Part Number: LM358
Hi team,
Could you please help to explain of the output current meaning as below table shows?
When Vs=15V, Vo=0V, VID=1V, source current -30mA(typ) and Vs=15V, Vo=15V, VID=-1V, sink current 12mA(min)?
Thanks.
James.
Part Number: LM358
Hi team,
Thanks.
James.
Hi Paul,
Thanks for the explanation.
Could you help to figure out this? I have 10kohm load, and I have Voutput=15V at the start up time, and then Vout drop to about 5V. Could LM358 due with the startup current spike?
James.
Hi Paul,
This is a question from customer, and I didn't have the waveform yet.
15V to 5V is just the response of input voltage changes, not meaning the supply voltage. I believe the supply votlage stays flat.
Thanks.
James
Hi Paul,
This LM358 use for 220V line current sensing, they use a 10kohm resistor as amplifier' load, and the output voltage is 0~5V. Could LM358 output current satisfy this resistor?
By the way, customer feedback the current will have a spike in start up,and they didn't have the waveform yet.
Thanks.
James
