am using one TLV320AIC14K in my circuit as a stand alone slave, can i use an external crystal oscillator to generate 20mhz clock for the MCLK of the TLV320AIC14K, and then use the microcontroller to generate my sclk
Hi Christian,
I don't recommend this. The SCLK must be synchronous with the MCLK and if the two sources are different it will be nearly impossible to make them synchronous. See this app note for more details on using an external MCLK https://www.ti.com/lit/an/slaa469a/slaa469a.pdf?ts=1723490700661&ref_url=https%253A%252F%252Fwww.ti.com%252Fproduct%252FTLV320AIC14K
Jeff McPherson
