Can I use the MC57xxPSIA to communicate with the TAS5707EVM2 mounted with a TAS5707A instead of TAS5707?
My question is where do I select the TAS5707A (different I2C address) in TAS570X GUI?
Andrew.
Hi, Andre(w). (Your screen name is Andre. Do you prefer Andrew?)
You can use the MC57xxPSIA to communicate with a TAS5707A-powered TAS5707EVM2 if you have the correct I²C address to talk to it.
I don't think there is a good way to set that I²C address in the TAS570X GDE. In fact, I had to write an Application Report about how to set different I²C communication addresses within Windows. It's a little more complicated than pressing a button in the GDE, but I hope it helps you get where you need to be. Please write back if you've got questions.
Matt
André is My name, but for english speakers is very hard to pronunciate... Fell free.
And your answer was perfect, thanks for the prompt and acurate support. I've just tested here and works perfectly.
TI is doing a great job in this E2E forum.
André Rairan.
