DRA746: eMMC1 switch to bus width failed with TS3A27518E multiplexer
Part Number: DRA746
Other Parts Discussed in Thread: TS3A27518E, , TS3A27518
Dear Experts
We have an eMMC mount issue on customized board (DRA746).  customer use an multiplexer(TS3A27518E) to select one of storage by eMMC1, block diagram as below.
default connection is MTFC8GACA (Micron)
When system try to mount MTFC8GACA, we found two main error message as below
(1) mmc0: switch to bus width 1 failed
(2) mmcblk0: error -84 transferring data, sector ?, nr 8, cmd response 0x900, card status 0xb00
2.610700] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    2.617392] [drm] No driver support for vblank timestamp query.
[    2.634855] [drm] Enabling DMM ywrap scrolling
[    2.639816] mmc0: MAN_BKOPS_EN bit is not set
[    2.641501] mmc0: switch to bus width 1 failed
[    2.641812] mmc0: new high speed MMC card at address 0001
[    2.642285] mmcblk0: mmc0:0001 R1J55A 7.28 GiB
[    2.652516] mmcblk0boot0: mmc0:0001 R1J55A partition 1 8.00 MiB
[    2.662751] mmcblk0boot1: mmc0:0001 R1J55A partition 2 8.00 MiB
[    2.663495] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
[    2.663557] mmcblk0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
[    2.663562] mmcblk0: retrying using single block read
[    2.663786] mmcblk0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
[    2.663793] blk_update_request: I/O error, dev mmcblk0, sector 0
[    2.663975] mmcblk0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
[    2.663980] blk_update_request: I/O error, dev mmcblk0, sector 1
[    2.664159] mmcblk0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
[    2.664164] blk_update_request: I/O error, dev mmcblk0, sector 2
[    2.664345] mmcblk0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
[    2.664350] blk_update_request: I/O error, dev mmcblk0, sector 3
[    2.664684] mmcblk0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
[    2.664689] blk_update_request: I/O error, dev mmcblk0, sector 5
[    2.665022] mmcblk0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
[    2.665027] blk_update_request: I/O error, dev mmcblk0, sector 7
[    2.665032] Buffer I/O error on dev mmcblk0, logical block 0, async page read
[    2.665256] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
[    2.665310] mmcblk0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
[    2.665313] mmcblk0: retrying using single block read
[    2.665544] mmcblk0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
[    2.665549] blk_update_request: I/O error, dev mmcblk0, sector 0
[    2.665728] mmcblk0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
[    2.665732] blk_update_request: I/O error, dev mmcblk0, sector 1
[    2.665910] mmcblk0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
[    2.665914] blk_update_request: I/O error, dev mmcblk0, sector 2
[    2.666393] mmcblk0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
[    2.666398] blk_update_request: I/O error, dev mmcblk0, sector 5
[    2.666728] mmcblk0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
so, we try to check eMMC0 information, it seems DRA746 can detect MTFC8GACA
root@wnc-j6:~# cat /sys/kernel/debug/mmc*/ios
clock:      52000000 Hz
vdd:     21 (3.3 ~ 3.4 V)
bus mode:   2 (push-pull)
chip select:   0 (don't care)
power mode: 2 (on)
bus width:  2 (4 bits)
timing spec:   1 (mmc high-speed)
signal voltage:   0 (3.30 V)
driver type:   0 (driver type B)
device tree as below:
&mmc1 {
	status = "okay";
	vmmc-supply = <&evm_3v3_sd>;
	vmmc_aux-supply = <&ldo1_reg>;
	bus-width = <4>;
	//cd-gpios = <&gpio6 27 GPIO_ACTIVE_LOW>;
	max-frequency = <192000000>;
	pinctrl-names = "default", "hs";
	pinctrl-0 = <&mmc1_pins_default>;
	pinctrl-1 = <&mmc1_pins_hs>;
We reference E2E as below:
https://e2e.ti.com/support/processors-group/processors/f/processors-forum/934051/am3354-am335x-mmc1-switch-to-bus-width-8-failed
https://e2e.ti.com/support/processors-group/processors/f/processors-forum/629097/linux-am5728-custom-board-emmc-issue
https://e2e.ti.com/support/processors-group/processors/f/processors-forum/805352/linux-am5728-emmc-configuration-issue
I believe (guess) it may be some problems on data line (D0~D3), because error happens when system try to switch bus width.
May any one can give us some debug direction? (include software and hardware)
Many Thanks
Gibbs
  • Hi Gibbs,
    Can you clarify whether multiplexing into SD mode is working properly? The problem only occurs when switching to eMMC? Can you clarify which speed modes you are trying to configure for each? Note that MMC1 only supports up to high speed DDR for eMMC.
    Marco
  • Hi, Marco
    Thanks you reply, sorry a little bit delay from my site.
    Answer your question as below:
    1. Can you clarify whether multiplexing into SD mode is working properly?
    No, we have the same mount issue when swaps into SD.
    2.The problem only occurs when switching to eMMC?
    No, SD interface also happens.
    3.  Can you clarify which speed modes you are trying to configure for each? (emmc1 interface)
    We have done some test. we found only "default speed" CLK = 24MHz works fine without mount error message, but when we let emmc1 works on "high speed (HS mode)" CLK = 48MHz clock, mount error message appear again.
    4. Note that MMC1 only supports up to high speed DDR for eMMC.
    Sure, base on customer emmc1 configuration, I think their max speed is HS mode. (3.3v)
    As far as I know, we can not adjust emmc1 "signal drive" mode, am I right?
    so, it seems that when clock raise, and then error happens.
    it could be "signal driver" or "timing issue", right?
    Gibbs
  • Hi, Dear Expert
    One week pass, Any suggestion for me?
    Many Thanks
    Gibbs
  • Hi Gibbs,
    Default speed runs correctly on both eMMC and SD, but High Speed works on neither?
    How are you swapping between DS and HS modes, and swapping between eMMC and SD modes on MMC1?
    Can you verify the connections to/from the multiplexer and any pullup resistors used, and share the more accurate schematic here?
    Drive strength for MMC mode can be modified at MMCHS_AC12[21:20] DS_SEL, and for SD mode at CTRL_CORE_CONTROL_HYST_1[30:29] SDCARD_IC.
    Thanks and regards,
    Marco
  • Hi, Macro
    Thanks your reply.
    Let's me answer you question.
    1. Default speed runs correctly on both eMMC and SD, but High Speed works on neither?
    Multiplexer default swap to connect eMMC.  We think we may narrow down this issue first, we may dedicate debug eMMC first. "default speed" (24MHz clock) runs well, but high speed (48MHz clock) failed. So we think clock speed is a factor.
    2. How are you swapping between DS and HS modes, and swapping between eMMC and SD modes on MMC1?
    We only test eMMC, we do not let multiplexer execute swap channel function, multiplexer default connection is eMMC. we modify linux device tree to force DRA746 work in DS or HS mode.
    3. Can you verify the connections to/from the multiplexer and any pullup resistors used, and share the more accurate schematic here?
    Sure, I will let customer direct post here.
    4. Drive strength for MMC mode can be modified at MMCHS_AC12[21:20] DS_SEL, and for SD mode at CTRL_CORE_CONTROL_HYST_1[30:29] SDCARD_IC.
    Thanks, let me double check first.
    Gibbs
  • Hi Gibbs, Macro,
    1. We found the issue was gone after changing voltage from 3.3v to 1.8v. The change dts(from 3.3v to 1.8v) is here. The changes of voltage are 1.vmmc-supply = <&evm_1v8_sd> 2.set regulator-max-microvolt = <1800000> in ldo1_reg:
    diff --git a/board-support/linux/arch/arm/boot/dts/dra7-evm-030003.dts b/board-support/linux/arch/arm/boot/dts/dra7-evm-030003.dts
    index 36cfa54..2d60198 100644
    --- a/board-support/linux/arch/arm/boot/dts/dra7-evm-030003.dts
    +++ b/board-support/linux/arch/arm/boot/dts/dra7-evm-030003.dts
    @@ -76,6 +76,15 @@
                    regulator-boot-on;
    +       evm_1v8_sd: fixedregulator-sd {
    +               compatible = "regulator-fixed";
    +               regulator-name = "evm_1v8_sd";
    +               regulator-min-microvolt = <1800000>;
    +               regulator-max-microvolt = <1800000>;
    +               regulator-always-on;
    +               regulator-boot-on;
            evm_3v3_sw: fixedregulator-evm_3v3_sw {
                    regulator-name = "evm_3v3_sw";
    @@ -1569,7 +1578,7 @@
                                            /* LDO1_OUT --> SDIO  */
                                            regulator-name = "ldo1";
    -                                       regulator-max-microvolt = <3300000>;
                                            regulator-boot-on;
    @@ -1880,11 +1889,16 @@ i2c_p3_exp: &i2c2 {
     &mmc1 {
            status = "okay";
    -       vmmc-supply = <&evm_3v3_sd>;
    +       vmmc-supply = <&evm_1v8_sd>;
            bus-width = <4>;
    +#if 1
    +       pinctrl-names = "default", "hs";
    +       pinctrl-0 = <&mmc1_pins_default>;
    +       pinctrl-1 = <&mmc1_pins_hs>;
    +#else
            pinctrl-names = "default", "hs", "sdr12", "sdr25", "sdr50", "ddr50-rev11", "sdr104-rev11", "ddr50", "sdr104";
    @@ -1895,6 +1909,7 @@ i2c_p3_exp: &i2c2 {
            pinctrl-6 = <&mmc1_pins_sdr104 &mmc1_iodelay_sdr104_rev11_conf>;
            pinctrl-7 = <&mmc1_pins_ddr50 &mmc1_iodelay_ddr50_rev20_conf>;
            pinctrl-8 = <&mmc1_pins_sdr104 &mmc1_iodelay_sdr104_rev20_conf>;
    +#endif
    And this dtb is not working for booting from SD when we multiplexing into SD, and it hangs on "Waiting for...", the error log is:
    [    2.682730] omap_hsmmc 4809c000.mmc: no support for card's volts
    [    2.688813] mmc0: error -22 whilst initialising SD card
    [    3.870665] Waiting for root device PARTUUID=fe13d755-02...
    2. Does it make sense of changing 1.8v on HS mode, according to the datasheet, the HS mode is running on 3.3v ?
  • Hi Kevin,
    I do not see why changing the supply to 1.8V would apply here for HS mode. Which software version are you using? Do you have a schematic of the SOC->Multiplexer->MMC/SD connections?
    Marco
  • Hi Marco,
    1. I checkout the branch 4.4.y and build it's zImage from https://git.ti.com/cgit/ti-linux-kernel/ti-linux-kernel/?h=linux-4.4.y and using the zImage applying with our original dts(HS + 3.3v) in our board. And it turns out the issue is gone and the signal voltage from /sys/kernel/debug/mmc1/ios becomes 1.8v(for some reason I don't know and I don't dig out). Hence I try to change the voltage from 3.3 to 1.8 in dts and the issue is gone.
    2. We are using processor-sdk-linux-automotive-03.02.00.03.
    3. The HW design for MMC1 is using Multiplexer to switch to J12 SD Card or U52 EMMC 4bit memory, as follows:
  • You'll want to update to the latest SDK version (6.00.00.03) to be sure software isn't introducing any known errata. MMC1 should be able to dynamically switch between 1.8V and 3.3V speed modes, whereas MMC2/3/4 are not capable of this and need a fixed voltage for the speed they are running. Do you have a boot log for the successful case at 1.8V? Can you confirm whether MMC1 is actually running HS, and whether the IOs are operating at 1.8V?
    Marco
  • 1. The kernel of latest SDK version (6.00.00.03) will be stuck at "Waiting for root device PARTUUID=bddb4f41-02...":
    U-Boot SPL 2016.05 (Nov 24 2017 - 15:38:03)
    DRA752-GP ES2.0
    *** Warning - bad CRC, using default environment
    Trying to boot from MMC2_2
    spl: falcon_args_file not set in environment, falling back to default
    reading args
    spl_load_image_fat_os: error reading image args, err - -1
    reading u-boot.img
    reading u-boot.img
    U-Boot 2016.05 (Nov 24 2017 - 15:38:03 +0800)
    CPU  : DRA752-GP ES2.0
    Board: DRA74x EVM REV
    I2C:   ready
    DRAM:  2 GiB
    MMC:   OMAP SD/MMC: 0, OMAP SD/MMC: 1
    Warning: fastboot.board_rev: unknown board revision
    GUID Partition Table Header signature is wrong: 0x0 != 0x5452415020494645
    part_get_info_efi: *** ERROR: Invalid GPT ***
    part_get_info_efi: *** ERROR: Invalid Backup GPT ***
    ERROR: cannot find partition: 'userdata'
    at arch/arm/cpu/armv7/omap-common/utils.c:195/mmc_get_part_size()
    Warning: fastboot.userdata_size: unable to calc
    Net:   <ethaddr> not set. Validating first E-fuse MAC
    Could not get PHY for cpsw: addr 2
    cpsw
    Hit any key to stop autoboot:  0
    J6 ...
    switch to partitions #0, OK
    mmc1(part 0) is current device
    SD/MMC found on device 1
    4403712 bytes read in 220 ms (19.1 MiB/s)
    113603 bytes read in 13 ms (8.3 MiB/s)
    Booting from mmc1 ...
    Kernel image @ 0x82000000 [ 0x000000 - 0x433200 ]
       Loading Device Tree to 8ffe1000, end 8ffffbc2 ... OK
    Starting kernel ...
    [    0.000000] Booting Linux on physical CPU 0x0
    [    0.000000] Linux version 4.19.73-g31275c05a1 (oe-user@oe-host) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36))) #1 SMP PREEMPT Wed Dec 11 12:53:11 UTC 2019
    [    0.000000] CPU: ARMv7 Processor [412fc0f2] revision 2 (ARMv7), cr=30c5387d
    [    0.000000] CPU: div instructions available: patching division code
    [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
    [    0.000000] OF: fdt: Machine model: TI DRA742 Bowei 20170929 17:30
    [    0.000000] Memory policy: Data cache writealloc
    [    0.000000] efi: Getting EFI parameters from FDT:
    [    0.000000] Reserved memory: created CMA memory pool at 0x0000000095800000, size 56 MiB
    [    0.000000] OF: reserved mem: initialized node ipu2_cma@95800000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created CMA memory pool at 0x0000000099000000, size 64 MiB
    [    0.000000] OF: reserved mem: initialized node dsp1_cma@99000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created CMA memory pool at 0x000000009d000000, size 32 MiB
    [    0.000000] OF: reserved mem: initialized node ipu1_cma@9d000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created CMA memory pool at 0x000000009f000000, size 8 MiB
    [    0.000000] OF: reserved mem: initialized node dsp2_cma@9f000000, compatible id shared-dma-pool
    [    0.000000] cma: Reserved 24 MiB at 0x00000000fd400000
    [    0.000000] OMAP4: Map 0x00000000fed00000 to (ptrval) for dram barrier
    [    0.000000] DRA752 ES2.0
    [    0.000000] random: get_random_bytes called from start_kernel+0xb4/0x470 with crng_init=0
    [    0.000000] percpu: Embedded 16 pages/cpu s36492 r8192 d20852 u65536
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 516416
    [    0.000000] Kernel command line: console=ttyO2,115200n8 root=PARTUUID=bddb4f41-02 rw rootfstype=ext4 rootwait consoleblank=0 omapdrm.num_crtc=2 drm.debug=0xff
    [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
    [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
    [    0.000000] Memory: 1847196K/2072576K available (10240K kernel code, 341K rwdata, 2800K rodata, 2048K init, 269K bss, 36964K reserved, 188416K cma-reserved, 1265664K highmem)
    [    0.000000] Virtual kernel memory layout:
    [    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    [    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
    [    0.000000]     vmalloc : 0xf0800000 - 0xff800000   ( 240 MB)
    [    0.000000]     lowmem  : 0xc0000000 - 0xf0000000   ( 768 MB)
    [    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
    [    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
    [    0.000000]       .text : 0x(ptrval) - 0x(ptrval)   (12256 kB)
    [    0.000000]       .init : 0x(ptrval) - 0x(ptrval)   (2048 kB)
    [    0.000000]       .data : 0x(ptrval) - 0x(ptrval)   ( 342 kB)
    [    0.000000]        .bss : 0x(ptrval) - 0x(ptrval)   ( 270 kB)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
    [    0.000000]  Tasks RCU enabled.
    [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
    [    0.000000] ti_dt_clocks_register: missing clkctrl nodes, please update your dts.
    [    0.000000] OMAP clockevent source: timer1 at 31475 Hz
    [    0.000000] arch_timer: cp15 timer(s) running at 5.90MHz (virt).
    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x15c70fb29, max_idle_ns: 440795202138 ns
    [    0.000005] sched_clock: 56 bits at 5MHz, resolution 169ns, wraps every 4398046511093ns
    [    0.000018] Switching to timer-based delay loop, resolution 169ns
    [    0.000352] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns
    [    0.000362] OMAP clocksource: 32k_counter at 32768 Hz
    [    0.000825] Console: colour dummy device 80x30
    [    0.000844] WARNING: Your 'console=ttyO2' has been replaced by 'ttyS2'
    [    0.000852] This ensures that you still see kernel messages. Please
    [    0.000860] update your kernel commandline.
    [    0.000893] Calibrating delay loop (skipped), value calculated using timer frequency.. 11.80 BogoMIPS (lpj=59016)
    [    0.000910] pid_max: default: 32768 minimum: 301
    [    0.001037] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
    [    0.001053] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
    [    0.001614] CPU: Testing write buffer coherency: ok
    [    0.001652] CPU0: Spectre v2: firmware did not set auxiliary control register IBE bit, system vulnerable
    [    0.001863] /cpus/cpu@0 missing clock-frequency property
    [    0.001883] /cpus/cpu@1 missing clock-frequency property
    [    0.001895] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
    [    0.059892] Setting up static identity map for 0x80200000 - 0x80200060
    [    0.079902] rcu: Hierarchical SRCU implementation.
    [    0.100098] EFI services will not be available.
    [    0.119963] smp: Bringing up secondary CPUs ...
    [    0.200303] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
    [    0.200309] CPU1: Spectre v2: using ICIALLU workaround
    [    0.200429] smp: Brought up 1 node, 2 CPUs
    [    0.200442] SMP: Total of 2 processors activated (23.60 BogoMIPS).
    [    0.200451] CPU: All CPU(s) started in SVC mode.
    [    0.200917] devtmpfs: initialized
    [    0.221580] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
    [    0.221840] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
    [    0.221858] futex hash table entries: 512 (order: 3, 32768 bytes)
    [    0.224710] pinctrl core: initialized pinctrl subsystem
    [    0.225222] DMI not present or invalid.
    [    0.225501] NET: Registered protocol family 16
    [    0.226666] DMA: preallocated 256 KiB pool for atomic coherent allocations
    [    0.227660] omap_hwmod: l3_main_2 using broken dt data from ocp
    [    0.249323] omap_hwmod: dma_system: no dt node
    [    0.249333] ------------[ cut here ]------------
    [    0.249356] WARNING: CPU: 0 PID: 1 at arch/arm/mach-omap2/omap_hwmod.c:2409 _init.constprop.22+0x1b0/0x4dc
    [    0.249365] omap_hwmod: dma_system: doesn't have mpu register target base
    [    0.249373] Modules linked in:
    [    0.249391] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 4.19.73-g31275c05a1 #1
    [    0.249401] Hardware name: Generic DRA74X (Flattened Device Tree)
    [    0.249409] Backtrace:
    [    0.249431] [<c020cad4>] (dump_backtrace) from [<c020ce0c>] (show_stack+0x18/0x1c)
    [    0.249443]  r7:c0dcff84 r6:60000013 r5:00000000 r4:c1251ff0
    [    0.249459] [<c020cdf4>] (show_stack) from [<c09f8a60>] (dump_stack+0x90/0xa4)
    [    0.249474] [<c09f89d0>] (dump_stack) from [<c022e1b8>] (__warn+0xdc/0xf8)
    [    0.249485]  r7:c0dcff84 r6:00000009 r5:00000000 r4:ee87bddc
    [    0.249497] [<c022e0dc>] (__warn) from [<c022ddfc>] (warn_slowpath_fmt+0x50/0x6c)
    [    0.249509]  r9:c104b824 r8:00000000 r7:c121252c r6:00000000 r5:c0dd0560 r4:c1204c48
    [    0.249524] [<c022ddb0>] (warn_slowpath_fmt) from [<c100cf2c>] (_init.constprop.22+0x1b0/0x4dc)
    [    0.249534]  r3:c0dd0a04 r2:c0dd0560
    [    0.249543]  r5:00000000 r4:c12124f4
    [    0.249558] [<c100cd7c>] (_init.constprop.22) from [<c100d388>] (__omap_hwmod_setup_all+0x48/0x134)
    [    0.249570]  r10:c10606f4 r9:c104b824 r8:00000000 r7:c100d340 r6:ffffe000 r5:c120a228
    [    0.249579]  r4:c12124f4
    [    0.249594] [<c100d340>] (__omap_hwmod_setup_all) from [<c020265c>] (do_one_initcall+0x84/0x1b0)
    [    0.249604]  r5:c1204c48 r4:c1255740
    [    0.249619] [<c02025d8>] (do_one_initcall) from [<c1000fe8>] (kernel_init_freeable+0x1c4/0x258)
    [    0.249630]  r8:c104b844 r7:c10004f0 r6:c1255740 r5:c1255740 r4:00000003
    [    0.249647] [<c1000e24>] (kernel_init_freeable) from [<c0a0cce8>] (kernel_init+0x10/0x11c)
    [    0.249658]  r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c0a0ccd8
    [    0.249666]  r4:00000000
    [    0.249679] [<c0a0ccd8>] (kernel_init) from [<c02010d8>] (ret_from_fork+0x14/0x3c)
    [    0.249688] Exception stack(0xee87bfb0 to 0xee87bff8)
    [    0.249698] bfa0:                                     00000000 00000000 00000000 00000000
    [    0.249709] bfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [    0.249719] bfe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [    0.249728]  r5:c0a0ccd8 r4:00000000
    [    0.249740] ---[ end trace 53f2d3aef28cd7ec ]---
    [    0.266863] omap_hwmod: hdq1w: no dt node
    [    0.266873] ------------[ cut here ]------------
    [    0.266889] WARNING: CPU: 0 PID: 1 at arch/arm/mach-omap2/omap_hwmod.c:2409 _init.constprop.22+0x1b0/0x4dc
    [    0.266898] omap_hwmod: hdq1w: doesn't have mpu register target base
    [    0.266905] Modules linked in:
    [    0.266922] CPU: 0 PID: 1 Comm: swapper/0 Tainted: G        W         4.19.73-g31275c05a1 #1
    [    0.266931] Hardware name: Generic DRA74X (Flattened Device Tree)
    [    0.266939] Backtrace:
    [    0.266957] [<c020cad4>] (dump_backtrace) from [<c020ce0c>] (show_stack+0x18/0x1c)
    [    0.266969]  r7:c0dcff84 r6:60000013 r5:00000000 r4:c1251ff0
    [    0.266983] [<c020cdf4>] (show_stack) from [<c09f8a60>] (dump_stack+0x90/0xa4)
    [    0.266996] [<c09f89d0>] (dump_stack) from [<c022e1b8>] (__warn+0xdc/0xf8)
    [    0.267007]  r7:c0dcff84 r6:00000009 r5:00000000 r4:ee87bddc
    [    0.267019] [<c022e0dc>] (__warn) from [<c022ddfc>] (warn_slowpath_fmt+0x50/0x6c)
    [    0.267031]  r9:c104b824 r8:00000000 r7:c12117c0 r6:00000000 r5:c0dd0560 r4:c1204c48
    [    0.267045] [<c022ddb0>] (warn_slowpath_fmt) from [<c100cf2c>] (_init.constprop.22+0x1b0/0x4dc)
    [    0.267054]  r3:c0dd26fc r2:c0dd0560
    [    0.267064]  r5:00000000 r4:c1211788
    [    0.267078] [<c100cd7c>] (_init.constprop.22) from [<c100d388>] (__omap_hwmod_setup_all+0x48/0x134)
    [    0.267090]  r10:c10606f4 r9:c104b824 r8:00000000 r7:c100d340 r6:ffffe000 r5:c120a228
    [    0.267098]  r4:c1211788
    [    0.267113] [<c100d340>] (__omap_hwmod_setup_all) from [<c020265c>] (do_one_initcall+0x84/0x1b0)
    [    0.267123]  r5:c1204c48 r4:c1255740
    [    0.267138] [<c02025d8>] (do_one_initcall) from [<c1000fe8>] (kernel_init_freeable+0x1c4/0x258)
    [    0.267150]  r8:c104b844 r7:c10004f0 r6:c1255740 r5:c1255740 r4:00000003
    [    0.267166] [<c1000e24>] (kernel_init_freeable) from [<c0a0cce8>] (kernel_init+0x10/0x11c)
    [    0.267178]  r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c0a0ccd8
    [    0.267186]  r4:00000000
    [    0.267199] [<c0a0ccd8>] (kernel_init) from [<c02010d8>] (ret_from_fork+0x14/0x3c)
    [    0.267208] Exception stack(0xee87bfb0 to 0xee87bff8)
    [    0.267217] bfa0:                                     00000000 00000000 00000000 00000000
    [    0.267227] bfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [    0.267237] bfe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [    0.267246]  r5:c0a0ccd8 r4:00000000
    [    0.267255] ---[ end trace 53f2d3aef28cd7ed ]---
    [    0.298674] omap_hwmod: smartreflex_core: no dt node
    [    0.298684] ------------[ cut here ]------------
    [    0.298699] WARNING: CPU: 0 PID: 1 at arch/arm/mach-omap2/omap_hwmod.c:2409 _init.constprop.22+0x1b0/0x4dc
    [    0.298708] omap_hwmod: smartreflex_core: doesn't have mpu register target base
    [    0.298716] Modules linked in:
    [    0.298731] CPU: 0 PID: 1 Comm: swapper/0 Tainted: G        W         4.19.73-g31275c05a1 #1
    [    0.298740] Hardware name: Generic DRA74X (Flattened Device Tree)
    [    0.298747] Backtrace:
    [    0.298765] [<c020cad4>] (dump_backtrace) from [<c020ce0c>] (show_stack+0x18/0x1c)
    [    0.298777]  r7:c0dcff84 r6:60000013 r5:00000000 r4:c1251ff0
    [    0.298791] [<c020cdf4>] (show_stack) from [<c09f8a60>] (dump_stack+0x90/0xa4)
    [    0.298804] [<c09f89d0>] (dump_stack) from [<c022e1b8>] (__warn+0xdc/0xf8)
    [    0.298815]  r7:c0dcff84 r6:00000009 r5:00000000 r4:ee87bddc
    [    0.298828] [<c022e0dc>] (__warn) from [<c022ddfc>] (warn_slowpath_fmt+0x50/0x6c)
    [    0.298839]  r9:c104b824 r8:00000000 r7:c120fcc8 r6:00000000 r5:c0dd0560 r4:c1204c48
    [    0.298854] [<c022ddb0>] (warn_slowpath_fmt) from [<c100cf2c>] (_init.constprop.22+0x1b0/0x4dc)
    [    0.298863]  r3:c0dd2248 r2:c0dd0560
    [    0.298872]  r5:00000000 r4:c120fc90
    [    0.298886] [<c100cd7c>] (_init.constprop.22) from [<c100d388>] (__omap_hwmod_setup_all+0x48/0x134)
    [    0.298898]  r10:c10606f4 r9:c104b824 r8:00000000 r7:c100d340 r6:ffffe000 r5:c120a228
    [    0.298907]  r4:c120fc90
    [    0.298920] [<c100d340>] (__omap_hwmod_setup_all) from [<c020265c>] (do_one_initcall+0x84/0x1b0)
    [    0.298929]  r5:c1204c48 r4:c1255740
    [    0.298944] [<c02025d8>] (do_one_initcall) from [<c1000fe8>] (kernel_init_freeable+0x1c4/0x258)
    [    0.298955]  r8:c104b844 r7:c10004f0 r6:c1255740 r5:c1255740 r4:00000003
    [    0.298971] [<c1000e24>] (kernel_init_freeable) from [<c0a0cce8>] (kernel_init+0x10/0x11c)
    [    0.298981]  r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c0a0ccd8
    [    0.298989]  r4:00000000
    [    0.299002] [<c0a0ccd8>] (kernel_init) from [<c02010d8>] (ret_from_fork+0x14/0x3c)
    [    0.299011] Exception stack(0xee87bfb0 to 0xee87bff8)
    [    0.299021] bfa0:                                     00000000 00000000 00000000 00000000
    [    0.299032] bfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [    0.299042] bfe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [    0.299051]  r5:c0a0ccd8 r4:00000000
    [    0.299060] ---[ end trace 53f2d3aef28cd7ee ]---
    [    0.300114] omap_hwmod: smartreflex_mpu: no dt node
    [    0.300123] ------------[ cut here ]------------
    [    0.300137] WARNING: CPU: 0 PID: 1 at arch/arm/mach-omap2/omap_hwmod.c:2409 _init.constprop.22+0x1b0/0x4dc
    [    0.300145] omap_hwmod: smartreflex_mpu: doesn't have mpu register target base
    [    0.300152] Modules linked in:
    [    0.300168] CPU: 0 PID: 1 Comm: swapper/0 Tainted: G        W         4.19.73-g31275c05a1 #1
    [    0.300176] Hardware name: Generic DRA74X (Flattened Device Tree)
    [    0.300184] Backtrace:
    [    0.300200] [<c020cad4>] (dump_backtrace) from [<c020ce0c>] (show_stack+0x18/0x1c)
    [    0.300212]  r7:c0dcff84 r6:60000013 r5:00000000 r4:c1251ff0
    [    0.300225] [<c020cdf4>] (show_stack) from [<c09f8a60>] (dump_stack+0x90/0xa4)
    [    0.300238] [<c09f89d0>] (dump_stack) from [<c022e1b8>] (__warn+0xdc/0xf8)
    [    0.300248]  r7:c0dcff84 r6:00000009 r5:00000000 r4:ee87bddc
    [    0.300260] [<c022e0dc>] (__warn) from [<c022ddfc>] (warn_slowpath_fmt+0x50/0x6c)
    [    0.300272]  r9:c104b824 r8:00000000 r7:c120fc54 r6:00000000 r5:c0dd0560 r4:c1204c48
    [    0.300285] [<c022ddb0>] (warn_slowpath_fmt) from [<c100cf2c>] (_init.constprop.22+0x1b0/0x4dc)
    [    0.300295]  r3:c0dd2238 r2:c0dd0560
    [    0.300303]  r5:00000000 r4:c120fc1c
    [    0.300318] [<c100cd7c>] (_init.constprop.22) from [<c100d388>] (__omap_hwmod_setup_all+0x48/0x134)
    [    0.300330]  r10:c10606f4 r9:c104b824 r8:00000000 r7:c100d340 r6:ffffe000 r5:c120a228
    [    0.300338]  r4:c120fc1c
    [    0.300352] [<c100d340>] (__omap_hwmod_setup_all) from [<c020265c>] (do_one_initcall+0x84/0x1b0)
    [    0.300361]  r5:c1204c48 r4:c1255740
    [    0.300376] [<c02025d8>] (do_one_initcall) from [<c1000fe8>] (kernel_init_freeable+0x1c4/0x258)
    [    0.300386]  r8:c104b844 r7:c10004f0 r6:c1255740 r5:c1255740 r4:00000003
    [    0.300401] [<c1000e24>] (kernel_init_freeable) from [<c0a0cce8>] (kernel_init+0x10/0x11c)
    [    0.300412]  r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c0a0ccd8
    [    0.300420]  r4:00000000
    [    0.300432] [<c0a0ccd8>] (kernel_init) from [<c02010d8>] (ret_from_fork+0x14/0x3c)
    [    0.300441] Exception stack(0xee87bfb0 to 0xee87bff8)
    [    0.300451] bfa0:                                     00000000 00000000 00000000 00000000
    [    0.300461] bfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [    0.300471] bfe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [    0.300480]  r5:c0a0ccd8 r4:00000000
    [    0.300503] ---[ end trace 53f2d3aef28cd7ef ]---
    [    0.413727] cpuidle: using governor ladder
    [    0.413762] cpuidle: using governor menu
    [    0.420395] OMAP GPIO hardware version 0.1
    [    0.423350] GPIO line 161 (radio_rst) hogged as output/low
    [    0.449103] No ATAGs?
    [    0.449182] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
    [    0.449198] hw-breakpoint: maximum watchpoint size is 8 bytes.
    [    0.449234] omap_device: omap_dma_system: build failed (-22)
    [    0.449245] omap2_system_dma_init_dev: Can't build omap_device for omap_dma_system:dma_system.
    [    0.449617] omap4_sram_init:Unable to allocate sram needed to handle errata I688
    [    0.449628] omap4_sram_init:Unable to get sram pool needed to handle errata I688
    [    0.461236] edma 43300000.edma: memcpy is disabled
    [    0.464490] edma 43300000.edma: TI EDMA DMA engine driver
    [    0.468860] omap-iommu 40d01000.mmu: 40d01000.mmu registered
    [    0.469038] omap-iommu 40d02000.mmu: 40d02000.mmu registered
    [    0.469268] omap-iommu 58882000.mmu: 58882000.mmu registered
    [    0.469500] omap-iommu 55082000.mmu: 55082000.mmu registered
    [    0.469891] omap-iommu 41501000.mmu: 41501000.mmu registered
    [    0.470063] omap-iommu 41502000.mmu: 41502000.mmu registered
    [    0.470321] iommu: Adding device 58820000.ipu to group 1
    [    0.470395] iommu: Adding device 55020000.ipu to group 2
    [    0.470518] iommu: Adding device 40800000.dsp to group 0
    [    0.470755] iommu: Adding device 41000000.dsp to group 3
    [    0.472051] SCSI subsystem initialized
    [    0.473214] palmas 0-0058: IRQ missing: skipping irq request
    [    0.502012] palmas 0-0058: Muxing GPIO a, PWM 0, LED 0
    [    0.503460] SMPS12: supplied by regulator-dummy
    [    0.504494] SMPS3: supplied by regulator-dummy
    [    0.505977] SMPS45: supplied by regulator-dummy
    [    0.507899] SMPS6: supplied by regulator-dummy
    [    0.509678] SMPS7: supplied by regulator-dummy
    [    0.511619] SMPS8: supplied by regulator-dummy
    [    0.513416] SMPS9: supplied by regulator-dummy
    [    0.514430] LDO1: supplied by regulator-dummy
    [    0.522497] LDO2: supplied by regulator-dummy
    [    0.532355] LDO3: supplied by regulator-dummy
    [    0.542366] LDO4: supplied by regulator-dummy
    [    0.542480] random: fast init done
    [    0.543106] LDO5: supplied by regulator-dummy
    [    0.543822] LDO6: supplied by regulator-dummy
    [    0.544536] LDO7: supplied by regulator-dummy
    [    0.545258] LDO8: supplied by regulator-dummy
    [    0.545983] LDO9: supplied by regulator-dummy
    [    0.552407] LDOLN: supplied by regulator-dummy
    [    0.562428] LDOUSB: supplied by regulator-dummy
    [    0.574354] omap_i2c 48070000.i2c: bus 0 rev0.12 at 400 kHz
    [    0.575034] omap_i2c 48072000.i2c: bus 1 rev0.12 at 400 kHz
    [    0.575434] omap_i2c 48060000.i2c: bus 2 rev0.12 at 400 kHz
    [    0.575819] omap_i2c 4807a000.i2c: bus 3 rev0.12 at 400 kHz
    [    0.576208] omap_i2c 4807c000.i2c: bus 4 rev0.12 at 400 kHz
    [    0.576442] media: Linux media interface: v0.10
    [    0.576481] videodev: Linux video capture interface: v2.00
    [    0.576554] pps_core: LinuxPPS API ver. 1 registered
    [    0.576564] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.576585] PTP clock support registered
    [    0.576615] EDAC MC: Ver: 3.0.0
    [    0.577357] omap-mailbox 48840000.mailbox: omap mailbox rev 0x400
    [    0.577608] omap-mailbox 48842000.mailbox: omap mailbox rev 0x400
    [    0.578128] Advanced Linux Sound Architecture Driver Initialized.
    [    0.578905] clocksource: Switched to clocksource arch_sys_counter
    [    0.586764] NET: Registered protocol family 2
    [    0.587353] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
    [    0.587382] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
    [    0.587446] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
    [    0.587573] TCP: Hash tables configured (established 8192 bind 8192)
    [    0.587646] UDP hash table entries: 512 (order: 2, 16384 bytes)
    [    0.587680] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
    [    0.587809] NET: Registered protocol family 1
    [    0.608247] RPC: Registered named UNIX socket transport module.
    [    0.608257] RPC: Registered udp transport module.
    [    0.608266] RPC: Registered tcp transport module.
    [    0.608275] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.609320] hw perfevents: no interrupt-affinity property for /pmu, guessing.
    [    0.609542] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
    [    0.610512] Initialise system trusted keyrings
    [    0.610637] workingset: timestamp_bits=14 max_order=19 bucket_order=5
    [    0.615512] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.626001] NFS: Registering the id_resolver key type
    [    0.626021] Key type id_resolver registered
    [    0.626030] Key type id_legacy registered
    [    0.626072] ntfs: driver 2.1.32 [Flags: R/O].
    [    0.627627] Key type asymmetric registered
    [    0.627639] Asymmetric key parser 'x509' registered
    [    0.627686] bounce: pool size: 64 pages
    [    0.627721] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
    [    0.627732] io scheduler noop registered
    [    0.627741] io scheduler deadline registered
    [    0.627838] io scheduler cfq registered (default)
    [    0.627849] io scheduler mq-deadline registered
    [    0.627859] io scheduler kyber registered
    [    0.632793] pinctrl-single 4a003400.pinmux: please update dts to use #pinctrl-cells = <1>
    [    0.633318] pinctrl-single 4a003400.pinmux: 282 pins, size 1128
    [    0.640553] pbias_mmc_omap5: Bringing 3300000uV into 3000000-3000000uV
    [    0.640569] pbias_mmc_omap5: failed to apply 3000000-3000000uV constraint(-22)
    [    0.640584] pbias-regulator 4a002e00.pbias_regulator: Failed to register regulator: -22
    [    0.640607] pbias-regulator: probe of 4a002e00.pbias_regulator failed with error -22
    [    0.641433] evm_3v3_sw: supplied by sysen1
    [    0.641672] aic_dvdd: supplied by evm_3v3_sw
    [    0.641746] vtt_fixed: supplied by sysen2
    [    0.684673] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
    [    0.688596] 4806a000.serial: ttyS0 at MMIO 0x4806a000 (irq = 43, base_baud = 3000000) is a 8250
    [    0.689534] 4806c000.serial: ttyS1 at MMIO 0x4806c000 (irq = 44, base_baud = 3000000) is a 8250
    [    0.690440] 48020000.serial: ttyS2 at MMIO 0x48020000 (irq = 45, base_baud = 3000000) is a 8250
    [    2.662588] console [ttyS2] enabled
    [    2.667015] 48066000.serial: ttyS4 at MMIO 0x48066000 (irq = 46, base_baud = 3000000) is a 8250
    [    2.676670] 48068000.serial: ttyS5 at MMIO 0x48068000 (irq = 47, base_baud = 3000000) is a 8250
    [    2.686320] 48424000.serial: ttyS8 at MMIO 0x48424000 (irq = 48, base_baud = 3000000) is a 8250
    [    2.695978] 4ae2b000.serial: ttyS9 at MMIO 0x4ae2b000 (irq = 49, base_baud = 3000000) is a 8250
    [    2.707068] omap_rng 48090000.rng: Random Number Generator ver. 20
    [    2.707405] random: crng init done
    [    2.717505] omapdss_dss 58000000.dss: Linked as a consumer to regulator.22
    [    2.724599] DSS: OMAP DSS rev 6.1
    [    2.729644] omapdss_dss 58000000.dss: bound 58001000.dispc (ops dispc_component_ops)
    [    2.750327] brd: module loaded
    [    2.759517] loop: module loaded
    [    2.768957] libphy: Fixed MDIO Bus: probed
    [    2.828934] davinci_mdio 48485000.mdio: davinci mdio revision 1.6, bus freq 1000000
    [    2.836627] davinci_mdio 48485000.mdio: no live phy, scanning all
    [    2.939022] davinci_mdio 48485000.mdio: timed out waiting for user access
    [    3.045927] davinci_mdio 48485000.mdio: timed out waiting for idle
    [    3.052180] davinci_mdio: probe of 48485000.mdio failed with error -5
    [    3.059289] cpsw 48484000.ethernet: Detected MACID = 54:45:38:a7:aa:1e
    [    3.065891] cpsw 48484000.ethernet: initialized cpsw ale version 1.4
    [    3.072295] cpsw 48484000.ethernet: ALE Table size 1024
    [    3.077569] cpsw 48484000.ethernet: cpts: overflow check period 500 (jiffies)
    [    3.085580] cpsw 48484000.ethernet: cpsw: Detected MACID = 54:45:38:a7:aa:1f
    [    3.094209] i2c /dev entries driver
    [    3.102604] cpu cpu0: "syscon" is missing, cannot use OPPv2 table.
    [    3.109347] sdhci: Secure Digital Host Controller Interface driver
    [    3.115555] sdhci: Copyright(c) Pierre Ossman
    [    3.120930] omap_hsmmc: probe of 4809c000.mmc failed with error -22
    [    3.127666] omap_hsmmc 480b4000.mmc: RX DMA channel request failed
    [    3.134325] omap_hsmmc 480d1000.mmc: RX DMA channel request failed
    [    3.140842] sdhci-pltfm: SDHCI platform and OF driver helper
    [    3.147883] ledtrig-cpu: registered to indicate activity on CPUs
    [    3.158457] pinctrl-single 4a003400.pinmux: pin PIN170 already requested by 4806a000.serial; cannot claim for 48460000.mcasp
    [    3.169766] pinctrl-single 4a003400.pinmux: pin-170 (48460000.mcasp) status -22
    [    3.177113] pinctrl-single 4a003400.pinmux: could not request pin 170 (PIN170) from group mcasp1_pins  on device pinctrl-single
    [    3.188662] davinci-mcasp 48460000.mcasp: Error applying setting, reverse things back
    [    3.196555] davinci-mcasp: probe of 48460000.mcasp failed with error -22
    [    3.203365] pinctrl-single 4a003400.pinmux: pin PIN192 already requested by 4806a000.serial; cannot claim for 48464000.mcasp
    [    3.214653] pinctrl-single 4a003400.pinmux: pin-192 (48464000.mcasp) status -22
    [    3.222021] pinctrl-single 4a003400.pinmux: could not request pin 192 (PIN192) from group mcasp2_pins  on device pinctrl-single
    [    3.233565] davinci-mcasp 48464000.mcasp: Error applying setting, reverse things back
    [    3.241452] davinci-mcasp: probe of 48464000.mcasp failed with error -22
    [    3.248237] pinctrl-single 4a003400.pinmux: pin PIN203 already requested by 4806a000.serial; cannot claim for 48468000.mcasp
    [    3.259523] pinctrl-single 4a003400.pinmux: pin-203 (48468000.mcasp) status -22
    [    3.266867] pinctrl-single 4a003400.pinmux: could not request pin 203 (PIN203) from group mcasp3_pins  on device pinctrl-single
    [    3.278408] davinci-mcasp 48468000.mcasp: Error applying setting, reverse things back
    [    3.286294] davinci-mcasp: probe of 48468000.mcasp failed with error -22
    [    3.293092] pinctrl-single 4a003400.pinmux: pin PIN205 already requested by 4806a000.serial; cannot claim for 4846c000.mcasp
    [    3.304377] pinctrl-single 4a003400.pinmux: pin-205 (4846c000.mcasp) status -22
    [    3.311736] pinctrl-single 4a003400.pinmux: could not request pin 205 (PIN205) from group mcasp4_pins  on device pinctrl-single
    [    3.323278] davinci-mcasp 4846c000.mcasp: Error applying setting, reverse things back
    [    3.331166] davinci-mcasp: probe of 4846c000.mcasp failed with error -22
    [    3.337955] pinctrl-single 4a003400.pinmux: pin PIN200 already requested by 4806a000.serial; cannot claim for 4847c000.mcasp
    [    3.349246] pinctrl-single 4a003400.pinmux: pin-200 (4847c000.mcasp) status -22
    [    3.356590] pinctrl-single 4a003400.pinmux: could not request pin 200 (PIN200) from group mcasp8_pins  on device pinctrl-single
    [    3.368134] davinci-mcasp 4847c000.mcasp: Error applying setting, reverse things back
    [    3.376023] davinci-mcasp: probe of 4847c000.mcasp failed with error -22
    [    3.383480] NET: Registered protocol family 10
    [    3.388888] Segment Routing with IPv6
    [    3.392659] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
    [    3.399094] NET: Registered protocol family 17
    [    3.403756] Key type dns_resolver registered
    [    3.408154] Registering SWP/SWPB emulation handler
    [    3.412990] omap_voltage_late_init: Voltage driver support not added
    [    3.419391] Power Management for TI OMAP4+ devices.
    [    3.424978] Loading compiled-in X.509 certificates
    [    3.446882] dmm 4e000000.dmm: failed to initialize work-around for i878
    [    3.455039] dmm 4e000000.dmm: initialized all PAT entries
    [    3.461135] omapdrm omapdrm.0: omap_modeset_init failed: ret=-517
    [    3.468175] omapdrm omapdrm.0: omap_modeset_init failed: ret=-517
    [    3.475138] omapdrm omapdrm.0: omap_modeset_init failed: ret=-517
    [    3.481870] hctosys: unable to open rtc device (rtc0)
    [    3.487585] aic_dvdd: disabling
    [    3.490956] ldousb: disabling
    [    3.494251] ALSA device list:
    [    3.497232]   No soundcards found.
    [    3.501323] Waiting for root device PARTUUID=bddb4f41-02...
    2. The boot log of DateCode2244/2245 booting successfully at 1.8V:
    DRA752-GP ES2.0
    reading args
    reading u-boot.img
    reading u-boot.img
    I2C:   ready
    DRAM:  2 GiB
    cpsw
    J6 ...
    4281344 bytes read in 213 ms (19.2 MiB/s)
    113071 bytes read in 12 ms (9 MiB/s)
    Kernel image @ 0x82000000 [ 0x000000 - 0x415400 ]
       Loading Device Tree to 8ffe1000, end 8ffff9ae ... OK
    Starting kernel ...
    [    0.000000] Initializing cgroup subsys cpuset
    [    0.000000] Initializing cgroup subsys cpuacct
    [    0.000000] Linux version 4.4.45 (bowei@bowei-Veriton-M490) (gcc version 5.3.1 20160113 (Linaro GCC 5.3-2016.02) ) #75 SMP PREEMPT Mon Jan 22 10:50:18 CST 2018
    [    0.000000] CPU: ARMv7 Processor [412fc0f2] revision 2 (ARMv7), cr=10c5387d
    [    0.000000] Machine model: TI DRA742 Louis 20170929 17:30
    [    0.000000] Reserved memory: created CMA memory pool at 0x95800000, size 56 MiB
    [    0.000000] Reserved memory: initialized node ipu2_cma@95800000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created CMA memory pool at 0x99000000, size 64 MiB
    [    0.000000] Reserved memory: initialized node dsp1_cma@99000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created CMA memory pool at 0x9d000000, size 32 MiB
    [    0.000000] Reserved memory: initialized node ipu1_cma@9d000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created CMA memory pool at 0x9f000000, size 8 MiB
    [    0.000000] Reserved memory: initialized node dsp2_cma@9f000000, compatible id shared-dma-pool
    [    0.000000] cma: Reserved 24 MiB at 0xfd400000
    [    0.000000] OMAP4: Map 0xfee00000 to fe600000 for dram barrier
    [    0.000000] PERCPU: Embedded 12 pages/cpu @eed51000 s18944 r8192 d22016 u49152
    [    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 516672
    [    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
    [    0.000000] Memory: 1851432K/2073600K available (7719K kernel code, 797K rwdata, 4560K rodata, 372K init, 291K bss, 33752K reserved, 188416K cma-reserved, 1266688K highmem)
    [    0.000000]       .text : 0xc0008000 - 0xc0c0607c   (12281 kB)
    [    0.000000]       .init : 0xc0c07000 - 0xc0c64000   ( 372 kB)
    [    0.000000]       .data : 0xc0c64000 - 0xc0d2b530   ( 798 kB)
    [    0.000000]        .bss : 0xc0d2d000 - 0xc0d75f00   ( 292 kB)
    [    0.000000] Preemptible hierarchical RCU implementation.
    [    0.000000]  Build-time adjustment of leaf fanout to 32.
    [    0.000000] NR_IRQS:16 nr_irqs:16 16
    [    0.000000] ti_dt_clocks_register: failed to lookup clock node gmac_gmii_ref_clk_div
    [    0.000000] Architected cp15 timer(s) running at 5.90MHz (virt).
    [    0.000004] sched_clock: 56 bits at 5MHz, resolution 169ns, wraps every 4398046511093ns
    [    0.000015] Switching to timer-based delay loop, resolution 169ns
    [    0.000325] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns
    [    0.000333] OMAP clocksource: 32k_counter at 32768 Hz
    [    0.000786] Console: colour dummy device 80x30
    [    0.000803] WARNING: Your 'console=ttyO2' has been replaced by 'ttyS2'
    [    0.000810] This ensures that you still see kernel messages. Please
    [    0.000816] update your kernel commandline.
    [    0.000828] Calibrating delay loop (skipped), value calculated using timer frequency.. 11.80 BogoMIPS (lpj=59016)
    [    0.000841] pid_max: default: 32768 minimum: 301
    [    0.000934] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
    [    0.000944] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
    [    0.001474] Initializing cgroup subsys io
    [    0.001492] Initializing cgroup subsys memory
    [    0.001515] Initializing cgroup subsys devices
    [    0.001528] Initializing cgroup subsys freezer
    [    0.001539] Initializing cgroup subsys perf_event
    [    0.001550] Initializing cgroup subsys pids
    [    0.001576] CPU: Testing write buffer coherency: ok
    [    0.001771] /cpus/cpu@0 missing clock-frequency property
    [    0.001787] /cpus/cpu@1 missing clock-frequency property
    [    0.001797] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
    [    0.001837] Setting up static identity map for 0x80008340 - 0x800083a0
    [    0.080051] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
    [    0.080113] Brought up 2 CPUs
    [    0.080126] SMP: Total of 2 processors activated (23.60 BogoMIPS).
    [    0.080133] CPU: All CPU(s) started in SVC mode.
    [    0.081170] devtmpfs: initialized
    [    0.111084] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
    [    0.112068] omap_hwmod: l3_main_2 using broken dt data from ocp
    [    0.310433] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
    [    0.314133] pinctrl core: initialized pinctrl subsystem
    [    0.314996] NET: Registered protocol family 16
    [    0.315935] DMA: preallocated 256 KiB pool for atomic coherent allocations
    [    0.340217] cpuidle: using governor ladder
    [    0.370240] cpuidle: using governor menu
    [    0.378504] OMAP GPIO hardware version 0.1
    [    0.382624] GPIO line 161 (radio_rst) hogged as output/low
    [    0.414591] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
    [    0.414601] hw-breakpoint: maximum watchpoint size is 8 bytes.
    [    0.415081] omap4_sram_init:Unable to allocate sram needed to handle errata I688
    [    0.415090] omap4_sram_init:Unable to get sram pool needed to handle errata I688
    [    0.415576] OMAP DMA hardware revision 0.0
    [    0.461550] omap-dma-engine 4a056000.dma-controller: OMAP DMA engine driver (LinkedList1/2/3 supported)
    [    0.462798] edma 43300000.edma: memcpy is disabled
    [    0.467537] edma 43300000.edma: TI EDMA DMA engine driver
    [    0.471761] omap-iommu 40d01000.mmu: 40d01000.mmu registered
    [    0.471943] omap-iommu 40d02000.mmu: 40d02000.mmu registered
    [    0.472102] omap-iommu 58882000.mmu: 58882000.mmu registered
    [    0.472260] omap-iommu 55082000.mmu: 55082000.mmu registered
    [    0.472557] omap-iommu 41501000.mmu: 41501000.mmu registered
    [    0.472749] omap-iommu 41502000.mmu: 41502000.mmu registered
    [    0.474753] SCSI subsystem initialized
    [    0.476005] ======palmas_i2c_probe:526========
    [    0.476022] ======palmas_i2c_probe:559, features=0x0========
    [    0.476333] palmas 0-0058: IRQ missing: skipping irq request
    [    0.491064] palmas 0-0058: Muxing GPIO a, PWM 0, LED 0
    [    0.562796] omap_i2c 48070000.i2c: bus 0 rev0.12 at 400 kHz
    [    0.563432] omap_i2c 48072000.i2c: bus 1 rev0.12 at 400 kHz
    [    0.563797] omap_i2c 48060000.i2c: bus 2 rev0.12 at 400 kHz
    [    0.564169] omap_i2c 4807a000.i2c: bus 3 rev0.12 at 400 kHz
    [    0.564534] omap_i2c 4807c000.i2c: bus 4 rev0.12 at 400 kHz
    [    0.564756] media: Linux media interface: v0.10
    [    0.564806] Linux video capture interface: v2.00
    [    0.564844] pps_core: LinuxPPS API ver. 1 registered
    [    0.564851] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.564874] PTP clock support registered
    [    0.564900] EDAC MC: Ver: 3.0.0
    [    0.565665] omap-mailbox 48840000.mailbox: omap mailbox rev 0x400
    [    0.565959] omap-mailbox 48842000.mailbox: omap mailbox rev 0x400
    [    0.566304] Advanced Linux Sound Architecture Driver Initialized.
    [    0.567188] clocksource: Switched to clocksource arch_sys_counter
    [    0.577940] NET: Registered protocol family 2
    [    0.578431] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
    [    0.578494] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
    [    0.578619] TCP: Hash tables configured (established 8192 bind 8192)
    [    0.578665] UDP hash table entries: 512 (order: 2, 16384 bytes)
    [    0.578698] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
    [    0.578907] NET: Registered protocol family 1
    [    0.579172] RPC: Registered named UNIX socket transport module.
    [    0.579181] RPC: Registered udp transport module.
    [    0.579187] RPC: Registered tcp transport module.
    [    0.579193] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.580238] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
    [    0.582696] futex hash table entries: 512 (order: 3, 32768 bytes)
    [    0.589425] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.590074] NFS: Registering the id_resolver key type
    [    0.590098] Key type id_resolver registered
    [    0.590106] Key type id_legacy registered
    [    0.590171] ntfs: driver 2.1.32 [Flags: R/O].
    [    0.592152] bounce: pool size: 64 pages
    [    0.592306] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
    [    0.592323] io scheduler noop registered
    [    0.592337] io scheduler deadline registered
    [    0.592371] io scheduler cfq registered (default)
    [    0.597689] pinctrl-single 4a003400.pinmux: 282 pins at pa fc003400 size 1128
    [    0.658363] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
    [    0.661951] 4806a000.serial: ttyS0 at MMIO 0x4806a000 (irq = 299, base_baud = 3000000) is a 8250
    [    0.662826] 4806c000.serial: ttyS1 at MMIO 0x4806c000 (irq = 300, base_baud = 3000000) is a 8250
    [    0.663687] console [ttyS2] disabled
    [    0.663732] 48020000.serial: ttyS2 at MMIO 0x48020000 (irq = 301, base_baud = 3000000) is a 8250
    [    1.550527] console [ttyS2] enabled
    [    1.554926] 48066000.serial: ttyS4 at MMIO 0x48066000 (irq = 302, base_baud = 3000000) is a 8250
    [    1.564654] 48068000.serial: ttyS5 at MMIO 0x48068000 (irq = 303, base_baud = 3000000) is a 8250
    [    1.574335] 48424000.serial: ttyS8 at MMIO 0x48424000 (irq = 304, base_baud = 3000000) is a 8250
    [    1.584013] 4ae2b000.serial: ttyS9 at MMIO 0x4ae2b000 (irq = 305, base_baud = 3000000) is a 8250
    [    1.594154] [drm] Initialized drm 1.1.0 20060810
    [    1.600370] OMAP DSS rev 6.1
    [    1.604134] omapdss_dss 58000000.dss: bound 58001000.dispc (ops dispc_component_ops)
    [    1.625872] brd: module loaded
    [    1.634088] loop: module loaded
    [    1.643758] libphy: Fixed MDIO Bus: probed
    [    1.648467] e1000: Intel(R) PRO/1000 Network Driver - version 7.3.21-k8-NAPI
    [    1.655547] e1000: Copyright (c) 1999-2006 Intel Corporation.
    [    1.661395] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
    [    1.667267] e1000e: Copyright(c) 1999 - 2015     2.019967] tvp5158 1-0058: ERROR: Chip id is not TVP5158
    [    2.025505] ov1063x 1-0037: ov1063x Product ID 0 Manufacturer ID 0
    [    2.031731] ov1063x 1-0037: ov1063x 1-0037 sensor driver registered !!
    [    2.039140] vpe 489d0000.vpe: loading firmware vpdma-1b8.bin
    [    2.046236] vip 48990000.vip: loading firmware vpdma-1b8.bin
    [    2.055636] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr104 mode
    [    2.062254] omap_hsmmc 4809c000.mmc: no pinctrl state for ddr50 mode
    [    2.068685] vpe 489d0000.vpe: Device registered as /dev/video0
    [    2.074558] vip 48990000.vip: VPDMA firmware loaded
    [    2.079496] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr50 mode
    [    2.079606] vip2-s1: Port B: Using subdev ov1063x 1-0037 for capture
    [    2.092316] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr25 mode
    [    2.092334] vip2-s1: device registered as video1
    [    2.103347] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr12 mode
    [    2.110958] ldo1: voltage operation not allowed
    [    2.115512] omap_hsmmc 4809c000.mmc: vmmc_aux set voltage failed
    [    2.121567] omap_hsmmc 4809c000.mmc: failed to switch to 3v
    [    2.167614] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr25 mode
    [    2.173998] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr12 mode
    [    2.180403] omap_hsmmc 480b4000.mmc: no pinctrl state for hs200_1_8v mode
    [    2.187373] evm_3v3_sw: supplied by sysen1
    [    2.227553] omap_hsmmc 480d1000.mmc: no pinctrl state for sdr25 mode
    [    2.233936] omap_hsmmc 480d1000.mmc: no pinctrl state for sdr12 mode
    [    2.240334] omap_hsmmc 480d1000.mmc: no pinctrl state for hs mode
    [    2.278007] ledtrig-cpu: registered to indicate activity on CPUs
    [    2.286092] hwspinlock_user gatemp: requested 10 hwspinlocks
    [    2.307085] pinctrl-single 4a003400.pinmux: pin 4a0036a8.0 already requested by 4806a000.serial; cannot claim for 48460000.mcasp
    [    2.318722] pinctrl-single 4a003400.pinmux: pin-170 (48460000.mcasp) status -22
    [    2.326065] pinctrl-single 4a003400.pinmux: could not request pin 170 (4a0036a8.0) from group mcasp1_pins  on device pinctrl-single
    [    2.337990] davinci-mcasp 48460000.mcasp: Error applying setting, reverse things back
    [    2.346265] davinci-mcasp 48460000.mcasp: Update the bindings to use assigned-clocks!
    [    2.354169] davinci-mcasp 48460000.mcasp: failed to reparent fck
    [    2.360453] pinctrl-single 4a003400.pinmux: pin 4a003700.0 already requested by 4806a000.serial; cannot claim for 48464000.mcasp
    [    2.372083] pinctrl-single 4a003400.pinmux: pin-192 (48464000.mcasp) status -22
    [    2.379466] pinctrl-single 4a003400.pinmux: could not request pin 192 (4a003700.0) from group mcasp2_pins  on device pinctrl-single
    [    2.391353] davinci-mcasp 48464000.mcasp: Error applying setting, reverse things back
    [    2.399601] davinci-mcasp 48464000.mcasp: Update the bindings to use assigned-clocks!
    [    2.407503] davinci-mcasp 48464000.mcasp: failed to reparent fck
    [    2.413764] pinctrl-single 4a003400.pinmux: pin 4a00372c.0 already requested by 4806a000.serial; cannot claim for 48468000.mcasp
    [    2.425394] pinctrl-single 4a003400.pinmux: pin-203 (48468000.mcasp) status -22
    [    2.432746] pinctrl-single 4a003400.pinmux: could not request pin 203 (4a00372c.0) from group mcasp3_pins  on device pinctrl-single
    [    2.444630] davinci-mcasp 48468000.mcasp: Error applying setting, reverse things back
    [    2.452883] davinci-mcasp 48468000.mcasp: Update the bindings to use assigned-clocks!
    [    2.460781] davinci-mcasp 48468000.mcasp: failed to reparent fck
    [    2.467029] pinctrl-single 4a003400.pinmux: pin 4a003734.0 already requested by 4806a000.serial; cannot claim for 4846c000.mcasp
    [    2.478659] pinctrl-single 4a003400.pinmux: pin-205 (4846c000.mcasp) status -22
    [    2.486000] pinctrl-single 4a003400.pinmux: could not request pin 205 (4a003734.0) from group mcasp4_pins  on device pinctrl-single
    [    2.497884] davinci-mcasp 4846c000.mcasp: Error applying setting, reverse things back
    [    2.506119] davinci-mcasp 4846c000.mcasp: Update the bindings to use assigned-clocks!
    [    2.514017] davinci-mcasp 4846c000.mcasp: failed to reparent fck
    [    2.520274] pinctrl-single 4a003400.pinmux: pin 4a003720.0 already requested by 4806a000.serial; cannot claim for 4847c000.mcasp
    [    2.531903] pinctrl-single 4a003400.pinmux: pin-200 (4847c000.mcasp) status -22
    [    2.539259] pinctrl-single 4a003400.pinmux: could not request pin 200 (4a003720.0) from group mcasp8_pins  on device pinctrl-single
    [    2.551144] davinci-mcasp 4847c000.mcasp: Error applying setting, reverse things back
    [    2.559399] davinci-mcasp 4847c000.mcasp: Update the bindings to use assigned-clocks!
    [    2.567295] davinci-mcasp 4847c000.mcasp: failed to reparent fck
    [    2.574511] NET: Registered protocol family 10
    [    2.589790] sit: IPv6 over IPv4 tunneling driver
    [    2.594962] NET: Registered protocol family 17
    [    2.599689] Key type dns_resolver registered
    [    2.604103] omap_voltage_late_init: Voltage driver support not added
    [    2.611013] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
    [    2.617234] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
    [    2.623486] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
    [    2.630118] Power Management for TI OMAP4+ devices.
    [    2.635259] Registering SWP/SWPB emulation handler
    [    2.642711] dmm 4e000000.dmm: initialized all PAT entries
    [    2.670836] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
    [    2.677498] [drm] No driver support for vblank timestamp query.
