TAS5630 library
Other Parts Discussed in Thread: TAS5630
Hello, I want to do the TAS5630 pcb, but there is not in altium's library. Is there a labrari for it?
thanks..
    The PCB footprint can be found in the end of the datasheet. There are 2 packages available for this device so make sure you use the correct footprint.
    I believe Altium has a multi-pin footprint generation tool that should allow you make the footprint very quickly.
    Matt
