242] pci 0002:01:00.0: BAR 0: assigned [mem 0x4400100000-0x4400103fff 64bit]
    [    4.034082] pci 0002:00:00.0: PCI bridge to [bus 01]
    [    4.039155] pci 0002:00:00.0:   bridge window [mem 0x4400100000-0x44001fffff]
    [    4.046544] pcieport 0002:00:00.0: enabling device (0000 -> 0002)
    [    4.052889] pcieport 0002:00:00.0: PME: Signaling with IRQ 97
    [    4.058916] pcieport 0002:00:00.0: AER: enabled with IRQ 97
    [    4.064756] j721e-pcie 2920000.pcie: PCI RC End
    [    4.070195] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235
    [    4.080075] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
    [    4.086837] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64
    [    4.095729] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211
    [    4.105875] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
    [    4.112633] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64
    [    4.120591] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 15, base_baud = 6000000) is a 8250
    [    4.129972] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 33, base_baud = 3000000) is a 8250
    [    4.138720] printk: console [ttyS2] enabled
    [    4.147158] printk: bootconsole [ns16550a0] disabled
    [    4.157611] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 34, base_baud = 3000000) is a 8250
    [    4.166536] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 35, base_baud = 3000000) is a 8250
    [    4.177117] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled
    [    4.187625] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcc-supply regulator, assuming enabled
    [    4.197780] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq-supply regulator, assuming enabled
    [    4.208019] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq2-supply regulator, assuming enabled
    [    4.218887] scsi host0: ufshcd
    [    4.240900] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[1, 1], lane[1, 1], pwr[SLOWAUTO_MODE, SLOWAUTO_MODE], rate = 0
    [    4.262561] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    4.271529] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
    [    4.279825] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
    [    4.293628] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[3, 3], lane[2, 2], pwr[FAST MODE, FAST MODE], rate = 2
    [    4.305343] cdns-ufshcd 4e84000.ufs: ufshcd_find_max_sup_active_icc_level: Regulator capability was not set, actvIccLevel=0
    [    4.316503] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0
    [    4.318715] scsi 0:0:0:49488: Well-known LUN    TOSHIBA  THGAF8G8T23BAILB 0300 PQ: 0 ANSI: 6
    [    4.333351] mmc0: CQHCI version 5.10
    [    4.333825] scsi 0:0:0:49476: Well-known LUN    TOSHIBA  THGAF8G8T23BAILB 0300 PQ: 0 ANSI: 6
    [    4.336990] davinci-mcasp 2ba0000.mcasp: IRQ common not found
    [    4.346229] cdns-ufshcd 4e84000.ufs: ufshcd_scsi_add_wlus: BOOT WLUN not found
    [    4.358635] scsi 0:0:0:0: Direct-Access     TOSHIBA  THGAF8G8T23BAILB 0300 PQ: 0 ANSI: 6
    [    4.366960] sd 0:0:0:0: Power-on or device reset occurred
    [    4.372556] sd 0:0:0:0: [sda] 8192 4096-byte logical blocks: (33.6 MB/32.0 MiB)
    [    4.372560] scsi 0:0:0:1: Direct-Access     TOSHIBA  THGAF8G8T23BAILB 0300 PQ: 0 ANSI: 6
    [    4.388073] sd 0:0:0:0: [sda] Write Protect is off
    [    4.392865] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
    [    4.400353] sd 0:0:0:1: Power-on or device reset occurred
    [    4.405946] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, supports DPO and FUA
    [    4.407835] sd 0:0:0:1: [sdb] 7808000 4096-byte logical blocks: (32.0 GB/29.8 GiB)
    [    4.422071] sd 0:0:0:0: [sda] Optimal transfer size 65536 bytes
    [    4.422108] sd 0:0:0:1: [sdb] Write Protect is off
    [    4.432881] sd 0:0:0:1: [sdb] Write cache: enabled, read cache: enabled, supports DPO and FUA
    [    4.441457] sd 0:0:0:1: [sdb] Optimal transfer size 65536 bytes
    [    4.450295] vdd_mmc1: supplied by vsys_3v3
    [    4.451050] sd 0:0:0:1: [sdb] Attached SCSI disk
    [    4.459120] sd 0:0:0:0: [sda] Attached SCSI disk
    [    4.463820] pca953x 4-0020: supply vcc not found, using dummy regulator
    [    4.470473] pca953x 4-0020: using no AI
    [    4.495530] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100
    [    4.502376] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100
    [    4.509205] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100
    [    4.516039] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100
    [    4.522853] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100
    [    4.524016] mmc0: Command Queue Engine enabled
    [    4.533821] mmc0: new HS200 MMC card at address 0001
    [    4.539149] mmcblk0: mmc0:0001 S0J56X 14.8 GiB
    [    4.543818] mmcblk0boot0: mmc0:0001 S0J56X partition 1 31.5 MiB
    [    4.549847] mmcblk0boot1: mmc0:0001 S0J56X partition 2 31.5 MiB
    [    4.550038] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
    [    4.564328] mmcblk0rpmb: mmc0:0001 S0J56X partition 3 4.00 MiB, chardev (236:0)
    [    4.573008] ti-udma 31150000.dma-controller: Channels: 122 (tchan: 61, rchan: 61, gp-rflow: 16)
    [    4.587497] spi-nor spi0.0: mt35xu512aba (65536 Kbytes)
    [    4.592733] 8 cmdlinepart partitions found on MTD device 47040000.spi.0
    [    4.599333] Creating 8 MTD partitions on "47040000.spi.0":
    [    4.604805] 0x000000000000-0x000000080000 : "ospi.tiboot3"
    [    4.610808] 0x000000080000-0x000000280000 : "ospi.tispl"
    [    4.616506] 0x000000280000-0x000000680000 : "ospi.u-boot"
    [    4.622247] 0x000000680000-0x0000006c0000 : "ospi.env"
    [    4.627803] 0x0000006c0000-0x0000007c0000 : "ospi.sysfw"
    [    4.633479] 0x0000007c0000-0x000000800000 : "ospi.env.backup"
    [    4.639604] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
    [    4.645343] 0x000003fc0000-0x000004000000 : "ospi.phypattern"
    [    4.654048] spi-nor spi1.0: mt25qu512a (65536 Kbytes)
    [    4.698568] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    4.707462] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
    [    4.715760] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
    [    4.729377] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
    [    4.736351] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
    [    4.743562] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
    [    4.749910] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0
    [    4.760229] davinci-mcasp 2ba0000.mcasp: IRQ common not found
    [    4.760638] mmc1: CQHCI version 5.10
    [    4.777704] debugfs: Directory 'pd:27' with parent 'pm_genpd' already present!
    [    4.784952] debugfs: Directory 'pd:26' with parent 'pm_genpd' already present!
    [    4.793162] debugfs: Directory 'pd:242' with parent 'pm_genpd' already present!
    [    4.800494] debugfs: Directory 'pd:241' with parent 'pm_genpd' already present!
    [    4.807801] debugfs: Directory 'pd:240' with parent 'pm_genpd' already present!
    [    4.815107] debugfs: Directory 'pd:239' with parent 'pm_genpd' already present!
    [    4.823304] input: gpio-keys as /devices/platform/gpio-keys/input/input0
    [    4.843874] ALSA device list:
    [    4.846844]   No soundcards found.
    [    5.754562] pcieport 0001:06:04.0: pciehp: Slot(0): No link
    [    5.833355] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
    [    5.841774] Waiting for root device PARTUUID=0c55d475-02...
    [    5.890420] mmc1: new ultra high speed DDR50 SDHC card at address 5048
    [    5.897247] mmcblk1: mmc1:5048 SDCIT 15.0 GiB
    [    5.904456]  mmcblk1: p1 p2
    [    6.238286] EXT4-fs (mmcblk1p2): recovery complete
    [    6.249709] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
    [    6.257815] VFS: Mounted root (ext4 filesystem) on device 179:98.
    [    6.268081] devtmpfs: mounted
    [    6.271352] Freeing unused kernel memory: 1984K
    [    6.275900] Run /sbin/init as init process
    [    6.429795] systemd[1]: System time before build time, advancing clock.
    [    6.484677] NET: Registered protocol family 10
    [    6.489561] Segment Routing with IPv6
    [    6.505017] systemd[1]: systemd 244 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
    [    6.526490] systemd[1]: Detected architecture arm64.
    Welcome to Arago 2021.09!
    [    6.567156] systemd[1]: Set hostname to <j7-evm>.
    [    6.745823] systemd[1]: /lib/systemd/system/docker.socket:6: ListenStream= references a path below legacy directory /var/run/, updating /var/run/docker.sock → /run/docker.sock; please update the unit file accordingly.
    [    6.809874] random: systemd: uninitialized urandom read (16 bytes read)
    [    6.816605] systemd[1]: system-getty.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
    [    6.828931] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
    [    6.838854] systemd[1]: Created slice system-getty.slice.
    [  OK  ] Created slice system-getty.slice.
    [    6.858633] random: systemd: uninitialized urandom read (16 bytes read)
    [    6.865911] systemd[1]: Created slice system-serial\x2dgetty.slice.
    [  OK  ] Created slice system-serial\x2dgetty.slice.
    [    6.886627] random: systemd: uninitialized urandom read (16 bytes read)
    [    6.893830] systemd[1]: Created slice system-serial\x2dgetty9600.slice.
    [  OK  ] Created slice system-serial\x2dgetty9600.slice.
    [    6.915235] systemd[1]: Created slice User and Session Slice.
    [  OK  ] Created slice User and Session Slice.
    [    6.938739] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [  OK  ] Started Dispatch Password …ts to Console Directory Watch.
    [    6.962675] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [  OK  ] Started Forward Password R…uests to Wall Directory Watch.
    [    6.986675] systemd[1]: Reached target Paths.
    [  OK  ] Reached target Paths.
    [    7.002605] systemd[1]: Reached target Remote File Systems.
    [  OK  ] Reached target Remote File Systems.
    [    7.022608] systemd[1]: Reached target Slices.
    [  OK  ] Reached target Slices.
    [    7.038614] systemd[1]: Reached target Swap.
    [  OK  ] Reached target Swap.
    [    7.056238] systemd[1]: Listening on RPCbind Server Activation Socket.
    [  OK  ] Listening on RPCbind Server Activation Socket.
    [    7.078636] systemd[1]: Reached target RPC Port Mapper.
    [  OK  ] Reached target RPC Port Mapper.
    [    7.101156] systemd[1]: Listening on Process Core Dump Socket.
    [  OK  ] Listening on Process Core Dump Socket.
    [    7.122724] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [  OK  ] Listening on initctl Compatibility Named Pipe.
    [    7.154520] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
    [    7.162841] systemd[1]: Listening on Journal Socket (/dev/log).
    [  OK  ] Listening on Journal Socket (/dev/log).
    [    7.182832] systemd[1]: Listening on Journal Socket.
    [  OK  ] Listening on Journal Socket.
    [    7.198875] systemd[1]: Listening on Network Service Netlink Socket.
    [  OK  ] Listening on Network Service Netlink Socket.
    [    7.222796] systemd[1]: Listening on udev Control Socket.
    [  OK  ] Listening on udev Control Socket.
    [    7.242709] systemd[1]: Listening on udev Kernel Socket.
    [  OK  ] Listening on udev Kernel Socket.
    [    7.265023] systemd[1]: Mounting Huge Pages File System...
    [    7.284663] systemd[1]: Mounting POSIX Message Queue File System...
    [    7.308706] systemd[1]: Mounting Kernel Debug File System...
    [    7.325645] systemd[1]: Mounting Temporary Directory (/tmp)...
    [    7.345446] systemd[1]: Starting Create list of static device nodes for the current kernel...
             Starting Create list of st…odes for the current kernel...
    [    7.373199] systemd[1]: Starting Start psplash boot splash screen...
    [    7.397661] systemd[1]: Starting RPC Bind...
    [    7.410987] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
    [    7.422836] systemd[1]: Starting Journal Service...
    [    7.443184] systemd[1]: Starting Load Kernel Modules...
    [    7.458582] systemd[1]: Starting Remount Root and Kernel File Systems...
    [    7.465501] cryptodev: loading out-of-tree module taints kernel.
    [    7.480873] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
    [    7.482745] cryptodev: driver 1.10 loaded.
    [    7.493804] systemd[1]: Starting udev Coldplug all Devices...
    [    7.517166] systemd[1]: Started RPC Bind.
    [  OK  ] Started RPC Bind.
    [    7.539091] systemd[1]: Mounted Huge Pages File System.
    [  OK  ] Mounted Huge Pages File System.
    [    7.558976] systemd[1]: Mounted POSIX Message Queue File System.
    [  OK  ] Mounted POSIX Message Queue File System.
    [    7.582955] systemd[1]: Mounted Kernel Debug File System.
    [  OK  ] Mounted Kernel Debug File System.
    [    7.602977] systemd[1]: Mounted Temporary Directory (/tmp).
    [  OK  ] Mounted Temporary Directory (/tmp).
    [    7.626943] systemd[1]: Started Journal Service.
    [  OK  ] Started Journal Service.
    [  OK  ] Started Create list of sta… nodes for the current kernel.
    [FAILED] Failed to start Start psplash boot splash screen.
    See 'systemctl status psplash-start.service' for details.
    [DEPEND] Dependency failed for Star…progress communication helper.
    [  OK  ] Started Load Kernel Modules.
    [  OK  ] Started Remount Root and Kernel File Systems.
             Mounting Kernel Configuration File System...
             Starting Flush Journal to Persistent Storage...
    [    7.774197] systemd-journald[183]: Received client request to flush runtime journal.
             Starting Apply Kernel Variables...
             Starting Create Static Device Nodes in /dev...
    [  OK  ] Mounted Kernel Configuration File System.
    [  OK  ] Started Flush Journal to Persistent Storage.
    [  OK  ] Started Apply Kernel Variables.
    [  OK  ] Started Create Static Device Nodes in /dev.
    [  OK  ] Reached target Local File Systems (Pre).
             Mounting /media/ram...
             Mounting /var/volatile...
             Starting udev Kernel Device Manager...
    [  OK  ] Started udev Coldplug all Devices.
    [  OK  ] Mounted /media/ram.
    [  OK  ] Mounted /var/volatile.
             Starting udev Wait for Complete Device Initialization...
             Starting Load/Save Random Seed...
    [  OK  ] Reached target Local File Systems.
             Starting Create Volatile Files and Directories...
    [  OK  ] Started udev Kernel Device Manager.
    [  OK  ] Started Create Volatile Files and Directories.
             Starting Network Time Synchronization...
             Starting Update UTMP about System Boot/Shutdown...
    [  OK  ] Started Update UTMP about System Boot/Shutdown.
    [  OK  ] Started Network Time Synchronization.
    [  OK  ] Reached target System Time Set.
    [  OK  ] Reached target System Time Synchronized.