    [    2.694269] [drm] Enabling DMM ywrap scrolling
    [    2.700353] mmc0: MAN_BKOPS_EN bit is not set
    [    2.766111] mmc0: new high speed MMC card at address 0001
    [    2.769704] Console: switching to colour frame buffer device 240x67
    [    2.776758] mmcblk0: mmc0:0001 R1J55A 7.28 GiB
    [    2.787071] mmcblk0boot0: mmc0:0001 R1J55A partition 1 128 KiB
    [    2.787361] mmcblk0boot1: mmc0:0001 R1J55A partition 2 128 KiB
    [    2.789666]  mmcblk0: p1
    [    2.819602] omapdrm omapdrm.0: fb0: omapdrm frame buffer device
    [    2.840325] mmc1: MAN_BKOPS_EN bit is not set
    [    2.848456] [drm] Initialized omapdrm 1.0.0 20110917 on minor 0
    [    2.876112] asoc-simple-card-mcasp1 sound@1: bt-sco-pcm-mcasp1 <-> 48460000.mcasp mapping ok
    [    2.885192] asoc-simple-card-mcasp1 sound@1: ASoC: no source widget found for HPLOUT
    [    2.895052] asoc-simple-card-mcasp1 sound@1: ASoC: Failed to add route HPLOUT -> direct -> Headphone Jack
    [    2.904698] asoc-simple-card-mcasp1 sound@1: ASoC: no source widget found for HPROUT
    [    2.912491] asoc-simple-card-mcasp1 sound@1: ASoC: Failed to add route HPROUT -> direct -> Headphone Jack
    [    2.922113] asoc-simple-card-mcasp1 sound@1: ASoC: no source widget found for LLOUT
    [    2.929912] asoc-simple-card-mcasp1 sound@1: ASoC: Failed to add route LLOUT -> direct -> Line Out
    [    2.938926] asoc-simple-card-mcasp1 sound@1: ASoC: no source widget found for RLOUT
    [    2.946616] asoc-simple-card-mcasp1 sound@1: ASoC: Failed to add route RLOUT -> direct -> Line Out
    [    2.955625] asoc-simple-card-mcasp1 sound@1: ASoC: no sink widget found for MIC3L
    [    2.963148] asoc-simple-card-mcasp1 sound@1: ASoC: Failed to add route Mic Jack -> direct -> MIC3L
    [    2.972157] asoc-simple-card-mcasp1 sound@1: ASoC: no sink widget found for MIC3R
    [    2.979688] asoc-simple-card-mcasp1 sound@1: ASoC: Failed to add route Mic Jack -> direct -> MIC3R
    [    2.988698] asoc-simple-card-mcasp1 sound@1: ASoC: no source widget found for Mic Bias
    [    2.996648] asoc-simple-card-mcasp1 sound@1: ASoC: Failed to add route Mic Bias -> direct -> Mic Jack
    [    3.005920] asoc-simple-card-mcasp1 sound@1: ASoC: no sink widget found for LINE1L
    [    3.013570] asoc-simple-card-mcasp1 sound@1: ASoC: Failed to add route Line In -> direct -> LINE1L
    [    3.022585] asoc-simple-card-mcasp1 sound@1: ASoC: no sink widget found for LINE1R
    [    3.030200] asoc-simple-card-mcasp1 sound@1: ASoC: Failed to add route Line In -> direct -> LINE1R
    [    3.041140] asoc-simple-card-mcasp2 sound@2: bt-sco-pcm-mcasp2 <-> 48464000.mcasp mapping ok
    [    3.049640] asoc-simple-card-mcasp2 sound@2: ASoC: no source widget found for HPLOUT
    [    3.057436] asoc-simple-card-mcasp2 sound@2: ASoC: Failed to add route HPLOUT -> direct -> Headphone Jack
    [    3.067046] asoc-simple-card-mcasp2 sound@2: ASoC: no source widget found for HPROUT
    [    3.074836] asoc-simple-card-mcasp2 sound@2: ASoC: Failed to add route HPROUT -> direct -> Headphone Jack
    [    3.084456] asoc-simple-card-mcasp2 sound@2: ASoC: no source widget found for LLOUT
    [    3.092158] asoc-simple-card-mcasp2 sound@2: ASoC: Failed to add route LLOUT -> direct -> Line Out
    [    3.101190] asoc-simple-card-mcasp2 sound@2: ASoC: no source widget found for RLOUT
    [    3.108899] asoc-simple-card-mcasp2 sound@2: ASoC: Failed to add route RLOUT -> direct -> Line Out
    [    3.117910] asoc-simple-card-mcasp2 sound@2: ASoC: no sink widget found for MIC3L
    [    3.125425] asoc-simple-card-mcasp2 sound@2: ASoC: Failed to add route Mic Jack -> direct -> MIC3L
    [    3.134431] asoc-simple-card-mcasp2 sound@2: ASoC: no sink widget found for MIC3R
    [    3.141957] asoc-simple-card-mcasp2 sound@2: ASoC: Failed to add route Mic Jack -> direct -> MIC3R
    [    3.150966] asoc-simple-card-mcasp2 sound@2: ASoC: no source widget found for Mic Bias
    [    3.158928] asoc-simple-card-mcasp2 sound@2: ASoC: Failed to add route Mic Bias -> direct -> Mic Jack
    [    3.168201] asoc-simple-card-mcasp2 sound@2: ASoC: no sink widget found for LINE1L
    [    3.175804] asoc-simple-card-mcasp2 sound@2: ASoC: Failed to add route Line In -> direct -> LINE1L
    [    3.184813] asoc-simple-card-mcasp2 sound@2: ASoC: no sink widget found for LINE1R
    [    3.192463] asoc-simple-card-mcasp2 sound@2: ASoC: Failed to add route Line In -> direct -> LINE1R
    [    3.203248] asoc-simple-card-mcasp3 sound@3: bt-sco-pcm-mcasp3 <-> 48468000.mcasp mapping ok
    [    3.211747] asoc-simple-card-mcasp3 sound@3: ASoC: no source widget found for HPLOUT
    [    3.217732] mmc1: new DDR MMC card at address 0001
    [    3.224358] asoc-simple-card-mcasp3 sound@3: ASoC: Failed to add route HPLOUT -> direct -> Headphone Jack
    [    3.228252] mmcblk1: mmc1:0001 R1J55A 7.28 GiB
    [    3.238527] mmcblk1boot0: mmc1:0001 R1J55A partition 1 128 KiB
    [    3.244403] asoc-simple-card-mcasp3 sound@3: ASoC: no source widget found for HPROUT
    [    3.248798] mmcblk1boot1: mmc1:0001 R1J55A partition 2 128 KiB
    [    3.253032]  mmcblk1: p1 p2
    [    3.260869] asoc-simple-card-mcasp3 sound@3: ASoC: Failed to add route HPROUT -> direct -> Headphone Jack
    [    3.270494] asoc-simple-card-mcasp3 sound@3: ASoC: no source widget found for LLOUT
    [    3.278203] asoc-simple-card-mcasp3 sound@3: ASoC: Failed to add route LLOUT -> direct -> Line Out
    [    3.287215] asoc-simple-card-mcasp3 sound@3: ASoC: no source widget found for RLOUT
    [    3.294904] asoc-simple-card-mcasp3 sound@3: ASoC: Failed to add route RLOUT -> direct -> Line Out
    [    3.303945] asoc-simple-card-mcasp3 sound@3: ASoC: no sink widget found for MIC3L
    [    3.311478] asoc-simple-card-mcasp3 sound@3: ASoC: Failed to add route Mic Jack -> direct -> MIC3L
    [    3.320489] asoc-simple-card-mcasp3 sound@3: ASoC: no sink widget found for MIC3R
    [    3.328017] asoc-simple-card-mcasp3 sound@3: ASoC: Failed to add route Mic Jack -> direct -> MIC3R
    [    3.337016] asoc-simple-card-mcasp3 sound@3: ASoC: no source widget found for Mic Bias
    [    3.344690] mmc2: host does not support reading read-only switch, assuming write-enable
    [    3.344758] mmc2: new SDHC card at address 0001
    [    3.355217] mmcblk2: mmc2:0001 SD4GB 3.64 GiB
    [    3.357067]  mmcblk2: p1 p2
    [    3.364844] asoc-simple-card-mcasp3 sound@3: ASoC: Failed to add route Mic Bias -> direct -> Mic Jack
    [    3.374128] asoc-simple-card-mcasp3 sound@3: ASoC: no sink widget found for LINE1L
    [    3.381745] asoc-simple-card-mcasp3 sound@3: ASoC: Failed to add route Line In -> direct -> LINE1L
    [    3.390761] asoc-simple-card-mcasp3 sound@3: ASoC: no sink widget found for LINE1R
    [    3.398378] asoc-simple-card-mcasp3 sound@3: ASoC: Failed to add route Line In -> direct -> LINE1R
    [    3.409327] asoc-simple-card-mcasp4 sound@4: bt-sco-pcm-mcasp4 <-> 4846c000.mcasp mapping ok
    [    3.417832] asoc-simple-card-mcasp4 sound@4: ASoC: no source widget found for HPLOUT
    [    3.425611] asoc-simple-card-mcasp4 sound@4: ASoC: Failed to add route HPLOUT -> direct -> Headphone Jack
    [    3.435232] asoc-simple-card-mcasp4 sound@4: ASoC: no source widget found for HPROUT
    [    3.443023] asoc-simple-card-mcasp4 sound@4: ASoC: Failed to add route HPROUT -> direct -> Headphone Jack
    [    3.452645] asoc-simple-card-mcasp4 sound@4: ASoC: no source widget found for LLOUT
    [    3.460342] asoc-simple-card-mcasp4 sound@4: ASoC: Failed to add route LLOUT -> direct -> Line Out
    [    3.469352] asoc-simple-card-mcasp4 sound@4: ASoC: no source widget found for RLOUT
    [    3.477041] asoc-simple-card-mcasp4 sound@4: ASoC: Failed to add route RLOUT -> direct -> Line Out
    [    3.486050] asoc-simple-card-mcasp4 sound@4: ASoC: no sink widget found for MIC3L
    [    3.493577] asoc-simple-card-mcasp4 sound@4: ASoC: Failed to add route Mic Jack -> direct -> MIC3L
    [    3.502613] asoc-simple-card-mcasp4 sound@4: ASoC: no sink widget found for MIC3R
    [    3.510142] asoc-simple-card-mcasp4 sound@4: ASoC: Failed to add route Mic Jack -> direct -> MIC3R
    [    3.519153] asoc-simple-card-mcasp4 sound@4: ASoC: no source widget found for Mic Bias
    [    3.527103] asoc-simple-card-mcasp4 sound@4: ASoC: Failed to add route Mic Bias -> direct -> Mic Jack
    [    3.536374] asoc-simple-card-mcasp4 sound@4: ASoC: no sink widget found for LINE1L
    [    3.543984] asoc-simple-card-mcasp4 sound@4: ASoC: Failed to add route Line In -> direct -> LINE1L
    [    3.552994] asoc-simple-card-mcasp4 sound@4: ASoC: no sink widget found for LINE1R
    [    3.560604] asoc-simple-card-mcasp4 sound@4: ASoC: Failed to add route Line In -> direct -> LINE1R
    [    3.571782] asoc-simple-card-mcasp8 sound@8: bt-sco-pcm-mcasp8 <-> 4847c000.mcasp mapping ok
    [    3.580284] asoc-simple-card-mcasp8 sound@8: ASoC: no source widget found for HPLOUT
    [    3.588077] asoc-simple-card-mcasp8 sound@8: ASoC: Failed to add route HPLOUT -> direct -> Headphone Jack
    [    3.597697] asoc-simple-card-mcasp8 sound@8: ASoC: no source widget found for HPROUT
    [    3.605474] asoc-simple-card-mcasp8 sound@8: ASoC: Failed to add route HPROUT -> direct -> Headphone Jack
    [    3.615090] asoc-simple-card-mcasp8 sound@8: ASoC: no source widget found for LLOUT
    [    3.622793] asoc-simple-card-mcasp8 sound@8: ASoC: Failed to add route LLOUT -> direct -> Line Out
    [    3.631802] asoc-simple-card-mcasp8 sound@8: ASoC: no source widget found for RLOUT
    [    3.639503] asoc-simple-card-mcasp8 sound@8: ASoC: Failed to add route RLOUT -> direct -> Line Out
    [    3.648514] asoc-simple-card-mcasp8 sound@8: ASoC: no sink widget found for MIC3L
    [    3.656027] asoc-simple-card-mcasp8 sound@8: ASoC: Failed to add route Mic Jack -> direct -> MIC3L
    [    3.665036] asoc-simple-card-mcasp8 sound@8: ASoC: no sink widget found for MIC3R
    [    3.672562] asoc-simple-card-mcasp8 sound@8: ASoC: Failed to add route Mic Jack -> direct -> MIC3R
    [    3.681572] asoc-simple-card-mcasp8 sound@8: ASoC: no source widget found for Mic Bias
    [    3.689533] asoc-simple-card-mcasp8 sound@8: ASoC: Failed to add route Mic Bias -> direct -> Mic Jack
    [    3.698836] asoc-simple-card-mcasp8 sound@8: ASoC: no sink widget found for LINE1L
    [    3.706439] asoc-simple-card-mcasp8 sound@8: ASoC: Failed to add route Line In -> direct -> LINE1L
    [    3.715447] asoc-simple-card-mcasp8 sound@8: ASoC: no sink widget found for LINE1R
    [    3.723063] asoc-simple-card-mcasp8 sound@8: ASoC: Failed to add route Line In -> direct -> LINE1R
    [    3.732961] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
    [    3.739190] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
    [    3.745445] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
    [    3.752502] hctosys: unable to open rtc device (rtc0)
    [    3.769351] aic_dvdd: disabling
    [    3.772756] ldousb: disabling
    [    3.776239] ALSA device list:
    [    3.779235]   #0: DRA7xx-EVM-MCASP1
    [    3.782737]   #1: DRA7xx-EVM-MCASP2
    [    3.786237]   #2: DRA7xx-EVM-MCASP3
    [    3.789751]   #3: DRA7xx-EVM-MCASP4
    [    3.793250]   #4: DRA7xx-EVM-MCASP8
    [    3.865870] EXT4-fs (mmcblk1p2): recovery complete
    [    3.871133] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
    [    3.879308] VFS: Mounted root (ext4 filesystem) on device 179:50.
    [    3.886821] devtmpfs: mounted
    [    3.890040] Freeing unused kernel memory: 372K (c0c07000 - c0c64000)
    [    3.896420] This architecture does not have kernel memory protection.
    INIT: version 2.88 booting
    Starting udev
    [    4.183148] udevd[129]: starting version 182
    [    4.641595] omap-rproc 58820000.ipu: assigned reserved memory node ipu1_cma@9d000000
    [    4.720397]  remoteproc0: 58820000.ipu is available
    [    4.872043]  remoteproc0: Note: remoteproc is still under development and considered experimental.
    [    4.987275]  remoteproc0: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
    [    5.014205] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
    [    5.014593]  remoteproc0: Direct firmware load for dra7-ipu1-fw.xem4 failed with error -2
    [    5.014601]  remoteproc0: failed to load dra7-ipu1-fw.xem4
    [    5.015604] omap-rproc 55020000.ipu: assigned reserved memory node ipu2_cma@95800000
    [    5.015663]  remoteproc1: 55020000.ipu is available
    [    5.015667]  remoteproc1: Note: remoteproc is still under development and considered experimental.
    [    5.015670]  remoteproc1: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
    [    5.017603] omap-rproc 40800000.dsp: assigned reserved memory node dsp1_cma@99000000
    [    5.017660]  remoteproc2: 40800000.dsp is available
    [    5.017664]  remoteproc2: Note: remoteproc is still under development and considered experimental.
    [    5.017667]  remoteproc2: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
    [    5.018494] omap-rproc 41000000.dsp: assigned reserved memory node dsp2_cma@9f000000
    [    5.018545]  remoteproc3: 41000000.dsp is available
    [    5.018549]  remoteproc3: Note: remoteproc is still under development and considered experimental.
    [    5.018551]  remoteproc3: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
    [    5.027750] omap_rng 48090000.rng: OMAP Random Number Generator ver. 20
    [    5.029286] omap-des 480a5000.des: OMAP DES hw accel rev: 2.2
    [    5.045557]  remoteproc3: Direct firmware load for dra7-dsp2-fw.xe66 failed with error -2
    [    5.045566]  remoteproc3: failed to load dra7-dsp2-fw.xe66
    [    5.046387]  remoteproc2: registered virtio0 (type 7)
    [    5.060817] alg: skcipher: setkey failed on test 5 for ecb-des-omap: flags=100
    [    5.061147] alg: skcipher-ddst: setkey failed on test 5 for ecb-des-omap: flags=100
    [    5.061496] alg: skcipher-ddst: setkey failed on test 5 for ecb-des-omap: flags=100
    [    5.089779]  remoteproc1: registered virtio1 (type 7)
    [    5.159347] omap_rtc 48838000.rtc: rtc core: registered 48838000.rtc as rtc0
    [    5.296794] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
    [    5.304018] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
    [    5.309334] ahci 4a140000.sata: forcing port_map 0x0 -> 0x1
    [    5.309379] ahci 4a140000.sata: AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl platform mode
    [    5.309389] ahci 4a140000.sata: flags: 64bit ncq sntf pm led clo only pmp pio slum part ccc apst
    [    5.353718] CAN device driver interface
    [    5.431211] scsi host0: ahci
    [    5.434490] ata1: SATA max UDMA/133 mmio [mem 0x4a140000-0x4a1410ff] port 0x100 irq 347
    [    5.447787] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
    [    5.491596] omap-sham 4b101000.sham: hw accel on OMAP rev 4.3
    [    5.509469] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
    [    5.515799] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
    [    5.697724] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
    [    5.703949] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
    [    5.885968] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
    udevd[619]: failed to execute '/etc/udev/scripts/mount.sh' '/etc/udev/scripts/mount.sh': No such file or directory
    udevd[622]: failed to execute '/etc/udev/scripts/mount.sh' '/etc/udev/scripts/mount.sh': No such file or directory[    6.521364] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
    [    6.522740] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
    [    6.523824] omap-aes 4b500000.aes: OMAP AES hw accel rev: 3.3
    udevd[632]: failed to execute '/etc/udev/scripts/mount.sh' '/etc/udev/scripts/mount.sh': No such file or directory
    udevd[631]: failed to execute '/etc/udev/scripts/mount.sh' '/etc/udev/scripts/mount.sh': No such file or directory
    [    6.572664] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
    [    6.580392] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
    [    6.598777] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
    [    6.604997] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
    udevd[635]: failed to execute '/etc/udev/scripts/mount.sh' '/etc/udev/scripts/mount.sh': No such file or directory
    [    6.674951] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
    [    6.742146] omap-aes 4b700000.aes: OMAP AES hw accel rev: 3.3
    [    6.742315] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
    [    6.742319] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
    [    6.742379] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
    [    6.767522] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
    [    6.773739] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
    [    6.778761] pinctrl-single 4a003400.pinmux: pin 4a0037d0.0 already requested by 4806a000.serial; cannot claim for 4ae3c000.can
    [    6.778768] pinctrl-single 4a003400.pinmux: pin-244 (4ae3c000.can) status -22
    [    6.778776] pinctrl-single 4a003400.pinmux: could not request pin 244 (4a0037d0.0) from group dcan1_pins_sleep  on device pinctrl-single
    [    6.778781] c_can_platform 4ae3c000.can: Error applying setting, reverse things back
    [    6.779620] c_can_platform 4ae3c000.can: c_can_platform device registered (regs=fce3c000, irq=367)
    [    6.799069] [drm] Initialized pvr 1.14.3699939 20110701 on minor 1
    [    6.864750] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
    [    6.877872] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
    [    6.889538] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
    [    6.903924] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
    [    7.052233]  remoteproc2: powering up 40800000.dsp
    [    7.062233]  remoteproc2: Booting fw image dra7-dsp1-fw.xe66, size 929770
    [    7.075814] omap_hwmod: mmu0_dsp1: _wait_target_disable failed
    [    7.081713] omap-iommu 40d01000.mmu: 40d01000.mmu: version 3.0
    [    7.087676] omap-iommu 40d02000.mmu: 40d02000.mmu: version 3.0
    [    7.150509]  remoteproc2: remote processor 40800000.dsp is now up
    [    7.157127] virtio_rpmsg_bus virtio0: rpmsg host is online
    [    7.162697] virtio_rpmsg_bus virtio0: creating channel rpmsg-client-sample addr 0x36
    [    7.170809] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
    [    7.177022] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
    [    7.183402] virtio_rpmsg_bus virtio0: creating channel rpmsg-client-sample addr 0x37
    [    7.191342] virtio_rpmsg_bus virtio0: creating channel rpmsg-rpc addr 0x3b
    [    7.191481] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
    [    7.204775]  remoteproc1: powering up 55020000.ipu
    [    7.215526]  remoteproc1: Booting fw image dra7-ipu2-fw.xem4, size 3484972
    [    7.222805] omap-iommu 55082000.mmu: 55082000.mmu: version 2.1
    [    7.289460]  remoteproc1: remote processor 55020000.ipu is now up
    [    7.296421] virtio_rpmsg_bus virtio1: rpmsg host is online
    [    7.301984] virtio_rpmsg_bus virtio1: creating channel rpmsg-rpc addr 0x3b
    [    7.309293] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
    [    7.315502] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
    [    7.330607] rpmsg_rpc rpmsg2: probing service rpmsg-dce-dsp with src 1024 dst 59
    [    7.337861] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
    [    7.338203] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
    [    7.338207] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
    [    7.338258] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
    [    7.363717] rpmsg_rpc rpmsg3: probing service rpmsg-dce with src 1024 dst 59
    [    7.363981] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
    [    7.363986] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
    [    7.364037] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
    [    7.364133] rpmsg_rpc rpmsg2: published functions = 8
    [    7.395425] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
    [    7.401975] rpmsg_rpc rpmsg3: published functions = 8
    [    7.406225] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
    [    7.406304] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
    [    7.557022] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
    [    7.557531] dwc3 48910000.usb: failed to register ULPI interface
    [    7.557561] dwc3: probe of 48910000.usb failed with error -110
    [    7.579085] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
    [    7.585405] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
    [    7.588391] usbcore: registered new interface driver usbfs
    [    7.588998] usbcore: registered new interface driver hub
    [    7.589636] usbcore: registered new device driver usb
    [    7.597673] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
    [    7.597698] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
    [    7.603740] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220f04c hci version 0x100 quirks 0x00210010
    [    7.603798] xhci-hcd xhci-hcd.0.auto: irq 445, io mem 0x48890000
    [    7.604928] hub 1-0:1.0: USB hub found
    [    7.604966] hub 1-0:1.0: 1 port detected
    [    7.605385] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
    [    7.605399] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
    [    7.605485] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
    [    7.606482] hub 2-0:1.0: USB hub found
    [    7.606518] hub 2-0:1.0: 1 port detected
    [    7.606987] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
    [    7.607011] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 3
    [    7.607421] xhci-hcd xhci-hcd.1.auto: hcc params 0x0220f04c hci version 0x100 quirks 0x00210010
    [    7.607469] xhci-hcd xhci-hcd.1.auto: irq 446, io mem 0x488d0000
    [    7.608516] hub 3-0:1.0: USB hub found
    [    7.608552] hub 3-0:1.0: 1 port detected
    [    7.608942] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
    [    7.608956] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 4
    [    7.609040] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
    [    7.610038] hub 4-0:1.0: USB hub found
    [    7.610073] hub 4-0:1.0: 1 port detected
    [    7.738006] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
    [    7.744218] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
    [    7.750564] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
    [   15.497208] ata1: softreset failed (1st FIS failed)
    [   25.507206] ata1: softreset failed (1st FIS failed)
    [   25.857213] ata1: SATA link down (SStatus 0 SControl 300)
    [   25.911882] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
    Starting Bootlog daemon: bootlogd.
    [   25.991990] random: dd: uninitialized urandom read (512 bytes read, 82 bits of entropy available)
    ALSA: Restoring mixer settings...
    No state is present for card DRA7xxEVMMCASP1
    Found hardware: "DRA7xx-EVM-MCAS" "" "" "" ""
    Hardware is initialized using a generic method
    No state is present for card DRA7xxEVMMCASP2
    No state is present for card DRA7xxEVMMCASP3
    No state is present for card DRA7xxEVMMCASP4
    No state is present for card DRA7xxEVMMCASP8
    Thu Sep  3 18:41:00 UTC 2015
    2017.11.23 15:00
    This version is for J6
    ****** This application only support ASCII code 0 to 127 ******
    ****** This application only support CB version #F ******
    [   41.433664] xhci-hcd xhci-hcd.1.auto: remove, state 4
    [   41.439692] usb usb4: USB disconnect, device number 1
    [   41.447339] xhci-hcd xhci-hcd.1.auto: USB bus 4 deregistered
    [   41.453060] xhci-hcd xhci-hcd.1.auto: remove, state 4
    [   41.458641] usb usb3: USB disconnect, device number 1
    [   41.469097] xhci-hcd xhci-hcd.1.auto: USB bus 3 deregistered
    [   41.476486] xhci-hcd xhci-hcd.0.auto: remove, state 4
    [   41.481618] usb usb2: USB disconnect, device number 1
    [   41.489682] xhci-hcd xhci-hcd.0.auto: USB bus 2 deregistered
    [   41.495391] xhci-hcd xhci-hcd.0.auto: remove, state 4
    [   41.500510] usb usb1: USB disconnect, device number 1
    [   41.508540] xhci-hcd xhci-hcd.0.auto: USB bus 1 deregistered
    [   41.627843] usbcore: deregistering device driver usb
    [   41.634408] usbcore: deregistering interface driver usbfs
    [   41.645342] usbcore: deregistering interface driver hub
    [AB_server.c, make_sure_usb_kernel_stack_removed, 374] temp: drwxr-xr-x   27 root     root             0 Jan  1  1970 .
    dr-xr-xr-x   12 root     root             0 Jan  1  1970 ..
    drwxr-xr-x    4 root     root             0 Jan  1  1970 ac97
    drwxr-xr-x    4 root     root             0 Jan  1  1970 clockevents
    drwxr-xr-x    4 root     root             0 Jan  1  1970 clocksource
    drwxr-xr-x    4 root     root             0 Jan  1  1970 container
    drwxr-xr-x    4 root     root             0 Jan  1  1970 cpu
    drwxr-xr-x    4 root     root             0 Jan  1  1970 edac
    drwxr-xr-x    4 root     root             0 Jan  1  1970 event_source
    drwxr-xr-x    4 root     root             0 Jan  1  1970 hid
    drwxr-xr-x    4 root     root             0 Jan  1  1970 i2c
    drwxr-xr-x    4 root     root             0 Jan  1  1970 iio
    drwxr-xr-x    4 root     root             0 Jan  1  1970 mdio_bus
    drwxr-xr-x    4 root     root             0 Jan  1  1970 media
    drwxr-xr-x    4 root     root             0 Jan  1  1970 mipi-dsi
    drwxr-xr-x    4 root     root             0 Jan  1  1970 mmc
    drwxr-xr-x    5 root     root             0 Jan  1  1970 pci
    drwxr-xr-x    4 root     root             0 Jan  1  1970 platform
    drwxr-xr-x    4 root     root             0 Jan  1  1970 rpmsg
    drwxr-xr-x    4 root     root             0 Jan  1  1970 scsi
    drwxr-xr-x    4 root     root             0 Jan  1  1970 sdio
    drwxr-xr-x    4 root     root             0 Jan  1  1970 serio
    drwxr-xr-x    4 root     root             0 Jan  1  1970 soc
    drwxr-xr-x    4 root     root             0 Jan  1  1970 spi
    drwxr-xr-x    4 root     root             0 Jan  1  1970 ulpi
    drwxr-xr-x    4 root     root             0 Jan  1  1970 virtio
    drwxr-xr-x    4 root     root             0 Jan  1  1970 workqueue
    [AB_server.c, AB_boot_finish, 181] AB boot success, pull high GPIO
    [AB_server.c, AB_boot_finish, 187] AB boot success, pull high GPIO finished
    [AB_server.c, get_CB_hardware_version, 212] Wait for CB send HW version
    [AB_server.c, get_CB_hardware_version, 216] Read CB HW version (0) Bytes
    /usr/local/bin/set_unused_gpio_input: line 14: echo: write error: Device or resource busy
    /usr/local/bin/set_unused_gpio_input: line 15: /sys/class/gpio/gpio161/direction: No such file or directory
    INIT: Entering runlevel: 5
    Configuring network interfaces... [   43.330140] net eth0: initializing cpsw version 1.15 (0)
    [   43.335508] net eth0: initialized cpsw ale version 1.4
    [   43.341101] net eth0: ALE Table size 1024
    [   43.348183] libphy: PHY 48485000.mdio:02 not found
    [   43.353001] net eth0: phy "48485000.mdio:02" not found on slave 0, err -19
    [   43.366926] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
    /bin/sh: udhcpc: command not found
    done.
    Starting system message bus: [   43.423376] random: dbus-daemon: uninitialized urandom read (12 bytes read, 106 bits of entropy available)
    [   43.439586] random: dbus-daemon: uninitialized urandom read (12 bytes read, 106 bits of entropy available)
    dbus.
    [AB_server.c, get_CB_hardware_version, 216] Read CB HW version (4) Bytes
    _version[0]: 30
    _version[1]: 31
    _version[2]: 31
    _version[3]: 30
    _version[4]: 0
    _version[5]: 0
    _version[6]: 0
    _version[7]: 0
    _version[8]: 0
    _version[9]: 0
    _version[10]: 0
    _version[11]: 0
    _version[12]: 0
    _version[13]: 0
    _version[14]: 0
    _version[15]: 0
    [AB_server.c, main, 517] AB_server: get CB's HW version 0110
    [AB_server.c, get_CB_hardware_version_finish, 254] AB get CB hw version finish, gpio pull low
    [AB_server.c, send_AB_model_info_to_CB, 279] write AB model info total (6) Bytes, model: (DRA74X
    [AB_server.c, sync_CB_status, 308] ______ AB GPIO 109 status: 0
     ______
    [AB_server.c, sync_CB_status, 317] ______ AB GPIO 109 LOW, AB booting ______
     ______
    UIM SYSFS Node Not Found
    Starting telnet daemon.
    Starting tiipclad daemon[AB_server.c, sync_CB_status, 308] ______ AB GPIO 109 status: 1
     ______
    [AB_server.c, sync_CB_status, 312] ______ AB GPIO 109 1, can go ______
    GateMP support enabled on host
    Opened log file: lad.txt
    numProcessors = 5 id = 0 baseId = 0
    Spawned daemon: /usr/bin/lad_dra7xx
    Starting rpcbind daemon...done.
    creating NFS state directory: done
    starting statd: done
    NFS daemon support not enabled in kernel
    Starting syslogd/klogd: done
    Starting thttpd.
    Enabling thermal zones...
    Stopping Bootlog daemon: bootlogd.
    root@wnc-j6:~# [AB_server.c, main, 550] ulpi on/off : J6, ULPI test on
    cat /sys/kernel/debug/mmc0/i[   54.779077] random: nonblocking pool is initialized
    os
    clock:          52000000 Hz
    vdd:            7 (1.65 - 1.95 V)
    bus mode:       2 (push-pull)
    chip select:    0 (don't care)
    power mode:     2 (on)
    bus width:      2 (4 bits)
    timing spec:    1 (mmc high-speed)
    signal voltage: 0 (1.80 V)
    driver type:    0 (driver type B)
    root@wnc-j6:~# lsblk
    NAME         MAJ:MIN RM  SIZE RO TYPE MOUNTPOINT
    mmcblk0boot0 179:16   0  128K  1 disk
    mmcblk0boot1 179:32   0  128K  1 disk
    mmcblk1boot0 179:64   0  128K  1 disk
    mmcblk1boot1 179:80   0  128K  1 disk
    mmcblk0      179:0    0  7.3G  0 disk
    `-mmcblk0p1  179:1    0  7.3G  0 part
    mmcblk1      179:48   0  7.3G  0 disk
    |-mmcblk1p1  179:49   0   64M  0 part
    `-mmcblk1p2  179:50   0  7.2G  0 part /
    mmcblk2      179:96   0  3.7G  0 disk
    |-mmcblk2p1  179:97   0   62M  0 part
    `-mmcblk2p2  179:98   0  3.6G  0 part
    root@wnc-j6:~#
    3. I cat /sys/kernel/debug/mmc0/ios to confirm whether MMC0 is running HS. Yes, HW detect the voltage is 1.8v.
    4. The boot log of DateCode2244/2245 booting with error message(sometime panic) at 3.3V:
    U-Boot SPL 2016.05 (Nov 24 2017 - 15:38:03)
    DRA752-GP ES2.0
    *** Warning - bad CRC, using default environment
    Trying to boot from MMC2_2
    spl: falcon_args_file not set in environment, falling back to default
    reading args
    spl_load_image_fat_os: error reading image args, err - -1
    reading u-boot.img
    reading u-boot.img
    U-Boot 2016.05 (Nov 24 2017 - 15:38:03 +0800)
    CPU  : DRA752-GP ES2.0
    Board: DRA74x EVM REV
    I2C:   ready
    DRAM:  2 GiB
    MMC:   OMAP SD/MMC: 0, OMAP SD/MMC: 1
    Warning: fastboot.board_rev: unknown board revision
    GUID Partition Table Header signature is wrong: 0x0 != 0x5452415020494645
    part_get_info_efi: *** ERROR: Invalid GPT ***
    part_get_info_efi: *** ERROR: Invalid Backup GPT ***
    ERROR: cannot find partition: 'userdata'
    at arch/arm/cpu/armv7/omap-common/utils.c:195/mmc_get_part_size()
    Warning: fastboot.userdata_size: unable to calc
    Net:   <ethaddr> not set. Validating first E-fuse MAC
    Could not get PHY for cpsw: addr 2
    cpsw
    Hit any key to stop autoboot:  0
    J6 ...
    switch to partitions #0, OK
    mmc1(part 0) is current device
    SD/MMC found on device 1
    4281344 bytes read in 214 ms (19.1 MiB/s)
    113603 bytes read in 12 ms (9 MiB/s)
    Booting from mmc1 ...
       Loading Device Tree to 8ffe1000, end 8ffffbc2 ... OK
    Starting kernel ...
    [    0.000000] Booting Linux on physical CPU 0x0
    [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
    [    0.000000] Machine model: TI DRA742 Bowei 20170929 17:30
    [    0.000000] Memory policy: Data cache writealloc
    [    0.000000] DRA752 ES2.0
    [    0.000000] Kernel command line: console=ttyO2,115200n8 root=PARTUUID=bddb4f41-02 rw rootfstype=ext4 rootwait consoleblank=0 omapdrm.num_crtc=2 drm.debug=0xff
    [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
    [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
    [    0.000000] Virtual kernel memory layout:
    [    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    [    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
    [    0.000000]     vmalloc : 0xf0800000 - 0xff800000   ( 240 MB)
    [    0.000000]     lowmem  : 0xc0000000 - 0xf0000000   ( 768 MB)
    [    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
    [    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
    [    0.000000] OMAP clockevent source: timer1 at 31475 Hz
    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x15c70fb29, max_idle_ns: 440795202138 ns
    [    0.000327] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns
    [    0.000334] OMAP clocksource: 32k_counter at 32768 Hz
    [    0.000788] Console: colour dummy device 80x30
    [    0.000805] WARNING: Your 'console=ttyO2' has been replaced by 'ttyS2'
    [    0.000811] This ensures that you still see kernel messages. Please
    [    0.000817] update your kernel commandline.
    [    0.000829] Calibrating delay loop (skipped), value calculated using timer frequency.. 11.80 BogoMIPS (lpj=59016)
    [    0.000843] pid_max: default: 32768 minimum: 301
    [    0.001476] Initializing cgroup subsys io
    [    0.001493] Initializing cgroup subsys memory
    [    0.001517] Initializing cgroup subsys devices
    [    0.001529] Initializing cgroup subsys freezer
    [    0.001540] Initializing cgroup subsys perf_event
    [    0.001551] Initializing cgroup subsys pids
    [    0.001579] CPU: Testing write buffer coherency: ok
    [    0.001775] /cpus/cpu@0 missing clock-frequency property
    [    0.001790] /cpus/cpu@1 missing clock-frequency property
    [    0.001800] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
    [    0.001840] Setting up static identity map for 0x80008340 - 0x800083a0
    [    0.080064] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
    [    0.080135] Brought up 2 CPUs
    [    0.080149] SMP: Total of 2 processors activated (23.60 BogoMIPS).
    [    0.080156] CPU: All CPU(s) started in SVC mode.
    [    0.081192] devtmpfs: initialized
    [    0.111040] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
    [    0.112025] omap_hwmod: l3_main_2 using broken dt data from ocp
    [    0.310748] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
    [    0.314458] pinctrl core: initialized pinctrl subsystem
    [    0.315315] NET: Registered protocol family 16
    [    0.316248] DMA: preallocated 256 KiB pool for atomic coherent allocations
    [    0.340278] cpuidle: using governor ladder
    [    0.370303] cpuidle: using governor menu
    [    0.378533] OMAP GPIO hardware version 0.1
    [    0.382634] GPIO line 161 (radio_rst) hogged as output/low
    [    0.414523] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
    [    0.414534] hw-breakpoint: maximum watchpoint size is 8 bytes.
    [    0.415009] omap4_sram_init:Unable to allocate sram needed to handle errata I688
    [    0.415018] omap4_sram_init:Unable to get sram pool needed to handle errata I688
    [    0.415505] OMAP DMA hardware revision 0.0
    [    0.461690] omap-dma-engine 4a056000.dma-controller: OMAP DMA engine driver (LinkedList1/2/3 supported)
    [    0.462936] edma 43300000.edma: memcpy is disabled
    [    0.467692] edma 43300000.edma: TI EDMA DMA engine driver
    [    0.471903] omap-iommu 40d01000.mmu: 40d01000.mmu registered
    [    0.472083] omap-iommu 40d02000.mmu: 40d02000.mmu registered
    [    0.472245] omap-iommu 58882000.mmu: 58882000.mmu registered
    [    0.472403] omap-iommu 55082000.mmu: 55082000.mmu registered
    [    0.472703] omap-iommu 41501000.mmu: 41501000.mmu registered
    [    0.472889] omap-iommu 41502000.mmu: 41502000.mmu registered
    [    0.474884] SCSI subsystem initialized
    [    0.476142] ======palmas_i2c_probe:526========
    [    0.476159] ======palmas_i2c_probe:559, features=0x0========
    [    0.476464] palmas 0-0058: IRQ missing: skipping irq request
    [    0.491206] palmas 0-0058: Muxing GPIO a, PWM 0, LED 0
    [    0.562945] omap_i2c 48070000.i2c: bus 0 rev0.12 at 400 kHz
    [    0.563584] omap_i2c 48072000.i2c: bus 1 rev0.12 at 400 kHz
    [    0.563950] omap_i2c 48060000.i2c: bus 2 rev0.12 at 400 kHz
    [    0.564309] omap_i2c 4807a000.i2c: bus 3 rev0.12 at 400 kHz
    [    0.564683] omap_i2c 4807c000.i2c: bus 4 rev0.12 at 400 kHz
    [    0.564902] media: Linux media interface: v0.10
    [    0.564958] Linux video capture interface: v2.00
    [    0.564997] pps_core: LinuxPPS API ver. 1 registered
    [    0.565003] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.565026] PTP clock support registered
    [    0.565051] EDAC MC: Ver: 3.0.0
    [    0.565807] omap-mailbox 48840000.mailbox: omap mailbox rev 0x400
    [    0.566099] omap-mailbox 48842000.mailbox: omap mailbox rev 0x400
    [    0.566445] Advanced Linux Sound Architecture Driver Initialized.
    [    0.567340] clocksource: Switched to clocksource arch_sys_counter
    [    0.578102] NET: Registered protocol family 2
    [    0.578596] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
    [    0.578659] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
    [    0.578784] TCP: Hash tables configured (established 8192 bind 8192)
    [    0.578830] UDP hash table entries: 512 (order: 2, 16384 bytes)
    [    0.578863] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
    [    0.579072] NET: Registered protocol family 1
    [    0.579335] RPC: Registered named UNIX socket transport module.
    [    0.579345] RPC: Registered udp transport module.
    [    0.579351] RPC: Registered tcp transport module.
    [    0.579357] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.580397] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
    [    0.582846] futex hash table entries: 512 (order: 3, 32768 bytes)
    [    0.589537] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.590190] NFS: Registering the id_resolver key type
    [    0.590215] Key type id_resolver registered
    [    0.590222] Key type id_legacy registered
    [    0.590288] ntfs: driver 2.1.32 [Flags: R/O].
    [    0.592263] bounce: pool size: 64 pages
    [    0.592414] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
    [    0.592431] io scheduler noop registered
    [    0.592446] io scheduler deadline registered
    [    0.592480] io scheduler cfq registered (default)
    [    0.597800] pinctrl-single 4a003400.pinmux: 282 pins at pa fc003400 size 1128
    [    0.659406] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
    [    0.663036] 4806a000.serial: ttyS0 at MMIO 0x4806a000 (irq = 299, base_baud = 3000000) is a 8250
    [    0.663917] 4806c000.serial: ttyS1 at MMIO 0x4806c000 (irq = 300, base_baud = 3000000) is a 8250
    [    0.664793] console [ttyS2] disabled
    [    0.664838] 48020000.serial: ttyS2 at MMIO 0x48020000 (irq = 301, base_baud = 3000000) is a 8250
    [    1.551629] console [ttyS2] enabled
    [    1.556023] 48066000.serial: ttyS4 at MMIO 0x48066000 (irq = 302, base_baud = 3000000) is a 8250
    [    1.565752] 48068000.serial: ttyS5 at MMIO 0x48068000 (irq = 303, base_baud = 3000000) is a 8250
    [    1.575435] 48424000.serial: ttyS8 at MMIO 0x48424000 (irq = 304, base_baud = 3000000) is a 8250
    [    1.585126] 4ae2b000.serial: ttyS9 at MMIO 0x4ae2b000 (irq = 305, base_baud = 3000000) is a 8250
    [    1.595260] [drm] Initialized drm 1.1.0 20060810
    [    1.601467] OMAP DSS rev 6.1
    [    1.605234] omapdss_dss 58000000.dss: bound 58001000.dispc (ops dispc_component_ops)
    [    1.627032] brd: module loaded
    [    1.635266] loop: module loaded
    [    1.644960] libphy: Fixed MDIO Bus: probed
    [    1.649677] e1000: Intel(R) PRO/1000 Network Driver - version 7.3.21-k8-NAPI
    [    1.656757] e1000: Copyright (c) 1999-2006 Intel Corporation.
    [    1.662607] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
    [    1.668478] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
    [    1.674482] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.3.0-k
    [    1.681487] igb: Copyright (c) 2007-2014 Intel Corporation.
    [    1.737371] davinci_mdio 48485000.mdio: davinci mdio revision 1.6
    [    1.743494] davinci_mdio 48485000.mdio: no live phy, scanning all
    [    1.847341] davinci_mdio 48485000.mdio: timed out waiting for user access
    [    1.947340] davinci_mdio 48485000.mdio: timed out waiting for idle
    [    1.953568] davinci_mdio: probe of 48485000.mdio failed with error -5
    [    1.960699] cpsw 48484000.ethernet: Detected MACID = 54:45:38:a7:aa:1e
    [    1.967378] cpsw 48484000.ethernet: cpts: overflow check period 800
    [    1.974347] cpsw 48484000.ethernet: cpsw: Detected MACID = 54:45:38:a7:aa:1f
    [    1.983056] mousedev: PS/2 mouse device common for all mice
    [    1.989285] i2c /dev entries driver
    [    2.007430] tvp5158 1-0058: i2c i/o error: rc == -121 (should be 1)
    [    2.013786] tvp5158 1-0058: i2c i/o error: rc == -121 (should be 1)
    [    2.020121] tvp5158 1-0058: ERROR: Chip id is not TVP5158
    [    2.025658] ov1063x 1-0037: ov1063x Product ID 0 Manufacturer ID 0
    [    2.031886] ov1063x 1-0037: ov1063x 1-0037 sensor driver registered !!
    [    2.039301] vpe 489d0000.vpe: loading firmware vpdma-1b8.bin
    [    2.046394] vip 48990000.vip: loading firmware vpdma-1b8.bin
    [    2.057521] vpe 489d0000.vpe: Device registered as /dev/video0
    [    2.067361] vip 48990000.vip: VPDMA firmware loaded
    [    2.072390] vip2-s1: Port B: Using subdev ov1063x 1-0037 for capture
    [    2.079183] vip2-s1: device registered as video1
    [    2.097763] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr25 mode
    [    2.104148] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr12 mode
    [    2.110574] omap_hsmmc 480b4000.mmc: no pinctrl state for hs200_1_8v mode
    [    2.117541] evm_3v3_sw: supplied by sysen1
    [    2.157699] omap_hsmmc 480d1000.mmc: no pinctrl state for sdr25 mode
    [    2.164084] omap_hsmmc 480d1000.mmc: no pinctrl state for sdr12 mode
    [    2.170479] omap_hsmmc 480d1000.mmc: no pinctrl state for hs mode
    [    2.208149] ledtrig-cpu: registered to indicate activity on CPUs
    [    2.216249] hwspinlock_user gatemp: requested 10 hwspinlocks
    [    2.237270] pinctrl-single 4a003400.pinmux: pin 4a0036a8.0 already requested by 4806a000.serial; cannot claim for 48460000.mcasp
    [    2.248934] pinctrl-single 4a003400.pinmux: pin-170 (48460000.mcasp) status -22
    [    2.256278] pinctrl-single 4a003400.pinmux: could not request pin 170 (4a0036a8.0) from group mcasp1_pins  on device pinctrl-single
    [    2.268211] davinci-mcasp 48460000.mcasp: Error applying setting, reverse things back
    [    2.276484] davinci-mcasp 48460000.mcasp: Update the bindings to use assigned-clocks!
    [    2.284391] davinci-mcasp 48460000.mcasp: failed to reparent fck
    [    2.290676] pinctrl-single 4a003400.pinmux: pin 4a003700.0 already requested by 4806a000.serial; cannot claim for 48464000.mcasp
    [    2.302305] pinctrl-single 4a003400.pinmux: pin-192 (48464000.mcasp) status -22
    [    2.309687] pinctrl-single 4a003400.pinmux: could not request pin 192 (4a003700.0) from group mcasp2_pins  on device pinctrl-single
    [    2.321575] davinci-mcasp 48464000.mcasp: Error applying setting, reverse things back
    [    2.329828] davinci-mcasp 48464000.mcasp: Update the bindings to use assigned-clocks!
    [    2.337725] davinci-mcasp 48464000.mcasp: failed to reparent fck
    [    2.343977] pinctrl-single 4a003400.pinmux: pin 4a00372c.0 already requested by 4806a000.serial; cannot claim for 48468000.mcasp
    [    2.355607] pinctrl-single 4a003400.pinmux: pin-203 (48468000.mcasp) status -22
    [    2.362959] pinctrl-single 4a003400.pinmux: could not request pin 203 (4a00372c.0) from group mcasp3_pins  on device pinctrl-single
    [    2.374844] davinci-mcasp 48468000.mcasp: Error applying setting, reverse things back
    [    2.383085] davinci-mcasp 48468000.mcasp: Update the bindings to use assigned-clocks!
    [    2.390983] davinci-mcasp 48468000.mcasp: failed to reparent fck
    [    2.397236] pinctrl-single 4a003400.pinmux: pin 4a003734.0 already requested by 4806a000.serial; cannot claim for 4846c000.mcasp
    [    2.408870] pinctrl-single 4a003400.pinmux: pin-205 (4846c000.mcasp) status -22
    [    2.416213] pinctrl-single 4a003400.pinmux: could not request pin 205 (4a003734.0) from group mcasp4_pins  on device pinctrl-single
    [    2.428097] davinci-mcasp 4846c000.mcasp: Error applying setting, reverse things back
    [    2.436336] davinci-mcasp 4846c000.mcasp: Update the bindings to use assigned-clocks!
    [    2.444233] davinci-mcasp 4846c000.mcasp: failed to reparent fck
    [    2.450499] pinctrl-single 4a003400.pinmux: pin 4a003720.0 already requested by 4806a000.serial; cannot claim for 4847c000.mcasp
    [    2.462128] pinctrl-single 4a003400.pinmux: pin-200 (4847c000.mcasp) status -22
    [    2.469480] pinctrl-single 4a003400.pinmux: could not request pin 200 (4a003720.0) from group mcasp8_pins  on device pinctrl-single
    [    2.481364] davinci-mcasp 4847c000.mcasp: Error applying setting, reverse things back
    [    2.489611] davinci-mcasp 4847c000.mcasp: Update the bindings to use assigned-clocks!
    [    2.497508] davinci-mcasp 4847c000.mcasp: failed to reparent fck
    [    2.504692] NET: Registered protocol family 10
    [    2.519972] sit: IPv6 over IPv4 tunneling driver
    [    2.525148] NET: Registered protocol family 17
    [    2.529873] Key type dns_resolver registered
    [    2.534292] omap_voltage_late_init: Voltage driver support not added
    [    2.541209] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
    [    2.548563] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
    [    2.554817] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
    [    2.561455] Power Management for TI OMAP4+ devices.
    [    2.566591] Registering SWP/SWPB emulation handler
    [    2.574136] dmm 4e000000.dmm: initialized all PAT entries
    [    2.601001] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
    [    2.607679] [drm] No driver support for vblank timestamp query.
    [    2.624846] [drm] Enabling DMM ywrap scrolling
    [    2.680497] mmc0: MAN_BKOPS_EN bit is not set
    [    2.682910] mmc0: switch to bus width 1 failed
    [    2.699844] Console: switching to colour frame buffer device 240x67
    [    2.729767] omapdrm omapdrm.0: fb0: omapdrm frame buffer device
    [    2.745328] mmc0: new high speed MMC card at address 0001
    [    2.761270] mmcblk0: mmc0:0001 R1J55A 7.28 GiB
    [    2.768647] [drm] Initialized omapdrm 1.0.0 20110917 on minor 0
    [    2.776079] mmcblk0boot0: mmc0:0001 R1J55A partition 1 128 KiB
    [    2.782184] mmcblk0boot1: mmc0:0001 R1J55A partition 2 128 KiB
    [    2.789519] asoc-simple-card-mcasp1 sound@1: bt-sco-pcm-mcasp1 <-> 48460000.mcasp mapping ok
    [    2.798021] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    2.807739] asoc-simple-card-mcasp1 sound@1: ASoC: no source widget found for HPLOUT
    [    2.817587] mmcblk0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    2.827021] mmcblk0: retrying using single block read
    [    2.832138] asoc-simple-card-mcasp1 sound@1: ASoC: Failed to add route HPLOUT -> direct -> Headphone Jack
    [    2.841761] asoc-simple-card-mcasp1 sound@1: ASoC: no source widget found for HPROUT
    [    2.849575] asoc-simple-card-mcasp1 sound@1: ASoC: Failed to add route HPROUT -> direct -> Headphone Jack
    [    2.859358] mmcblk0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    2.868642] blk_update_request: I/O error, dev mmcblk0, sector 0
    [    2.868655] asoc-simple-card-mcasp1 sound@1: ASoC: no source widget found for LLOUT
    [    2.868662] asoc-simple-card-mcasp1 sound@1: ASoC: Failed to add route LLOUT -> direct -> Line Out
    [    2.868667] asoc-simple-card-mcasp1 sound@1: ASoC: no source widget found for RLOUT
    [    2.868672] asoc-simple-card-mcasp1 sound@1: ASoC: Failed to add route RLOUT -> direct -> Line Out
    [    2.868677] asoc-simple-card-mcasp1 sound@1: ASoC: no sink widget found for MIC3L
    [    2.868682] asoc-simple-card-mcasp1 sound@1: ASoC: Failed to add route Mic Jack -> direct -> MIC3L
    [    2.868687] asoc-simple-card-mcasp1 sound@1: ASoC: no sink widget found for MIC3R
    [    2.868692] asoc-simple-card-mcasp1 sound@1: ASoC: Failed to add route Mic Jack -> direct -> MIC3R
    [    2.868697] asoc-simple-card-mcasp1 sound@1: ASoC: no source widget found for Mic Bias
    [    2.868701] asoc-simple-card-mcasp1 sound@1: ASoC: Failed to add route Mic Bias -> direct -> Mic Jack
    [    2.868707] asoc-simple-card-mcasp1 sound@1: ASoC: no sink widget found for LINE1L
    [    2.868712] asoc-simple-card-mcasp1 sound@1: ASoC: Failed to add route Line In -> direct -> LINE1L
    [    2.868717] asoc-simple-card-mcasp1 sound@1: ASoC: no sink widget found for LINE1R
    [    2.868722] asoc-simple-card-mcasp1 sound@1: ASoC: Failed to add route Line In -> direct -> LINE1R
    [    2.880987] asoc-simple-card-mcasp2 sound@2: bt-sco-pcm-mcasp2 <-> 48464000.mcasp mapping ok
    [    2.880996] asoc-simple-card-mcasp2 sound@2: ASoC: no source widget found for HPLOUT
    [    2.881001] asoc-simple-card-mcasp2 sound@2: ASoC: Failed to add route HPLOUT -> direct -> Headphone Jack
    [    2.881006] asoc-simple-card-mcasp2 sound@2: ASoC: no source widget found for HPROUT
    [    2.881011] asoc-simple-card-mcasp2 sound@2: ASoC: Failed to add route HPROUT -> direct -> Headphone Jack
    [    2.881016] asoc-simple-card-mcasp2 sound@2: ASoC: no source widget found for LLOUT
    [    2.881022] asoc-simple-card-mcasp2 sound@2: ASoC: Failed to add route LLOUT -> direct -> Line Out
    [    2.881028] asoc-simple-card-mcasp2 sound@2: ASoC: no source widget found for RLOUT
    [    2.881033] asoc-simple-card-mcasp2 sound@2: ASoC: Failed to add route RLOUT -> direct -> Line Out
    [    2.881038] asoc-simple-card-mcasp2 sound@2: ASoC: no sink widget found for MIC3L
    [    2.881043] asoc-simple-card-mcasp2 sound@2: ASoC: Failed to add route Mic Jack -> direct -> MIC3L
    [    2.881048] asoc-simple-card-mcasp2 sound@2: ASoC: no sink widget found for MIC3R
    [    2.881053] asoc-simple-card-mcasp2 sound@2: ASoC: Failed to add route Mic Jack -> direct -> MIC3R
    [    2.881058] asoc-simple-card-mcasp2 sound@2: ASoC: no source widget found for Mic Bias
    [    2.881063] asoc-simple-card-mcasp2 sound@2: ASoC: Failed to add route Mic Bias -> direct -> Mic Jack
    [    2.881068] asoc-simple-card-mcasp2 sound@2: ASoC: no sink widget found for LINE1L
    [    2.881073] asoc-simple-card-mcasp2 sound@2: ASoC: Failed to add route Line In -> direct -> LINE1L
    [    2.881077] asoc-simple-card-mcasp2 sound@2: ASoC: no sink widget found for LINE1R
    [    2.881082] asoc-simple-card-mcasp2 sound@2: ASoC: Failed to add route Line In -> direct -> LINE1R
    [    2.883098] asoc-simple-card-mcasp3 sound@3: bt-sco-pcm-mcasp3 <-> 48468000.mcasp mapping ok
    [    2.883107] asoc-simple-card-mcasp3 sound@3: ASoC: no source widget found for HPLOUT
    [    2.883112] asoc-simple-card-mcasp3 sound@3: ASoC: Failed to add route HPLOUT -> direct -> Headphone Jack
    [    2.883118] asoc-simple-card-mcasp3 sound@3: ASoC: no source widget found for HPROUT
    [    2.883122] asoc-simple-card-mcasp3 sound@3: ASoC: Failed to add route HPROUT -> direct -> Headphone Jack
    [    2.883127] asoc-simple-card-mcasp3 sound@3: ASoC: no source widget found for LLOUT
    [    2.883132] asoc-simple-card-mcasp3 sound@3: ASoC: Failed to add route LLOUT -> direct -> Line Out
    [    2.883138] asoc-simple-card-mcasp3 sound@3: ASoC: no source widget found for RLOUT
    [    2.883143] asoc-simple-card-mcasp3 sound@3: ASoC: Failed to add route RLOUT -> direct -> Line Out
    [    2.883148] asoc-simple-card-mcasp3 sound@3: ASoC: no sink widget found for MIC3L
    [    2.883153] asoc-simple-card-mcasp3 sound@3: ASoC: Failed to add route Mic Jack -> direct -> MIC3L
    [    2.883158] asoc-simple-card-mcasp3 sound@3: ASoC: no sink widget found for MIC3R
    [    2.883162] asoc-simple-card-mcasp3 sound@3: ASoC: Failed to add route Mic Jack -> direct -> MIC3R
    [    2.883167] asoc-simple-card-mcasp3 sound@3: ASoC: no source widget found for Mic Bias
    [    2.883172] asoc-simple-card-mcasp3 sound@3: ASoC: Failed to add route Mic Bias -> direct -> Mic Jack
    [    2.883177] asoc-simple-card-mcasp3 sound@3: ASoC: no sink widget found for LINE1L
    [    2.883182] asoc-simple-card-mcasp3 sound@3: ASoC: Failed to add route Line In -> direct -> LINE1L
    [    2.883187] asoc-simple-card-mcasp3 sound@3: ASoC: no sink widget found for LINE1R
    [    2.883191] asoc-simple-card-mcasp3 sound@3: ASoC: Failed to add route Line In -> direct -> LINE1R
    [    2.885254] asoc-simple-card-mcasp4 sound@4: bt-sco-pcm-mcasp4 <-> 4846c000.mcasp mapping ok
    [    2.885262] asoc-simple-card-mcasp4 sound@4: ASoC: no source widget found for HPLOUT
    [    2.885268] asoc-simple-card-mcasp4 sound@4: ASoC: Failed to add route HPLOUT -> direct -> Headphone Jack
    [    2.885273] asoc-simple-card-mcasp4 sound@4: ASoC: no source widget found for HPROUT
    [    2.885279] asoc-simple-card-mcasp4 sound@4: ASoC: Failed to add route HPROUT -> direct -> Headphone Jack
    [    2.885284] asoc-simple-card-mcasp4 sound@4: ASoC: no source widget found for LLOUT
    [    2.885290] asoc-simple-card-mcasp4 sound@4: ASoC: Failed to add route LLOUT -> direct -> Line Out
    [    2.885295] asoc-simple-card-mcasp4 sound@4: ASoC: no source widget found for RLOUT
    [    2.885300] asoc-simple-card-mcasp4 sound@4: ASoC: Failed to add route RLOUT -> direct -> Line Out
    [    2.885305] asoc-simple-card-mcasp4 sound@4: ASoC: no sink widget found for MIC3L
    [    2.885310] asoc-simple-card-mcasp4 sound@4: ASoC: Failed to add route Mic Jack -> direct -> MIC3L
    [    2.885314] asoc-simple-card-mcasp4 sound@4: ASoC: no sink widget found for MIC3R
    [    2.885319] asoc-simple-card-mcasp4 sound@4: ASoC: Failed to add route Mic Jack -> direct -> MIC3R
    [    2.885324] asoc-simple-card-mcasp4 sound@4: ASoC: no source widget found for Mic Bias
    [    2.885328] asoc-simple-card-mcasp4 sound@4: ASoC: Failed to add route Mic Bias -> direct -> Mic Jack
    [    2.885334] asoc-simple-card-mcasp4 sound@4: ASoC: no sink widget found for LINE1L
    [    2.885339] asoc-simple-card-mcasp4 sound@4: ASoC: Failed to add route Line In -> direct -> LINE1L
    [    2.885344] asoc-simple-card-mcasp4 sound@4: ASoC: no sink widget found for LINE1R
    [    2.885349] asoc-simple-card-mcasp4 sound@4: ASoC: Failed to add route Line In -> direct -> LINE1R
    [    2.887766] asoc-simple-card-mcasp8 sound@8: bt-sco-pcm-mcasp8 <-> 4847c000.mcasp mapping ok
    [    2.887775] asoc-simple-card-mcasp8 sound@8: ASoC: no source widget found for HPLOUT
    [    2.887780] asoc-simple-card-mcasp8 sound@8: ASoC: Failed to add route HPLOUT -> direct -> Headphone Jack
    [    2.887786] asoc-simple-card-mcasp8 sound@8: ASoC: no source widget found for HPROUT
    [    2.887791] asoc-simple-card-mcasp8 sound@8: ASoC: Failed to add route HPROUT -> direct -> Headphone Jack
    [    2.887796] asoc-simple-card-mcasp8 sound@8: ASoC: no source widget found for LLOUT
    [    2.887801] asoc-simple-card-mcasp8 sound@8: ASoC: Failed to add route LLOUT -> direct -> Line Out
    [    2.887806] asoc-simple-card-mcasp8 sound@8: ASoC: no source widget found for RLOUT
    [    2.887811] asoc-simple-card-mcasp8 sound@8: ASoC: Failed to add route RLOUT -> direct -> Line Out
    [    2.887816] asoc-simple-card-mcasp8 sound@8: ASoC: no sink widget found for MIC3L
    [    2.887820] asoc-simple-card-mcasp8 sound@8: ASoC: Failed to add route Mic Jack -> direct -> MIC3L
    [    2.887825] asoc-simple-card-mcasp8 sound@8: ASoC: no sink widget found for MIC3R
    [    2.887829] asoc-simple-card-mcasp8 sound@8: ASoC: Failed to add route Mic Jack -> direct -> MIC3R
    [    2.887834] asoc-simple-card-mcasp8 sound@8: ASoC: no source widget found for Mic Bias
    [    2.887839] asoc-simple-card-mcasp8 sound@8: ASoC: Failed to add route Mic Bias -> direct -> Mic Jack
    [    2.887844] asoc-simple-card-mcasp8 sound@8: ASoC: no sink widget found for LINE1L
    [    2.887848] asoc-simple-card-mcasp8 sound@8: ASoC: Failed to add route Line In -> direct -> LINE1L
    [    2.887853] asoc-simple-card-mcasp8 sound@8: ASoC: no sink widget found for LINE1R
    [    2.887858] asoc-simple-card-mcasp8 sound@8: ASoC: Failed to add route Line In -> direct -> LINE1R
    [    2.888877] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
    [    2.888880] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
    [    2.888940] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
    [    2.898610] hctosys: unable to open rtc device (rtc0)
    [    2.913245] aic_dvdd: disabling
    [    2.932189] ldousb: disabling
    [    2.982904] ALSA device list:
    [    2.982908]   #0: DRA7xx-EVM-MCASP1
    [    2.982911]   #1: DRA7xx-EVM-MCASP2
    [    2.982913]   #2: DRA7xx-EVM-MCASP3
    [    2.982916]   #3: DRA7xx-EVM-MCASP4
    [    2.982918]   #4: DRA7xx-EVM-MCASP8
    [    3.686889] mmcblk0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    3.696185] blk_update_request: I/O error, dev mmcblk0, sector 1
    [    3.702414] mmcblk0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    3.711698] blk_update_request: I/O error, dev mmcblk0, sector 2
    [    3.717930] mmcblk0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    3.727190] blk_update_request: I/O error, dev mmcblk0, sector 3
    [    3.733426] mmcblk0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    3.742704] blk_update_request: I/O error, dev mmcblk0, sector 4
    [    3.748936] mmcblk0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    3.758212] blk_update_request: I/O error, dev mmcblk0, sector 5
    [    3.764427] mmcblk0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    3.773700] blk_update_request: I/O error, dev mmcblk0, sector 6
    [    3.779925] mmcblk0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    3.789201] blk_update_request: I/O error, dev mmcblk0, sector 7
    [    3.795236] Buffer I/O error on dev mmcblk0, logical block 0, async page read
    [    3.802602] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    3.811756] mmcblk0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    3.821206] mmcblk0: retrying using single block read
    [    3.826458] mmcblk0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    3.835732] blk_update_request: I/O error, dev mmcblk0, sector 0
    [    3.841953] mmcblk0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    3.851230] blk_update_request: I/O error, dev mmcblk0, sector 1
    [    3.857446] mmcblk0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    3.866885] mmcblk0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    3.876337] mmcblk0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    3.885797] mmcblk0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    3.895249] mmcblk0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    3.904704] mmcblk0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    3.913983] Buffer I/O error on dev mmcblk0, logical block 0, async page read
    [    3.921172]  mmcblk0: unable to read partition table
    [    3.927519] Waiting for root device PARTUUID=bddb4f41-02...
    [    3.927595] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
    [    3.927599] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
    [    3.927652] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
    [    3.990491] mmc1: MAN_BKOPS_EN bit is not set
    [    4.099283] mmc1: new DDR MMC card at address 0001
    [    4.104543] mmcblk1: mmc1:0001 R1J55A 7.28 GiB
    [    4.119371] mmcblk1boot0: mmc1:0001 R1J55A partition 1 128 KiB
    [    4.135483] mmcblk1boot1: mmc1:0001 R1J55A partition 2 128 KiB
    [    4.142371]  mmcblk1: p1 p2
    [    4.146693] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
    [    4.153034] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
    [    4.159341] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
    [    4.197251] EXT4-fs (mmcblk1p2): recovery complete
    [    4.202499] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
    [    4.210690] VFS: Mounted root (ext4 filesystem) on device 179:50.
    [    4.218233] devtmpfs: mounted
    [    4.221434] Freeing unused kernel memory: 372K (c0c07000 - c0c64000)
    [    4.227856] This architecture does not have kernel memory protection.
    [    4.241563] mmc2: host does not support reading read-only switch, assuming write-enable
    [    4.249694] mmc2: new SDHC card at address 0001
    [    4.254638] mmcblk2: mmc2:0001 SD4GB 3.64 GiB
    [    4.260955]  mmcblk2: p1 p2
    [    4.264566] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
    [    4.270865] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
    [    4.270929] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
    Starting udev
    [    4.552320] udevd[129]: starting version 182
    [    4.731554] omap-rproc 58820000.ipu: assigned reserved memory node ipu1_cma@9d000000
    [    4.857486]  remoteproc0: 58820000.ipu is available
    [    4.862418]  remoteproc0: Note: remoteproc is still under development and considered experimental.
    [    5.037117]  remoteproc0: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
    [    5.201575]  remoteproc0: Direct firmware load for dra7-ipu1-fw.xem4 failed with error -2
    [    5.207640] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
    [    5.207645] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
    [    5.207709] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
    [    5.229078] omap-rproc 55020000.ipu: assigned reserved memory node ipu2_cma@95800000
    [    5.337466]  remoteproc1: 55020000.ipu is available
    [    5.342383]  remoteproc1: Note: remoteproc is still under development and considered experimental.
