When testing the signal-to-noise ratio of TPA6304, it was found that the signal-to-noise ratio at the output of 1Vrms was only 74dB (>80dB is required), and the bottom noise was 220uV (the SPEC of 6304 is 60uV). Please provide optimization suggestions. Thank you. Attached are the test report, PCB and schematic diagram.
