DEM-OPA-SO-1A: DEM-OPA-SO-1A
Part Number: DEM-OPA-SO-1A
FOR EVAL BOARD  : DEM-OPA-SO-1A, WE REQUIRED BOM TO BE POPULATED ON THE PCB WITH SCHEMATICS, ASSEMBLY INSTRUCTIONS AND TESTING PROCEDURE AS PER DATA SHEET.
  • Hello Abin,
    There is not an option to order the DEM-OPA-SO-1A EVM populated; the schematics, PCB layouts, and BOM present in the user guide for the DEM-OPA-SO-1A are sufficient to select and place your own components, appropriately sized and connected, onto the PCB.
    If you have specific questions about setting up the DEM-OPA-SO-1A for a certain amplifier or circuit configuration, please ask those questions as well.
    This EVM board was intentionally designed to be generic; the Altium source files also include generic resistors and capacitors as there is not a set use or behavior for this circuit.  It can be configured to suit the needs of your design.
    Please see the attached PDF for additional information on the PCB layout & BOM, though the information is very similar to what is made available on the DEM-OPA-SO-1A product page.
    DEM-OPA-SO-1A_e2e_aws_PCB.pdf
    Alec