    [    5.489896]  remoteproc0: failed to load dra7-ipu1-fw.xem4
    [    5.500558]  remoteproc1: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
    [    5.583597] omap-rproc 40800000.dsp: assigned reserved memory node dsp1_cma@99000000
    [    5.583681] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
    [    5.583686] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
    [    5.583748] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
    [    5.639004]  remoteproc2: 40800000.dsp is available
    [    5.643951] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    5.653192] mmcblk0: error -84 transferring data, sector 15269760, nr 8, cmd response 0x900, card status 0x0
    [    5.653198] mmcblk0: retrying using single block read
    [    5.668254] mmcblk0: error -84 transferring data, sector 15269760, nr 8, cmd response 0x900, card status 0x0
    [    5.678210] mmcblk0: error -84 transferring data, sector 15269761, nr 7, cmd response 0x900, card status 0x0
    [    5.719653] CAN device driver interface
    [    5.737930] mmcblk0: error -84 transferring data, sector 15269762, nr 6, cmd response 0x900, card status 0x0
    [    5.745950]  remoteproc2: Note: remoteproc is still under development and considered experimental.
    [    5.745955]  remoteproc2: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
    [    5.747055] omap-rproc 41000000.dsp: assigned reserved memory node dsp2_cma@9f000000
    [    5.747112]  remoteproc3: 41000000.dsp is available
    [    5.747115]  remoteproc3: Note: remoteproc is still under development and considered experimental.
    [    5.747118]  remoteproc3: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
    [    5.751380] pinctrl-single 4a003400.pinmux: pin 4a0037d0.0 already requested by 4806a000.serial; cannot claim for 4ae3c000.can
    [    5.751388] pinctrl-single 4a003400.pinmux: pin-244 (4ae3c000.can) status -22
    [    5.751396] pinctrl-single 4a003400.pinmux: could not request pin 244 (4a0037d0.0) from group dcan1_pins_sleep  on device pinctrl-single
    [    5.751400] c_can_platform 4ae3c000.can: Error applying setting, reverse things back
    [    5.752239] c_can_platform 4ae3c000.can: c_can_platform device registered (regs=fce3c000, irq=367)
    [    5.757730] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
    [    5.757734] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
    [    5.757795] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
    [    5.784380]  remoteproc1: registered virtio0 (type 7)
    [    5.784988]  remoteproc3: Direct firmware load for dra7-dsp2-fw.xe66 failed with error -2
    [    5.784994]  remoteproc3: failed to load dra7-dsp2-fw.xe66
    [    5.787759]  remoteproc2: registered virtio1 (type 7)
    [    5.814972] [drm] Initialized pvr 1.14.3699939 20110701 on minor 1
    [    5.816385] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
    [    5.816390] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
    [    5.816454] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
    [    5.915905] omap_rng 48090000.rng: OMAP Random Number Generator ver. 20
    [    5.916023] omap-des 480a5000.des: OMAP DES hw accel rev: 2.2
    [    5.923383] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
    [    5.923388] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
    [    5.923445] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
    [    6.018191] mmcblk0: error -84 transferring data, sector 15269763, nr 5, cmd response 0x900, card status 0x0
    [    6.018559] mmcblk0: error -84 transferring data, sector 15269764, nr 4, cmd response 0x900, card status 0x0
    [    6.018945] mmcblk0: error -84 transferring data, sector 15269765, nr 3, cmd response 0x900, card status 0x0
    [    6.018972] alg: skcipher: setkey failed on test 5 for ecb-des-omap: flags=100
    [    6.019921] mmcblk0: error -84 transferring data, sector 15269766, nr 2, cmd response 0x900, card status 0x0
    [    6.020140] mmcblk0: error -84 transferring data, sector 15269767, nr 1, cmd response 0x900, card status 0x0
    [    6.020268] alg: skcipher-ddst: setkey failed on test 5 for ecb-des-omap: flags=100
    [    6.020340] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    6.038687] mmcblk0: error -84 transferring data, sector 15269760, nr 8, cmd response 0x900, card status 0xb00
    [    6.038692] mmcblk0: retrying using single block read
    [    6.039368] mmcblk0: error -84 transferring data, sector 15269760, nr 8, cmd response 0x900, card status 0x0
    [    6.041806] mmcblk0: error -84 transferring data, sector 15269761, nr 7, cmd response 0x900, card status 0x0
    [    6.041968] mmcblk0: error -84 transferring data, sector 15269762, nr 6, cmd response 0x900, card status 0x0
    [    6.042083] alg: skcipher-ddst: setkey failed on test 5 for ecb-des-omap: flags=100
    [    6.042145] mmcblk0: error -84 transferring data, sector 15269763, nr 5, cmd response 0x900, card status 0x0
    [    6.042296] mmcblk0: error -84 transferring data, sector 15269764, nr 4, cmd response 0x900, card status 0x0
    [    6.042459] mmcblk0: error -84 transferring data, sector 15269765, nr 3, cmd response 0x900, card status 0x0
    [    6.042614] mmcblk0: error -84 transferring data, sector 15269766, nr 2, cmd response 0x900, card status 0x0
    [    6.042780] mmcblk0: error -84 transferring data, sector 15269767, nr 1, cmd response 0x900, card status 0x0
    [    6.042790] Buffer I/O error on dev mmcblk0, logical block 1908720, async page read
    [    6.043014] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    6.043093] mmcblk0: error -84 transferring data, sector 15269872, nr 8, cmd response 0x900, card status 0xb00
    [    6.043097] mmcblk0: retrying using single block read
    [    6.043256] mmcblk0: error -84 transferring data, sector 15269872, nr 8, cmd response 0x900, card status 0x0
    [    6.043418] mmcblk0: error -84 transferring data, sector 15269873, nr 7, cmd response 0x900, card status 0x0
    [    6.043545] mmcblk0: error -84 transferring data, sector 15269874, nr 6, cmd response 0x900, card status 0x0
    [    6.043701] mmcblk0: error -84 transferring data, sector 15269875, nr 5, cmd response 0x900, card status 0x0
    [    6.043829] mmcblk0: error -84 transferring data, sector 15269876, nr 4, cmd response 0x900, card status 0x0
    [    6.043964] mmcblk0: error -84 transferring data, sector 15269877, nr 3, cmd response 0x900, card status 0x0
    [    6.044091] mmcblk0: error -84 transferring data, sector 15269878, nr 2, cmd response 0x900, card status 0x0
    [    6.044250] mmcblk0: error -84 transferring data, sector 15269879, nr 1, cmd response 0x900, card status 0x0
    [    6.044420] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    6.044483] mmcblk0: error -84 transferring data, sector 15269872, nr 8, cmd response 0x900, card status 0xb00
    [    6.044487] mmcblk0: retrying using single block read
    [    6.044610] mmcblk0: error -84 transferring data, sector 15269872, nr 8, cmd response 0x900, card status 0x0
    [    6.044738] mmcblk0: error -84 transferring data, sector 15269873, nr 7, cmd response 0x900, card status 0x0
    [    6.044861] mmcblk0: error -84 transferring data, sector 15269874, nr 6, cmd response 0x900, card status 0x0
    [    6.044985] mmcblk0: error -84 transferring data, sector 15269875, nr 5, cmd response 0x900, card status 0x0
    [    6.045111] mmcblk0: error -84 transferring data, sector 15269876, nr 4, cmd response 0x900, card status 0x0
    [    6.045236] mmcblk0: error -84 transferring data, sector 15269877, nr 3, cmd response 0x900, card status 0x0
    [    6.045368] mmcblk0: error -84 transferring data, sector 15269878, nr 2, cmd response 0x900, card status 0x0
    [    6.045493] mmcblk0: error -84 transferring data, sector 15269879, nr 1, cmd response 0x900, card status 0x0
    [    6.045500] Buffer I/O error on dev mmcblk0, logical block 1908734, async page read
    [    6.045705] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    6.045760] mmcblk0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    6.045763] mmcblk0: retrying using single block read
    [    6.045945] mmcblk0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    6.046129] mmcblk0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    6.046307] mmcblk0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    6.046492] mmcblk0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    6.046674] mmcblk0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    6.046850] mmcblk0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    6.047024] mmcblk0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    6.047198] mmcblk0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    6.047379] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    6.047430] mmcblk0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    6.047434] mmcblk0: retrying using single block read
    [    6.047615] mmcblk0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    6.047794] mmcblk0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    6.047970] mmcblk0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    6.048144] mmcblk0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    6.048319] mmcblk0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    6.048498] mmcblk0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    6.048674] mmcblk0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    6.048848] mmcblk0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    6.048856] Buffer I/O error on dev mmcblk0, logical block 0, async page read
    [    6.049125] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    6.049173] mmcblk0: error -84 transferring data, sector 8, nr 8, cmd response 0x900, card status 0xb00
    [    6.049176] mmcblk0: retrying using single block read
    [    6.049355] mmcblk0: error -84 transferring data, sector 8, nr 8, cmd response 0x900, card status 0x0
    [    6.049537] mmcblk0: error -84 transferring data, sector 9, nr 7, cmd response 0x900, card status 0x0
    [    6.049718] mmcblk0: error -84 transferring data, sector 10, nr 6, cmd response 0x900, card status 0x0
    [    6.049900] mmcblk0: error -84 transferring data, sector 11, nr 5, cmd response 0x900, card status 0x0
    [    6.050082] mmcblk0: error -84 transferring data, sector 12, nr 4, cmd response 0x900, card status 0x0
    [    6.050264] mmcblk0: error -84 transferring data, sector 13, nr 3, cmd response 0x900, card status 0x0
    [    6.057238] mmcblk0: error -84 transferring data, sector 14, nr 2, cmd response 0x900, card status 0x0
    [    6.058705] mmcblk0: error -84 transferring data, sector 15, nr 1, cmd response 0x900, card status 0x0
    [    6.058715] Buffer I/O error on dev mmcblk0, logical block 1, async page read
    [    6.059005] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    ** 52 printk messages dropped ** [    6.065593] mmcblk0: error -84 transferring data, sector 15269882, nr 6, cmd response 0x900, card status 0x0
    ** 18 printk messages dropped ** [    6.069256] mmcblk0: retrying using single block read
    ** 3 printk messages dropped ** [    6.069802] mmcblk0: error -84 transferring data, sector 15269827, nr 5, cmd response 0x900, card status 0x0
    ** 14 printk messages dropped ** [    6.071657] mmcblk0: error -84 transferring data, sector 15269879, nr 1, cmd response 0x900, card status 0x0
    ** 12 printk messages dropped ** [    6.073786] mmcblk0: error -84 transferring data, sector 8, nr 8, cmd response 0x900, card status 0xb00
    [    6.073789] mmcblk0: retrying using single block read
    ** 7 printk messages dropped ** [    6.075318] mmcblk0: error -84 transferring data, sector 15, nr 1, cmd response 0x900, card status 0x0
    ** 11 printk messages dropped ** [    6.116558] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    ** 23 printk messages dropped ** [    6.120261] mmcblk0: retrying using single block read
    ** 22 printk messages dropped ** [    6.123844] mmcblk0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    ** 17 printk messages dropped ** [    6.126763] mmcblk0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    ** 7 printk messages dropped ** [    6.128098] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
    ** 74 printk messages dropped ** [    6.147089] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    ** 129 printk messages dropped ** [    6.169535] mmcblk0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    ** 118 printk messages dropped ** [    6.219804] mmcblk0: error -84 transferring data, sector 28, nr 4, cmd response 0x900, card status 0x0
    ** 33 printk messages dropped ** [    6.225384] mmcblk0: error -84 transferring data, sector 61, nr 3, cmd response 0x900, card status 0x0
    ** 38 printk messages dropped ** [    6.249558] mmcblk0: error -84 transferring data, sector 120, nr 8, cmd response 0x900, card status 0x0
    ** 31 printk messages dropped ** [    6.308644] mmcblk0: retrying using single block read
    ** 20 printk messages dropped ** [    6.435325] mmcblk0: error -84 transferring data, sector 8, nr 8, cmd response 0x900, card status 0xb00
    ** 45 printk messages dropped ** [    6.615830] mmcblk0: error -84 transferring data, sector 56, nr 8, cmd response 0x900, card status 0x0
    ** 28 printk messages dropped ** [    6.679610] mmcblk0: error -84 transferring data, sector 127, nr 1, cmd response 0x900, card status 0x0
    ** 23 printk messages dropped ** [    6.723007] mmcblk0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    ** 31 printk messages dropped ** [    6.765942] omap-sham 4b101000.sham: hw accel on OMAP rev 4.3
    ** 20 printk messages dropped ** [    6.781631] mmcblk0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    ** 25 printk messages dropped ** [    6.786248] mmcblk0: error -84 transferring data, sector 134, nr 2, cmd response 0x900, card status 0x0
    ** 34 printk messages dropped ** [    6.871495] mmcblk0: error -84 transferring data, sector 23, nr 1, cmd response 0x900, card status 0x0
    ** 31 printk messages dropped ** [    6.926403] mmcblk0: error -84 transferring data, sector 68, nr 4, cmd response 0x900, card status 0x0
    ** 27 printk messages dropped ** [    6.948468] mmcblk0: retrying using single block read
    ** 21 printk messages dropped ** [    6.952079] mmcblk0: retrying using single block read
    ** 21 printk messages dropped ** [    6.955778] mmcblk0: retrying using single block read
    ** 26 printk messages dropped ** [    6.969841] mmcblk0: error -84 transferring data, sector 260, nr 4, cmd response 0x900, card status 0x0
    ** 42 printk messages dropped ** [    6.976413] mmcblk0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    ** 34 printk messages dropped ** [    6.991654] mmcblk0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    ** 31 printk messages dropped ** [    7.005727] mmcblk0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    ** 26 printk messages dropped ** [    7.010401] mmcblk0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    ** 30 printk messages dropped ** [    7.015684] mmcblk0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    ** 23 printk messages dropped ** [    7.025203] mmcblk0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    ** 25 printk messages dropped ** [    7.029420] mmcblk0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    ** 22 printk messages dropped ** [    7.048313] mmcblk0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    ** 24 printk messages dropped ** [    7.052102] mmcblk0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    ** 25 printk messages dropped ** [    7.068499] mmcblk0: retrying using single block read
    ** 15 printk messages dropped ** [    7.079640] mmcblk0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    ** 25 printk messages dropped ** [    7.118820] mmcblk0: error -84 transferring data, sector 10, nr 6, cmd response 0x900, card status 0x0
    ** 26 printk messages dropped ** [    7.136739] mmcblk0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    ** 25 printk messages dropped ** [    7.156549] mmcblk0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    ** 21 printk messages dropped ** [    7.166335] mmcblk0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    ** 25 printk messages dropped ** [    7.192523] mmcblk0: error -84 transferring data, sector 15, nr 1, cmd response 0x900, card status 0x0
    ** 24 printk messages dropped ** [    7.210238] mmcblk0: retrying using single block read
    ** 16 printk messages dropped ** [    7.213104] mmcblk0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    ** 24 printk messages dropped ** [    7.217209] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    ** 23 printk messages dropped ** [    7.220633] mmcblk0: retrying using single block read
    ** 17 printk messages dropped ** [    7.223560] mmcblk0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    ** 24 printk messages dropped ** [    7.227328] mmcblk0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    ** 24 printk messages dropped ** [    7.231222] mmcblk0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    ** 24 printk messages dropped ** [    7.235646] mmcblk0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    ** 24 printk messages dropped ** [    7.240086] mmcblk0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    ** 26 printk messages dropped ** [    7.244258] mmcblk0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    ** 24 printk messages dropped ** [    7.248282] mmcblk0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    ** 22 printk messages dropped ** [    7.252922] mmcblk0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    ** 25 printk messages dropped ** [    7.266619] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    ** 30 printk messages dropped ** [    7.283300] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    ** 26 printk messages dropped ** [    7.296234] mmcblk0boot1: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    ** 25 printk messages dropped ** [    7.308987] mmcblk0boot1: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    ** 23 printk messages dropped ** [    7.317826] virtio_rpmsg_bus virtio1: creating channel rpmsg-rpc addr 0x3b
    ** 19 printk messages dropped ** [    7.328665] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    ** 23 printk messages dropped ** [    7.339639] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    ** 26 printk messages dropped ** [    7.375730] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    ** 24 printk messages dropped ** [    7.387996] mmcblk0boot0: retrying using single block read
    ** 15 printk messages dropped ** [    7.396588] mmcblk0boot0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    ** 26 printk messages dropped ** [    7.410223] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    ** 24 printk messages dropped ** [    7.422433] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    ** 24 printk messages dropped ** [    7.434769] mmcblk0boot0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    ** 25 printk messages dropped ** [    7.448173] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    ** 23 printk messages dropped ** [    7.457492] mmcblk0boot0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    ** 24 printk messages dropped ** [    7.470932] mmcblk0boot1: retrying using single block read
    ** 19 printk messages dropped ** [    7.485725] mmcblk0boot1: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    ** 22 printk messages dropped ** [    7.496512] mmcblk0boot1: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    ** 25 printk messages dropped ** [    7.507213] mmcblk0boot1: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    ** 23 printk messages dropped ** [    7.515723] mmcblk0boot1: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    ** 25 printk messages dropped ** [    7.528630] hub 2-0:1.0: 1 port detected
    ** 14 printk messages dropped ** [    7.530561] mmcblk0boot0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    ** 23 printk messages dropped ** [    7.542362] hub 3-0:1.0: USB hub found
    ** 13 printk messages dropped ** [    7.545214] mmcblk0boot0: retrying using single block read
    ** 16 printk messages dropped ** [    7.554414] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    ** 24 printk messages dropped ** [    7.564891] mmcblk0boot0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    ** 23 printk messages dropped ** [    7.580896] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    ** 26 printk messages dropped ** [    7.593840] mmcblk0boot0: retrying using single block read
    ** 15 printk messages dropped ** [    7.602451] mmcblk0boot0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    ** 23 printk messages dropped ** [    7.614720] mmcblk0boot0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    ** 22 printk messages dropped ** [    7.626842] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    ** 26 printk messages dropped ** [    7.640057] mmcblk0boot1: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    ** 23 printk messages dropped ** [    7.652295] mmcblk0boot1: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    ** 24 printk messages dropped ** [    7.665124] mmcblk0boot1: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    ** 24 printk messages dropped ** [    7.677741] mmcblk0boot0: error -84 transferring data, sector 8, nr 8, cmd response 0x900, card status 0xb00
    ** 24 printk messages dropped ** [    7.689811] mmcblk0boot0: error -84 transferring data, sector 25, nr 7, cmd response 0x900, card status 0x0
    ** 24 printk messages dropped ** [    7.703497] mmcblk0boot0: error -84 transferring data, sector 28, nr 4, cmd response 0x900, card status 0x0
    ** 23 printk messages dropped ** [    7.715515] mmcblk0boot0: error -84 transferring data, sector 62, nr 2, cmd response 0x900, card status 0x0
    ** 25 printk messages dropped ** [    7.727552] mmcblk0boot0: retrying using single block read
    ** 15 printk messages dropped ** [    7.736586] mmcblk0boot1: error -84 transferring data, sector 12, nr 4, cmd response 0x900, card status 0x0
    ** 24 printk messages dropped ** [    7.749156] mmcblk0boot1: error -84 transferring data, sector 15, nr 1, cmd response 0x900, card status 0x0
    ** 24 printk messages dropped ** [    7.760599] mmcblk0boot1: retrying using single block read
    ** 15 printk messages dropped ** [    7.769047] mmcblk0boot1: error -84 transferring data, sector 28, nr 4, cmd response 0x900, card status 0x0
    ** 24 printk messages dropped ** [    7.781646] mmcblk0boot1: error -84 transferring data, sector 63, nr 1, cmd response 0x900, card status 0x0
    ** 25 printk messages dropped ** [    7.794372] mmcblk0boot0: error -84 transferring data, sector 120, nr 8, cmd response 0x900, card status 0x0
    ** 24 printk messages dropped ** [    7.806983] mmcblk0boot0: error -84 transferring data, sector 123, nr 5, cmd response 0x900, card status 0x0
    ** 23 printk messages dropped ** [    7.819066] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    ** 24 printk messages dropped ** [    7.831755] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    ** 23 printk messages dropped ** [    7.842638] mmcblk0boot0: retrying using single block read
    ** 16 printk messages dropped ** [    7.851671] mmcblk0boot0: error -84 transferring data, sector 61, nr 3, cmd response 0x900, card status 0x0
    ** 23 printk messages dropped ** [    7.864298] mmcblk0boot1: error -84 transferring data, sector 127, nr 1, cmd response 0x900, card status 0x0
    ** 24 printk messages dropped ** [    7.875772] mmcblk0boot1: retrying using single block read
    ** 18 printk messages dropped ** [    7.881972] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    ** 25 printk messages dropped ** [    7.892885] mmcblk0boot1: error -84 transferring data, sector 8, nr 8, cmd response 0x900, card status 0x0
    ** 25 printk messages dropped ** [    7.906077] mmcblk0boot1: error -84 transferring data, sector 28, nr 4, cmd response 0x900, card status 0x0
    ** 24 printk messages dropped ** [    7.919273] mmcblk0boot0: error -84 transferring data, sector 127, nr 1, cmd response 0x900, card status 0x0
    ** 22 printk messages dropped ** [    7.930777] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    ** 28 printk messages dropped ** [    7.944954] mmcblk0boot0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    ** 23 printk messages dropped ** [    7.957215] mmcblk0boot0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    ** 24 printk messages dropped ** [    7.970087] mmcblk0boot1: error -84 transferring data, sector 56, nr 8, cmd response 0x900, card status 0xb00
    ** 26 printk messages dropped ** [    7.983366] mmcblk0boot1: error -84 transferring data, sector 123, nr 5, cmd response 0x900, card status 0x0
    ** 22 printk messages dropped ** [    7.994863] mmcblk0boot1: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    ** 24 printk messages dropped ** [    8.007689] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    ** 23 printk messages dropped ** [    8.019354] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    ** 26 printk messages dropped ** [    8.033500] mmcblk0boot0: error -84 transferring data, sector 131, nr 5, cmd response 0x900, card status 0x0
    ** 24 printk messages dropped ** [    8.046346] mmcblk0boot0: error -84 transferring data, sector 22, nr 2, cmd response 0x900, card status 0x0
    ** 23 printk messages dropped ** [    8.058582] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    ** 22 printk messages dropped ** [    8.069704] mmcblk0boot0: error -84 transferring data, sector 64, nr 8, cmd response 0x900, card status 0xb00
    ** 10 printk messages dropped ** [    8.075243] mmcblk0boot0: error -84 transferring data, sector 64, nr 8, cmd response 0x900, card status 0xb00
    ** 21 printk messages dropped ** [    8.086308] mmcblk0boot0: error -84 transferring data, sector 64, nr 8, cmd response 0x900, card status 0xb00
    ** 26 printk messages dropped ** [    8.100486] mmcblk0boot1: error -84 transferring data, sector 131, nr 5, cmd response 0x900, card status 0x0
    ** 16 printk messages dropped ** [    8.109046] mmcblk0boot1: error -84 transferring data, sector 16, nr 8, cmd response 0x900, card status 0xb00
    [    8.109050] mmcblk0boot1: retrying using single block read
    [    8.109723] mmcblk0boot1: error -84 transferring data, sector 16, nr 8, cmd response 0x900, card status 0x0
    [    8.110328] mmcblk0boot1: error -84 transferring data, sector 17, nr 7, cmd response 0x900, card status 0x0
    [    8.110932] mmcblk0boot1: error -84 transferring data, sector 18, nr 6, cmd response 0x900, card status 0x0
    [    8.111541] mmcblk0boot1: error -84 transferring data, sector 19, nr 5, cmd response 0x900, card status 0x0
    [    8.112142] mmcblk0boot1: error -84 transferring data, sector 20, nr 4, cmd response 0x900, card status 0x0
    [    8.112741] mmcblk0boot1: error -84 transferring data, sector 21, nr 3, cmd response 0x900, card status 0x0
    [    8.113340] mmcblk0boot1: error -84 transferring data, sector 22, nr 2, cmd response 0x900, card status 0x0
    [    8.113935] mmcblk0boot1: error -84 transferring data, sector 23, nr 1, cmd response 0x900, card status 0x0
    [    8.114514] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.114567] mmcblk0boot1: error -84 transferring data, sector 128, nr 8, cmd response 0x900, card status 0xb00
    [    8.114571] mmcblk0boot1: retrying using single block read
    [    8.115246] mmcblk0boot1: error -84 transferring data, sector 128, nr 8, cmd response 0x900, card status 0x0
    [    8.115851] mmcblk0boot1: error -84 transferring data, sector 129, nr 7, cmd response 0x900, card status 0x0
    [    8.116455] mmcblk0boot1: error -84 transferring data, sector 130, nr 6, cmd response 0x900, card status 0x0
    [    8.117058] mmcblk0boot1: error -84 transferring data, sector 131, nr 5, cmd response 0x900, card status 0x0
    [    8.117673] mmcblk0boot1: error -84 transferring data, sector 132, nr 4, cmd response 0x900, card status 0x0
    [    8.118270] mmcblk0boot1: error -84 transferring data, sector 133, nr 3, cmd response 0x900, card status 0x0
    [    8.118866] mmcblk0boot1: error -84 transferring data, sector 134, nr 2, cmd response 0x900, card status 0x0
    [    8.119473] mmcblk0boot1: error -84 transferring data, sector 135, nr 1, cmd response 0x900, card status 0x0
    [    8.120041] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.120100] mmcblk0boot1: error -84 transferring data, sector 64, nr 8, cmd response 0x900, card status 0xb00
    [    8.120103] mmcblk0boot1: retrying using single block read
    [    8.120785] mmcblk0boot1: error -84 transferring data, sector 64, nr 8, cmd response 0x900, card status 0x0
    [    8.121392] mmcblk0boot1: error -84 transferring data, sector 65, nr 7, cmd response 0x900, card status 0x0
    [    8.122001] mmcblk0boot1: error -84 transferring data, sector 66, nr 6, cmd response 0x900, card status 0x0
    [    8.122603] mmcblk0boot1: error -84 transferring data, sector 67, nr 5, cmd response 0x900, card status 0x0
    [    8.123209] mmcblk0boot1: error -84 transferring data, sector 68, nr 4, cmd response 0x900, card status 0x0
    [    8.123815] mmcblk0boot1: error -84 transferring data, sector 69, nr 3, cmd response 0x900, card status 0x0
    [    8.124412] mmcblk0boot1: error -84 transferring data, sector 70, nr 2, cmd response 0x900, card status 0x0
    [    8.125013] mmcblk0boot1: error -84 transferring data, sector 71, nr 1, cmd response 0x900, card status 0x0
    [    8.125582] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.125644] mmcblk0boot1: error -84 transferring data, sector 64, nr 8, cmd response 0x900, card status 0xb00
    [    8.125648] mmcblk0boot1: retrying using single block read
    [    8.126325] mmcblk0boot1: error -84 transferring data, sector 64, nr 8, cmd response 0x900, card status 0x0
    [    8.126937] mmcblk0boot1: error -84 transferring data, sector 65, nr 7, cmd response 0x900, card status 0x0
    [    8.127554] mmcblk0boot1: error -84 transferring data, sector 66, nr 6, cmd response 0x900, card status 0x0
    [    8.128150] mmcblk0boot1: error -84 transferring data, sector 67, nr 5, cmd response 0x900, card status 0x0
    [    8.128754] mmcblk0boot1: error -84 transferring data, sector 68, nr 4, cmd response 0x900, card status 0x0
    [    8.129355] mmcblk0boot1: error -84 transferring data, sector 69, nr 3, cmd response 0x900, card status 0x0
    [    8.129952] mmcblk0boot1: error -84 transferring data, sector 70, nr 2, cmd response 0x900, card status 0x0
    [    8.130550] mmcblk0boot1: error -84 transferring data, sector 71, nr 1, cmd response 0x900, card status 0x0
    [    8.131123] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.131184] mmcblk0boot1: error -84 transferring data, sector 64, nr 8, cmd response 0x900, card status 0xb00
    [    8.131188] mmcblk0boot1: retrying using single block read
    [    8.131867] mmcblk0boot1: error -84 transferring data, sector 64, nr 8, cmd response 0x900, card status 0x0
    [    8.132473] mmcblk0boot1: error -84 transferring data, sector 65, nr 7, cmd response 0x900, card status 0x0
    [    8.133079] mmcblk0boot1: error -84 transferring data, sector 66, nr 6, cmd response 0x900, card status 0x0
    [    8.133680] mmcblk0boot1: error -84 transferring data, sector 67, nr 5, cmd response 0x900, card status 0x0
    [    8.134282] mmcblk0boot1: error -84 transferring data, sector 68, nr 4, cmd response 0x900, card status 0x0
    [    8.134882] mmcblk0boot1: error -84 transferring data, sector 69, nr 3, cmd response 0x900, card status 0x0
    [    8.135480] mmcblk0boot1: error -84 transferring data, sector 70, nr 2, cmd response 0x900, card status 0x0
    [    8.136079] mmcblk0boot1: error -84 transferring data, sector 71, nr 1, cmd response 0x900, card status 0x0
    [    8.136647] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.136707] mmcblk0boot1: error -84 transferring data, sector 64, nr 8, cmd response 0x900, card status 0xb00
    [    8.136711] mmcblk0boot1: retrying using single block read
    [    8.137396] mmcblk0boot1: error -84 transferring data, sector 64, nr 8, cmd response 0x900, card status 0x0
    [    8.138002] mmcblk0boot1: error -84 transferring data, sector 65, nr 7, cmd response 0x900, card status 0x0
    [    8.138604] mmcblk0boot1: error -84 transferring data, sector 66, nr 6, cmd response 0x900, card status 0x0
    [    8.139210] mmcblk0boot1: error -84 transferring data, sector 67, nr 5, cmd response 0x900, card status 0x0
    [    8.139808] mmcblk0boot1: error -84 transferring data, sector 68, nr 4, cmd response 0x900, card status 0x0
    [    8.140407] mmcblk0boot1: error -84 transferring data, sector 69, nr 3, cmd response 0x900, card status 0x0
    [    8.141006] mmcblk0boot1: error -84 transferring data, sector 70, nr 2, cmd response 0x900, card status 0x0
    [    8.141609] mmcblk0boot1: error -84 transferring data, sector 71, nr 1, cmd response 0x900, card status 0x0
    [    8.142178] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.142236] mmcblk0boot1: error -84 transferring data, sector 64, nr 8, cmd response 0x900, card status 0xb00
    [    8.142240] mmcblk0boot1: retrying using single block read
    [    8.142920] mmcblk0boot1: error -84 transferring data, sector 64, nr 8, cmd response 0x900, card status 0x0
    [    8.143525] mmcblk0boot1: error -84 transferring data, sector 65, nr 7, cmd response 0x900, card status 0x0
    [    8.144132] mmcblk0boot1: error -84 transferring data, sector 66, nr 6, cmd response 0x900, card status 0x0
    [    8.144739] mmcblk0boot1: error -84 transferring data, sector 67, nr 5, cmd response 0x900, card status 0x0
    [    8.145344] mmcblk0boot1: error -84 transferring data, sector 68, nr 4, cmd response 0x900, card status 0x0
    [    8.145946] mmcblk0boot1: error -84 transferring data, sector 69, nr 3, cmd response 0x900, card status 0x0
    [    8.146548] mmcblk0boot1: error -84 transferring data, sector 70, nr 2, cmd response 0x900, card status 0x0
    [    8.147149] mmcblk0boot1: error -84 transferring data, sector 71, nr 1, cmd response 0x900, card status 0x0
    [    8.147723] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.147782] mmcblk0boot1: error -84 transferring data, sector 64, nr 8, cmd response 0x900, card status 0xb00
    [    8.147786] mmcblk0boot1: retrying using single block read
    [    8.148459] mmcblk0boot1: error -84 transferring data, sector 64, nr 8, cmd response 0x900, card status 0x0
    [    8.149071] mmcblk0boot1: error -84 transferring data, sector 65, nr 7, cmd response 0x900, card status 0x0
    [    8.149675] mmcblk0boot1: error -84 transferring data, sector 66, nr 6, cmd response 0x900, card status 0x0
    [    8.150283] mmcblk0boot1: error -84 transferring data, sector 67, nr 5, cmd response 0x900, card status 0x0
    [    8.150888] mmcblk0boot1: error -84 transferring data, sector 68, nr 4, cmd response 0x900, card status 0x0
    [    8.151488] mmcblk0boot1: error -84 transferring data, sector 69, nr 3, cmd response 0x900, card status 0x0
    [    8.152086] mmcblk0boot1: error -84 transferring data, sector 70, nr 2, cmd response 0x900, card status 0x0
    [    8.152682] mmcblk0boot1: error -84 transferring data, sector 71, nr 1, cmd response 0x900, card status 0x0
    [    8.153859] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.153911] mmcblk0boot0: error -84 transferring data, sector 64, nr 8, cmd response 0x900, card status 0xb00
    [    8.153914] mmcblk0boot0: retrying using single block read
    [    8.154589] mmcblk0boot0: error -84 transferring data, sector 64, nr 8, cmd response 0x900, card status 0x0
    [    8.155196] mmcblk0boot0: error -84 transferring data, sector 65, nr 7, cmd response 0x900, card status 0x0
    [    8.155800] mmcblk0boot0: error -84 transferring data, sector 66, nr 6, cmd response 0x900, card status 0x0
    [    8.156405] mmcblk0boot0: error -84 transferring data, sector 67, nr 5, cmd response 0x900, card status 0x0
    [    8.157004] mmcblk0boot0: error -84 transferring data, sector 68, nr 4, cmd response 0x900, card status 0x0
    [    8.157611] mmcblk0boot0: error -84 transferring data, sector 69, nr 3, cmd response 0x900, card status 0x0
    [    8.158210] mmcblk0boot0: error -84 transferring data, sector 70, nr 2, cmd response 0x900, card status 0x0
    [    8.158807] mmcblk0boot0: error -84 transferring data, sector 71, nr 1, cmd response 0x900, card status 0x0
    [    8.159380] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.159434] mmcblk0boot0: error -84 transferring data, sector 64, nr 8, cmd response 0x900, card status 0xb00
    [    8.159438] mmcblk0boot0: retrying using single block read
    [    8.160115] mmcblk0boot0: error -84 transferring data, sector 64, nr 8, cmd response 0x900, card status 0x0
    [    8.160722] mmcblk0boot0: error -84 transferring data, sector 65, nr 7, cmd response 0x900, card status 0x0
    [    8.161324] mmcblk0boot0: error -84 transferring data, sector 66, nr 6, cmd response 0x900, card status 0x0
    [    8.161930] mmcblk0boot0: error -84 transferring data, sector 67, nr 5, cmd response 0x900, card status 0x0
    [    8.162532] mmcblk0boot0: error -84 transferring data, sector 68, nr 4, cmd response 0x900, card status 0x0
    [    8.163132] mmcblk0boot0: error -84 transferring data, sector 69, nr 3, cmd response 0x900, card status 0x0
    [    8.163736] mmcblk0boot0: error -84 transferring data, sector 70, nr 2, cmd response 0x900, card status 0x0
    [    8.164331] mmcblk0boot0: error -84 transferring data, sector 71, nr 1, cmd response 0x900, card status 0x0
    [    8.164908] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.164962] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.164965] mmcblk0boot0: retrying using single block read
    [    8.165639] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.166243] mmcblk0boot0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.166849] mmcblk0boot0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.167457] mmcblk0boot0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.168057] mmcblk0boot0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.168660] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.169254] mmcblk0boot0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.169857] mmcblk0boot0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.170428] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.170481] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.170485] mmcblk0boot0: retrying using single block read
    [    8.171159] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.171768] mmcblk0boot0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.172372] mmcblk0boot0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.172975] mmcblk0boot0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.173577] mmcblk0boot0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.174179] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.174774] mmcblk0boot0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.175373] mmcblk0boot0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.175943] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.175999] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.176001] mmcblk0boot0: retrying using single block read
    [    8.176674] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.177279] mmcblk0boot0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.177882] mmcblk0boot0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.178485] mmcblk0boot0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.179089] mmcblk0boot0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.179689] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.180284] mmcblk0boot0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.180882] mmcblk0boot0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.181456] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.181510] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.181513] mmcblk0boot0: retrying using single block read
    [    8.182188] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.182793] mmcblk0boot0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.183395] mmcblk0boot0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.183997] mmcblk0boot0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.184602] mmcblk0boot0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.185204] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.185801] mmcblk0boot0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.186401] mmcblk0boot0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.186972] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.187023] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.187026] mmcblk0boot0: retrying using single block read
    [    8.187713] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.188310] mmcblk0boot0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.188913] mmcblk0boot0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.189516] mmcblk0boot0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.190118] mmcblk0boot0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.190717] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.191313] mmcblk0boot0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.191911] mmcblk0boot0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.192484] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.192537] mmcblk0boot0: error -84 transferring data, sector 16, nr 8, cmd response 0x900, card status 0xb00
    [    8.192541] mmcblk0boot0: retrying using single block read
    [    8.193221] mmcblk0boot0: error -84 transferring data, sector 16, nr 8, cmd response 0x900, card status 0x0
    [    8.193827] mmcblk0boot0: error -84 transferring data, sector 17, nr 7, cmd response 0x900, card status 0x0
    [    8.194431] mmcblk0boot0: error -84 transferring data, sector 18, nr 6, cmd response 0x900, card status 0x0
    [    8.195035] mmcblk0boot0: error -84 transferring data, sector 19, nr 5, cmd response 0x900, card status 0x0
    [    8.195634] mmcblk0boot0: error -84 transferring data, sector 20, nr 4, cmd response 0x900, card status 0x0
    [    8.196236] mmcblk0boot0: error -84 transferring data, sector 21, nr 3, cmd response 0x900, card status 0x0
    [    8.196838] mmcblk0boot0: error -84 transferring data, sector 22, nr 2, cmd response 0x900, card status 0x0
    [    8.197436] mmcblk0boot0: error -84 transferring data, sector 23, nr 1, cmd response 0x900, card status 0x0
    [    8.198006] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.198060] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.198063] mmcblk0boot0: retrying using single block read
    [    8.198736] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.199342] mmcblk0boot0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.199946] mmcblk0boot0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.200550] mmcblk0boot0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.201151] mmcblk0boot0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.201749] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.202347] mmcblk0boot0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.202946] mmcblk0boot0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.203519] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.203573] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.203576] mmcblk0boot0: retrying using single block read
    [    8.204248] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.204854] mmcblk0boot0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.205455] mmcblk0boot0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.206062] mmcblk0boot0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.206660] mmcblk0boot0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.207264] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.208832] mmcblk0boot0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.209251] mmcblk0boot0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.209807] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.209867] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.209870] mmcblk0boot0: retrying using single block read
    [    8.210550] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.211157] mmcblk0boot0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.211758] mmcblk0boot0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.212361] mmcblk0boot0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.212958] mmcblk0boot0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.213563] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.214165] mmcblk0boot0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.214759] mmcblk0boot0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.215941] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.215998] mmcblk0boot1: error -84 transferring data, sector 64, nr 8, cmd response 0x900, card status 0xb00
    [    8.216001] mmcblk0boot1: retrying using single block read
    [    8.216681] mmcblk0boot1: error -84 transferring data, sector 64, nr 8, cmd response 0x900, card status 0x0
    [    8.217290] mmcblk0boot1: error -84 transferring data, sector 65, nr 7, cmd response 0x900, card status 0x0
    [    8.217904] mmcblk0boot1: error -84 transferring data, sector 66, nr 6, cmd response 0x900, card status 0x0
    [    8.218498] mmcblk0boot1: error -84 transferring data, sector 67, nr 5, cmd response 0x900, card status 0x0
    [    8.219100] mmcblk0boot1: error -84 transferring data, sector 68, nr 4, cmd response 0x900, card status 0x0
    [    8.219703] mmcblk0boot1: error -84 transferring data, sector 69, nr 3, cmd response 0x900, card status 0x0
    [    8.220304] mmcblk0boot1: error -84 transferring data, sector 70, nr 2, cmd response 0x900, card status 0x0
    [    8.220902] mmcblk0boot1: error -84 transferring data, sector 71, nr 1, cmd response 0x900, card status 0x0
    [    8.221477] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.221533] mmcblk0boot1: error -84 transferring data, sector 64, nr 8, cmd response 0x900, card status 0xb00
    [    8.221537] mmcblk0boot1: retrying using single block read
    [    8.222212] mmcblk0boot1: error -84 transferring data, sector 64, nr 8, cmd response 0x900, card status 0x0
    [    8.222823] mmcblk0boot1: error -84 transferring data, sector 65, nr 7, cmd response 0x900, card status 0x0
    [    8.223427] mmcblk0boot1: error -84 transferring data, sector 66, nr 6, cmd response 0x900, card status 0x0
    [    8.224035] mmcblk0boot1: error -84 transferring data, sector 67, nr 5, cmd response 0x900, card status 0x0
    [    8.224635] mmcblk0boot1: error -84 transferring data, sector 68, nr 4, cmd response 0x900, card status 0x0
    [    8.225234] mmcblk0boot1: error -84 transferring data, sector 69, nr 3, cmd response 0x900, card status 0x0
    [    8.225835] mmcblk0boot1: error -84 transferring data, sector 70, nr 2, cmd response 0x900, card status 0x0
    [    8.226431] mmcblk0boot1: error -84 transferring data, sector 71, nr 1, cmd response 0x900, card status 0x0
    [    8.227005] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.227062] mmcblk0boot1: error -84 transferring data, sector 64, nr 8, cmd response 0x900, card status 0xb00
    [    8.227065] mmcblk0boot1: retrying using single block read
    [    8.227741] mmcblk0boot1: error -84 transferring data, sector 64, nr 8, cmd response 0x900, card status 0x0
    [    8.228346] mmcblk0boot1: error -84 transferring data, sector 65, nr 7, cmd response 0x900, card status 0x0
    [    8.228951] mmcblk0boot1: error -84 transferring data, sector 66, nr 6, cmd response 0x900, card status 0x0
    [    8.229553] mmcblk0boot1: error -84 transferring data, sector 67, nr 5, cmd response 0x900, card status 0x0
    [    8.230160] mmcblk0boot1: error -84 transferring data, sector 68, nr 4, cmd response 0x900, card status 0x0
    [    8.230760] mmcblk0boot1: error -84 transferring data, sector 69, nr 3, cmd response 0x900, card status 0x0
    [    8.231357] mmcblk0boot1: error -84 transferring data, sector 70, nr 2, cmd response 0x900, card status 0x0
    [    8.231955] mmcblk0boot1: error -84 transferring data, sector 71, nr 1, cmd response 0x900, card status 0x0
    [    8.232527] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.232580] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.232583] mmcblk0boot1: retrying using single block read
    [    8.233258] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.233862] mmcblk0boot1: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.234468] mmcblk0boot1: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.235071] mmcblk0boot1: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.235669] mmcblk0boot1: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.236269] mmcblk0boot1: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.236867] mmcblk0boot1: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.237481] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.238039] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.238093] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.238097] mmcblk0boot1: retrying using single block read
    [    8.238770] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.239380] mmcblk0boot1: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.239981] mmcblk0boot1: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.240589] mmcblk0boot1: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.241187] mmcblk0boot1: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.241790] mmcblk0boot1: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.242391] mmcblk0boot1: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.242986] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.243558] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.243612] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.243615] mmcblk0boot1: retrying using single block read
    [    8.244292] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.244899] mmcblk0boot1: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.245505] mmcblk0boot1: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.246106] mmcblk0boot1: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.246705] mmcblk0boot1: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.247302] mmcblk0boot1: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.247907] mmcblk0boot1: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.248501] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.249074] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.249129] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.249131] mmcblk0boot1: retrying using single block read
    [    8.249804] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.250410] mmcblk0boot1: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.251016] mmcblk0boot1: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.251618] mmcblk0boot1: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.252220] mmcblk0boot1: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.252816] mmcblk0boot1: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.253412] mmcblk0boot1: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.254010] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.254585] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.254639] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.254642] mmcblk0boot1: retrying using single block read
    [    8.255315] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.255919] mmcblk0boot1: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.256528] mmcblk0boot1: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.257133] mmcblk0boot1: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.257741] mmcblk0boot1: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.258338] mmcblk0boot1: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.258934] mmcblk0boot1: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.259533] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.260106] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.260159] mmcblk0boot1: error -84 transferring data, sector 16, nr 8, cmd response 0x900, card status 0xb00
    [    8.260163] mmcblk0boot1: retrying using single block read
    [    8.260836] mmcblk0boot1: error -84 transferring data, sector 16, nr 8, cmd response 0x900, card status 0x0
    [    8.261446] mmcblk0boot1: error -84 transferring data, sector 17, nr 7, cmd response 0x900, card status 0x0
    [    8.262055] mmcblk0boot1: error -84 transferring data, sector 18, nr 6, cmd response 0x900, card status 0x0
    [    8.262659] mmcblk0boot1: error -84 transferring data, sector 19, nr 5, cmd response 0x900, card status 0x0
    [    8.263261] mmcblk0boot1: error -84 transferring data, sector 20, nr 4, cmd response 0x900, card status 0x0
    [    8.263862] mmcblk0boot1: error -84 transferring data, sector 21, nr 3, cmd response 0x900, card status 0x0
    [    8.264461] mmcblk0boot1: error -84 transferring data, sector 22, nr 2, cmd response 0x900, card status 0x0
    [    8.265058] mmcblk0boot1: error -84 transferring data, sector 23, nr 1, cmd response 0x900, card status 0x0
    [    8.265631] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.265684] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.265687] mmcblk0boot1: retrying using single block read
    [    8.266360] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.266965] mmcblk0boot1: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.267569] mmcblk0boot1: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.268172] mmcblk0boot1: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.268768] mmcblk0boot1: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.269370] mmcblk0boot1: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.269966] mmcblk0boot1: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.270561] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.271134] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.271189] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.271192] mmcblk0boot1: retrying using single block read
    [    8.271864] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.272468] mmcblk0boot1: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.273073] mmcblk0boot1: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.273675] mmcblk0boot1: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.274273] mmcblk0boot1: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.274876] mmcblk0boot1: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.275473] mmcblk0boot1: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.276075] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.277254] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.277310] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.277313] mmcblk0boot0: retrying using single block read
    [    8.277990] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.278597] mmcblk0boot0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.279203] mmcblk0boot0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.279808] mmcblk0boot0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.280404] mmcblk0boot0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.281009] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.281608] mmcblk0boot0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.282203] mmcblk0boot0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.282775] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.282829] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.282832] mmcblk0boot0: retrying using single block read
    [    8.283509] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.284115] mmcblk0boot0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.284717] mmcblk0boot0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.285317] mmcblk0boot0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.285918] mmcblk0boot0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.286518] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.287112] mmcblk0boot0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.287714] mmcblk0boot0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.288281] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.288336] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.288340] mmcblk0boot0: retrying using single block read
    [    8.289015] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.289620] mmcblk0boot0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.290223] mmcblk0boot0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.290826] mmcblk0boot0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.291425] mmcblk0boot0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.292026] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.292625] mmcblk0boot0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.293220] mmcblk0boot0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.293797] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.293851] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.293854] mmcblk0boot0: retrying using single block read
    [    8.294526] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.295131] mmcblk0boot0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.295735] mmcblk0boot0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.296343] mmcblk0boot0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.296943] mmcblk0boot0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.297561] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.298150] mmcblk0boot0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.298750] mmcblk0boot0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.299316] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.299375] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.299378] mmcblk0boot0: retrying using single block read
    [    8.300056] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.300666] mmcblk0boot0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.301272] mmcblk0boot0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.301874] mmcblk0boot0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.302477] mmcblk0boot0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.303075] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.303673] mmcblk0boot0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.304267] mmcblk0boot0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.304835] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.304896] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.304900] mmcblk0boot0: retrying using single block read
    [    8.305579] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.306185] mmcblk0boot0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.306786] mmcblk0boot0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.307397] mmcblk0boot0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.307993] mmcblk0boot0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.308590] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.309188] mmcblk0boot0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.309783] mmcblk0boot0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.310355] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.310416] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.310419] mmcblk0boot0: retrying using single block read
    [    8.311095] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.311703] mmcblk0boot0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.312305] mmcblk0boot0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.312909] mmcblk0boot0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.313507] mmcblk0boot0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.314111] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.314707] mmcblk0boot0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.315308] mmcblk0boot0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.315874] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.315932] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.315935] mmcblk0boot0: retrying using single block read
    [    8.316614] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.317222] mmcblk0boot0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.317836] mmcblk0boot0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.318431] mmcblk0boot0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.319032] mmcblk0boot0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.319633] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.320235] mmcblk0boot0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.320834] mmcblk0boot0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.321400] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.321457] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.321460] mmcblk0boot0: retrying using single block read
    [    8.322142] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.322751] mmcblk0boot0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.323352] mmcblk0boot0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.323953] mmcblk0boot0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.324556] mmcblk0boot0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.325152] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.325750] mmcblk0boot0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.326346] mmcblk0boot0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.326915] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.326975] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.326978] mmcblk0boot0: retrying using single block read
    [    8.327662] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.328262] mmcblk0boot0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.328866] mmcblk0boot0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.329465] mmcblk0boot0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.330063] mmcblk0boot0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.330662] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.331264] mmcblk0boot0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.331860] mmcblk0boot0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.332430] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.332490] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.332494] mmcblk0boot0: retrying using single block read
    [    8.333172] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.333776] mmcblk0boot0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.334381] mmcblk0boot0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.334986] mmcblk0boot0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.335591] mmcblk0boot0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.336189] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.336789] mmcblk0boot0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.337391] mmcblk0boot0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.338563] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.338615] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.338618] mmcblk0boot1: retrying using single block read
    [    8.339292] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.339902] mmcblk0boot1: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.340508] mmcblk0boot1: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.341108] mmcblk0boot1: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.341713] mmcblk0boot1: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.342314] mmcblk0boot1: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.342909] mmcblk0boot1: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.343505] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.344083] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.344137] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.344140] mmcblk0boot1: retrying using single block read
    [    8.344811] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.345416] mmcblk0boot1: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.346020] mmcblk0boot1: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.346621] mmcblk0boot1: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.347225] mmcblk0boot1: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.347829] mmcblk0boot1: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.348422] mmcblk0boot1: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.349018] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.349592] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.349645] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.349648] mmcblk0boot1: retrying using single block read
    [    8.350320] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.350927] mmcblk0boot1: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.351528] mmcblk0boot1: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.352129] mmcblk0boot1: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.352734] mmcblk0boot1: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.353336] mmcblk0boot1: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.353932] mmcblk0boot1: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.354530] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.355105] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.355159] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.355162] mmcblk0boot1: retrying using single block read
    [    8.355834] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.356443] mmcblk0boot1: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.357046] mmcblk0boot1: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.357665] mmcblk0boot1: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.358260] mmcblk0boot1: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.358861] mmcblk0boot1: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.359462] mmcblk0boot1: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.360058] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.360626] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.360685] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.360688] mmcblk0boot1: retrying using single block read
    [    8.361370] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.361979] mmcblk0boot1: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.362581] mmcblk0boot1: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.363184] mmcblk0boot1: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.363785] mmcblk0boot1: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.364381] mmcblk0boot1: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.364979] mmcblk0boot1: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.365576] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.366143] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.366201] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.366204] mmcblk0boot1: retrying using single block read
    [    8.366883] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.367492] mmcblk0boot1: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.368084] mmcblk0boot1: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.368687] mmcblk0boot1: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.369285] mmcblk0boot1: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.369885] mmcblk0boot1: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.370481] mmcblk0boot1: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.371081] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.371653] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.371707] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.371710] mmcblk0boot1: retrying using single block read
    [    8.372382] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.372988] mmcblk0boot1: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.373590] mmcblk0boot1: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.374195] mmcblk0boot1: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.374793] mmcblk0boot1: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.375397] mmcblk0boot1: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.375999] mmcblk0boot1: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.376592] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.377167] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.377220] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.377224] mmcblk0boot1: retrying using single block read
    [    8.377900] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.378508] mmcblk0boot1: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.379111] mmcblk0boot1: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.379717] mmcblk0boot1: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.380317] mmcblk0boot1: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.380916] mmcblk0boot1: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.381512] mmcblk0boot1: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.382107] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.382684] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.382738] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.382741] mmcblk0boot1: retrying using single block read
    [    8.383413] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.384019] mmcblk0boot1: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.384623] mmcblk0boot1: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.385223] mmcblk0boot1: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.385823] mmcblk0boot1: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.386420] mmcblk0boot1: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.387020] mmcblk0boot1: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.387629] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.388189] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.388248] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.388252] mmcblk0boot1: retrying using single block read
    [    8.388930] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.389534] mmcblk0boot1: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.390140] mmcblk0boot1: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.390740] mmcblk0boot1: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.391339] mmcblk0boot1: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.391942] mmcblk0boot1: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.392538] mmcblk0boot1: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.393140] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.393710] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.393769] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.393772] mmcblk0boot1: retrying using single block read
    [    8.394455] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.395060] mmcblk0boot1: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.395664] mmcblk0boot1: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.396268] mmcblk0boot1: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.396873] mmcblk0boot1: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.397483] mmcblk0boot1: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.398066] mmcblk0boot1: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.398662] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.399837] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.399890] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.399894] mmcblk0boot0: retrying using single block read
    [    8.400570] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.401174] mmcblk0boot0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.401778] mmcblk0boot0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.402378] mmcblk0boot0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.402978] mmcblk0boot0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.403579] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.404175] mmcblk0boot0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.404771] mmcblk0boot0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.405343] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.405397] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.405401] mmcblk0boot0: retrying using single block read
    [    8.406072] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.406679] mmcblk0boot0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.407277] mmcblk0boot0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.407885] mmcblk0boot0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.408483] mmcblk0boot0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.409084] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.409682] mmcblk0boot0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.410279] mmcblk0boot0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.410854] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.410908] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.410911] mmcblk0boot0: retrying using single block read
    [    8.411580] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.412193] mmcblk0boot0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.412794] mmcblk0boot0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.413400] mmcblk0boot0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.414003] mmcblk0boot0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.414603] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.415206] mmcblk0boot0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.415799] mmcblk0boot0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.416373] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.416429] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.416431] mmcblk0boot0: retrying using single block read
    [    8.417106] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.417727] mmcblk0boot0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.418323] mmcblk0boot0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.418926] mmcblk0boot0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.419525] mmcblk0boot0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.420125] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.420721] mmcblk0boot0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.421320] mmcblk0boot0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.421883] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.421941] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.421945] mmcblk0boot0: retrying using single block read
    [    8.422622] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.423228] mmcblk0boot0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.423832] mmcblk0boot0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.424431] mmcblk0boot0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.425031] mmcblk0boot0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.425633] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.426227] mmcblk0boot0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.426825] mmcblk0boot0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.427402] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.427462] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.427465] mmcblk0boot0: retrying using single block read
    [    8.428145] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.428748] mmcblk0boot0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.429351] mmcblk0boot0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.429958] mmcblk0boot0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.430554] mmcblk0boot0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.431159] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.431753] mmcblk0boot0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.432356] mmcblk0boot0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.432927] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.432984] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.432987] mmcblk0boot0: retrying using single block read
    [    8.433670] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.434275] mmcblk0boot0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.434879] mmcblk0boot0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.435485] mmcblk0boot0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.436090] mmcblk0boot0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.436692] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.437288] mmcblk0boot0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.437890] mmcblk0boot0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.438453] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.438508] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.438511] mmcblk0boot0: retrying using single block read
    [    8.439185] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.439794] mmcblk0boot0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.440398] mmcblk0boot0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.440997] mmcblk0boot0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.441599] mmcblk0boot0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.442197] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.442793] mmcblk0boot0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.443390] mmcblk0boot0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.443962] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.444016] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.444019] mmcblk0boot0: retrying using single block read
    [    8.444692] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.445300] mmcblk0boot0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.445904] mmcblk0boot0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.446505] mmcblk0boot0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.447106] mmcblk0boot0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.447708] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.448302] mmcblk0boot0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.448903] mmcblk0boot0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.449475] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.449528] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.449531] mmcblk0boot0: retrying using single block read
    [    8.450204] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.450815] mmcblk0boot0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.451418] mmcblk0boot0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.452024] mmcblk0boot0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.452626] mmcblk0boot0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.453227] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.453825] mmcblk0boot0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.454427] mmcblk0boot0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.454987] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.455040] mmcblk0boot0: error -84 transferring data, sector 8, nr 8, cmd response 0x900, card status 0xb00
    [    8.455044] mmcblk0boot0: retrying using single block read
    [    8.455709] mmcblk0boot0: error -84 transferring data, sector 8, nr 8, cmd response 0x900, card status 0x0
    [    8.456305] mmcblk0boot0: error -84 transferring data, sector 9, nr 7, cmd response 0x900, card status 0x0
    [    8.456893] mmcblk0boot0: error -84 transferring data, sector 10, nr 6, cmd response 0x900, card status 0x0
    [    8.457500] mmcblk0boot0: error -84 transferring data, sector 11, nr 5, cmd response 0x900, card status 0x0
    [    8.458073] mmcblk0boot0: error -84 transferring data, sector 12, nr 4, cmd response 0x900, card status 0x0
    [    8.458661] mmcblk0boot0: error -84 transferring data, sector 13, nr 3, cmd response 0x900, card status 0x0
    [    8.459244] mmcblk0boot0: error -84 transferring data, sector 14, nr 2, cmd response 0x900, card status 0x0
    [    8.459827] mmcblk0boot0: error -84 transferring data, sector 15, nr 1, cmd response 0x900, card status 0x0
    [    8.461008] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.461060] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.461064] mmcblk0boot1: retrying using single block read
    [    8.461736] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.462343] mmcblk0boot1: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.462947] mmcblk0boot1: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.463558] mmcblk0boot1: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.464154] mmcblk0boot1: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.464758] mmcblk0boot1: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.465356] mmcblk0boot1: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.465954] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.466528] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.466584] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.466588] mmcblk0boot1: retrying using single block read
    [    8.467262] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.467873] mmcblk0boot1: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.468479] mmcblk0boot1: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.469081] mmcblk0boot1: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.469684] mmcblk0boot1: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.470284] mmcblk0boot1: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.470879] mmcblk0boot1: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.471473] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.472052] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.472104] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.472107] mmcblk0boot1: retrying using single block read
    [    8.472781] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.473385] mmcblk0boot1: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.473990] mmcblk0boot1: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.474590] mmcblk0boot1: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.475196] mmcblk0boot1: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.475796] mmcblk0boot1: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.476392] mmcblk0boot1: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.476985] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.477567] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.477630] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.477633] mmcblk0boot1: retrying using single block read
    [    8.478308] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.478912] mmcblk0boot1: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.479515] mmcblk0boot1: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.480117] mmcblk0boot1: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.480717] mmcblk0boot1: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.481321] mmcblk0boot1: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.481916] mmcblk0boot1: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.482517] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.483089] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.483142] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.483145] mmcblk0boot1: retrying using single block read
    [    8.483819] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.484425] mmcblk0boot1: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.485034] mmcblk0boot1: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.485636] mmcblk0boot1: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.486239] mmcblk0boot1: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.486840] mmcblk0boot1: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.487442] mmcblk0boot1: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.488036] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.488610] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.488663] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.488666] mmcblk0boot1: retrying using single block read
    [    8.489342] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.489952] mmcblk0boot1: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.490554] mmcblk0boot1: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.491156] mmcblk0boot1: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.491755] mmcblk0boot1: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.492353] mmcblk0boot1: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.492951] mmcblk0boot1: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.493547] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.494120] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.494174] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.494177] mmcblk0boot1: retrying using single block read
    [    8.494850] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.495454] mmcblk0boot1: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.496056] mmcblk0boot1: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.496658] mmcblk0boot1: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.497256] mmcblk0boot1: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.497873] mmcblk0boot1: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.498461] mmcblk0boot1: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.499061] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.499628] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.499686] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.499690] mmcblk0boot1: retrying using single block read
    [    8.500367] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.500972] mmcblk0boot1: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.501575] mmcblk0boot1: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.502180] mmcblk0boot1: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.502787] mmcblk0boot1: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.503383] mmcblk0boot1: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.503983] mmcblk0boot1: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.504580] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.505153] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.505214] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.505217] mmcblk0boot1: retrying using single block read
    [    8.505899] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.506507] mmcblk0boot1: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.507110] mmcblk0boot1: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.507726] mmcblk0boot1: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.508318] mmcblk0boot1: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.508920] mmcblk0boot1: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.509516] mmcblk0boot1: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.510115] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.510682] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.510740] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.510744] mmcblk0boot1: retrying using single block read
    [    8.511428] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.512031] mmcblk0boot1: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.512633] mmcblk0boot1: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.513234] mmcblk0boot1: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.513834] mmcblk0boot1: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.514433] mmcblk0boot1: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.515029] mmcblk0boot1: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.515628] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.516196] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.516253] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.516256] mmcblk0boot1: retrying using single block read
    [    8.516937] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.517552] mmcblk0boot1: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.518140] mmcblk0boot1: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.518743] mmcblk0boot1: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.519340] mmcblk0boot1: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.519939] mmcblk0boot1: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.520544] mmcblk0boot1: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.521139] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.522316] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.522368] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.522371] mmcblk0boot0: retrying using single block read
    [    8.523043] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.523651] mmcblk0boot0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.524259] mmcblk0boot0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.524863] mmcblk0boot0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.525465] mmcblk0boot0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.526064] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.526664] mmcblk0boot0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.527260] mmcblk0boot0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.527831] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.527885] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.527888] mmcblk0boot0: retrying using single block read
    [    8.528564] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.529174] mmcblk0boot0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.529779] mmcblk0boot0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.530380] mmcblk0boot0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.530979] mmcblk0boot0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.531577] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.532175] mmcblk0boot0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.532771] mmcblk0boot0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.533342] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.533396] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.533399] mmcblk0boot0: retrying using single block read
    [    8.534074] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.534682] mmcblk0boot0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.535283] mmcblk0boot0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.535884] mmcblk0boot0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.536485] mmcblk0boot0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.537086] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.537681] mmcblk0boot0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.538284] mmcblk0boot0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.538854] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.538903] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.538906] mmcblk0boot0: retrying using single block read
    [    8.539574] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.540181] mmcblk0boot0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.540786] mmcblk0boot0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.541394] mmcblk0boot0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.541993] mmcblk0boot0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.542597] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.543197] mmcblk0boot0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.543794] mmcblk0boot0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.544365] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.544418] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.544421] mmcblk0boot0: retrying using single block read
    [    8.545098] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.545704] mmcblk0boot0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.546309] mmcblk0boot0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.546916] mmcblk0boot0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.547529] mmcblk0boot0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.548119] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.548715] mmcblk0boot0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.549309] mmcblk0boot0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.549883] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.549943] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.549947] mmcblk0boot0: retrying using single block read
    [    8.550622] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.551229] mmcblk0boot0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.551833] mmcblk0boot0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.552433] mmcblk0boot0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.553057] mmcblk0boot0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.553628] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.554225] mmcblk0boot0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.554819] mmcblk0boot0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.555396] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.555450] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.555453] mmcblk0boot0: retrying using single block read
    [    8.556127] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.556731] mmcblk0boot0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.557349] mmcblk0boot0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.557936] mmcblk0boot0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.558534] mmcblk0boot0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.559138] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.559735] mmcblk0boot0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.560335] mmcblk0boot0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.560910] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.560963] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.560966] mmcblk0boot0: retrying using single block read
    [    8.561643] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.562247] mmcblk0boot0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.562853] mmcblk0boot0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.563454] mmcblk0boot0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.564060] mmcblk0boot0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.564664] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.565258] mmcblk0boot0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.565857] mmcblk0boot0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.566427] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.566482] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.566484] mmcblk0boot0: retrying using single block read
    [    8.567157] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.567768] mmcblk0boot0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.568368] mmcblk0boot0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.568971] mmcblk0boot0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.569571] mmcblk0boot0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.570174] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.570768] mmcblk0boot0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.571365] mmcblk0boot0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.571937] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.571990] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.571993] mmcblk0boot0: retrying using single block read
    [    8.572664] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.573275] mmcblk0boot0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.573877] mmcblk0boot0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.574477] mmcblk0boot0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.575081] mmcblk0boot0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.575679] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.576274] mmcblk0boot0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.576875] mmcblk0boot0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.577437] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.577489] mmcblk0boot0: error -84 transferring data, sector 24, nr 8, cmd response 0x900, card status 0xb00
    [    8.577493] mmcblk0boot0: retrying using single block read
    [    8.578157] mmcblk0boot0: error -84 transferring data, sector 24, nr 8, cmd response 0x900, card status 0x0
    [    8.578753] mmcblk0boot0: error -84 transferring data, sector 25, nr 7, cmd response 0x900, card status 0x0
    [    8.579345] mmcblk0boot0: error -84 transferring data, sector 26, nr 6, cmd response 0x900, card status 0x0
    [    8.579940] mmcblk0boot0: error -84 transferring data, sector 27, nr 5, cmd response 0x900, card status 0x0
    [    8.580531] mmcblk0boot0: error -84 transferring data, sector 28, nr 4, cmd response 0x900, card status 0x0
    [    8.581120] mmcblk0boot0: error -84 transferring data, sector 29, nr 3, cmd response 0x900, card status 0x0
    [    8.581708] mmcblk0boot0: error -84 transferring data, sector 30, nr 2, cmd response 0x900, card status 0x0
    [    8.582296] mmcblk0boot0: error -84 transferring data, sector 31, nr 1, cmd response 0x900, card status 0x0
    [    8.583458] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.583510] mmcblk0boot1: error -84 transferring data, sector 8, nr 8, cmd response 0x900, card status 0xb00
    [    8.583513] mmcblk0boot1: retrying using single block read
    [    8.584179] mmcblk0boot1: error -84 transferring data, sector 8, nr 8, cmd response 0x900, card status 0x0
    [    8.584772] mmcblk0boot1: error -84 transferring data, sector 9, nr 7, cmd response 0x900, card status 0x0
    [    8.585361] mmcblk0boot1: error -84 transferring data, sector 10, nr 6, cmd response 0x900, card status 0x0
    [    8.585951] mmcblk0boot1: error -84 transferring data, sector 11, nr 5, cmd response 0x900, card status 0x0
    [    8.586538] mmcblk0boot1: error -84 transferring data, sector 12, nr 4, cmd response 0x900, card status 0x0
    [    8.587128] mmcblk0boot1: error -84 transferring data, sector 13, nr 3, cmd response 0x900, card status 0x0
    [    8.587717] mmcblk0boot1: error -84 transferring data, sector 14, nr 2, cmd response 0x900, card status 0x0
    [    8.588301] mmcblk0boot1: error -84 transferring data, sector 15, nr 1, cmd response 0x900, card status 0x0
    [    8.588873] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.588927] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.588931] mmcblk0boot1: retrying using single block read
    [    8.589605] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.590214] mmcblk0boot1: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.590821] mmcblk0boot1: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.591422] mmcblk0boot1: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.592021] mmcblk0boot1: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.592622] mmcblk0boot1: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.593218] mmcblk0boot1: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.593819] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.594390] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.594443] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.594446] mmcblk0boot1: retrying using single block read
    [    8.595119] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.595724] mmcblk0boot1: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.596330] mmcblk0boot1: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.596932] mmcblk0boot1: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.597533] mmcblk0boot1: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.598134] mmcblk0boot1: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.598729] mmcblk0boot1: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.599331] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.599905] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.599958] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.599961] mmcblk0boot1: retrying using single block read
    [    8.600635] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.601241] mmcblk0boot1: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.601842] mmcblk0boot1: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.602445] mmcblk0boot1: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.603049] mmcblk0boot1: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.603648] mmcblk0boot1: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.604248] mmcblk0boot1: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.604847] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.605420] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.605473] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.605477] mmcblk0boot1: retrying using single block read
    [    8.606149] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.606761] mmcblk0boot1: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.607390] mmcblk0boot1: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.607980] mmcblk0boot1: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.608576] mmcblk0boot1: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.609174] mmcblk0boot1: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.609772] mmcblk0boot1: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.610369] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.610936] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.610997] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.611000] mmcblk0boot1: retrying using single block read
    [    8.611682] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.612286] mmcblk0boot1: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.612889] mmcblk0boot1: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.613490] mmcblk0boot1: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.614089] mmcblk0boot1: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.614689] mmcblk0boot1: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.615286] mmcblk0boot1: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.615882] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.616451] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.616511] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.616515] mmcblk0boot1: retrying using single block read
    [    8.617196] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.617805] mmcblk0boot1: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.618402] mmcblk0boot1: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.619003] mmcblk0boot1: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.619604] mmcblk0boot1: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.620202] mmcblk0boot1: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.620802] mmcblk0boot1: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.621399] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.621969] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.622028] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.622031] mmcblk0boot1: retrying using single block read
    [    8.622709] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.623318] mmcblk0boot1: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.623920] mmcblk0boot1: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.624527] mmcblk0boot1: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.625126] mmcblk0boot1: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.625731] mmcblk0boot1: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.626332] mmcblk0boot1: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.626927] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.627499] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.627560] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.627563] mmcblk0boot1: retrying using single block read
    [    8.628245] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.628852] mmcblk0boot1: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.629457] mmcblk0boot1: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.630063] mmcblk0boot1: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.630663] mmcblk0boot1: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.631260] mmcblk0boot1: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.631858] mmcblk0boot1: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.632454] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.633026] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.633086] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.633089] mmcblk0boot1: retrying using single block read
    [    8.633768] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.634375] mmcblk0boot1: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.634978] mmcblk0boot1: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.635578] mmcblk0boot1: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.636179] mmcblk0boot1: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.636777] mmcblk0boot1: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.637378] mmcblk0boot1: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.637964] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.638539] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.638593] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.638596] mmcblk0boot1: retrying using single block read
    [    8.639267] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.639873] mmcblk0boot1: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.640480] mmcblk0boot1: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.641081] mmcblk0boot1: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.641680] mmcblk0boot1: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.642284] mmcblk0boot1: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.642878] mmcblk0boot1: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.643478] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.644657] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.644710] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.644714] mmcblk0boot0: retrying using single block read
    [    8.645389] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.645995] mmcblk0boot0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.646599] mmcblk0boot0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.647205] mmcblk0boot0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.647810] mmcblk0boot0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.648407] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.649004] mmcblk0boot0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.649598] mmcblk0boot0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.650172] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.650226] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.650229] mmcblk0boot0: retrying using single block read
    [    8.650903] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.651511] mmcblk0boot0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.652113] mmcblk0boot0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.652715] mmcblk0boot0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.653316] mmcblk0boot0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.653913] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.654508] mmcblk0boot0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.655109] mmcblk0boot0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.655678] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.655730] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.655733] mmcblk0boot0: retrying using single block read
    [    8.656404] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.657012] mmcblk0boot0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.657615] mmcblk0boot0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.658217] mmcblk0boot0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.658815] mmcblk0boot0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.659414] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.660018] mmcblk0boot0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.660613] mmcblk0boot0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.661190] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.661244] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.661247] mmcblk0boot0: retrying using single block read
    [    8.661920] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.662530] mmcblk0boot0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.663132] mmcblk0boot0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.663737] mmcblk0boot0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.664337] mmcblk0boot0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.664941] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.665540] mmcblk0boot0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.666137] mmcblk0boot0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.666708] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.666760] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.666763] mmcblk0boot0: retrying using single block read
    [    8.667455] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.668050] mmcblk0boot0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.668657] mmcblk0boot0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.669259] mmcblk0boot0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.669861] mmcblk0boot0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.670458] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.671059] mmcblk0boot0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.671655] mmcblk0boot0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.681707] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.681759] mmcblk0boot1: error -84 transferring data, sector 24, nr 8, cmd response 0x900, card status 0xb00
    [    8.681763] mmcblk0boot1: retrying using single block read
    [    8.682429] mmcblk0boot1: error -84 transferring data, sector 24, nr 8, cmd response 0x900, card status 0x0
    [    8.683022] mmcblk0boot1: error -84 transferring data, sector 25, nr 7, cmd response 0x900, card status 0x0
    [    8.683619] mmcblk0boot1: error -84 transferring data, sector 26, nr 6, cmd response 0x900, card status 0x0
    [    8.684213] mmcblk0boot1: error -84 transferring data, sector 27, nr 5, cmd response 0x900, card status 0x0
    [    8.684802] mmcblk0boot1: error -84 transferring data, sector 28, nr 4, cmd response 0x900, card status 0x0
    [    8.685391] mmcblk0boot1: error -84 transferring data, sector 29, nr 3, cmd response 0x900, card status 0x0
    [    8.685980] mmcblk0boot1: error -84 transferring data, sector 30, nr 2, cmd response 0x900, card status 0x0
    [    8.686566] mmcblk0boot1: error -84 transferring data, sector 31, nr 1, cmd response 0x900, card status 0x0
    [    8.687140] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.687194] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.687197] mmcblk0boot1: retrying using single block read
    [    8.687876] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.688477] mmcblk0boot1: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.689079] mmcblk0boot1: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.689682] mmcblk0boot1: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.690282] mmcblk0boot1: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.690882] mmcblk0boot1: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.691480] mmcblk0boot1: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.692079] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.692653] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.692707] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.692710] mmcblk0boot1: retrying using single block read
    [    8.693381] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.693987] mmcblk0boot1: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.694592] mmcblk0boot1: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.695199] mmcblk0boot1: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.695798] mmcblk0boot1: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.696403] mmcblk0boot1: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.696998] mmcblk0boot1: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.697600] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.698171] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.698225] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.698228] mmcblk0boot1: retrying using single block read
    [    8.698899] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.699512] mmcblk0boot1: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.700117] mmcblk0boot1: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.700719] mmcblk0boot1: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.701318] mmcblk0boot1: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.701917] mmcblk0boot1: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.702514] mmcblk0boot1: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.703112] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.703683] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.703736] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.703739] mmcblk0boot1: retrying using single block read
    [    8.704411] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.705016] mmcblk0boot1: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.705620] mmcblk0boot1: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.706222] mmcblk0boot1: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.706820] mmcblk0boot1: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.708853] mmcblk0boot1: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.709261] mmcblk0boot1: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.709857] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.710432] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.710485] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.710488] mmcblk0boot1: retrying using single block read
    [    8.711160] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.711765] mmcblk0boot1: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.712367] mmcblk0boot1: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.712974] mmcblk0boot1: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.713572] mmcblk0boot1: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.714178] mmcblk0boot1: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.714772] mmcblk0boot1: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.715373] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [   17.497366] ata1: softreset failed (1st FIS failed)
    udevd[404]: failed to execute '/etc/udev/scripts/mount.sh' '/etc/udev/scripts/mount.sh': No such file or directory
    udevd[413]: failed to execute '/etc/udev/scripts/mount.sh' '/etc/udev/scripts/mount.sh': No such file or directory
    udevd[417]: failed to execute '/etc/udev/scripts/mount.sh' '/etc/udev/scripts/mount.sh': No such file or directory
    udevd[444]: failed to execute '/etc/udev/scripts/mount.sh' '/etc/udev/scripts/mount.sh': No such file or directory
    [   27.507359] ata1: softreset failed (1st FIS failed)
    [   27.857363] ata1: SATA link down (SStatus 0 SControl 300)
    [   27.896671] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
    Starting Bootlog daemon: bootlogd.
