A customer posted the following questions about TAS5631 startup.
We turn on the PWM/AMP chips for about 120mS and send a 4500Hz tone for about 70ms during the 120mS interval. We repeat this roughly every 2 seconds. We use the PWDN and RESET pins of the PWM/AMP chips to do this. This works very well.
However, we would like to power down PVDD between the 120mS intervals to minimize power dissipation. We have tried this with a delay of about 50mS before enabling TAS5631, but the startup time at VI_CM with the standard 4.7uF cap is much longer than 50mS, so the pulse is distorted.
Can we vary the caps at VI_CM and/or PSU_REF to speed up startup to less than 50mS, to avoid the distortion? Is there any other means of doing that?
Is it normal for VI_CM to take this time to settle?
An immediate answer is that we will consider this and see if there is a way to accomplish the customer's goal.
Steve Crump.
