Hi Team,
The customer is looking for the disable and enable timing information in the Typical Characteristics section of the LMH6521 datasheet.
The customer would like also to know if the supply current will be in half if one channel is disabled since the datasheet states that the supply current is 275 mA both channels enabled.
Thank you very much in advance.
Mark
Hello Mark,
Each channel of the LMH6521 should draw 17.5 mA when disabled.
Hasan Babiker
Also for enable and disable timing, you can use Figures 31 & 32 from the LMH6522 datasheet.