    ALSA: Restoring mixer settings...
    No state is present for card DRA7xxEVMMCASP1
    Found hardware: "DRA7xx-EVM-MCAS" "" "" "" ""
    Hardware is initialized using a generic method
    No state is present for card DRA7xxEVMMCASP2
    No state is present for card DRA7xxEVMMCASP3
    No state is present for card DRA7xxEVMMCASP4
    No state is present for card DRA7xxEVMMCASP8
    Thu Sep  3 18:41:00 UTC 2015
    2017.11.23 15:00
    This version is for J6
    ****** This application only support ASCII code 0 to 127 ******
    ****** This application only support CB version #F ******
    [   43.416085] xhci-hcd xhci-hcd.1.auto: remove, state 4
    [   43.422627] usb usb4: USB disconnect, device number 1
    [   43.430892] xhci-hcd xhci-hcd.1.auto: USB bus 4 deregistered
    [   43.436608] xhci-hcd xhci-hcd.1.auto: remove, state 4
    [   43.441755] usb usb3: USB disconnect, device number 1
    [   43.449122] xhci-hcd xhci-hcd.1.auto: USB bus 3 deregistered
    [   43.455756] xhci-hcd xhci-hcd.0.auto: remove, state 4
    [   43.460880] usb usb2: USB disconnect, device number 1
    [   43.468127] xhci-hcd xhci-hcd.0.auto: USB bus 2 deregistered
    [   43.473839] xhci-hcd xhci-hcd.0.auto: remove, state 4
    [   43.479011] usb usb1: USB disconnect, device number 1
    [   43.486322] xhci-hcd xhci-hcd.0.auto: USB bus 1 deregistered
    [   43.597557] usbcore: deregistering device driver usb
    [   43.604204] usbcore: deregistering interface driver usbfs
    [   43.611324] usbcore: deregistering interface driver hub
    [AB_server.c, make_sure_usb_kernel_stack_removed, 374] temp: drwxr-xr-x   27 root     root             0 Jan  1  1970 .
    dr-xr-xr-x   12 root     root             0 Jan  1  1970 ..
    drwxr-xr-x    4 root     root             0 Jan  1  1970 ac97
    drwxr-xr-x    4 root     root             0 Jan  1  1970 clockevents
    drwxr-xr-x    4 root     root             0 Jan  1  1970 clocksource
    drwxr-xr-x    4 root     root             0 Jan  1  1970 container
    drwxr-xr-x    4 root     root             0 Jan  1  1970 cpu
    drwxr-xr-x    4 root     root             0 Jan  1  1970 edac
    drwxr-xr-x    4 root     root             0 Jan  1  1970 event_source
    drwxr-xr-x    4 root     root             0 Jan  1  1970 hid
    drwxr-xr-x    4 root     root             0 Jan  1  1970 i2c
    drwxr-xr-x    4 root     root             0 Jan  1  1970 iio
    drwxr-xr-x    4 root     root             0 Jan  1  1970 mdio_bus
    drwxr-xr-x    4 root     root             0 Jan  1  1970 media
    drwxr-xr-x    4 root     root             0 Jan  1  1970 mipi-dsi
    drwxr-xr-x    4 root     root             0 Jan  1  1970 mmc
    drwxr-xr-x    5 root     root             0 Jan  1  1970 pci
    drwxr-xr-x    4 root     root             0 Jan  1  1970 platform
    drwxr-xr-x    4 root     root             0 Jan  1  1970 rpmsg
    drwxr-xr-x    4 root     root             0 Jan  1  1970 scsi
    drwxr-xr-x    4 root     root             0 Jan  1  1970 sdio
    drwxr-xr-x    4 root     root             0 Jan  1  1970 serio
    drwxr-xr-x    4 root     root             0 Jan  1  1970 soc
    drwxr-xr-x    4 root     root             0 Jan  1  1970 spi
    drwxr-xr-x    4 root     root             0 Jan  1  1970 ulpi
    drwxr-xr-x    4 root     root             0 Jan  1  1970 virtio
    drwxr-xr-x    4 root     root             0 Jan  1  1970 workqueue
    [AB_server.c, AB_boot_finish, 181] AB boot success, pull high GPIO
    [AB_server.c, AB_boot_finish, 187] AB boot success, pull high GPIO finished
    [AB_server.c, get_CB_hardware_version, 212] Wait for CB send HW version
    [AB_server.c, get_CB_hardware_version, 216] Read CB HW version (0) Bytes
    /usr/local/bin/set_unused_gpio_input: line 14: echo: write error: Device or resource busy
    /usr/local/bin/set_unused_gpio_input: line 15: /sys/class/gpio/gpio161/direction: No such file or directory
    INIT: Entering runlevel: 5
    Configuring network interfaces... [   45.373449] net eth0: initializing cpsw version 1.15 (0)
    [   45.379130] net eth0: initialized cpsw ale version 1.4
    [   45.384293] net eth0: ALE Table size 1024
    [   45.391355] libphy: PHY 48485000.mdio:02 not found
    [   45.396173] net eth0: phy "48485000.mdio:02" not found on slave 0, err -19
    [   45.410785] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
    /bin/sh: udhcpc: command not found
    done.
    Starting system message bus: dbus.
    [AB_server.c, get_CB_hardware_version, 216] Read CB HW version (4) Bytes
    _version[0]: 30
    _version[1]: 31
    _version[2]: 31
    _version[3]: 30
    _version[4]: 0
    _version[5]: 0
    _version[6]: 0
    _version[7]: 0
    _version[8]: 0
    _version[9]: 0
    _version[10]: 0
    _version[11]: 0
    _version[12]: 0
    _version[13]: 0
    _version[14]: 0
    _version[15]: 0
    [AB_server.c, main, 517] AB_server: get CB's HW version 0110
    [AB_server.c, get_CB_hardware_version_finish, 254] AB get CB hw version finish, gpio pull low
    [AB_server.c, send_AB_model_info_to_CB, 279] write AB model info total (6) Bytes, model: (DRA74X
    [AB_server.c, sync_CB_status, 308] ______ AB GPIO 109 status: 0
     ______
    [AB_server.c, sync_CB_status, 317] ______ AB GPIO 109 LOW, AB booting ______
     ______
    UIM SYSFS Node Not Found
    Starting telnet daemon.
    Starting tiipclad daemon
    GateMP support enabled on host
    Opened log file: lad.txt
    numProcessors = 5 id = 0 baseId = 0
    Spawned daemon: /usr/bin/lad_dra7xx
    Starting rpcbind daemon...[AB_server.c, sync_CB_status, 308] ______ AB GPIO 109 status: 1
     ______
    [AB_server.c, sync_CB_status, 312] ______ AB GPIO 109 1, can go ______
    done.
    creating NFS state directory: done
    starting statd: done
    NFS daemon support not enabled in kernel
    Starting syslogd/klogd: done
    Starting thttpd.
    Enabling thermal zones...
    Stopping Bootlog daemon: bootlogd.
    root@wnc-j6:~# [AB_server.c, main, 550] ulpi on/off : J6, ULPI test on
    cat /sys/kernel/debug/mmc0/ios
    clock:          52000000 Hz
    vdd:            21 (3.3 ~ 3.4 V)
    bus mode:       2 (push-pull)
    chip select:    0 (don't care)
    power mode:     2 (on)
    bus width:      2 (4 bits)
    timing spec:    1 (mmc high-speed)
    signal voltage: 0 (3.30 V)
    driver type:    0 (driver type B)
    root@wnc-j6:~# lsblk
    NAME         MAJ:MIN RM  SIZE RO TYPE MOUNTPOINT
    mmcblk0boot0 179:16   0  128K  1 disk
    mmcblk0boot1 179:32   0  128K  1 disk
    mmcblk1boot0 179:64   0  128K  1 disk
    mmcblk1boot1 179:80   0  128K  1 disk
    mmcblk0      179:0    0  7.3G  0 disk
    mmcblk1      179:48   0  7.3G  0 disk
    |-mmcblk1p1  179:49   0   64M  0 part
    `-mmcblk1p2  179:50   0  7.2G  0 part /
    mmcblk2      179:96   0  3.7G  0 disk
    |-mmcblk2p1  179:97   0   62M  0 part
    `-mmcblk2p2  179:98   0  3.6G  0 part
    root@wnc-j6:~#
  • Hi, Kevin,
    Base on your previous post, I feel a little bit confuse.
    If it possible, please describes more detail about these logs.
    for example,
    * DRA746 eMMC1 interface boots with eMMC flash, include TS3A27518, VDD 3.3V, IO 3.3V ? please confirm?  log as below?
    U-Boot SPL 2016.05 (Nov 24 2017 - 15:38:03)
    DRA752-GP ES2.0
    *** Warning - bad CRC, using default environment
    Trying to boot from MMC2_2
    spl: falcon_args_file not set in environment, falling back to default
    reading args
    spl_load_image_fat_os: error reading image args, err - -1
    reading u-boot.img
    reading u-boot.img
    U-Boot 2016.05 (Nov 24 2017 - 15:38:03 +0800)
    CPU  : DRA752-GP ES2.0
    Board: DRA74x EVM REV
    I2C:   ready
    DRAM:  2 GiB
    MMC:   OMAP SD/MMC: 0, OMAP SD/MMC: 1
    Warning: fastboot.board_rev: unknown board revision
    GUID Partition Table Header signature is wrong: 0x0 != 0x5452415020494645
    part_get_info_efi: *** ERROR: Invalid GPT ***
    part_get_info_efi: *** ERROR: Invalid Backup GPT ***
    ERROR: cannot find partition: 'userdata'
    at arch/arm/cpu/armv7/omap-common/utils.c:195/mmc_get_part_size()
    Warning: fastboot.userdata_size: unable to calc
    Net:   <ethaddr> not set. Validating first E-fuse MAC
    Could not get PHY for cpsw: addr 2
    cpsw
    Hit any key to stop autoboot:  0
    J6 ...
    switch to partitions #0, OK
    mmc1(part 0) is current device
    SD/MMC found on device 1
    4403712 bytes read in 220 ms (19.1 MiB/s)
    113603 bytes read in 13 ms (8.3 MiB/s)
    Booting from mmc1 ...
    Kernel image @ 0x82000000 [ 0x000000 - 0x433200 ]
       Loading Device Tree to 8ffe1000, end 8ffffbc2 ... OK
    Starting kernel ...
    [    0.000000] Booting Linux on physical CPU 0x0
    [    0.000000] Linux version 4.19.73-g31275c05a1 (oe-user@oe-host) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36))) #1 SMP PREEMPT Wed Dec 11 12:53:11 UTC 2019
    [    0.000000] CPU: ARMv7 Processor [412fc0f2] revision 2 (ARMv7), cr=30c5387d
    [    0.000000] CPU: div instructions available: patching division code
    [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
    [    0.000000] OF: fdt: Machine model: TI DRA742 Bowei 20170929 17:30
    [    0.000000] Memory policy: Data cache writealloc
    [    0.000000] efi: Getting EFI parameters from FDT:
    [    0.000000] Reserved memory: created CMA memory pool at 0x0000000095800000, size 56 MiB
    [    0.000000] OF: reserved mem: initialized node ipu2_cma@95800000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created CMA memory pool at 0x0000000099000000, size 64 MiB
    [    0.000000] OF: reserved mem: initialized node dsp1_cma@99000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created CMA memory pool at 0x000000009d000000, size 32 MiB
    [    0.000000] OF: reserved mem: initialized node ipu1_cma@9d000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created CMA memory pool at 0x000000009f000000, size 8 MiB
    [    0.000000] OF: reserved mem: initialized node dsp2_cma@9f000000, compatible id shared-dma-pool
    [    0.000000] cma: Reserved 24 MiB at 0x00000000fd400000
    [    0.000000] OMAP4: Map 0x00000000fed00000 to (ptrval) for dram barrier
    [    0.000000] DRA752 ES2.0
    [    0.000000] random: get_random_bytes called from start_kernel+0xb4/0x470 with crng_init=0
    [    0.000000] percpu: Embedded 16 pages/cpu s36492 r8192 d20852 u65536
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 516416
    [    0.000000] Kernel command line: console=ttyO2,115200n8 root=PARTUUID=bddb4f41-02 rw rootfstype=ext4 rootwait consoleblank=0 omapdrm.num_crtc=2 drm.debug=0xff
    [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
    [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
    [    0.000000] Memory: 1847196K/2072576K available (10240K kernel code, 341K rwdata, 2800K rodata, 2048K init, 269K bss, 36964K reserved, 188416K cma-reserved, 1265664K highmem)
    [    0.000000] Virtual kernel memory layout:
    [    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    [    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
    [    0.000000]     vmalloc : 0xf0800000 - 0xff800000   ( 240 MB)
    [    0.000000]     lowmem  : 0xc0000000 - 0xf0000000   ( 768 MB)
    [    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
    [    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
    [    0.000000]       .text : 0x(ptrval) - 0x(ptrval)   (12256 kB)
    [    0.000000]       .init : 0x(ptrval) - 0x(ptrval)   (2048 kB)
    [    0.000000]       .data : 0x(ptrval) - 0x(ptrval)   ( 342 kB)
    [    0.000000]        .bss : 0x(ptrval) - 0x(ptrval)   ( 270 kB)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
    [    0.000000]  Tasks RCU enabled.
    [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
    [    0.000000] ti_dt_clocks_register: missing clkctrl nodes, please update your dts.
    [    0.000000] OMAP clockevent source: timer1 at 31475 Hz
    [    0.000000] arch_timer: cp15 timer(s) running at 5.90MHz (virt).
    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x15c70fb29, max_idle_ns: 440795202138 ns
    [    0.000005] sched_clock: 56 bits at 5MHz, resolution 169ns, wraps every 4398046511093ns
    [    0.000018] Switching to timer-based delay loop, resolution 169ns
    [    0.000352] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns
    [    0.000362] OMAP clocksource: 32k_counter at 32768 Hz
    [    0.000825] Console: colour dummy device 80x30
    [    0.000844] WARNING: Your 'console=ttyO2' has been replaced by 'ttyS2'
    [    0.000852] This ensures that you still see kernel messages. Please
    [    0.000860] update your kernel commandline.
    [    0.000893] Calibrating delay loop (skipped), value calculated using timer frequency.. 11.80 BogoMIPS (lpj=59016)
    [    0.000910] pid_max: default: 32768 minimum: 301
    [    0.001037] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
    [    0.001053] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
    [    0.001614] CPU: Testing write buffer coherency: ok
    [    0.001652] CPU0: Spectre v2: firmware did not set auxiliary control register IBE bit, system vulnerable
    [    0.001863] /cpus/cpu@0 missing clock-frequency property
    [    0.001883] /cpus/cpu@1 missing clock-frequency property
    [    0.001895] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
    [    0.059892] Setting up static identity map for 0x80200000 - 0x80200060
    [    0.079902] rcu: Hierarchical SRCU implementation.
    [    0.100098] EFI services will not be available.
    [    0.119963] smp: Bringing up secondary CPUs ...
    [    0.200303] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
    [    0.200309] CPU1: Spectre v2: using ICIALLU workaround
    [    0.200429] smp: Brought up 1 node, 2 CPUs
    [    0.200442] SMP: Total of 2 processors activated (23.60 BogoMIPS).
    [    0.200451] CPU: All CPU(s) started in SVC mode.
    [    0.200917] devtmpfs: initialized
    [    0.221580] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
    [    0.221840] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
    [    0.221858] futex hash table entries: 512 (order: 3, 32768 bytes)
    [    0.224710] pinctrl core: initialized pinctrl subsystem
    [    0.225222] DMI not present or invalid.
    [    0.225501] NET: Registered protocol family 16
    [    0.226666] DMA: preallocated 256 KiB pool for atomic coherent allocations
    [    0.227660] omap_hwmod: l3_main_2 using broken dt data from ocp
    [    0.249323] omap_hwmod: dma_system: no dt node
    [    0.249333] ------------[ cut here ]------------
    [    0.249356] WARNING: CPU: 0 PID: 1 at arch/arm/mach-omap2/omap_hwmod.c:2409 _init.constprop.22+0x1b0/0x4dc
    [    0.249365] omap_hwmod: dma_system: doesn't have mpu register target base
    [    0.249373] Modules linked in:
    [    0.249391] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 4.19.73-g31275c05a1 #1
    [    0.249401] Hardware name: Generic DRA74X (Flattened Device Tree)
    [    0.249409] Backtrace:
    [    0.249431] [<c020cad4>] (dump_backtrace) from [<c020ce0c>] (show_stack+0x18/0x1c)
    [    0.249443]  r7:c0dcff84 r6:60000013 r5:00000000 r4:c1251ff0
    [    0.249459] [<c020cdf4>] (show_stack) from [<c09f8a60>] (dump_stack+0x90/0xa4)
    [    0.249474] [<c09f89d0>] (dump_stack) from [<c022e1b8>] (__warn+0xdc/0xf8)
    [    0.249485]  r7:c0dcff84 r6:00000009 r5:00000000 r4:ee87bddc
    [    0.249497] [<c022e0dc>] (__warn) from [<c022ddfc>] (warn_slowpath_fmt+0x50/0x6c)
    [    0.249509]  r9:c104b824 r8:00000000 r7:c121252c r6:00000000 r5:c0dd0560 r4:c1204c48
    [    0.249524] [<c022ddb0>] (warn_slowpath_fmt) from [<c100cf2c>] (_init.constprop.22+0x1b0/0x4dc)
    [    0.249534]  r3:c0dd0a04 r2:c0dd0560
    [    0.249543]  r5:00000000 r4:c12124f4
    [    0.249558] [<c100cd7c>] (_init.constprop.22) from [<c100d388>] (__omap_hwmod_setup_all+0x48/0x134)
    [    0.249570]  r10:c10606f4 r9:c104b824 r8:00000000 r7:c100d340 r6:ffffe000 r5:c120a228
    [    0.249579]  r4:c12124f4
    [    0.249594] [<c100d340>] (__omap_hwmod_setup_all) from [<c020265c>] (do_one_initcall+0x84/0x1b0)
    [    0.249604]  r5:c1204c48 r4:c1255740
    [    0.249619] [<c02025d8>] (do_one_initcall) from [<c1000fe8>] (kernel_init_freeable+0x1c4/0x258)
    [    0.249630]  r8:c104b844 r7:c10004f0 r6:c1255740 r5:c1255740 r4:00000003
    [    0.249647] [<c1000e24>] (kernel_init_freeable) from [<c0a0cce8>] (kernel_init+0x10/0x11c)
    [    0.249658]  r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c0a0ccd8
    [    0.249666]  r4:00000000
    [    0.249679] [<c0a0ccd8>] (kernel_init) from [<c02010d8>] (ret_from_fork+0x14/0x3c)
    [    0.249688] Exception stack(0xee87bfb0 to 0xee87bff8)
    [    0.249698] bfa0:                                     00000000 00000000 00000000 00000000
    [    0.249709] bfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [    0.249719] bfe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [    0.249728]  r5:c0a0ccd8 r4:00000000
    [    0.249740] ---[ end trace 53f2d3aef28cd7ec ]---
    [    0.266863] omap_hwmod: hdq1w: no dt node
    [    0.266873] ------------[ cut here ]------------
    [    0.266889] WARNING: CPU: 0 PID: 1 at arch/arm/mach-omap2/omap_hwmod.c:2409 _init.constprop.22+0x1b0/0x4dc
    [    0.266898] omap_hwmod: hdq1w: doesn't have mpu register target base
    [    0.266905] Modules linked in:
    [    0.266922] CPU: 0 PID: 1 Comm: swapper/0 Tainted: G        W         4.19.73-g31275c05a1 #1
    [    0.266931] Hardware name: Generic DRA74X (Flattened Device Tree)
    [    0.266939] Backtrace:
    [    0.266957] [<c020cad4>] (dump_backtrace) from [<c020ce0c>] (show_stack+0x18/0x1c)
    [    0.266969]  r7:c0dcff84 r6:60000013 r5:00000000 r4:c1251ff0
    [    0.266983] [<c020cdf4>] (show_stack) from [<c09f8a60>] (dump_stack+0x90/0xa4)
    [    0.266996] [<c09f89d0>] (dump_stack) from [<c022e1b8>] (__warn+0xdc/0xf8)
    [    0.267007]  r7:c0dcff84 r6:00000009 r5:00000000 r4:ee87bddc
    [    0.267019] [<c022e0dc>] (__warn) from [<c022ddfc>] (warn_slowpath_fmt+0x50/0x6c)
    [    0.267031]  r9:c104b824 r8:00000000 r7:c12117c0 r6:00000000 r5:c0dd0560 r4:c1204c48
    [    0.267045] [<c022ddb0>] (warn_slowpath_fmt) from [<c100cf2c>] (_init.constprop.22+0x1b0/0x4dc)
    [    0.267054]  r3:c0dd26fc r2:c0dd0560
    [    0.267064]  r5:00000000 r4:c1211788
    [    0.267078] [<c100cd7c>] (_init.constprop.22) from [<c100d388>] (__omap_hwmod_setup_all+0x48/0x134)
    [    0.267090]  r10:c10606f4 r9:c104b824 r8:00000000 r7:c100d340 r6:ffffe000 r5:c120a228
    [    0.267098]  r4:c1211788
    [    0.267113] [<c100d340>] (__omap_hwmod_setup_all) from [<c020265c>] (do_one_initcall+0x84/0x1b0)
    [    0.267123]  r5:c1204c48 r4:c1255740
    [    0.267138] [<c02025d8>] (do_one_initcall) from [<c1000fe8>] (kernel_init_freeable+0x1c4/0x258)
    [    0.267150]  r8:c104b844 r7:c10004f0 r6:c1255740 r5:c1255740 r4:00000003
    [    0.267166] [<c1000e24>] (kernel_init_freeable) from [<c0a0cce8>] (kernel_init+0x10/0x11c)
    [    0.267178]  r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c0a0ccd8
    [    0.267186]  r4:00000000
    [    0.267199] [<c0a0ccd8>] (kernel_init) from [<c02010d8>] (ret_from_fork+0x14/0x3c)
    [    0.267208] Exception stack(0xee87bfb0 to 0xee87bff8)
    [    0.267217] bfa0:                                     00000000 00000000 00000000 00000000
    [    0.267227] bfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [    0.267237] bfe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [    0.267246]  r5:c0a0ccd8 r4:00000000
    [    0.267255] ---[ end trace 53f2d3aef28cd7ed ]---
    [    0.298674] omap_hwmod: smartreflex_core: no dt node
    [    0.298684] ------------[ cut here ]------------
    [    0.298699] WARNING: CPU: 0 PID: 1 at arch/arm/mach-omap2/omap_hwmod.c:2409 _init.constprop.22+0x1b0/0x4dc
    [    0.298708] omap_hwmod: smartreflex_core: doesn't have mpu register target base
    [    0.298716] Modules linked in:
    [    0.298731] CPU: 0 PID: 1 Comm: swapper/0 Tainted: G        W         4.19.73-g31275c05a1 #1
    [    0.298740] Hardware name: Generic DRA74X (Flattened Device Tree)
    [    0.298747] Backtrace:
    [    0.298765] [<c020cad4>] (dump_backtrace) from [<c020ce0c>] (show_stack+0x18/0x1c)
    [    0.298777]  r7:c0dcff84 r6:60000013 r5:00000000 r4:c1251ff0
    [    0.298791] [<c020cdf4>] (show_stack) from [<c09f8a60>] (dump_stack+0x90/0xa4)
    [    0.298804] [<c09f89d0>] (dump_stack) from [<c022e1b8>] (__warn+0xdc/0xf8)
    [    0.298815]  r7:c0dcff84 r6:00000009 r5:00000000 r4:ee87bddc
    [    0.298828] [<c022e0dc>] (__warn) from [<c022ddfc>] (warn_slowpath_fmt+0x50/0x6c)
    [    0.298839]  r9:c104b824 r8:00000000 r7:c120fcc8 r6:00000000 r5:c0dd0560 r4:c1204c48
    [    0.298854] [<c022ddb0>] (warn_slowpath_fmt) from [<c100cf2c>] (_init.constprop.22+0x1b0/0x4dc)
    [    0.298863]  r3:c0dd2248 r2:c0dd0560
    [    0.298872]  r5:00000000 r4:c120fc90
    [    0.298886] [<c100cd7c>] (_init.constprop.22) from [<c100d388>] (__omap_hwmod_setup_all+0x48/0x134)
    [    0.298898]  r10:c10606f4 r9:c104b824 r8:00000000 r7:c100d340 r6:ffffe000 r5:c120a228
    [    0.298907]  r4:c120fc90
    [    0.298920] [<c100d340>] (__omap_hwmod_setup_all) from [<c020265c>] (do_one_initcall+0x84/0x1b0)
    [    0.298929]  r5:c1204c48 r4:c1255740
    [    0.298944] [<c02025d8>] (do_one_initcall) from [<c1000fe8>] (kernel_init_freeable+0x1c4/0x258)
    [    0.298955]  r8:c104b844 r7:c10004f0 r6:c1255740 r5:c1255740 r4:00000003
    [    0.298971] [<c1000e24>] (kernel_init_freeable) from [<c0a0cce8>] (kernel_init+0x10/0x11c)
    [    0.298981]  r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c0a0ccd8
    [    0.298989]  r4:00000000
    [    0.299002] [<c0a0ccd8>] (kernel_init) from [<c02010d8>] (ret_from_fork+0x14/0x3c)
    [    0.299011] Exception stack(0xee87bfb0 to 0xee87bff8)
    [    0.299021] bfa0:                                     00000000 00000000 00000000 00000000
    [    0.299032] bfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [    0.299042] bfe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [    0.299051]  r5:c0a0ccd8 r4:00000000
    [    0.299060] ---[ end trace 53f2d3aef28cd7ee ]---
    [    0.300114] omap_hwmod: smartreflex_mpu: no dt node
    [    0.300123] ------------[ cut here ]------------
    [    0.300137] WARNING: CPU: 0 PID: 1 at arch/arm/mach-omap2/omap_hwmod.c:2409 _init.constprop.22+0x1b0/0x4dc
    [    0.300145] omap_hwmod: smartreflex_mpu: doesn't have mpu register target base
    [    0.300152] Modules linked in:
    [    0.300168] CPU: 0 PID: 1 Comm: swapper/0 Tainted: G        W         4.19.73-g31275c05a1 #1
    [    0.300176] Hardware name: Generic DRA74X (Flattened Device Tree)
    [    0.300184] Backtrace:
    [    0.300200] [<c020cad4>] (dump_backtrace) from [<c020ce0c>] (show_stack+0x18/0x1c)
    [    0.300212]  r7:c0dcff84 r6:60000013 r5:00000000 r4:c1251ff0
    [    0.300225] [<c020cdf4>] (show_stack) from [<c09f8a60>] (dump_stack+0x90/0xa4)
    [    0.300238] [<c09f89d0>] (dump_stack) from [<c022e1b8>] (__warn+0xdc/0xf8)
    [    0.300248]  r7:c0dcff84 r6:00000009 r5:00000000 r4:ee87bddc
    [    0.300260] [<c022e0dc>] (__warn) from [<c022ddfc>] (warn_slowpath_fmt+0x50/0x6c)
    [    0.300272]  r9:c104b824 r8:00000000 r7:c120fc54 r6:00000000 r5:c0dd0560 r4:c1204c48
    [    0.300285] [<c022ddb0>] (warn_slowpath_fmt) from [<c100cf2c>] (_init.constprop.22+0x1b0/0x4dc)
    [    0.300295]  r3:c0dd2238 r2:c0dd0560
    [    0.300303]  r5:00000000 r4:c120fc1c
    [    0.300318] [<c100cd7c>] (_init.constprop.22) from [<c100d388>] (__omap_hwmod_setup_all+0x48/0x134)
    [    0.300330]  r10:c10606f4 r9:c104b824 r8:00000000 r7:c100d340 r6:ffffe000 r5:c120a228
    [    0.300338]  r4:c120fc1c
    [    0.300352] [<c100d340>] (__omap_hwmod_setup_all) from [<c020265c>] (do_one_initcall+0x84/0x1b0)
    [    0.300361]  r5:c1204c48 r4:c1255740
    [    0.300376] [<c02025d8>] (do_one_initcall) from [<c1000fe8>] (kernel_init_freeable+0x1c4/0x258)
    [    0.300386]  r8:c104b844 r7:c10004f0 r6:c1255740 r5:c1255740 r4:00000003
    [    0.300401] [<c1000e24>] (kernel_init_freeable) from [<c0a0cce8>] (kernel_init+0x10/0x11c)
    [    0.300412]  r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c0a0ccd8
    [    0.300420]  r4:00000000
    [    0.300432] [<c0a0ccd8>] (kernel_init) from [<c02010d8>] (ret_from_fork+0x14/0x3c)
    [    0.300441] Exception stack(0xee87bfb0 to 0xee87bff8)
    [    0.300451] bfa0:                                     00000000 00000000 00000000 00000000
    [    0.300461] bfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [    0.300471] bfe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [    0.300480]  r5:c0a0ccd8 r4:00000000
    [    0.300503] ---[ end trace 53f2d3aef28cd7ef ]---
    [    0.413727] cpuidle: using governor ladder
    [    0.413762] cpuidle: using governor menu
    [    0.420395] OMAP GPIO hardware version 0.1
    [    0.423350] GPIO line 161 (radio_rst) hogged as output/low
    [    0.449103] No ATAGs?
    [    0.449182] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
    [    0.449198] hw-breakpoint: maximum watchpoint size is 8 bytes.
    [    0.449234] omap_device: omap_dma_system: build failed (-22)
    [    0.449245] omap2_system_dma_init_dev: Can't build omap_device for omap_dma_system:dma_system.
    [    0.449617] omap4_sram_init:Unable to allocate sram needed to handle errata I688
    [    0.449628] omap4_sram_init:Unable to get sram pool needed to handle errata I688
    [    0.461236] edma 43300000.edma: memcpy is disabled
    [    0.464490] edma 43300000.edma: TI EDMA DMA engine driver
    [    0.468860] omap-iommu 40d01000.mmu: 40d01000.mmu registered
    [    0.469038] omap-iommu 40d02000.mmu: 40d02000.mmu registered
    [    0.469268] omap-iommu 58882000.mmu: 58882000.mmu registered
    [    0.469500] omap-iommu 55082000.mmu: 55082000.mmu registered
    [    0.469891] omap-iommu 41501000.mmu: 41501000.mmu registered
    [    0.470063] omap-iommu 41502000.mmu: 41502000.mmu registered
    [    0.470321] iommu: Adding device 58820000.ipu to group 1
    [    0.470395] iommu: Adding device 55020000.ipu to group 2
    [    0.470518] iommu: Adding device 40800000.dsp to group 0
    [    0.470755] iommu: Adding device 41000000.dsp to group 3
    [    0.472051] SCSI subsystem initialized
    [    0.473214] palmas 0-0058: IRQ missing: skipping irq request
    [    0.502012] palmas 0-0058: Muxing GPIO a, PWM 0, LED 0
    [    0.503460] SMPS12: supplied by regulator-dummy
    [    0.504494] SMPS3: supplied by regulator-dummy
    [    0.505977] SMPS45: supplied by regulator-dummy
    [    0.507899] SMPS6: supplied by regulator-dummy
    [    0.509678] SMPS7: supplied by regulator-dummy
    [    0.511619] SMPS8: supplied by regulator-dummy
    [    0.513416] SMPS9: supplied by regulator-dummy
    [    0.514430] LDO1: supplied by regulator-dummy
    [    0.522497] LDO2: supplied by regulator-dummy
    [    0.532355] LDO3: supplied by regulator-dummy
    [    0.542366] LDO4: supplied by regulator-dummy
    [    0.542480] random: fast init done
    [    0.543106] LDO5: supplied by regulator-dummy
    [    0.543822] LDO6: supplied by regulator-dummy
    [    0.544536] LDO7: supplied by regulator-dummy
    [    0.545258] LDO8: supplied by regulator-dummy
    [    0.545983] LDO9: supplied by regulator-dummy
    [    0.552407] LDOLN: supplied by regulator-dummy
    [    0.562428] LDOUSB: supplied by regulator-dummy
    [    0.574354] omap_i2c 48070000.i2c: bus 0 rev0.12 at 400 kHz
    [    0.575034] omap_i2c 48072000.i2c: bus 1 rev0.12 at 400 kHz
    [    0.575434] omap_i2c 48060000.i2c: bus 2 rev0.12 at 400 kHz
    [    0.575819] omap_i2c 4807a000.i2c: bus 3 rev0.12 at 400 kHz
    [    0.576208] omap_i2c 4807c000.i2c: bus 4 rev0.12 at 400 kHz
    [    0.576442] media: Linux media interface: v0.10
    [    0.576481] videodev: Linux video capture interface: v2.00
    [    0.576554] pps_core: LinuxPPS API ver. 1 registered
    [    0.576564] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.576585] PTP clock support registered
    [    0.576615] EDAC MC: Ver: 3.0.0
    [    0.577357] omap-mailbox 48840000.mailbox: omap mailbox rev 0x400
    [    0.577608] omap-mailbox 48842000.mailbox: omap mailbox rev 0x400
    [    0.578128] Advanced Linux Sound Architecture Driver Initialized.
    [    0.578905] clocksource: Switched to clocksource arch_sys_counter
    [    0.586764] NET: Registered protocol family 2
    [    0.587353] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
    [    0.587382] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
    [    0.587446] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
    [    0.587573] TCP: Hash tables configured (established 8192 bind 8192)
    [    0.587646] UDP hash table entries: 512 (order: 2, 16384 bytes)
    [    0.587680] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
    [    0.587809] NET: Registered protocol family 1
    [    0.608247] RPC: Registered named UNIX socket transport module.
    [    0.608257] RPC: Registered udp transport module.
    [    0.608266] RPC: Registered tcp transport module.
    [    0.608275] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.609320] hw perfevents: no interrupt-affinity property for /pmu, guessing.
    [    0.609542] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
    [    0.610512] Initialise system trusted keyrings
    [    0.610637] workingset: timestamp_bits=14 max_order=19 bucket_order=5
    [    0.615512] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.626001] NFS: Registering the id_resolver key type
    [    0.626021] Key type id_resolver registered
    [    0.626030] Key type id_legacy registered
    [    0.626072] ntfs: driver 2.1.32 [Flags: R/O].
    [    0.627627] Key type asymmetric registered
    [    0.627639] Asymmetric key parser 'x509' registered
    [    0.627686] bounce: pool size: 64 pages
    [    0.627721] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
    [    0.627732] io scheduler noop registered
    [    0.627741] io scheduler deadline registered
    [    0.627838] io scheduler cfq registered (default)
    [    0.627849] io scheduler mq-deadline registered
    [    0.627859] io scheduler kyber registered
    [    0.632793] pinctrl-single 4a003400.pinmux: please update dts to use #pinctrl-cells = <1>
    [    0.633318] pinctrl-single 4a003400.pinmux: 282 pins, size 1128
    [    0.640553] pbias_mmc_omap5: Bringing 3300000uV into 3000000-3000000uV
    [    0.640569] pbias_mmc_omap5: failed to apply 3000000-3000000uV constraint(-22)
    [    0.640584] pbias-regulator 4a002e00.pbias_regulator: Failed to register regulator: -22
    [    0.640607] pbias-regulator: probe of 4a002e00.pbias_regulator failed with error -22
    [    0.641433] evm_3v3_sw: supplied by sysen1
    [    0.641672] aic_dvdd: supplied by evm_3v3_sw
    [    0.641746] vtt_fixed: supplied by sysen2
    [    0.684673] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
    [    0.688596] 4806a000.serial: ttyS0 at MMIO 0x4806a000 (irq = 43, base_baud = 3000000) is a 8250
    [    0.689534] 4806c000.serial: ttyS1 at MMIO 0x4806c000 (irq = 44, base_baud = 3000000) is a 8250
    [    0.690440] 48020000.serial: ttyS2 at MMIO 0x48020000 (irq = 45, base_baud = 3000000) is a 8250
    [    2.662588] console [ttyS2] enabled
    [    2.667015] 48066000.serial: ttyS4 at MMIO 0x48066000 (irq = 46, base_baud = 3000000) is a 8250
    [    2.676670] 48068000.serial: ttyS5 at MMIO 0x48068000 (irq = 47, base_baud = 3000000) is a 8250
    [    2.686320] 48424000.serial: ttyS8 at MMIO 0x48424000 (irq = 48, base_baud = 3000000) is a 8250
    [    2.695978] 4ae2b000.serial: ttyS9 at MMIO 0x4ae2b000 (irq = 49, base_baud = 3000000) is a 8250
    [    2.707068] omap_rng 48090000.rng: Random Number Generator ver. 20
    [    2.707405] random: crng init done
    [    2.717505] omapdss_dss 58000000.dss: Linked as a consumer to regulator.22
    [    2.724599] DSS: OMAP DSS rev 6.1
    [    2.729644] omapdss_dss 58000000.dss: bound 58001000.dispc (ops dispc_component_ops)
    [    2.750327] brd: module loaded
    [    2.759517] loop: module loaded
    [    2.768957] libphy: Fixed MDIO Bus: probed
    [    2.828934] davinci_mdio 48485000.mdio: davinci mdio revision 1.6, bus freq 1000000
    [    2.836627] davinci_mdio 48485000.mdio: no live phy, scanning all
    [    2.939022] davinci_mdio 48485000.mdio: timed out waiting for user access
    [    3.045927] davinci_mdio 48485000.mdio: timed out waiting for idle
    [    3.052180] davinci_mdio: probe of 48485000.mdio failed with error -5
    [    3.059289] cpsw 48484000.ethernet: Detected MACID = 54:45:38:a7:aa:1e
    [    3.065891] cpsw 48484000.ethernet: initialized cpsw ale version 1.4
    [    3.072295] cpsw 48484000.ethernet: ALE Table size 1024
    [    3.077569] cpsw 48484000.ethernet: cpts: overflow check period 500 (jiffies)
    [    3.085580] cpsw 48484000.ethernet: cpsw: Detected MACID = 54:45:38:a7:aa:1f
    [    3.094209] i2c /dev entries driver
    [    3.102604] cpu cpu0: "syscon" is missing, cannot use OPPv2 table.
    [    3.109347] sdhci: Secure Digital Host Controller Interface driver
    [    3.115555] sdhci: Copyright(c) Pierre Ossman
    [    3.120930] omap_hsmmc: probe of 4809c000.mmc failed with error -22
    [    3.127666] omap_hsmmc 480b4000.mmc: RX DMA channel request failed
    [    3.134325] omap_hsmmc 480d1000.mmc: RX DMA channel request failed
    [    3.140842] sdhci-pltfm: SDHCI platform and OF driver helper
    [    3.147883] ledtrig-cpu: registered to indicate activity on CPUs
    [    3.158457] pinctrl-single 4a003400.pinmux: pin PIN170 already requested by 4806a000.serial; cannot claim for 48460000.mcasp
    [    3.169766] pinctrl-single 4a003400.pinmux: pin-170 (48460000.mcasp) status -22
    [    3.177113] pinctrl-single 4a003400.pinmux: could not request pin 170 (PIN170) from group mcasp1_pins  on device pinctrl-single
    [    3.188662] davinci-mcasp 48460000.mcasp: Error applying setting, reverse things back
    [    3.196555] davinci-mcasp: probe of 48460000.mcasp failed with error -22
    [    3.203365] pinctrl-single 4a003400.pinmux: pin PIN192 already requested by 4806a000.serial; cannot claim for 48464000.mcasp
    [    3.214653] pinctrl-single 4a003400.pinmux: pin-192 (48464000.mcasp) status -22
    [    3.222021] pinctrl-single 4a003400.pinmux: could not request pin 192 (PIN192) from group mcasp2_pins  on device pinctrl-single
    [    3.233565] davinci-mcasp 48464000.mcasp: Error applying setting, reverse things back
    [    3.241452] davinci-mcasp: probe of 48464000.mcasp failed with error -22
    [    3.248237] pinctrl-single 4a003400.pinmux: pin PIN203 already requested by 4806a000.serial; cannot claim for 48468000.mcasp
    [    3.259523] pinctrl-single 4a003400.pinmux: pin-203 (48468000.mcasp) status -22
    [    3.266867] pinctrl-single 4a003400.pinmux: could not request pin 203 (PIN203) from group mcasp3_pins  on device pinctrl-single
    [    3.278408] davinci-mcasp 48468000.mcasp: Error applying setting, reverse things back
    [    3.286294] davinci-mcasp: probe of 48468000.mcasp failed with error -22
    [    3.293092] pinctrl-single 4a003400.pinmux: pin PIN205 already requested by 4806a000.serial; cannot claim for 4846c000.mcasp
    [    3.304377] pinctrl-single 4a003400.pinmux: pin-205 (4846c000.mcasp) status -22
    [    3.311736] pinctrl-single 4a003400.pinmux: could not request pin 205 (PIN205) from group mcasp4_pins  on device pinctrl-single
    [    3.323278] davinci-mcasp 4846c000.mcasp: Error applying setting, reverse things back
    [    3.331166] davinci-mcasp: probe of 4846c000.mcasp failed with error -22
    [    3.337955] pinctrl-single 4a003400.pinmux: pin PIN200 already requested by 4806a000.serial; cannot claim for 4847c000.mcasp
    [    3.349246] pinctrl-single 4a003400.pinmux: pin-200 (4847c000.mcasp) status -22
    [    3.356590] pinctrl-single 4a003400.pinmux: could not request pin 200 (PIN200) from group mcasp8_pins  on device pinctrl-single
    [    3.368134] davinci-mcasp 4847c000.mcasp: Error applying setting, reverse things back
    [    3.376023] davinci-mcasp: probe of 4847c000.mcasp failed with error -22
    [    3.383480] NET: Registered protocol family 10
    [    3.388888] Segment Routing with IPv6
    [    3.392659] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
    [    3.399094] NET: Registered protocol family 17
    [    3.403756] Key type dns_resolver registered
    [    3.408154] Registering SWP/SWPB emulation handler
    [    3.412990] omap_voltage_late_init: Voltage driver support not added
    [    3.419391] Power Management for TI OMAP4+ devices.
    [    3.424978] Loading compiled-in X.509 certificates
    [    3.446882] dmm 4e000000.dmm: failed to initialize work-around for i878
    [    3.455039] dmm 4e000000.dmm: initialized all PAT entries
    [    3.461135] omapdrm omapdrm.0: omap_modeset_init failed: ret=-517
    [    3.468175] omapdrm omapdrm.0: omap_modeset_init failed: ret=-517
    [    3.475138] omapdrm omapdrm.0: omap_modeset_init failed: ret=-517
    [    3.481870] hctosys: unable to open rtc device (rtc0)
    [    3.487585] aic_dvdd: disabling
    [    3.490956] ldousb: disabling
    [    3.494251] ALSA device list:
    [    3.497232]   No soundcards found.
    [    3.501323] Waiting for root device PARTUUID=bddb4f41-02...
    * DRA746 eMMC1 interface boots with eMMC flash, include TS3A27518, VDD 1.8V, IO 1.8V ? please confirm?  log as below?
    I think you can post device tree here, base on this log case.
    DRA752-GP ES2.0
    reading args
    reading u-boot.img
    reading u-boot.img
    I2C:   ready
    DRAM:  2 GiB
    cpsw
    J6 ...
    4281344 bytes read in 213 ms (19.2 MiB/s)
    113071 bytes read in 12 ms (9 MiB/s)
    Kernel image @ 0x82000000 [ 0x000000 - 0x415400 ]
       Loading Device Tree to 8ffe1000, end 8ffff9ae ... OK
    Starting kernel ...
    [    0.000000] Initializing cgroup subsys cpuset
    [    0.000000] Initializing cgroup subsys cpuacct
    [    0.000000] Linux version 4.4.45 (bowei@bowei-Veriton-M490) (gcc version 5.3.1 20160113 (Linaro GCC 5.3-2016.02) ) #75 SMP PREEMPT Mon Jan 22 10:50:18 CST 2018
    [    0.000000] CPU: ARMv7 Processor [412fc0f2] revision 2 (ARMv7), cr=10c5387d
    [    0.000000] Machine model: TI DRA742 Louis 20170929 17:30
    [    0.000000] Reserved memory: created CMA memory pool at 0x95800000, size 56 MiB
    [    0.000000] Reserved memory: initialized node ipu2_cma@95800000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created CMA memory pool at 0x99000000, size 64 MiB
    [    0.000000] Reserved memory: initialized node dsp1_cma@99000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created CMA memory pool at 0x9d000000, size 32 MiB
    [    0.000000] Reserved memory: initialized node ipu1_cma@9d000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created CMA memory pool at 0x9f000000, size 8 MiB
    [    0.000000] Reserved memory: initialized node dsp2_cma@9f000000, compatible id shared-dma-pool
    [    0.000000] cma: Reserved 24 MiB at 0xfd400000
    [    0.000000] OMAP4: Map 0xfee00000 to fe600000 for dram barrier
    [    0.000000] PERCPU: Embedded 12 pages/cpu @eed51000 s18944 r8192 d22016 u49152
    [    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 516672
    [    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
    [    0.000000] Memory: 1851432K/2073600K available (7719K kernel code, 797K rwdata, 4560K rodata, 372K init, 291K bss, 33752K reserved, 188416K cma-reserved, 1266688K highmem)
    [    0.000000]       .text : 0xc0008000 - 0xc0c0607c   (12281 kB)
    [    0.000000]       .init : 0xc0c07000 - 0xc0c64000   ( 372 kB)
    [    0.000000]       .data : 0xc0c64000 - 0xc0d2b530   ( 798 kB)
    [    0.000000]        .bss : 0xc0d2d000 - 0xc0d75f00   ( 292 kB)
    [    0.000000] Preemptible hierarchical RCU implementation.
    [    0.000000]  Build-time adjustment of leaf fanout to 32.
    [    0.000000] NR_IRQS:16 nr_irqs:16 16
    [    0.000000] ti_dt_clocks_register: failed to lookup clock node gmac_gmii_ref_clk_div
    [    0.000000] Architected cp15 timer(s) running at 5.90MHz (virt).
    [    0.000004] sched_clock: 56 bits at 5MHz, resolution 169ns, wraps every 4398046511093ns
    [    0.000015] Switching to timer-based delay loop, resolution 169ns
    [    0.000325] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns
    [    0.000333] OMAP clocksource: 32k_counter at 32768 Hz
    [    0.000786] Console: colour dummy device 80x30
    [    0.000803] WARNING: Your 'console=ttyO2' has been replaced by 'ttyS2'
    [    0.000810] This ensures that you still see kernel messages. Please
    [    0.000816] update your kernel commandline.
    [    0.000828] Calibrating delay loop (skipped), value calculated using timer frequency.. 11.80 BogoMIPS (lpj=59016)
    [    0.000841] pid_max: default: 32768 minimum: 301
    [    0.000934] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
    [    0.000944] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
    [    0.001474] Initializing cgroup subsys io
    [    0.001492] Initializing cgroup subsys memory
    [    0.001515] Initializing cgroup subsys devices
    [    0.001528] Initializing cgroup subsys freezer
    [    0.001539] Initializing cgroup subsys perf_event
    [    0.001550] Initializing cgroup subsys pids
    [    0.001576] CPU: Testing write buffer coherency: ok
    [    0.001771] /cpus/cpu@0 missing clock-frequency property
    [    0.001787] /cpus/cpu@1 missing clock-frequency property
    [    0.001797] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
    [    0.001837] Setting up static identity map for 0x80008340 - 0x800083a0
    [    0.080051] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
    [    0.080113] Brought up 2 CPUs
    [    0.080126] SMP: Total of 2 processors activated (23.60 BogoMIPS).
    [    0.080133] CPU: All CPU(s) started in SVC mode.
    [    0.081170] devtmpfs: initialized
    [    0.111084] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
    [    0.112068] omap_hwmod: l3_main_2 using broken dt data from ocp
    [    0.310433] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
    [    0.314133] pinctrl core: initialized pinctrl subsystem
    [    0.314996] NET: Registered protocol family 16
    [    0.315935] DMA: preallocated 256 KiB pool for atomic coherent allocations
    [    0.340217] cpuidle: using governor ladder
    [    0.370240] cpuidle: using governor menu
    [    0.378504] OMAP GPIO hardware version 0.1
    [    0.382624] GPIO line 161 (radio_rst) hogged as output/low
    [    0.414591] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
    [    0.414601] hw-breakpoint: maximum watchpoint size is 8 bytes.
    [    0.415081] omap4_sram_init:Unable to allocate sram needed to handle errata I688
    [    0.415090] omap4_sram_init:Unable to get sram pool needed to handle errata I688
    [    0.415576] OMAP DMA hardware revision 0.0
    [    0.461550] omap-dma-engine 4a056000.dma-controller: OMAP DMA engine driver (LinkedList1/2/3 supported)
    [    0.462798] edma 43300000.edma: memcpy is disabled
    [    0.467537] edma 43300000.edma: TI EDMA DMA engine driver
    [    0.471761] omap-iommu 40d01000.mmu: 40d01000.mmu registered
    [    0.471943] omap-iommu 40d02000.mmu: 40d02000.mmu registered
    [    0.472102] omap-iommu 58882000.mmu: 58882000.mmu registered
    [    0.472260] omap-iommu 55082000.mmu: 55082000.mmu registered
    [    0.472557] omap-iommu 41501000.mmu: 41501000.mmu registered
    [    0.472749] omap-iommu 41502000.mmu: 41502000.mmu registered
    [    0.474753] SCSI subsystem initialized
    [    0.476005] ======palmas_i2c_probe:526========
    [    0.476022] ======palmas_i2c_probe:559, features=0x0========
    [    0.476333] palmas 0-0058: IRQ missing: skipping irq request
    [    0.491064] palmas 0-0058: Muxing GPIO a, PWM 0, LED 0
    [    0.562796] omap_i2c 48070000.i2c: bus 0 rev0.12 at 400 kHz
    [    0.563432] omap_i2c 48072000.i2c: bus 1 rev0.12 at 400 kHz
    [    0.563797] omap_i2c 48060000.i2c: bus 2 rev0.12 at 400 kHz
    [    0.564169] omap_i2c 4807a000.i2c: bus 3 rev0.12 at 400 kHz
    [    0.564534] omap_i2c 4807c000.i2c: bus 4 rev0.12 at 400 kHz
    [    0.564756] media: Linux media interface: v0.10
    [    0.564806] Linux video capture interface: v2.00
    [    0.564844] pps_core: LinuxPPS API ver. 1 registered
    [    0.564851] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.564874] PTP clock support registered
    [    0.564900] EDAC MC: Ver: 3.0.0
    [    0.565665] omap-mailbox 48840000.mailbox: omap mailbox rev 0x400
    [    0.565959] omap-mailbox 48842000.mailbox: omap mailbox rev 0x400
    [    0.566304] Advanced Linux Sound Architecture Driver Initialized.
    [    0.567188] clocksource: Switched to clocksource arch_sys_counter
    [    0.577940] NET: Registered protocol family 2
    [    0.578431] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
    [    0.578494] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
    [    0.578619] TCP: Hash tables configured (established 8192 bind 8192)
    [    0.578665] UDP hash table entries: 512 (order: 2, 16384 bytes)
    [    0.578698] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
    [    0.578907] NET: Registered protocol family 1
    [    0.579172] RPC: Registered named UNIX socket transport module.
    [    0.579181] RPC: Registered udp transport module.
    [    0.579187] RPC: Registered tcp transport module.
    [    0.579193] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.580238] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
    [    0.582696] futex hash table entries: 512 (order: 3, 32768 bytes)
    [    0.589425] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.590074] NFS: Registering the id_resolver key type
    [    0.590098] Key type id_resolver registered
    [    0.590106] Key type id_legacy registered
    [    0.590171] ntfs: driver 2.1.32 [Flags: R/O].
    [    0.592152] bounce: pool size: 64 pages
    [    0.592306] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
    [    0.592323] io scheduler noop registered
    [    0.592337] io scheduler deadline registered
    [    0.592371] io scheduler cfq registered (default)
    [    0.597689] pinctrl-single 4a003400.pinmux: 282 pins at pa fc003400 size 1128
    [    0.658363] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
    [    0.661951] 4806a000.serial: ttyS0 at MMIO 0x4806a000 (irq = 299, base_baud = 3000000) is a 8250
    [    0.662826] 4806c000.serial: ttyS1 at MMIO 0x4806c000 (irq = 300, base_baud = 3000000) is a 8250
    [    0.663687] console [ttyS2] disabled
    [    0.663732] 48020000.serial: ttyS2 at MMIO 0x48020000 (irq = 301, base_baud = 3000000) is a 8250
    [    1.550527] console [ttyS2] enabled
    [    1.554926] 48066000.serial: ttyS4 at MMIO 0x48066000 (irq = 302, base_baud = 3000000) is a 8250
    [    1.564654] 48068000.serial: ttyS5 at MMIO 0x48068000 (irq = 303, base_baud = 3000000) is a 8250
    [    1.574335] 48424000.serial: ttyS8 at MMIO 0x48424000 (irq = 304, base_baud = 3000000) is a 8250
    [    1.584013] 4ae2b000.serial: ttyS9 at MMIO 0x4ae2b000 (irq = 305, base_baud = 3000000) is a 8250
    [    1.594154] [drm] Initialized drm 1.1.0 20060810
    [    1.600370] OMAP DSS rev 6.1
    [    1.604134] omapdss_dss 58000000.dss: bound 58001000.dispc (ops dispc_component_ops)
    [    1.625872] brd: module loaded
    [    1.634088] loop: module loaded
    [    1.643758] libphy: Fixed MDIO Bus: probed
    [    1.648467] e1000: Intel(R) PRO/1000 Network Driver - version 7.3.21-k8-NAPI
    [    1.655547] e1000: Copyright (c) 1999-2006 Intel Corporation.
    [    1.661395] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
    [    1.667267] e1000e: Copyright(c) 1999 - 2015     2.019967] tvp5158 1-0058: ERROR: Chip id is not TVP5158
    [    2.025505] ov1063x 1-0037: ov1063x Product ID 0 Manufacturer ID 0
    [    2.031731] ov1063x 1-0037: ov1063x 1-0037 sensor driver registered !!