    [    8.334193] CAN device driver interface
    [    8.354958] ina2xx 5-0040: power monitor ina226 (Rshunt = 10000 uOhm)
    [    8.371683] ina2xx 5-0041: power monitor ina226 (Rshunt = 10000 uOhm)
    [    8.414098] ina2xx 5-0042: power monitor ina226 (Rshunt = 10000 uOhm)
    [    8.422155] ina2xx 5-0043: power monitor ina226 (Rshunt = 10000 uOhm)
    [    8.438780] ina2xx 5-0044: power monitor ina226 (Rshunt = 10000 uOhm)
    [    8.456755] ina2xx 5-0045: power monitor ina226 (Rshunt = 5000 uOhm)
    [    8.468264] ina2xx 5-0046: power monitor ina226 (Rshunt = 10000 uOhm)
    [    8.476711] ina2xx 5-0047: power monitor ina226 (Rshunt = 10000 uOhm)
    [    8.495268] ina2xx 5-0048: power monitor ina226 (Rshunt = 10000 uOhm)
    [    8.507059] ina2xx 5-0049: power monitor ina226 (Rshunt = 10000 uOhm)
    [    8.517211] ina2xx 5-004a: power monitor ina226 (Rshunt = 10000 uOhm)
    [    8.533814] ina2xx 5-004b: power monitor ina226 (Rshunt = 10000 uOhm)
    [    8.555970] ina2xx 5-004c: power monitor ina226 (Rshunt = 10000 uOhm)
    [    8.571955] ina2xx 5-004d: power monitor ina226 (Rshunt = 10000 uOhm)
    [    8.572906] nvme nvme0: pci function 0002:01:00.0
    [    8.587249] ina2xx 5-004e: power monitor ina226 (Rshunt = 10000 uOhm)
    [    8.612139] nvme 0002:01:00.0: enabling device (0000 -> 0002)
    [    8.624421] nvme nvme0: missing or invalid SUBNQN field.
    [    8.630985] ina2xx 5-004f: power monitor ina226 (Rshunt = 10000 uOhm)
    [    8.639908] nvme nvme0: 2/0/0 default/read/poll queues
    [    8.803632] img_enc 4200000.video-encoder: vxe_enc_probe: using heap 1 for internal alloc
    [    8.864279] img_dec 4300000.video-decoder: decoder registered as /dev/video0
    [    8.883294] k3-dsp-rproc 4d80800000.dsp: assigned reserved memory node c66-dma-memory@a7000000
    [    8.921786] k3-dsp-rproc 4d80800000.dsp: configured DSP for remoteproc mode
    [    8.972280] [drm] Initialized tidss 1.0.0 20180215 for 4a00000.dss on minor 0
    [    8.982601] tidss 4a00000.dss: [drm] Cannot find any crtc or sizes
    [    9.002723] img_enc 4200000.video-encoder: encoder registered as /dev/video1
    [    9.006701] k3-dsp-rproc 4d80800000.dsp: local reset is deasserted for device
    [    9.022891] PVR_K:  209: Read BVNC 22.104.208.318 from HW device registers
    [    9.038275] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
    [    9.096861] PVR_K:  209: RGX Device registered with BVNC 22.104.208.318
    [    9.175831] remoteproc remoteproc0: 4d80800000.dsp is available
    [    9.227161] [drm] Initialized pvr 1.13.5776728 20170530 for 4e20000000.gpu on minor 1
    [    9.235232] platform 41000000.r5f: configured R5F for IPC-only mode
    [    9.292006] k3-dsp-rproc 4d81800000.dsp: assigned reserved memory node c66-dma-memory@a6000000
    [    9.305722] remoteproc remoteproc0: powering up 4d80800000.dsp
    [    9.311617] remoteproc remoteproc0: Booting fw image j7-c66_0-fw, size 144692
    [    9.323321] k3-dsp-rproc 4d80800000.dsp: booting DSP core using boot addr = 0xa6200400
    [    9.333243]  remoteproc0#vdev0buffer: assigned reserved memory node c66-dma-memory@a7000000
    [    9.341906] virtio_rpmsg_bus virtio0: rpmsg host is online
    [    9.349404] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd
    [    9.349793]  remoteproc0#vdev0buffer: registered virtio0 (type 7)
    [    9.358528] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe
    [    9.362988] remoteproc remoteproc0: remote processor 4d80800000.dsp is now up
    [    9.364661] platform 41000000.r5f: assigned reserved memory node r5f-dma-memory@a0000000
    [    9.385667] k3-dsp-rproc 4d81800000.dsp: configured DSP for remoteproc mode
    [    9.393452] remoteproc remoteproc1: 41000000.r5f is available
    [    9.399372] remoteproc remoteproc1: attaching to 41000000.r5f
    [    9.405278] k3-dsp-rproc 4d81800000.dsp: local reset is deasserted for device
    [    9.414850] remoteproc remoteproc2: 4d81800000.dsp is available
    [    9.417325] platform 41000000.r5f: R5F core initialized in IPC-only mode
    [    9.431114] k3-dsp-rproc 64800000.dsp: assigned reserved memory node c71-dma-memory@a8000000
    [    9.439907] remoteproc remoteproc2: powering up 4d81800000.dsp
    [    9.445782] remoteproc remoteproc2: Booting fw image j7-c66_1-fw, size 144692
    [    9.454567] k3-dsp-rproc 4d81800000.dsp: booting DSP core using boot addr = 0xa7200400
    [    9.466140]  remoteproc2#vdev0buffer: assigned reserved memory node c66-dma-memory@a6000000
    [    9.478362] virtio_rpmsg_bus virtio1: rpmsg host is online
    [    9.486779]  remoteproc2#vdev0buffer: registered virtio1 (type 7)
    [    9.492200] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xd
    [    9.498561] remoteproc remoteproc2: remote processor 4d81800000.dsp is now up
    [    9.501515] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xe
    [    9.664679] k3-dsp-rproc 64800000.dsp: configured DSP for remoteproc mode
    [    9.672845]  remoteproc1#vdev0buffer: assigned reserved memory node r5f-dma-memory@a0000000
    [    9.742661] remoteproc remoteproc3: 64800000.dsp is available
    [    9.767436] virtio_rpmsg_bus virtio2: rpmsg host is online
    [    9.775979] virtio_rpmsg_bus virtio2: creating channel ti.ipc4.ping-pong addr 0xd
    [    9.899526]  remoteproc1#vdev0buffer: registered virtio2 (type 7)
    [   10.078891] remoteproc remoteproc3: powering up 64800000.dsp
    [   10.084570] remoteproc remoteproc3: Booting fw image j7-c71_0-fw, size 10489000
    [   10.096949] remoteproc remoteproc3: unsupported resource 65538
    [   10.103375] k3-dsp-rproc 64800000.dsp: booting DSP core using boot addr = 0xa8e00000
    [   10.116048]  remoteproc3#vdev0buffer: assigned reserved memory node c71-dma-memory@a8000000
    [   10.124718] virtio_rpmsg_bus virtio3: rpmsg host is online
    [   10.134592] random: crng init done
    [   10.134893] remoteproc remoteproc1: remote processor 41000000.r5f is now attached
    [   10.137986] random: 7 urandom warning(s) missed due to ratelimiting
    [   10.145507]  remoteproc3#vdev0buffer: registered virtio3 (type 7)
    [   10.151784] virtio_rpmsg_bus virtio3: creating channel ti.ipc4.ping-pong addr 0xd
    [   10.157794] remoteproc remoteproc3: remote processor 64800000.dsp is now up
    [   10.181893] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0xe
    [  OK  ] Started Load/Save Random Seed.
    [   10.218412] platform 5c00000.r5f: configured R5F for remoteproc mode
    [   10.227177] platform 5c00000.r5f: assigned reserved memory node r5f-dma-memory@a2000000
    [   10.236172] remoteproc remoteproc4: 5c00000.r5f is available
    [   10.243910] platform 5d00000.r5f: configured R5F for remoteproc mode
    [   10.259079] platform 5d00000.r5f: assigned reserved memory node r5f-dma-memory@a3000000
    [   10.274047] remoteproc remoteproc4: powering up 5c00000.r5f
    [   10.279756] remoteproc remoteproc4: Booting fw image j7-main-r5f0_0-fw, size 626036
    [   10.292422]  remoteproc4#vdev0buffer: assigned reserved memory node r5f-dma-memory@a2000000
    [   10.306773] virtio_rpmsg_bus virtio4: rpmsg host is online
    [   10.312363]  remoteproc4#vdev0buffer: registered virtio4 (type 7)
    [   10.318459] remoteproc remoteproc4: remote processor 5c00000.r5f is now up
    [   10.323382] remoteproc remoteproc5: 5d00000.r5f is available
    [   10.404843] remoteproc remoteproc5: powering up 5d00000.r5f
    [   10.410718] remoteproc remoteproc5: Booting fw image j7-main-r5f0_1-fw, size 98444
    [   10.424691]  remoteproc5#vdev0buffer: assigned reserved memory node r5f-dma-memory@a3000000
    [   10.437338] virtio_rpmsg_bus virtio5: rpmsg host is online
    [   10.442885]  remoteproc5#vdev0buffer: registered virtio5 (type 7)
    [   10.452635] remoteproc remoteproc5: remote processor 5d00000.r5f is now up
    [   10.459898] virtio_rpmsg_bus virtio5: creating channel ti.ipc4.ping-pong addr 0xd
    [   10.471174] platform 5e00000.r5f: configured R5F for remoteproc mode
    [   10.529374] platform 5e00000.r5f: assigned reserved memory node r5f-dma-memory@a4000000
    [   10.581149] remoteproc remoteproc6: 5e00000.r5f is available
    [   10.617275] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xe
    [   10.634685] platform 5f00000.r5f: configured R5F for remoteproc mode
    [   10.641243] remoteproc remoteproc6: powering up 5e00000.r5f
    [   10.646905] remoteproc remoteproc6: Booting fw image j7-main-r5f1_0-fw, size 98444
    [   10.659240]  remoteproc6#vdev0buffer: assigned reserved memory node r5f-dma-memory@a4000000
    [   10.668093] virtio_rpmsg_bus virtio6: rpmsg host is online
    [   10.678713]  remoteproc6#vdev0buffer: registered virtio6 (type 7)
    [   10.684839] remoteproc remoteproc6: remote processor 5e00000.r5f is now up
    [   10.698924] virtio_rpmsg_bus virtio6: creating channel ti.ipc4.ping-pong addr 0xd
    [  OK  ] Created slice system-systemd\x2dfsc[   10.714830] platform 5f00000.r5f: assigned reserved memory node r5f-dma-memory@a5000000
    k.slice.
    [   10.736955] remoteproc remoteproc7: 5f00000.r5f is available
    [  OK  ] Found device THGAF8G8T23BAILB.
    [   10.775824] remoteproc remoteproc7: powering up 5f00000.r5f
             Starting File System Check on /dev/sdb...[   10.785184] remoteproc remoteproc7: Booting fw image j7-main-r5f1_1-fw, size 98444
    [   10.808135]  remoteproc7#vdev0buffer: assigned reserved memory node r5f-dma-memory@a5000000
    [   10.820896] virtio_rpmsg_bus virtio7: rpmsg host is online
    [   10.824095] virtio_rpmsg_bus virtio6: creating channel rpmsg_chrdev addr 0xe
    [   10.829337]  remoteproc7#vdev0buffer: registered virtio7 (type 7)
    [   10.837532] virtio_rpmsg_bus virtio7: creating channel ti.ipc4.ping-pong addr 0xd
    [   10.844185] remoteproc remoteproc7: remote processor 5f00000.r5f is now up
    [   10.851804] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0xe
    [  OK  ] Started File System Check on /dev/sdb.
             Mounting /run/media/sdb...
    [   10.897888] virtio_rpmsg_bus virtio7: creating channel rpmsg_chrdev addr 0xe
    [   10.927736] EXT4-fs (sdb): mounted filesystem with ordered data mode. Opts: (null)
    [  OK  ] Mounted /run/media/sdb.
    [   10.961485] m_can_platform 40528000.can: m_can device registered (irq=23, version=32)
    [   10.977672] m_can_platform 40568000.can: m_can device registered (irq=25, version=32)
    [   10.995657] m_can_platform 2701000.can: m_can device registered (irq=55, version=32)
    [   11.014309] m_can_platform 2721000.can: m_can device registered (irq=57, version=32)
    [   11.608972] virtio_rpmsg_bus virtio4: creating channel ti.ethfw.notifyservice addr 0x1e
    [   11.670004] virtio_rpmsg_bus virtio4: creating channel rpmsg-kdrv addr 0x1a
    [   11.678754] rpmsg-kdrv-eth-switch rpmsg-kdrv-1-mpu_1_0_ethswitch-device-0: Device info: permissions: 3FFFFFFF uart_id: 2
    [   11.697135] rpmsg-kdrv-eth-switch rpmsg-kdrv-1-mpu_1_0_ethswitch-device-0: FW ver 0.2 (rev 0)  2/Feb/2022 SHA:bd5a13f4
    [   11.713474] rpmsg-kdrv-eth-switch rpmsg-kdrv-3-mpu_1_0_ethmac-device-1: Device info: permissions: 3FFFFFFF uart_id: 2
    [  OK  ] Found device /dev/mmcblk1p1.
    [   11.724959] rpmsg-kdrv-eth-switch rpmsg-kdrv-3-mpu_1_0_ethmac-device-1: FW ver 0.2 (rev 0)  2/Feb/2022 SHA:bd5a13f4
             Starting File System Check on /dev/mmcblk1p1...
    [   11.776560] usbcore: registered new interface driver usbfs
    [   11.783339] usbcore: registered new interface driver hub
    [   11.799482] remoteproc remoteproc8: b034000.pru is available
    [   11.805673] remoteproc remoteproc9: b004000.rtu is available
    [   11.814296] remoteproc remoteproc10: b00a000.txpru is available
    [   11.822498] remoteproc remoteproc11: b038000.pru is available
    [   11.828608] remoteproc remoteproc12: b006000.rtu is available
    [   11.833963] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: rpmsg attach_ext - rx_mtu:1522 features:0000000B tx_mtu[0]:2024 flow_idx:172 tx_cpsw_psil_dst_id:51712 mac_addr:70:ff:76:1d:92:c1 mac-only:0
    [   11.855087] remoteproc remoteproc13: b00c000.txpru is available
    [   11.858666] usbcore: registered new device driver usb
    [   11.875268] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: virt_cpsw_nuss mac loaded
    [   11.886657] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: rdev_features:0000000B rdev_mtu:1522 flow_id:172 tx_psil_dst_id:4A00 mac_only:0
    [   11.894951] remoteproc remoteproc14: b134000.pru is available
    [   11.905381] cdns-csi2rx: probe of 4504000.csi-bridge failed with error -22
    [   11.909028] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: local_mac_addr:00:00:00:00:00:00 rdev_mac_addr:70:ff:76:1d:92:c1
    [   11.913318] remoteproc remoteproc15: b104000.rtu is available
    [   11.929767] remoteproc remoteproc16: b10a000.txpru is available
    [   11.933704] cdns-csi2rx: probe of 4514000.csi-bridge failed with error -22
    [   11.935888] remoteproc remoteproc17: b138000.pru is available
    [   11.948593] remoteproc remoteproc18: b106000.rtu is available
    [   11.954718] remoteproc remoteproc19: b10c000.txpru is available
    [  OK  ] Started File System Check on /dev/mmcblk1p1.
             Mounting /run/media/mmcblk1p1...
    [   12.007934] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: rpmsg attach_ext - rx_mtu:1522 features:00000007 tx_mtu[0]:2024 flow_idx:173 tx_cpsw_psil_dst_id:51713 mac_addr:70:ff:76:1d:92:c2 mac-only:1
    [  OK  ] Mounted /run/media/mmcblk1p1.
    [   12.051603] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: virt_cpsw_nuss mac loaded
    [   12.062602] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: rdev_features:00000007 rdev_mtu:1522 flow_id:173 tx_psil_dst_id:4A01 mac_only:1
    [   12.086597] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: local_mac_addr:00:00:00:00:00:00 rdev_mac_addr:70:ff:76:1d:92:c2
    [   12.181814] omap_rng 4e10000.rng: Random Number Generator ver. 241b34c
    [  OK  ] Found device KINGSTON OM8PDP3512B-A01.
             Starting File System Check on /dev/nvme0n1...
    [  OK  ] Started File System Check on /dev/nvme0n1.
             Mounting /run/media/nvme0n1...
