Part Number: PCM5100A
Hi Sir,
My customer used PCM5100A in product, they found the PCM5100A does no audio output after it power on, but reset the system and audio output is normal.
They also found the pin-out CAPP and CAPM only 900kHz when the PCM5100A does no audio output, but it is in the audio output normal, both pin-outs have 1.536MHz.
They also captured the waveform for pin-out at 3.3Vcc, BCK, LRCK, XSMT and OUTL and put them in the attached file.
Could you please review the schematics and waveform, and advise some comments. Thanks!