    [    2.039140] vpe 489d0000.vpe: loading firmware vpdma-1b8.bin
    [    2.046236] vip 48990000.vip: loading firmware vpdma-1b8.bin
    [    2.055636] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr104 mode
    [    2.062254] omap_hsmmc 4809c000.mmc: no pinctrl state for ddr50 mode
    [    2.068685] vpe 489d0000.vpe: Device registered as /dev/video0
    [    2.074558] vip 48990000.vip: VPDMA firmware loaded
    [    2.079496] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr50 mode
    [    2.079606] vip2-s1: Port B: Using subdev ov1063x 1-0037 for capture
    [    2.092316] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr25 mode
    [    2.092334] vip2-s1: device registered as video1
    [    2.103347] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr12 mode
    [    2.110958] ldo1: voltage operation not allowed
    [    2.115512] omap_hsmmc 4809c000.mmc: vmmc_aux set voltage failed
    [    2.121567] omap_hsmmc 4809c000.mmc: failed to switch to 3v
    [    2.167614] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr25 mode
    [    2.173998] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr12 mode
    [    2.180403] omap_hsmmc 480b4000.mmc: no pinctrl state for hs200_1_8v mode
    [    2.187373] evm_3v3_sw: supplied by sysen1
    [    2.227553] omap_hsmmc 480d1000.mmc: no pinctrl state for sdr25 mode
    [    2.233936] omap_hsmmc 480d1000.mmc: no pinctrl state for sdr12 mode
    [    2.240334] omap_hsmmc 480d1000.mmc: no pinctrl state for hs mode
    [    2.278007] ledtrig-cpu: registered to indicate activity on CPUs
    [    2.286092] hwspinlock_user gatemp: requested 10 hwspinlocks
    [    2.307085] pinctrl-single 4a003400.pinmux: pin 4a0036a8.0 already requested by 4806a000.serial; cannot claim for 48460000.mcasp
    [    2.318722] pinctrl-single 4a003400.pinmux: pin-170 (48460000.mcasp) status -22
    [    2.326065] pinctrl-single 4a003400.pinmux: could not request pin 170 (4a0036a8.0) from group mcasp1_pins  on device pinctrl-single
    [    2.337990] davinci-mcasp 48460000.mcasp: Error applying setting, reverse things back
    [    2.346265] davinci-mcasp 48460000.mcasp: Update the bindings to use assigned-clocks!
    [    2.354169] davinci-mcasp 48460000.mcasp: failed to reparent fck
    [    2.360453] pinctrl-single 4a003400.pinmux: pin 4a003700.0 already requested by 4806a000.serial; cannot claim for 48464000.mcasp
    [    2.372083] pinctrl-single 4a003400.pinmux: pin-192 (48464000.mcasp) status -22
    [    2.379466] pinctrl-single 4a003400.pinmux: could not request pin 192 (4a003700.0) from group mcasp2_pins  on device pinctrl-single
    [    2.391353] davinci-mcasp 48464000.mcasp: Error applying setting, reverse things back
    [    2.399601] davinci-mcasp 48464000.mcasp: Update the bindings to use assigned-clocks!
    [    2.407503] davinci-mcasp 48464000.mcasp: failed to reparent fck
    [    2.413764] pinctrl-single 4a003400.pinmux: pin 4a00372c.0 already requested by 4806a000.serial; cannot claim for 48468000.mcasp
    [    2.425394] pinctrl-single 4a003400.pinmux: pin-203 (48468000.mcasp) status -22
    [    2.432746] pinctrl-single 4a003400.pinmux: could not request pin 203 (4a00372c.0) from group mcasp3_pins  on device pinctrl-single
    [    2.444630] davinci-mcasp 48468000.mcasp: Error applying setting, reverse things back
    [    2.452883] davinci-mcasp 48468000.mcasp: Update the bindings to use assigned-clocks!
    [    2.460781] davinci-mcasp 48468000.mcasp: failed to reparent fck
    [    2.467029] pinctrl-single 4a003400.pinmux: pin 4a003734.0 already requested by 4806a000.serial; cannot claim for 4846c000.mcasp
    [    2.478659] pinctrl-single 4a003400.pinmux: pin-205 (4846c000.mcasp) status -22
    [    2.486000] pinctrl-single 4a003400.pinmux: could not request pin 205 (4a003734.0) from group mcasp4_pins  on device pinctrl-single
    [    2.497884] davinci-mcasp 4846c000.mcasp: Error applying setting, reverse things back
    [    2.506119] davinci-mcasp 4846c000.mcasp: Update the bindings to use assigned-clocks!
    [    2.514017] davinci-mcasp 4846c000.mcasp: failed to reparent fck
    [    2.520274] pinctrl-single 4a003400.pinmux: pin 4a003720.0 already requested by 4806a000.serial; cannot claim for 4847c000.mcasp
    [    2.531903] pinctrl-single 4a003400.pinmux: pin-200 (4847c000.mcasp) status -22
    [    2.539259] pinctrl-single 4a003400.pinmux: could not request pin 200 (4a003720.0) from group mcasp8_pins  on device pinctrl-single
    [    2.551144] davinci-mcasp 4847c000.mcasp: Error applying setting, reverse things back
    [    2.559399] davinci-mcasp 4847c000.mcasp: Update the bindings to use assigned-clocks!
    [    2.567295] davinci-mcasp 4847c000.mcasp: failed to reparent fck
    [    2.574511] NET: Registered protocol family 10
    [    2.589790] sit: IPv6 over IPv4 tunneling driver
    [    2.594962] NET: Registered protocol family 17
    [    2.599689] Key type dns_resolver registered
    [    2.604103] omap_voltage_late_init: Voltage driver support not added
    [    2.611013] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
    [    2.617234] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
    [    2.623486] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
    [    2.630118] Power Management for TI OMAP4+ devices.
    [    2.635259] Registering SWP/SWPB emulation handler
    [    2.642711] dmm 4e000000.dmm: initialized all PAT entries
    [    2.670836] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
    [    2.677498] [drm] No driver support for vblank timestamp query.
    [    2.694269] [drm] Enabling DMM ywrap scrolling
    [    2.700353] mmc0: MAN_BKOPS_EN bit is not set
    [    2.766111] mmc0: new high speed MMC card at address 0001
    [    2.769704] Console: switching to colour frame buffer device 240x67
    [    2.776758] mmcblk0: mmc0:0001 R1J55A 7.28 GiB
    [    2.787071] mmcblk0boot0: mmc0:0001 R1J55A partition 1 128 KiB
    [    2.787361] mmcblk0boot1: mmc0:0001 R1J55A partition 2 128 KiB
    [    2.789666]  mmcblk0: p1
    [    2.819602] omapdrm omapdrm.0: fb0: omapdrm frame buffer device
    [    2.840325] mmc1: MAN_BKOPS_EN bit is not set
    [    2.848456] [drm] Initialized omapdrm 1.0.0 20110917 on minor 0
    [    2.876112] asoc-simple-card-mcasp1 sound@1: bt-sco-pcm-mcasp1 <-> 48460000.mcasp mapping ok
    [    2.885192] asoc-simple-card-mcasp1 sound@1: ASoC: no source widget found for HPLOUT
    [    2.895052] asoc-simple-card-mcasp1 sound@1: ASoC: Failed to add route HPLOUT -> direct -> Headphone Jack
    [    2.904698] asoc-simple-card-mcasp1 sound@1: ASoC: no source widget found for HPROUT
    [    2.912491] asoc-simple-card-mcasp1 sound@1: ASoC: Failed to add route HPROUT -> direct -> Headphone Jack
    [    2.922113] asoc-simple-card-mcasp1 sound@1: ASoC: no source widget found for LLOUT
    [    2.929912] asoc-simple-card-mcasp1 sound@1: ASoC: Failed to add route LLOUT -> direct -> Line Out
    [    2.938926] asoc-simple-card-mcasp1 sound@1: ASoC: no source widget found for RLOUT
    [    2.946616] asoc-simple-card-mcasp1 sound@1: ASoC: Failed to add route RLOUT -> direct -> Line Out
    [    2.955625] asoc-simple-card-mcasp1 sound@1: ASoC: no sink widget found for MIC3L
    [    2.963148] asoc-simple-card-mcasp1 sound@1: ASoC: Failed to add route Mic Jack -> direct -> MIC3L
    [    2.972157] asoc-simple-card-mcasp1 sound@1: ASoC: no sink widget found for MIC3R
    [    2.979688] asoc-simple-card-mcasp1 sound@1: ASoC: Failed to add route Mic Jack -> direct -> MIC3R
    [    2.988698] asoc-simple-card-mcasp1 sound@1: ASoC: no source widget found for Mic Bias
    [    2.996648] asoc-simple-card-mcasp1 sound@1: ASoC: Failed to add route Mic Bias -> direct -> Mic Jack
    [    3.005920] asoc-simple-card-mcasp1 sound@1: ASoC: no sink widget found for LINE1L
    [    3.013570] asoc-simple-card-mcasp1 sound@1: ASoC: Failed to add route Line In -> direct -> LINE1L
    [    3.022585] asoc-simple-card-mcasp1 sound@1: ASoC: no sink widget found for LINE1R
    [    3.030200] asoc-simple-card-mcasp1 sound@1: ASoC: Failed to add route Line In -> direct -> LINE1R
    [    3.041140] asoc-simple-card-mcasp2 sound@2: bt-sco-pcm-mcasp2 <-> 48464000.mcasp mapping ok
    [    3.049640] asoc-simple-card-mcasp2 sound@2: ASoC: no source widget found for HPLOUT
    [    3.057436] asoc-simple-card-mcasp2 sound@2: ASoC: Failed to add route HPLOUT -> direct -> Headphone Jack
    [    3.067046] asoc-simple-card-mcasp2 sound@2: ASoC: no source widget found for HPROUT
    [    3.074836] asoc-simple-card-mcasp2 sound@2: ASoC: Failed to add route HPROUT -> direct -> Headphone Jack
    [    3.084456] asoc-simple-card-mcasp2 sound@2: ASoC: no source widget found for LLOUT
    [    3.092158] asoc-simple-card-mcasp2 sound@2: ASoC: Failed to add route LLOUT -> direct -> Line Out
    [    3.101190] asoc-simple-card-mcasp2 sound@2: ASoC: no source widget found for RLOUT
    [    3.108899] asoc-simple-card-mcasp2 sound@2: ASoC: Failed to add route RLOUT -> direct -> Line Out
    [    3.117910] asoc-simple-card-mcasp2 sound@2: ASoC: no sink widget found for MIC3L
    [    3.125425] asoc-simple-card-mcasp2 sound@2: ASoC: Failed to add route Mic Jack -> direct -> MIC3L
    [    3.134431] asoc-simple-card-mcasp2 sound@2: ASoC: no sink widget found for MIC3R
    [    3.141957] asoc-simple-card-mcasp2 sound@2: ASoC: Failed to add route Mic Jack -> direct -> MIC3R
    [    3.150966] asoc-simple-card-mcasp2 sound@2: ASoC: no source widget found for Mic Bias
    [    3.158928] asoc-simple-card-mcasp2 sound@2: ASoC: Failed to add route Mic Bias -> direct -> Mic Jack
    [    3.168201] asoc-simple-card-mcasp2 sound@2: ASoC: no sink widget found for LINE1L
    [    3.175804] asoc-simple-card-mcasp2 sound@2: ASoC: Failed to add route Line In -> direct -> LINE1L
    [    3.184813] asoc-simple-card-mcasp2 sound@2: ASoC: no sink widget found for LINE1R
    [    3.192463] asoc-simple-card-mcasp2 sound@2: ASoC: Failed to add route Line In -> direct -> LINE1R
    [    3.203248] asoc-simple-card-mcasp3 sound@3: bt-sco-pcm-mcasp3 <-> 48468000.mcasp mapping ok
    [    3.211747] asoc-simple-card-mcasp3 sound@3: ASoC: no source widget found for HPLOUT
    [    3.217732] mmc1: new DDR MMC card at address 0001
    [    3.224358] asoc-simple-card-mcasp3 sound@3: ASoC: Failed to add route HPLOUT -> direct -> Headphone Jack
    [    3.228252] mmcblk1: mmc1:0001 R1J55A 7.28 GiB
    [    3.238527] mmcblk1boot0: mmc1:0001 R1J55A partition 1 128 KiB
    [    3.244403] asoc-simple-card-mcasp3 sound@3: ASoC: no source widget found for HPROUT
    [    3.248798] mmcblk1boot1: mmc1:0001 R1J55A partition 2 128 KiB
    [    3.253032]  mmcblk1: p1 p2
    [    3.260869] asoc-simple-card-mcasp3 sound@3: ASoC: Failed to add route HPROUT -> direct -> Headphone Jack
    [    3.270494] asoc-simple-card-mcasp3 sound@3: ASoC: no source widget found for LLOUT
    [    3.278203] asoc-simple-card-mcasp3 sound@3: ASoC: Failed to add route LLOUT -> direct -> Line Out
    [    3.287215] asoc-simple-card-mcasp3 sound@3: ASoC: no source widget found for RLOUT
    [    3.294904] asoc-simple-card-mcasp3 sound@3: ASoC: Failed to add route RLOUT -> direct -> Line Out
    [    3.303945] asoc-simple-card-mcasp3 sound@3: ASoC: no sink widget found for MIC3L
    [    3.311478] asoc-simple-card-mcasp3 sound@3: ASoC: Failed to add route Mic Jack -> direct -> MIC3L
    [    3.320489] asoc-simple-card-mcasp3 sound@3: ASoC: no sink widget found for MIC3R
    [    3.328017] asoc-simple-card-mcasp3 sound@3: ASoC: Failed to add route Mic Jack -> direct -> MIC3R
    [    3.337016] asoc-simple-card-mcasp3 sound@3: ASoC: no source widget found for Mic Bias
    [    3.344690] mmc2: host does not support reading read-only switch, assuming write-enable
    [    3.344758] mmc2: new SDHC card at address 0001
    [    3.355217] mmcblk2: mmc2:0001 SD4GB 3.64 GiB
    [    3.357067]  mmcblk2: p1 p2
    [    3.364844] asoc-simple-card-mcasp3 sound@3: ASoC: Failed to add route Mic Bias -> direct -> Mic Jack
    [    3.374128] asoc-simple-card-mcasp3 sound@3: ASoC: no sink widget found for LINE1L
    [    3.381745] asoc-simple-card-mcasp3 sound@3: ASoC: Failed to add route Line In -> direct -> LINE1L
    [    3.390761] asoc-simple-card-mcasp3 sound@3: ASoC: no sink widget found for LINE1R
    [    3.398378] asoc-simple-card-mcasp3 sound@3: ASoC: Failed to add route Line In -> direct -> LINE1R
    [    3.409327] asoc-simple-card-mcasp4 sound@4: bt-sco-pcm-mcasp4 <-> 4846c000.mcasp mapping ok
    [    3.417832] asoc-simple-card-mcasp4 sound@4: ASoC: no source widget found for HPLOUT
    [    3.425611] asoc-simple-card-mcasp4 sound@4: ASoC: Failed to add route HPLOUT -> direct -> Headphone Jack
    [    3.435232] asoc-simple-card-mcasp4 sound@4: ASoC: no source widget found for HPROUT
    [    3.443023] asoc-simple-card-mcasp4 sound@4: ASoC: Failed to add route HPROUT -> direct -> Headphone Jack
    [    3.452645] asoc-simple-card-mcasp4 sound@4: ASoC: no source widget found for LLOUT
    [    3.460342] asoc-simple-card-mcasp4 sound@4: ASoC: Failed to add route LLOUT -> direct -> Line Out
    [    3.469352] asoc-simple-card-mcasp4 sound@4: ASoC: no source widget found for RLOUT
    [    3.477041] asoc-simple-card-mcasp4 sound@4: ASoC: Failed to add route RLOUT -> direct -> Line Out
    [    3.486050] asoc-simple-card-mcasp4 sound@4: ASoC: no sink widget found for MIC3L
    [    3.493577] asoc-simple-card-mcasp4 sound@4: ASoC: Failed to add route Mic Jack -> direct -> MIC3L
    [    3.502613] asoc-simple-card-mcasp4 sound@4: ASoC: no sink widget found for MIC3R
    [    3.510142] asoc-simple-card-mcasp4 sound@4: ASoC: Failed to add route Mic Jack -> direct -> MIC3R
    [    3.519153] asoc-simple-card-mcasp4 sound@4: ASoC: no source widget found for Mic Bias
    [    3.527103] asoc-simple-card-mcasp4 sound@4: ASoC: Failed to add route Mic Bias -> direct -> Mic Jack
    [    3.536374] asoc-simple-card-mcasp4 sound@4: ASoC: no sink widget found for LINE1L
    [    3.543984] asoc-simple-card-mcasp4 sound@4: ASoC: Failed to add route Line In -> direct -> LINE1L
    [    3.552994] asoc-simple-card-mcasp4 sound@4: ASoC: no sink widget found for LINE1R
    [    3.560604] asoc-simple-card-mcasp4 sound@4: ASoC: Failed to add route Line In -> direct -> LINE1R
    [    3.571782] asoc-simple-card-mcasp8 sound@8: bt-sco-pcm-mcasp8 <-> 4847c000.mcasp mapping ok
    [    3.580284] asoc-simple-card-mcasp8 sound@8: ASoC: no source widget found for HPLOUT
    [    3.588077] asoc-simple-card-mcasp8 sound@8: ASoC: Failed to add route HPLOUT -> direct -> Headphone Jack
    [    3.597697] asoc-simple-card-mcasp8 sound@8: ASoC: no source widget found for HPROUT
    [    3.605474] asoc-simple-card-mcasp8 sound@8: ASoC: Failed to add route HPROUT -> direct -> Headphone Jack
    [    3.615090] asoc-simple-card-mcasp8 sound@8: ASoC: no source widget found for LLOUT
    [    3.622793] asoc-simple-card-mcasp8 sound@8: ASoC: Failed to add route LLOUT -> direct -> Line Out
    [    3.631802] asoc-simple-card-mcasp8 sound@8: ASoC: no source widget found for RLOUT
    [    3.639503] asoc-simple-card-mcasp8 sound@8: ASoC: Failed to add route RLOUT -> direct -> Line Out
    [    3.648514] asoc-simple-card-mcasp8 sound@8: ASoC: no sink widget found for MIC3L
    [    3.656027] asoc-simple-card-mcasp8 sound@8: ASoC: Failed to add route Mic Jack -> direct -> MIC3L
    [    3.665036] asoc-simple-card-mcasp8 sound@8: ASoC: no sink widget found for MIC3R
    [    3.672562] asoc-simple-card-mcasp8 sound@8: ASoC: Failed to add route Mic Jack -> direct -> MIC3R
    [    3.681572] asoc-simple-card-mcasp8 sound@8: ASoC: no source widget found for Mic Bias
    [    3.689533] asoc-simple-card-mcasp8 sound@8: ASoC: Failed to add route Mic Bias -> direct -> Mic Jack
    [    3.698836] asoc-simple-card-mcasp8 sound@8: ASoC: no sink widget found for LINE1L
    [    3.706439] asoc-simple-card-mcasp8 sound@8: ASoC: Failed to add route Line In -> direct -> LINE1L
    [    3.715447] asoc-simple-card-mcasp8 sound@8: ASoC: no sink widget found for LINE1R
    [    3.723063] asoc-simple-card-mcasp8 sound@8: ASoC: Failed to add route Line In -> direct -> LINE1R
    [    3.732961] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
    [    3.739190] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
    [    3.745445] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
    [    3.752502] hctosys: unable to open rtc device (rtc0)
    [    3.769351] aic_dvdd: disabling
    [    3.772756] ldousb: disabling
    [    3.776239] ALSA device list:
    [    3.779235]   #0: DRA7xx-EVM-MCASP1
    [    3.782737]   #1: DRA7xx-EVM-MCASP2
    [    3.786237]   #2: DRA7xx-EVM-MCASP3
    [    3.789751]   #3: DRA7xx-EVM-MCASP4
    [    3.793250]   #4: DRA7xx-EVM-MCASP8
    [    3.865870] EXT4-fs (mmcblk1p2): recovery complete
    [    3.871133] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
    [    3.879308] VFS: Mounted root (ext4 filesystem) on device 179:50.
    [    3.886821] devtmpfs: mounted
    [    3.890040] Freeing unused kernel memory: 372K (c0c07000 - c0c64000)
    [    3.896420] This architecture does not have kernel memory protection.
    INIT: version 2.88 booting
    Starting udev
    [    4.183148] udevd[129]: starting version 182
    [    4.641595] omap-rproc 58820000.ipu: assigned reserved memory node ipu1_cma@9d000000
    [    4.720397]  remoteproc0: 58820000.ipu is available
    [    4.872043]  remoteproc0: Note: remoteproc is still under development and considered experimental.
    [    4.987275]  remoteproc0: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
    [    5.014205] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
    [    5.014593]  remoteproc0: Direct firmware load for dra7-ipu1-fw.xem4 failed with error -2
    [    5.014601]  remoteproc0: failed to load dra7-ipu1-fw.xem4
    [    5.015604] omap-rproc 55020000.ipu: assigned reserved memory node ipu2_cma@95800000
    [    5.015663]  remoteproc1: 55020000.ipu is available
    [    5.015667]  remoteproc1: Note: remoteproc is still under development and considered experimental.
    [    5.015670]  remoteproc1: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
    [    5.017603] omap-rproc 40800000.dsp: assigned reserved memory node dsp1_cma@99000000
    [    5.017660]  remoteproc2: 40800000.dsp is available
    [    5.017664]  remoteproc2: Note: remoteproc is still under development and considered experimental.
    [    5.017667]  remoteproc2: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
    [    5.018494] omap-rproc 41000000.dsp: assigned reserved memory node dsp2_cma@9f000000
    [    5.018545]  remoteproc3: 41000000.dsp is available
    [    5.018549]  remoteproc3: Note: remoteproc is still under development and considered experimental.
    [    5.018551]  remoteproc3: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
    [    5.027750] omap_rng 48090000.rng: OMAP Random Number Generator ver. 20
    [    5.029286] omap-des 480a5000.des: OMAP DES hw accel rev: 2.2
    [    5.045557]  remoteproc3: Direct firmware load for dra7-dsp2-fw.xe66 failed with error -2
    [    5.045566]  remoteproc3: failed to load dra7-dsp2-fw.xe66
    [    5.046387]  remoteproc2: registered virtio0 (type 7)
    [    5.060817] alg: skcipher: setkey failed on test 5 for ecb-des-omap: flags=100
    [    5.061147] alg: skcipher-ddst: setkey failed on test 5 for ecb-des-omap: flags=100
    [    5.061496] alg: skcipher-ddst: setkey failed on test 5 for ecb-des-omap: flags=100
    [    5.089779]  remoteproc1: registered virtio1 (type 7)
    [    5.159347] omap_rtc 48838000.rtc: rtc core: registered 48838000.rtc as rtc0
    [    5.296794] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
    [    5.304018] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
    [    5.309334] ahci 4a140000.sata: forcing port_map 0x0 -> 0x1
    [    5.309379] ahci 4a140000.sata: AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl platform mode
    [    5.309389] ahci 4a140000.sata: flags: 64bit ncq sntf pm led clo only pmp pio slum part ccc apst
    [    5.353718] CAN device driver interface
    [    5.431211] scsi host0: ahci
    [    5.434490] ata1: SATA max UDMA/133 mmio [mem 0x4a140000-0x4a1410ff] port 0x100 irq 347
    [    5.447787] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
    [    5.491596] omap-sham 4b101000.sham: hw accel on OMAP rev 4.3
    [    5.509469] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
    [    5.515799] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
    [    5.697724] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
    [    5.703949] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
    [    5.885968] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
    udevd[619]: failed to execute '/etc/udev/scripts/mount.sh' '/etc/udev/scripts/mount.sh': No such file or directory
    udevd[622]: failed to execute '/etc/udev/scripts/mount.sh' '/etc/udev/scripts/mount.sh': No such file or directory[    6.521364] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
    [    6.522740] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
    [    6.523824] omap-aes 4b500000.aes: OMAP AES hw accel rev: 3.3
    udevd[632]: failed to execute '/etc/udev/scripts/mount.sh' '/etc/udev/scripts/mount.sh': No such file or directory
    udevd[631]: failed to execute '/etc/udev/scripts/mount.sh' '/etc/udev/scripts/mount.sh': No such file or directory
    [    6.572664] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
    [    6.580392] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
    [    6.598777] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
    [    6.604997] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
    udevd[635]: failed to execute '/etc/udev/scripts/mount.sh' '/etc/udev/scripts/mount.sh': No such file or directory
    [    6.674951] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
    [    6.742146] omap-aes 4b700000.aes: OMAP AES hw accel rev: 3.3
    [    6.742315] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
    [    6.742319] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
    [    6.742379] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
    [    6.767522] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
    [    6.773739] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
    [    6.778761] pinctrl-single 4a003400.pinmux: pin 4a0037d0.0 already requested by 4806a000.serial; cannot claim for 4ae3c000.can
    [    6.778768] pinctrl-single 4a003400.pinmux: pin-244 (4ae3c000.can) status -22
    [    6.778776] pinctrl-single 4a003400.pinmux: could not request pin 244 (4a0037d0.0) from group dcan1_pins_sleep  on device pinctrl-single
    [    6.778781] c_can_platform 4ae3c000.can: Error applying setting, reverse things back
    [    6.779620] c_can_platform 4ae3c000.can: c_can_platform device registered (regs=fce3c000, irq=367)
    [    6.799069] [drm] Initialized pvr 1.14.3699939 20110701 on minor 1
    [    6.864750] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
    [    6.877872] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
    [    6.889538] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
    [    6.903924] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
    [    7.052233]  remoteproc2: powering up 40800000.dsp
    [    7.062233]  remoteproc2: Booting fw image dra7-dsp1-fw.xe66, size 929770
    [    7.075814] omap_hwmod: mmu0_dsp1: _wait_target_disable failed
    [    7.081713] omap-iommu 40d01000.mmu: 40d01000.mmu: version 3.0
    [    7.087676] omap-iommu 40d02000.mmu: 40d02000.mmu: version 3.0
    [    7.150509]  remoteproc2: remote processor 40800000.dsp is now up
    [    7.157127] virtio_rpmsg_bus virtio0: rpmsg host is online
    [    7.162697] virtio_rpmsg_bus virtio0: creating channel rpmsg-client-sample addr 0x36
    [    7.170809] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
    [    7.177022] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
    [    7.183402] virtio_rpmsg_bus virtio0: creating channel rpmsg-client-sample addr 0x37
    [    7.191342] virtio_rpmsg_bus virtio0: creating channel rpmsg-rpc addr 0x3b
    [    7.191481] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
    [    7.204775]  remoteproc1: powering up 55020000.ipu
    [    7.215526]  remoteproc1: Booting fw image dra7-ipu2-fw.xem4, size 3484972
    [    7.222805] omap-iommu 55082000.mmu: 55082000.mmu: version 2.1
    [    7.289460]  remoteproc1: remote processor 55020000.ipu is now up
    [    7.296421] virtio_rpmsg_bus virtio1: rpmsg host is online
    [    7.301984] virtio_rpmsg_bus virtio1: creating channel rpmsg-rpc addr 0x3b
    [    7.309293] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
    [    7.315502] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
    [    7.330607] rpmsg_rpc rpmsg2: probing service rpmsg-dce-dsp with src 1024 dst 59
    [    7.337861] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
    [    7.338203] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
    [    7.338207] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
    [    7.338258] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
    [    7.363717] rpmsg_rpc rpmsg3: probing service rpmsg-dce with src 1024 dst 59
    [    7.363981] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
    [    7.363986] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
    [    7.364037] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
    [    7.364133] rpmsg_rpc rpmsg2: published functions = 8
    [    7.395425] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
    [    7.401975] rpmsg_rpc rpmsg3: published functions = 8
    [    7.406225] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
    [    7.406304] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
    [    7.557022] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
    [    7.557531] dwc3 48910000.usb: failed to register ULPI interface
    [    7.557561] dwc3: probe of 48910000.usb failed with error -110
    [    7.579085] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
    [    7.585405] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
    [    7.588391] usbcore: registered new interface driver usbfs
    [    7.588998] usbcore: registered new interface driver hub
    [    7.589636] usbcore: registered new device driver usb
    [    7.597673] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
    [    7.597698] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
    [    7.603740] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220f04c hci version 0x100 quirks 0x00210010
    [    7.603798] xhci-hcd xhci-hcd.0.auto: irq 445, io mem 0x48890000
    [    7.604928] hub 1-0:1.0: USB hub found
    [    7.604966] hub 1-0:1.0: 1 port detected
    [    7.605385] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
    [    7.605399] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
    [    7.605485] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
    [    7.606482] hub 2-0:1.0: USB hub found
    [    7.606518] hub 2-0:1.0: 1 port detected
    [    7.606987] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
    [    7.607011] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 3
    [    7.607421] xhci-hcd xhci-hcd.1.auto: hcc params 0x0220f04c hci version 0x100 quirks 0x00210010
    [    7.607469] xhci-hcd xhci-hcd.1.auto: irq 446, io mem 0x488d0000
    [    7.608516] hub 3-0:1.0: USB hub found
    [    7.608552] hub 3-0:1.0: 1 port detected
    [    7.608942] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
    [    7.608956] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 4
    [    7.609040] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
    [    7.610038] hub 4-0:1.0: USB hub found
    [    7.610073] hub 4-0:1.0: 1 port detected
    [    7.738006] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
    [    7.744218] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
    [    7.750564] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
    [   15.497208] ata1: softreset failed (1st FIS failed)
    [   25.507206] ata1: softreset failed (1st FIS failed)
    [   25.857213] ata1: SATA link down (SStatus 0 SControl 300)
    [   25.911882] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
    Starting Bootlog daemon: bootlogd.
    [   25.991990] random: dd: uninitialized urandom read (512 bytes read, 82 bits of entropy available)
    ALSA: Restoring mixer settings...
    No state is present for card DRA7xxEVMMCASP1
    Found hardware: "DRA7xx-EVM-MCAS" "" "" "" ""
    Hardware is initialized using a generic method
    No state is present for card DRA7xxEVMMCASP2
    No state is present for card DRA7xxEVMMCASP3
    No state is present for card DRA7xxEVMMCASP4
    No state is present for card DRA7xxEVMMCASP8
    Thu Sep  3 18:41:00 UTC 2015
    2017.11.23 15:00
    This version is for J6
    ****** This application only support ASCII code 0 to 127 ******
    ****** This application only support CB version #F ******
    [   41.433664] xhci-hcd xhci-hcd.1.auto: remove, state 4
    [   41.439692] usb usb4: USB disconnect, device number 1
    [   41.447339] xhci-hcd xhci-hcd.1.auto: USB bus 4 deregistered
    [   41.453060] xhci-hcd xhci-hcd.1.auto: remove, state 4
    [   41.458641] usb usb3: USB disconnect, device number 1
    [   41.469097] xhci-hcd xhci-hcd.1.auto: USB bus 3 deregistered
    [   41.476486] xhci-hcd xhci-hcd.0.auto: remove, state 4
    [   41.481618] usb usb2: USB disconnect, device number 1
    [   41.489682] xhci-hcd xhci-hcd.0.auto: USB bus 2 deregistered
    [   41.495391] xhci-hcd xhci-hcd.0.auto: remove, state 4
    [   41.500510] usb usb1: USB disconnect, device number 1
    [   41.508540] xhci-hcd xhci-hcd.0.auto: USB bus 1 deregistered
    [   41.627843] usbcore: deregistering device driver usb
    [   41.634408] usbcore: deregistering interface driver usbfs
    [   41.645342] usbcore: deregistering interface driver hub
    [AB_server.c, make_sure_usb_kernel_stack_removed, 374] temp: drwxr-xr-x   27 root     root             0 Jan  1  1970 .
    dr-xr-xr-x   12 root     root             0 Jan  1  1970 ..
    drwxr-xr-x    4 root     root             0 Jan  1  1970 ac97
    drwxr-xr-x    4 root     root             0 Jan  1  1970 clockevents
    drwxr-xr-x    4 root     root             0 Jan  1  1970 clocksource
    drwxr-xr-x    4 root     root             0 Jan  1  1970 container
    drwxr-xr-x    4 root     root             0 Jan  1  1970 cpu
    drwxr-xr-x    4 root     root             0 Jan  1  1970 edac
    drwxr-xr-x    4 root     root             0 Jan  1  1970 event_source
    drwxr-xr-x    4 root     root             0 Jan  1  1970 hid
    drwxr-xr-x    4 root     root             0 Jan  1  1970 i2c
    drwxr-xr-x    4 root     root             0 Jan  1  1970 iio
    drwxr-xr-x    4 root     root             0 Jan  1  1970 mdio_bus
    drwxr-xr-x    4 root     root             0 Jan  1  1970 media
    drwxr-xr-x    4 root     root             0 Jan  1  1970 mipi-dsi
    drwxr-xr-x    4 root     root             0 Jan  1  1970 mmc
    drwxr-xr-x    5 root     root             0 Jan  1  1970 pci
    drwxr-xr-x    4 root     root             0 Jan  1  1970 platform
    drwxr-xr-x    4 root     root             0 Jan  1  1970 rpmsg
    drwxr-xr-x    4 root     root             0 Jan  1  1970 scsi
    drwxr-xr-x    4 root     root             0 Jan  1  1970 sdio
    drwxr-xr-x    4 root     root             0 Jan  1  1970 serio
    drwxr-xr-x    4 root     root             0 Jan  1  1970 soc
    drwxr-xr-x    4 root     root             0 Jan  1  1970 spi
    drwxr-xr-x    4 root     root             0 Jan  1  1970 ulpi
    drwxr-xr-x    4 root     root             0 Jan  1  1970 virtio
    drwxr-xr-x    4 root     root             0 Jan  1  1970 workqueue
    [AB_server.c, AB_boot_finish, 181] AB boot success, pull high GPIO
    [AB_server.c, AB_boot_finish, 187] AB boot success, pull high GPIO finished
    [AB_server.c, get_CB_hardware_version, 212] Wait for CB send HW version
    [AB_server.c, get_CB_hardware_version, 216] Read CB HW version (0) Bytes
    /usr/local/bin/set_unused_gpio_input: line 14: echo: write error: Device or resource busy
    /usr/local/bin/set_unused_gpio_input: line 15: /sys/class/gpio/gpio161/direction: No such file or directory
    INIT: Entering runlevel: 5
    Configuring network interfaces... [   43.330140] net eth0: initializing cpsw version 1.15 (0)
    [   43.335508] net eth0: initialized cpsw ale version 1.4
    [   43.341101] net eth0: ALE Table size 1024
    [   43.348183] libphy: PHY 48485000.mdio:02 not found
    [   43.353001] net eth0: phy "48485000.mdio:02" not found on slave 0, err -19
    [   43.366926] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
    /bin/sh: udhcpc: command not found
    done.
    Starting system message bus: [   43.423376] random: dbus-daemon: uninitialized urandom read (12 bytes read, 106 bits of entropy available)
    [   43.439586] random: dbus-daemon: uninitialized urandom read (12 bytes read, 106 bits of entropy available)
    dbus.
    [AB_server.c, get_CB_hardware_version, 216] Read CB HW version (4) Bytes
    _version[0]: 30
    _version[1]: 31
    _version[2]: 31
    _version[3]: 30
    _version[4]: 0
    _version[5]: 0
    _version[6]: 0
    _version[7]: 0
    _version[8]: 0
    _version[9]: 0
    _version[10]: 0
    _version[11]: 0
    _version[12]: 0
    _version[13]: 0
    _version[14]: 0
    _version[15]: 0
    [AB_server.c, main, 517] AB_server: get CB's HW version 0110
    [AB_server.c, get_CB_hardware_version_finish, 254] AB get CB hw version finish, gpio pull low
    [AB_server.c, send_AB_model_info_to_CB, 279] write AB model info total (6) Bytes, model: (DRA74X
    [AB_server.c, sync_CB_status, 308] ______ AB GPIO 109 status: 0
     ______
    [AB_server.c, sync_CB_status, 317] ______ AB GPIO 109 LOW, AB booting ______
     ______
    UIM SYSFS Node Not Found
    Starting telnet daemon.
    Starting tiipclad daemon[AB_server.c, sync_CB_status, 308] ______ AB GPIO 109 status: 1
     ______
    [AB_server.c, sync_CB_status, 312] ______ AB GPIO 109 1, can go ______
    GateMP support enabled on host
    Opened log file: lad.txt
    numProcessors = 5 id = 0 baseId = 0
    Spawned daemon: /usr/bin/lad_dra7xx
    Starting rpcbind daemon...done.
    creating NFS state directory: done
    starting statd: done
    NFS daemon support not enabled in kernel
    Starting syslogd/klogd: done
    Starting thttpd.
    Enabling thermal zones...
    Stopping Bootlog daemon: bootlogd.
    root@wnc-j6:~# [AB_server.c, main, 550] ulpi on/off : J6, ULPI test on
    cat /sys/kernel/debug/mmc0/i[   54.779077] random: nonblocking pool is initialized
    os
    clock:          52000000 Hz
    vdd:            7 (1.65 - 1.95 V)
    bus mode:       2 (push-pull)
    chip select:    0 (don't care)
    power mode:     2 (on)
    bus width:      2 (4 bits)
    timing spec:    1 (mmc high-speed)
    signal voltage: 0 (1.80 V)
    driver type:    0 (driver type B)
    root@wnc-j6:~# lsblk
    NAME         MAJ:MIN RM  SIZE RO TYPE MOUNTPOINT
    mmcblk0boot0 179:16   0  128K  1 disk
    mmcblk0boot1 179:32   0  128K  1 disk
    mmcblk1boot0 179:64   0  128K  1 disk
    mmcblk1boot1 179:80   0  128K  1 disk
    mmcblk0      179:0    0  7.3G  0 disk
    `-mmcblk0p1  179:1    0  7.3G  0 part
    mmcblk1      179:48   0  7.3G  0 disk
    |-mmcblk1p1  179:49   0   64M  0 part
    `-mmcblk1p2  179:50   0  7.2G  0 part /
    mmcblk2      179:96   0  3.7G  0 disk
    |-mmcblk2p1  179:97   0   62M  0 part
    `-mmcblk2p2  179:98   0  3.6G  0 part
    root@wnc-j6:~#
    * DRA746 eMMC? boots , but mount eMMC1 interface (include TS3A27518? )
    U-Boot SPL 2016.05 (Nov 24 2017 - 15:38:03)
    DRA752-GP ES2.0
    *** Warning - bad CRC, using default environment
    Trying to boot from MMC2_2
    spl: falcon_args_file not set in environment, falling back to default
    reading args
    spl_load_image_fat_os: error reading image args, err - -1
    reading u-boot.img
    reading u-boot.img
    U-Boot 2016.05 (Nov 24 2017 - 15:38:03 +0800)
    CPU  : DRA752-GP ES2.0
    Board: DRA74x EVM REV
    I2C:   ready
    DRAM:  2 GiB
    MMC:   OMAP SD/MMC: 0, OMAP SD/MMC: 1
    Warning: fastboot.board_rev: unknown board revision
    GUID Partition Table Header signature is wrong: 0x0 != 0x5452415020494645
    part_get_info_efi: *** ERROR: Invalid GPT ***
    part_get_info_efi: *** ERROR: Invalid Backup GPT ***
    ERROR: cannot find partition: 'userdata'
    at arch/arm/cpu/armv7/omap-common/utils.c:195/mmc_get_part_size()
    Warning: fastboot.userdata_size: unable to calc
    Net:   <ethaddr> not set. Validating first E-fuse MAC
    Could not get PHY for cpsw: addr 2
    cpsw
    Hit any key to stop autoboot:  0
    J6 ...
    switch to partitions #0, OK
    mmc1(part 0) is current device
    SD/MMC found on device 1
    4281344 bytes read in 214 ms (19.1 MiB/s)
    113603 bytes read in 12 ms (9 MiB/s)
    Booting from mmc1 ...
       Loading Device Tree to 8ffe1000, end 8ffffbc2 ... OK
    Starting kernel ...
    [    0.000000] Booting Linux on physical CPU 0x0
    [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
    [    0.000000] Machine model: TI DRA742 Bowei 20170929 17:30
    [    0.000000] Memory policy: Data cache writealloc
    [    0.000000] DRA752 ES2.0
    [    0.000000] Kernel command line: console=ttyO2,115200n8 root=PARTUUID=bddb4f41-02 rw rootfstype=ext4 rootwait consoleblank=0 omapdrm.num_crtc=2 drm.debug=0xff
    [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
    [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
    [    0.000000] Virtual kernel memory layout:
    [    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    [    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
    [    0.000000]     vmalloc : 0xf0800000 - 0xff800000   ( 240 MB)
    [    0.000000]     lowmem  : 0xc0000000 - 0xf0000000   ( 768 MB)
    [    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
    [    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
    [    0.000000] OMAP clockevent source: timer1 at 31475 Hz
    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x15c70fb29, max_idle_ns: 440795202138 ns
    [    0.000327] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns
    [    0.000334] OMAP clocksource: 32k_counter at 32768 Hz
    [    0.000788] Console: colour dummy device 80x30
    [    0.000805] WARNING: Your 'console=ttyO2' has been replaced by 'ttyS2'
    [    0.000811] This ensures that you still see kernel messages. Please
    [    0.000817] update your kernel commandline.
    [    0.000829] Calibrating delay loop (skipped), value calculated using timer frequency.. 11.80 BogoMIPS (lpj=59016)
    [    0.000843] pid_max: default: 32768 minimum: 301
    [    0.001476] Initializing cgroup subsys io
    [    0.001493] Initializing cgroup subsys memory
    [    0.001517] Initializing cgroup subsys devices
    [    0.001529] Initializing cgroup subsys freezer
    [    0.001540] Initializing cgroup subsys perf_event
    [    0.001551] Initializing cgroup subsys pids
    [    0.001579] CPU: Testing write buffer coherency: ok
    [    0.001775] /cpus/cpu@0 missing clock-frequency property
    [    0.001790] /cpus/cpu@1 missing clock-frequency property
    [    0.001800] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
    [    0.001840] Setting up static identity map for 0x80008340 - 0x800083a0
    [    0.080064] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
    [    0.080135] Brought up 2 CPUs
    [    0.080149] SMP: Total of 2 processors activated (23.60 BogoMIPS).
    [    0.080156] CPU: All CPU(s) started in SVC mode.
    [    0.081192] devtmpfs: initialized
    [    0.111040] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
    [    0.112025] omap_hwmod: l3_main_2 using broken dt data from ocp
    [    0.310748] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
    [    0.314458] pinctrl core: initialized pinctrl subsystem
    [    0.315315] NET: Registered protocol family 16
    [    0.316248] DMA: preallocated 256 KiB pool for atomic coherent allocations
    [    0.340278] cpuidle: using governor ladder
    [    0.370303] cpuidle: using governor menu
    [    0.378533] OMAP GPIO hardware version 0.1
    [    0.382634] GPIO line 161 (radio_rst) hogged as output/low
    [    0.414523] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
    [    0.414534] hw-breakpoint: maximum watchpoint size is 8 bytes.
    [    0.415009] omap4_sram_init:Unable to allocate sram needed to handle errata I688
    [    0.415018] omap4_sram_init:Unable to get sram pool needed to handle errata I688
    [    0.415505] OMAP DMA hardware revision 0.0
    [    0.461690] omap-dma-engine 4a056000.dma-controller: OMAP DMA engine driver (LinkedList1/2/3 supported)
    [    0.462936] edma 43300000.edma: memcpy is disabled
    [    0.467692] edma 43300000.edma: TI EDMA DMA engine driver
    [    0.471903] omap-iommu 40d01000.mmu: 40d01000.mmu registered
    [    0.472083] omap-iommu 40d02000.mmu: 40d02000.mmu registered
    [    0.472245] omap-iommu 58882000.mmu: 58882000.mmu registered
    [    0.472403] omap-iommu 55082000.mmu: 55082000.mmu registered
    [    0.472703] omap-iommu 41501000.mmu: 41501000.mmu registered
    [    0.472889] omap-iommu 41502000.mmu: 41502000.mmu registered
    [    0.474884] SCSI subsystem initialized
    [    0.476142] ======palmas_i2c_probe:526========
    [    0.476159] ======palmas_i2c_probe:559, features=0x0========
    [    0.476464] palmas 0-0058: IRQ missing: skipping irq request
    [    0.491206] palmas 0-0058: Muxing GPIO a, PWM 0, LED 0
    [    0.562945] omap_i2c 48070000.i2c: bus 0 rev0.12 at 400 kHz
    [    0.563584] omap_i2c 48072000.i2c: bus 1 rev0.12 at 400 kHz
    [    0.563950] omap_i2c 48060000.i2c: bus 2 rev0.12 at 400 kHz
    [    0.564309] omap_i2c 4807a000.i2c: bus 3 rev0.12 at 400 kHz
    [    0.564683] omap_i2c 4807c000.i2c: bus 4 rev0.12 at 400 kHz
    [    0.564902] media: Linux media interface: v0.10
    [    0.564958] Linux video capture interface: v2.00
    [    0.564997] pps_core: LinuxPPS API ver. 1 registered
    [    0.565003] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.565026] PTP clock support registered
    [    0.565051] EDAC MC: Ver: 3.0.0
    [    0.565807] omap-mailbox 48840000.mailbox: omap mailbox rev 0x400
    [    0.566099] omap-mailbox 48842000.mailbox: omap mailbox rev 0x400
    [    0.566445] Advanced Linux Sound Architecture Driver Initialized.
    [    0.567340] clocksource: Switched to clocksource arch_sys_counter
    [    0.578102] NET: Registered protocol family 2
    [    0.578596] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
    [    0.578659] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
    [    0.578784] TCP: Hash tables configured (established 8192 bind 8192)
    [    0.578830] UDP hash table entries: 512 (order: 2, 16384 bytes)
    [    0.578863] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
    [    0.579072] NET: Registered protocol family 1
    [    0.579335] RPC: Registered named UNIX socket transport module.
    [    0.579345] RPC: Registered udp transport module.
    [    0.579351] RPC: Registered tcp transport module.
    [    0.579357] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.580397] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
    [    0.582846] futex hash table entries: 512 (order: 3, 32768 bytes)
    [    0.589537] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.590190] NFS: Registering the id_resolver key type
    [    0.590215] Key type id_resolver registered
    [    0.590222] Key type id_legacy registered
    [    0.590288] ntfs: driver 2.1.32 [Flags: R/O].
    [    0.592263] bounce: pool size: 64 pages
    [    0.592414] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
    [    0.592431] io scheduler noop registered
    [    0.592446] io scheduler deadline registered
    [    0.592480] io scheduler cfq registered (default)
    [    0.597800] pinctrl-single 4a003400.pinmux: 282 pins at pa fc003400 size 1128
    [    0.659406] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
    [    0.663036] 4806a000.serial: ttyS0 at MMIO 0x4806a000 (irq = 299, base_baud = 3000000) is a 8250
    [    0.663917] 4806c000.serial: ttyS1 at MMIO 0x4806c000 (irq = 300, base_baud = 3000000) is a 8250
    [    0.664793] console [ttyS2] disabled
    [    0.664838] 48020000.serial: ttyS2 at MMIO 0x48020000 (irq = 301, base_baud = 3000000) is a 8250
    [    1.551629] console [ttyS2] enabled
    [    1.556023] 48066000.serial: ttyS4 at MMIO 0x48066000 (irq = 302, base_baud = 3000000) is a 8250
    [    1.565752] 48068000.serial: ttyS5 at MMIO 0x48068000 (irq = 303, base_baud = 3000000) is a 8250
    [    1.575435] 48424000.serial: ttyS8 at MMIO 0x48424000 (irq = 304, base_baud = 3000000) is a 8250
    [    1.585126] 4ae2b000.serial: ttyS9 at MMIO 0x4ae2b000 (irq = 305, base_baud = 3000000) is a 8250
    [    1.595260] [drm] Initialized drm 1.1.0 20060810
    [    1.601467] OMAP DSS rev 6.1
    [    1.605234] omapdss_dss 58000000.dss: bound 58001000.dispc (ops dispc_component_ops)
    [    1.627032] brd: module loaded
    [    1.635266] loop: module loaded
    [    1.644960] libphy: Fixed MDIO Bus: probed
    [    1.649677] e1000: Intel(R) PRO/1000 Network Driver - version 7.3.21-k8-NAPI
    [    1.656757] e1000: Copyright (c) 1999-2006 Intel Corporation.
    [    1.662607] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
    [    1.668478] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
    [    1.674482] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.3.0-k
    [    1.681487] igb: Copyright (c) 2007-2014 Intel Corporation.
    [    1.737371] davinci_mdio 48485000.mdio: davinci mdio revision 1.6
    [    1.743494] davinci_mdio 48485000.mdio: no live phy, scanning all
    [    1.847341] davinci_mdio 48485000.mdio: timed out waiting for user access
    [    1.947340] davinci_mdio 48485000.mdio: timed out waiting for idle
    [    1.953568] davinci_mdio: probe of 48485000.mdio failed with error -5
    [    1.960699] cpsw 48484000.ethernet: Detected MACID = 54:45:38:a7:aa:1e
    [    1.967378] cpsw 48484000.ethernet: cpts: overflow check period 800
    [    1.974347] cpsw 48484000.ethernet: cpsw: Detected MACID = 54:45:38:a7:aa:1f
    [    1.983056] mousedev: PS/2 mouse device common for all mice
    [    1.989285] i2c /dev entries driver
    [    2.007430] tvp5158 1-0058: i2c i/o error: rc == -121 (should be 1)
    [    2.013786] tvp5158 1-0058: i2c i/o error: rc == -121 (should be 1)
    [    2.020121] tvp5158 1-0058: ERROR: Chip id is not TVP5158
    [    2.025658] ov1063x 1-0037: ov1063x Product ID 0 Manufacturer ID 0
    [    2.031886] ov1063x 1-0037: ov1063x 1-0037 sensor driver registered !!
    [    2.039301] vpe 489d0000.vpe: loading firmware vpdma-1b8.bin
    [    2.046394] vip 48990000.vip: loading firmware vpdma-1b8.bin
    [    2.057521] vpe 489d0000.vpe: Device registered as /dev/video0
    [    2.067361] vip 48990000.vip: VPDMA firmware loaded
    [    2.072390] vip2-s1: Port B: Using subdev ov1063x 1-0037 for capture
    [    2.079183] vip2-s1: device registered as video1
    [    2.097763] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr25 mode
    [    2.104148] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr12 mode
    [    2.110574] omap_hsmmc 480b4000.mmc: no pinctrl state for hs200_1_8v mode
    [    2.117541] evm_3v3_sw: supplied by sysen1
    [    2.157699] omap_hsmmc 480d1000.mmc: no pinctrl state for sdr25 mode
    [    2.164084] omap_hsmmc 480d1000.mmc: no pinctrl state for sdr12 mode
    [    2.170479] omap_hsmmc 480d1000.mmc: no pinctrl state for hs mode
    [    2.208149] ledtrig-cpu: registered to indicate activity on CPUs
    [    2.216249] hwspinlock_user gatemp: requested 10 hwspinlocks
    [    2.237270] pinctrl-single 4a003400.pinmux: pin 4a0036a8.0 already requested by 4806a000.serial; cannot claim for 48460000.mcasp
    [    2.248934] pinctrl-single 4a003400.pinmux: pin-170 (48460000.mcasp) status -22
    [    2.256278] pinctrl-single 4a003400.pinmux: could not request pin 170 (4a0036a8.0) from group mcasp1_pins  on device pinctrl-single
    [    2.268211] davinci-mcasp 48460000.mcasp: Error applying setting, reverse things back
    [    2.276484] davinci-mcasp 48460000.mcasp: Update the bindings to use assigned-clocks!
    [    2.284391] davinci-mcasp 48460000.mcasp: failed to reparent fck
    [    2.290676] pinctrl-single 4a003400.pinmux: pin 4a003700.0 already requested by 4806a000.serial; cannot claim for 48464000.mcasp
    [    2.302305] pinctrl-single 4a003400.pinmux: pin-192 (48464000.mcasp) status -22
    [    2.309687] pinctrl-single 4a003400.pinmux: could not request pin 192 (4a003700.0) from group mcasp2_pins  on device pinctrl-single
    [    2.321575] davinci-mcasp 48464000.mcasp: Error applying setting, reverse things back
    [    2.329828] davinci-mcasp 48464000.mcasp: Update the bindings to use assigned-clocks!
    [    2.337725] davinci-mcasp 48464000.mcasp: failed to reparent fck
    [    2.343977] pinctrl-single 4a003400.pinmux: pin 4a00372c.0 already requested by 4806a000.serial; cannot claim for 48468000.mcasp
    [    2.355607] pinctrl-single 4a003400.pinmux: pin-203 (48468000.mcasp) status -22
    [    2.362959] pinctrl-single 4a003400.pinmux: could not request pin 203 (4a00372c.0) from group mcasp3_pins  on device pinctrl-single
    [    2.374844] davinci-mcasp 48468000.mcasp: Error applying setting, reverse things back
    [    2.383085] davinci-mcasp 48468000.mcasp: Update the bindings to use assigned-clocks!
    [    2.390983] davinci-mcasp 48468000.mcasp: failed to reparent fck
    [    2.397236] pinctrl-single 4a003400.pinmux: pin 4a003734.0 already requested by 4806a000.serial; cannot claim for 4846c000.mcasp
    [    2.408870] pinctrl-single 4a003400.pinmux: pin-205 (4846c000.mcasp) status -22
    [    2.416213] pinctrl-single 4a003400.pinmux: could not request pin 205 (4a003734.0) from group mcasp4_pins  on device pinctrl-single
    [    2.428097] davinci-mcasp 4846c000.mcasp: Error applying setting, reverse things back
    [    2.436336] davinci-mcasp 4846c000.mcasp: Update the bindings to use assigned-clocks!
    [    2.444233] davinci-mcasp 4846c000.mcasp: failed to reparent fck
    [    2.450499] pinctrl-single 4a003400.pinmux: pin 4a003720.0 already requested by 4806a000.serial; cannot claim for 4847c000.mcasp
    [    2.462128] pinctrl-single 4a003400.pinmux: pin-200 (4847c000.mcasp) status -22
    [    2.469480] pinctrl-single 4a003400.pinmux: could not request pin 200 (4a003720.0) from group mcasp8_pins  on device pinctrl-single
    [    2.481364] davinci-mcasp 4847c000.mcasp: Error applying setting, reverse things back
    [    2.489611] davinci-mcasp 4847c000.mcasp: Update the bindings to use assigned-clocks!
    [    2.497508] davinci-mcasp 4847c000.mcasp: failed to reparent fck
    [    2.504692] NET: Registered protocol family 10
    [    2.519972] sit: IPv6 over IPv4 tunneling driver
    [    2.525148] NET: Registered protocol family 17
    [    2.529873] Key type dns_resolver registered
    [    2.534292] omap_voltage_late_init: Voltage driver support not added
    [    2.541209] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
    [    2.548563] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
    [    2.554817] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
    [    2.561455] Power Management for TI OMAP4+ devices.
    [    2.566591] Registering SWP/SWPB emulation handler
    [    2.574136] dmm 4e000000.dmm: initialized all PAT entries
    [    2.601001] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
    [    2.607679] [drm] No driver support for vblank timestamp query.
    [    2.624846] [drm] Enabling DMM ywrap scrolling
    [    2.680497] mmc0: MAN_BKOPS_EN bit is not set
    [    2.682910] mmc0: switch to bus width 1 failed
    [    2.699844] Console: switching to colour frame buffer device 240x67
    [    2.729767] omapdrm omapdrm.0: fb0: omapdrm frame buffer device
    [    2.745328] mmc0: new high speed MMC card at address 0001
    [    2.761270] mmcblk0: mmc0:0001 R1J55A 7.28 GiB
    [    2.768647] [drm] Initialized omapdrm 1.0.0 20110917 on minor 0
    [    2.776079] mmcblk0boot0: mmc0:0001 R1J55A partition 1 128 KiB
    [    2.782184] mmcblk0boot1: mmc0:0001 R1J55A partition 2 128 KiB
    [    2.789519] asoc-simple-card-mcasp1 sound@1: bt-sco-pcm-mcasp1 <-> 48460000.mcasp mapping ok
    [    2.798021] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    2.807739] asoc-simple-card-mcasp1 sound@1: ASoC: no source widget found for HPLOUT
    [    2.817587] mmcblk0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    2.827021] mmcblk0: retrying using single block read
    [    2.832138] asoc-simple-card-mcasp1 sound@1: ASoC: Failed to add route HPLOUT -> direct -> Headphone Jack
    [    2.841761] asoc-simple-card-mcasp1 sound@1: ASoC: no source widget found for HPROUT
    [    2.849575] asoc-simple-card-mcasp1 sound@1: ASoC: Failed to add route HPROUT -> direct -> Headphone Jack
    [    2.859358] mmcblk0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    2.868642] blk_update_request: I/O error, dev mmcblk0, sector 0
    [    2.868655] asoc-simple-card-mcasp1 sound@1: ASoC: no source widget found for LLOUT
    [    2.868662] asoc-simple-card-mcasp1 sound@1: ASoC: Failed to add route LLOUT -> direct -> Line Out
    [    2.868667] asoc-simple-card-mcasp1 sound@1: ASoC: no source widget found for RLOUT
    [    2.868672] asoc-simple-card-mcasp1 sound@1: ASoC: Failed to add route RLOUT -> direct -> Line Out
    [    2.868677] asoc-simple-card-mcasp1 sound@1: ASoC: no sink widget found for MIC3L
    [    2.868682] asoc-simple-card-mcasp1 sound@1: ASoC: Failed to add route Mic Jack -> direct -> MIC3L
    [    2.868687] asoc-simple-card-mcasp1 sound@1: ASoC: no sink widget found for MIC3R
    [    2.868692] asoc-simple-card-mcasp1 sound@1: ASoC: Failed to add route Mic Jack -> direct -> MIC3R
    [    2.868697] asoc-simple-card-mcasp1 sound@1: ASoC: no source widget found for Mic Bias
    [    2.868701] asoc-simple-card-mcasp1 sound@1: ASoC: Failed to add route Mic Bias -> direct -> Mic Jack
    [    2.868707] asoc-simple-card-mcasp1 sound@1: ASoC: no sink widget found for LINE1L
    [    2.868712] asoc-simple-card-mcasp1 sound@1: ASoC: Failed to add route Line In -> direct -> LINE1L
    [    2.868717] asoc-simple-card-mcasp1 sound@1: ASoC: no sink widget found for LINE1R
    [    2.868722] asoc-simple-card-mcasp1 sound@1: ASoC: Failed to add route Line In -> direct -> LINE1R
    [    2.880987] asoc-simple-card-mcasp2 sound@2: bt-sco-pcm-mcasp2 <-> 48464000.mcasp mapping ok
    [    2.880996] asoc-simple-card-mcasp2 sound@2: ASoC: no source widget found for HPLOUT
    [    2.881001] asoc-simple-card-mcasp2 sound@2: ASoC: Failed to add route HPLOUT -> direct -> Headphone Jack
    [    2.881006] asoc-simple-card-mcasp2 sound@2: ASoC: no source widget found for HPROUT
    [    2.881011] asoc-simple-card-mcasp2 sound@2: ASoC: Failed to add route HPROUT -> direct -> Headphone Jack
    [    2.881016] asoc-simple-card-mcasp2 sound@2: ASoC: no source widget found for LLOUT
    [    2.881022] asoc-simple-card-mcasp2 sound@2: ASoC: Failed to add route LLOUT -> direct -> Line Out
    [    2.881028] asoc-simple-card-mcasp2 sound@2: ASoC: no source widget found for RLOUT
    [    2.881033] asoc-simple-card-mcasp2 sound@2: ASoC: Failed to add route RLOUT -> direct -> Line Out
    [    2.881038] asoc-simple-card-mcasp2 sound@2: ASoC: no sink widget found for MIC3L
    [    2.881043] asoc-simple-card-mcasp2 sound@2: ASoC: Failed to add route Mic Jack -> direct -> MIC3L
    [    2.881048] asoc-simple-card-mcasp2 sound@2: ASoC: no sink widget found for MIC3R
    [    2.881053] asoc-simple-card-mcasp2 sound@2: ASoC: Failed to add route Mic Jack -> direct -> MIC3R
    [    2.881058] asoc-simple-card-mcasp2 sound@2: ASoC: no source widget found for Mic Bias
    [    2.881063] asoc-simple-card-mcasp2 sound@2: ASoC: Failed to add route Mic Bias -> direct -> Mic Jack
    [    2.881068] asoc-simple-card-mcasp2 sound@2: ASoC: no sink widget found for LINE1L
    [    2.881073] asoc-simple-card-mcasp2 sound@2: ASoC: Failed to add route Line In -> direct -> LINE1L
    [    2.881077] asoc-simple-card-mcasp2 sound@2: ASoC: no sink widget found for LINE1R
    [    2.881082] asoc-simple-card-mcasp2 sound@2: ASoC: Failed to add route Line In -> direct -> LINE1R
    [    2.883098] asoc-simple-card-mcasp3 sound@3: bt-sco-pcm-mcasp3 <-> 48468000.mcasp mapping ok
    [    2.883107] asoc-simple-card-mcasp3 sound@3: ASoC: no source widget found for HPLOUT
    [    2.883112] asoc-simple-card-mcasp3 sound@3: ASoC: Failed to add route HPLOUT -> direct -> Headphone Jack
    [    2.883118] asoc-simple-card-mcasp3 sound@3: ASoC: no source widget found for HPROUT
    [    2.883122] asoc-simple-card-mcasp3 sound@3: ASoC: Failed to add route HPROUT -> direct -> Headphone Jack
    [    2.883127] asoc-simple-card-mcasp3 sound@3: ASoC: no source widget found for LLOUT
    [    2.883132] asoc-simple-card-mcasp3 sound@3: ASoC: Failed to add route LLOUT -> direct -> Line Out
    [    2.883138] asoc-simple-card-mcasp3 sound@3: ASoC: no source widget found for RLOUT
    [    2.883143] asoc-simple-card-mcasp3 sound@3: ASoC: Failed to add route RLOUT -> direct -> Line Out
    [    2.883148] asoc-simple-card-mcasp3 sound@3: ASoC: no sink widget found for MIC3L
    [    2.883153] asoc-simple-card-mcasp3 sound@3: ASoC: Failed to add route Mic Jack -> direct -> MIC3L
    [    2.883158] asoc-simple-card-mcasp3 sound@3: ASoC: no sink widget found for MIC3R
    [    2.883162] asoc-simple-card-mcasp3 sound@3: ASoC: Failed to add route Mic Jack -> direct -> MIC3R
    [    2.883167] asoc-simple-card-mcasp3 sound@3: ASoC: no source widget found for Mic Bias
    [    2.883172] asoc-simple-card-mcasp3 sound@3: ASoC: Failed to add route Mic Bias -> direct -> Mic Jack
    [    2.883177] asoc-simple-card-mcasp3 sound@3: ASoC: no sink widget found for LINE1L
    [    2.883182] asoc-simple-card-mcasp3 sound@3: ASoC: Failed to add route Line In -> direct -> LINE1L
    [    2.883187] asoc-simple-card-mcasp3 sound@3: ASoC: no sink widget found for LINE1R
    [    2.883191] asoc-simple-card-mcasp3 sound@3: ASoC: Failed to add route Line In -> direct -> LINE1R
    [    2.885254] asoc-simple-card-mcasp4 sound@4: bt-sco-pcm-mcasp4 <-> 4846c000.mcasp mapping ok
    [    2.885262] asoc-simple-card-mcasp4 sound@4: ASoC: no source widget found for HPLOUT
    [    2.885268] asoc-simple-card-mcasp4 sound@4: ASoC: Failed to add route HPLOUT -> direct -> Headphone Jack
    [    2.885273] asoc-simple-card-mcasp4 sound@4: ASoC: no source widget found for HPROUT
    [    2.885279] asoc-simple-card-mcasp4 sound@4: ASoC: Failed to add route HPROUT -> direct -> Headphone Jack
    [    2.885284] asoc-simple-card-mcasp4 sound@4: ASoC: no source widget found for LLOUT
    [    2.885290] asoc-simple-card-mcasp4 sound@4: ASoC: Failed to add route LLOUT -> direct -> Line Out
    [    2.885295] asoc-simple-card-mcasp4 sound@4: ASoC: no source widget found for RLOUT
    [    2.885300] asoc-simple-card-mcasp4 sound@4: ASoC: Failed to add route RLOUT -> direct -> Line Out
    [    2.885305] asoc-simple-card-mcasp4 sound@4: ASoC: no sink widget found for MIC3L
    [    2.885310] asoc-simple-card-mcasp4 sound@4: ASoC: Failed to add route Mic Jack -> direct -> MIC3L
    [    2.885314] asoc-simple-card-mcasp4 sound@4: ASoC: no sink widget found for MIC3R
    [    2.885319] asoc-simple-card-mcasp4 sound@4: ASoC: Failed to add route Mic Jack -> direct -> MIC3R
    [    2.885324] asoc-simple-card-mcasp4 sound@4: ASoC: no source widget found for Mic Bias
    [    2.885328] asoc-simple-card-mcasp4 sound@4: ASoC: Failed to add route Mic Bias -> direct -> Mic Jack
    [    2.885334] asoc-simple-card-mcasp4 sound@4: ASoC: no sink widget found for LINE1L
    [    2.885339] asoc-simple-card-mcasp4 sound@4: ASoC: Failed to add route Line In -> direct -> LINE1L
    [    2.885344] asoc-simple-card-mcasp4 sound@4: ASoC: no sink widget found for LINE1R
    [    2.885349] asoc-simple-card-mcasp4 sound@4: ASoC: Failed to add route Line In -> direct -> LINE1R
    [    2.887766] asoc-simple-card-mcasp8 sound@8: bt-sco-pcm-mcasp8 <-> 4847c000.mcasp mapping ok
    [    2.887775] asoc-simple-card-mcasp8 sound@8: ASoC: no source widget found for HPLOUT
    [    2.887780] asoc-simple-card-mcasp8 sound@8: ASoC: Failed to add route HPLOUT -> direct -> Headphone Jack
    [    2.887786] asoc-simple-card-mcasp8 sound@8: ASoC: no source widget found for HPROUT
    [    2.887791] asoc-simple-card-mcasp8 sound@8: ASoC: Failed to add route HPROUT -> direct -> Headphone Jack
    [    2.887796] asoc-simple-card-mcasp8 sound@8: ASoC: no source widget found for LLOUT
    [    2.887801] asoc-simple-card-mcasp8 sound@8: ASoC: Failed to add route LLOUT -> direct -> Line Out
    [    2.887806] asoc-simple-card-mcasp8 sound@8: ASoC: no source widget found for RLOUT
    [    2.887811] asoc-simple-card-mcasp8 sound@8: ASoC: Failed to add route RLOUT -> direct -> Line Out
    [    2.887816] asoc-simple-card-mcasp8 sound@8: ASoC: no sink widget found for MIC3L
    [    2.887820] asoc-simple-card-mcasp8 sound@8: ASoC: Failed to add route Mic Jack -> direct -> MIC3L
    [    2.887825] asoc-simple-card-mcasp8 sound@8: ASoC: no sink widget found for MIC3R
    [    2.887829] asoc-simple-card-mcasp8 sound@8: ASoC: Failed to add route Mic Jack -> direct -> MIC3R
    [    2.887834] asoc-simple-card-mcasp8 sound@8: ASoC: no source widget found for Mic Bias
    [    2.887839] asoc-simple-card-mcasp8 sound@8: ASoC: Failed to add route Mic Bias -> direct -> Mic Jack
    [    2.887844] asoc-simple-card-mcasp8 sound@8: ASoC: no sink widget found for LINE1L
    [    2.887848] asoc-simple-card-mcasp8 sound@8: ASoC: Failed to add route Line In -> direct -> LINE1L
    [    2.887853] asoc-simple-card-mcasp8 sound@8: ASoC: no sink widget found for LINE1R
    [    2.887858] asoc-simple-card-mcasp8 sound@8: ASoC: Failed to add route Line In -> direct -> LINE1R
    [    2.888877] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
    [    2.888880] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
    [    2.888940] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
    [    2.898610] hctosys: unable to open rtc device (rtc0)
    [    2.913245] aic_dvdd: disabling
    [    2.932189] ldousb: disabling
    [    2.982904] ALSA device list:
    [    2.982908]   #0: DRA7xx-EVM-MCASP1
    [    2.982911]   #1: DRA7xx-EVM-MCASP2
    [    2.982913]   #2: DRA7xx-EVM-MCASP3
    [    2.982916]   #3: DRA7xx-EVM-MCASP4
    [    2.982918]   #4: DRA7xx-EVM-MCASP8
    [    3.686889] mmcblk0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    3.696185] blk_update_request: I/O error, dev mmcblk0, sector 1
    [    3.702414] mmcblk0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    3.711698] blk_update_request: I/O error, dev mmcblk0, sector 2
    [    3.717930] mmcblk0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    3.727190] blk_update_request: I/O error, dev mmcblk0, sector 3
    [    3.733426] mmcblk0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    3.742704] blk_update_request: I/O error, dev mmcblk0, sector 4
    [    3.748936] mmcblk0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    3.758212] blk_update_request: I/O error, dev mmcblk0, sector 5
    [    3.764427] mmcblk0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    3.773700] blk_update_request: I/O error, dev mmcblk0, sector 6
    [    3.779925] mmcblk0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    3.789201] blk_update_request: I/O error, dev mmcblk0, sector 7
    [    3.795236] Buffer I/O error on dev mmcblk0, logical block 0, async page read
    [    3.802602] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    3.811756] mmcblk0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    3.821206] mmcblk0: retrying using single block read
    [    3.826458] mmcblk0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    3.835732] blk_update_request: I/O error, dev mmcblk0, sector 0
    [    3.841953] mmcblk0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    3.851230] blk_update_request: I/O error, dev mmcblk0, sector 1
    [    3.857446] mmcblk0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    3.866885] mmcblk0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    3.876337] mmcblk0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    3.885797] mmcblk0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    3.895249] mmcblk0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    3.904704] mmcblk0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    3.913983] Buffer I/O error on dev mmcblk0, logical block 0, async page read
    [    3.921172]  mmcblk0: unable to read partition table
    [    3.927519] Waiting for root device PARTUUID=bddb4f41-02...
