TAS5xxx - Lower power rating rating requirement?
Other Parts Discussed in Thread: TAS5342L
"I need an amplifier that can produce 75 Watts per channel.  Your product line does not indicate that you have one.  Do you have a 75 Watt amplifier that I have been unable to locate?"
ANSWER:  No, we do not manufacture a 75 Watt amplifer.  The way to do this is to use an amplifier that is rated from the next highest power node and reduce the H-Bridge supply voltage (PVDD).  In your case, plase consider the TAS5342L.  The power supply voltage graphs are on Page 1 of the TAS5342L datasheet.
