Other Parts Discussed in Thread: USB2ANY
Question about the LM48901 eval board and the LM48901 registers.
I programmed the eval board using the GUI (basic stereo mode, no spatial coefficients loaded), then removed the USB2ANY connector and attached the SCL and SDA lines from my LM3S9D96 eval board to the correct connectors. The LM48901 eval board still played audio just fine. I then ran an application on the Stellaris to read the LM48901 registers (0x500 to 0x507) over I2C, and even though the addressing headers looked normal on scope, all 4 bytes of all registers came back as 0xff values. Any idea what is causing this, and how to fix it?
Or, can someone supply a mapping of the LM48901 registers look like after the initial scan has activated the chip to play audio? I want to compare what the GUI is displaying with the actual register values.
Ron