    [   12.808549] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
    [   12.814074] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 1
    [   12.816881] EXT4-fs (nvme0n1): mounted filesystem with ordered data mode. Opts: (null)
    [   12.822236] xhci-hcd xhci-hcd.2.auto: hcc params 0x200073c9 hci version 0x100 quirks 0x0000002000010010
    [   12.839140] xhci-hcd xhci-hcd.2.auto: irq 693, io mem 0x06410000
    [   12.839325] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
    [   12.839328] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [   12.839330] usb usb1: Product: xHCI Host Controller
    [  OK  ] Mounted /run/media/nvme0n1.
    [   12.839332] usb usb1: Manufacturer: Linux 5.10.100-g7a7a3af903 xhci-hcd
    [   12.839335] usb usb1: SerialNumber: xhci-hcd.2.auto
    [   12.840685] hub 1-0:1.0: USB hub found
    [   12.886405] hub 1-0:1.0: 1 port detected
    [   12.890871] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
    [   12.896441] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 2
    [   12.904102] xhci-hcd xhci-hcd.2.auto: Host supports USB 3.0 SuperSpeed
    [   12.910674] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
    [   12.918830] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
    [   12.927097] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [   12.934319] usb usb2: Product: xHCI Host Controller
    [   12.939210] usb usb2: Manufacturer: Linux 5.10.100-g7a7a3af903 xhci-hcd
    [   12.945826] usb usb2: SerialNumber: xhci-hcd.2.auto
    [   12.950962] hub 2-0:1.0: USB hub found
    [   12.954737] hub 2-0:1.0: 1 port detected
    [   13.142576] usb 1-1: new high-speed USB device number 2 using xhci-hcd
    [   13.294840] usb 1-1: New USB device found, idVendor=0451, idProduct=8142, bcdDevice= 1.00
    [   13.303005] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=1
    [   13.310127] usb 1-1: SerialNumber: 7F0600790B90
    [   13.315147] hub 1-1:1.0: USB hub found
    [   13.318931] hub 1-1:1.0: 4 ports detected
    [  OK  ] Started udev Wait for Complete Device Initialization.
    [  OK  ] Started Hardware RNG Entropy Gatherer Daemon.
    [  OK  ] Reached target System Initialization.
    [  OK  ] Started Daily rotation of log files.
    [  OK  ] Started Daily Cleanup of Temporary Directories.
    [  OK  ] Reached target Timers.
    [  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
    [  OK  ] Listening on D-Bus System Message Bus Socket.
             Starting Docker Socket for the API.
    [  OK  ] Listening on dropbear.socket.
             Starting Reboot and dump vmcore via kexec...
    [  OK  ] Listening on Docker Socket for the API.
    [  OK  ] Started Reboot and dump vmcore via kexec.
    [  OK  ] Reached target Sockets.
    [  OK  ] Reached target Basic System.
             Starting Save/Restore Sound Card State...
    [  OK  ] Started Job spooling tools.
    [  OK  ] Started Periodic Command Scheduler.
    [  OK  ] Started D-Bus System Message Bus.
             Starting Print notice about GPLv3 packages...
             Starting set host name as per compatible name...
             Starting IPv6 Packet Filtering Framework...
             Starting IPv4 Packet Filtering Framework...
    [  OK  ] Started irqbalance daemon.
             Starting Telephony service...
             Starting rc.pvr.service...
             Starting startwlanap...
             Starting startwlansta...
             Starting Login Service...
    [  OK  ] Started TEE Supplicant.
             Starting Update weston ini… based on the platform name...
    [  OK  ] Started Save/Restore Sound Card State.
    [  OK  ] Started IPv6 Packet Filtering Framework.
    [  OK  ] Started IPv4 Packet Filtering Framework.
    [  OK  ] Started startwlansta.
    [  OK  ] Reached target Network (Pre).
    [  OK  ] Reached target Sound Card.
             Starting Network Service...
    [  OK  ] Started Telephony service.
    [  OK  ] Started Update weston ini …ge based on the platform name.
    [  OK  ] Started set host name as per compatible name.
    [  OK  ] Started startwlanap.
    [   13.958707] Bluetooth: Core ver 2.22
    [   13.965808] NET: Registered protocol family 31
    [   13.974603] Bluetooth: HCI device and connection manager initialized
    [   13.987045] Bluetooth: HCI socket layer initialized
    [   13.996612] Bluetooth: L2CAP socket layer initialized
    [   14.006451] Bluetooth: SCO socket layer initialized
    [  OK  ] Started Network Service.
             Starting Wait for Network to be Configured...
             Starting Network Name Resolution...
    [  OK  ] Started Login Service.
    [  OK  ] Started rc.pvr.service.
             Starting weston.service...
    [  OK  ] Started weston.service.
             Starting DEMO...
             Starting telnetd.service...
    [  OK  ] Started DEMO.
    [  OK  ] Started telnetd.service.
    [   14.331321] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: virt_cpsw_nuss mac started
    [  OK  ] Listening on Load/Save RF …itch Status /dev/rfkill Watch.
    [   14.594013] PVR_K:  1083: RGX Firmware image 'rgx.fw.22.104.208.318' loaded
    [   14.697011] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: virt_cpsw_nuss mac started
    [  OK  ] Started Network Name Resolution.
    [  OK  ] Reached target Network.
    [  OK  ] Reached target Host and Network Name Lookups.
             Starting Avahi mDNS/DNS-SD Stack...
             Starting Enable and configure wl18xx bluetooth stack...
    [  OK  ] Started NFS status monitor for NFSv2/3 locking..
             Starting Simple Network Ma…ent Protocol (SNMP) Daemon....
             Starting Permit User Sessions...
    [   14.768165] TI DP83867 46000f00.mdio:00: attached PHY driver [TI DP83867] (mii_bus:phy_addr=46000f00.mdio:00, irq=POLL)
    [  OK  ] Started Permit User Sessions.
    [  OK  ] Started Getty on tty1.
    [  OK  ] Started Serial Getty on ttyS3.
    [   14.795260] am65-cpsw-nuss 46000000.ethernet eth0: Link is Down
    [  OK  ] Started Serial Getty on ttyS2.
    [  OK  ] Reached target Login Prompts.
             Starting Synchronize System and HW clocks...
    [  OK  ] Started Enable and configure wl18xx bluetooth stack.
    [FAILED] Failed to start Synchronize System and HW clocks.
    See 'systemctl status sync-clocks.service' for details.
    [  OK  ] Started Avahi mDNS/DNS-SD Stack.
    [  OK  ] Started Simple Network Man…ement Protocol (SNMP) Daemon..
    NOTICE: This file system contains the following GPLv3 packages:
    	autoconf
    	bash-dev
    	bash
    	bc
    	binutils
    	cifs-utils
    	coreutils-stdbuf
    	coreutils
    	cpio
    	cpp-symlinks
    	cpp
    	dosfstools
    	elfutils
    	g++-symlinks
    	g++
    	gawk
    	gcc-symlinks
    	gcc
    	gdb
    	gdbserver
    	gettext
    	glmark2
    	gstreamer1.0-libav-dev
    	gstreamer1.0-libav
    	gzip
    	less
    	libasm1
    	libbfd
    	libdw1
    	libelf1
    	libgdbm-compat4
    	libgdbm-dev
    	libgdbm6
    	libgettextlib
    	libgettextsrc
    	libgmp-dev
    	libgmp10
    	libgmpxx4
    	libidn2-0
    	libidn2-dev
    	libmpc3
    	libmpfr6
    	libreadline-dev
    	libreadline8
    	libunistring-dev
    	libunistring2
    	m4-dev
    	m4
    	make
    	nettle-dev
    	nettle
    	parted
    	python3-rfc3987
    	python3-strict-rfc3339
    	tar
    	which
    	zeromq
    If you do not wish to distribute GPLv3 components please remove
    the above packages prior to distribution.  This can be done using
    the opkg remove command.  i.e.:
        opkg remove <package>
    Where <package> is the name printed in the list above
    NOTE: If the package is a dependency of another package you
          will be notified of the dependent packages.  You should
          use the --force-removal-of-dependent-packages option to
          also remove the dependent packages as well
    [  OK  ] Started Print notice about GPLv3 packages.
     _____                    _____           _         _
    |  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
    |     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
    |__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
                  |___|                    |___|
    Arago Project http://arago-project.org j7-evm ttyS2
    Arago 2021.09 j7-evm ttyS2
    j7-evm login: root (automatic login)
    Last login: Tue Jun 28 08:05:16 UTC 2022 on ttyS3
    No directory, logging in with HOME=/
    root@j7-evm:/#
    The SDK version we are using is ti-processor-sdk-linux-rt-j7-evm-08_02_00_01.
    I'm thinking of doing the following two things.
    ・Confirmation with a custom board
    ・SDK updated to 8.6.1.2
    Takumi
  • Hi Takumi,
    Awesome! That is good to hear that the error logs are gone. Can I also get a confirmation that the PCIe switch device becomes functional with this patch?
    As I mentioned before, it is not the cleanest of patches since the quick patch I made for atf effects all errors. I will try out with Linux RT 8.2 version SDK on my end as well and see if there is a cleaner workaround we can make and share with you. In the meantime, the patch I shared should unblock you from development, since there should be no issues as long as no 'real' critical errors are encountered, such as accessing invalid memory locations, real bus errors, etc.
    Takuma
  • Hi Takuma-san,
    I updated the SDK to 8.06.1.2 and checked the patch and lspci listed the device behind PCIeSW. I was also able to run pcitest.sh in RC.
    However, I get the following error in the kernel boot log:
    I would like to ask you some questions.
    1. The error you are getting is interrupt related. Is this a problem?
    2. Do you have 0001-arm64-dts-j721e-Enable-Minimal-DT-configuration.patch for SDK 8.06.1.2?
    For 2,
    In 8.02.0.1 use 0001-arm64-dts-j721e-Enable-Minimal-DT-configuration.patch for custom boards. Using the above patch with 8.06.1.2 will result in a build error.
    Takumi
  • Hi Takumi,
    I assume the 0001-arm64-dts-j721e-Enable-Minimal-DT-configuration.patch is from a FAQ or another E2E like this one: https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1201887/processor-sdk-j721e-custom-board-bring-up-with-8-05?tisearch=e2e-sitesearch&keymatch=0001-arm64-dts-j721e-Enable-Minimal-DT-configuration.patch#. If the patch commit ID is different, please share with me the correct one that you are referencing.
    Looking through the patch on the E2E thread I found, I see that all the serdes and pcie nodes are removed from the dts file, in which case it would be strange for PCIe to be functional at all. Therefore, I assume there are some some custom changes to re-enable PCIe. If possible, could you share a .patch file that can be applied on the default 8.6.1.2 SDK with your changes, so that I can reproduce the issue on my end?
    Also, could you clarify what the behavior is in 1? For example, is the switch and devices connected on the switch functional, and other than the one line of error, everything is working fine? Or you are getting a kernel panic like before?
    And lastly, could you share the full boot logs for question 1, and the build logs for question 2? I assume the build logs are something about dts since you are mentioning dts, but I would like to know if there were errors before dts compilation, and what the error logs are saying to verify that I am able to reproduce the issue seen on your end.
    Takuma
  • HI Takuma-san,
    For operation 1, No kernel panic occurs and pcitest.sh succeeds. I got the following error log in the startup log, so I'm worried that this error might affect other parts.
    I am attaching the boot log of TDA4VMSDK 8.6.1.2.
    U-Boot SPL 2021.01-g44a87e3ab8 (Sep 06 2022 - 07:31:49 +0000)
    Model: Texas Instruments K3 J721E SoC
    Board: J721EX-PM2-SOM rev A
    SYSFW ABI: 3.1 (firmware rev 0x0016 '22.1.1--v2022.01 (Terrific Llam')
    Trying to boot from MMC2
    spl_load_fit_image: Skip load 'dm': image size is 0!
    Starting ATF on ARM64 core...
    NOTICE:  BL31: v2.5(release):08.01.00.006-dirty
    NOTICE:  BL31: Built : 00:07:53, Aug  2 2023
    U-Boot SPL 2021.01-dirty (Aug 02 2023 - 00:57:18 +0000)
    Detected: J7X-BASE-CPB rev E3
    Detected: J7X-VSC8514-ETH rev E2
    U-Boot 2021.01-g44a87e3ab8 (Mar 29 2023 - 04:13:35 +0000)
    SoC:   J721E SR1.1
    DRAM:  4 GiB
    Flash: 0 Bytes
    MMC:   sdhci@4f80000: 0, sdhci@4fb0000: 1
    In:    serial@2800000
    Out:   serial@2800000
    Err:   serial@2800000
    am65_cpsw_nuss ethernet@46000000: K3 CPSW: nuss_ver: 0x6BA00101 cpsw_ver: 0x6BA80100 ale_ver: 0x00293904 Ports:1 mdio_freq:1000000
    Net:   eth0: ethernet@46000000port@1
    Hit any key to stop autoboot:  0
    switch to partitions #0, OK
    mmc1 is current device
    SD/MMC found on device 1
    Failed to load 'boot.scr'
    Failed to load 'uEnv.txt'
    20236800 bytes read in 843 ms (22.9 MiB/s)
    102282 bytes read in 13 ms (7.5 MiB/s)
       Loading Device Tree to 000000008fee4000, end 000000008fffffff ... OK
    Starting kernel ...
    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
    [    0.000000] Linux version 5.10.100-g7a7a3af903 (oe-user@oe-host) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #1 SMP PREEMPT Tue Aug 1 01:28:31 UTC 2023
    [    0.000000] Machine model: Texas Instruments K3 J721E SoC
    [    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
    [    0.000000] printk: bootconsole [ns16550a0] enabled
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a1000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a1100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a2000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a2100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a3000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a3100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a4000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a4100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a5000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a5000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a5100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a5100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node c66-dma-memory@a6000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node c66-memory@a6100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node c66-dma-memory@a7000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node c66-memory@a7100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node c71-dma-memory@a8000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node c71-memory@a8100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000ac000000, size 2 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-virtual-eth-queues@ac000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000ac200000, size 30 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-virtual-eth-buffers@ac200000, compatible id shared-dma-pool
    [    0.000000] Zone ranges:
    [    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
    [    0.000000]   DMA32    empty
    [    0.000000]   Normal   [mem 0x0000000100000000-0x00000008ffffffff]
    [    0.000000] Movable zone start for each node
    [    0.000000] Early memory node ranges
    [    0.000000]   node   0: [mem 0x0000000080000000-0x000000009e7fffff]
    [    0.000000]   node   0: [mem 0x000000009e800000-0x00000000a8ffffff]
    [    0.000000]   node   0: [mem 0x00000000a9000000-0x00000000a9ffffff]
    [    0.000000]   node   0: [mem 0x00000000aa000000-0x00000000abbfffff]
    [    0.000000]   node   0: [mem 0x00000000abc00000-0x00000000abffffff]
    [    0.000000]   node   0: [mem 0x00000000ac000000-0x00000000adffffff]
    [    0.000000]   node   0: [mem 0x00000000ae000000-0x00000000ffffffff]
    [    0.000000]   node   0: [mem 0x0000000880000000-0x00000008ffffffff]
    [    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff]
    [    0.000000] cma: Reserved 512 MiB at 0x00000000e0000000
    [    0.000000] psci: probing for conduit method from DT.
    [    0.000000] psci: PSCIv1.1 detected in firmware.
