Hi expert,
I am designing one EMI board, and audio interface device uses DIR9001-Q1. According to first version board EMI test, there is coupling from SCKO and BCKO.
I have one question about SCKO (pin #4). If SCKO is not used, is there anyway to disable SCKO output? If not, can we short SCKO to ground through 49.9ohm+10nF?
Thank you!
Hello Yanming,
I am not aware a way of disabling the SCKO but I believe grounding it through RC network should be ok since your not using it,
Arash
