Hi Team,
When the Dynamic Range Enhancer (DRE) function is active, the sound output by PCM5120 will continuous beep.
In addition to configuring the registers in the diagram, is there any other configuration required to setting the DRE function?
Using the default DRE parameters instead of the parameter configuration in the red block in the figure below will cause problems?