    [    0.000000] psci: Using standard PSCI v0.2 function IDs
    [    0.000000] psci: Trusted OS migration not required
    [    0.000000] psci: SMC Calling Convention v1.2
    [    0.000000] percpu: Embedded 2 pages/cpu s50776 r8192 d72104 u131072
    [    0.000000] Detected PIPT I-cache on CPU0
    [    0.000000] CPU features: detected: GIC system register CPU interface
    [    0.000000] CPU features: detected: EL2 vector hardening
    [    0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 65472
    [    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),1m(ospi.sysfw),256k(ospi.env.backup),57088k@8m(ospi.rootfs),256k(ospi.phypattern);47034000.hyperbus:512k(hbmc.tiboot3),2m(hbmc.tispl),4m(hbmc.u-boot),256k(hbmc.env),1m(hbmc.sysfw),-@8m(hbmc.rootfs) root=PARTUUID=f2fdac57-02 rw rootfstype=ext4 rootwait
    [    0.000000] Dentry cache hash table entries: 524288 (order: 6, 4194304 bytes, linear)
    [    0.000000] Inode-cache hash table entries: 262144 (order: 5, 2097152 bytes, linear)
    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
    [    0.000000] software IO TLB: mapped [mem 0x00000000dc000000-0x00000000e0000000] (64MB)
    [    0.000000] Memory: 3338176K/4194304K available (11392K kernel code, 1330K rwdata, 4608K rodata, 1984K init, 752K bss, 331840K reserved, 524288K cma-reserved)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
    [    0.000000] rcu:     RCU event tracing is enabled.
    [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
    [    0.000000]  Trampoline variant of Tasks RCU enabled.
    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    [    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
    [    0.000000] GICv3: 960 SPIs implemented
    [    0.000000] GICv3: 0 Extended SPIs implemented
    [    0.000000] GICv3: Distributor has no Range Selector support
    [    0.000000] GICv3: 16 PPIs implemented
    [    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
    [    0.000000] ITS [mem 0x01820000-0x0182ffff]
    [    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
    [    0.000000] ITS@0x0000000001820000: allocated 1048576 Devices @880800000 (flat, esz 8, psz 64K, shr 0)
    [    0.000000] ITS: using cache flushing for cmd queue
    [    0.000000] GICv3: using LPI property table @0x00000008800b0000
    [    0.000000] GIC: using cache flushing for LPI property table
    [    0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008800c0000
    [    0.000000] random: get_random_bytes called from start_kernel+0x31c/0x4cc with crng_init=0
    [    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
    [    0.000002] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
    [    0.008382] Console: colour dummy device 80x25
    [    0.012945] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [    0.023614] pid_max: default: 32768 minimum: 301
    [    0.028362] LSM: Security Framework initializing
    [    0.033106] Mount-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
    [    0.040673] Mountpoint-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
    [    0.049635] rcu: Hierarchical SRCU implementation.
    [    0.054691] Platform MSI: msi-controller@1820000 domain created
    [    0.060932] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
    [    0.070233] EFI services will not be available.
    [    0.074980] smp: Bringing up secondary CPUs ...
    [    0.080216] Detected PIPT I-cache on CPU1
    [    0.080238] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
    [    0.080248] GICv3: CPU1: using allocated LPI pending table @0x00000008800d0000
    [    0.080283] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
    [    0.080333] smp: Brought up 1 node, 2 CPUs
    [    0.109680] SMP: Total of 2 processors activated.
    [    0.114485] CPU features: detected: 32-bit EL0 Support
    [    0.119740] CPU features: detected: CRC32 instructions
    [    0.133503] CPU: All CPU(s) started at EL2
    [    0.137697] alternatives: patching kernel code
    [    0.142682] devtmpfs: initialized
    [    0.150939] KASLR disabled due to lack of seed
    [    0.155598] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.165561] futex hash table entries: 512 (order: -1, 32768 bytes, linear)
    [    0.173242] pinctrl core: initialized pinctrl subsystem
    [    0.178825] DMI not present or invalid.
    [    0.183039] NET: Registered protocol family 16
    [    0.190474] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
    [    0.197776] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.205777] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.214079] thermal_sys: Registered thermal governor 'step_wise'
    [    0.214081] thermal_sys: Registered thermal governor 'power_allocator'
    [    0.220526] cpuidle: using governor menu
    [    0.231323] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.238282] ASID allocator initialised with 65536 entries
    [    0.261822] HugeTLB registered 16.0 GiB page size, pre-allocated 0 pages
    [    0.268682] HugeTLB registered 512 MiB page size, pre-allocated 0 pages
    [    0.275440] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.283361] cryptd: max_cpu_qlen set to 1000
    [    0.289116] ACPI: Interpreter disabled.
    [    0.293242] k3-chipinfo 43000014.chipid: Family:J721E rev:SR2.0 JTAGID[0x1bb6402f] Detected
    [    0.302035] vsys_3v3: supplied by evm_12v0
    [    0.306405] vsys_5v0: supplied by evm_12v0
    [    0.311164] iommu: Default domain type: Translated
    [    0.316308] SCSI subsystem initialized
    [    0.320433] mc: Linux media interface: v0.10
    [    0.324851] videodev: Linux video capture interface: v2.00
    [    0.330479] pps_core: LinuxPPS API ver. 1 registered
    [    0.335553] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.344890] PTP clock support registered
    [    0.348909] EDAC MC: Ver: 3.0.0
    [    0.352694] FPGA manager framework
    [    0.356207] Advanced Linux Sound Architecture Driver Initialized.
    [    0.362804] clocksource: Switched to clocksource arch_sys_counter
    [    0.369232] VFS: Disk quotas dquot_6.6.0
    [    0.373279] VFS: Dquot-cache hash table entries: 8192 (order 0, 65536 bytes)
    [    0.380585] pnp: PnP ACPI: disabled
    [    0.386413] NET: Registered protocol family 2
    [    0.390992] IP idents hash table entries: 65536 (order: 3, 524288 bytes, linear)
    [    0.399610] tcp_listen_portaddr_hash hash table entries: 4096 (order: 0, 65536 bytes, linear)
    [    0.408379] TCP established hash table entries: 32768 (order: 2, 262144 bytes, linear)
    [    0.416574] TCP bind hash table entries: 32768 (order: 3, 524288 bytes, linear)
    [    0.424513] TCP: Hash tables configured (established 32768 bind 32768)
    [    0.431262] UDP hash table entries: 2048 (order: 0, 65536 bytes, linear)
    [    0.438156] UDP-Lite hash table entries: 2048 (order: 0, 65536 bytes, linear)
    [    0.445541] NET: Registered protocol family 1
    [    0.450235] RPC: Registered named UNIX socket transport module.
    [    0.456297] RPC: Registered udp transport module.
    [    0.461101] RPC: Registered tcp transport module.
    [    0.465904] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.472489] PCI: CLS 0 bytes, default 64
    [    0.476848] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
    [    0.487105] Initialise system trusted keyrings
    [    0.491716] workingset: timestamp_bits=46 max_order=16 bucket_order=0
    [    0.499932] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.506123] NFS: Registering the id_resolver key type
    [    0.511302] Key type id_resolver registered
    [    0.515573] Key type id_legacy registered
    [    0.519690] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.526538] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    0.534177] 9p: Installing v9fs 9p2000 file system support
    [    0.559203] Key type asymmetric registered
    [    0.563390] Asymmetric key parser 'x509' registered
    [    0.568386] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
    [    0.575945] io scheduler mq-deadline registered
    [    0.580571] io scheduler kyber registered
    [    0.585890] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
    [    0.592069] pinctrl-single 11c000.pinctrl: 173 pins, size 692
    [    0.598474] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
    [    0.606310] switchtec: loaded.
    [    0.611056] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
    [    0.617317] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
    [    0.625110] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
    [    0.633254] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x00001faf)
    [    0.642215] arm-smmu-v3 36600000.iommu: allocated 524288 entries for cmdq
    [    0.651061] arm-smmu-v3 36600000.iommu: allocated 524288 entries for evtq
    [    0.658772] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to wired irqs
    [    0.671981] brd: module loaded
    [    0.677745] loop: module loaded
    [    0.681656] megasas: 07.714.04.00-rc1
    [    0.687238] tun: Universal TUN/TAP device driver, 1.6
    [    0.692680] igbvf: Intel(R) Gigabit Virtual Function Network Driver
    [    0.699090] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
    [    0.705166] sky2: driver version 1.30
    [    0.709481] VFIO - User Level meta-driver version: 0.3
    [    0.715176] i2c /dev entries driver
    [    0.719059] Error: Driver 'k3-soc-thermal' is already registered, aborting...
    [    0.726710] sdhci: Secure Digital Host Controller Interface driver
    [    0.733027] sdhci: Copyright(c) Pierre Ossman
    [    0.737743] sdhci-pltfm: SDHCI platform and OF driver helper
    [    0.744108] ledtrig-cpu: registered to indicate activity on CPUs
    [    0.750429] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    0.757612] optee: probing for conduit method.
    [    0.762170] optee: revision 3.12 (3d47a131)
    [    0.762414] optee: initialized driver
    [    0.771809] NET: Registered protocol family 17
    [    0.776420] 9pnet: Installing 9P2000 support
    [    0.780804] Key type dns_resolver registered
    [    0.785327] Loading compiled-in X.509 certificates
    [    0.794969] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
    [    0.801304] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
    [    0.809471] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0016 '22.1.1--v2022.01 (Terrific Llam')
    [    0.839555] random: fast init done
    [    0.873232] davinci-mcasp 2ba0000.mcasp: IRQ common not found
    [    0.880898] omap_i2c 40b00000.i2c: bus 0 rev0.12 at 100 kHz
    [    0.886985] omap_i2c 40b10000.i2c: bus 1 rev0.12 at 100 kHz
    [    0.893039] omap_i2c 42120000.i2c: bus 2 rev0.12 at 100 kHz
    [    0.899504] pca953x 3-0020: supply vcc not found, using dummy regulator
    [    0.906316] pca953x 3-0020: using no AI
    [    0.931613] pca953x 3-0022: supply vcc not found, using dummy regulator
    [    0.938414] pca953x 3-0022: using AI
    [    0.942682] gpio-480 (CTRL_PM_I2C_OE): hogged as output/high
    [    0.948656] gpio-481 (MCASP/TRACE_MUX_S0): hogged as output/low
    [    0.954909] gpio-482 (MCASP/TRACE_MUX_S1): hogged as output/high
    [    0.961405] omap_i2c 2000000.i2c: bus 3 rev0.12 at 400 kHz
    [    0.967832] omap_i2c 2010000.i2c: bus 4 rev0.12 at 400 kHz
    [    0.977904] omap_i2c 2020000.i2c: bus 5 rev0.12 at 400 kHz
    [    0.984215] pca953x 6-0020: supply vcc not found, using dummy regulator
    [    0.991033] pca953x 6-0020: using no AI
    [    1.019487] omap_i2c 2030000.i2c: bus 6 rev0.12 at 400 kHz
    [    1.025566] omap_i2c 2040000.i2c: bus 7 rev0.12 at 100 kHz
    [    1.031529] omap_i2c 2050000.i2c: bus 8 rev0.12 at 100 kHz
    [    1.037789] pca953x 9-0020: supply vcc not found, using dummy regulator
    [    1.044602] pca953x 9-0020: using no AI
    [    1.071131] omap_i2c 2060000.i2c: bus 9 rev0.12 at 400 kHz
    [    1.077564] ti-sci-intr bus@100000:bus@28380000:interrupt-controller2: Interrupt Router 137 domain created
    [    1.087544] ti-sci-intr bus@100000:interrupt-controller0: Interrupt Router 131 domain created
    [    1.096350] ti-sci-intr bus@100000:main-navss:interrupt-controller1: Interrupt Router 213 domain created
    [    1.106202] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created
    [    1.128542] j721e-pcie 2900000.pcie: J721E PROBE
    [    1.133282] j721e-pcie 2900000.pcie: pcie->mode 0
    [    1.138192] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    1.145856] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    1.154132] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    1.162409] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    2.173762] j721e-pcie 2900000.pcie: PCI host bridge to bus 0000:00
    [    2.180186] pci_bus 0000:00: root bus resource [bus 00-ff]
    [    2.185799] pci_bus 0000:00: root bus resource [io  0x0000-0xffff] (bus address [0x10001000-0x10010fff])
    [    2.195489] pci_bus 0000:00: root bus resource [mem 0x10011000-0x17ffffff]
    [    2.202540] pci 0000:00:00.0: [104c:b00d] type 01 class 0x060400
    [    2.208679] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
    [    2.218548] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
    [    2.228438] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0xe8 may corrupt adjacent RW1C bits
    [    2.238396] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits
    [    2.248365] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x92 may corrupt adjacent RW1C bits
    [    2.258325] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0xb2 may corrupt adjacent RW1C bits
    [    2.268309] pci 0000:00:00.0: supports D1
    [    2.272403] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
    [    2.278273] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x84 may corrupt adjacent RW1C bits
    [    2.288262] pci 0000:00:00.0: DPC: DPC init
    [    2.294218] pci 0000:00:00.0: scanning [bus 00-00] behind bridge, pass 0
    [    2.301071] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    2.309255] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits
    [    2.319213] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits
    [    2.329173] pci 0000:00:00.0: scanning [bus 00-00] behind bridge, pass 1
    [    2.336023] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits
    [    2.346020] pci 0000:00:00.0: write PRIMARY_BUS  00ff0100, busn_res.end 0x02x is_cardbus
    [    2.355764] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
    [    2.362534] pci 0000:00:00.0: PCI bridge to [bus 01]
    [    2.367822] pcieport 0000:00:00.0: PME: Signaling with IRQ 61
