TLV320AIC3204: TLV320AIC3204EVM :How to use two mics to route to HP and LO respectively?
Part Number: TLV320AIC3204
Hi Team,
I am using 3204EVM debugging, I want to use IN1 and IN3 to route to LO and HP channels respectively, and achieve stereo effect, I configured their registers, but found that IN1 has no input, and LO has no output, can you help me to see what is the reason, the following is my register configuration:
# Software Reset
# Select Page 0
w 30 00 00
# Initialize the device through software reset
w 30 01 01
# Clock Settings
#The input clock signal : MCLK = 11.2896 MHz,BLCK = 1.4 MHz, WCLK = 44.1 kHz
# Select Page 0
w 30 00 00
# NADC = 1, MADC = 2
w 30 12 81 82
# NDAC = 1, MDAC = 2
w 30 0b 81 82
# Signal Processing Settings
# Select Page 0
# w 30 00 00
# Set the ADC Mode to PRB_P1
w 30 3d 01
# Set the DAC Mode to PRB_P8
w 30 3c 08
# Enable Loopback Page 0 register 29
# Loopback enable for stereo audio data
w 30 1D 10
# Initialize Codec
# Select Page 1
w 30 00 01
# Disable weak AVDD in presence of external
# AVDD supply
w 30 01 08
# Enable Master Analog Power Control; AVDD LDO is powered down
w 30 02 00
# Select ADC PTM_R4
w 30 3d 00
# Set the input powerup time to 3.1ms (for ADC)
w 30 47 32
# Set the REF charging time to 40ms
w 30 7b 01
#AGC
w 30 00 00
w 30 57 7E
w 30 56 F0
w 30 58 44
w 30 59 1A
w 30 5A 08
w 30 5B 18
w 30 5C 06
w 30 5E 7E
w 30 5F F0
w 30 60 44
w 30 61 1A
w 30 62 08
w 30 63 18
w 30 64 06
# Recording Setup
# Select Page 1
w 30 00 01
# MICBIAS set to 1.7V
w 30 33 50
# Route IN3L to LEFT_PGA_P with 10K input impedance
w 30 34 04
# Route IN3R to LEFT_PGA_N with 10K input impedance
w 30 36 04
# Route IN1R to Right_PGA_P with 10K input impedance
w 30 37 40
# Route IN1L to Right_PGA_P with 10K input impedance
w 30 39 10
w 30 3b 0c
w 30 3c 0c
# Playback Setup
# Select Page 1
w 30 00 01
# De-pop/Soft stepping
w 30 14 25
# Route LDAC to HPL and  HPR
w 30 0c 08 10
# Route RDAC to LOL and  LOR
w 30 0e 10 08
# HPL/HPR powered up
w 30 09 3C
# Unmute HPL/HPR driver, 0dB Gain
w 30 10 00 00
w 30 12 00 00
# Select Page 0
w 30 00 00
# DRC
w 30 41 FC FC
w 30 44 73
w 30 45 00
w 30 46 B6
# Power up LADC/RADC
w 30 51 c0
# Unmute LADC/RADC
w 30 52 00
# Power up LDAC/RDAC
w 30 3f d6
# Unmute LDAC/RDAC
w 30 40 00
  • Hi Luo,
    To troubleshoot, begin with confirming power to the IC, and confirm correct I2S clock frequencies. Then test record and playback path individually.
    Ensure a clean signal is provided to IN1 and test the record path only, confirm valid data is on DOUT. Repeat the same for the playback path. Scripts are available in the typical configurations tab of the AIC3204 GUI.
  • Hi Daveon,
    I connected IN1 with the same bias voltage and pull-down resistor as IN3. Now the sound of IN1 can be routed to LO, and IN3 can be routed to HP. HP can normally produce ambient stereo effect, but LO has no ambient stereo effect. Is there anything wrong with my register configuration? Please take a look at it for me. Thank you very much.
    Regards.
  • Hi Luo,
    I will look into register config more during my day time. However, for testing please isolate recording and playback script to ensure each signal path is working correctly. Also the order of writes is important, AGC should follow power-up/unmute of ADC and DAC and please confirm on oscilloscope the clocks are correct.
  • Hi Daveon,
    Does isolating recording and playback scripts means setting Page 0 registers 60 to 0,not using a signal processing block? When I set it to 0, my mic and headphones stop working. How do I test?
    Regards.
  • Hi Luo,
    By isolating, I mean verify the ADC path along with any audio processing settings is working correctly before looping to the DAC signal path.
    There are preset scripts given in the AIC3204 GUI, that you can use as a starting point. Then modify/add registers as need be.
