Because of the Thanksgiving holiday in the U.S., TI E2E™ design support forum responses may be delayed from November 25 through December 2. Thank you for your patience.
TAS5601: How to set-up 4x10W configuration?
Part Number: TAS5601
Dear
Is there an example for code and hardware, how to use the 4x10W config?
Greetings
Thomas Van Aken
  • Hello Thomas,
    In the datasheet Figure 2 highlights the 4x10W configuration, insofar as the code I would need to check internally since this is an older device the SW was previously given on the CD that came with the EVM.
    For this project is this an evaluation for a future project or an existing system? May I ask why the TAS5601 is being used since it's an older device and there might be newer devices in our portfolio that would offer better performance/features/or cost and significantly streamlined SW/Firmware development.
    Luis