    [    2.373852] pcieport 0000:00:00.0: AER: enabled with IRQ 61
    [    2.379663] j721e-pcie 2900000.pcie: PCI RC End
    [    2.384607] j721e-pcie 2910000.pcie: J721E PROBE
    [    2.389329] j721e-pcie 2910000.pcie: pcie->mode 0
    [    2.394230] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [    2.401892] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [    2.410166] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [    2.418444] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    2.529624] j721e-pcie 2910000.pcie: Link up
    [    2.534040] j721e-pcie 2910000.pcie: PCI host bridge to bus 0001:00
    [    2.540446] pci_bus 0001:00: root bus resource [bus 00-ff]
    [    2.546051] pci_bus 0001:00: root bus resource [io  0x10000-0x1ffff] (bus address [0x18001000-0x18010fff])
    [    2.555918] pci_bus 0001:00: root bus resource [mem 0x18011000-0x1fffffff]
    [    2.562964] pci 0001:00:00.0: [104c:b00d] type 01 class 0x060400
    [    2.569164] pci 0001:00:00.0: supports D1
    [    2.573257] pci 0001:00:00.0: PME# supported from D0 D1 D3hot
    [    2.579160] pci 0001:00:00.0: DPC: DPC init
    [    2.585062] pci 0001:00:00.0: scanning [bus 00-00] behind bridge, pass 0
    [    2.591917] pci 0001:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    2.600103] pci 0001:00:00.0: scanning [bus 00-00] behind bridge, pass 1
    [    2.606987] pci 0001:00:00.0: write PRIMARY_BUS  00ff0100, busn_res.end 0x02x is_cardbus
    [    2.615309] pci 0001:01:00.0: [12d8:c232] type 01 class 0x060400
    [    2.621467] pci 0001:01:00.0: reg 0x10: [mem 0x00000000-0x0007ffff]
    [    2.628087] pci 0001:01:00.0: PME# supported from D0 D3hot D3cold
    [    2.634462] pci 0001:01:00.0: DPC: DPC init
    [    2.638758] pci 0001:01:00.0: 15.752 Gb/s available PCIe bandwidth, limited by 8.0 GT/s PCIe x2 link at 0001:00:00.0 (capable of 63.008 Gb/s with 8.0 GT/s PCIe x8 link)
    [    2.664317] pci 0001:01:00.0: scanning [bus 00-00] behind bridge, pass 0
    [    2.671170] pci 0001:01:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    2.679363] pci 0001:01:00.0: scanning [bus 00-00] behind bridge, pass 1
    [    2.686298] pci 0001:01:00.0: write PRIMARY_BUS  00ff0201, busn_res.end 0x02x is_cardbus
    [    2.694818] pci 0001:02:04.0: [12d8:c232] type 01 class 0x060400
    [    2.701194] pci 0001:02:04.0: PME# supported from D0 D3hot D3cold
    [    2.707558] pci 0001:02:04.0: DPC: DPC init
    [    2.711843] pci 0001:02:04.0: DPC: dpc->cap 0x2a0
    [    2.716860] pci 0001:02:06.0: [12d8:c232] type 01 class 0x060400
    [    2.723238] pci 0001:02:06.0: PME# supported from D0 D3hot D3cold
    [    2.729602] pci 0001:02:06.0: DPC: DPC init
    [    2.733887] pci 0001:02:06.0: DPC: dpc->cap 0x2a0
    [    2.738940] pci 0001:02:09.0: [12d8:c232] type 01 class 0x060400
    [    2.745265] pci 0001:02:09.0: PME# supported from D0 D3hot D3cold
    [    2.751566] pci 0001:02:09.0: DPC: DPC init
    [    2.757022] pci 0001:02:04.0: scanning [bus 00-00] behind bridge, pass 0
    [    2.763869] pci 0001:02:04.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    2.772061] pci 0001:02:06.0: scanning [bus 00-00] behind bridge, pass 0
    [    2.778908] pci 0001:02:06.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    2.787102] pci 0001:02:09.0: scanning [bus 00-00] behind bridge, pass 0
    [    2.793949] pci 0001:02:09.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    2.802141] pci 0001:02:04.0: scanning [bus 00-00] behind bridge, pass 1
    [    2.809066] pci 0001:02:04.0: write PRIMARY_BUS  00ff0302, busn_res.end 0x02x is_cardbus
    [    2.818809] pci_bus 0001:03: busn_res: [bus 03-ff] end is updated to 03
    [    2.825576] pci 0001:02:06.0: scanning [bus 00-00] behind bridge, pass 1
    [    2.832501] pci 0001:02:06.0: write PRIMARY_BUS  00ff0402, busn_res.end 0x02x is_cardbus
    [    2.840852] pci 0001:04:00.0: [104c:b00d] type 00 class 0xff0000
    [    2.847019] pci 0001:04:00.0: reg 0x10: [mem 0x00000000-0x000000ff]
    [    2.853434] pci 0001:04:00.0: reg 0x14: [mem 0x00000000-0x000001ff]
    [    2.859849] pci 0001:04:00.0: reg 0x18: [mem 0x00000000-0x000003ff]
    [    2.866263] pci 0001:04:00.0: reg 0x1c: [mem 0x00000000-0x00003fff]
    [    2.872678] pci 0001:04:00.0: reg 0x20: [mem 0x00000000-0x0001ffff]
    [    2.879092] pci 0001:04:00.0: reg 0x24: [mem 0x00000000-0x000fffff]
    [    2.885799] pci 0001:04:00.0: supports D1
    [    2.889892] pci 0001:04:00.0: PME# supported from D0 D1 D3hot
    [    2.895848] pci 0001:04:00.0: reg 0x224: [mem 0x00000000-0x003fffff 64bit]
    [    2.902874] pci 0001:04:00.0: VF(n) BAR0 space: [mem 0x00000000-0x00ffffff 64bit] (contains BAR0 for 4 VFs)
    [    2.913062] pci 0001:04:00.0: DPC: DPC init
    [    2.918974] pci_bus 0001:04: busn_res: [bus 04-ff] end is updated to 04
    [    2.925742] pci 0001:02:09.0: scanning [bus 00-00] behind bridge, pass 1
    [    2.932669] pci 0001:02:09.0: write PRIMARY_BUS  00ff0502, busn_res.end 0x02x is_cardbus
    [    2.940975] pci 0001:05:00.0: [12d8:c232] type 01 class 0x060400
    [    2.947303] pci 0001:05:00.0: PME# supported from D0 D3hot D3cold
    [    2.953601] pci 0001:05:00.0: DPC: DPC init
    [    2.957889] pci 0001:05:00.0: 15.752 Gb/s available PCIe bandwidth, limited by 8.0 GT/s PCIe x2 link at 0001:00:00.0 (capable of 126.016 Gb/s with 8.0 GT/s PCIe x16 link)
    [    2.975026] pci 0001:05:00.0: scanning [bus 00-00] behind bridge, pass 0
    [    2.981873] pci 0001:05:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    2.990065] pci 0001:05:00.0: scanning [bus 00-00] behind bridge, pass 1
    [    2.997003] pci 0001:05:00.0: write PRIMARY_BUS  00ff0605, busn_res.end 0x02x is_cardbus
    [    3.005328] pci 0001:06:00.0: [12d8:c232] type 01 class 0x060400
    [    3.011714] pci 0001:06:00.0: PME# supported from D0 D3hot D3cold
    [    3.018087] pci 0001:06:00.0: DPC: DPC init
    [    3.022372] pci 0001:06:00.0: DPC: dpc->cap 0x2a0
    [    3.027393] pci 0001:06:02.0: [12d8:c232] type 01 class 0x060400
    [    3.033783] pci 0001:06:02.0: PME# supported from D0 D3hot D3cold
    [    3.040152] pci 0001:06:02.0: DPC: DPC init
    [    3.044437] pci 0001:06:02.0: DPC: dpc->cap 0x2a0
    [    3.049457] pci 0001:06:04.0: [12d8:c232] type 01 class 0x060400
    [    3.055846] pci 0001:06:04.0: PME# supported from D0 D3hot D3cold
    [    3.062215] pci 0001:06:04.0: DPC: DPC init
    [    3.066500] pci 0001:06:04.0: DPC: dpc->cap 0x2a0
    [    3.071527] pci 0001:06:06.0: [12d8:c232] type 01 class 0x060400
    [    3.077915] pci 0001:06:06.0: PME# supported from D0 D3hot D3cold
    [    3.084284] pci 0001:06:06.0: DPC: DPC init
    [    3.088570] pci 0001:06:06.0: DPC: dpc->cap 0x2a0
    [    3.094727] pci 0001:06:00.0: scanning [bus 00-00] behind bridge, pass 0
    [    3.101577] pci 0001:06:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    3.109769] pci 0001:06:02.0: scanning [bus 00-00] behind bridge, pass 0
    [    3.116616] pci 0001:06:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    3.124808] pci 0001:06:04.0: scanning [bus 00-00] behind bridge, pass 0
    [    3.131655] pci 0001:06:04.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    3.139847] pci 0001:06:06.0: scanning [bus 00-00] behind bridge, pass 0
    [    3.146693] pci 0001:06:06.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    3.154887] pci 0001:06:00.0: scanning [bus 00-00] behind bridge, pass 1
    [    3.161818] pci 0001:06:00.0: write PRIMARY_BUS  00ff0706, busn_res.end 0x02x is_cardbus
    [    3.171558] pci_bus 0001:07: busn_res: [bus 07-ff] end is updated to 07
    [    3.178326] pci 0001:06:02.0: scanning [bus 00-00] behind bridge, pass 1
    [    3.185255] pci 0001:06:02.0: write PRIMARY_BUS  00ff0806, busn_res.end 0x02x is_cardbus
    [    3.194994] pci_bus 0001:08: busn_res: [bus 08-ff] end is updated to 08
    [    3.201762] pci 0001:06:04.0: scanning [bus 00-00] behind bridge, pass 1
    [    3.208689] pci 0001:06:04.0: write PRIMARY_BUS  00ff0906, busn_res.end 0x02x is_cardbus
    [    3.218427] pci_bus 0001:09: busn_res: [bus 09-ff] end is updated to 09
    [    3.225195] pci 0001:06:06.0: scanning [bus 00-00] behind bridge, pass 1
    [    3.232122] pci 0001:06:06.0: write PRIMARY_BUS  00ff0a06, busn_res.end 0x02x is_cardbus
    [    3.241857] pci_bus 0001:0a: busn_res: [bus 0a-ff] end is updated to 0a
    [    3.248623] pci_bus 0001:06: busn_res: [bus 06-ff] end is updated to 0a
    [    3.255389] pci_bus 0001:05: busn_res: [bus 05-ff] end is updated to 0a
    [    3.262154] pci_bus 0001:02: busn_res: [bus 02-ff] end is updated to 0a
    [    3.268919] pci_bus 0001:01: busn_res: [bus 01-ff] end is updated to 0a
    [    3.275704] pci 0001:00:00.0: BAR 14: assigned [mem 0x18100000-0x195fffff]
    [    3.282732] pci 0001:00:00.0: BAR 15: assigned [mem 0x19600000-0x197fffff 64bit pref]
    [    3.290734] pci 0001:00:00.0: BAR 13: assigned [io  0x10000-0x10fff]
    [    3.297227] pci 0001:01:00.0: BAR 14: assigned [mem 0x18200000-0x195fffff]
    [    3.304252] pci 0001:01:00.0: BAR 15: assigned [mem 0x19600000-0x197fffff 64bit pref]
    [    3.312254] pci 0001:01:00.0: BAR 0: assigned [mem 0x18100000-0x1817ffff]
    [    3.319195] pci 0001:01:00.0: BAR 13: assigned [io  0x10000-0x10fff]
    [    3.325688] pci 0001:02:06.0: BAR 14: assigned [mem 0x18200000-0x193fffff]
    [    3.332713] pci 0001:02:09.0: BAR 14: assigned [mem 0x19400000-0x195fffff]
    [    3.339740] pci 0001:02:09.0: BAR 15: assigned [mem 0x19600000-0x197fffff 64bit pref]
    [    3.347742] pci 0001:02:09.0: BAR 13: assigned [io  0x10000-0x10fff]
    [    3.354234] pci 0001:02:04.0: PCI bridge to [bus 03]
    [    3.359328] pci 0001:04:00.0: BAR 7: assigned [mem 0x18400000-0x193fffff 64bit]
    [    3.366807] pci 0001:04:00.0: BAR 5: assigned [mem 0x18200000-0x182fffff]
    [    3.373749] pci 0001:04:00.0: BAR 4: assigned [mem 0x18300000-0x1831ffff]
    [    3.380692] pci 0001:04:00.0: BAR 3: assigned [mem 0x18320000-0x18323fff]
    [    3.387633] pci 0001:04:00.0: BAR 2: assigned [mem 0x18324000-0x183243ff]
    [    3.394574] pci 0001:04:00.0: BAR 1: assigned [mem 0x18324400-0x183245ff]
    [    3.401517] pci 0001:04:00.0: BAR 0: assigned [mem 0x18324600-0x183246ff]
    [    3.408458] pci 0001:02:06.0: PCI bridge to [bus 04]
    [    3.413535] pci 0001:02:06.0:   bridge window [mem 0x18200000-0x193fffff]
    [    3.420483] pci 0001:05:00.0: BAR 14: assigned [mem 0x19400000-0x195fffff]
    [    3.427509] pci 0001:05:00.0: BAR 15: assigned [mem 0x19600000-0x197fffff 64bit pref]
    [    3.435511] pci 0001:05:00.0: BAR 13: assigned [io  0x10000-0x10fff]
    [    3.442003] pci 0001:06:04.0: BAR 14: assigned [mem 0x19400000-0x195fffff]
    [    3.449028] pci 0001:06:04.0: BAR 15: assigned [mem 0x19600000-0x197fffff 64bit pref]
    [    3.457030] pci 0001:06:04.0: BAR 13: assigned [io  0x10000-0x10fff]
    [    3.463523] pci 0001:06:00.0: PCI bridge to [bus 07]
    [    3.468612] pci 0001:06:02.0: PCI bridge to [bus 08]
    [    3.473701] pci 0001:06:04.0: PCI bridge to [bus 09]
    [    3.478773] pci 0001:06:04.0:   bridge window [io  0x10000-0x10fff]
    [    3.485182] pci 0001:06:04.0:   bridge window [mem 0x19400000-0x195fffff]
    [    3.492121] pci 0001:06:04.0:   bridge window [mem 0x19600000-0x197fffff 64bit pref]
    [    3.500042] pci 0001:06:06.0: PCI bridge to [bus 0a]
    [    3.505131] pci 0001:05:00.0: PCI bridge to [bus 06-0a]
    [    3.510469] pci 0001:05:00.0:   bridge window [io  0x10000-0x10fff]
    [    3.516877] pci 0001:05:00.0:   bridge window [mem 0x19400000-0x195fffff]
    [    3.523819] pci 0001:05:00.0:   bridge window [mem 0x19600000-0x197fffff 64bit pref]
    [    3.531740] pci 0001:02:09.0: PCI bridge to [bus 05-0a]
    [    3.537078] pci 0001:02:09.0:   bridge window [io  0x10000-0x10fff]
    [    3.543487] pci 0001:02:09.0:   bridge window [mem 0x19400000-0x195fffff]
    [    3.550426] pci 0001:02:09.0:   bridge window [mem 0x19600000-0x197fffff 64bit pref]
    [    3.558346] pci 0001:01:00.0: PCI bridge to [bus 02-0a]
    [    3.563685] pci 0001:01:00.0:   bridge window [io  0x10000-0x10fff]
    [    3.570093] pci 0001:01:00.0:   bridge window [mem 0x18200000-0x195fffff]
    [    3.577032] pci 0001:01:00.0:   bridge window [mem 0x19600000-0x197fffff 64bit pref]
    [    3.584954] pci 0001:00:00.0: PCI bridge to [bus 01-0a]
    [    3.590292] pci 0001:00:00.0:   bridge window [io  0x10000-0x10fff]
    [    3.596696] pci 0001:00:00.0:   bridge window [mem 0x18100000-0x195fffff]
    [    3.603632] pci 0001:00:00.0:   bridge window [mem 0x19600000-0x197fffff 64bit pref]
    [    3.611644] pcieport 0001:00:00.0: enabling device (0000 -> 0003)
    [    3.617994] pcieport 0001:00:00.0: PME: Signaling with IRQ 64
    [    3.624044] pcieport 0001:00:00.0: AER: enabled with IRQ 64
    [    3.629904] pcieport 0001:01:00.0: enabling device (0000 -> 0003)
    [    3.637226] pcieport 0001:02:04.0: DPC: DPC probe
    [    3.642124] pcieport 0001:02:04.0: DPC: enabled with IRQ 70
    [    3.647822] pcieport 0001:02:04.0: DPC: error containment capabilities: Int Msg #1, RPExt- PoisonedTLP- SwTrigger- RP PIO Log 0, DL_ActiveErr-
    [    3.661153] pcieport 0001:00:00.0: of_irq_parse_pci: failed with rc=-22
    [    3.667926] pcieport 0001:02:06.0: enabling device (0000 -> 0002)
    [    3.674591] pcieport 0001:02:06.0: DPC: DPC probe
    [    3.679479] pcieport 0001:02:06.0: DPC: enabled with IRQ 74
    [    3.685182] pcieport 0001:02:06.0: DPC: error containment capabilities: Int Msg #1, RPExt- PoisonedTLP- SwTrigger- RP PIO Log 0, DL_ActiveErr-
    [    3.698549] pcieport 0001:00:00.0: of_irq_parse_pci: failed with rc=-22
    [    3.705322] pcieport 0001:02:09.0: enabling device (0000 -> 0003)
    [    3.712124] pcieport 0001:00:00.0: of_irq_parse_pci: failed with rc=-22
    [    3.718905] pci-endpoint-test 0001:04:00.0: enabling device (0000 -> 0002)
    [    3.726089] pcieport 0001:05:00.0: enabling device (0000 -> 0003)
    [    3.732893] pcieport 0001:00:00.0: of_irq_parse_pci: failed with rc=-22
    [    3.740116] pcieport 0001:06:00.0: DPC: DPC probe
    [    3.745015] pcieport 0001:06:00.0: DPC: enabled with IRQ 80
    [    3.750714] pcieport 0001:06:00.0: DPC: error containment capabilities: Int Msg #1, RPExt- PoisonedTLP- SwTrigger- RP PIO Log 0, DL_ActiveErr-
    [    3.764060] pcieport 0001:00:00.0: of_irq_parse_pci: failed with rc=-22
    [    3.771276] pcieport 0001:06:02.0: DPC: DPC probe
    [    3.776152] pcieport 0001:06:02.0: DPC: enabled with IRQ 84
    [    3.781851] pcieport 0001:06:02.0: DPC: error containment capabilities: Int Msg #1, RPExt- PoisonedTLP- SwTrigger- RP PIO Log 0, DL_ActiveErr-