    [    3.927595] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
    [    3.927599] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
    [    3.927652] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
    [    3.990491] mmc1: MAN_BKOPS_EN bit is not set
    [    4.099283] mmc1: new DDR MMC card at address 0001
    [    4.104543] mmcblk1: mmc1:0001 R1J55A 7.28 GiB
    [    4.119371] mmcblk1boot0: mmc1:0001 R1J55A partition 1 128 KiB
    [    4.135483] mmcblk1boot1: mmc1:0001 R1J55A partition 2 128 KiB
    [    4.142371]  mmcblk1: p1 p2
    [    4.146693] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
    [    4.153034] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
    [    4.159341] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
    [    4.197251] EXT4-fs (mmcblk1p2): recovery complete
    [    4.202499] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
    [    4.210690] VFS: Mounted root (ext4 filesystem) on device 179:50.
    [    4.218233] devtmpfs: mounted
    [    4.221434] Freeing unused kernel memory: 372K (c0c07000 - c0c64000)
    [    4.227856] This architecture does not have kernel memory protection.
    [    4.241563] mmc2: host does not support reading read-only switch, assuming write-enable
    [    4.249694] mmc2: new SDHC card at address 0001
    [    4.254638] mmcblk2: mmc2:0001 SD4GB 3.64 GiB
    [    4.260955]  mmcblk2: p1 p2
    [    4.264566] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
    [    4.270865] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
    [    4.270929] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
    Starting udev
    [    4.552320] udevd[129]: starting version 182
    [    4.731554] omap-rproc 58820000.ipu: assigned reserved memory node ipu1_cma@9d000000
    [    4.857486]  remoteproc0: 58820000.ipu is available
    [    4.862418]  remoteproc0: Note: remoteproc is still under development and considered experimental.
    [    5.037117]  remoteproc0: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
    [    5.201575]  remoteproc0: Direct firmware load for dra7-ipu1-fw.xem4 failed with error -2
    [    5.207640] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
    [    5.207645] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
    [    5.207709] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
    [    5.229078] omap-rproc 55020000.ipu: assigned reserved memory node ipu2_cma@95800000
    [    5.337466]  remoteproc1: 55020000.ipu is available
    [    5.342383]  remoteproc1: Note: remoteproc is still under development and considered experimental.
    [    5.489896]  remoteproc0: failed to load dra7-ipu1-fw.xem4
    [    5.500558]  remoteproc1: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
    [    5.583597] omap-rproc 40800000.dsp: assigned reserved memory node dsp1_cma@99000000
    [    5.583681] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
    [    5.583686] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
    [    5.583748] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
    [    5.639004]  remoteproc2: 40800000.dsp is available
    [    5.643951] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    5.653192] mmcblk0: error -84 transferring data, sector 15269760, nr 8, cmd response 0x900, card status 0x0
    [    5.653198] mmcblk0: retrying using single block read
    [    5.668254] mmcblk0: error -84 transferring data, sector 15269760, nr 8, cmd response 0x900, card status 0x0
    [    5.678210] mmcblk0: error -84 transferring data, sector 15269761, nr 7, cmd response 0x900, card status 0x0
    [    5.719653] CAN device driver interface
    [    5.737930] mmcblk0: error -84 transferring data, sector 15269762, nr 6, cmd response 0x900, card status 0x0
    [    5.745950]  remoteproc2: Note: remoteproc is still under development and considered experimental.
    [    5.745955]  remoteproc2: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
    [    5.747055] omap-rproc 41000000.dsp: assigned reserved memory node dsp2_cma@9f000000
    [    5.747112]  remoteproc3: 41000000.dsp is available
    [    5.747115]  remoteproc3: Note: remoteproc is still under development and considered experimental.
    [    5.747118]  remoteproc3: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
    [    5.751380] pinctrl-single 4a003400.pinmux: pin 4a0037d0.0 already requested by 4806a000.serial; cannot claim for 4ae3c000.can
    [    5.751388] pinctrl-single 4a003400.pinmux: pin-244 (4ae3c000.can) status -22
    [    5.751396] pinctrl-single 4a003400.pinmux: could not request pin 244 (4a0037d0.0) from group dcan1_pins_sleep  on device pinctrl-single
    [    5.751400] c_can_platform 4ae3c000.can: Error applying setting, reverse things back
    [    5.752239] c_can_platform 4ae3c000.can: c_can_platform device registered (regs=fce3c000, irq=367)
    [    5.757730] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
    [    5.757734] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
    [    5.757795] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
    [    5.784380]  remoteproc1: registered virtio0 (type 7)
    [    5.784988]  remoteproc3: Direct firmware load for dra7-dsp2-fw.xe66 failed with error -2
    [    5.784994]  remoteproc3: failed to load dra7-dsp2-fw.xe66
    [    5.787759]  remoteproc2: registered virtio1 (type 7)
    [    5.814972] [drm] Initialized pvr 1.14.3699939 20110701 on minor 1
    [    5.816385] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
    [    5.816390] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
    [    5.816454] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
    [    5.915905] omap_rng 48090000.rng: OMAP Random Number Generator ver. 20
    [    5.916023] omap-des 480a5000.des: OMAP DES hw accel rev: 2.2
    [    5.923383] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
    [    5.923388] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
    [    5.923445] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
    [    6.018191] mmcblk0: error -84 transferring data, sector 15269763, nr 5, cmd response 0x900, card status 0x0
    [    6.018559] mmcblk0: error -84 transferring data, sector 15269764, nr 4, cmd response 0x900, card status 0x0
    [    6.018945] mmcblk0: error -84 transferring data, sector 15269765, nr 3, cmd response 0x900, card status 0x0
    [    6.018972] alg: skcipher: setkey failed on test 5 for ecb-des-omap: flags=100
    [    6.019921] mmcblk0: error -84 transferring data, sector 15269766, nr 2, cmd response 0x900, card status 0x0
    [    6.020140] mmcblk0: error -84 transferring data, sector 15269767, nr 1, cmd response 0x900, card status 0x0
    [    6.020268] alg: skcipher-ddst: setkey failed on test 5 for ecb-des-omap: flags=100
    [    6.020340] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    6.038687] mmcblk0: error -84 transferring data, sector 15269760, nr 8, cmd response 0x900, card status 0xb00
    [    6.038692] mmcblk0: retrying using single block read
    [    6.039368] mmcblk0: error -84 transferring data, sector 15269760, nr 8, cmd response 0x900, card status 0x0
    [    6.041806] mmcblk0: error -84 transferring data, sector 15269761, nr 7, cmd response 0x900, card status 0x0
    [    6.041968] mmcblk0: error -84 transferring data, sector 15269762, nr 6, cmd response 0x900, card status 0x0
    [    6.042083] alg: skcipher-ddst: setkey failed on test 5 for ecb-des-omap: flags=100
    [    6.042145] mmcblk0: error -84 transferring data, sector 15269763, nr 5, cmd response 0x900, card status 0x0
    [    6.042296] mmcblk0: error -84 transferring data, sector 15269764, nr 4, cmd response 0x900, card status 0x0
    [    6.042459] mmcblk0: error -84 transferring data, sector 15269765, nr 3, cmd response 0x900, card status 0x0
    [    6.042614] mmcblk0: error -84 transferring data, sector 15269766, nr 2, cmd response 0x900, card status 0x0
    [    6.042780] mmcblk0: error -84 transferring data, sector 15269767, nr 1, cmd response 0x900, card status 0x0
    [    6.042790] Buffer I/O error on dev mmcblk0, logical block 1908720, async page read
    [    6.043014] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    6.043093] mmcblk0: error -84 transferring data, sector 15269872, nr 8, cmd response 0x900, card status 0xb00
    [    6.043097] mmcblk0: retrying using single block read
    [    6.043256] mmcblk0: error -84 transferring data, sector 15269872, nr 8, cmd response 0x900, card status 0x0
    [    6.043418] mmcblk0: error -84 transferring data, sector 15269873, nr 7, cmd response 0x900, card status 0x0
    [    6.043545] mmcblk0: error -84 transferring data, sector 15269874, nr 6, cmd response 0x900, card status 0x0
    [    6.043701] mmcblk0: error -84 transferring data, sector 15269875, nr 5, cmd response 0x900, card status 0x0
    [    6.043829] mmcblk0: error -84 transferring data, sector 15269876, nr 4, cmd response 0x900, card status 0x0
    [    6.043964] mmcblk0: error -84 transferring data, sector 15269877, nr 3, cmd response 0x900, card status 0x0
    [    6.044091] mmcblk0: error -84 transferring data, sector 15269878, nr 2, cmd response 0x900, card status 0x0
    [    6.044250] mmcblk0: error -84 transferring data, sector 15269879, nr 1, cmd response 0x900, card status 0x0
    [    6.044420] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    6.044483] mmcblk0: error -84 transferring data, sector 15269872, nr 8, cmd response 0x900, card status 0xb00
    [    6.044487] mmcblk0: retrying using single block read
    [    6.044610] mmcblk0: error -84 transferring data, sector 15269872, nr 8, cmd response 0x900, card status 0x0
    [    6.044738] mmcblk0: error -84 transferring data, sector 15269873, nr 7, cmd response 0x900, card status 0x0
    [    6.044861] mmcblk0: error -84 transferring data, sector 15269874, nr 6, cmd response 0x900, card status 0x0
    [    6.044985] mmcblk0: error -84 transferring data, sector 15269875, nr 5, cmd response 0x900, card status 0x0
    [    6.045111] mmcblk0: error -84 transferring data, sector 15269876, nr 4, cmd response 0x900, card status 0x0
    [    6.045236] mmcblk0: error -84 transferring data, sector 15269877, nr 3, cmd response 0x900, card status 0x0
    [    6.045368] mmcblk0: error -84 transferring data, sector 15269878, nr 2, cmd response 0x900, card status 0x0
    [    6.045493] mmcblk0: error -84 transferring data, sector 15269879, nr 1, cmd response 0x900, card status 0x0
    [    6.045500] Buffer I/O error on dev mmcblk0, logical block 1908734, async page read
    [    6.045705] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    6.045760] mmcblk0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    6.045763] mmcblk0: retrying using single block read
    [    6.045945] mmcblk0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    6.046129] mmcblk0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    6.046307] mmcblk0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    6.046492] mmcblk0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    6.046674] mmcblk0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    6.046850] mmcblk0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    6.047024] mmcblk0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    6.047198] mmcblk0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    6.047379] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    6.047430] mmcblk0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    6.047434] mmcblk0: retrying using single block read
    [    6.047615] mmcblk0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    6.047794] mmcblk0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    6.047970] mmcblk0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    6.048144] mmcblk0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    6.048319] mmcblk0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    6.048498] mmcblk0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    6.048674] mmcblk0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    6.048848] mmcblk0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    6.048856] Buffer I/O error on dev mmcblk0, logical block 0, async page read
    [    6.049125] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    6.049173] mmcblk0: error -84 transferring data, sector 8, nr 8, cmd response 0x900, card status 0xb00
    [    6.049176] mmcblk0: retrying using single block read
    [    6.049355] mmcblk0: error -84 transferring data, sector 8, nr 8, cmd response 0x900, card status 0x0
    [    6.049537] mmcblk0: error -84 transferring data, sector 9, nr 7, cmd response 0x900, card status 0x0
    [    6.049718] mmcblk0: error -84 transferring data, sector 10, nr 6, cmd response 0x900, card status 0x0
    [    6.049900] mmcblk0: error -84 transferring data, sector 11, nr 5, cmd response 0x900, card status 0x0
    [    6.050082] mmcblk0: error -84 transferring data, sector 12, nr 4, cmd response 0x900, card status 0x0
    [    6.050264] mmcblk0: error -84 transferring data, sector 13, nr 3, cmd response 0x900, card status 0x0
    [    6.057238] mmcblk0: error -84 transferring data, sector 14, nr 2, cmd response 0x900, card status 0x0
    [    6.058705] mmcblk0: error -84 transferring data, sector 15, nr 1, cmd response 0x900, card status 0x0
    [    6.058715] Buffer I/O error on dev mmcblk0, logical block 1, async page read
    [    6.059005] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    ** 52 printk messages dropped ** [    6.065593] mmcblk0: error -84 transferring data, sector 15269882, nr 6, cmd response 0x900, card status 0x0
    ** 18 printk messages dropped ** [    6.069256] mmcblk0: retrying using single block read
    ** 3 printk messages dropped ** [    6.069802] mmcblk0: error -84 transferring data, sector 15269827, nr 5, cmd response 0x900, card status 0x0
    ** 14 printk messages dropped ** [    6.071657] mmcblk0: error -84 transferring data, sector 15269879, nr 1, cmd response 0x900, card status 0x0
    ** 12 printk messages dropped ** [    6.073786] mmcblk0: error -84 transferring data, sector 8, nr 8, cmd response 0x900, card status 0xb00
    [    6.073789] mmcblk0: retrying using single block read
    ** 7 printk messages dropped ** [    6.075318] mmcblk0: error -84 transferring data, sector 15, nr 1, cmd response 0x900, card status 0x0
    ** 11 printk messages dropped ** [    6.116558] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    ** 23 printk messages dropped ** [    6.120261] mmcblk0: retrying using single block read
    ** 22 printk messages dropped ** [    6.123844] mmcblk0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    ** 17 printk messages dropped ** [    6.126763] mmcblk0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    ** 7 printk messages dropped ** [    6.128098] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
    ** 74 printk messages dropped ** [    6.147089] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    ** 129 printk messages dropped ** [    6.169535] mmcblk0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    ** 118 printk messages dropped ** [    6.219804] mmcblk0: error -84 transferring data, sector 28, nr 4, cmd response 0x900, card status 0x0
    ** 33 printk messages dropped ** [    6.225384] mmcblk0: error -84 transferring data, sector 61, nr 3, cmd response 0x900, card status 0x0
    ** 38 printk messages dropped ** [    6.249558] mmcblk0: error -84 transferring data, sector 120, nr 8, cmd response 0x900, card status 0x0
    ** 31 printk messages dropped ** [    6.308644] mmcblk0: retrying using single block read
    ** 20 printk messages dropped ** [    6.435325] mmcblk0: error -84 transferring data, sector 8, nr 8, cmd response 0x900, card status 0xb00
    ** 45 printk messages dropped ** [    6.615830] mmcblk0: error -84 transferring data, sector 56, nr 8, cmd response 0x900, card status 0x0
    ** 28 printk messages dropped ** [    6.679610] mmcblk0: error -84 transferring data, sector 127, nr 1, cmd response 0x900, card status 0x0
    ** 23 printk messages dropped ** [    6.723007] mmcblk0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    ** 31 printk messages dropped ** [    6.765942] omap-sham 4b101000.sham: hw accel on OMAP rev 4.3
    ** 20 printk messages dropped ** [    6.781631] mmcblk0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    ** 25 printk messages dropped ** [    6.786248] mmcblk0: error -84 transferring data, sector 134, nr 2, cmd response 0x900, card status 0x0
    ** 34 printk messages dropped ** [    6.871495] mmcblk0: error -84 transferring data, sector 23, nr 1, cmd response 0x900, card status 0x0
    ** 31 printk messages dropped ** [    6.926403] mmcblk0: error -84 transferring data, sector 68, nr 4, cmd response 0x900, card status 0x0
    ** 27 printk messages dropped ** [    6.948468] mmcblk0: retrying using single block read
    ** 21 printk messages dropped ** [    6.952079] mmcblk0: retrying using single block read
    ** 21 printk messages dropped ** [    6.955778] mmcblk0: retrying using single block read
    ** 26 printk messages dropped ** [    6.969841] mmcblk0: error -84 transferring data, sector 260, nr 4, cmd response 0x900, card status 0x0
    ** 42 printk messages dropped ** [    6.976413] mmcblk0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    ** 34 printk messages dropped ** [    6.991654] mmcblk0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    ** 31 printk messages dropped ** [    7.005727] mmcblk0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    ** 26 printk messages dropped ** [    7.010401] mmcblk0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    ** 30 printk messages dropped ** [    7.015684] mmcblk0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    ** 23 printk messages dropped ** [    7.025203] mmcblk0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    ** 25 printk messages dropped ** [    7.029420] mmcblk0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    ** 22 printk messages dropped ** [    7.048313] mmcblk0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    ** 24 printk messages dropped ** [    7.052102] mmcblk0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    ** 25 printk messages dropped ** [    7.068499] mmcblk0: retrying using single block read
    ** 15 printk messages dropped ** [    7.079640] mmcblk0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    ** 25 printk messages dropped ** [    7.118820] mmcblk0: error -84 transferring data, sector 10, nr 6, cmd response 0x900, card status 0x0
    ** 26 printk messages dropped ** [    7.136739] mmcblk0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    ** 25 printk messages dropped ** [    7.156549] mmcblk0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    ** 21 printk messages dropped ** [    7.166335] mmcblk0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    ** 25 printk messages dropped ** [    7.192523] mmcblk0: error -84 transferring data, sector 15, nr 1, cmd response 0x900, card status 0x0
    ** 24 printk messages dropped ** [    7.210238] mmcblk0: retrying using single block read
    ** 16 printk messages dropped ** [    7.213104] mmcblk0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    ** 24 printk messages dropped ** [    7.217209] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    ** 23 printk messages dropped ** [    7.220633] mmcblk0: retrying using single block read
    ** 17 printk messages dropped ** [    7.223560] mmcblk0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    ** 24 printk messages dropped ** [    7.227328] mmcblk0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    ** 24 printk messages dropped ** [    7.231222] mmcblk0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    ** 24 printk messages dropped ** [    7.235646] mmcblk0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    ** 24 printk messages dropped ** [    7.240086] mmcblk0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    ** 26 printk messages dropped ** [    7.244258] mmcblk0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    ** 24 printk messages dropped ** [    7.248282] mmcblk0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    ** 22 printk messages dropped ** [    7.252922] mmcblk0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    ** 25 printk messages dropped ** [    7.266619] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    ** 30 printk messages dropped ** [    7.283300] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    ** 26 printk messages dropped ** [    7.296234] mmcblk0boot1: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    ** 25 printk messages dropped ** [    7.308987] mmcblk0boot1: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    ** 23 printk messages dropped ** [    7.317826] virtio_rpmsg_bus virtio1: creating channel rpmsg-rpc addr 0x3b
    ** 19 printk messages dropped ** [    7.328665] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    ** 23 printk messages dropped ** [    7.339639] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    ** 26 printk messages dropped ** [    7.375730] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    ** 24 printk messages dropped ** [    7.387996] mmcblk0boot0: retrying using single block read
    ** 15 printk messages dropped ** [    7.396588] mmcblk0boot0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    ** 26 printk messages dropped ** [    7.410223] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    ** 24 printk messages dropped ** [    7.422433] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    ** 24 printk messages dropped ** [    7.434769] mmcblk0boot0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    ** 25 printk messages dropped ** [    7.448173] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    ** 23 printk messages dropped ** [    7.457492] mmcblk0boot0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    ** 24 printk messages dropped ** [    7.470932] mmcblk0boot1: retrying using single block read
    ** 19 printk messages dropped ** [    7.485725] mmcblk0boot1: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    ** 22 printk messages dropped ** [    7.496512] mmcblk0boot1: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    ** 25 printk messages dropped ** [    7.507213] mmcblk0boot1: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    ** 23 printk messages dropped ** [    7.515723] mmcblk0boot1: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    ** 25 printk messages dropped ** [    7.528630] hub 2-0:1.0: 1 port detected
    ** 14 printk messages dropped ** [    7.530561] mmcblk0boot0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    ** 23 printk messages dropped ** [    7.542362] hub 3-0:1.0: USB hub found
    ** 13 printk messages dropped ** [    7.545214] mmcblk0boot0: retrying using single block read
    ** 16 printk messages dropped ** [    7.554414] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    ** 24 printk messages dropped ** [    7.564891] mmcblk0boot0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    ** 23 printk messages dropped ** [    7.580896] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    ** 26 printk messages dropped ** [    7.593840] mmcblk0boot0: retrying using single block read
    ** 15 printk messages dropped ** [    7.602451] mmcblk0boot0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    ** 23 printk messages dropped ** [    7.614720] mmcblk0boot0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    ** 22 printk messages dropped ** [    7.626842] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    ** 26 printk messages dropped ** [    7.640057] mmcblk0boot1: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    ** 23 printk messages dropped ** [    7.652295] mmcblk0boot1: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    ** 24 printk messages dropped ** [    7.665124] mmcblk0boot1: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    ** 24 printk messages dropped ** [    7.677741] mmcblk0boot0: error -84 transferring data, sector 8, nr 8, cmd response 0x900, card status 0xb00
    ** 24 printk messages dropped ** [    7.689811] mmcblk0boot0: error -84 transferring data, sector 25, nr 7, cmd response 0x900, card status 0x0
    ** 24 printk messages dropped ** [    7.703497] mmcblk0boot0: error -84 transferring data, sector 28, nr 4, cmd response 0x900, card status 0x0
    ** 23 printk messages dropped ** [    7.715515] mmcblk0boot0: error -84 transferring data, sector 62, nr 2, cmd response 0x900, card status 0x0
    ** 25 printk messages dropped ** [    7.727552] mmcblk0boot0: retrying using single block read
    ** 15 printk messages dropped ** [    7.736586] mmcblk0boot1: error -84 transferring data, sector 12, nr 4, cmd response 0x900, card status 0x0
    ** 24 printk messages dropped ** [    7.749156] mmcblk0boot1: error -84 transferring data, sector 15, nr 1, cmd response 0x900, card status 0x0
    ** 24 printk messages dropped ** [    7.760599] mmcblk0boot1: retrying using single block read
    ** 15 printk messages dropped ** [    7.769047] mmcblk0boot1: error -84 transferring data, sector 28, nr 4, cmd response 0x900, card status 0x0
    ** 24 printk messages dropped ** [    7.781646] mmcblk0boot1: error -84 transferring data, sector 63, nr 1, cmd response 0x900, card status 0x0
    ** 25 printk messages dropped ** [    7.794372] mmcblk0boot0: error -84 transferring data, sector 120, nr 8, cmd response 0x900, card status 0x0
    ** 24 printk messages dropped ** [    7.806983] mmcblk0boot0: error -84 transferring data, sector 123, nr 5, cmd response 0x900, card status 0x0
    ** 23 printk messages dropped ** [    7.819066] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    ** 24 printk messages dropped ** [    7.831755] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    ** 23 printk messages dropped ** [    7.842638] mmcblk0boot0: retrying using single block read
    ** 16 printk messages dropped ** [    7.851671] mmcblk0boot0: error -84 transferring data, sector 61, nr 3, cmd response 0x900, card status 0x0
    ** 23 printk messages dropped ** [    7.864298] mmcblk0boot1: error -84 transferring data, sector 127, nr 1, cmd response 0x900, card status 0x0
    ** 24 printk messages dropped ** [    7.875772] mmcblk0boot1: retrying using single block read
    ** 18 printk messages dropped ** [    7.881972] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    ** 25 printk messages dropped ** [    7.892885] mmcblk0boot1: error -84 transferring data, sector 8, nr 8, cmd response 0x900, card status 0x0
    ** 25 printk messages dropped ** [    7.906077] mmcblk0boot1: error -84 transferring data, sector 28, nr 4, cmd response 0x900, card status 0x0
    ** 24 printk messages dropped ** [    7.919273] mmcblk0boot0: error -84 transferring data, sector 127, nr 1, cmd response 0x900, card status 0x0
    ** 22 printk messages dropped ** [    7.930777] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    ** 28 printk messages dropped ** [    7.944954] mmcblk0boot0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    ** 23 printk messages dropped ** [    7.957215] mmcblk0boot0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    ** 24 printk messages dropped ** [    7.970087] mmcblk0boot1: error -84 transferring data, sector 56, nr 8, cmd response 0x900, card status 0xb00
    ** 26 printk messages dropped ** [    7.983366] mmcblk0boot1: error -84 transferring data, sector 123, nr 5, cmd response 0x900, card status 0x0
    ** 22 printk messages dropped ** [    7.994863] mmcblk0boot1: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    ** 24 printk messages dropped ** [    8.007689] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    ** 23 printk messages dropped ** [    8.019354] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    ** 26 printk messages dropped ** [    8.033500] mmcblk0boot0: error -84 transferring data, sector 131, nr 5, cmd response 0x900, card status 0x0
    ** 24 printk messages dropped ** [    8.046346] mmcblk0boot0: error -84 transferring data, sector 22, nr 2, cmd response 0x900, card status 0x0
    ** 23 printk messages dropped ** [    8.058582] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    ** 22 printk messages dropped ** [    8.069704] mmcblk0boot0: error -84 transferring data, sector 64, nr 8, cmd response 0x900, card status 0xb00
    ** 10 printk messages dropped ** [    8.075243] mmcblk0boot0: error -84 transferring data, sector 64, nr 8, cmd response 0x900, card status 0xb00
    ** 21 printk messages dropped ** [    8.086308] mmcblk0boot0: error -84 transferring data, sector 64, nr 8, cmd response 0x900, card status 0xb00
    ** 26 printk messages dropped ** [    8.100486] mmcblk0boot1: error -84 transferring data, sector 131, nr 5, cmd response 0x900, card status 0x0
    ** 16 printk messages dropped ** [    8.109046] mmcblk0boot1: error -84 transferring data, sector 16, nr 8, cmd response 0x900, card status 0xb00
    [    8.109050] mmcblk0boot1: retrying using single block read
    [    8.109723] mmcblk0boot1: error -84 transferring data, sector 16, nr 8, cmd response 0x900, card status 0x0
    [    8.110328] mmcblk0boot1: error -84 transferring data, sector 17, nr 7, cmd response 0x900, card status 0x0
    [    8.110932] mmcblk0boot1: error -84 transferring data, sector 18, nr 6, cmd response 0x900, card status 0x0
    [    8.111541] mmcblk0boot1: error -84 transferring data, sector 19, nr 5, cmd response 0x900, card status 0x0
    [    8.112142] mmcblk0boot1: error -84 transferring data, sector 20, nr 4, cmd response 0x900, card status 0x0
    [    8.112741] mmcblk0boot1: error -84 transferring data, sector 21, nr 3, cmd response 0x900, card status 0x0
    [    8.113340] mmcblk0boot1: error -84 transferring data, sector 22, nr 2, cmd response 0x900, card status 0x0
    [    8.113935] mmcblk0boot1: error -84 transferring data, sector 23, nr 1, cmd response 0x900, card status 0x0
    [    8.114514] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.114567] mmcblk0boot1: error -84 transferring data, sector 128, nr 8, cmd response 0x900, card status 0xb00
    [    8.114571] mmcblk0boot1: retrying using single block read
    [    8.115246] mmcblk0boot1: error -84 transferring data, sector 128, nr 8, cmd response 0x900, card status 0x0
    [    8.115851] mmcblk0boot1: error -84 transferring data, sector 129, nr 7, cmd response 0x900, card status 0x0
    [    8.116455] mmcblk0boot1: error -84 transferring data, sector 130, nr 6, cmd response 0x900, card status 0x0
    [    8.117058] mmcblk0boot1: error -84 transferring data, sector 131, nr 5, cmd response 0x900, card status 0x0
    [    8.117673] mmcblk0boot1: error -84 transferring data, sector 132, nr 4, cmd response 0x900, card status 0x0
    [    8.118270] mmcblk0boot1: error -84 transferring data, sector 133, nr 3, cmd response 0x900, card status 0x0
    [    8.118866] mmcblk0boot1: error -84 transferring data, sector 134, nr 2, cmd response 0x900, card status 0x0
    [    8.119473] mmcblk0boot1: error -84 transferring data, sector 135, nr 1, cmd response 0x900, card status 0x0
    [    8.120041] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.120100] mmcblk0boot1: error -84 transferring data, sector 64, nr 8, cmd response 0x900, card status 0xb00
    [    8.120103] mmcblk0boot1: retrying using single block read
    [    8.120785] mmcblk0boot1: error -84 transferring data, sector 64, nr 8, cmd response 0x900, card status 0x0
    [    8.121392] mmcblk0boot1: error -84 transferring data, sector 65, nr 7, cmd response 0x900, card status 0x0
    [    8.122001] mmcblk0boot1: error -84 transferring data, sector 66, nr 6, cmd response 0x900, card status 0x0
    [    8.122603] mmcblk0boot1: error -84 transferring data, sector 67, nr 5, cmd response 0x900, card status 0x0
    [    8.123209] mmcblk0boot1: error -84 transferring data, sector 68, nr 4, cmd response 0x900, card status 0x0
    [    8.123815] mmcblk0boot1: error -84 transferring data, sector 69, nr 3, cmd response 0x900, card status 0x0
    [    8.124412] mmcblk0boot1: error -84 transferring data, sector 70, nr 2, cmd response 0x900, card status 0x0
    [    8.125013] mmcblk0boot1: error -84 transferring data, sector 71, nr 1, cmd response 0x900, card status 0x0
    [    8.125582] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.125644] mmcblk0boot1: error -84 transferring data, sector 64, nr 8, cmd response 0x900, card status 0xb00
    [    8.125648] mmcblk0boot1: retrying using single block read
    [    8.126325] mmcblk0boot1: error -84 transferring data, sector 64, nr 8, cmd response 0x900, card status 0x0
    [    8.126937] mmcblk0boot1: error -84 transferring data, sector 65, nr 7, cmd response 0x900, card status 0x0
    [    8.127554] mmcblk0boot1: error -84 transferring data, sector 66, nr 6, cmd response 0x900, card status 0x0
    [    8.128150] mmcblk0boot1: error -84 transferring data, sector 67, nr 5, cmd response 0x900, card status 0x0
    [    8.128754] mmcblk0boot1: error -84 transferring data, sector 68, nr 4, cmd response 0x900, card status 0x0
    [    8.129355] mmcblk0boot1: error -84 transferring data, sector 69, nr 3, cmd response 0x900, card status 0x0
    [    8.129952] mmcblk0boot1: error -84 transferring data, sector 70, nr 2, cmd response 0x900, card status 0x0
    [    8.130550] mmcblk0boot1: error -84 transferring data, sector 71, nr 1, cmd response 0x900, card status 0x0
    [    8.131123] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.131184] mmcblk0boot1: error -84 transferring data, sector 64, nr 8, cmd response 0x900, card status 0xb00
    [    8.131188] mmcblk0boot1: retrying using single block read
    [    8.131867] mmcblk0boot1: error -84 transferring data, sector 64, nr 8, cmd response 0x900, card status 0x0
    [    8.132473] mmcblk0boot1: error -84 transferring data, sector 65, nr 7, cmd response 0x900, card status 0x0
    [    8.133079] mmcblk0boot1: error -84 transferring data, sector 66, nr 6, cmd response 0x900, card status 0x0
    [    8.133680] mmcblk0boot1: error -84 transferring data, sector 67, nr 5, cmd response 0x900, card status 0x0
    [    8.134282] mmcblk0boot1: error -84 transferring data, sector 68, nr 4, cmd response 0x900, card status 0x0
    [    8.134882] mmcblk0boot1: error -84 transferring data, sector 69, nr 3, cmd response 0x900, card status 0x0
    [    8.135480] mmcblk0boot1: error -84 transferring data, sector 70, nr 2, cmd response 0x900, card status 0x0
    [    8.136079] mmcblk0boot1: error -84 transferring data, sector 71, nr 1, cmd response 0x900, card status 0x0
    [    8.136647] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.136707] mmcblk0boot1: error -84 transferring data, sector 64, nr 8, cmd response 0x900, card status 0xb00
    [    8.136711] mmcblk0boot1: retrying using single block read
    [    8.137396] mmcblk0boot1: error -84 transferring data, sector 64, nr 8, cmd response 0x900, card status 0x0
    [    8.138002] mmcblk0boot1: error -84 transferring data, sector 65, nr 7, cmd response 0x900, card status 0x0
    [    8.138604] mmcblk0boot1: error -84 transferring data, sector 66, nr 6, cmd response 0x900, card status 0x0
    [    8.139210] mmcblk0boot1: error -84 transferring data, sector 67, nr 5, cmd response 0x900, card status 0x0
    [    8.139808] mmcblk0boot1: error -84 transferring data, sector 68, nr 4, cmd response 0x900, card status 0x0
    [    8.140407] mmcblk0boot1: error -84 transferring data, sector 69, nr 3, cmd response 0x900, card status 0x0
    [    8.141006] mmcblk0boot1: error -84 transferring data, sector 70, nr 2, cmd response 0x900, card status 0x0
    [    8.141609] mmcblk0boot1: error -84 transferring data, sector 71, nr 1, cmd response 0x900, card status 0x0
    [    8.142178] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.142236] mmcblk0boot1: error -84 transferring data, sector 64, nr 8, cmd response 0x900, card status 0xb00
    [    8.142240] mmcblk0boot1: retrying using single block read
    [    8.142920] mmcblk0boot1: error -84 transferring data, sector 64, nr 8, cmd response 0x900, card status 0x0
    [    8.143525] mmcblk0boot1: error -84 transferring data, sector 65, nr 7, cmd response 0x900, card status 0x0
    [    8.144132] mmcblk0boot1: error -84 transferring data, sector 66, nr 6, cmd response 0x900, card status 0x0
    [    8.144739] mmcblk0boot1: error -84 transferring data, sector 67, nr 5, cmd response 0x900, card status 0x0
    [    8.145344] mmcblk0boot1: error -84 transferring data, sector 68, nr 4, cmd response 0x900, card status 0x0
    [    8.145946] mmcblk0boot1: error -84 transferring data, sector 69, nr 3, cmd response 0x900, card status 0x0
    [    8.146548] mmcblk0boot1: error -84 transferring data, sector 70, nr 2, cmd response 0x900, card status 0x0
    [    8.147149] mmcblk0boot1: error -84 transferring data, sector 71, nr 1, cmd response 0x900, card status 0x0
    [    8.147723] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.147782] mmcblk0boot1: error -84 transferring data, sector 64, nr 8, cmd response 0x900, card status 0xb00
    [    8.147786] mmcblk0boot1: retrying using single block read
    [    8.148459] mmcblk0boot1: error -84 transferring data, sector 64, nr 8, cmd response 0x900, card status 0x0
    [    8.149071] mmcblk0boot1: error -84 transferring data, sector 65, nr 7, cmd response 0x900, card status 0x0
    [    8.149675] mmcblk0boot1: error -84 transferring data, sector 66, nr 6, cmd response 0x900, card status 0x0
    [    8.150283] mmcblk0boot1: error -84 transferring data, sector 67, nr 5, cmd response 0x900, card status 0x0
    [    8.150888] mmcblk0boot1: error -84 transferring data, sector 68, nr 4, cmd response 0x900, card status 0x0
    [    8.151488] mmcblk0boot1: error -84 transferring data, sector 69, nr 3, cmd response 0x900, card status 0x0
    [    8.152086] mmcblk0boot1: error -84 transferring data, sector 70, nr 2, cmd response 0x900, card status 0x0
    [    8.152682] mmcblk0boot1: error -84 transferring data, sector 71, nr 1, cmd response 0x900, card status 0x0
    [    8.153859] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.153911] mmcblk0boot0: error -84 transferring data, sector 64, nr 8, cmd response 0x900, card status 0xb00
    [    8.153914] mmcblk0boot0: retrying using single block read
    [    8.154589] mmcblk0boot0: error -84 transferring data, sector 64, nr 8, cmd response 0x900, card status 0x0
    [    8.155196] mmcblk0boot0: error -84 transferring data, sector 65, nr 7, cmd response 0x900, card status 0x0
    [    8.155800] mmcblk0boot0: error -84 transferring data, sector 66, nr 6, cmd response 0x900, card status 0x0
    [    8.156405] mmcblk0boot0: error -84 transferring data, sector 67, nr 5, cmd response 0x900, card status 0x0
    [    8.157004] mmcblk0boot0: error -84 transferring data, sector 68, nr 4, cmd response 0x900, card status 0x0
    [    8.157611] mmcblk0boot0: error -84 transferring data, sector 69, nr 3, cmd response 0x900, card status 0x0
    [    8.158210] mmcblk0boot0: error -84 transferring data, sector 70, nr 2, cmd response 0x900, card status 0x0
    [    8.158807] mmcblk0boot0: error -84 transferring data, sector 71, nr 1, cmd response 0x900, card status 0x0
    [    8.159380] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.159434] mmcblk0boot0: error -84 transferring data, sector 64, nr 8, cmd response 0x900, card status 0xb00
    [    8.159438] mmcblk0boot0: retrying using single block read
    [    8.160115] mmcblk0boot0: error -84 transferring data, sector 64, nr 8, cmd response 0x900, card status 0x0
    [    8.160722] mmcblk0boot0: error -84 transferring data, sector 65, nr 7, cmd response 0x900, card status 0x0
    [    8.161324] mmcblk0boot0: error -84 transferring data, sector 66, nr 6, cmd response 0x900, card status 0x0
    [    8.161930] mmcblk0boot0: error -84 transferring data, sector 67, nr 5, cmd response 0x900, card status 0x0
    [    8.162532] mmcblk0boot0: error -84 transferring data, sector 68, nr 4, cmd response 0x900, card status 0x0
    [    8.163132] mmcblk0boot0: error -84 transferring data, sector 69, nr 3, cmd response 0x900, card status 0x0
    [    8.163736] mmcblk0boot0: error -84 transferring data, sector 70, nr 2, cmd response 0x900, card status 0x0
    [    8.164331] mmcblk0boot0: error -84 transferring data, sector 71, nr 1, cmd response 0x900, card status 0x0
    [    8.164908] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.164962] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.164965] mmcblk0boot0: retrying using single block read
    [    8.165639] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.166243] mmcblk0boot0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.166849] mmcblk0boot0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.167457] mmcblk0boot0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.168057] mmcblk0boot0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.168660] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.169254] mmcblk0boot0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.169857] mmcblk0boot0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.170428] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.170481] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.170485] mmcblk0boot0: retrying using single block read
    [    8.171159] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.171768] mmcblk0boot0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.172372] mmcblk0boot0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.172975] mmcblk0boot0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.173577] mmcblk0boot0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.174179] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.174774] mmcblk0boot0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.175373] mmcblk0boot0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.175943] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.175999] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.176001] mmcblk0boot0: retrying using single block read
    [    8.176674] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.177279] mmcblk0boot0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.177882] mmcblk0boot0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.178485] mmcblk0boot0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.179089] mmcblk0boot0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.179689] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.180284] mmcblk0boot0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.180882] mmcblk0boot0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.181456] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.181510] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.181513] mmcblk0boot0: retrying using single block read
    [    8.182188] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.182793] mmcblk0boot0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.183395] mmcblk0boot0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.183997] mmcblk0boot0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.184602] mmcblk0boot0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.185204] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.185801] mmcblk0boot0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.186401] mmcblk0boot0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.186972] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.187023] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.187026] mmcblk0boot0: retrying using single block read
    [    8.187713] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.188310] mmcblk0boot0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.188913] mmcblk0boot0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.189516] mmcblk0boot0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.190118] mmcblk0boot0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.190717] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.191313] mmcblk0boot0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.191911] mmcblk0boot0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.192484] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.192537] mmcblk0boot0: error -84 transferring data, sector 16, nr 8, cmd response 0x900, card status 0xb00
    [    8.192541] mmcblk0boot0: retrying using single block read
    [    8.193221] mmcblk0boot0: error -84 transferring data, sector 16, nr 8, cmd response 0x900, card status 0x0
    [    8.193827] mmcblk0boot0: error -84 transferring data, sector 17, nr 7, cmd response 0x900, card status 0x0
    [    8.194431] mmcblk0boot0: error -84 transferring data, sector 18, nr 6, cmd response 0x900, card status 0x0
    [    8.195035] mmcblk0boot0: error -84 transferring data, sector 19, nr 5, cmd response 0x900, card status 0x0
    [    8.195634] mmcblk0boot0: error -84 transferring data, sector 20, nr 4, cmd response 0x900, card status 0x0
    [    8.196236] mmcblk0boot0: error -84 transferring data, sector 21, nr 3, cmd response 0x900, card status 0x0
    [    8.196838] mmcblk0boot0: error -84 transferring data, sector 22, nr 2, cmd response 0x900, card status 0x0
    [    8.197436] mmcblk0boot0: error -84 transferring data, sector 23, nr 1, cmd response 0x900, card status 0x0
    [    8.198006] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.198060] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.198063] mmcblk0boot0: retrying using single block read
    [    8.198736] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.199342] mmcblk0boot0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.199946] mmcblk0boot0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.200550] mmcblk0boot0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.201151] mmcblk0boot0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.201749] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.202347] mmcblk0boot0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.202946] mmcblk0boot0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.203519] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.203573] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.203576] mmcblk0boot0: retrying using single block read
    [    8.204248] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.204854] mmcblk0boot0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.205455] mmcblk0boot0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.206062] mmcblk0boot0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.206660] mmcblk0boot0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.207264] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.208832] mmcblk0boot0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.209251] mmcblk0boot0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.209807] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.209867] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.209870] mmcblk0boot0: retrying using single block read
    [    8.210550] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.211157] mmcblk0boot0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.211758] mmcblk0boot0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.212361] mmcblk0boot0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.212958] mmcblk0boot0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.213563] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.214165] mmcblk0boot0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.214759] mmcblk0boot0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.215941] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.215998] mmcblk0boot1: error -84 transferring data, sector 64, nr 8, cmd response 0x900, card status 0xb00
    [    8.216001] mmcblk0boot1: retrying using single block read
    [    8.216681] mmcblk0boot1: error -84 transferring data, sector 64, nr 8, cmd response 0x900, card status 0x0
    [    8.217290] mmcblk0boot1: error -84 transferring data, sector 65, nr 7, cmd response 0x900, card status 0x0
    [    8.217904] mmcblk0boot1: error -84 transferring data, sector 66, nr 6, cmd response 0x900, card status 0x0
    [    8.218498] mmcblk0boot1: error -84 transferring data, sector 67, nr 5, cmd response 0x900, card status 0x0
    [    8.219100] mmcblk0boot1: error -84 transferring data, sector 68, nr 4, cmd response 0x900, card status 0x0
    [    8.219703] mmcblk0boot1: error -84 transferring data, sector 69, nr 3, cmd response 0x900, card status 0x0
    [    8.220304] mmcblk0boot1: error -84 transferring data, sector 70, nr 2, cmd response 0x900, card status 0x0
    [    8.220902] mmcblk0boot1: error -84 transferring data, sector 71, nr 1, cmd response 0x900, card status 0x0
    [    8.221477] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.221533] mmcblk0boot1: error -84 transferring data, sector 64, nr 8, cmd response 0x900, card status 0xb00
    [    8.221537] mmcblk0boot1: retrying using single block read
    [    8.222212] mmcblk0boot1: error -84 transferring data, sector 64, nr 8, cmd response 0x900, card status 0x0
    [    8.222823] mmcblk0boot1: error -84 transferring data, sector 65, nr 7, cmd response 0x900, card status 0x0
    [    8.223427] mmcblk0boot1: error -84 transferring data, sector 66, nr 6, cmd response 0x900, card status 0x0
    [    8.224035] mmcblk0boot1: error -84 transferring data, sector 67, nr 5, cmd response 0x900, card status 0x0
    [    8.224635] mmcblk0boot1: error -84 transferring data, sector 68, nr 4, cmd response 0x900, card status 0x0
    [    8.225234] mmcblk0boot1: error -84 transferring data, sector 69, nr 3, cmd response 0x900, card status 0x0
    [    8.225835] mmcblk0boot1: error -84 transferring data, sector 70, nr 2, cmd response 0x900, card status 0x0
    [    8.226431] mmcblk0boot1: error -84 transferring data, sector 71, nr 1, cmd response 0x900, card status 0x0
    [    8.227005] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.227062] mmcblk0boot1: error -84 transferring data, sector 64, nr 8, cmd response 0x900, card status 0xb00
    [    8.227065] mmcblk0boot1: retrying using single block read
    [    8.227741] mmcblk0boot1: error -84 transferring data, sector 64, nr 8, cmd response 0x900, card status 0x0
    [    8.228346] mmcblk0boot1: error -84 transferring data, sector 65, nr 7, cmd response 0x900, card status 0x0
    [    8.228951] mmcblk0boot1: error -84 transferring data, sector 66, nr 6, cmd response 0x900, card status 0x0
    [    8.229553] mmcblk0boot1: error -84 transferring data, sector 67, nr 5, cmd response 0x900, card status 0x0
    [    8.230160] mmcblk0boot1: error -84 transferring data, sector 68, nr 4, cmd response 0x900, card status 0x0
    [    8.230760] mmcblk0boot1: error -84 transferring data, sector 69, nr 3, cmd response 0x900, card status 0x0
    [    8.231357] mmcblk0boot1: error -84 transferring data, sector 70, nr 2, cmd response 0x900, card status 0x0
    [    8.231955] mmcblk0boot1: error -84 transferring data, sector 71, nr 1, cmd response 0x900, card status 0x0
    [    8.232527] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.232580] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.232583] mmcblk0boot1: retrying using single block read
    [    8.233258] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.233862] mmcblk0boot1: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.234468] mmcblk0boot1: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.235071] mmcblk0boot1: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.235669] mmcblk0boot1: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.236269] mmcblk0boot1: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.236867] mmcblk0boot1: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.237481] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.238039] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.238093] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.238097] mmcblk0boot1: retrying using single block read
    [    8.238770] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.239380] mmcblk0boot1: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.239981] mmcblk0boot1: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.240589] mmcblk0boot1: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.241187] mmcblk0boot1: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.241790] mmcblk0boot1: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.242391] mmcblk0boot1: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.242986] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.243558] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.243612] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.243615] mmcblk0boot1: retrying using single block read
    [    8.244292] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.244899] mmcblk0boot1: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.245505] mmcblk0boot1: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.246106] mmcblk0boot1: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.246705] mmcblk0boot1: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.247302] mmcblk0boot1: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.247907] mmcblk0boot1: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.248501] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.249074] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.249129] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.249131] mmcblk0boot1: retrying using single block read
    [    8.249804] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.250410] mmcblk0boot1: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.251016] mmcblk0boot1: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.251618] mmcblk0boot1: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.252220] mmcblk0boot1: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.252816] mmcblk0boot1: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.253412] mmcblk0boot1: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.254010] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.254585] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.254639] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.254642] mmcblk0boot1: retrying using single block read
    [    8.255315] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.255919] mmcblk0boot1: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.256528] mmcblk0boot1: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.257133] mmcblk0boot1: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.257741] mmcblk0boot1: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.258338] mmcblk0boot1: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.258934] mmcblk0boot1: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.259533] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.260106] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.260159] mmcblk0boot1: error -84 transferring data, sector 16, nr 8, cmd response 0x900, card status 0xb00
    [    8.260163] mmcblk0boot1: retrying using single block read
    [    8.260836] mmcblk0boot1: error -84 transferring data, sector 16, nr 8, cmd response 0x900, card status 0x0
    [    8.261446] mmcblk0boot1: error -84 transferring data, sector 17, nr 7, cmd response 0x900, card status 0x0
    [    8.262055] mmcblk0boot1: error -84 transferring data, sector 18, nr 6, cmd response 0x900, card status 0x0
    [    8.262659] mmcblk0boot1: error -84 transferring data, sector 19, nr 5, cmd response 0x900, card status 0x0
    [    8.263261] mmcblk0boot1: error -84 transferring data, sector 20, nr 4, cmd response 0x900, card status 0x0
    [    8.263862] mmcblk0boot1: error -84 transferring data, sector 21, nr 3, cmd response 0x900, card status 0x0
    [    8.264461] mmcblk0boot1: error -84 transferring data, sector 22, nr 2, cmd response 0x900, card status 0x0
    [    8.265058] mmcblk0boot1: error -84 transferring data, sector 23, nr 1, cmd response 0x900, card status 0x0
    [    8.265631] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.265684] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.265687] mmcblk0boot1: retrying using single block read
    [    8.266360] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.266965] mmcblk0boot1: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.267569] mmcblk0boot1: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.268172] mmcblk0boot1: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.268768] mmcblk0boot1: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.269370] mmcblk0boot1: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.269966] mmcblk0boot1: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.270561] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.271134] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.271189] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.271192] mmcblk0boot1: retrying using single block read
    [    8.271864] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.272468] mmcblk0boot1: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.273073] mmcblk0boot1: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.273675] mmcblk0boot1: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.274273] mmcblk0boot1: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.274876] mmcblk0boot1: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.275473] mmcblk0boot1: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.276075] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.277254] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.277310] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.277313] mmcblk0boot0: retrying using single block read
    [    8.277990] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.278597] mmcblk0boot0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.279203] mmcblk0boot0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.279808] mmcblk0boot0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.280404] mmcblk0boot0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.281009] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.281608] mmcblk0boot0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.282203] mmcblk0boot0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.282775] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.282829] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.282832] mmcblk0boot0: retrying using single block read
    [    8.283509] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.284115] mmcblk0boot0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.284717] mmcblk0boot0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.285317] mmcblk0boot0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.285918] mmcblk0boot0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.286518] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.287112] mmcblk0boot0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.287714] mmcblk0boot0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.288281] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.288336] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.288340] mmcblk0boot0: retrying using single block read
    [    8.289015] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.289620] mmcblk0boot0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.290223] mmcblk0boot0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.290826] mmcblk0boot0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.291425] mmcblk0boot0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.292026] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.292625] mmcblk0boot0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.293220] mmcblk0boot0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.293797] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.293851] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.293854] mmcblk0boot0: retrying using single block read
    [    8.294526] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.295131] mmcblk0boot0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.295735] mmcblk0boot0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.296343] mmcblk0boot0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.296943] mmcblk0boot0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.297561] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.298150] mmcblk0boot0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.298750] mmcblk0boot0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.299316] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.299375] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.299378] mmcblk0boot0: retrying using single block read
    [    8.300056] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.300666] mmcblk0boot0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.301272] mmcblk0boot0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.301874] mmcblk0boot0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.302477] mmcblk0boot0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.303075] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.303673] mmcblk0boot0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.304267] mmcblk0boot0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.304835] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.304896] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.304900] mmcblk0boot0: retrying using single block read
    [    8.305579] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.306185] mmcblk0boot0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.306786] mmcblk0boot0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.307397] mmcblk0boot0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.307993] mmcblk0boot0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.308590] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.309188] mmcblk0boot0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.309783] mmcblk0boot0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.310355] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.310416] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.310419] mmcblk0boot0: retrying using single block read
    [    8.311095] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.311703] mmcblk0boot0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.312305] mmcblk0boot0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.312909] mmcblk0boot0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.313507] mmcblk0boot0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.314111] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.314707] mmcblk0boot0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.315308] mmcblk0boot0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.315874] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.315932] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.315935] mmcblk0boot0: retrying using single block read
    [    8.316614] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.317222] mmcblk0boot0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.317836] mmcblk0boot0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.318431] mmcblk0boot0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.319032] mmcblk0boot0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.319633] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.320235] mmcblk0boot0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.320834] mmcblk0boot0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.321400] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.321457] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.321460] mmcblk0boot0: retrying using single block read
    [    8.322142] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.322751] mmcblk0boot0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.323352] mmcblk0boot0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.323953] mmcblk0boot0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.324556] mmcblk0boot0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.325152] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.325750] mmcblk0boot0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.326346] mmcblk0boot0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.326915] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.326975] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.326978] mmcblk0boot0: retrying using single block read
    [    8.327662] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.328262] mmcblk0boot0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.328866] mmcblk0boot0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.329465] mmcblk0boot0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.330063] mmcblk0boot0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.330662] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.331264] mmcblk0boot0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.331860] mmcblk0boot0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.332430] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.332490] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.332494] mmcblk0boot0: retrying using single block read
    [    8.333172] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.333776] mmcblk0boot0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.334381] mmcblk0boot0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.334986] mmcblk0boot0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.335591] mmcblk0boot0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.336189] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.336789] mmcblk0boot0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.337391] mmcblk0boot0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.338563] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.338615] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.338618] mmcblk0boot1: retrying using single block read
    [    8.339292] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.339902] mmcblk0boot1: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.340508] mmcblk0boot1: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.341108] mmcblk0boot1: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.341713] mmcblk0boot1: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.342314] mmcblk0boot1: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.342909] mmcblk0boot1: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.343505] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.344083] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.344137] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.344140] mmcblk0boot1: retrying using single block read
    [    8.344811] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.345416] mmcblk0boot1: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.346020] mmcblk0boot1: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.346621] mmcblk0boot1: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.347225] mmcblk0boot1: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.347829] mmcblk0boot1: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.348422] mmcblk0boot1: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.349018] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.349592] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.349645] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.349648] mmcblk0boot1: retrying using single block read
    [    8.350320] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.350927] mmcblk0boot1: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.351528] mmcblk0boot1: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.352129] mmcblk0boot1: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.352734] mmcblk0boot1: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.353336] mmcblk0boot1: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.353932] mmcblk0boot1: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.354530] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.355105] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.355159] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.355162] mmcblk0boot1: retrying using single block read
    [    8.355834] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.356443] mmcblk0boot1: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.357046] mmcblk0boot1: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.357665] mmcblk0boot1: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.358260] mmcblk0boot1: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.358861] mmcblk0boot1: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.359462] mmcblk0boot1: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.360058] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.360626] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.360685] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.360688] mmcblk0boot1: retrying using single block read
    [    8.361370] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.361979] mmcblk0boot1: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.362581] mmcblk0boot1: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.363184] mmcblk0boot1: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.363785] mmcblk0boot1: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.364381] mmcblk0boot1: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.364979] mmcblk0boot1: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.365576] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.366143] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.366201] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.366204] mmcblk0boot1: retrying using single block read
    [    8.366883] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.367492] mmcblk0boot1: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.368084] mmcblk0boot1: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.368687] mmcblk0boot1: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.369285] mmcblk0boot1: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.369885] mmcblk0boot1: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.370481] mmcblk0boot1: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.371081] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.371653] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.371707] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.371710] mmcblk0boot1: retrying using single block read
    [    8.372382] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.372988] mmcblk0boot1: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.373590] mmcblk0boot1: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.374195] mmcblk0boot1: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.374793] mmcblk0boot1: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.375397] mmcblk0boot1: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.375999] mmcblk0boot1: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.376592] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.377167] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.377220] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.377224] mmcblk0boot1: retrying using single block read
    [    8.377900] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.378508] mmcblk0boot1: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.379111] mmcblk0boot1: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.379717] mmcblk0boot1: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.380317] mmcblk0boot1: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.380916] mmcblk0boot1: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.381512] mmcblk0boot1: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.382107] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.382684] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.382738] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.382741] mmcblk0boot1: retrying using single block read
    [    8.383413] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.384019] mmcblk0boot1: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.384623] mmcblk0boot1: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.385223] mmcblk0boot1: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.385823] mmcblk0boot1: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.386420] mmcblk0boot1: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.387020] mmcblk0boot1: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.387629] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.388189] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.388248] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.388252] mmcblk0boot1: retrying using single block read
    [    8.388930] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.389534] mmcblk0boot1: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.390140] mmcblk0boot1: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.390740] mmcblk0boot1: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.391339] mmcblk0boot1: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.391942] mmcblk0boot1: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.392538] mmcblk0boot1: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.393140] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.393710] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.393769] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.393772] mmcblk0boot1: retrying using single block read
    [    8.394455] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.395060] mmcblk0boot1: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.395664] mmcblk0boot1: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.396268] mmcblk0boot1: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.396873] mmcblk0boot1: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.397483] mmcblk0boot1: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.398066] mmcblk0boot1: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.398662] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.399837] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.399890] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.399894] mmcblk0boot0: retrying using single block read
    [    8.400570] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.401174] mmcblk0boot0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.401778] mmcblk0boot0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.402378] mmcblk0boot0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.402978] mmcblk0boot0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.403579] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.404175] mmcblk0boot0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.404771] mmcblk0boot0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.405343] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.405397] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.405401] mmcblk0boot0: retrying using single block read
    [    8.406072] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.406679] mmcblk0boot0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.407277] mmcblk0boot0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.407885] mmcblk0boot0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.408483] mmcblk0boot0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.409084] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.409682] mmcblk0boot0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.410279] mmcblk0boot0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.410854] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.410908] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.410911] mmcblk0boot0: retrying using single block read
    [    8.411580] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.412193] mmcblk0boot0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.412794] mmcblk0boot0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.413400] mmcblk0boot0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.414003] mmcblk0boot0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.414603] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.415206] mmcblk0boot0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.415799] mmcblk0boot0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.416373] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.416429] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.416431] mmcblk0boot0: retrying using single block read
    [    8.417106] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.417727] mmcblk0boot0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.418323] mmcblk0boot0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.418926] mmcblk0boot0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.419525] mmcblk0boot0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.420125] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.420721] mmcblk0boot0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.421320] mmcblk0boot0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.421883] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.421941] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.421945] mmcblk0boot0: retrying using single block read
    [    8.422622] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.423228] mmcblk0boot0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.423832] mmcblk0boot0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.424431] mmcblk0boot0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.425031] mmcblk0boot0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.425633] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.426227] mmcblk0boot0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.426825] mmcblk0boot0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.427402] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.427462] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.427465] mmcblk0boot0: retrying using single block read
    [    8.428145] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.428748] mmcblk0boot0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.429351] mmcblk0boot0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.429958] mmcblk0boot0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.430554] mmcblk0boot0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.431159] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.431753] mmcblk0boot0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.432356] mmcblk0boot0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.432927] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.432984] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.432987] mmcblk0boot0: retrying using single block read
    [    8.433670] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.434275] mmcblk0boot0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.434879] mmcblk0boot0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.435485] mmcblk0boot0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.436090] mmcblk0boot0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.436692] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.437288] mmcblk0boot0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.437890] mmcblk0boot0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.438453] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.438508] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.438511] mmcblk0boot0: retrying using single block read
    [    8.439185] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.439794] mmcblk0boot0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.440398] mmcblk0boot0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.440997] mmcblk0boot0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.441599] mmcblk0boot0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.442197] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.442793] mmcblk0boot0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.443390] mmcblk0boot0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.443962] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.444016] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.444019] mmcblk0boot0: retrying using single block read
    [    8.444692] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.445300] mmcblk0boot0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.445904] mmcblk0boot0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.446505] mmcblk0boot0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.447106] mmcblk0boot0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.447708] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.448302] mmcblk0boot0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.448903] mmcblk0boot0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.449475] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.449528] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.449531] mmcblk0boot0: retrying using single block read
    [    8.450204] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.450815] mmcblk0boot0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.451418] mmcblk0boot0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.452024] mmcblk0boot0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.452626] mmcblk0boot0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.453227] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.453825] mmcblk0boot0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.454427] mmcblk0boot0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.454987] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.455040] mmcblk0boot0: error -84 transferring data, sector 8, nr 8, cmd response 0x900, card status 0xb00
    [    8.455044] mmcblk0boot0: retrying using single block read
    [    8.455709] mmcblk0boot0: error -84 transferring data, sector 8, nr 8, cmd response 0x900, card status 0x0
    [    8.456305] mmcblk0boot0: error -84 transferring data, sector 9, nr 7, cmd response 0x900, card status 0x0
    [    8.456893] mmcblk0boot0: error -84 transferring data, sector 10, nr 6, cmd response 0x900, card status 0x0
    [    8.457500] mmcblk0boot0: error -84 transferring data, sector 11, nr 5, cmd response 0x900, card status 0x0
    [    8.458073] mmcblk0boot0: error -84 transferring data, sector 12, nr 4, cmd response 0x900, card status 0x0
    [    8.458661] mmcblk0boot0: error -84 transferring data, sector 13, nr 3, cmd response 0x900, card status 0x0
    [    8.459244] mmcblk0boot0: error -84 transferring data, sector 14, nr 2, cmd response 0x900, card status 0x0
    [    8.459827] mmcblk0boot0: error -84 transferring data, sector 15, nr 1, cmd response 0x900, card status 0x0
    [    8.461008] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.461060] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.461064] mmcblk0boot1: retrying using single block read
    [    8.461736] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.462343] mmcblk0boot1: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.462947] mmcblk0boot1: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.463558] mmcblk0boot1: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.464154] mmcblk0boot1: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.464758] mmcblk0boot1: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.465356] mmcblk0boot1: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.465954] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.466528] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.466584] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.466588] mmcblk0boot1: retrying using single block read
    [    8.467262] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.467873] mmcblk0boot1: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.468479] mmcblk0boot1: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.469081] mmcblk0boot1: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.469684] mmcblk0boot1: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.470284] mmcblk0boot1: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.470879] mmcblk0boot1: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.471473] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.472052] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.472104] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.472107] mmcblk0boot1: retrying using single block read
    [    8.472781] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.473385] mmcblk0boot1: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.473990] mmcblk0boot1: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.474590] mmcblk0boot1: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.475196] mmcblk0boot1: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.475796] mmcblk0boot1: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.476392] mmcblk0boot1: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.476985] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.477567] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.477630] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.477633] mmcblk0boot1: retrying using single block read
    [    8.478308] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.478912] mmcblk0boot1: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.479515] mmcblk0boot1: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.480117] mmcblk0boot1: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.480717] mmcblk0boot1: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.481321] mmcblk0boot1: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.481916] mmcblk0boot1: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.482517] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.483089] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.483142] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.483145] mmcblk0boot1: retrying using single block read
    [    8.483819] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.484425] mmcblk0boot1: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.485034] mmcblk0boot1: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.485636] mmcblk0boot1: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.486239] mmcblk0boot1: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.486840] mmcblk0boot1: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.487442] mmcblk0boot1: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.488036] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.488610] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.488663] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.488666] mmcblk0boot1: retrying using single block read
    [    8.489342] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.489952] mmcblk0boot1: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.490554] mmcblk0boot1: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.491156] mmcblk0boot1: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.491755] mmcblk0boot1: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.492353] mmcblk0boot1: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.492951] mmcblk0boot1: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.493547] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.494120] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.494174] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.494177] mmcblk0boot1: retrying using single block read
    [    8.494850] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.495454] mmcblk0boot1: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.496056] mmcblk0boot1: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.496658] mmcblk0boot1: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.497256] mmcblk0boot1: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.497873] mmcblk0boot1: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.498461] mmcblk0boot1: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.499061] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.499628] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.499686] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.499690] mmcblk0boot1: retrying using single block read
    [    8.500367] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.500972] mmcblk0boot1: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.501575] mmcblk0boot1: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.502180] mmcblk0boot1: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.502787] mmcblk0boot1: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.503383] mmcblk0boot1: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.503983] mmcblk0boot1: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.504580] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.505153] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.505214] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.505217] mmcblk0boot1: retrying using single block read
    [    8.505899] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.506507] mmcblk0boot1: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.507110] mmcblk0boot1: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.507726] mmcblk0boot1: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.508318] mmcblk0boot1: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.508920] mmcblk0boot1: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.509516] mmcblk0boot1: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.510115] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.510682] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.510740] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.510744] mmcblk0boot1: retrying using single block read
    [    8.511428] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.512031] mmcblk0boot1: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.512633] mmcblk0boot1: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.513234] mmcblk0boot1: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.513834] mmcblk0boot1: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.514433] mmcblk0boot1: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.515029] mmcblk0boot1: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.515628] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.516196] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.516253] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.516256] mmcblk0boot1: retrying using single block read
    [    8.516937] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.517552] mmcblk0boot1: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.518140] mmcblk0boot1: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.518743] mmcblk0boot1: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.519340] mmcblk0boot1: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.519939] mmcblk0boot1: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.520544] mmcblk0boot1: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.521139] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.522316] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.522368] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.522371] mmcblk0boot0: retrying using single block read
    [    8.523043] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.523651] mmcblk0boot0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.524259] mmcblk0boot0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.524863] mmcblk0boot0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.525465] mmcblk0boot0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.526064] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.526664] mmcblk0boot0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.527260] mmcblk0boot0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.527831] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.527885] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.527888] mmcblk0boot0: retrying using single block read
    [    8.528564] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.529174] mmcblk0boot0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.529779] mmcblk0boot0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.530380] mmcblk0boot0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.530979] mmcblk0boot0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.531577] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.532175] mmcblk0boot0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.532771] mmcblk0boot0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.533342] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.533396] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.533399] mmcblk0boot0: retrying using single block read
    [    8.534074] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.534682] mmcblk0boot0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.535283] mmcblk0boot0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.535884] mmcblk0boot0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.536485] mmcblk0boot0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.537086] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.537681] mmcblk0boot0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.538284] mmcblk0boot0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.538854] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.538903] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.538906] mmcblk0boot0: retrying using single block read
    [    8.539574] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.540181] mmcblk0boot0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.540786] mmcblk0boot0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.541394] mmcblk0boot0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.541993] mmcblk0boot0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.542597] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.543197] mmcblk0boot0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.543794] mmcblk0boot0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.544365] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.544418] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.544421] mmcblk0boot0: retrying using single block read
    [    8.545098] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.545704] mmcblk0boot0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.546309] mmcblk0boot0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.546916] mmcblk0boot0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.547529] mmcblk0boot0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.548119] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.548715] mmcblk0boot0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.549309] mmcblk0boot0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.549883] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.549943] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.549947] mmcblk0boot0: retrying using single block read
    [    8.550622] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.551229] mmcblk0boot0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.551833] mmcblk0boot0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.552433] mmcblk0boot0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.553057] mmcblk0boot0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.553628] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.554225] mmcblk0boot0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.554819] mmcblk0boot0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.555396] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.555450] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.555453] mmcblk0boot0: retrying using single block read
    [    8.556127] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.556731] mmcblk0boot0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.557349] mmcblk0boot0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.557936] mmcblk0boot0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.558534] mmcblk0boot0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.559138] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.559735] mmcblk0boot0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.560335] mmcblk0boot0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.560910] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.560963] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.560966] mmcblk0boot0: retrying using single block read
    [    8.561643] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.562247] mmcblk0boot0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.562853] mmcblk0boot0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.563454] mmcblk0boot0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.564060] mmcblk0boot0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.564664] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.565258] mmcblk0boot0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.565857] mmcblk0boot0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.566427] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.566482] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.566484] mmcblk0boot0: retrying using single block read
    [    8.567157] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.567768] mmcblk0boot0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.568368] mmcblk0boot0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.568971] mmcblk0boot0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.569571] mmcblk0boot0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.570174] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.570768] mmcblk0boot0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.571365] mmcblk0boot0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.571937] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.571990] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.571993] mmcblk0boot0: retrying using single block read
    [    8.572664] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.573275] mmcblk0boot0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.573877] mmcblk0boot0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.574477] mmcblk0boot0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.575081] mmcblk0boot0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.575679] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.576274] mmcblk0boot0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.576875] mmcblk0boot0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.577437] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.577489] mmcblk0boot0: error -84 transferring data, sector 24, nr 8, cmd response 0x900, card status 0xb00
    [    8.577493] mmcblk0boot0: retrying using single block read
    [    8.578157] mmcblk0boot0: error -84 transferring data, sector 24, nr 8, cmd response 0x900, card status 0x0
    [    8.578753] mmcblk0boot0: error -84 transferring data, sector 25, nr 7, cmd response 0x900, card status 0x0
    [    8.579345] mmcblk0boot0: error -84 transferring data, sector 26, nr 6, cmd response 0x900, card status 0x0
    [    8.579940] mmcblk0boot0: error -84 transferring data, sector 27, nr 5, cmd response 0x900, card status 0x0
    [    8.580531] mmcblk0boot0: error -84 transferring data, sector 28, nr 4, cmd response 0x900, card status 0x0
    [    8.581120] mmcblk0boot0: error -84 transferring data, sector 29, nr 3, cmd response 0x900, card status 0x0
    [    8.581708] mmcblk0boot0: error -84 transferring data, sector 30, nr 2, cmd response 0x900, card status 0x0
    [    8.582296] mmcblk0boot0: error -84 transferring data, sector 31, nr 1, cmd response 0x900, card status 0x0
    [    8.583458] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.583510] mmcblk0boot1: error -84 transferring data, sector 8, nr 8, cmd response 0x900, card status 0xb00
    [    8.583513] mmcblk0boot1: retrying using single block read
    [    8.584179] mmcblk0boot1: error -84 transferring data, sector 8, nr 8, cmd response 0x900, card status 0x0
    [    8.584772] mmcblk0boot1: error -84 transferring data, sector 9, nr 7, cmd response 0x900, card status 0x0
    [    8.585361] mmcblk0boot1: error -84 transferring data, sector 10, nr 6, cmd response 0x900, card status 0x0
    [    8.585951] mmcblk0boot1: error -84 transferring data, sector 11, nr 5, cmd response 0x900, card status 0x0
    [    8.586538] mmcblk0boot1: error -84 transferring data, sector 12, nr 4, cmd response 0x900, card status 0x0
    [    8.587128] mmcblk0boot1: error -84 transferring data, sector 13, nr 3, cmd response 0x900, card status 0x0
    [    8.587717] mmcblk0boot1: error -84 transferring data, sector 14, nr 2, cmd response 0x900, card status 0x0
    [    8.588301] mmcblk0boot1: error -84 transferring data, sector 15, nr 1, cmd response 0x900, card status 0x0
    [    8.588873] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.588927] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.588931] mmcblk0boot1: retrying using single block read
    [    8.589605] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.590214] mmcblk0boot1: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.590821] mmcblk0boot1: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.591422] mmcblk0boot1: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.592021] mmcblk0boot1: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.592622] mmcblk0boot1: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.593218] mmcblk0boot1: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.593819] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.594390] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.594443] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.594446] mmcblk0boot1: retrying using single block read
    [    8.595119] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.595724] mmcblk0boot1: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.596330] mmcblk0boot1: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.596932] mmcblk0boot1: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.597533] mmcblk0boot1: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.598134] mmcblk0boot1: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.598729] mmcblk0boot1: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.599331] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.599905] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.599958] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.599961] mmcblk0boot1: retrying using single block read
    [    8.600635] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.601241] mmcblk0boot1: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.601842] mmcblk0boot1: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.602445] mmcblk0boot1: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.603049] mmcblk0boot1: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.603648] mmcblk0boot1: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.604248] mmcblk0boot1: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.604847] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.605420] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.605473] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.605477] mmcblk0boot1: retrying using single block read
    [    8.606149] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.606761] mmcblk0boot1: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.607390] mmcblk0boot1: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.607980] mmcblk0boot1: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.608576] mmcblk0boot1: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.609174] mmcblk0boot1: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.609772] mmcblk0boot1: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.610369] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.610936] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.610997] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.611000] mmcblk0boot1: retrying using single block read
    [    8.611682] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.612286] mmcblk0boot1: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.612889] mmcblk0boot1: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.613490] mmcblk0boot1: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.614089] mmcblk0boot1: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.614689] mmcblk0boot1: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.615286] mmcblk0boot1: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.615882] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.616451] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.616511] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.616515] mmcblk0boot1: retrying using single block read
    [    8.617196] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.617805] mmcblk0boot1: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.618402] mmcblk0boot1: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.619003] mmcblk0boot1: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.619604] mmcblk0boot1: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.620202] mmcblk0boot1: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.620802] mmcblk0boot1: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.621399] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.621969] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.622028] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.622031] mmcblk0boot1: retrying using single block read
    [    8.622709] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.623318] mmcblk0boot1: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.623920] mmcblk0boot1: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.624527] mmcblk0boot1: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.625126] mmcblk0boot1: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.625731] mmcblk0boot1: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.626332] mmcblk0boot1: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.626927] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.627499] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.627560] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.627563] mmcblk0boot1: retrying using single block read
    [    8.628245] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.628852] mmcblk0boot1: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.629457] mmcblk0boot1: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.630063] mmcblk0boot1: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.630663] mmcblk0boot1: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.631260] mmcblk0boot1: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.631858] mmcblk0boot1: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.632454] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.633026] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.633086] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.633089] mmcblk0boot1: retrying using single block read
    [    8.633768] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.634375] mmcblk0boot1: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.634978] mmcblk0boot1: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.635578] mmcblk0boot1: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.636179] mmcblk0boot1: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.636777] mmcblk0boot1: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.637378] mmcblk0boot1: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.637964] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.638539] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.638593] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.638596] mmcblk0boot1: retrying using single block read
    [    8.639267] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.639873] mmcblk0boot1: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.640480] mmcblk0boot1: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.641081] mmcblk0boot1: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.641680] mmcblk0boot1: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.642284] mmcblk0boot1: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.642878] mmcblk0boot1: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.643478] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.644657] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.644710] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.644714] mmcblk0boot0: retrying using single block read
    [    8.645389] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.645995] mmcblk0boot0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.646599] mmcblk0boot0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.647205] mmcblk0boot0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.647810] mmcblk0boot0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.648407] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.649004] mmcblk0boot0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.649598] mmcblk0boot0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.650172] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.650226] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.650229] mmcblk0boot0: retrying using single block read
    [    8.650903] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.651511] mmcblk0boot0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.652113] mmcblk0boot0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.652715] mmcblk0boot0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.653316] mmcblk0boot0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.653913] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.654508] mmcblk0boot0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.655109] mmcblk0boot0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.655678] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.655730] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.655733] mmcblk0boot0: retrying using single block read
    [    8.656404] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.657012] mmcblk0boot0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.657615] mmcblk0boot0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.658217] mmcblk0boot0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.658815] mmcblk0boot0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.659414] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.660018] mmcblk0boot0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.660613] mmcblk0boot0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.661190] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.661244] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.661247] mmcblk0boot0: retrying using single block read
    [    8.661920] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.662530] mmcblk0boot0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.663132] mmcblk0boot0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.663737] mmcblk0boot0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.664337] mmcblk0boot0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.664941] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.665540] mmcblk0boot0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.666137] mmcblk0boot0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.666708] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.666760] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.666763] mmcblk0boot0: retrying using single block read
    [    8.667455] mmcblk0boot0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.668050] mmcblk0boot0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.668657] mmcblk0boot0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.669259] mmcblk0boot0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.669861] mmcblk0boot0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.670458] mmcblk0boot0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.671059] mmcblk0boot0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.671655] mmcblk0boot0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.681707] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.681759] mmcblk0boot1: error -84 transferring data, sector 24, nr 8, cmd response 0x900, card status 0xb00
    [    8.681763] mmcblk0boot1: retrying using single block read
    [    8.682429] mmcblk0boot1: error -84 transferring data, sector 24, nr 8, cmd response 0x900, card status 0x0
    [    8.683022] mmcblk0boot1: error -84 transferring data, sector 25, nr 7, cmd response 0x900, card status 0x0
    [    8.683619] mmcblk0boot1: error -84 transferring data, sector 26, nr 6, cmd response 0x900, card status 0x0
    [    8.684213] mmcblk0boot1: error -84 transferring data, sector 27, nr 5, cmd response 0x900, card status 0x0
    [    8.684802] mmcblk0boot1: error -84 transferring data, sector 28, nr 4, cmd response 0x900, card status 0x0
    [    8.685391] mmcblk0boot1: error -84 transferring data, sector 29, nr 3, cmd response 0x900, card status 0x0
    [    8.685980] mmcblk0boot1: error -84 transferring data, sector 30, nr 2, cmd response 0x900, card status 0x0
    [    8.686566] mmcblk0boot1: error -84 transferring data, sector 31, nr 1, cmd response 0x900, card status 0x0
    [    8.687140] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.687194] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.687197] mmcblk0boot1: retrying using single block read
    [    8.687876] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.688477] mmcblk0boot1: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.689079] mmcblk0boot1: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.689682] mmcblk0boot1: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.690282] mmcblk0boot1: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.690882] mmcblk0boot1: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.691480] mmcblk0boot1: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.692079] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.692653] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.692707] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.692710] mmcblk0boot1: retrying using single block read
    [    8.693381] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.693987] mmcblk0boot1: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.694592] mmcblk0boot1: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.695199] mmcblk0boot1: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.695798] mmcblk0boot1: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.696403] mmcblk0boot1: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.696998] mmcblk0boot1: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.697600] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.698171] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.698225] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.698228] mmcblk0boot1: retrying using single block read
    [    8.698899] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.699512] mmcblk0boot1: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.700117] mmcblk0boot1: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.700719] mmcblk0boot1: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.701318] mmcblk0boot1: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.701917] mmcblk0boot1: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.702514] mmcblk0boot1: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.703112] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.703683] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.703736] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.703739] mmcblk0boot1: retrying using single block read
    [    8.704411] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.705016] mmcblk0boot1: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.705620] mmcblk0boot1: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.706222] mmcblk0boot1: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.706820] mmcblk0boot1: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.708853] mmcblk0boot1: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.709261] mmcblk0boot1: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.709857] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [    8.710432] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xfd441008 follows the erroneous one
    [    8.710485] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb00
    [    8.710488] mmcblk0boot1: retrying using single block read
    [    8.711160] mmcblk0boot1: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
    [    8.711765] mmcblk0boot1: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
    [    8.712367] mmcblk0boot1: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
    [    8.712974] mmcblk0boot1: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
    [    8.713572] mmcblk0boot1: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
    [    8.714178] mmcblk0boot1: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
    [    8.714772] mmcblk0boot1: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
    [    8.715373] mmcblk0boot1: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
    [   17.497366] ata1: softreset failed (1st FIS failed)
    udevd[404]: failed to execute '/etc/udev/scripts/mount.sh' '/etc/udev/scripts/mount.sh': No such file or directory
    udevd[413]: failed to execute '/etc/udev/scripts/mount.sh' '/etc/udev/scripts/mount.sh': No such file or directory
    udevd[417]: failed to execute '/etc/udev/scripts/mount.sh' '/etc/udev/scripts/mount.sh': No such file or directory
    udevd[444]: failed to execute '/etc/udev/scripts/mount.sh' '/etc/udev/scripts/mount.sh': No such file or directory
    [   27.507359] ata1: softreset failed (1st FIS failed)
    [   27.857363] ata1: SATA link down (SStatus 0 SControl 300)
    [   27.896671] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
    Starting Bootlog daemon: bootlogd.
