OPA855: TIA PSpice simulation issue with Opamp OPA855
Part Number: OPA855
Hello TI teams,
Firstly hope all is doing well.
In the case of the implementation of a TIA for SiPM sensor application I tried to simulate a dummy TIA circuit using OPA855 but the output gain is unexpected (very low) as it would be approx Vout = Vd-1000*1mV = 1V when the current source is on. Could you help me with this ?
Here is also the schematic picture.
Have a nice day,
Simon
  • Hi Simon,
    I saw that you posted more recently, so maybe you've moved past this already, but I tried your setup and wasn't able to replicate your odd result. Below I included a screenshot and the file of my results and circuit configuration, let me know if I missed something about your setup.
    I wanted to mention that the large overshoot visible in Vout is a result of having no feedback capacitance and source capacitance. I linked a TIA calculator below, which can be used to calculate the feedback capacitor value.
    I don't know what SiPM sensor you are using, but I wanted to warn you that you may need to configure the OPA855 as a standard voltage feedback instead of as a TIA, because many have a voltage output. Feel free to link the datasheet and let us know your requirements if you would like us to take a look at it and help to configure it.
    Sim file:
    OPA855_tia_Frabelfin.TSC
    Calculator:
    https://e2e.ti.com/support/amplifiers-group/amplifiers/f/amplifiers-forum/956151/faq-transimpedance-amplifier-calculator
    Hypatia
  • Hello Hypatia,
    Thanks for your reply. Indeed I ll use FB capacitance but I was first wanting to try a "dummy" circuit to see how is working the OPA855. If it is working with Tina I think it is more an issue with the PSpice library ?
    Thanks for your help,
    Yours,
    Simon
  • I'll try the same simulation in Pspice and get back to you
    Hypatia