    [    3.795196] pcieport 0001:00:00.0: of_irq_parse_pci: failed with rc=-22
    [    3.801969] pcieport 0001:06:04.0: enabling device (0000 -> 0003)
    [    3.808677] pcieport 0001:06:04.0: pciehp: Slot #0 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise+ Interlock- NoCompl- IbPresDis- LLActRep+
    [    3.822580] pcieport 0001:06:04.0: pciehp: Slot(0): Card present
    [    3.822598] pcieport 0001:06:04.0: DPC: DPC probe
    [    3.833607] pcieport 0001:06:04.0: DPC: enabled with IRQ 88
    [    3.839306] pcieport 0001:06:04.0: DPC: error containment capabilities: Int Msg #1, RPExt- PoisonedTLP- SwTrigger- RP PIO Log 0, DL_ActiveErr-
    [    3.852659] pcieport 0001:00:00.0: of_irq_parse_pci: failed with rc=-22
    [    3.859878] pcieport 0001:06:06.0: DPC: DPC probe
    [    3.864759] pcieport 0001:06:06.0: DPC: enabled with IRQ 92
    [    3.870455] pcieport 0001:06:06.0: DPC: error containment capabilities: Int Msg #1, RPExt- PoisonedTLP- SwTrigger- RP PIO Log 0, DL_ActiveErr-
    [    3.883757] j721e-pcie 2910000.pcie: PCI RC End
    [    3.888713] j721e-pcie 2920000.pcie: J721E PROBE
    [    3.893446] j721e-pcie 2920000.pcie: pcie->mode 0
    [    3.898347] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [    3.906013] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
    [    3.914288] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
    [    3.922566] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    4.033901] j721e-pcie 2920000.pcie: Link up
    [    4.038320] j721e-pcie 2920000.pcie: PCI host bridge to bus 0002:00
    [    4.044726] pci_bus 0002:00: root bus resource [bus 00-ff]
    [    4.050331] pci_bus 0002:00: root bus resource [io  0x20000-0x2ffff] (bus address [0x1000-0x10fff])
    [    4.059578] pci_bus 0002:00: root bus resource [mem 0x4400011000-0x4407ffffff] (bus address [0x00011000-0x07ffffff])
    [    4.070356] pci 0002:00:00.0: [104c:b00d] type 01 class 0x060400
    [    4.076555] pci 0002:00:00.0: supports D1
    [    4.080649] pci 0002:00:00.0: PME# supported from D0 D1 D3hot
    [    4.086552] pci 0002:00:00.0: DPC: DPC init
    [    4.092487] pci 0002:00:00.0: scanning [bus 00-00] behind bridge, pass 0
    [    4.099340] pci 0002:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    4.107526] pci 0002:00:00.0: scanning [bus 00-00] behind bridge, pass 1
    [    4.114416] pci 0002:00:00.0: write PRIMARY_BUS  00ff0100, busn_res.end 0x02x is_cardbus
    [    4.122723] pci 0002:01:00.0: [2646:500d] type 00 class 0x010802
    [    4.128893] pci 0002:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
    [    4.136105] pci 0002:01:00.0: DPC: DPC init
    [    4.140394] pci 0002:01:00.0: 15.752 Gb/s available PCIe bandwidth, limited by 8.0 GT/s PCIe x2 link at 0002:00:00.0 (capable of 31.504 Gb/s with 8.0 GT/s PCIe x4 link)
    [    4.168316] pci_bus 0002:01: busn_res: [bus 01-ff] end is updated to 01
    [    4.175089] pci 0002:00:00.0: BAR 14: assigned [mem 0x4400100000-0x44001fffff]
    [    4.182472] pci 0002:01:00.0: BAR 0: assigned [mem 0x4400100000-0x4400103fff 64bit]
    [    4.190312] pci 0002:00:00.0: PCI bridge to [bus 01]
    [    4.195384] pci 0002:00:00.0:   bridge window [mem 0x4400100000-0x44001fffff]
    [    4.202771] pcieport 0002:00:00.0: enabling device (0000 -> 0002)
    [    4.209120] pcieport 0002:00:00.0: PME: Signaling with IRQ 97
    [    4.215143] pcieport 0002:00:00.0: AER: enabled with IRQ 97
    [    4.220981] j721e-pcie 2920000.pcie: PCI RC End
    [    4.226422] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235
    [    4.236299] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
    [    4.243058] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64
    [    4.251990] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211
    [    4.262132] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
    [    4.268890] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64
    [    4.276848] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 15, base_baud = 6000000) is a 8250
    [    4.286224] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 33, base_baud = 3000000) is a 8250
    [    4.294970] printk: console [ttyS2] enabled
    [    4.303407] printk: bootconsole [ns16550a0] disabled
    [    4.313854] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 34, base_baud = 3000000) is a 8250
    [    4.322786] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 35, base_baud = 3000000) is a 8250
    [    4.332910] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled
    [    4.343420] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcc-supply regulator, assuming enabled
    [    4.353572] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq-supply regulator, assuming enabled
    [    4.363811] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq2-supply regulator, assuming enabled
    [    4.374696] scsi host0: ufshcd
    [    4.396726] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[1, 1], lane[1, 1], pwr[SLOWAUTO_MODE, SLOWAUTO_MODE], rate = 0
    [    4.418808] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    4.427773] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
    [    4.436070] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
    [    4.450038] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0
    [    4.457850] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[3, 3], lane[2, 2], pwr[FAST MODE, FAST MODE], rate = 2
    [    4.469878] cdns-ufshcd 4e84000.ufs: ufshcd_find_max_sup_active_icc_level: Regulator capability was not set, actvIccLevel=0
    [    4.470038] mmc0: CQHCI version 5.10
    [    4.481164] scsi 0:0:0:49488: Well-known LUN    TOSHIBA  THGAF8G8T23BAILB 0300 PQ: 0 ANSI: 6
    [    4.484598] davinci-mcasp 2ba0000.mcasp: IRQ common not found
    [    4.493763] scsi 0:0:0:49476: Well-known LUN    TOSHIBA  THGAF8G8T23BAILB 0300 PQ: 0 ANSI: 6
    [    4.507587] cdns-ufshcd 4e84000.ufs: ufshcd_scsi_add_wlus: BOOT WLUN not found
    [    4.515002] scsi 0:0:0:0: Direct-Access     TOSHIBA  THGAF8G8T23BAILB 0300 PQ: 0 ANSI: 6
    [    4.523286] sd 0:0:0:0: Power-on or device reset occurred
    [    4.528992] scsi 0:0:0:1: Direct-Access     TOSHIBA  THGAF8G8T23BAILB 0300 PQ: 0 ANSI: 6
    [    4.529739] sd 0:0:0:0: [sda] 8192 4096-byte logical blocks: (33.6 MB/32.0 MiB)
    [    4.538836] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
    [    4.551859] sd 0:0:0:1: Power-on or device reset occurred
    [    4.551898] sd 0:0:0:0: [sda] Write Protect is off
    [    4.558928] sd 0:0:0:1: [sdb] 7808000 4096-byte logical blocks: (32.0 GB/29.8 GiB)
    [    4.569683] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, supports DPO and FUA
    [    4.569692] sd 0:0:0:1: [sdb] Write Protect is off
    [    4.583018] sd 0:0:0:0: [sda] Optimal transfer size 65536 bytes
    [    4.589026] sd 0:0:0:1: [sdb] Write cache: enabled, read cache: enabled, supports DPO and FUA
    [    4.597595] sd 0:0:0:1: [sdb] Optimal transfer size 65536 bytes
    [    4.606042] sd 0:0:0:0: [sda] Attached SCSI disk
    [    4.610979] sd 0:0:0:1: [sdb] Attached SCSI disk
    [    4.615616] vdd_mmc1: supplied by vsys_3v3
    [    4.620531] pca953x 4-0020: supply vcc not found, using dummy regulator
    [    4.627183] pca953x 4-0020: using no AI
    [    4.655768] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100
    [    4.662603] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100
    [    4.669426] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100
    [    4.676241] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100
    [    4.683048] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100
    [    4.686162] mmc0: Command Queue Engine enabled
    [    4.694014] mmc0: new HS200 MMC card at address 0001
    [    4.699329] mmcblk0: mmc0:0001 S0J56X 14.8 GiB
    [    4.704001] mmcblk0boot0: mmc0:0001 S0J56X partition 1 31.5 MiB
    [    4.710043] mmcblk0boot1: mmc0:0001 S0J56X partition 2 31.5 MiB
    [    4.710231] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
    [    4.724519] mmcblk0rpmb: mmc0:0001 S0J56X partition 3 4.00 MiB, chardev (236:0)
    [    4.733217] ti-udma 31150000.dma-controller: Channels: 122 (tchan: 61, rchan: 61, gp-rflow: 16)
    [    4.747714] spi-nor spi0.0: mt35xu512aba (65536 Kbytes)
    [    4.752949] 8 cmdlinepart partitions found on MTD device 47040000.spi.0
    [    4.759548] Creating 8 MTD partitions on "47040000.spi.0":
    [    4.765020] 0x000000000000-0x000000080000 : "ospi.tiboot3"
    [    4.771006] 0x000000080000-0x000000280000 : "ospi.tispl"
    [    4.776684] 0x000000280000-0x000000680000 : "ospi.u-boot"
    [    4.782427] 0x000000680000-0x0000006c0000 : "ospi.env"
    [    4.787965] 0x0000006c0000-0x0000007c0000 : "ospi.sysfw"
    [    4.793627] 0x0000007c0000-0x000000800000 : "ospi.env.backup"
    [    4.799762] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
    [    4.805536] 0x000003fc0000-0x000004000000 : "ospi.phypattern"
    [    4.814287] spi-nor spi1.0: mt25qu512a (65536 Kbytes)
    [    4.858815] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    4.867639] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
    [    4.875929] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
    [    4.889540] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
    [    4.896522] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
    [    4.903733] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
    [    4.910050] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0
    [    4.920332] davinci-mcasp 2ba0000.mcasp: IRQ common not found
    [    4.920724] mmc1: CQHCI version 5.10
    [    4.937791] debugfs: Directory 'pd:27' with parent 'pm_genpd' already present!
    [    4.945041] debugfs: Directory 'pd:26' with parent 'pm_genpd' already present!
    [    4.953225] debugfs: Directory 'pd:242' with parent 'pm_genpd' already present!
    [    4.960551] debugfs: Directory 'pd:241' with parent 'pm_genpd' already present!
    [    4.967856] debugfs: Directory 'pd:240' with parent 'pm_genpd' already present!
    [    4.975163] debugfs: Directory 'pd:239' with parent 'pm_genpd' already present!
    [    4.983398] input: gpio-keys as /devices/platform/gpio-keys/input/input0
    [    5.004163] ALSA device list:
    [    5.007129]   No soundcards found.
    [    5.934810] pcieport 0001:06:04.0: pciehp: Slot(0): No link
    [    5.993596] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
    [    6.002014] Waiting for root device PARTUUID=f2fdac57-02...
    [    6.050596] mmc1: new ultra high speed DDR50 SDHC card at address 5048
    [    6.057426] mmcblk1: mmc1:5048 SDCIT 15.0 GiB
    [    6.064606]  mmcblk1: p1 p2
    [    6.440138] EXT4-fs (mmcblk1p2): recovery complete
    [    6.451825] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
    [    6.459932] VFS: Mounted root (ext4 filesystem) on device 179:98.
    [    6.466941] devtmpfs: mounted
    [    6.470205] Freeing unused kernel memory: 1984K
    [    6.474760] Run /sbin/init as init process
    [    6.624285] systemd[1]: System time before build time, advancing clock.
    [    6.674950] NET: Registered protocol family 10
    [    6.679850] Segment Routing with IPv6
    [    6.695688] systemd[1]: systemd 244 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
    [    6.717172] systemd[1]: Detected architecture arm64.
    Welcome to Arago 2021.09!
    [    6.751774] systemd[1]: Set hostname to <j7-evm>.
    [    6.926770] systemd[1]: /lib/systemd/system/docker.socket:6: ListenStream= references a path below legacy directory /var/run/, updating /var/run/docker.sock → /run/docker.sock; please update the unit file accordingly.
    [    6.990261] random: systemd: uninitialized urandom read (16 bytes read)
    [    6.996990] systemd[1]: system-getty.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
    [    7.009331] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
    [    7.019236] systemd[1]: Created slice system-getty.slice.
    [  OK  ] Created slice system-getty.slice.
    [    7.038883] random: systemd: uninitialized urandom read (16 bytes read)
    [    7.046178] systemd[1]: Created slice system-serial\x2dgetty.slice.
    [  OK  ] Created slice system-serial\x2dgetty.slice.
    [    7.066876] random: systemd: uninitialized urandom read (16 bytes read)
    [    7.074093] systemd[1]: Created slice system-serial\x2dgetty9600.slice.
    [  OK  ] Created slice system-serial\x2dgetty9600.slice.
    [    7.095534] systemd[1]: Created slice User and Session Slice.
    [  OK  ] Created slice User and Session Slice.
    [    7.118998] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [  OK  ] Started Dispatch Password …ts to Console Directory Watch.
    [    7.142920] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [  OK  ] Started Forward Password R…uests to Wall Directory Watch.
    [    7.166921] systemd[1]: Reached target Paths.
    [  OK  ] Reached target Paths.
    [    7.182860] systemd[1]: Reached target Remote File Systems.
    [  OK  ] Reached target Remote File Systems.
    [    7.202854] systemd[1]: Reached target Slices.
    [  OK  ] Reached target Slices.
    [    7.218854] systemd[1]: Reached target Swap.
    [  OK  ] Reached target Swap.
    [    7.236444] systemd[1]: Listening on RPCbind Server Activation Socket.
    [  OK  ] Listening on RPCbind Server Activation Socket.
    [    7.258884] systemd[1]: Reached target RPC Port Mapper.
    [  OK  ] Reached target RPC Port Mapper.
    [    7.281503] systemd[1]: Listening on Process Core Dump Socket.
    [  OK  ] Listening on Process Core Dump Socket.
    [    7.302973] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [  OK  ] Listening on initctl Compatibility Named Pipe.
    [    7.334648] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
    [    7.342971] systemd[1]: Listening on Journal Socket (/dev/log).
    [  OK  ] Listening on Journal Socket (/dev/log).
    [    7.363080] systemd[1]: Listening on Journal Socket.
    [  OK  ] Listening on Journal Socket.
    [    7.379125] systemd[1]: Listening on Network Service Netlink Socket.
    [  OK  ] Listening on Network Service Netlink Socket.
    [    7.403052] systemd[1]: Listening on udev Control Socket.
    [  OK  ] Listening on udev Control Socket.
    [    7.422957] systemd[1]: Listening on udev Kernel Socket.
    [  OK  ] Listening on udev Kernel Socket.
    [    7.444996] systemd[1]: Mounting Huge Pages File System...
    [    7.461071] systemd[1]: Mounting POSIX Message Queue File System...
    [    7.489318] systemd[1]: Mounting Kernel Debug File System...
    [    7.514282] systemd[1]: Mounting Temporary Directory (/tmp)...
