Part Number: PCM3060
To whom it may concern;
PCM3060 supports HS protocol from Intel, if it is not which Codec do you suggest that supports HD.
REgards
Albert Tello
REgards
Albert Tello
Hi Albert,
Can you provide more information about the requirements? It's not clear what you are asking. Is it for software driver support?
Brian
Hi Brian
We need to provide sound for a carrier board with COMM Express Type 6.
The CMM Express manufacturer support HD (High Resolution ) from Intel. We need to replace ADL888 from Realtek with TI codec .
We need , Input Digital and analog , I2C , Output 1 Stereo , the output audio will be amplified with our circuit.
We can develop a driver for Windows 10
Please let me know if have any more questions, please let me know
Regards ,
Albert Tello
Can you send the ADL888 data sheet? I am not able to get the spec online and your information is not detailed enough to suggest a replacement.
Regards.
Hi Pdjuandi
Is attached the datasheet as per your request
Albert Tello
We do not have device that has everything in this datasheet such as beam forming. We have devices with mini-DSP but for AEC/ANC we recommend to use external DSP as this algorithm requires extensive memory and processing power. If this is acceptable then please list out what the must have and we can narrow down further.
Here is a list of our CODEC devices which you peruse and filter further.
https://www.ti.com/audio-ic/converters/codec/products.html
Regards.
