Other Parts Discussed in Thread: TAS5631B
For a specific design we intend to use TAS5631B in 4ch single ended mode. In the application schematic in the datasheet I see a pull-up resistor named R-comp between PVdd and each HB output. What is the function of this resistor? Effectively, this resistor of around 200K is in parallel with two 10K in series, so I was wondering why the value of Rcomp is specified so specifically as a function of the PVdd voltage?
regards
Geert
