Part Number: LMH6881EVAL
According to LMH6881EVAL user guide:
"The LMH688x GUI software was written using LabVIEW 2011. In order to run the executable file the National Instruments LabVIEW Run-Time Engine 2011 needs to be downloaded and installed. It can be found at the NI website or at the link below. http://joule.ni.com/nidu/cds/view/p/id/2534/lang/en"
Having trouble installing LabVIEW 2011 -
File from NI support, got the ZIP for 2011 as per TI document:
“LabView Run Time LVRE2011 f2Patch” but failed to install ? (See attached Capture_NI_Failure.PNG)
We have also downloaded from NI web site and succeeded this time to install the following NI Run Time:
“LabView Run Time LVRE2011 SP1f2Patch” but TI application LMH688x does not start ? (See attached Capture_NI_Failure_2.PNG)
“LabView Run Time LVRE2012 SP1f3Patch”, but TI application LMH688x does not start as per 2011 SP1)
“LabView Run Time LVRE2014 SP1f2Patch”, but TI application LMH688x does not start as per 2011 SP1)
Do you know if your application should also work with the newer version: 2011 SP1, 2012 or 2014 ?
On my side it does not work.
Capture_NI_Failure.PNG:
Capture_NI_Failure_2.PNG:
