Part Number: OPA145
i got the OPA145 recommended from the TI team for biosignal processing. We used the amplifier as a voltage follower. we supplied the part with +6.6V and -3.3V (originally we wanted to use +-3.3V but then we found this forum entry https://e2e.ti.com/support/amplifiers-group/amplifiers/f/amplifiers-forum/927000/opa145-opa145-spice-model ;so we added a voltag doubler to the 3.3V).
we simulated the circuit in LTSpice with an input signal of +-10µV (blue). The output signal appeared to be +-10µV with a little offset.
we estimated that a little noise in the nV range will be added.
in reality we received a lot of noice in the µV range.
the circuit should be the same as in the simulation. do you have any idea why we measure a decent amount of noice using the OPA145.
best,
Martin
