Part Number: TAS6424E-Q1
Other Parts Discussed in Thread: TAS6424
Hi TI Team
May I ask how to calculate the TAS6424 or TAS6584 for the THD+N or THD algorithm?
Hi TI Team
Hsinhung,
THD is not calculated but measured with audio test equipment.
Gregg Scott
Hi Gregg
Below is our structure, We design this for measured the total power from AMP and want to know the total hormonic value(R-load is 4Ω), I'ii provide THD algorithm to our SW team, So I need to know how to calculated it, could you have any suggestion?
Hsinhung,
This request is outside the use of our amplifiers, because we measure the THD with calibrated test equipment.
I performed a quick search and found that Matlab has a function to calculate the THD. I see there is a thd() function inside the signal processing library. If you do not have access to Matlab, I suggest you perform more searches online to see how to do it in the digital domain.
Gregg Scott
