Hi
Recently I find out that the part PCM9211PT is short of samples. But the part PCM9211PTR still available.
I want to ask what is the difference between this two parts, and which one do you recommend to use?
I already used PCM9211PT on the board, I could replace it with PCM9211PTR and needn't any PCB change, correct?
Thanks.
