The TI E2E™ design support forums will undergo maintenance from July 11 to July 13. If you need design support during this time, open a new support request with our customer support center.
OPA858: PSpice Noise Simulation
Part Number: OPA858
Other Parts Discussed in Thread: THS4541
Hello all,
I am trying to simulate the noise of the following circuit. The circuit has a transimpedance amplifier (TIA - OPA858) and a fully differential amplifier (FDA - THS4541). However, I am not getting the expected results.
This is the configuration profile window. Basically, I want to measure the noise at the output of both circuits. Although in this window, I am only measuring the noise at one of the FDA outputs.
So, after running the simulation, I got the results below. The simulation gives me a maximum noise value of 22fV/sqrt(Hz) which I believe is too small for what I expected.
Since only the total noise of the resistors appear on the available traces, I believe that the Op-Amp noise isn't being simulated.
So, how can I insert the Op-Amps noise in this simulation, in order to have a proper noise simulation?
Thank you in advance.
