Goal: USB Audio & Audio amp.
Planning to use a PCM2902C SPDIF output into a TAS2780 (25W Class-D audio amp)
but the TAS2780 takes in a TDM signal while the PCM2902 outputs a SPDIF signal.
Suggestions?
Hi Michael,
The device you're looking for to interface between PCM290x and digital speaker amp is a SPDIF transceiver such as DIR9001 . This decodes SPDIF and provides clocks necessary for I2S.
https://www.ti.com/audio-ic/interface/spdif-transceivers/products.html : You can see our portfolio of transceivers here.
