Hi Team,
We try to use PCM5121 in our system. PCM5121 is set by slave mode, it is controlled by a BT module, and BCK=3.072MHz, LRCK=48KHz, data sample length=16bit. but there is no any output of PCM5121, we suspect the setup code maybe wrong. Below is our code, could you help to check if it is ok? thanks.
W 98 00 00 #select page0
W 98 3B 66 #mute
W 98 3C 01 #right volume follow left settings
W 98 3D 4F #left digital volume
W 98 3E 4F #right digital volume(omit?)
W 98 3F BB # set vol changes for every 4 samples, 0.5 sample steps.
W 98 20 00 # R20 P=1
W 98 21 0x10 # R21 J=16
W 98 24 0x01 # R24,R=2
W 98 41 0x01 # R41, 1 bck offset.
W 98 13 0x10 # R13, selectt BCK
W 98 14 0x10 # R14, selectt PLL
W 98 27 0x02 # R27, set dsp clock
W 98 28 0x10 # R28, selectt dac clock
W 98 29 0x02 # R29, selectt ncp clock
W 98 30 0x08 # R30, selectt dosr clock
W 98 04 0x01 # R04, pll enable
best regards.
Wiky
