LM49270: LM49270: Mono sound
Part Number: LM49270
I would like to know. Can I set mono audio signal on LM49270? (on the right and left chanell at the same time)
  • Hi Anton,
    There is no internal signal routing/mux that can be configured for this device, so if you want to set the same output signal for both channels you would need to connect both inputs to the same source signal.
    -Ivan Salazar
    Applications Engineer - Low Power Audio & Actuators
