TAS5613 single ended vs differential
Other Parts Discussed in Thread: TAS5613
I am testing a 5613 design and I am finding that given the same level input:  The output from the 5613 evaluation card is greater than the output from our own designed card.
One of the differences between the cards is that the 5613 evaluation card is driving the inputs to the 5613 differentially and our own designed card is driving the 5613 inputs single ended.
So my question is… does driving the 5613 inputs differentially result in a higher output level compared to driving them single ended?
Bruce
  • Bruce, all that should matter is the signal difference between the inputs to TAS5613.  Of course, if the difference in our EVM is higher than the difference on your board the output of TAS5613 will be higher in the EVM.  The EVM includes a preamp with gain of about 7dB (10k/4.4k), and it amplifies the EVM signal by that amount, whether the EVM input is differential or single ended (with one side at ground).
    Can you post a schematic of what you are doing?  Please note the inputs of TAS5613 must be AC coupled, because DC coupling will alter the output bias.
    Steve.
  • Oops.  I missed the 7dB gain in the EVM.  So my pre-amplifier will need more gain to get to where we want it.
    Thanks for your help.
    -Bruce
