THS3215: THS3215 DAC output
Genius 12120 points
Part Number: THS3215
Hi Team
For DAC output "buffer + differential to single ended" scheme, please help confirm whether THS3215 HD2 (40MHz 1vpp) supports < - 75dbc, or there are other schemes。
Thanks in advance
William
  • Hi William,
    The data we have available for differential to single ended HD2 over frequency is at specified at 2Vpp:
    It looks like 1Vpp at 40MHz probably puts you around -70dBc. Could you clarify what you mean by other schemes?
    Sam
  • Hi Sam
    Thanks for your kindly reply,
    Is there a way to improve HD2 performance to -75dBc
    Thank you a lot.
    William
  • I believe the plot Sam put in was for the combined D2S +OPS into 100ohm load. That plot shows about -69dBc for 2Vpp, it should get a little lower for a 1Vpp swing and if you were to increase the loading on each stage a little.
    -75dBc is a pretty good number at 40MHz, keep in mind these are typical plots and you should anticipate some spread around this (most likely in the worse direction).
  • Hi Team
    Thank you for your letter. We haven't found a solution yet,
    Is there a chance to increase the voltage (+ / - 6V - > + / - 7.5V) to get better HD2? How much can it increase?
    Or other models of buffer + differential to single end DAC output amplifier are available
    William