    ALSA: Restoring mixer settings...
    No state is present for card DRA7xxEVMMCASP1
    Found hardware: "DRA7xx-EVM-MCAS" "" "" "" ""
    Hardware is initialized using a generic method
    No state is present for card DRA7xxEVMMCASP2
    No state is present for card DRA7xxEVMMCASP3
    No state is present for card DRA7xxEVMMCASP4
    No state is present for card DRA7xxEVMMCASP8
    Thu Sep  3 18:41:00 UTC 2015
    2017.11.23 15:00
    This version is for J6
    ****** This application only support ASCII code 0 to 127 ******
    ****** This application only support CB version #F ******
    [   43.416085] xhci-hcd xhci-hcd.1.auto: remove, state 4
    [   43.422627] usb usb4: USB disconnect, device number 1
    [   43.430892] xhci-hcd xhci-hcd.1.auto: USB bus 4 deregistered
    [   43.436608] xhci-hcd xhci-hcd.1.auto: remove, state 4
    [   43.441755] usb usb3: USB disconnect, device number 1
    [   43.449122] xhci-hcd xhci-hcd.1.auto: USB bus 3 deregistered
    [   43.455756] xhci-hcd xhci-hcd.0.auto: remove, state 4
    [   43.460880] usb usb2: USB disconnect, device number 1
    [   43.468127] xhci-hcd xhci-hcd.0.auto: USB bus 2 deregistered
    [   43.473839] xhci-hcd xhci-hcd.0.auto: remove, state 4
    [   43.479011] usb usb1: USB disconnect, device number 1
    [   43.486322] xhci-hcd xhci-hcd.0.auto: USB bus 1 deregistered
    [   43.597557] usbcore: deregistering device driver usb
    [   43.604204] usbcore: deregistering interface driver usbfs
    [   43.611324] usbcore: deregistering interface driver hub
    [AB_server.c, make_sure_usb_kernel_stack_removed, 374] temp: drwxr-xr-x   27 root     root             0 Jan  1  1970 .
    dr-xr-xr-x   12 root     root             0 Jan  1  1970 ..
    drwxr-xr-x    4 root     root             0 Jan  1  1970 ac97
    drwxr-xr-x    4 root     root             0 Jan  1  1970 clockevents
    drwxr-xr-x    4 root     root             0 Jan  1  1970 clocksource
    drwxr-xr-x    4 root     root             0 Jan  1  1970 container
    drwxr-xr-x    4 root     root             0 Jan  1  1970 cpu
    drwxr-xr-x    4 root     root             0 Jan  1  1970 edac
    drwxr-xr-x    4 root     root             0 Jan  1  1970 event_source
    drwxr-xr-x    4 root     root             0 Jan  1  1970 hid
    drwxr-xr-x    4 root     root             0 Jan  1  1970 i2c
    drwxr-xr-x    4 root     root             0 Jan  1  1970 iio
    drwxr-xr-x    4 root     root             0 Jan  1  1970 mdio_bus
    drwxr-xr-x    4 root     root             0 Jan  1  1970 media
    drwxr-xr-x    4 root     root             0 Jan  1  1970 mipi-dsi
    drwxr-xr-x    4 root     root             0 Jan  1  1970 mmc
    drwxr-xr-x    5 root     root             0 Jan  1  1970 pci
    drwxr-xr-x    4 root     root             0 Jan  1  1970 platform
    drwxr-xr-x    4 root     root             0 Jan  1  1970 rpmsg
    drwxr-xr-x    4 root     root             0 Jan  1  1970 scsi
    drwxr-xr-x    4 root     root             0 Jan  1  1970 sdio
    drwxr-xr-x    4 root     root             0 Jan  1  1970 serio
    drwxr-xr-x    4 root     root             0 Jan  1  1970 soc
    drwxr-xr-x    4 root     root             0 Jan  1  1970 spi
    drwxr-xr-x    4 root     root             0 Jan  1  1970 ulpi
    drwxr-xr-x    4 root     root             0 Jan  1  1970 virtio
    drwxr-xr-x    4 root     root             0 Jan  1  1970 workqueue
    [AB_server.c, AB_boot_finish, 181] AB boot success, pull high GPIO
    [AB_server.c, AB_boot_finish, 187] AB boot success, pull high GPIO finished
    [AB_server.c, get_CB_hardware_version, 212] Wait for CB send HW version
    [AB_server.c, get_CB_hardware_version, 216] Read CB HW version (0) Bytes
    /usr/local/bin/set_unused_gpio_input: line 14: echo: write error: Device or resource busy
    /usr/local/bin/set_unused_gpio_input: line 15: /sys/class/gpio/gpio161/direction: No such file or directory
    INIT: Entering runlevel: 5
    Configuring network interfaces... [   45.373449] net eth0: initializing cpsw version 1.15 (0)
    [   45.379130] net eth0: initialized cpsw ale version 1.4
    [   45.384293] net eth0: ALE Table size 1024
    [   45.391355] libphy: PHY 48485000.mdio:02 not found
    [   45.396173] net eth0: phy "48485000.mdio:02" not found on slave 0, err -19
    [   45.410785] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
    /bin/sh: udhcpc: command not found
    done.
    Starting system message bus: dbus.
    [AB_server.c, get_CB_hardware_version, 216] Read CB HW version (4) Bytes
    _version[0]: 30
    _version[1]: 31
    _version[2]: 31
    _version[3]: 30
    _version[4]: 0
    _version[5]: 0
    _version[6]: 0
    _version[7]: 0
    _version[8]: 0
    _version[9]: 0
    _version[10]: 0
    _version[11]: 0
    _version[12]: 0
    _version[13]: 0
    _version[14]: 0
    _version[15]: 0
    [AB_server.c, main, 517] AB_server: get CB's HW version 0110
    [AB_server.c, get_CB_hardware_version_finish, 254] AB get CB hw version finish, gpio pull low
    [AB_server.c, send_AB_model_info_to_CB, 279] write AB model info total (6) Bytes, model: (DRA74X
    [AB_server.c, sync_CB_status, 308] ______ AB GPIO 109 status: 0
     ______
    [AB_server.c, sync_CB_status, 317] ______ AB GPIO 109 LOW, AB booting ______
     ______
    UIM SYSFS Node Not Found
    Starting telnet daemon.
    Starting tiipclad daemon
    GateMP support enabled on host
    Opened log file: lad.txt
    numProcessors = 5 id = 0 baseId = 0
    Spawned daemon: /usr/bin/lad_dra7xx
    Starting rpcbind daemon...[AB_server.c, sync_CB_status, 308] ______ AB GPIO 109 status: 1
     ______
    [AB_server.c, sync_CB_status, 312] ______ AB GPIO 109 1, can go ______
    done.
    creating NFS state directory: done
    starting statd: done
    NFS daemon support not enabled in kernel
    Starting syslogd/klogd: done
    Starting thttpd.
    Enabling thermal zones...
    Stopping Bootlog daemon: bootlogd.
    root@wnc-j6:~# [AB_server.c, main, 550] ulpi on/off : J6, ULPI test on
    cat /sys/kernel/debug/mmc0/ios
    clock:          52000000 Hz
    vdd:            21 (3.3 ~ 3.4 V)
    bus mode:       2 (push-pull)
    chip select:    0 (don't care)
    power mode:     2 (on)
    bus width:      2 (4 bits)
    timing spec:    1 (mmc high-speed)
    signal voltage: 0 (3.30 V)
    driver type:    0 (driver type B)
    root@wnc-j6:~# lsblk
    NAME         MAJ:MIN RM  SIZE RO TYPE MOUNTPOINT
    mmcblk0boot0 179:16   0  128K  1 disk
    mmcblk0boot1 179:32   0  128K  1 disk
    mmcblk1boot0 179:64   0  128K  1 disk
    mmcblk1boot1 179:80   0  128K  1 disk
    mmcblk0      179:0    0  7.3G  0 disk
    mmcblk1      179:48   0  7.3G  0 disk
    |-mmcblk1p1  179:49   0   64M  0 part
    `-mmcblk1p2  179:50   0  7.2G  0 part /
    mmcblk2      179:96   0  3.7G  0 disk
    |-mmcblk2p1  179:97   0   62M  0 part
    `-mmcblk2p2  179:98   0  3.6G  0 part
    root@wnc-j6:~#
    Gibbs
  • Hi Gibbs,
    1. * DRA746 eMMC1 interface boots with eMMC flash, include TS3A27518, VDD 3.3V, IO 3.3V ? please confirm?  log as below?
    [Kevin] This kernel is latest SDK version (6.00.00.03) and VDD 3.3V, IO unknown, the booting stuck at "Waiting for root device PARTUUID=bddb4f41-02..."
    2. * DRA746 eMMC1 interface boots with eMMC flash, include TS3A27518, VDD 1.8V, IO 1.8V ? please confirm?  log as below?
    [Kevin] Yes, VDD 1.8V, IO 1.8V. DTS is as below:
     * Copyright (C) 2013 Texas Instruments Incorporated - http://www.ti.com/
     * This program is free software; you can redistribute it and/or modify
     * it under the terms of the GNU General Public License version 2 as
     * published by the Free Software Foundation.
    /dts-v1/;
    #include "dra74x.dtsi"
    #include <dt-bindings/gpio/gpio.h>
    #include <dt-bindings/clk/ti-dra7-atl.h>
    #include <dt-bindings/input/input.h>
    #include <dt-bindings/pinmux/mux_dra7xx.h>
    	model = "TI DRA746 KC 20230317 12:48";
    	compatible = "ti,dra7-evm", "ti,dra742", "ti,dra74", "ti,dra7";
    	version = "30003-20161032";
    	memory {
    		device_type = "memory";
    		reg = <0x0 0x80000000 0x0 0x80000000>; /* 2048 MB */
    //		reg = <0x0 0x80000000 0x0 0x60000000>; /* 1536 MB */
    	reserved_mem: reserved-memory {
    		#address-cells = <2>;
    		#size-cells = <2>;
    		ranges;
    		ipu2_cma_pool: ipu2_cma@95800000 {
    			compatible = "shared-dma-pool";
    			reg = <0x0 0x95800000 0x0 0x3800000>;
    			reusable;
    			status = "okay";
    		dsp1_cma_pool: dsp1_cma@99000000 {
    			reg = <0x0 0x99000000 0x0 0x4000000>;
    			reusable;
    			status = "okay";
    		ipu1_cma_pool: ipu1_cma@9d000000 {
    			reg = <0x0 0x9d000000 0x0 0x2000000>;
    			reusable;
    			status = "okay";
    		dsp2_cma_pool: dsp2_cma@9f000000 {
    			reg = <0x0 0x9f000000 0x0 0x800000>;
    			reusable;
    			status = "okay";
    #if 0
    	aliases {
    		display0 = &hdmi0;
    		display1 = &fpd_disp;
    		//sound0 = &snd0;
    		sound1 = &hdmi;
    		//i2c7 = &disp_ser;
    #endif
    	evm_3v3_sd: fixedregulator-sd {
    		compatible = "regulator-fixed";
    		regulator-name = "evm_3v3_sd";
    		regulator-min-microvolt = <3300000>;
    		regulator-max-microvolt = <3300000>;
    		regulator-always-on;
    		regulator-boot-on;
    	evm_1v8_sd: fixedregulator-sd {
    		regulator-name = "evm_1v8_sd";
    		regulator-min-microvolt = <1800000>;
    		regulator-max-microvolt = <1800000>;
    		regulator-boot-on;
    	evm_3v3_sw: fixedregulator-evm_3v3_sw {
    		regulator-name = "evm_3v3_sw";
    		vin-supply = <&sysen1>;
    	aic_dvdd: fixedregulator-aic_dvdd {
    		/* TPS77018DBVT */
    		regulator-name = "aic_dvdd";
    		vin-supply = <&evm_3v3_sw>;
    	vmmcwl_fixed: fixedregulator-mmcwl {
    		regulator-name = "vmmcwl_fixed";
    		//gpio = <&gpio5 8 0>;	/* gpio5_8 */
    		startup-delay-us = <70000>;
    		regulator-boot-on;
    #if 0
    	extcon_usb1: extcon_usb1 {
    		compatible = "linux,extcon-usb-gpio";
    		id-gpio = <&pcf_gpio_21 1 GPIO_ACTIVE_HIGH>;
    	extcon_usb2: extcon_usb2 {
    		id-gpio = <&pcf_gpio_21 2 GPIO_ACTIVE_HIGH>;
    #endif
    	vtt_fixed: fixedregulator-vtt {
    		regulator-name = "vtt_fixed";
    		regulator-min-microvolt = <1350000>;
    		regulator-max-microvolt = <1350000>;
    		regulator-boot-on;
    		enable-active-high;
    		vin-supply = <&sysen2>;
    		//gpio = <&gpio7 11 GPIO_ACTIVE_HIGH>;
    	btsco_mcasp1: btsco_mcasp1@0 {
    		#sound-dai-cells = <0>;
    		compatible = "delta,dfbmcs320-mcasp1";
    		status = "okay";
    	btsco_mcasp2: btsco_mcasp2@0 {
    		compatible = "delta,dfbmcs320-mcasp2";
    		status = "okay";
    	btsco_mcasp3: btsco_mcasp3@0 {
    		compatible = "delta,dfbmcs320-mcasp3";
    		status = "okay";
    	btsco_mcasp4: btsco_mcasp4@0 {
    		compatible = "delta,dfbmcs320-mcasp4";
    		status = "okay";
    	btsco_mcasp8: btsco_mcasp8@0 {
    		compatible = "delta,dfbmcs320-mcasp8";
    		status = "okay";
    	snd1: sound@1 {
    		compatible = "simple-audio-card-mcasp1";
    		simple-audio-card,name = "DRA7xx-EVM-MCASP1";
    #if 0
    		/* we do not have codec */
    		simple-audio-card,mclk-fs = <256>;
    #endif
    		simple-audio-card,widgets =
    			"Headphone", "Headphone Jack",
    			"Line", "Line Out",
    			"Microphone", "Mic Jack",
    			"Line", "Line In";
    		simple-audio-card,routing =
    			"Headphone Jack",       "HPLOUT",
    			"Headphone Jack",       "HPROUT",
    			"Line Out",		"LLOUT",
    			"Line Out",		"RLOUT",
    			"MIC3L",		"Mic Jack",
    			"MIC3R",		"Mic Jack",
    			"Mic Jack",		"Mic Bias",
    			"LINE1L",               "Line In",
    			"LINE1R",               "Line In";
    		status = "okay";
    		simple-audio-card,dai-link@0 {
    			format = "i2s";
    			bitclock-master = <&btsco_codec1>;
    			frame-master = <&btsco_codec1>;
    			bitclock-inversion;
    			cpu {
    				sound-dai = <&mcasp1>;
    				system-clock-frequency = <8192000>;
    			btsco_codec1: codec {
    				sound-dai = <&btsco_mcasp1>;
    	snd2: sound@2 {
    		compatible = "simple-audio-card-mcasp2";
    		simple-audio-card,name = "DRA7xx-EVM-MCASP2";
    #if 0
    #endif
    			"Line", "Line Out",
    			"Line", "Line In";
    		status = "okay";
    			format = "i2s";
    			bitclock-master = <&btsco_codec2>;
    			frame-master = <&btsco_codec2>;
    			bitclock-inversion;
    			cpu {
    				sound-dai = <&mcasp2>;
    			btsco_codec2: codec {
    				sound-dai = <&btsco_mcasp2>;
    	snd3: sound@3 {
    		compatible = "simple-audio-card-mcasp3";
    		simple-audio-card,name = "DRA7xx-EVM-MCASP3";
    #if 0
    #endif
    			"Line", "Line Out",
    			"Line", "Line In";
    		status = "okay";
    #if 0
    			format = "i2s";
    			bitclock-master = <&sound3_master>;
    			frame-master = <&sound3_master>;
    			bitclock-inversion;
    			sound3_master: cpu {
    				sound-dai = <&mcasp3>;
    			codec {
    				sound-dai = <&btsco_mcasp3>;
    #else
    			format = "i2s";
    			bitclock-master = <&btsco_codec3>;
    			frame-master = <&btsco_codec3>;
    			bitclock-inversion;
    			cpu {
    			btsco_codec3: codec {
    #endif
    	snd4: sound@4 {
    		compatible = "simple-audio-card-mcasp4";
    		simple-audio-card,name = "DRA7xx-EVM-MCASP4";
    #if 0
    #endif
    			"Line", "Line Out",
    			"Line", "Line In";
    		status = "okay";
    #if 0
    			format = "i2s";
    			bitclock-master = <&sound4_master>;
    			frame-master = <&sound4_master>;
    			bitclock-inversion;
    			sound4_master: cpu {
    				sound-dai = <&mcasp4>;
    			codec {
    				sound-dai = <&btsco_mcasp4>;
    #else
    			format = "i2s";
    			bitclock-master = <&btsco_codec4>;
    			frame-master = <&btsco_codec4>;
    			bitclock-inversion;
    			cpu {
    			btsco_codec4: codec {
    #endif
    	snd8: sound@8 {
    		compatible = "simple-audio-card-mcasp8";
    		simple-audio-card,name = "DRA7xx-EVM-MCASP8";
    #if 0
    #endif
    			"Line", "Line Out",
    			"Line", "Line In";
    		status = "okay";
    			format = "i2s";
    			bitclock-master = <&sound8_master>;
    			frame-master = <&sound8_master>;
    			bitclock-inversion;
    			sound8_master: cpu {
    				sound-dai = <&mcasp8>;
    			codec {
    				sound-dai = <&btsco_mcasp8>;
    	hdmi0: connector@1 {
    		status = "disabled";
    		compatible = "hdmi-connector";
    		label = "hdmi";
    		type = "a";
    		port {
    			hdmi_connector_in: endpoint {
    				remote-endpoint = <&tpd12s015_out>;
    	tpd12s015: encoder@1 {
    		compatible = "ti,dra7evm-tpd12s015";
    		pinctrl-names = "i2c", "ddc";
    		pinctrl-0 = <&hdmi_i2c_sel_pin &hdmi_i2c_pins_i2c>;
    		pinctrl-1 = <&hdmi_i2c_sel_pin &hdmi_i2c_pins_ddc>;
    		ddc-i2c-bus = <&i2c2>;
    		mcasp-gpio = <&mcasp8>;
    		gpios = <&pcf_hdmi 4 0>,	/* P4, CT CP HPD */
    			<&pcf_hdmi 5 0>,	/* P5, LS OE */
    			<&gpio7 12 0>;	/* gpio7_12/sp1_cs2, HPD */
    		ports {
    			#address-cells = <1>;
    			#size-cells = <0>;
    			port@0 {
    				reg = <0>;
    				tpd12s015_in: endpoint@0 {
    					remote-endpoint = <&hdmi_out>;
    			port@1 {
    				reg = <1>;
    				tpd12s015_out: endpoint@0 {
    					remote-endpoint = <&hdmi_connector_in>;
    &dra7_iodelay_core {
            mmc1_iodelay_ddr50_conf: mmc1_iodelay_ddr50_conf {
                    pinctrl-single,pins = <
                            0x618 (A_DELAY(572) | G_DELAY(540))     /* CFG_MMC1_CLK_IN */
                            0x624 (A_DELAY(0) | G_DELAY(600))       /* CFG_MMC1_CMD_IN */
                            0x630 (A_DELAY(403) | G_DELAY(120))     /* CFG_MMC1_DAT0_IN */
                            0x63c (A_DELAY(23) | G_DELAY(60))       /* CFG_MMC1_DAT1_IN */
                            0x648 (A_DELAY(25) | G_DELAY(60))       /* CFG_MMC1_DAT2_IN */
                            0x654 (A_DELAY(0) | G_DELAY(0))         /* CFG_MMC1_DAT3_IN */
                            0x620 (A_DELAY(1525) | G_DELAY(0))      /* CFG_MMC1_CLK_IN */
                            0x628 (A_DELAY(0) | G_DELAY(0))         /* CFG_MMC1_CMD_OEN */
                            0x62c (A_DELAY(55) | G_DELAY(0))        /* CFG_MMC1_CMD_OUT */
                            0x634 (A_DELAY(0) | G_DELAY(0))         /* CFG_MMC1_DAT0_OEN */
                            0x638 (A_DELAY(0) | G_DELAY(0))         /* CFG_MMC1_DAT0_OUT */
                            0x640 (A_DELAY(0) | G_DELAY(0))         /* CFG_MMC1_DAT1_OEN */
                            0x644 (A_DELAY(0) | G_DELAY(0))         /* CFG_MMC1_DAT1_OUT */
                            0x64c (A_DELAY(0) | G_DELAY(0))         /* CFG_MMC1_DAT2_OEN */
                            0x650 (A_DELAY(0) | G_DELAY(0))         /* CFG_MMC1_DAT2_OUT */
                            0x658 (A_DELAY(0) | G_DELAY(0))         /* CFG_MMC1_DAT3_OEN */
                            0x65c (A_DELAY(0) | G_DELAY(0))         /* CFG_MMC1_DAT3_OUT */
            mmc2_iodelay_ddr_3_3v_conf: mmc2_iodelay_ddr_3_3v_conf {
                            0x18c (A_DELAY(0) | G_DELAY(120))       /* CFG_GPMC_A19_IN */
                            0x1a4 (A_DELAY(265) | G_DELAY(360))     /* CFG_GPMC_A20_IN */
                            0x1b0 (A_DELAY(0) | G_DELAY(120))       /* CFG_GPMC_A21_IN */
                            0x1bc (A_DELAY(0) | G_DELAY(120))       /* CFG_GPMC_A22_IN */
                            0x1c8 (A_DELAY(287) | G_DELAY(420))     /* CFG_GPMC_A23_IN */
                            0x1d4 (A_DELAY(144) | G_DELAY(240))     /* CFG_GPMC_A24_IN */
                            0x1e0 (A_DELAY(0) | G_DELAY(0))         /* CFG_GPMC_A25_IN */
                            0x1ec (A_DELAY(0) | G_DELAY(120))       /* CFG_GPMC_A26_IN */
                            0x1f8 (A_DELAY(120) | G_DELAY(180))     /* CFG_GPMC_A27_IN */
                            0x360 (A_DELAY(0) | G_DELAY(0))         /* CFG_GPMC_CS1_IN */
                            0x190 (A_DELAY(0) | G_DELAY(0))         /* CFG_GPMC_A19_OEN */
                            0x194 (A_DELAY(174) | G_DELAY(0))       /* CFG_GPMC_A19_OUT */
                            0x1a8 (A_DELAY(0) | G_DELAY(0))         /* CFG_GPMC_A20_OEN */
                            0x1ac (A_DELAY(168) | G_DELAY(0))       /* CFG_GPMC_A20_OUT */
                            0x1b4 (A_DELAY(0) | G_DELAY(0))         /* CFG_GPMC_A21_OEN */
                            0x1b8 (A_DELAY(136) | G_DELAY(0))       /* CFG_GPMC_A21_OUT */
                            0x1c0 (A_DELAY(0) | G_DELAY(0))         /* CFG_GPMC_A22_OEN */
                            0x1c4 (A_DELAY(0) | G_DELAY(0))         /* CFG_GPMC_A22_OUT */
                            0x1d0 (A_DELAY(879) | G_DELAY(0))       /* CFG_GPMC_A23_OUT */
                            0x1d8 (A_DELAY(0) | G_DELAY(0))         /* CFG_GPMC_A24_OEN */
                            0x1dc (A_DELAY(0) | G_DELAY(0))         /* CFG_GPMC_A24_OUT */
                            0x1e4 (A_DELAY(0) | G_DELAY(0))         /* CFG_GPMC_A25_OEN */
                            0x1e8 (A_DELAY(34) | G_DELAY(0))        /* CFG_GPMC_A25_OUT */
                            0x1f0 (A_DELAY(0) | G_DELAY(0))         /* CFG_GPMC_A26_OEN */
                            0x1f4 (A_DELAY(120) | G_DELAY(0))       /* CFG_GPMC_A26_OUT */
                            0x1fc (A_DELAY(0) | G_DELAY(0))         /* CFG_GPMC_A27_OEN */
                            0x200 (A_DELAY(0) | G_DELAY(0))         /* CFG_GPMC_A27_OUT */
                            0x364 (A_DELAY(0) | G_DELAY(0))         /* CFG_GPMC_CS1_OEN */
                            0x368 (A_DELAY(11) | G_DELAY(0))        /* CFG_GPMC_CS1_OUT */
    &dra7_pmx_core {
    	// Audio
    	mcasp1_pins: mcasp1_pins {
    			/* all data PINs have to set output due to clk PINs mux (aclk"r", fs"r") in CB */
    			/* clk slave */
    			0x2a8 (PIN_INPUT           | MUX_MODE0)		/* D14, mcasp1_fsx,  mode 0 */
    			0x2cc (PIN_OUTPUT_PULLDOWN | MUX_MODE0)		/* C12, mcasp1_axr6, mode 0, rx */
    			0x2d0 (PIN_OUTPUT_PULLDOWN | MUX_MODE0)		/* D12, mcasp1_axr7, mode 0, tx */
    			0x2c4 (PIN_OUTPUT_PULLDOWN | MUX_MODE0)		/* E12, mcasp1_axr4, mode 0, rx*/
    			/* clk slave */
    			0x2a4 (PIN_INPUT           | MUX_MODE0)		/* C14, mcasp1_aclkx, mode 0  */
    			0x2c8 (PIN_OUTPUT_PULLDOWN | MUX_MODE0)		/* F13, mcasp1_axr5, mode 0, tx  */
    			0x2c0 (PIN_OUTPUT_PULLDOWN | MUX_MODE0)		/* J11, mcasp1_axr3, mode 0, tx */
    	mcasp2_pins: mcasp2_pins {
    			/* all data PINs have to set input due to clk PINs mux (aclk"r", fs"r") in AB */
    			/* clk slave */
    			0x300 (PIN_INPUT           | MUX_MODE0)		/* A20, mcasp2_fsr, mode 0 */
    			0x304 (PIN_INPUT           | MUX_MODE0)		/* B15, mcasp2_axr0, mode 0, DT_FM1, tx */
    			0x310 (PIN_INPUT           | MUX_MODE0)		/* A16, mcasp2_axr3, mode 0, DT_FM3, rx */
    			0x30c (PIN_INPUT           | MUX_MODE0)		/* C15, mcasp2_axr2, mode 0, DT_FM3, tx */
    			/* clk slave */
    			0x2fc (PIN_INPUT           | MUX_MODE0)		/* E15, mcasp2_aclkr, mode 0 */
    			0x308 (PIN_INPUT           | MUX_MODE0)		/* A15, mcasp2_axr1, mode 0, DT_FM1, rx */
    	mcasp3_pins: mcasp3_pins {
    			0x32c (PIN_OUTPUT_PULLDOWN | MUX_MODE0)		/* B19, mcasp3_axr0, mode 0, tx */
    			/* clk slave */
    			0x324 (PIN_INPUT           | MUX_MODE0)		/* B18, mcasp3_aclkx, mode 0 */
    			0x330 (PIN_INPUT           | MUX_MODE0)		/* C17, mcasp3_axr1, mode 0, rx */
    			/* clk slave */
    			0x328 (PIN_INPUT           | MUX_MODE0)		/* F15, mcasp3_fsx, mode 0 */
    	mcasp4_pins: mcasp4_pins {
    			/* clk slave */
    			0x334 (PIN_INPUT           | MUX_MODE0)		/* C18, mcasp4_aclkx, mode 0,  */
    			/* clk slave */
    			0x338 (PIN_INPUT           | MUX_MODE0)		/* A21, mcasp4_fsx, mode 0,  */
    			0x33C (PIN_INPUT           | MUX_MODE0)		/* G16, mcasp4_axr0, mode 0, rx */
    	mcasp8_pins: mcasp8_pins {
    			/* clk master */
    			0x320 (PIN_OUTPUT_PULLDOWN | MUX_MODE1)		/* A17, mcasp8_fsx, mode 1 */
    			/* clk master */
    			0x31c (PIN_OUTPUT_PULLDOWN | MUX_MODE1)		/* B17, mcasp8_aclkx, mode 1 */
    			0x314 (PIN_INPUT           | MUX_MODE1)		/* D15, mcasp8_axr0, mode 1, rx */
    			0x318 (PIN_OUTPUT_PULLDOWN | MUX_MODE1)		/* B16, mcasp8_axr1, mode 1, tx */
    	// ULPI
    	usb3_pins: pinmux_usb3_pins {
    			0x3a0 (PIN_INPUT_PULLDOWN | MUX_MODE3)	// mmc3_dat7.usb3_ulpi_clk  GPIO1_25 AB5
    			0x39c (PIN_OUTPUT | MUX_MODE3)			// mmc3_dat6.usb3_ulpi_stp  GPIO1_24 AB8
    			0x398 (PIN_INPUT_PULLDOWN | MUX_MODE3)	// mmc3_dat5.usb3_ulpi_dir  GPIO1_23 AD6
    			0x394 (PIN_INPUT_PULLDOWN | MUX_MODE3)	// mmc3_dat4.usb3_ulpi_nxt  GPIO1_22 AC8
    			0x390 (PIN_INPUT_PULLDOWN | MUX_MODE3)	// mmc3_dat3.usb3_ulpi_d0  GPIO7_2 AC3
    			0x38c (PIN_INPUT_PULLDOWN | MUX_MODE3)	// mmc3_dat2.usb3_ulpi_d1  GPIO7_1 AC9
    			0x388 (PIN_INPUT_PULLDOWN | MUX_MODE3)	// mmc3_dat1.usb3_ulpi_d2  GPIO7_0 AC6
    			0x384 (PIN_INPUT_PULLDOWN | MUX_MODE3)	// mmc3_dat0.usb3_ulpi_d3  GPIO6_31 AC7
    			0x380 (PIN_INPUT_PULLDOWN | MUX_MODE3)	// mmc3_cmd.usb3_ulpi_d4  GPIO6_30 AC4
    			0x37c (PIN_INPUT_PULLDOWN | MUX_MODE3)	// mmc3_clk.usb3_ulpi_d5  GPIO6_29 AD4
    			0x378 (PIN_INPUT_PULLDOWN | MUX_MODE3)	// gpio6_11.usb3_ulpi_d6  GPIO6_11 AB4
    			0x374 (PIN_INPUT_PULLDOWN | MUX_MODE3)	// gpio6_10.usb3_ulpi_d7  GPIO6_10 AC5
    	uart1_pins: pinmux_uart1_pins {
    			/* mcasp1 test with Carrier Board */
    			/* clk slave */
    			/* clk slave */
    			/* mcasp2 test with Carrier Board */
    			/* clk slave */
    			/* clk slave */
    			/* mcasp3 test with Carrier Board */
    			/* clk slave */
    			/* clk slave */
    			/* mcasp4 test with Carrier Board */
    			/* clk slave */
    			/* clk slave */
    			/* mcasp8 test with Carrier Board */
    			/* clk master */
    			/* clk master */
    			// i2c_3
    			GPMC_ADVN_ALE (PIN_INPUT | MUX_MODE8)	/* gpmc_advn_ale.i2c3_sda -> 8 */
    			GPMC_CLK      (PIN_INPUT | MUX_MODE8)	/* gpmc_clk.i2c3_scl -> 8 */
    			// i2c_4
    			MMC1_SDCD (PIN_INPUT | MUX_MODE4)  		/* mmc1_sdcd.i2c4_sda -> 4 */
    			MMC1_SDWP (PIN_INPUT | MUX_MODE4)  		/* mmc1_sdwp.i2c4_scl -> 4 */
    			// i2c_5
    			MCASP1_AXR0 (PIN_INPUT | MUX_MODE10)	/* mcasp1_axr0.i2c5_sda -> 10 */
    			MCASP1_AXR1 (PIN_INPUT | MUX_MODE10)	/* mcasp1_axr1.i2c5_scl -> 10 */
    			// spi 1.0, 1.1, 1.3
    			SPI1_SCLK	(PIN_INPUT | MUX_MODE0)	/*	0x3A4	*/
    			SPI1_D1		(PIN_INPUT | MUX_MODE0)	/*	0x3A8	*/
    			SPI1_D0		(PIN_INPUT | MUX_MODE0)	/*	0x3AC	*/
    			SPI1_CS0	(PIN_INPUT | MUX_MODE0)	/*	0x3B0	*/
    			SPI1_CS1	(PIN_INPUT | MUX_MODE0)	/*	0x3B4	*/
    			SPI1_CS3	(PIN_INPUT | MUX_MODE0)	/*	0x3BC	*/
    			// spi 2.0
    			SPI2_SCLK	( PIN_INPUT | MUX_MODE0 )	/*	0x3C0	*/
    			SPI2_D1		( PIN_INPUT | MUX_MODE0 )	/*	0x3C4	*/
    			SPI2_D0		( PIN_INPUT | MUX_MODE0 )	/*	0x3C8	*/
    			SPI2_CS0	( PIN_INPUT | MUX_MODE0 )	/*	0x3CC	*/
    			// spi 3.0
    			VOUT1_CLK		(PIN_INPUT | MUX_MODE8)	// DAB_SPI_CS		GPIO4_19
    			VOUT1_DE		(PIN_INPUT | MUX_MODE8)	// DAB_SPI_MISO	GPIO4_20
    			VOUT1_HSYNC	(PIN_INPUT | MUX_MODE8)	// DAB_SPI_MOSI	GPIO4_22
    			VOUT1_VSYNC	(PIN_INPUT | MUX_MODE8)	// DAB_SPI_SCK		GPIO4_23
    			// BT656 vin4b
    			MDIO_MCLK	(PIN_INPUT | MUX_MODE5)		/*	0x23C	*/	// BT656_CLK1
    			MDIO_D	(PIN_INPUT | MUX_MODE5)		/*	0x240	*/		// BT656_DO
    			UART3_RXD	(PIN_INPUT | MUX_MODE5)	/*	0x248	*/		// BT656_D1
    			UART3_TXD	(PIN_INPUT | MUX_MODE5)	/*	0x24C	*/		// BT656_D2
    			RGMII0_TXC	(PIN_INPUT | MUX_MODE5)	/*	0x250	*/	// BT656_D3
    			RGMII0_TXCTL	(PIN_INPUT | MUX_MODE5)	/*	0x254	*/	// BT656_D4
    			RGMII0_RXC	(PIN_INPUT | MUX_MODE5)	/*	0x268	*/		// BT656_D5
    			RGMII0_RXCTL	(PIN_INPUT | MUX_MODE5)	/*	0x26C	*/	// BT656_D6
    			RGMII0_RXD3	(PIN_INPUT | MUX_MODE5)	/*	0x270	*/		// BT656_D7
    			RGMII0_RXD2	(PIN_INPUT | MUX_MODE14)	/*	0x274	*/
    			VIN2A_DE0	(PIN_INPUT | MUX_MODE14)	/*	0x158	*/
    		//GPMC_AD0	(PIN_INPUT | MUX_MODE14)	/*	0x000	*/
    		//GPMC_AD1	(PIN_INPUT | MUX_MODE14)	/*	0x004	*/
    		//GPMC_AD2	(PIN_INPUT | MUX_MODE14)	/*	0x008	*/
    		//GPMC_AD3	(PIN_INPUT | MUX_MODE14)	/*	0x00C	*/
    		//GPMC_AD4	(PIN_INPUT | MUX_MODE14)	/*	0x010	*/
    		//GPMC_AD5	(PIN_INPUT | MUX_MODE14)	/*	0x014	*/
    		//GPMC_AD6	(PIN_INPUT | MUX_MODE14)	/*	0x018	*/
    		//GPMC_AD7	(PIN_INPUT | MUX_MODE14)	/*	0x01C	*/
    		//GPMC_AD8	(PIN_INPUT | MUX_MODE14)	/*	0x020	*/
    		//GPMC_AD9	(PIN_INPUT | MUX_MODE14)	/*	0x024	*/
    		//GPMC_AD10	(PIN_INPUT | MUX_MODE14)	/*	0x028	*/
    		//GPMC_AD11	(PIN_INPUT | MUX_MODE14)	/*	0x02C	*/
    		//GPMC_AD12	(PIN_INPUT | MUX_MODE14)	/*	0x030	*/
    		//GPMC_AD13	(PIN_INPUT | MUX_MODE14)	/*	0x034	*/
    		//GPMC_AD14	(PIN_INPUT | MUX_MODE14)	/*	0x038	*/
    		//GPMC_AD15	(PIN_INPUT | MUX_MODE14)	/*	0x03C	*/
    		//GPMC_A0	(PIN_INPUT | MUX_MODE14)	/*	0x040	*/
    		//GPMC_A1	(PIN_INPUT | MUX_MODE14)	/*	0x044	*/
    		//GPMC_A2	(PIN_INPUT | MUX_MODE14)	/*	0x048	*/
    		//GPMC_A3	(PIN_INPUT | MUX_MODE14)	/*	0x04C	*/
    		//GPMC_A4	(PIN_INPUT | MUX_MODE14)	/*	0x050	*/
    		//GPMC_A5	(PIN_INPUT | MUX_MODE14)	/*	0x054	*/
    		//GPMC_A6	(PIN_INPUT | MUX_MODE14)	/*	0x058	*/
    		//GPMC_A7	(PIN_INPUT | MUX_MODE14)	/*	0x05C	*/
    		//GPMC_A8	(PIN_INPUT | MUX_MODE14)	/*	0x060	*/
    		//GPMC_A9	(PIN_INPUT | MUX_MODE14)	/*	0x064	*/
    		//GPMC_A10	(PIN_INPUT | MUX_MODE14)	/*	0x068	*/
    		//GPMC_A11	(PIN_INPUT | MUX_MODE14)	/*	0x06C	*/
    		GPMC_A12	(PIN_INPUT | MUX_MODE14)	/*	0x070	*/
    		GPMC_A13	(PIN_INPUT | MUX_MODE14)	/*	0x074	*/
    		GPMC_A14	(PIN_INPUT | MUX_MODE14)	/*	0x078	*/
    		GPMC_A15	(PIN_INPUT | MUX_MODE14)	/*	0x07C	*/
    		GPMC_A16	(PIN_INPUT | MUX_MODE14)	/*	0x080	*/
    		GPMC_A17	(PIN_INPUT | MUX_MODE14)	/*	0x084	*/
    		GPMC_A18	(PIN_INPUT | MUX_MODE14)	/*	0x088	*/
    		//GPMC_A19	(PIN_INPUT | MUX_MODE14)	/*	0x08C	*/
    		//GPMC_A20	(PIN_INPUT | MUX_MODE14)	/*	0x090	*/
    		//GPMC_A21	(PIN_INPUT | MUX_MODE14)	/*	0x094	*/
    		//GPMC_A22	(PIN_INPUT | MUX_MODE14)	/*	0x098	*/
    		//GPMC_A23	(PIN_INPUT | MUX_MODE14)	/*	0x09C	*/
    		//GPMC_A24	(PIN_INPUT | MUX_MODE14)	/*	0x0A0	*/
    		//GPMC_A25	(PIN_INPUT | MUX_MODE14)	/*	0x0A4	*/
    		//GPMC_A26	(PIN_INPUT | MUX_MODE14)	/*	0x0A8	*/
    		//GPMC_A27	(PIN_INPUT | MUX_MODE14)	/*	0x0AC	*/
    		//GPMC_CS1	(PIN_INPUT | MUX_MODE14)	/*	0x0B0	*/
    		GPMC_CS0	(PIN_INPUT | MUX_MODE14)	/*	0x0B4	*/
    		GPMC_CS2	(PIN_INPUT | MUX_MODE14)	/*	0x0B8	*/
    		//GPMC_CS3	(PIN_INPUT | MUX_MODE14)	/*	0x0BC	*/
    		//GPMC_CLK	(PIN_INPUT | MUX_MODE14)	/*	0x0C0	*/
    		//GPMC_ADVN_ALE	(PIN_INPUT | MUX_MODE14)	/*	0x0C4	*/
    		GPMC_OEN_REN	(PIN_INPUT | MUX_MODE14)	/*	0x0C8	*/
    		GPMC_WEN	(PIN_INPUT | MUX_MODE14)	/*	0x0CC	*/
    		GPMC_BEN0	(PIN_INPUT | MUX_MODE14)	/*	0x0D0	*/
    		GPMC_BEN1	(PIN_INPUT | MUX_MODE14)	/*	0x0D4	*/
    		GPMC_WAIT0	(PIN_INPUT | MUX_MODE14)	/*	0x0D8	*/
    		VIN1A_CLK0	(PIN_INPUT | MUX_MODE14)	/*	0x0DC	*/
    		VIN1B_CLK1	(PIN_INPUT | MUX_MODE14)	/*	0x0E0	*/
    		VIN1A_DE0	(PIN_INPUT | MUX_MODE14)	/*	0x0E4	*/
    		VIN1A_FLD0	(PIN_INPUT | MUX_MODE14)	/*	0x0E8	*/
    		VIN1A_HSYNC0	(PIN_INPUT | MUX_MODE14)	/*	0x0EC	*/
    		VIN1A_VSYNC0	(PIN_INPUT | MUX_MODE14)	/*	0x0F0	*/
    		VIN1A_D0	(PIN_INPUT | MUX_MODE14)	/*	0x0F4	*/
    		VIN1A_D1	(PIN_INPUT | MUX_MODE14)	/*	0x0F8	*/
    		VIN1A_D2	(PIN_INPUT | MUX_MODE14)	/*	0x0FC	*/
    		VIN1A_D3	(PIN_INPUT | MUX_MODE14)	/*	0x100	*/
    		VIN1A_D4	(PIN_INPUT | MUX_MODE14)	/*	0x104	*/
    		VIN1A_D5	(PIN_INPUT | MUX_MODE14)	/*	0x108	*/
    		VIN1A_D6	(PIN_INPUT | MUX_MODE14)	/*	0x10C	*/
    		VIN1A_D7	(PIN_INPUT | MUX_MODE14)	/*	0x110	*/
    		VIN1A_D8	(PIN_INPUT | MUX_MODE14)	/*	0x114	*/
    		VIN1A_D9	(PIN_INPUT | MUX_MODE14)	/*	0x118	*/
    		VIN1A_D10	(PIN_INPUT | MUX_MODE14)	/*	0x11C	*/
    		VIN1A_D11	(PIN_INPUT | MUX_MODE14)	/*	0x120	*/
    		VIN1A_D12	(PIN_INPUT | MUX_MODE14)	/*	0x124	*/
    		VIN1A_D13	(PIN_INPUT | MUX_MODE14)	/*	0x128	*/
    		VIN1A_D14	(PIN_INPUT | MUX_MODE14)	/*	0x12C	*/
    		VIN1A_D15	(PIN_INPUT | MUX_MODE14)	/*	0x130	*/
    		VIN1A_D16	(PIN_INPUT | MUX_MODE14)	/*	0x134	*/
    		VIN1A_D17	(PIN_INPUT | MUX_MODE14)	/*	0x138	*/
    		VIN1A_D18	(PIN_INPUT | MUX_MODE14)	/*	0x13C	*/
    		VIN1A_D19	(PIN_INPUT | MUX_MODE14)	/*	0x140	*/
    		VIN1A_D20	(PIN_INPUT | MUX_MODE14)	/*	0x144	*/
    		VIN1A_D21	(PIN_INPUT | MUX_MODE14)	/*	0x148	*/
    		VIN1A_D22	(PIN_INPUT | MUX_MODE14)	/*	0x14C	*/
    		VIN1A_D23	(PIN_INPUT | MUX_MODE14)	/*	0x150	*/
    		VIN2A_CLK0	(PIN_INPUT | MUX_MODE14)	/*	0x154	*/
    //		VIN2A_DE0	(PIN_INPUT | MUX_MODE14)	/*	0x158	*/
    		VIN2A_FLD0	(PIN_INPUT | MUX_MODE14)	/*	0x15C	*/
    		VIN2A_HSYNC0	(PIN_INPUT | MUX_MODE14)	/*	0x160	*/
    		VIN2A_VSYNC0	(PIN_INPUT | MUX_MODE14)	/*	0x164	*/
    		VIN2A_D0	(PIN_INPUT | MUX_MODE14)	/*	0x168	*/
    		VIN2A_D1	(PIN_INPUT | MUX_MODE14)	/*	0x16C	*/
    		//VIN2A_D2	(PIN_INPUT | MUX_MODE14)	/*	0x170	*/
    		//VIN2A_D3	(PIN_INPUT | MUX_MODE14)	/*	0x174	*/
    		VIN2A_D4	(PIN_INPUT | MUX_MODE14)	/*	0x178	*/
    		VIN2A_D5	(PIN_INPUT | MUX_MODE14)	/*	0x17C	*/
    		VIN2A_D6	(PIN_INPUT | MUX_MODE14)	/*	0x180	*/
    		VIN2A_D7	(PIN_INPUT | MUX_MODE14)	/*	0x184	*/
    		//VIN2A_D8	(PIN_INPUT | MUX_MODE14)	/*	0x188	*/
    		//VIN2A_D9	(PIN_INPUT | MUX_MODE14)	/*	0x18C	*/
    		VIN2A_D10	(PIN_INPUT | MUX_MODE14)	/*	0x190	*/
    		VIN2A_D11	(PIN_INPUT | MUX_MODE14)	/*	0x194	*/
    		VIN2A_D12	(PIN_INPUT | MUX_MODE14)	/*	0x198	*/
    		VIN2A_D13	(PIN_INPUT | MUX_MODE14)	/*	0x19C	*/
    		VIN2A_D14	(PIN_INPUT | MUX_MODE14)	/*	0x1A0	*/
    		VIN2A_D15	(PIN_INPUT | MUX_MODE14)	/*	0x1A4	*/
    		VIN2A_D16	(PIN_INPUT | MUX_MODE14)	/*	0x1A8	*/
    		VIN2A_D17	(PIN_INPUT | MUX_MODE14)	/*	0x1AC	*/
    		VIN2A_D18	(PIN_INPUT | MUX_MODE14)	/*	0x1B0	*/
    		VIN2A_D19	(PIN_INPUT | MUX_MODE14)	/*	0x1B4	*/
    		VIN2A_D20	(PIN_INPUT | MUX_MODE14)	/*	0x1B8	*/
    		VIN2A_D21	(PIN_INPUT | MUX_MODE14)	/*	0x1BC	*/
    		VIN2A_D22	(PIN_INPUT | MUX_MODE14)	/*	0x1C0	*/
    		VIN2A_D23	(PIN_INPUT | MUX_MODE14)	/*	0x1C4	*/
    		//VOUT1_CLK	(PIN_INPUT | MUX_MODE14)	/*	0x1C8	*/
    		//VOUT1_DE	(PIN_INPUT | MUX_MODE14)	/*	0x1CC	*/
    		VOUT1_FLD	(PIN_INPUT | MUX_MODE14)	/*	0x1D0	*/
    		//VOUT1_HSYNC	(PIN_INPUT | MUX_MODE14)	/*	0x1D4	*/
    		//VOUT1_VSYNC	(PIN_INPUT | MUX_MODE14)	/*	0x1D8	*/
    		//VOUT1_D0	(PIN_INPUT | MUX_MODE14)	/*	0x1DC	*/	// uart5
    		//VOUT1_D1	(PIN_INPUT | MUX_MODE14)	/*	0x1E0	*/	// uart5
    		VOUT1_D2	(PIN_INPUT | MUX_MODE14)	/*	0x1E4	*/
    		VOUT1_D3	(PIN_INPUT | MUX_MODE14)	/*	0x1E8	*/
    		VOUT1_D4	(PIN_INPUT | MUX_MODE14)	/*	0x1EC	*/
    		VOUT1_D5	(PIN_INPUT | MUX_MODE14)	/*	0x1F0	*/
    		VOUT1_D6	(PIN_INPUT | MUX_MODE14)	/*	0x1F4	*/
    		VOUT1_D7	(PIN_INPUT | MUX_MODE14)	/*	0x1F8	*/
    		//VOUT1_D8	(PIN_INPUT | MUX_MODE14)	/*	0x1FC	*/	// uart6
    		//VOUT1_D9	(PIN_INPUT | MUX_MODE14)	/*	0x200	*/	// uart6
    		VOUT1_D10	(PIN_INPUT | MUX_MODE14)	/*	0x204	*/
    		VOUT1_D11	(PIN_INPUT | MUX_MODE14)	/*	0x208	*/
    		VOUT1_D12	(PIN_INPUT | MUX_MODE14)	/*	0x20C	*/
    		VOUT1_D13	(PIN_INPUT | MUX_MODE14)	/*	0x210	*/
    		VOUT1_D14	(PIN_INPUT | MUX_MODE14)	/*	0x214	*/
    		VOUT1_D15	(PIN_INPUT | MUX_MODE14)	/*	0x218	*/
    		VOUT1_D16	(PIN_INPUT | MUX_MODE14)	/*	0x21C	*/
    		VOUT1_D17	(PIN_INPUT | MUX_MODE14)	/*	0x220	*/
    		VOUT1_D18	(PIN_INPUT | MUX_MODE14)	/*	0x224	*/
    		VOUT1_D19	(PIN_INPUT | MUX_MODE14)	/*	0x228	*/
    		VOUT1_D20	(PIN_INPUT | MUX_MODE14)	/*	0x22C	*/
    		VOUT1_D21	(PIN_INPUT | MUX_MODE14)	/*	0x230	*/
    		VOUT1_D22	(PIN_INPUT | MUX_MODE14)	/*	0x234	*/
    		VOUT1_D23	(PIN_INPUT | MUX_MODE14)	/*	0x238	*/
    //		MDIO_MCLK	(PIN_INPUT | MUX_MODE14)	/*	0x23C	*/
    //		MDIO_D	(PIN_INPUT | MUX_MODE14)	/*	0x240	*/
    		RMII_MHZ_50_CLK	(PIN_INPUT | MUX_MODE14)	/*	0x244	*/
    //		UART3_RXD	(PIN_INPUT | MUX_MODE14)	/*	0x248	*/
    //		UART3_TXD	(PIN_INPUT | MUX_MODE14)	/*	0x24C	*/
    //		RGMII0_TXC	(PIN_INPUT | MUX_MODE14)	/*	0x250	*/
    //		RGMII0_TXCTL	(PIN_INPUT | MUX_MODE14)	/*	0x254	*/
    		RGMII0_TXD3	(PIN_INPUT | MUX_MODE14)	/*	0x258	*/
    		RGMII0_TXD2	(PIN_INPUT | MUX_MODE14)	/*	0x25C	*/
    		RGMII0_TXD1	(PIN_INPUT | MUX_MODE14)	/*	0x260	*/
    		RGMII0_TXD0	(PIN_INPUT | MUX_MODE14)	/*	0x264	*/
    //		RGMII0_RXC	(PIN_INPUT | MUX_MODE14)	/*	0x268	*/
    //		RGMII0_RXCTL	(PIN_INPUT | MUX_MODE14)	/*	0x26C	*/
    //		RGMII0_RXD3	(PIN_INPUT | MUX_MODE14)	/*	0x270	*/
    //		RGMII0_RXD2	(PIN_INPUT | MUX_MODE14)	/*	0x274	*/
    		RGMII0_RXD1	(PIN_INPUT | MUX_MODE14)	/*	0x278	*/
    		RGMII0_RXD0	(PIN_INPUT | MUX_MODE14)	/*	0x27C	*/
    		USB1_DRVVBUS	(PIN_INPUT | MUX_MODE14)	/*	0x280	*/
    		USB2_DRVVBUS	(PIN_INPUT | MUX_MODE14)	/*	0x284	*/
    		GPIO6_14	(PIN_INPUT | MUX_MODE14)	/*	0x288	*/
    		GPIO6_15	(PIN_INPUT | MUX_MODE14)	/*	0x28C	*/
    		GPIO6_16	(PIN_INPUT | MUX_MODE14)	/*	0x290	*/
    		XREF_CLK0	(PIN_INPUT | MUX_MODE14)	/*	0x294	*/
    		XREF_CLK1	(PIN_INPUT | MUX_MODE14)	/*	0x298	*/
    		XREF_CLK2	(PIN_INPUT | MUX_MODE14)	/*	0x29C	*/
    		XREF_CLK3	(PIN_INPUT | MUX_MODE14)	/*	0x2A0	*/
    //		MCASP1_ACLKX	(PIN_INPUT | MUX_MODE14)	/*	0x2A4	*/
    //		MCASP1_FSX	(PIN_INPUT | MUX_MODE14)	/*	0x2A8	*/
    		MCASP1_ACLKR	(PIN_INPUT | MUX_MODE14)	/*	0x2AC	*/
    		MCASP1_FSR	(PIN_INPUT | MUX_MODE14)	/*	0x2B0	*/
    		//MCASP1_AXR0	(PIN_INPUT | MUX_MODE14)	/*	0x2B4	*/
    		//MCASP1_AXR1	(PIN_INPUT | MUX_MODE14)	/*	0x2B8	*/
    		MCASP1_AXR2	(PIN_INPUT | MUX_MODE14)	/*	0x2BC	*/
    //		MCASP1_AXR3	(PIN_INPUT | MUX_MODE14)	/*	0x2C0	*/
    //		MCASP1_AXR4	(PIN_INPUT | MUX_MODE14)	/*	0x2C4	*/
    //		MCASP1_AXR5	(PIN_INPUT | MUX_MODE14)	/*	0x2C8	*/
    //		MCASP1_AXR6	(PIN_INPUT | MUX_MODE14)	/*	0x2CC	*/
    //		MCASP1_AXR7	(PIN_INPUT | MUX_MODE14)	/*	0x2D0	*/
    		MCASP1_AXR8	(PIN_INPUT | MUX_MODE14)	/*	0x2D4	*/
    		MCASP1_AXR9	(PIN_INPUT | MUX_MODE14)	/*	0x2D8	*/
    		MCASP1_AXR10	(PIN_INPUT | MUX_MODE14)	/*	0x2DC	*/
    		MCASP1_AXR11	(PIN_INPUT | MUX_MODE14)	/*	0x2E0	*/
    		MCASP1_AXR12	(PIN_INPUT | MUX_MODE14)	/*	0x2E4	*/
    		MCASP1_AXR13	(PIN_INPUT | MUX_MODE14)	/*	0x2E8	*/
    		MCASP1_AXR14	(PIN_INPUT | MUX_MODE14)	/*	0x2EC	*/
    		MCASP1_AXR15	(PIN_INPUT | MUX_MODE14)	/*	0x2F0	*/
    //		MCASP2_AXR2	(PIN_INPUT | MUX_MODE14)	/*	0x30C	*/
    //		MCASP2_AXR3	(PIN_INPUT | MUX_MODE14)	/*	0x310	*/
    //		MCASP2_AXR4	(PIN_INPUT | MUX_MODE14)	/*	0x314	*/
    //		MCASP2_AXR5	(PIN_INPUT | MUX_MODE14)	/*	0x318	*/
    //		MCASP2_AXR6	(PIN_INPUT | MUX_MODE14)	/*	0x31C	*/
    //		MCASP2_AXR7	(PIN_INPUT | MUX_MODE14)	/*	0x320	*/
    //		MCASP3_ACLKX	(PIN_INPUT | MUX_MODE14)	/*	0x324	*/
    //		MCASP3_FSX	(PIN_INPUT | MUX_MODE14)	/*	0x328	*/
    		//MMC1_CLK	(PIN_INPUT | MUX_MODE14)	/*	0x354	*/
    		//MMC1_CMD	(PIN_INPUT | MUX_MODE14)	/*	0x358	*/
    		//MMC1_DAT0	(PIN_INPUT | MUX_MODE14)	/*	0x35C	*/
    		//MMC1_DAT1	(PIN_INPUT | MUX_MODE14)	/*	0x360	*/
    		//MMC1_DAT2	(PIN_INPUT | MUX_MODE14)	/*	0x364	*/
    		//MMC1_DAT3	(PIN_INPUT | MUX_MODE14)	/*	0x368	*/
    		//MMC1_SDCD	(PIN_INPUT | MUX_MODE14)	/*	0x36C	*/
    		//MMC1_SDWP	(PIN_INPUT | MUX_MODE14)	/*	0x370	*/
    		//ulpi
    		//GPIO6_10	(PIN_INPUT | MUX_MODE14)	/*	0x374	*/
    		//GPIO6_11	(PIN_INPUT | MUX_MODE14)	/*	0x378	*/
    		//MMC3_CLK	(PIN_INPUT | MUX_MODE14)	/*	0x37C	*/