    [    7.533168] systemd[1]: Starting Create list of static device nodes for the current kernel...
             Starting Create list of st…odes for the current kernel...
    [    7.561349] systemd[1]: Starting Start psplash boot splash screen...
    [    7.585246] systemd[1]: Starting RPC Bind...
    [    7.599005] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
    [    7.610917] systemd[1]: Starting Journal Service...
    [    7.635242] systemd[1]: Starting Load Kernel Modules...
    [    7.650972] cryptodev: loading out-of-tree module taints kernel.
    [    7.659359] systemd[1]: Starting Remount Root and Kernel File Systems...
             Starting Remount Root and Kernel File Systems cryptodev: driver 1.10 loaded.
    [0m...
    [    7.686560] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
    [    7.697333] systemd[1]: Starting udev Coldplug all Devices...
    [    7.721684] systemd[1]: Started RPC Bind.
    [  OK  ] Started RPC Bind.
    [    7.739253] systemd[1]: Mounted Huge Pages File System.
    [  OK  ] Mounted Huge Pages File System.
    [    7.759209] systemd[1]: Mounted POSIX Message Queue File System.
    [  OK  ] Mounted POSIX Message Queue File System.
    [    7.787265] systemd[1]: Mounted Kernel Debug File System.
    [  OK  ] Mounted Kernel Debug File System.
    [    7.807181] systemd[1]: Mounted Temporary Directory (/tmp).
    [  OK  ] Mounted Temporary Directory (/tmp).
    [    7.827126] systemd[1]: Started Journal Service.
    [  OK  ] Started Journal Service.
    [  OK  ] Started Create list of sta… nodes for the current kernel.
    [FAILED] Failed to start Start psplash boot splash screen.
    See 'systemctl status psplash-start.service' for details.
    [DEPEND] Dependency failed for Star…progress communication helper.
    [  OK  ] Started Load Kernel Modules.
    [  OK  ] Started Remount Root and Kernel File Systems.
             Mounting Kernel Configuration File System...
             Starting Flush Journal to Persistent Storage...
             Starting Apply Kernel Variables...
    [    7.978920] systemd-journald[183]: Received client request to flush runtime journal.
             Starting Create Static Device Nodes in /dev...
    [  OK  ] Mounted Kernel Configuration File System.
    [  OK  ] Started Flush Journal to Persistent Storage.
    [  OK  ] Started Apply Kernel Variables.
    [  OK  ] Started Create Static Device Nodes in /dev.
    [  OK  ] Reached target Local File Systems (Pre).
             Mounting /media/ram...
             Mounting /var/volatile...
             Starting udev Kernel Device Manager...
    [  OK  ] Started udev Coldplug all Devices.
    [  OK  ] Mounted /media/ram.
    [  OK  ] Mounted /var/volatile.
             Starting udev Wait for Complete Device Initialization...
             Starting Load/Save Random Seed...
    [  OK  ] Reached target Local File Systems.
             Starting Create Volatile Files and Directories...
    [  OK  ] Started udev Kernel Device Manager.
    [  OK  ] Started Create Volatile Files and Directories.
             Starting Network Time Synchronization...
             Starting Update UTMP about System Boot/Shutdown...
    [  OK  ] Started Update UTMP about System Boot/Shutdown.
    [  OK  ] Started Network Time Synchronization.
    [  OK  ] Reached target System Time Set.
    [  OK  ] Reached target System Time Synchronized.
    [    8.417514] CAN device driver interface
    [    8.571212] ina2xx 5-0040: power monitor ina226 (Rshunt = 10000 uOhm)
    [    8.580925] ina2xx 5-0041: power monitor ina226 (Rshunt = 10000 uOhm)
    [    8.606303] ina2xx 5-0042: power monitor ina226 (Rshunt = 10000 uOhm)
    [    8.615870] ina2xx 5-0043: power monitor ina226 (Rshunt = 10000 uOhm)
    [    8.625335] ina2xx 5-0044: power monitor ina226 (Rshunt = 10000 uOhm)
    [    8.645809] ina2xx 5-0045: power monitor ina226 (Rshunt = 5000 uOhm)
    [    8.654405] ina2xx 5-0046: power monitor ina226 (Rshunt = 10000 uOhm)
    [    8.671046] ina2xx 5-0047: power monitor ina226 (Rshunt = 10000 uOhm)
    [    8.704318] ina2xx 5-0048: power monitor ina226 (Rshunt = 10000 uOhm)
    [    8.729229] ina2xx 5-0049: power monitor ina226 (Rshunt = 10000 uOhm)
    [    8.738058] ina2xx 5-004a: power monitor ina226 (Rshunt = 10000 uOhm)
    [    8.751104] ina2xx 5-004b: power monitor ina226 (Rshunt = 10000 uOhm)
    [    8.764103] ina2xx 5-004c: power monitor ina226 (Rshunt = 10000 uOhm)
    [    8.772207] nvme nvme0: pci function 0002:01:00.0
    [    8.780167] nvme 0002:01:00.0: enabling device (0000 -> 0002)
    [    8.790210] nvme nvme0: missing or invalid SUBNQN field.
    [    8.800112] ina2xx 5-004d: power monitor ina226 (Rshunt = 10000 uOhm)
    [    8.807115] nvme nvme0: 2/0/0 default/read/poll queues
    [    8.850840] ina2xx 5-004e: power monitor ina226 (Rshunt = 10000 uOhm)
    [    8.875821] ina2xx 5-004f: power monitor ina226 (Rshunt = 10000 uOhm)
    [    8.888530] img_enc 4200000.video-encoder: vxe_enc_probe: using heap 1 for internal alloc
    [    9.065141] k3-dsp-rproc 4d80800000.dsp: assigned reserved memory node c66-dma-memory@a7000000
    [    9.119486] img_enc 4200000.video-encoder: encoder registered as /dev/video0
    [    9.152310] k3-dsp-rproc 4d80800000.dsp: configured DSP for remoteproc mode
    [    9.154667] img_dec 4300000.video-decoder: decoder registered as /dev/video1
    [    9.174846] k3-dsp-rproc 4d80800000.dsp: local reset is deasserted for device
    [    9.188142] [drm] Initialized tidss 1.0.0 20180215 for 4a00000.dss on minor 0
    [    9.198255] tidss 4a00000.dss: [drm] Cannot find any crtc or sizes
    [    9.230934] remoteproc remoteproc0: 4d80800000.dsp is available
    [    9.243868] PVR_K:  207: Read BVNC 22.104.208.318 from HW device registers
    [    9.252026] k3-dsp-rproc 4d81800000.dsp: assigned reserved memory node c66-dma-memory@a6000000
    [    9.260847] remoteproc remoteproc0: powering up 4d80800000.dsp
    [    9.266779] remoteproc remoteproc0: Booting fw image j7-c66_0-fw, size 144692
    [    9.278406] k3-dsp-rproc 4d80800000.dsp: booting DSP core using boot addr = 0xa6200400
    [    9.291906] PVR_K:  207: RGX Device registered with BVNC 22.104.208.318
    [    9.291966]  remoteproc0#vdev0buffer: assigned reserved memory node c66-dma-memory@a7000000
    [    9.315377] virtio_rpmsg_bus virtio0: rpmsg host is online
    [    9.320891]  remoteproc0#vdev0buffer: registered virtio0 (type 7)
    [    9.333623] remoteproc remoteproc0: remote processor 4d80800000.dsp is now up
    [    9.341109] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd
    [    9.348672] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe
    [    9.357595] [drm] Initialized pvr 1.13.5776728 20170530 for 4e20000000.gpu on minor 1
    [    9.367645] k3-dsp-rproc 4d81800000.dsp: configured DSP for remoteproc mode
    [    9.378047] k3-dsp-rproc 4d81800000.dsp: local reset is deasserted for device
    [    9.401117] remoteproc remoteproc1: 4d81800000.dsp is available
    [    9.412287] remoteproc remoteproc1: powering up 4d81800000.dsp
    [    9.418610] remoteproc remoteproc1: Booting fw image j7-c66_1-fw, size 144692
    [    9.425997] k3-dsp-rproc 64800000.dsp: assigned reserved memory node c71-dma-memory@a8000000
    [    9.434598] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
    [    9.447111] k3-dsp-rproc 4d81800000.dsp: booting DSP core using boot addr = 0xa7200400
    [    9.455843] k3-dsp-rproc 64800000.dsp: configured DSP for remoteproc mode
    [    9.465528] platform 41000000.r5f: configured R5F for IPC-only mode
    [    9.473973]  remoteproc1#vdev0buffer: assigned reserved memory node c66-dma-memory@a6000000
    [    9.482669] virtio_rpmsg_bus virtio1: rpmsg host is online
    [    9.489796]  remoteproc1#vdev0buffer: registered virtio1 (type 7)
    [    9.496252] remoteproc remoteproc2: 64800000.dsp is available
    [    9.502161] remoteproc remoteproc1: remote processor 4d81800000.dsp is now up
    [    9.509650] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xd
    [    9.517314] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xe
    [    9.564425] platform 41000000.r5f: assigned reserved memory node r5f-dma-memory@a0000000
    [    9.695057] remoteproc remoteproc3: 41000000.r5f is available
    [    9.803056] remoteproc remoteproc2: powering up 64800000.dsp
    [    9.808717] remoteproc remoteproc2: Booting fw image j7-c71_0-fw, size 10489000
    [    9.819732] remoteproc remoteproc2: unsupported resource 65538
    [    9.822967] remoteproc remoteproc3: attaching to 41000000.r5f
    [    9.826146] k3-dsp-rproc 64800000.dsp: booting DSP core using boot addr = 0xa8e00000
    [    9.848795]  remoteproc2#vdev0buffer: assigned reserved memory node c71-dma-memory@a8000000
    [    9.861076] virtio_rpmsg_bus virtio2: rpmsg host is online
    [    9.866612]  remoteproc2#vdev0buffer: registered virtio2 (type 7)
    [    9.871668] virtio_rpmsg_bus virtio2: creating channel ti.ipc4.ping-pong addr 0xd
    [    9.878397] remoteproc remoteproc2: remote processor 64800000.dsp is now up
    [    9.882139] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xe
    [    9.947677] platform 41000000.r5f: R5F core initialized in IPC-only mode
    [   10.012003]  remoteproc3#vdev0buffer: assigned reserved memory node r5f-dma-memory@a0000000
    [   10.169725] virtio_rpmsg_bus virtio3: rpmsg host is online
    [   10.187471] virtio_rpmsg_bus virtio3: creating channel ti.ipc4.ping-pong addr 0xd
    [   10.212949]  remoteproc3#vdev0buffer: registered virtio3 (type 7)
    [   10.220657] remoteproc remoteproc3: remote processor 41000000.r5f is now attached
    [   10.365257] platform 5c00000.r5f: configured R5F for remoteproc mode
    [   10.493509] platform 5c00000.r5f: assigned reserved memory node r5f-dma-memory@a2000000
    [   10.530850] random: crng init done
    [   10.534254] random: 7 urandom warning(s) missed due to ratelimiting
    [   10.544084] remoteproc remoteproc4: 5c00000.r5f is available
    [   10.551014] platform 5d00000.r5f: configured R5F for remoteproc mode
    [   10.571517] platform 5d00000.r5f: assigned reserved memory node r5f-dma-memory@a3000000
    [   10.581422] remoteproc remoteproc5: 5d00000.r5f is available
    [   10.585061] remoteproc remoteproc4: powering up 5c00000.r5f
    [  OK  ] Started Load/Save Random Seed.[   10.597055] remoteproc remoteproc4: Booting fw image j7-main-r5f0_0-fw, size 626036
    [   10.611405] remoteproc remoteproc5: powering up 5d00000.r5f
    [   10.617005] remoteproc remoteproc5: Booting fw image j7-main-r5f0_1-fw, size 98444
    [   10.642778] platform 5e00000.r5f: configured R5F for remoteproc mode
    [   10.649202]  remoteproc4#vdev0buffer: assigned reserved memory node r5f-dma-memory@a2000000
    [   10.657725]  remoteproc5#vdev0buffer: assigned reserved memory node r5f-dma-memory@a3000000
    [   10.658016] virtio_rpmsg_bus virtio4: rpmsg host is online
    [   10.666350] virtio_rpmsg_bus virtio5: rpmsg host is online
    [   10.680584]  remoteproc4#vdev0buffer: registered virtio4 (type 7)
    [   10.682350]  remoteproc5#vdev0buffer: registered virtio5 (type 7)
    [   10.686691] remoteproc remoteproc4: remote processor 5c00000.r5f is now up
    [   10.694314] remoteproc remoteproc5: remote processor 5d00000.r5f is now up
    [   10.711619] platform 5e00000.r5f: assigned reserved memory node r5f-dma-memory@a4000000
    [   10.719893] virtio_rpmsg_bus virtio5: creating channel ti.ipc4.ping-pong addr 0xd
    [   10.736671] remoteproc remoteproc6: 5e00000.r5f is available
    [   10.746923] platform 5f00000.r5f: configured R5F for remoteproc mode
    [   10.753533] remoteproc remoteproc6: powering up 5e00000.r5f
    [   10.759229] remoteproc remoteproc6: Booting fw image j7-main-r5f1_0-fw, size 98444
    [   10.773204] platform 5f00000.r5f: assigned reserved memory node r5f-dma-memory@a5000000
    [   10.781443]  remoteproc6#vdev0buffer: assigned reserved memory node r5f-dma-memory@a4000000
    [   10.801216] remoteproc remoteproc7: 5f00000.r5f is available
    [   10.807268] virtio_rpmsg_bus virtio6: rpmsg host is online
    [   10.818886]  remoteproc6#vdev0buffer: registered virtio6 (type 7)
    [   10.830853] remoteproc remoteproc6: remote processor 5e00000.r5f is now up
    [   10.843258] remoteproc remoteproc7: powering up 5f00000.r5f
    [   10.849022] remoteproc remoteproc7: Booting fw image j7-main-r5f1_1-fw, size 98444
    [   10.851166] virtio_rpmsg_bus virtio6: creating channel ti.ipc4.ping-pong addr 0xd
    [   10.872819]  remoteproc7#vdev0buffer: assigned reserved memory node r5f-dma-memory@a5000000
    [   10.885772] virtio_rpmsg_bus virtio7: rpmsg host is online
    [   10.895864]  remoteproc7#vdev0buffer: registered virtio7 (type 7)
    [   10.901598] virtio_rpmsg_bus virtio7: creating channel ti.ipc4.ping-pong addr 0xd
    [   10.906644] remoteproc remoteproc7: remote processor 5f00000.r5f is now up
    [   10.915133] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0xe
    [   10.964409] virtio_rpmsg_bus virtio7: creating channel rpmsg_chrdev addr 0xe
    [   10.979418] virtio_rpmsg_bus virtio6: creating channel rpmsg_chrdev addr 0xe
    [  OK  ] Created slice system-systemd\x2dfsck.slice.
    [   11.043232] m_can_platform 40528000.can: m_can device registered (irq=23, version=32)
    [   11.059310] m_can_platform 40568000.can: m_can device registered (irq=25, version=32)
    [   11.078204] m_can_platform 2701000.can: m_can device registered (irq=55, version=32)
    [   11.095945] m_can_platform 2721000.can: m_can device registered (irq=57, version=32)
    [  OK  ] Found device THGAF8G8T23BAILB.
             Starting File System Check on /dev/sdb...
    [  OK  ] Started File System Check on /dev/sdb.
             Mounting /run/media/sdb...
    [   11.287977] EXT4-fs (sdb): mounted filesystem with ordered data mode. Opts: (null)
    [  OK  ] Mounted /run/media/sdb.
    [  OK  ] Found device /dev/mmcblk1p1.
             Starting File System Check on /dev/mmcblk1p1...
