Part Number: BUF634A
Other Parts Discussed in Thread: THS3491, OPA1656, OPA1611
When you parallel power amps for load sharing you need a ballast resistor to share the current suppress excessive output to output currents due to mismatched offset voltage, this document digs pretty deeply into that, but gives you the basics as well,
Hi Michael-san,
Thank you for the information.
THS3491 is the current feedback amplifier. So, is it possible to apply the topology which is mentioned in this document to voltage feedback amplifier as well?
Are the series resistors(Rs1 and Rs2) which is mentioned in "2.3.1.1 Concept of Load-Sharing Configuration" also necessary for the voltage feed amplifier?
Additionally, should two OPA1656 be added as well if using two BUF634A in parallel?
Kato
Hi Hasan-san,
Thank you for your quick response.
I understand.
By the way, could you please give me your comment about the following post?
OPA1611: Isolation Resistor
https://e2e.ti.com/support/audio/f/6/t/928473
Kato
