Hi Sirs,
As title
1. Could you help double confirm schematic again?
2. When connected to headphones in Windows 10 X64, as long as there is use of windows sound effects, such as windows keyboard, audio bar sound ... and so on. Except the original sound will be appeared, the background sound will appear noise as well. Moreover, the noise will continue for some time before it will end
Add windows sound effects +noise waveform
Could you share the experience for fix this noise?
By the way, our device no speaker.
Thanks!!
Hi, Shu-Cheng,
This is not an expected behavior for this device, the schematic seems to be working fine. Can you please provide more details about the issue? is the noise present in the headphone outputs?, where is the signal measured?. Is the issue replicable only with Windows 10?.
-Diego Meléndez López
Audio Applications Engineer
