WEBENCH® Tools/TAS5755MEVM: TAS5755MEVM
Part Number: TAS5755MEVM
Hi TI,
I am trying to get my TAS5755MEVM up and running.  The Purepath GDE fails on startup.  It gives me the following error:
Unable to create an instance of the process flow controller.
C:Program Files(x86)\Texas Instruments Inc\TAS57x1 GDE\ComponentCache\TAS570xAudioApp_TI_v1\PfcTAS570xAudioApp_TI_V1.dll not found
I have tried to search for this file on the TI website to replace it, but could not find it.  I tried to repair the installation with the GDESetup.msi file, but was unable to solve the problem that way.
I was looking for what version of GDE I am using, but the program closes before I can get any information from it.  I used the setup file version 8.0.50727.42
I have attached the error log to this post.  Please let me know how I can repair this program and work with the GDE.  Thank you
Marshall Kinnison
Error_Log.txt
Time: 3/28/2018 1:33:09 PM
Object reference not set to an instance of an object.
   at System.Environment.GetStackTrace(Exception e, Boolean needFileInfo)
   at System.Environment.get_StackTrace()
   at TexasInstruments.Gde.Gde.GdeUIExceptionHandler(Object sender, ThreadExceptionEventArgs e)
   at System.Windows.Forms.Application.ThreadContext.OnThreadException(Exception t)
   at System.Windows.Forms.Control.WndProcException(Exception e)
   at System.Windows.Forms.Control.ControlNativeWindow.OnThreadException(Exception e)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
   at System.Windows.Forms.NativeWindow.DefWndProc(Message& m)
   at System.Windows.Forms.NativeWindow.WndProc(Message& m)
   at Syncfusion.Windows.Forms.Tools.CommandBarController.AppMainFormWnd.WndProc(Message& m)
   at Syncfusion.Windows.Forms.Tools.XPMenus.MenuActivationControl.WndProc(Message& m)
   at Syncfusion.Windows.Forms.Tools.TabbedMDIManager.MdiParentNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.UnsafeNativeMethods.SendMessage(HandleRef hWnd, Int32 msg, Int32 wParam, Int32 lParam)
   at System.Windows.Forms.Form.SetVisibleCore(Boolean value)
   at System.Windows.Forms.Control.set_Visible(Boolean value)
   at System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(Int32 reason, ApplicationContext context)
   at System.Windows.Forms.Application.ThreadContext.RunMessageLoop(Int32 reason, ApplicationContext context)
   at System.Windows.Forms.Application.Run(Form mainForm)
   at TexasInstruments.Gde.SingleApplication.Run(Form frmMain, Arguments args)
   at TexasInstruments.Gde.Gde.Main()
Time: 3/28/2018 1:33:39 PM
Time: 3/28/2018 1:34:20 PM
Time: 3/28/2018 1:42:43 PM
