Other Parts Discussed in Thread: INA138, INA139, INA170, INA169, INA168
Hi Support,
Do you have any current sense IC that monitors negative voltages?
Application below.
Thanks.
Hello ikon,
Thank you for considering to use Texas Instruments in your design. All of our current, voltage monitor devices typically require a positive common mode voltage. However, there is a way to get around this obstacle. In this thread, I show how you could measure with a negative bus voltage. With this implementation I believe you could use any of the parts listed on this page.
Hi Patrick,
Customer is interested to try out the method in https://www.edn.com/design/test-and-measurement/4331372/High-side-current-sensor-monitors-negative-rail
Do you have similar current sense amplifier to offer?
Thanks.