    [   11.959364] virtio_rpmsg_bus virtio4: creating channel ti.ethfw.notifyservice addr 0x1e
    [   11.970246] usbcore: registered new interface driver usbfs
    [   11.991251] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0xe
    [  OK  ] Started File System Check on /dev/mmcblk1p1.
    [   12.018257] virtio_rpmsg_bus virtio4: creating channel rpmsg-kdrv addr 0x1a
    [   12.026134] rpmsg-kdrv-eth-switch rpmsg-kdrv-1-mpu_1_0_ethswitch-device-0: Device info: permissions: 3FFFFFFF uart_id: 2
    [   12.039385] rpmsg-kdrv-eth-switch rpmsg-kdrv-1-mpu_1_0_ethswitch-device-0: FW ver 0.2 (rev 0)  2/Feb/2022 SHA:bd5a13f4
             Mounting /run/media/mmcblk1p1...
    [   12.053873] rpmsg-kdrv-eth-switch rpmsg-kdrv-3-mpu_1_0_ethmac-device-1: Device info: permissions: 3FFFFFFF uart_id: 2
    [   12.067386] usbcore: registered new interface driver hub
    [   12.068374] rpmsg-kdrv-eth-switch rpmsg-kdrv-3-mpu_1_0_ethmac-device-1: FW ver 0.2 (rev 0)  2/Feb/2022 SHA:bd5a13f4
    [  OK  ] Mounted /run/media/mmcblk1p1.
    [   12.163585] usbcore: registered new device driver usb
    [   12.183512] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: rpmsg attach_ext - rx_mtu:1522 features:0000000B tx_mtu[0]:2024 flow_idx:172 tx_cpsw_psil_dst_id:51712 mac_addr:70:ff:76:1d:92:c1 mac-only:0
    [   12.184153] omap_rng 4e10000.rng: Random Number Generator ver. 241b34c
    [   12.211767] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: virt_cpsw_nuss mac loaded
    [   12.213957] remoteproc remoteproc8: b034000.pru is available
    [   12.222825] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: rdev_features:0000000B rdev_mtu:1522 flow_id:172 tx_psil_dst_id:4A00 mac_only:0
    [   12.237969] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: local_mac_addr:00:00:00:00:00:00 rdev_mac_addr:70:ff:76:1d:92:c1
    [   12.254990] cdns-csi2rx: probe of 4504000.csi-bridge failed with error -22
    [   12.276656] cdns-csi2rx: probe of 4514000.csi-bridge failed with error -22
    [   12.296763] remoteproc remoteproc9: b004000.rtu is available
    [   12.315463] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: rpmsg attach_ext - rx_mtu:1522 features:00000007 tx_mtu[0]:2024 flow_idx:173 tx_cpsw_psil_dst_id:51713 mac_addr:70:ff:76:1d:92:c2 mac-only:1
    [   12.330324] remoteproc remoteproc10: b00a000.txpru is available
    [   12.348748] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: virt_cpsw_nuss mac loaded
    [   12.350572] remoteproc remoteproc11: b038000.pru is available
    [   12.356706] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: rdev_features:00000007 rdev_mtu:1522 flow_id:173 tx_psil_dst_id:4A01 mac_only:1
    [   12.363882] remoteproc remoteproc12: b006000.rtu is available
    [   12.383308] remoteproc remoteproc13: b00c000.txpru is available
    [   12.386878] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: local_mac_addr:00:00:00:00:00:00 rdev_mac_addr:70:ff:76:1d:92:c2
    [   12.391792] remoteproc remoteproc14: b134000.pru is available
    [   12.419223] remoteproc remoteproc15: b104000.rtu is available
    [   12.425488] remoteproc remoteproc16: b10a000.txpru is available
    [   12.431605] remoteproc remoteproc17: b138000.pru is available
    [   12.441958] remoteproc remoteproc18: b106000.rtu is available
    [   12.448700] remoteproc remoteproc19: b10c000.txpru is available
    [  OK  ] Found device KINGSTON OM8PDP3512B-A01.
             Starting File System Check on /dev/nvme0n1...
    [  OK  ] Started File System Check on /dev/nvme0n1.
             Mounting /run/media/nvme0n1...
    [   13.020151] EXT4-fs (nvme0n1): mounted filesystem with ordered data mode. Opts: (null)
    [  OK  ] Mounted /run/media/nvme0n1.
    [   13.112217] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
    [   13.117723] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 1
    [   13.125983] xhci-hcd xhci-hcd.2.auto: hcc params 0x200073c9 hci version 0x100 quirks 0x0000002000010010
    [   13.135416] xhci-hcd xhci-hcd.2.auto: irq 693, io mem 0x06410000
    [   13.141584] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
    [   13.149839] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [   13.157047] usb usb1: Product: xHCI Host Controller
    [   13.161917] usb usb1: Manufacturer: Linux 5.10.100-g7a7a3af903 xhci-hcd
    [   13.168518] usb usb1: SerialNumber: xhci-hcd.2.auto
    [   13.173651] hub 1-0:1.0: USB hub found
    [   13.177430] hub 1-0:1.0: 1 port detected
    [   13.181546] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
    [   13.187034] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 2
    [   13.194686] xhci-hcd xhci-hcd.2.auto: Host supports USB 3.0 SuperSpeed
    [   13.201234] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
    [   13.209371] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
    [   13.217621] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [   13.224830] usb usb2: Product: xHCI Host Controller
    [   13.229696] usb usb2: Manufacturer: Linux 5.10.100-g7a7a3af903 xhci-hcd
    [   13.236301] usb usb2: SerialNumber: xhci-hcd.2.auto
    [   13.241402] hub 2-0:1.0: USB hub found
    [   13.246766] hub 2-0:1.0: 1 port detected
    [  OK  ] Started udev Wait for Complete Device Initialization.
    [  OK  ] Started Hardware RNG Entropy Gatherer Daemon.
    [  OK  ] Reached target System Initialization.
    [  OK  ] Started Daily rotation of log files.
    [  OK  ] Started Daily Cleanup of Temporary Directories.
    [  OK  ] Reached target Timers.
    [  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
    [  OK  ] Listening on D-Bus System Message B[   13.439242] usb 1-1: new high-speed USB device number 2 using xhci-hcd
    us Socket.
             Starting Docker Socket for the API.
    [  OK  ] Listening on dropbear.socket.
             Starting Reboot and dump vmcore via kexec...
    [  OK  ] Listening on Docker Socket for the API.
    [  OK  ] Started Reboot and dump vmcore via kexec.
    [  OK  ] Reached target Sockets.
    [  OK  ] Reached target Basic System.
             Starting Save/Restore Sound Card State...[   13.607180] usb 1-1: New USB device found, idVendor=0451, idProduct=8142, bcdDevice= 1.00
    [   13.618837] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=1
    [  OK  ] Started Job spooling tools.[   13.630260] usb 1-1: SerialNumber: 7F0600790B90
    [   13.647363] hub 1-1:1.0: USB hub found
    [   13.652702] hub 1-1:1.0: 4 ports detected
    [  OK  ] Started Periodic Command Scheduler.
    [  OK  ] Started D-Bus System Message Bus.
             Starting Print notice about GPLv3 packages...
             Starting set host name as per compatible name...
             Starting IPv6 Packet Filtering Framework...
             Starting IPv4 Packet Filtering Framework...
    [  OK  ] Started irqbalance daemon.
             Starting Telephony service...
             Starting rc.pvr.service...
             Starting startwlanap...
             Starting startwlansta...
             Starting Login Service...
    [  OK  ] Started TEE Supplicant.
             Starting Update weston ini… based on the platform name...
    [  OK  ] Started Save/Restore Sound Card State.
    [  OK  ] Started IPv6 Packet Filtering Framework.
    [  OK  ] Started IPv4 Packet Filtering Framework.
    [  OK  ] Reached target Network (Pre).
    [  OK  ] Reached target Sound Card.
             Starting Network Service...
    [  OK  ] Started startwlansta.
    [  OK  ] Started startwlanap.
    [  OK  ] Started Telephony service.
    [  OK  ] Started set host name as per compatible name.
    [  OK  ] Started Update weston ini …ge based on the platform name.
    [   13.951842] Bluetooth: Core ver 2.22
    [   13.960839] NET: Registered protocol family 31
    [   13.968572] Bluetooth: HCI device and connection manager initialized
    [   13.977847] Bluetooth: HCI socket layer initialized
    [   13.986846] Bluetooth: L2CAP socket layer initialized
    [   13.991969] Bluetooth: SCO socket layer initialized
    [  OK  ] Started Network Service.
             Starting Wait for Network to be Configured...
             Starting Network Name Resolution...
    [  OK  ] Started rc.pvr.service.
             Starting weston.service...
    [  OK  ] Listening on Load/Save RF …itch Status /dev/rfkill Watch.
    [  OK  ] Started weston.service.
             Starting DEMO...
             Starting telnetd.service...
    [  OK  ] Started DEMO.
    [   14.179917] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: virt_cpsw_nuss mac started
    [  OK  ] Started telnetd.service.
    [  OK  ] Started Login Service.
    [   14.438341] PVR_K:  1092: RGX Firmware image 'rgx.fw.22.104.208.318' loaded
    [   14.528514] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: virt_cpsw_nuss mac started
    [  OK  ] Started Network Name Resolution.
    [  OK  ] Reached target Network.
    [  OK  ] Reached target Host and Network Name Lookups.
             Starting Avahi mDNS/DNS-SD Stack...
             Starting Enable and configure wl18xx bluetooth stack...
    [  OK  ] Started NFS status monitor for NFSv2/3 locking..
             Starting Simple Network Ma…ent Protocol (SNMP) Daemon....
             Starting Permit User Sessions...
    [  OK  ] Started Permit User Sessions.
    [  OK  ] Started Getty on tty1.
    [  OK  ] Started Serial Getty on ttyS3.
    [  OK  ] Started Serial Getty on ttyS2.
    [   14.631964] TI DP83867 46000f00.mdio:00: attached PHY driver [TI DP83867] (mii_bus:phy_addr=46000f00.mdio:00, irq=POLL)
             Starting Synchronize System and HW clocks...
    [FAILED] Failed to start Synchronize System and HW clocks.
    See 'systemctl status sync-clocks.service' for details.
    [  OK  ] Started Enable and configure wl18xx bluetooth stack.
    [  OK  ] Started Avahi mDNS/DNS-SD Stack.
    [   14.677990] am65-cpsw-nuss 46000000.ethernet eth0: Link is Down
    [  OK  ] Started Simple Network Man…ement Protocol (SNMP) Daemon..
    NOTICE: This file system contains the following GPLv3 packages:
            autoconf
            bash-dev
            bash
            bc
            binutils
            cifs-utils
            coreutils-stdbuf
            coreutils
            cpio
            cpp-symlinks
            cpp
            dosfstools
            elfutils
            g++-symlinks
            g++
            gawk
            gcc-symlinks
            gcc
            gdb
            gdbserver
            gettext
            glmark2
            gstreamer1.0-libav-dev
            gstreamer1.0-libav
            gzip
            less
            libasm1
            libbfd
            libdw1
            libelf1
            libgdbm-compat4
            libgdbm-dev
            libgdbm6
            libgettextlib
            libgettextsrc
            libgmp-dev
            libgmp10
            libgmpxx4
            libidn2-0
            libidn2-dev
            libmpc3
            libmpfr6
            libreadline-dev
            libreadline8
            libunistring-dev
            libunistring2
            m4-dev
            m4
            make
            nettle-dev
            nettle
            parted
            python3-rfc3987
            python3-strict-rfc3339
            tar
            which
            zeromq
    If you do not wish to distribute GPLv3 components please remove
    the above packages prior to distribution.  This can be done using
    the opkg remove command.  i.e.:
        opkg remove <package>
    Where <package> is the name printed in the list above
    NOTE: If the package is a dependency of another package you
          will be notified of the dependent packages.  You should
          use the --force-removal-of-dependent-packages option to
          also remove the dependent packages as well
    [  OK  ] Started Print notice about GPLv3 packages.
    |  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
    |     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
    |__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
                  |___|                    |___|
    Arago Project http://arago-project.org j7-evm ttyS2
    Arago 2021.09 j7-evm ttyS2
    j7-evm login: root (automatic login)
    No directory, logging in with HOME=/
    root@j7-evm:/#
    root@j7-evm:/#
    root@j7-evm:/# /usr/sbin/lspci
    0000:00:00.0 PCI bridge: Texas Instruments Device b00d
    0001:00:00.0 PCI bridge: Texas Instruments Device b00d
    0001:01:00.0 PCI bridge: Pericom Semiconductor Device c232 (rev 07)
    0001:02:04.0 PCI bridge: Pericom Semiconductor Device c232 (rev 06)
    0001:02:06.0 PCI bridge: Pericom Semiconductor Device c232 (rev 06)
    0001:02:09.0 PCI bridge: Pericom Semiconductor Device c232 (rev 06)
    0001:04:00.0 Unassigned class [ff00]: Texas Instruments Device b00d
    0001:05:00.0 PCI bridge: Pericom Semiconductor Device c232 (rev 06)
    0001:06:00.0 PCI bridge: Pericom Semiconductor Device c232 (rev 07)
    0001:06:02.0 PCI bridge: Pericom Semiconductor Device c232 (rev 06)
    0001:06:04.0 PCI bridge: Pericom Semiconductor Device c232 (rev 06)
    0001:06:06.0 PCI bridge: Pericom Semiconductor Device c232 (rev 06)
    0002:00:00.0 PCI bridge: Texas Instruments Device b00d
    0002:01:00.0 Non-Volatile memory controller: Kingston Technology Company, Inc. Device 500d (rev 01)
    root@j7-evm:/# /usr/sbin/lspci -vvt
    -+-[0002:00]---00.0-[01]----00.0  Kingston Technology Company, Inc. Device 500d
     +-[0001:00]---00.0-[01-0a]----00.0-[02-0a]--+-04.0-[03]--
     |                                           +-06.0-[04]----00.0  Texas Instruments Device b00d
     |                                           \-09.0-[05-0a]----00.0-[06-0a]--+-00.0-[07]--
     |        +-02.0-[08]--
     |        +-04.0-[09]--
     |        \-06.0-[0a]--
     \-[0000:00]---00.0-[01]--
    root@j7-evm:/#
    2 is a whole other story, but I'd like to eventually get it working on a custom board.
    The patch I'm using is the one you pointed out.
    For SDK 8.02.0.1 I used 0001-arm64-dts-j721e-Enable-Minimal-DT-configuration.patch and added what I needed. I wanted to do the same with SDK 8.6.1.2, so I initially built using only the 0001-arm64-dts-j721e-Enable-Minimal-DT-configuration.patch that I was using, but here I am getting the error has occurred. So I figured I needed something for 8.6.
    I will check the situation a little more and make another thread if there are any unclear points.
    Takumi
  • Hi Takumi,
    For 1, looking through some patches to the upstream Linux kernel online, it seems this irq debug message is known. To quote from a commit message,
    Interrupt Pin register is read-only and optional. Some pci devices may use
    msi/msix but leave the value of Interrupt Pin non-zero. In this case, the
    driver will print information as below:
    pci 0000:40:00.0: of_irq_parse_pci() failed with rc=-22
    So it looks like the message depends on the PCIe device that is being connected, and furthermore, not necessarily an error that could break the system if the device that is being connected does not have interrupt pin register. If the PCIe devices are functioning as intended, I think it would be fine to ignore the log.
    For 2, yes, I think it makes sense to make a separate thread to not dilute the current thread as it is a separate topic. However, please post the link to the new E2E in this thread for better tracking.
    Takuma
  • HI Takuma-san,
    Thank you for your reply.
    We can actually use PCIeSW to proceed with debugging.
    Takumi