    Audio recording (ADC path) example:
    # High Performance Stereo Recording
    # PowerTune mode PTM_R4 is used for high
    # performance 16-bit audio.
    # For normal USB Audio, no hardware change
    # is required.
    # If using an external interface, SW2.4 and
    # SW2.5 of the USB-ModEVM must be set to
    # HI and clocks can be connected to J14 of
    # the USB-ModEVM.
    # IN1L/R is routed to the LADC/RADC in a
    # single-ended manner.
    # Software Reset
    # Select Page 0
    w 30 00 00
    w 30 01 01
    # Clock Settings
    # The codec receives: MCLK = 11.2896 MHz,
    # BLCK = 2.8224 MHz, WCLK = 44.1 kHz
    # Select Page 0
    w 30 00 00
    w 30 12 81 82
    # Select Page 0
    w 30 00 00
    w 30 3d 01
    # Initialize Codec
    # Select Page 1
    w 30 00 01
    # AVDD supply
    w 30 01 08
    w 30 02 00
    # Select ADC PTM_R4
    w 30 3d 00
    w 30 47 32
    w 30 7b 01
    # Recording Setup
    # Select Page 1
    w 30 00 01
    # Route IN1L to LEFT_P with 20K input impedance
    w 30 34 80
    # Route Common Mode to LEFT_M with impedance of 20K
    w 30 36 80
    # Route IN1R to RIGHT_P with input impedance of 20K
    w 30 37 80
    # Route Common Mode to RIGHT_M with impedance of 20K
    w 30 39 80
    # Unmute Left MICPGA, Gain selection of 6dB to make channel gain 0dB
    # Register of 6dB with input impedance of 20K => Channel Gain of 0dB
    w 30 3b 0c
    # Unmute Right MICPGA, Gain selection of 6dB to make channel gain 0dB
    w 30 3c 0c
    # Select Page 0
    w 30 00 00
    w 30 51 c0
    # Unmute LADC/RADC
    w 30 52 00
  • Hi Daveon,
    I added the configuration of DAC playback on the script you provided, connected the computer with EVM, HP and LO played the audio of the computer, and the volume of HP played was higher than that of LO. Then the environment stereo configuration is added, LO can output the stereo gain effect, but the stereo gain effect of LO is also lower than that of HP. I checked the peripheral circuit of EVM LO and HP, and found that the resistors and capacitors used are different. My question is:
    1. Does the difference in the volume of LO and HP result from the difference in their peripheral circuits? If the peripheral circuit of LO is modified to be consistent with that of HP, can they output the same volume?
    2, LO starts to play AGC gain pop sound how to solve?
    PS: My requirement now is to use IN3 and IN1 corresponding to HP and LO respectively as the left and right channels to output the same ambient stereo gain effect, without involving the transmission of audio.
    The following register configuration is for EVM to play computer audio through HP and LO:
    # is required.
    # the USB-ModEVM.
    # Software Reset
    # Select Page 0
    w 30 00 00
    w 30 01 01
    # Clock Settings
    # Select Page 0
    w 30 00 00
    w 30 12 81 82
    # Select Page 0
    w 30 00 00
    w 30 3d 01
    # Initialize Codec
    # Select Page 1
    w 30 00 01
    # AVDD supply
    w 30 01 08
    w 30 02 00
    # Select ADC PTM_R4
    w 30 3d 00
    w 30 47 32
    w 30 7b 01
    # Recording Setup
    # Select Page 1
    w 30 00 01
    w 30 34 80
    w 30 36 80
    w 30 37 80
    w 30 39 80
    w 30 3b 0c
    w 30 3c 0c
    # Select Page 0
    w 30 00 00
    w 30 51 c0
    # Unmute LADC/RADC
    w 30 52 00
    # High Performance Stereo Playback
    # PowerTune mode PTM_P3 is used for high
    # performance 16-bit audio. For PTM_P4,
    # an external audio interface that provides
    # 20-bit audio is required.
    # is required.
    # the USB-ModEVM.
    # Audio is routed to both headphone and
    # line outputs.
    # Clock Settings
    # The input clock signal : MCLK = 11.2896 MHz,BLCK = 1.4 MHz, WCLK = 44.1 kHz: MCLK = 11.2896 MHz,
    # Select Page 0
    w 30 00 00
    w 30 0b 81 82
    # Select Page 0
    # w 30 00 00
    w 30 3c 08
    # Playback Setup
    # Select Page 1
    w 30 00 01
    # De-pop
    w 30 14 25
    # Route LDAC to HPL/HPR
    w 30 0c 08 10
    # Route RDAC to LOL/LOR
    w 30 0e 10 08
    # Power up HPL/HPR and LOL/LOR drivers
    w 30 09 3c
    w 30 10 00 00
    # Unmute LOL/LOR driver, 0dB Gain
    w 30 12 00 00
    # Select Page 0
    w 30 00 00
    # DAC => 0dB
    w 30 41 00 00
    w 30 3f d6
    # Unmute LDAC/RDAC
    w 30 40 00
    Regards.
