Other Parts Discussed in Thread: TAS5825P, TAS5827
I am working on a small mono speaker with 1 passive radiator. It will use the TAS2781 amplifier. While tuning, we are having issues getting the output level desired from the speaker. We suspect that this may be because of the Smart Amp limiting. We measured the characterization data of the driver using a separate system analyzer (MLSSA) and imported those results into PPC3. However, we don't see an option to change the speaker type from "closed box" to one that accounts for a passive radiator. Additionally, we aren't able to find a combination of smart amp settings that provides the bass response that we are looking for. We have tried changing the protection tuning band crossover points, priorities, and speeds to no real avail. We have been following the Smart Amp Tuning Guide (SLAA751) and its recommendations, but the bass response always reaches its max at about -28dB volume. The other bands keep increasing in volume above this which results in weak bass for those higher volume levels. Here are the excursion estimation verification results from a bass-heavy dance song at low and high volume respectively:
Are there more smart amp settings that we are missing? And how can we properly account for the passive radiator?
CC: Adam Lock
Thank you,
Elliott R
