Other Parts Discussed in Thread: TLV320AIC3007
I am playing audio ... but it turns out my BCLK was shorted to MCLK. We fixed the short and now have no MCLK and therefore no audio. I still have a BCLK.
So I think I just need to get MCLK running.
Here are the relevant codec / MCLK pieces from my device tree:
sound-tlv320 {
compatible = "fsl,imx-audio-tlv320";
model = "imx-tlv320";
audio-cpu = <&sai1>;
audio-codec = <&tlv320aic3107_1>;
audio-routing =
"Speaker Positive", "SPOP",
"Speaker Negative", "SPOM",
"Speaker Positive", "SWOUTP",
"Speaker Negative", "SWOUTM",
"Headphone Jack", "HPLOUT",
"Headphone Jack", "HPROUT",
"Line Out Jack", "LLOUT",
"Line Out Jack", "RLOUT",
"LINE1L", "Line In Jack",
"LINE2L", "Line In Jack",
"LINE1R", "Line In Jack",
"LINE2R", "Line In Jack";
&i2c3 {
clock-frequency = <100000>;
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_i2c3>;
status = "okay";
tlv320aic3107_1: tlv320aic3107_1@18 {
#sound-dai-cells = <0>;
compatible = "ti,tlv320aic3007";
reg = <0x18>;
tdm-offset = <0>;
gpio-reset = <&gpio1 15 GPIO_ACTIVE_LOW>;
clocks = <&clks IMX7D_OSC_24M_CLK>;
clock-names = "mclk";
status = "okay";
/* Regulators */
ai3x-ocmv = <3>;
IOVDD-supply = <®_3p3v>; /* I/O Voltage */
DVDD-supply = <®_3p3v>; /* Digital Core Voltage */
AVDD-supply = <®_3p3v>; /* Analog DAC Voltage */
DRVDD-supply = <®_3p3v>; /* ADC Analog and Output Driver Voltage */
&clks {
assigned-clocks = <&clks IMX7D_PLL_AUDIO_POST_DIV>;
assigned-clock-rates = <884736000>;
&sai1 {
pinctrl-0 = <&pinctrl_sai1>;
assigned-clocks = <&clks IMX7D_SAI1_ROOT_SRC>,
<&clks IMX7D_SAI1_ROOT_CLK>;
assigned-clock-parents = <&clks IMX7D_PLL_AUDIO_POST_DIV>;
assigned-clock-rates = <0>, <36864000>;
status = "okay";
&iomuxc {
asc-imx7s {
pinctrl_i2c3: i2c3grp {
fsl,pins = <
MX7D_PAD_I2C3_SDA__I2C3_SDA 0x4000007f
MX7D_PAD_I2C3_SCL__I2C3_SCL 0x4000007f
pinctrl_sai1: sai1grp {
fsl,pins = <
MX7D_PAD_SAI1_MCLK__SAI1_MCLK 0x1f
MX7D_PAD_SAI1_RX_BCLK__GPIO6_IO17 0x14
MX7D_PAD_SAI1_RX_SYNC__GPIO6_IO16 0x14
MX7D_PAD_SAI1_TX_DATA__SAI1_TX_DATA0 0x30
MX7D_PAD_SAI1_TX_SYNC__SAI1_TX_SYNC 0x1f
MX7D_PAD_SAI1_TX_BCLK__SAI1_TX_BCLK 0x1f
MX7D_PAD_SAI1_RX_DATA__SAI1_RX_DATA0 0x1f
MX7D_PAD_GPIO1_IO15__GPIO1_IO15 0x74
I’m wondering if you see anything wrong here related to MCLK?