    		//MMC3_CMD	(PIN_INPUT | MUX_MODE14)	/*	0x380	*/
    		//MMC3_DAT0	(PIN_INPUT | MUX_MODE14)	/*	0x384	*/
    		//MMC3_DAT1	(PIN_INPUT | MUX_MODE14)	/*	0x388	*/
    		//MMC3_DAT2	(PIN_INPUT | MUX_MODE14)	/*	0x38C	*/
    		//MMC3_DAT3	(PIN_INPUT | MUX_MODE14)	/*	0x390	*/
    		//MMC3_DAT4	(PIN_INPUT | MUX_MODE14)	/*	0x394	*/
    		//MMC3_DAT5	(PIN_INPUT | MUX_MODE14)	/*	0x398	*/
    		//MMC3_DAT6	(PIN_INPUT | MUX_MODE14)	/*	0x39C	*/
    		//MMC3_DAT7	(PIN_INPUT | MUX_MODE14)	/*	0x3A0	*/
    		//SPI1_SCLK	(PIN_INPUT | MUX_MODE14)	/*	0x3A4	*/
    		//SPI1_D1	(PIN_INPUT | MUX_MODE14)	/*	0x3A8	*/
    		//SPI1_D0	(PIN_INPUT | MUX_MODE14)	/*	0x3AC	*/
    		//SPI1_CS0	(PIN_INPUT | MUX_MODE14)	/*	0x3B0	*/
    		//SPI1_CS1	(PIN_INPUT | MUX_MODE14)	/*	0x3B4	*/
    		SPI1_CS2	(PIN_INPUT | MUX_MODE14)	/*	0x3B8	*/
    		//SPI1_CS3	(PIN_INPUT | MUX_MODE14)	/*	0x3BC	*/
    		//SPI2_SCLK	(PIN_INPUT | MUX_MODE14)	/*	0x3C0	*/
    		//SPI2_D1	(PIN_INPUT | MUX_MODE14)	/*	0x3C4	*/
    		//SPI2_D0	(PIN_INPUT | MUX_MODE14)	/*	0x3C8	*/
    		//SPI2_CS0	(PIN_INPUT | MUX_MODE14)	/*	0x3CC	*/
    		DCAN1_TX	(PIN_INPUT | MUX_MODE14)	/*	0x3D0	*/
    		DCAN1_RX	(PIN_INPUT | MUX_MODE14)	/*	0x3D4	*/
    		DCAN2_TX	(PIN_INPUT | MUX_MODE14)	/*	0x3D8	*/
    		DCAN2_RX	(PIN_INPUT | MUX_MODE14)	/*	0x3DC	*/
    		UART1_RXD	(PIN_INPUT | MUX_MODE14)	/*	0x3E0	*/
    		UART1_TXD	(PIN_INPUT | MUX_MODE14)	/*	0x3E4	*/
    		//UART1_CTSN	(PIN_INPUT | MUX_MODE14)	/*	0x3E8	*/
    		//UART1_RTSN	(PIN_INPUT | MUX_MODE14)	/*	0x3EC	*/
    		//UART2_RXD	(PIN_INPUT | MUX_MODE14)	/*	0x3F0	*/
    		//UART2_TXD	(PIN_INPUT | MUX_MODE14)	/*	0x3F4	*/
    		//UART2_CTSN	(PIN_INPUT | MUX_MODE14)	/*	0x3F8	*/
    		//UART2_RTSN	(PIN_INPUT | MUX_MODE14)	/*	0x3FC	*/
    		WAKEUP0	(PIN_INPUT | MUX_MODE14)	/*	0x418	*/
    		WAKEUP1	(PIN_INPUT | MUX_MODE14)	/*	0x41C	*/
    		WAKEUP2	(PIN_INPUT | MUX_MODE14)	/*	0x420	*/
    		WAKEUP3	(PIN_INPUT | MUX_MODE14)	/*	0x424	*/
    		TDI	(PIN_INPUT | MUX_MODE14)	/*	0x434	*/
    		TDO	(PIN_INPUT | MUX_MODE14)	/*	0x438	*/
    		TCLK	(PIN_INPUT | MUX_MODE14)	/*	0x43C	*/
    		TRSTN	(PIN_INPUT | MUX_MODE14)	/*	0x440	*/
    		RTCK	(PIN_INPUT | MUX_MODE14)	/*	0x444	*/
    		EMU2	(PIN_INPUT | MUX_MODE14)	/*	0x450	*/
    		EMU3	(PIN_INPUT | MUX_MODE14)	/*	0x454	*/
    	uart3_pins_default: pinmux_uart3_pins {
    			0x34c (PIN_INPUT | MUX_MODE4) /* mcasp5_axr0.uart3_rxd */
    			0x350 (PIN_OUTPUT | MUX_MODE4) /* mcasp5_axr1.uart3_txd */
    	uart5_pins_default: pinmux_uart5_pins {
    			VOUT1_D0 (WAKEUP_EN | PIN_INPUT | MUX_MODE2)	/* vout1_d0.uart5_rxd */
    			VOUT1_D1 (PIN_OUTPUT | MUX_MODE2)						/* vout1_d1.uart5_txd */
    	uart6_pins_default: pinmux_uart6_pins {
    			VOUT1_D8 (PIN_INPUT | MUX_MODE2)  /* vout1_d8.uart6_rxd */
    			VOUT1_D9 (PIN_OUTPUT | MUX_MODE2) /* vout1_d9.uart6_txd */
    	uart9_pins_default: pinmux_uart9_pins {
    			MCASP5_ACLKX (PIN_INPUT | MUX_MODE8)  /* mcasp5_aclkx.uart9_rxd */
    			MCASP5_FSX (PIN_OUTPUT | MUX_MODE3) /* mcasp5_fsx.uart9_txd */
    	uart10_pins_default: pinmux_uart10_pins {
    			VIN2A_D2 (PIN_INPUT | MUX_MODE8)  /* vin2a_d2.uart10_rxd */
    			VIN2A_D3 (PIN_OUTPUT | MUX_MODE8) /* vin2a_d3.uart10_txd */
    			//VIN2A_D4 (PIN_INPUT | MUX_MODE8)  /* vin2a_d4.uart10_ctsn */
    			//VIN2A_D5 (PIN_OUTPUT | MUX_MODE8) /* vin2a_d5.uart10_rtsn */
    	dcan1_pins_default: dcan1_pins_default {
    			0x3d0   (PIN_OUTPUT_PULLUP | MUX_MODE0) /* dcan1_tx */
    			0x418   (PULL_UP | MUX_MODE1) /* wakeup0.dcan1_rx */
    	dcan1_pins_sleep: dcan1_pins_sleep {
    			0x3d0   (MUX_MODE15 | PULL_UP)	/* dcan1_tx.off */
    			0x418   (MUX_MODE15 | PULL_UP)	/* wakeup0.off */
    	hdmi_i2c_sel_pin: pinmux_hdmi_i2c_sel_pin {
    			/* this pin is used as a GPIO via mcasp */
    			0x2fc   (PIN_OUTPUT | MUX_MODE1) /* mcasp8_axr2 */
    	hdmi_i2c_pins_i2c: pinmux_hdmi_i2c_pins_default {
    			0x408   (PIN_INPUT | MUX_MODE0) /* i2c2_sda.i2c2_sda */
    			0x40c   (PIN_INPUT | MUX_MODE0) /* i2c2_scl.i2c2_scl */
    	hdmi_i2c_pins_ddc: pinmux_hdmi_i2c_pins_ddc {
    			0x408   (PIN_INPUT | MUX_MODE1) /* i2c2_sda.hdmi1_ddc_scl */
    			0x40c   (PIN_INPUT | MUX_MODE1) /* i2c2_scl.hdmi1_ddc_sda */
    	mmc1_pins_default: pinmux_mmc1_default_pins {
    			0x354 (PIN_INPUT_PULLUP | MUX_MODE0)	/* mmc1_clk.clk */
    			0x358 (PIN_INPUT_PULLUP | MUX_MODE0)	/* mmc1_cmd.cmd */
    			0x35c (PIN_INPUT_PULLUP | MUX_MODE0)	/* mmc1_dat0.dat0 */
    			0x360 (PIN_INPUT_PULLUP | MUX_MODE0)	/* mmc1_dat1.dat1 */
    			0x364 (PIN_INPUT_PULLUP | MUX_MODE0)	/* mmc1_dat2.dat2 */
    			0x368 (PIN_INPUT_PULLUP | MUX_MODE0)	/* mmc1_dat3.dat3 */
    	mmc1_pins_sdr12: pinmux_mmc1_sdr12_pins {
    	mmc1_pins_hs: pinmux_mmc1_hs_pins {
    			0x354 (PIN_INPUT_PULLUP | MUX_VIRTUAL_MODE11 | MUX_MODE0)	/* mmc1_clk.clk */
    			0x358 (PIN_INPUT_PULLUP | MUX_VIRTUAL_MODE11 | MUX_MODE0)	/* mmc1_cmd.cmd */
    			0x35c (PIN_INPUT_PULLUP | MUX_VIRTUAL_MODE11 | MUX_MODE0)	/* mmc1_dat0.dat0 */
    			0x360 (PIN_INPUT_PULLUP | MUX_VIRTUAL_MODE11 | MUX_MODE0)	/* mmc1_dat1.dat1 */
    			0x364 (PIN_INPUT_PULLUP | MUX_VIRTUAL_MODE11 | MUX_MODE0)	/* mmc1_dat2.dat2 */
    			0x368 (PIN_INPUT_PULLUP | MUX_VIRTUAL_MODE11 | MUX_MODE0)	/* mmc1_dat3.dat3 */
    	mmc1_pins_sdr25: pinmux_mmc1_sdr25_pins {
    	mmc1_pins_sdr50: pinmux_mmc1_sdr50_pins {
    			0x354 (PIN_INPUT_PULLUP | MUX_VIRTUAL_MODE10 | MUX_MODE0)	/* mmc1_clk.clk */
    			0x358 (PIN_INPUT_PULLUP | MUX_VIRTUAL_MODE10 | MUX_MODE0)	/* mmc1_cmd.cmd */
    			0x35c (PIN_INPUT_PULLUP | MUX_VIRTUAL_MODE10 | MUX_MODE0)	/* mmc1_dat0.dat0 */
    			0x360 (PIN_INPUT_PULLUP | MUX_VIRTUAL_MODE10 | MUX_MODE0)	/* mmc1_dat1.dat1 */
    			0x364 (PIN_INPUT_PULLUP | MUX_VIRTUAL_MODE10 | MUX_MODE0)	/* mmc1_dat2.dat2 */
    			0x368 (PIN_INPUT_PULLUP | MUX_VIRTUAL_MODE10 | MUX_MODE0)	/* mmc1_dat3.dat3 */
    	mmc1_pins_ddr50: pinmux_mmc1_ddr50_pins {
    			0x354 (PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE0)	/* mmc1_clk.clk */
    			0x358 (PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE0)	/* mmc1_cmd.cmd */
    			0x35c (PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE0)	/* mmc1_dat0.dat0 */
    			0x360 (PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE0)	/* mmc1_dat1.dat1 */
    			0x364 (PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE0)	/* mmc1_dat2.dat2 */
    			0x368 (PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE0)	/* mmc1_dat3.dat3 */
    	mmc1_pins_sdr104: pinmux_mmc1_sdr104_pins {
    	mmc2_pins_default: mmc2_pins_default {
    			0x9c (PIN_INPUT_PULLUP | MUX_MODE1)	/* gpmc_a23.mmc2_clk */
    			0xb0 (PIN_INPUT_PULLUP | MUX_MODE1)	/* gpmc_cs1.mmc2_cmd */
    			0xa0 (PIN_INPUT_PULLUP | MUX_MODE1)	/* gpmc_a24.mmc2_dat0 */
    			0xa4 (PIN_INPUT_PULLUP | MUX_MODE1)	/* gpmc_a25.mmc2_dat1 */
    			0xa8 (PIN_INPUT_PULLUP | MUX_MODE1)	/* gpmc_a26.mmc2_dat2 */
    			0xac (PIN_INPUT_PULLUP | MUX_MODE1)	/* gpmc_a27.mmc2_dat3 */
    			0x8c (PIN_INPUT_PULLUP | MUX_MODE1)	/* gpmc_a19.mmc2_dat4 */
    			0x90 (PIN_INPUT_PULLUP | MUX_MODE1)	/* gpmc_a20.mmc2_dat5 */
    			0x94 (PIN_INPUT_PULLUP | MUX_MODE1)	/* gpmc_a21.mmc2_dat6 */
    			0x98 (PIN_INPUT_PULLUP | MUX_MODE1)	/* gpmc_a22.mmc2_dat7 */
    	mmc2_pins_hs: mmc2_pins_hs {
            mmc2_pins_ddr_3_3v: pinmux_mmc2_ddr_3_3v_pins {
                            0x9c (PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE1) /* gpmc_a23.mmc2_clk */
                            0xb0 (PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE1) /* gpmc_cs1.mmc2_cmd */
                            0xa0 (PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE1) /* gpmc_a24.mmc2_dat0 */
                            0xa4 (PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE1) /* gpmc_a25.mmc2_dat1 */
                            0xa8 (PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE1) /* gpmc_a26.mmc2_dat2 */
                            0xac (PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE1) /* gpmc_a27.mmc2_dat3 */
                            0x8c (PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE1) /* gpmc_a19.mmc2_dat4 */
                            0x90 (PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE1) /* gpmc_a20.mmc2_dat5 */
                            0x94 (PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE1) /* gpmc_a21.mmc2_dat6 */
                            0x98 (PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE1) /* gpmc_a22.mmc2_dat7 */
    	mmc2_pins_ddr_1_8v: pinmux_mmc2_ddr_1_8v_pins {
    	mmc2_pins_hs200_1_8v: mmc2_pins_hs200_1_8v {
    	mmc4_pins_default: mmc4_pins_default {
    			0x3e8 (PIN_INPUT_PULLUP | MUX_MODE3) /* uart1_ctsn.mmc4_clk */
    			0x3ec (PIN_INPUT_PULLUP | MUX_MODE3) /* uart1_rtsn.mmc4_cmd */
    			0x3f0 (PIN_INPUT_PULLUP | MUX_MODE3) /* uart2_rxd.mmc4_dat0 */
    			0x3f4 (PIN_INPUT_PULLUP | MUX_MODE3) /* uart2_txd.mmc4_dat1 */
    			0x3f8 (PIN_INPUT_PULLUP | MUX_MODE3) /* uart2_ctsn.mmc4_dat2 */
    			0x3fC (PIN_INPUT_PULLUP | MUX_MODE3) /* uart2_rtsn.mmc4_dat3 */
    	mmc4_pins_hs: mmc4_pins_hs {
    			0x3e8 (PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE3) /* uart1_ctsn.mmc4_clk */
    			0x3ec (PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE3) /* uart1_rtsn.mmc4_cmd */
    			0x3f0 (PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE3) /* uart2_rxd.mmc4_dat0 */
    			0x3f4 (PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE3) /* uart2_txd.mmc4_dat1 */
    			0x3f8 (PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE3) /* uart2_ctsn.mmc4_dat2 */
    			0x3fC (PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE3) /* uart2_rtsn.mmc4_dat3 */
    	mmc4_pins_sdr12: mmc4_pins_sdr12 {
    			0x3eC (PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE3) /* uart1_rtsn.mmc4_cmd */
    			0x3fc (PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE3) /* uart2_rtsn.mmc4_dat3 */
    	mmc4_pins_sdr25: mmc4_pins_sdr25 {
    	mmc1_iodelay_ddr50_rev11_conf: mmc1_iodelay_ddr50_rev11_conf {
    			0x620 (A_DELAY(1525) | G_DELAY(0))	/* CFG_MMC1_CLK_OUT */
    	mmc1_iodelay_ddr50_rev20_conf: mmc1_iodelay_ddr50_rev20_conf {
    			0x618 (A_DELAY(0) | G_DELAY(0))		/* CFG_MMC1_CLK_IN */
    			0x620 (A_DELAY(1271) | G_DELAY(0))	/* CFG_MMC1_CLK_OUT */
    			0x624 (A_DELAY(229) | G_DELAY(0))	/* CFG_MMC1_CMD_IN */
    			0x62C (A_DELAY(0) | G_DELAY(0))		/* CFG_MMC1_CMD_OUT */
    			0x630 (A_DELAY(850) | G_DELAY(0))	/* CFG_MMC1_DAT0_IN */
    			0x638 (A_DELAY(20) | G_DELAY(0))	/* CFG_MMC1_DAT0_OUT */
    			0x63C (A_DELAY(468) | G_DELAY(0))	/* CFG_MMC1_DAT1_IN */
    			0x648 (A_DELAY(466) | G_DELAY(0))	/* CFG_MMC1_DAT2_IN */
    			0x64C (A_DELAY(0) | G_DELAY(0))		/* CFG_MMC1_DAT2_OEN */
    			0x654 (A_DELAY(399) | G_DELAY(0))	/* CFG_MMC1_DAT3_IN */
    			0x65C (A_DELAY(0) | G_DELAY(0))		/* CFG_MMC1_DAT3_OUT */
    	mmc1_iodelay_sdr104_rev11_conf: mmc1_iodelay_sdr104_rev11_conf {
    			0x620 (A_DELAY(1063) | G_DELAY(17))	/* CFG_MMC1_CLK_OUT */
    			0x62c (A_DELAY(23) | G_DELAY(0))	/* CFG_MMC1_CMD_OUT */
    			0x644 (A_DELAY(2) | G_DELAY(0))		/* CFG_MMC1_DAT1_OUT */
    	mmc1_iodelay_sdr104_rev20_conf: mmc1_iodelay_sdr104_rev20_conf {
    			0x620 (A_DELAY(600) | G_DELAY(400))	/* CFG_MMC1_CLK_OUT */
    			0x62c (A_DELAY(0) | G_DELAY(0))		/* CFG_MMC1_CMD_OUT */
    			0x638 (A_DELAY(30) | G_DELAY(0))	/* CFG_MMC1_DAT0_OUT */
    	mmc2_iodelay_hs200_1_8v_rev11_conf: mmc2_iodelay_hs200_1_8v_rev11_conf {
    			0x190 (A_DELAY(621) | G_DELAY(600))	/* CFG_GPMC_A19_OEN */
    			0x194 (A_DELAY(300) | G_DELAY(0))	/* CFG_GPMC_A19_OUT */
    			0x1a8 (A_DELAY(739) | G_DELAY(600))	/* CFG_GPMC_A20_OEN */
    			0x1ac (A_DELAY(240) | G_DELAY(0))	/* CFG_GPMC_A20_OUT */
    			0x1b4 (A_DELAY(812) | G_DELAY(600))	/* CFG_GPMC_A21_OEN */
    			0x1b8 (A_DELAY(240) | G_DELAY(0))	/* CFG_GPMC_A21_OUT */
    			0x1c0 (A_DELAY(954) | G_DELAY(600))	/* CFG_GPMC_A22_OEN */
    			0x1c4 (A_DELAY(60)  | G_DELAY(0))	/* CFG_GPMC_A22_OUT */
    			0x1d0 (A_DELAY(1340)| G_DELAY(420))	/* CFG_GPMC_A23_OUT */
    			0x1d8 (A_DELAY(935) | G_DELAY(600))	/* CFG_GPMC_A24_OEN */
    			0x1e4 (A_DELAY(525) | G_DELAY(600))	/* CFG_GPMC_A25_OEN */
    			0x1e8 (A_DELAY(120) | G_DELAY(0))	/* CFG_GPMC_A25_OUT */
    			0x1f0 (A_DELAY(767) | G_DELAY(600))	/* CFG_GPMC_A26_OEN */
    			0x1f4 (A_DELAY(225) | G_DELAY(0))	/* CFG_GPMC_A26_OUT */
    			0x1fc (A_DELAY(565) | G_DELAY(600))	/* CFG_GPMC_A27_OEN */
    			0x200 (A_DELAY(60) | G_DELAY(0))	/* CFG_GPMC_A27_OUT */
    			0x364 (A_DELAY(969) | G_DELAY(600))	/* CFG_GPMC_CS1_OEN */
    			0x368 (A_DELAY(180) | G_DELAY(0))	/* CFG_GPMC_CS1_OUT */
    	mmc2_iodelay_hs200_1_8v_rev20_conf: mmc2_iodelay_hs200_1_8v_rev20_conf {
    			0x190 (A_DELAY(274) | G_DELAY(0))       /* CFG_GPMC_A19_OEN */
    			0x194 (A_DELAY(162) | G_DELAY(0))       /* CFG_GPMC_A19_OUT */
    			0x1a8 (A_DELAY(401) | G_DELAY(0))       /* CFG_GPMC_A20_OEN */
    			0x1ac (A_DELAY(73) | G_DELAY(0))        /* CFG_GPMC_A20_OUT */
    			0x1b4 (A_DELAY(465) | G_DELAY(0))       /* CFG_GPMC_A21_OEN */
    			0x1b8 (A_DELAY(115) | G_DELAY(0))       /* CFG_GPMC_A21_OUT */
    			0x1c0 (A_DELAY(633) | G_DELAY(0))       /* CFG_GPMC_A22_OEN */
    			0x1c4 (A_DELAY(47) | G_DELAY(0))        /* CFG_GPMC_A22_OUT */
    			0x1d0 (A_DELAY(935) | G_DELAY(280))     /* CFG_GPMC_A23_OUT */
    			0x1d8 (A_DELAY(621) | G_DELAY(0))       /* CFG_GPMC_A24_OEN */
    			0x1e4 (A_DELAY(183) | G_DELAY(0))       /* CFG_GPMC_A25_OEN */
    			0x1e8 (A_DELAY(0) | G_DELAY(0))         /* CFG_GPMC_A25_OUT */
    			0x1f0 (A_DELAY(467) | G_DELAY(0))       /* CFG_GPMC_A26_OEN */
    			0x1f4 (A_DELAY(0) | G_DELAY(0))         /* CFG_GPMC_A26_OUT */
    			0x1fc (A_DELAY(262) | G_DELAY(0))       /* CFG_GPMC_A27_OEN */
    			0x200 (A_DELAY(46) | G_DELAY(0))        /* CFG_GPMC_A27_OUT */
    			0x364 (A_DELAY(684) | G_DELAY(0))       /* CFG_GPMC_CS1_OEN */
    			0x368 (A_DELAY(76) | G_DELAY(0))        /* CFG_GPMC_CS1_OUT */
    	mmc2_iodelay_ddr_1_8v_rev11_conf: mmc2_iodelay_ddr_1_8v_rev11_conf {
    			0x18c (A_DELAY(0) | G_DELAY(0))		/* CFG_GPMC_A19_IN */
    			0x1a4 (A_DELAY(274) | G_DELAY(240))	/* CFG_GPMC_A20_IN */
    			0x1b0 (A_DELAY(0) | G_DELAY(60))	/* CFG_GPMC_A21_IN */
    			0x1bc (A_DELAY(0) | G_DELAY(60))	/* CFG_GPMC_A22_IN */
    			0x1c8 (A_DELAY(514) | G_DELAY(360))	/* CFG_GPMC_A23_IN */
    			0x1d4 (A_DELAY(187) | G_DELAY(120))	/* CFG_GPMC_A24_IN */
    			0x1ec (A_DELAY(0) | G_DELAY(60))	/* CFG_GPMC_A26_IN */
    			0x1f8 (A_DELAY(121) | G_DELAY(60))	/* CFG_GPMC_A27_IN */
    	mmc2_iodelay_ddr_1_8v_rev20_conf: mmc2_iodelay_ddr_1_8v_rev20_conf {
    			0x18c (A_DELAY(270) | G_DELAY(0))	/* CFG_GPMC_A19_IN */
    			0x1a4 (A_DELAY(0) | G_DELAY(0))		/* CFG_GPMC_A20_IN */
    			0x1b0 (A_DELAY(170) | G_DELAY(0))	/* CFG_GPMC_A21_IN */
    			0x1bc (A_DELAY(758) | G_DELAY(0))	/* CFG_GPMC_A22_IN */
    			0x1c8 (A_DELAY(0) | G_DELAY(0))		/* CFG_GPMC_A23_IN */
    			0x1d4 (A_DELAY(81) | G_DELAY(0))	/* CFG_GPMC_A24_IN */
    			0x1e0 (A_DELAY(286) | G_DELAY(0))	/* CFG_GPMC_A25_IN */
    			0x1ec (A_DELAY(0) | G_DELAY(0))		/* CFG_GPMC_A26_IN */
    			0x1f8 (A_DELAY(123) | G_DELAY(0))	/* CFG_GPMC_A27_IN */
    			0x360 (A_DELAY(346) | G_DELAY(0))	/* CFG_GPMC_CS1_IN */
    			0x194 (A_DELAY(55) | G_DELAY(0))	/* CFG_GPMC_A19_OUT */
    			0x1ac (A_DELAY(422) | G_DELAY(0))	/* CFG_GPMC_A20_OUT */
    			0x1b4 (A_DELAY(642) | G_DELAY(0))	/* CFG_GPMC_A21_OEN */
    			0x1b8 (A_DELAY(0) | G_DELAY(0))		/* CFG_GPMC_A21_OUT */
    			0x1c4 (A_DELAY(128) | G_DELAY(0))	/* CFG_GPMC_A22_OUT */
    			0x1d0 (A_DELAY(0) | G_DELAY(0))		/* CFG_GPMC_A23_OUT */
    			0x1dc (A_DELAY(395) | G_DELAY(0))	/* CFG_GPMC_A24_OUT */
    			0x1f0 (A_DELAY(623) | G_DELAY(0))	/* CFG_GPMC_A26_OEN */
    			0x1fc (A_DELAY(54) | G_DELAY(0))	/* CFG_GPMC_A27_OEN */
    			0x368 (A_DELAY(0) | G_DELAY(0))		/* CFG_GPMC_CS1_OUT */
    	mmc4_iodelay_ds_rev11_conf: mmc4_iodelay_ds_rev11_conf {
    			0x840 (A_DELAY(0) | G_DELAY(0))		/* CFG_UART1_CTSN_IN */
    			0x848 (A_DELAY(0) | G_DELAY(0))		/* CFG_UART1_CTSN_OUT */
    			0x84c (A_DELAY(96) | G_DELAY(0))	/* CFG_UART1_RTSN_IN */
    			0x850 (A_DELAY(0) | G_DELAY(0))		/* CFG_UART1_RTSN_OEN */
    			0x854 (A_DELAY(0) | G_DELAY(0))		/* CFG_UART1_RTSN_OUT */
    			0x870 (A_DELAY(582) | G_DELAY(0))	/* CFG_UART2_CTSN_IN */
    			0x874 (A_DELAY(0) | G_DELAY(0))		/* CFG_UART2_CTSN_OEN */
    			0x878 (A_DELAY(0) | G_DELAY(0))		/* CFG_UART2_CTSN_OUT */
    			0x87c (A_DELAY(391) | G_DELAY(0))	/* CFG_UART2_RTSN_IN */
    			0x880 (A_DELAY(0) | G_DELAY(0))		/* CFG_UART2_RTSN_OEN */
    			0x884 (A_DELAY(0) | G_DELAY(0))		/* CFG_UART2_RTSN_OUT */
    			0x888 (A_DELAY(561) | G_DELAY(0))	/* CFG_UART2_RXD_IN */
    			0x88c (A_DELAY(0) | G_DELAY(0))		/* CFG_UART2_RXD_OEN */
    			0x890 (A_DELAY(0) | G_DELAY(0))		/* CFG_UART2_RXD_OUT */
    			0x894 (A_DELAY(588) | G_DELAY(0))	/* CFG_UART2_TXD_IN */
    			0x898 (A_DELAY(0) | G_DELAY(0))		/* CFG_UART2_TXD_OEN */
    			0x89c (A_DELAY(0) | G_DELAY(0))		/* CFG_UART2_TXD_OUT */
    	mmc4_iodelay_ds_rev20_conf: mmc4_iodelay_ds_rev20_conf {
    			0x84c (A_DELAY(307) | G_DELAY(0))	/* CFG_UART1_RTSN_IN */
    			0x870 (A_DELAY(785) | G_DELAY(0))	/* CFG_UART2_CTSN_IN */
    			0x87c (A_DELAY(613) | G_DELAY(0))	/* CFG_UART2_RTSN_IN */
    			0x888 (A_DELAY(683) | G_DELAY(0))	/* CFG_UART2_RXD_IN */
    			0x894 (A_DELAY(835) | G_DELAY(0))	/* CFG_UART2_TXD_IN */
    	mmc4_iodelay_sdr12_hs_sdr25_rev11_conf: mmc4_iodelay_sdr12_hs_sdr25_rev11_conf {
    			0x848 (A_DELAY(2651) | G_DELAY(0))	/* CFG_UART1_CTSN_OUT */
    			0x84c (A_DELAY(1572) | G_DELAY(0))	/* CFG_UART1_RTSN_IN */
    			0x870 (A_DELAY(1913) | G_DELAY(0))	/* CFG_UART2_CTSN_IN */
    			0x87c (A_DELAY(1721) | G_DELAY(0))	/* CFG_UART2_RTSN_IN */
    			0x888 (A_DELAY(1891) | G_DELAY(0))	/* CFG_UART2_RXD_IN */
    			0x894 (A_DELAY(1919) | G_DELAY(0))	/* CFG_UART2_TXD_IN */
    	mmc4_iodelay_sdr12_hs_sdr25_rev20_conf: mmc4_iodelay_sdr12_hs_sdr25_rev20_conf {
    			0x848 (A_DELAY(1147) | G_DELAY(0))	/* CFG_UART1_CTSN_OUT */
    			0x84c (A_DELAY(1834) | G_DELAY(0))	/* CFG_UART1_RTSN_IN */
    			0x870 (A_DELAY(2165) | G_DELAY(0))	/* CFG_UART2_CTSN_IN */
    			0x87c (A_DELAY(1929) | G_DELAY(64))	/* CFG_UART2_RTSN_IN */
    			0x888 (A_DELAY(1935) | G_DELAY(128))	/* CFG_UART2_RXD_IN */
    			0x894 (A_DELAY(2172) | G_DELAY(44))	/* CFG_UART2_TXD_IN */
    &i2c1 {
    	status = "okay";
    	clock-frequency = <400000>;
    	tps659038: tps659038@58 {
    		compatible = "ti,tps659038";
    		reg = <0x58>;
    		tps659038_pmic {
    			compatible = "ti,tps659038-pmic";
    			regulators {
    				smps123_reg: smps123 {
    					/* VDD_MPU */
    					regulator-name = "smps123";
    					regulator-min-microvolt = < 850000>;
    					regulator-max-microvolt = <1250000>;
    					regulator-boot-on;
    				smps45_reg: smps45 {
    					/* VDD_DSPEVE */
    					regulator-name = "smps45";
    					regulator-boot-on;
    				smps6_reg: smps6 {
    					/* VDD_GPU - over VDD_SMPS6 */
    					regulator-name = "smps6";
    					regulator-min-microvolt = <850000>;
    					regulator-boot-on;
    				smps7_reg: smps7 {
    					/* CORE_VDD */
    					regulator-name = "smps7";
    					regulator-max-microvolt = <1150000>;
    					regulator-boot-on;
    				smps8_reg: smps8 {
    					/* VDD_IVAHD */
    					regulator-name = "smps8";
    					regulator-boot-on;
    				smps9_reg: smps9 {
    					/* VDDS1V8 */
    					regulator-name = "smps9";
    					regulator-boot-on;
    				ldo1_reg: ldo1 {
    					/* LDO1_OUT --> SDIO  */
    					regulator-name = "ldo1";
    					regulator-boot-on;
    				ldo2_reg: ldo2 {
    					/* VDD_RTCIO */
    					/* LDO2 -> VDDSHV5, LDO2 also goes to CAN_PHY_3V3 */
    					regulator-name = "ldo2";
    					regulator-boot-on;
    				ldo3_reg: ldo3 {
    					/* VDDA_1V8_PHY */
    					regulator-name = "ldo3";
    					regulator-boot-on;
    				ldo9_reg: ldo9 {
    					/* VDD_RTC */
    					regulator-name = "ldo9";
    					regulator-min-microvolt = <1050000>;
    					regulator-max-microvolt = <1050000>;
    					regulator-boot-on;
    					regulator-allow-bypass;
    				ldoln_reg: ldoln {
    					/* VDDA_1V8_PLL */
    					regulator-name = "ldoln";
    					regulator-boot-on;
    				ldousb_reg: ldousb {
    					/* VDDA_3V_USB: VDDA_USBHS33 */
    					regulator-name = "ldousb";
    					regulator-boot-on;
    				/* REGEN1 is unused */
    				regen2: regen2 {
    					/* Needed for PMIC internal resources */
    					regulator-name = "regen2";
    					regulator-boot-on;
    				/* REGEN3 is unused */
    				sysen1: sysen1 {
    					/* PMIC_REGEN_3V3 */
    					regulator-name = "sysen1";
    					regulator-boot-on;
    				sysen2: sysen2 {
    					/* PMIC_REGEN_DDR */
    					regulator-name = "sysen2";
    					regulator-boot-on;
    	pcf_lcd: gpio@20 {
    		compatible = "nxp,pcf8575";
    		reg = <0x20>;
    		gpio-controller;
    		#gpio-cells = <2>;
    		interrupt-parent = <&gpio6>;
    		interrupts = <11 IRQ_TYPE_EDGE_FALLING>;
    		interrupt-controller;
    		#interrupt-cells = <2>;
    	pcf_gpio_21: gpio@21 {
    		compatible = "ti,pcf8575";
    		reg = <0x21>;
    		lines-initial-states = <0x1408>;
    		gpio-controller;
    		#gpio-cells = <2>;
    #if 0
    	tlv320aic3106: tlv320aic3106@19 {
    		compatible = "ti,tlv320aic3106";
    		reg = <0x19>;
    		adc-settle-ms = <40>;
    		ai3x-micbias-vg = <1>;		/* 2.0V */
    		//status = "okay";
    		/* Regulators */
    		AVDD-supply = <&evm_3v3_sw>;
    		IOVDD-supply = <&evm_3v3_sw>;
    		DRVDD-supply = <&evm_3v3_sw>;
    		DVDD-supply = <&aic_dvdd>;
    #endif
    i2c_p3_exp: &i2c2 {
    	status = "okay";
    #if 0
    	tvp_5158: tvp5158@58 {
    		compatible= "ti,tvp5158";
    		reg = <0x58>;
    		port {
    			tvp_decoder: endpoint@0 {
    				remote-endpoint = <&vin2a>;
    				//channels = <0 2 4 6>;
    				channels = <0>;
    				//pixel-mux;
    				//pclk-sample = <0>;
    #endif
    	pcf_hdmi: gpio@26 {
    		reg = <0x26>;
    		gpio-controller;
    		#gpio-cells = <2>;
    		p1 {
    			/* vin6_sel_s0: high: VIN6, low: audio */
    			gpio-hog;
    			gpios = <1 GPIO_ACTIVE_HIGH>;
    			output-low;
    			line-name = "vin6_sel_s0";
    	ov10633@37 {
    		status = "okay";
    		compatible = "ovti,ov10633";
    		reg = <0x37>;
    		mux-gpios = <&pcf_hdmi 3 GPIO_ACTIVE_LOW>; /* CAM_FPD_MUX_S0 */
    		port {
    			onboardLI: endpoint {
    				//remote-endpoint = <&vin1a>;
    				remote-endpoint = <&vin4b>;
    				//hsync-active = <1>;
    				//vsync-active = <1>;
    				pclk-sample = <0>;
    				channels = <0>;
    	disp_ser: serializer@1b {
    		status = "disabled" ;
    		compatible = "ti,ds90uh925q";
    		reg = <0x1b>;
    		#size-cells = <0>;
    		ranges = <0x2c 0x2c>,
    			<0x1c 0x1c>;
    		disp_des: deserializer@2c {
    			compatible = "ti,ds90uh928q";
    			reg = <0x2c>;
    			slave-mode;
    		/* TLC chip for LCD panel power and backlight */
    		fpd_disp: tlc59108@1c {
    			reg = <0x1c>;
    			compatible = "ti,tlc59108-fpddisp";
    			enable-gpios = <&pcf_gpio_21 0 GPIO_ACTIVE_LOW>;
    			/* P0, SEL_GPMC_AD_VID_S0 */
    			port@lcd3 {
    					fpd_in: endpoint {
    					remote-endpoint = <&dpi_out3>;
    &i2c3 {
    	status = "okay";
    &mcspi1 {
            status = "okay";
            ti,pindir-d0-out-d1-in;
            spidev@0
        spi-max-frequency = <16000000>;
        reg = <0>;
            compatible = "rohm,dh2228fv";
            status = "okay" ;
            spidev@1
        reg = <1>;
            status = "okay" ;
            spidev@3
        reg = <3>;
            status = "okay" ;
    &mcspi2 {
            status = "okay";
            spidev@0
        reg = <0>;
    &mcspi3 {
            status = "okay";
            spidev@0
        reg = <0>;
    &uart1 {
    	status = "okay";
    	pinctrl-names = "default";
    	pinctrl-0 = <&uart1_pins>;
    	//interrupts-extended = <&gic GIC_SPI 67 IRQ_TYPE_LEVEL_HIGH &dra7_pmx_core 0x3e0>;
    &uart2 {
    	status = "okay";
    &uart3 {
    	status = "okay";
    	/* gpios = <&pcf_gpio_21 14 GPIO_ACTIVE_LOW>; */
    	pinctrl-0 = <&uart3_pins_default>;
    &uart5 {
    	status = "okay";
    	pinctrl-0 = <&uart5_pins_default>;
    &uart6 {
    	status = "okay";
    	pinctrl-0 = <&uart6_pins_default>;
    &uart9 {
    	status = "okay";
    	pinctrl-0 = <&uart9_pins_default>;
    &uart10 {
    	status = "okay";
    	pinctrl-0 = <&uart10_pins_default>;
    &mmc1 {
    	status = "okay";
    	vmmc-supply = <&evm_1v8_sd>;
    	vmmc_aux-supply = <&ldo1_reg>;
    	bus-width = <4>;
    	//cd-gpios = <&gpio6 27 GPIO_ACTIVE_LOW>;
    	max-frequency = <192000000>;
    	pinctrl-names = "default", "hs", "sdr12", "sdr25", "sdr50", "ddr50-rev11", "sdr104-rev11", "ddr50", "sdr104";
    	pinctrl-0 = <&mmc1_pins_default>;
    	pinctrl-1 = <&mmc1_pins_hs>;
    	pinctrl-2 = <&mmc1_pins_sdr12>;
    	pinctrl-3 = <&mmc1_pins_sdr25>;
    	pinctrl-4 = <&mmc1_pins_sdr50>;
    	pinctrl-5 = <&mmc1_pins_ddr50 &mmc1_iodelay_ddr50_rev11_conf>;
    	pinctrl-6 = <&mmc1_pins_sdr104 &mmc1_iodelay_sdr104_rev11_conf>;
    	pinctrl-7 = <&mmc1_pins_ddr50 &mmc1_iodelay_ddr50_rev20_conf>;
    	pinctrl-8 = <&mmc1_pins_sdr104 &mmc1_iodelay_sdr104_rev20_conf>;
    #if 0
    &mmc2 {
    	status = "okay";
    	vmmc-supply = <&evm_3v3_sw>;
    	bus-width = <8>;
    	pinctrl-names = "default", "hs", "ddr_1_8v-rev11", "ddr_1_8v", "hs200_1_8v-rev11", "hs200_1_8v";
    	pinctrl-0 = <&mmc2_pins_default>;
    	pinctrl-1 = <&mmc2_pins_hs>;
    	pinctrl-2 = <&mmc2_pins_ddr_1_8v &mmc2_iodelay_ddr_1_8v_rev11_conf>;
    	pinctrl-3 = <&mmc2_pins_ddr_1_8v &mmc2_iodelay_ddr_1_8v_rev20_conf>;
    	pinctrl-4 = <&mmc2_pins_hs200_1_8v &mmc2_iodelay_hs200_1_8v_rev11_conf>;
    	pinctrl-5 = <&mmc2_pins_hs200_1_8v &mmc2_iodelay_hs200_1_8v_rev20_conf>;
    #else
    &mmc2 {
            status = "okay";
            bus-width = <8>;
    	ti,non-removable;
            pinctrl-names = "default", "hs", "ddr_1_8v";
            pinctrl-2 = <&mmc2_pins_ddr_1_8v>;
    #endif
    #if 0
    &mmc4 {
    	status = "okay";
    	vmmc-supply = <&vmmcwl_fixed>;
    	bus-width = <4>;
    	cap-power-off-card;
    	keep-power-in-suspend;
    	ti,non-removable;
    	pinctrl-names = "default-rev11", "default", "hs-rev11", "hs", "sdr12-rev11", "sdr12", "sdr25-rev11", "sdr25";
    	pinctrl-0 = <&mmc4_pins_default &mmc4_iodelay_ds_rev11_conf>;
    	pinctrl-1 = <&mmc4_pins_default &mmc4_iodelay_ds_rev20_conf>;
    	pinctrl-2 = <&mmc4_pins_hs &mmc4_iodelay_sdr12_hs_sdr25_rev11_conf>;
    	pinctrl-3 = <&mmc4_pins_hs &mmc4_iodelay_sdr12_hs_sdr25_rev20_conf>;
    	pinctrl-4 = <&mmc4_pins_sdr12 &mmc4_iodelay_sdr12_hs_sdr25_rev11_conf>;
    	pinctrl-5 = <&mmc4_pins_sdr12 &mmc4_iodelay_sdr12_hs_sdr25_rev20_conf>;
    	pinctrl-6 = <&mmc4_pins_sdr25 &mmc4_iodelay_sdr12_hs_sdr25_rev11_conf>;
    	pinctrl-7 = <&mmc4_pins_sdr25 &mmc4_iodelay_sdr12_hs_sdr25_rev20_conf>;
    	#size-cells = <0>;
    	wlcore: wlcore@0 {
    		compatible = "ti,wl1835";
    		reg = <2>;
    		interrupt-parent = <&gpio5>;
    		interrupts = <7 IRQ_TYPE_LEVEL_HIGH>;
    #else
    &mmc4 {
            status = "okay";
            bus-width = <4>;
            pinctrl-0 = <&mmc4_pins_default>;
            status = "okay";
            bus-width = <4>;
            cap-power-off-card;
            ti,non-removable;
            #size-cells = <0>;
            wlcore: wlcore@0 {
                    compatible = "ti,wlcore";
                    reg = <2>;
    #endif
    &oppdm_mpu {
    	vdd-supply = <&smps123_reg>;
    &oppdm_dspeve {
    	vdd-supply = <&smps45_reg>;
    &oppdm_gpu {
    	vdd-supply = <&smps6_reg>;
    &oppdm_ivahd {
    	vdd-supply = <&smps8_reg>;
    &oppdm_core {
    	vdd-supply = <&smps7_reg>;
    &qspi {
    	//status = "okay";
    	spi-max-frequency = <64000000>;
    	m25p80@0 {
    		compatible = "s25fl256s1";
    		reg = <0>;
    		spi-tx-bus-width = <1>;
    		spi-rx-bus-width = <4>;
    		#size-cells = <1>;
    		/* MTD partition table.
    		 * The ROM checks the first four physical blocks
    		 * for a valid file to boot and the flash here is
    		 * 64KiB block size.
    		partition@0 {
    			label = "QSPI.SPL";
    			reg = <0x00000000 0x000040000>;
    		partition@1 {
    			label = "QSPI.u-boot";
    			reg = <0x00040000 0x00100000>;
    		partition@2 {
    			label = "QSPI.u-boot-spl-os";
    			reg = <0x00140000 0x00080000>;
    		partition@3 {
    			label = "QSPI.u-boot-env";
    			reg = <0x001c0000 0x00010000>;
    		partition@4 {
    			label = "QSPI.u-boot-env.backup1";
    			reg = <0x001d0000 0x0010000>;
    		partition@5 {
    			label = "QSPI.kernel";
    			reg = <0x001e0000 0x0800000>;
    		partition@6 {
    			label = "QSPI.file-system";
    			reg = <0x009e0000 0x01620000>;
    &omap_dwc3_1 {
    	//extcon = <&extcon_usb1>;
    &omap_dwc3_2 {
    	//extcon = <&extcon_usb2>;
    &usb1 {
    	status = "ok";
    	dr_mode = "host";
    &usb2 {
    	status = "ok";
    	dr_mode = "host";
    &usb3 {
    	pinctrl-0 = <&usb3_pins>;
    	status = "ok";
    	dr_mode = "host";
        snps,hsphy_interface = "ulpi";
    &elm {
    	status = "okay";
    &gpmc {
    	ranges = <0 0 0x08000000 0x01000000>;	/* minimum GPMC partition = 16MB */
    	nand@0,0 {
    		compatible = "ti,omap2-nand";
    		reg = <0 0 4>;		/* device IO registers */
    		interrupt-parent = <&gpmc>;
    		interrupts = <0 IRQ_TYPE_NONE>, /* fifoevent */
    			     <1 IRQ_TYPE_NONE>; /* termcount */
    		rb-gpios = <&gpmc 0 GPIO_ACTIVE_HIGH>; /* gpmc_wait0 pin */
    		ti,nand-ecc-opt = "bch8";
    		ti,elm-id = <&elm>;
    		nand-bus-width = <16>;
    		gpmc,device-width = <2>;
    		gpmc,sync-clk-ps = <0>;
    		gpmc,cs-rd-off-ns = <80>;
    		gpmc,cs-wr-off-ns = <80>;
    		gpmc,adv-on-ns = <0>;
    		gpmc,adv-rd-off-ns = <60>;
    		gpmc,adv-wr-off-ns = <60>;
    		gpmc,we-on-ns = <10>;
    		gpmc,we-off-ns = <50>;
    		gpmc,oe-on-ns = <4>;
    		gpmc,oe-off-ns = <40>;
    		gpmc,access-ns = <40>;
    		gpmc,wr-access-ns = <80>;
    		gpmc,rd-cycle-ns = <80>;
    		gpmc,wr-cycle-ns = <80>;
    		gpmc,bus-turnaround-ns = <0>;
    		gpmc,cycle2cycle-delay-ns = <0>;
    		gpmc,clk-activation-ns = <0>;
    		gpmc,wr-data-mux-bus-ns = <0>;
    		/* MTD partition table */
    		/* All SPL-* partitions are sized to minimal length
    		 * which can be independently programmable. For
    		 * NAND flash this is equal to size of erase-block */
    		#size-cells = <1>;
    		partition@0 {
    			label = "NAND.SPL";
    			reg = <0x00000000 0x000020000>;
    		partition@1 {
    			label = "NAND.SPL.backup1";
    			reg = <0x00020000 0x00020000>;
    		partition@2 {
    			label = "NAND.SPL.backup2";
    			reg = <0x00040000 0x00020000>;
    		partition@3 {
    			label = "NAND.SPL.backup3";
    			reg = <0x00060000 0x00020000>;
    		partition@4 {
    			label = "NAND.u-boot-spl-os";
    			reg = <0x00080000 0x00040000>;
    		partition@5 {
    			label = "NAND.u-boot";
    			reg = <0x000c0000 0x00100000>;
    		partition@6 {
    			label = "NAND.u-boot-env";
    			reg = <0x001c0000 0x00020000>;
    		partition@7 {
    			label = "NAND.u-boot-env.backup1";
    			reg = <0x001e0000 0x00020000>;
    		partition@8 {
    			label = "NAND.kernel";
    			reg = <0x00200000 0x00800000>;
    		partition@9 {
    			label = "NAND.file-system";
    			reg = <0x00a00000 0x0f600000>;
    &usb2_phy1 {
    	phy-supply = <&ldousb_reg>;
    &usb2_phy2 {
    &gpio7 {
    	ti,no-reset-on-init;
    	ti,no-idle-on-init;
    &mac {
    	status = "okay";
    	dual_emac;
    &cpsw_emac0 {
    	phy_id = <&davinci_mdio>, <2>;
    	phy-mode = "rgmii";
    	dual_emac_res_vlan = <1>;
    &cpsw_emac1 {
    	phy_id = <&davinci_mdio>, <3>;
    	phy-mode = "rgmii";
    	dual_emac_res_vlan = <2>;
    &dcan1 {
    	status = "ok";
    	pinctrl-names = "default", "sleep", "active";
    	pinctrl-0 = <&dcan1_pins_sleep>;
    	pinctrl-1 = <&dcan1_pins_sleep>;
    	pinctrl-2 = <&dcan1_pins_default>;
    &atl {
    	assigned-clocks = <&abe_dpll_sys_clk_mux>,
    			  <&atl_gfclk_mux>,
    			  <&dpll_abe_m2x2_ck>,
    			  <&atl_clkin1_ck>,
    			  <&atl_clkin2_ck>;
    	assigned-clock-parents = <&sys_clkin2>, <&dpll_abe_m2_ck>;
    	assigned-clock-rates = <0>, <0>,  <361267200>,
    			       <11289600>, <11289600>;
    	atl2 {
    		bws = <DRA7_ATL_WS_MCASP2_FSX>;
    		aws = <DRA7_ATL_WS_MCASP3_FSX>;
    &mcasp1 {
    	fck_parent = "atl_clkin2_ck";
    	pinctrl-0 = <&mcasp1_pins>;
    	status = "okay";
    	op-mode = <0>;          /* MCASP_IIS_MODE */
    	tdm-slots = <2>;
    	/* 16 serializer */
    	serial-dir = <  /* 0: INACTIVE, 1: TX, 2: RX */
    		0 0 0 1
    		1 1 1 1
    		0 0 0 0
    		0 0 0 0
    	tx-num-evt = <8>;
    	rx-num-evt = <8>;
    	async;
    &mcasp2 {
    	pinctrl-0 = <&mcasp2_pins>;
    	status = "okay";
    	tdm-slots = <2>;
    	/* 16 serializer */
    		2 2 2 2
    		0 0 0 0
    		0 0 0 0
    		0 0 0 0
    	tx-num-evt = <8>;
    	rx-num-evt = <8>;
    	async;
    &mcasp3 {
    	pinctrl-0 = <&mcasp3_pins>;
    	status = "okay";
    	tdm-slots = <2>;
    	/* 4 serializer */
    		1 2 0 0
    	tx-num-evt = <8>;
    	rx-num-evt = <8>;
    &mcasp4 {
    	pinctrl-0 = <&mcasp4_pins>;
    	status = "okay";
    	tdm-slots = <2>;
    	/* 4 serializer */
    		2 0 0 0
    	tx-num-evt = <8>;
    	rx-num-evt = <8>;
    &mcasp8 {
    	pinctrl-0 = <&mcasp8_pins>;
    	status = "okay";
    	tdm-slots = <2>;
    	/* 4 serializer */
    		2 1 0 0
    	tx-num-evt = <8>;
    	rx-num-evt = <8>;
    &mailbox5 {
    	status = "okay";
    	mbox_ipu1_ipc3x: mbox_ipu1_ipc3x {
    		status = "okay";
    	mbox_dsp1_ipc3x: mbox_dsp1_ipc3x {
    		status = "okay";
    &mailbox6 {
    	status = "okay";
    	mbox_ipu2_ipc3x: mbox_ipu2_ipc3x {
    		status = "okay";
    	mbox_dsp2_ipc3x: mbox_dsp2_ipc3x {
    		status = "okay";
    &mmu0_dsp1 {
    	status = "okay";
    &mmu1_dsp1 {
    	status = "okay";
    &mmu0_dsp2 {
    	status = "okay";
    &mmu1_dsp2 {
    	status = "okay";
    &mmu_ipu1 {
    	status = "okay";
    &mmu_ipu2 {
    	status = "okay";
    &ipu2 {
    	status = "okay";
    	memory-region = <&ipu2_cma_pool>;
    	mboxes = <&mailbox6 &mbox_ipu2_ipc3x>;
    	timers = <&timer3>;
    	watchdog-timers = <&timer4>, <&timer9>;
    &ipu1 {
    	status = "okay";
    	memory-region = <&ipu1_cma_pool>;
    	mboxes = <&mailbox5 &mbox_ipu1_ipc3x>;
    	timers = <&timer11>;
    	watchdog-timers = <&timer7>, <&timer8>;
    &dsp1 {
    	status = "okay";
    	memory-region = <&dsp1_cma_pool>;
    	mboxes = <&mailbox5 &mbox_dsp1_ipc3x>;
    	timers = <&timer5>;
    	watchdog-timers = <&timer10>;
    &dsp2 {
    	status = "okay";
    	memory-region = <&dsp2_cma_pool>;
    	mboxes = <&mailbox6 &mbox_dsp2_ipc3x>;
    	timers = <&timer6>;
    &dss {
    	status = "okay";
    	vdda_video-supply = <&ldoln_reg>;
    	ports {
    		#size-cells = <0>;
    		port@lcd3 {
    			reg = <2>;
    			dpi_out3: endpoint {
    				remote-endpoint = <&fpd_in>;
    				data-lines = <24>;
    &hdmi {
    	vdda-supply = <&ldo3_reg>;
    	port {
    		hdmi_out: endpoint {
    			remote-endpoint = <&tpd12s015_in>;
    #if 0
    &vip1 {
    	status = "okay";
    video_in: &vin1a {
    	status = "okay";
    	endpoint@0 {
    		slave-mode;
    		remote-endpoint = <&onboardLI>;
    #endif
    &vip2 {
    	status = "okay";
    video_in: &vin4b {
    	status = "okay";
    	endpoint@0 {
    		slave-mode;
    #include "dra7xx-jamr3.dtsi"
    #if 0
    &tvp_5158{
    	mux-gpios = <&pcf_hdmi 3 GPIO_ACTIVE_HIGH>,	/*CAM_FPD_MUX_S0*/
    		    <&pcf_jamr3_21 8 GPIO_ACTIVE_LOW>;	/*SEL_TVP_FPD*/
    #endif
    3. * DRA746 eMMC? boots , but mount eMMC1 interface (include TS3A27518? )
    [Kevin] This is our major issue that DateCode 2244/2245 booting with error message(sometime panic) at 3.3V:
    3.1 DRA746 boots from eMMC2(/dev/mmcblk1, the rootfs storage), but in mounting FS process it will try to read to MMC1(/dev/mmcblk0) and error message happens as below:
    "[    3.857446] mmcblk0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0".
    3.2 Yes, include TS3A27518.
  • Your schematic shows that SDCD (Card Detect) is being pulled up by the 1.8V, which would explain why it is only working with this IO level.
    On newest software (v6), you run into a 'Waiting for root device' error associated with not detecting SD which also suggests this.
     You have disabled this line, but it can be used to have GPIO control over SDCD -> //cd-gpios = <&gpio6 27 GPIO_ACTIVE_LOW>;
    Since you are multiplexing an eMMC device and SD card on the same controller, you do not want Card Detect to be pulled high always, or you can split the SD and eMMC onto any of the other controllers on the device MMC1/2/3/4.
    Are you booting from an eMMC device on MMC2?
  • Hi, Macro.
    Thanks your reply.
    As far as I know, customer board can also boot from MMC2.
    For recent days debug, customer has work around way to skip this issue.
    because multiplexer just for factory MP only, not for normal use.
    So, I think we can close this thread.
    Thanks again
    Gibbs