  • Can you answer my question?
  • Hi Luo,
    1. Audio performance can be quantified by SNR,DR, and THDN. This can affect the perceived loudness of the output so please note the difference in the specifications in the electrical characteristics table. Also note the test conditions and loads used. Additionally, the RC filters present on the output do affect the output as the output drivers are designed for different loads and use cases (i.e class d amplifier, headphone amp, speaker, etc.)
    2. For trouble shooting:
    • Does this pop occur when AGC is disabled?
    • What is the max gain applied to the signal? What is the input signal level
  • Hi Daveon,
    Regarding the LO channel pop sound, disabling AGC will also have a pop sound,Is it also necessary to connect Rpop circuits like HP channels?
    Regards.
  • Hi Luo,
    Pop noise occurring in LO is often due to the power sequence or playback sequence. Please ensure the script is following the sequence outline in 2.4.6 of the datasheet.
    I do not recommend connecting Rpop circuits for LO as they are given for HPOUT.
  • Hi Daveon,
    Our application scenarios are headphone amplifiers, speakers connected to LOL,LOR,HPL,HPR. The current issue is that LOL is connected to the positive side of the speaker, while LOR is connected to the negative side of the speaker. HPL is connected to the positive corner, and HPR is connected to the negative corner. The sound effect of the two speakers is inconsistent. LOL and LOR speakers are buzzing. HPL and HPR speakers are good (no buzzing).
    How to fix this (LOL and LOR speakers have buzzing) problem? How do I set up the software and hardware?
    The following is the register configuration and the line connection of the horn:
    # Software Reset
    # Select Page 0
    w 30 00 00
    w 30 01 01
    # Clock Settings
    # Select Page 0
    w 30 00 00
    w 30 12 81 82
    #AGC
    w 30 00 00
    w 30 57 7E
    w 30 56 F0
    w 30 58 3E
    w 30 59 08
    w 30 5A 32
    w 30 5B 18
    w 30 5C 06
    w 30 5F 7E
    w 30 5E F0
    w 30 60 3E
    w 30 61 08
    w 30 62 32
    w 30 63 18
    w 30 64 06
    w 30 1D 10
    # Select Page 0
    w 30 00 00
    # Set the ADC Mode to PRB_R1
    w 30 3d 01
    # Initialize Codec
    # Select Page 1
    w 30 00 01
    # AVDD supply
    w 30 01 08
    w 30 02 00
    # Select ADC PTM_R4
    w 30 3d 00
    w 30 47 32
    w 30 7b 01
    # Recording Setup
    # Select Page 1
    w 30 00 01
    #MICBIAS
    w 30 33 50
    # Route IN3L to LEFT_PGA_P with 20K input impedance
    w 30 34 08
    # Route IN3R to LEFT_PGA_N with 20K input impedance
    w 30 36 08
    # Route IN1R to Right_PGA_N with 20K input impedance
    w 30 37 80
    # Route IN1L to Right_PGA_P with 20K input impedance
    w 30 39 20
    w 30 3b 00
    w 30 3c 00
    # Select Page 0
    w 30 00 00
    w 30 51 c0
    # Unmute LADC/RADC
    w 30 52 00
    # is required.
    # the USB-ModEVM.
    # line outputs.
    # Clock Settings
    # Select Page 0
    w 30 00 00
    w 30 0b 81 82
    # Select Page 0
    # w 30 00 00
    w 30 3c 08
    # Playback Setup
    # Select Page 1
    w 30 00 01
    # De-pop
    w 30 14 16
    w 30 0c 08 10
    w 30 0e 10 08
    w 30 09 3c
    w 30 10 00 00
    w 30 12 00 00
    # Select Page 0
    w 30 00 00
    # DAC => 0dB
    #w 30 41 00 00
    # DRC
    w 30 41 E4 E4
    w 30 44 73
    w 30 45 00
    w 30 46 B6
    w 30 3f d6
    # Unmute LDAC/RDAC
    w 30 40 00
     PA - V1.5.pdfReagards.
  • Hi Luo,
    I've looped in our codec expert to help support your issue
  • Ok, looking forward to your reply.
  • Hi Luo,
    The line drivers have no special pop protection, so removing all the pop may not be possible. However to mitigate it, I recommend the following sequence:
    Power up DAC(s)
    Power up Line Driver(s)
    Unmute DAC(s)
    Unmute Line Driver(s)
    Your current sequence unmutes the DAC after the line drivers are unmuted and powered up. The best practice is to power up and unmute in the direction of signal flow.
    Jeff McPherson
