Hi team,
For the DRV595, what's the maximum differential output voltage?
Does the maximum differential output voltage relate to the supply voltage and the load?
I have find the spec in the datasheet, the datasheet shows the output differential voltage can't be larger than 12V.(as below)
So I don't know if this spec is related to specific condition.
Can you help to provide the method to know the maximum differential output voltage? such as the PVDD=12V, the output load is 8 ohm.
Lacey
Thanks a lot!
