Other Parts Discussed in Thread: TPA3116D2-Q1
Team,
For TPA3118D2-Q1, is a thermal model available for thermal simulation? If not, what is the recommended approach for accurate 3D thermal modeling with airflow?
Phil
Team,
Phil
Hi Adam - as we are waiting for the thermal models, could you please address my original question to TI support on the thermal modeling of the TPA3118D2-Q1 for a 3D airflow/thermal simulation?
I know the external geometry of the part, and I have modeled it as solid single-material case with a thermal pad on the bottom; pins are not modeled. All the heat load is applied to the thermal pad. Is there a more accurate approach to 3D thermal modeling the TPA3118D2-Q1?
Thank you,
Tomasz
Hi Tomasz,
Adam is out of office for travelling for now. He will get back to you soon later.
Shawn Zheng
Tomasz,
Here is the file.
/cfs-file/__key/communityserver-discussions-components-files/6/TPA3118D2_2D00_Q1_5F00_Delphi.pdml
-Adam
