Dear All,
Can I get some reference schematics for configuring the 4-20mA signal 2-wire and 4-wire configuration signal input using RCV420. output 0-5Vdc
Hi Mohammad,
Does the typical schematic of the figure 1 in the RCV420 data sheet work well?
You can also see the other examples in some application notes in as below.
https://www.ti.com/product/RCV420#tech-docs
https://www.ti.com/lit/an/sboa023/sboa023.pdf
Thank you and Best regards,
Iwata Etsuji
Dear Iwata,
Thanks for the replay,
I am unable to understand how to do 4-20mA input can be configured for 4wire and 2 wire selection type configuration in a single schematic with jumper selection type for 2 wire and 4wire.
Wasim
Hi Wasim,
In my understanding, there is not necessary for RCV420 to identify the 4-20mA wiring is 2-wired or 4-wired.
So I have to know more about your expected system with RCV420.
Is it possible for you to share the system block diagram?
Would you like to configure the loop voltage for each case?
Iwata Etsuji
Hi Mohammad,
We haven't heard from you in a while. We hope the issue was resolved. Closing this thread now. Reply to re-open if you have any additional questions.
